TMS320C5535: Accuracy of TIESR very bad when interfaced with Audio Pre-processing module
Part Number: TMS320C5535
Other Parts Discussed in Thread: TIDEP-0077
I have 2 C5535EZDSP boards.
  1. Board 1, I am using for TIESR Demo Application for detection of words- open door, lock , unlock, vent windows, etc, running at 16Khz.
  2. Board 2, I am using for Audio Pre-processing library for 16Khz.
The problem I am facing is when I interface these boards, I am expecting better noise reduction. Instead the speech recognition accuracy reduces drastically.
Without Pre-Processing board interfaced the recognition accuracy is very good.
I have interfaced these boards by connecting wires between L-R channels of Stereo OUT of Board 2 and Stereo IN of Board 1.
Please indicate what I can do to improve accuracy even with pre-processing module attached.
    I've notified the sw team. They will post their feedback directly here.
    Yordan
  • Hi Abhinandan,
    1. You mentioned in your post that you have a C5535EZDSP board running Audio Pre-processing Demo at 16Khz, but the TIDEP-0077 ( Audio Pre-processing Demo) is for C5517 EVM with LMB. How do you connect the LMB with the C5535EZDSP. Please let us know.
    2. As I recall, the TIESR demo is running at 8Khz. Have you made any changes to the TIESR demo? If yes, what are the changes.
    3. There is an incorrect audio codec (AIC3204) setting for the Audio Preprocessing Demo. It will cause the aduio codec output (Stereo OUT of Board 2) to be incorrect. It maybe the reason why the TIESR demo is not working properly. Send me the codec_aic3254.c to me, so that we can determine whether the audio codec setting is correct or not.
    4. You should use the Left channel of the Stereo OUT of Board 2 for TIESR demo, since it is the processed the audio. The Right channel is the bypass of the mic1.
    Ming
  • Hi Ming,
    1. The same demo works for C5535 . Also for Circular Mic Array they provide patch files which I am using.
    2. Yes I have made changes in TI ESR for 16khz.
    Refer:
    3.  PFA attached file as requested.
    e2e.ti.com/.../codec_5F00_aic3254.c
    4. I am currently using both Left and Right Channels.
    Also please tell if possible on c5535 or not? Please let me know if you require any other files?
  • Hi Abhinandan,
    The codec_aic3254.c file you shared has the old settings which will cause the incorrect audio DAC output. Please use the the attached file to replace the one you are using.
     * Copyright (c) 2008-2017 Texas Instruments Incorporated.
     *  Redistribution and use in source and binary forms, with or without
     *  modification, are permitted provided that the following conditions
     *  are met:
     *    Redistributions of source code must retain the above copyright
     *    Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the
     *    distribution.
     *    Neither the name of Texas Instruments Incorporated nor the names of
     *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
     *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
     *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
     *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
     *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
     *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
     *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
     *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
     *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
     *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
     *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     *  \file   codec_aic3254.c
     *  \brief  codec configuration function
     *   This file contains the APIs for codec(AIC3254) read and write using I2C
     *  (C) Copyright 2005, Texas Instruments, Inc
     *  \author     PR Mistral
     *  \version    1.0
    #include "stdio.h"
    #include "stdlib.h"
    #include "codec_aic3254.h"
    #include "codec_pcm186x.h"
    #include "sample_rate.h"
    #define ENABLE_RECORD
    #define I2C_OWN_ADDR            (0x2F)
    #define I2C_CODEC_ADDR          (0x18)
    #define I2C_EEPROM_ADDR         (0x50)
    #define I2C_BUS_FREQ            (400)   // I2C 400Khz
    extern int pll_mhz;
    extern pI2cHandle i2cHandle;
    pI2cHandle    hi2c = NULL;
     * Mute control for codec output
     * TRUE = Mute codec output
     * FALSE = UnMute codec output
    Bool Set_Mute_State(Bool flag)
        CSL_Status    result = CSL_SOK;
        Bool retval;
        retval = TRUE;
        // write 0 to page register to select page 0
        result = AIC3254_Write(0, 0, hi2c);
        if (result != CSL_SOK)
            retval = FALSE;
        else
            if (flag == TRUE)
                //mute output
                result = AIC3254_Write(64,0xd,hi2c);
                    retval = FALSE;
            else
                //unmute output
                result = AIC3254_Write(64,0x1,hi2c);
                    retval = FALSE;
    #if 1
        // write 1 to page register to select page 1 - prepare for next headset volume change
        result = AIC3254_Write(0, 1, hi2c);
            retval = FALSE;
    #endif
        return retval;
    #define HEADPHONE_DRIVER_GAIN_MUTE_ENABLE  0x40    // bit6 =1 mute headphone driver
    #define VOLUME_STEP_SIZE                   256
    #define VOLUME_TABLE_MAX_GAIN_INDEX        29      // headphone gain setting = 29 -> 29 dB gain
    #define VOLUME_TABLE_MAX_ATTNEUATION_INDEX 35      // headphone gain setting = 0x3A -> -6dB gain
    #define USB_MAX_ATTENUATION_VALUE          -32768
    #define VOLUME_TABLE_MUTE_HEADPHONE_INDEX  36      // headphone gain setting = 0x7B set gain to -5dB with headphone driver muted
    // table has both gain and attenuation settings for headphone output of the codec.
    // 0 : no gain/no attenuation, gain : 1 - 29, attenuation : 0x3F - 0x3A, muted: 0x7B
    const Uint16 volume_table[] =  {
        0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,
        0x3F,0x3E,0x3D,0x3C,0x3B,0x3A,(0x3B | HEADPHONE_DRIVER_GAIN_MUTE_ENABLE)
     * Change gain setting of headphone output of codec
     * volume = gain setting received from USB
     * channel = 0:left channel, =1 right channel
    Bool Adjust_Volume(Int16 volume, Uint16 channel)
        Uint16        gain;
        // goto max attentuation
        if (volume == USB_MAX_ATTENUATION_VALUE)
            // the max attenuation for the headpphone  is -6dB so we will mute the headphone driver
            // and set the codec gain to the lowest value(-5dB) that allows the headphone driver
            // to be muted. any volume change other than the max attenuation will turn off the
            // headphone driver mute
            gain = VOLUME_TABLE_MUTE_HEADPHONE_INDEX;
        else if (volume >= 0)
            // determine gain index
            gain = volume/VOLUME_STEP_SIZE;
            // check range
            if(gain > VOLUME_TABLE_MAX_GAIN_INDEX)
                // set to max gain
                gain = VOLUME_TABLE_MAX_GAIN_INDEX;
        else
            // determine attenuation index
            gain = (-volume)/VOLUME_STEP_SIZE;
            if (gain !=0)
                //index from start of attentuation values in table
                gain += VOLUME_TABLE_MAX_GAIN_INDEX;
                if (gain > VOLUME_TABLE_MAX_ATTNEUATION_INDEX)
                    // set to max attenuation
                    gain = VOLUME_TABLE_MAX_ATTNEUATION_INDEX;
        if (channel == 0)
            //adjust volume setting of left headphone
            result = AIC3254_Write(0x10,volume_table[gain],hi2c);
                return result;
        else
            //adjust volume setting of right headphone
            result = AIC3254_Write(0x11,volume_table[gain],hi2c);
                return result;
        return TRUE;
    #define I2S2_SRGR          *(volatile ioport Uint16*)(0x2A04)
    #define I2S2_ICMR          *(volatile ioport Uint16*)(0x2A14)
    #define I2S2_CR            *(volatile ioport Uint16*)(0x2A00)
    #define I2S3_SRGR          *(volatile ioport Uint16*)(0x2B04)
    #define I2S3_ICMR          *(volatile ioport Uint16*)(0x2B14)
    #define I2S3_CR            *(volatile ioport Uint16*)(0x2B00)
    CSL_I2cSetup     i2cSetup;
    CSL_Status AIC3254_init(
        Uint16 sampRatePb,
        Uint16 sampRateRec,
        Uint32 i2cInClk)
        volatile Uint32 looper;
        /* Reset AIC3254 */
        /* NOTE: Assumes EBSR and GPIO are set correctly before function is called */
    #if (defined(CHIP_C5517))
        CSL_GPIO_REGS->IODATAOUT1 = 0x0000; /* reset active low */
    #else
        CSL_GPIO_REGS->IOOUTDATA1 = 0x0000; /* reset active low */
    #endif
        for(looper=0; looper<1000; looper++ )
            asm("    nop");
        CSL_GPIO_REGS->IODATAOUT1 = 0x0400;
    #else
        CSL_GPIO_REGS->IOOUTDATA1 = 0x0400;
    #endif
        // I2C hardware initialization
        result = I2C_init(CSL_I2C0);
        if (result!=CSL_SOK)
            return result;
        // I2C setup
        i2cSetup.addrMode    = CSL_I2C_ADDR_7BIT;
        i2cSetup.bitCount    = CSL_I2C_BC_8BITS;
        i2cSetup.loopBack    = CSL_I2C_LOOPBACK_DISABLE;
        i2cSetup.freeMode    = CSL_I2C_FREEMODE_ENABLE;//CSL_I2C_FREEMODE_DISABLE;
        i2cSetup.repeatMode  = CSL_I2C_REPEATMODE_DISABLE;
        i2cSetup.ownAddr     = I2C_OWN_ADDR;
        i2cSetup.sysInputClk = i2cInClk;
        i2cSetup.i2cBusFreq  = I2C_BUS_FREQ;
        result = I2C_setup(&i2cSetup);
        if(result != CSL_SOK)
            return (result);
        // validate the I2c handle
        hi2c = i2cHandle;
     *   Configure AIC3204                                                      *
     *      CODEC_CLKIN = PLL CLK = 64Mhz                                               *
     *      CODEC_CLKIN = NADC * MADC * AOSR * ADCFS                            *
     *      PLL_CLK     = PLL_CLKIN * R * J.D / P = 64Mhz                       *
     *      PLL_CLKIN   = BCLK = 1MHz                                       *
     *      ADCFS       = 16KHz                                                 *
     *      NDAC = MADC = 8                                                     *
     *      MDAC = MADC = 2                                                     *
     *      DOSR = ASOR = 256                                                    *
     *      J = 32                                                               *
     *      D = 0                                                               *
     *      P = 1                                                               *
     *      R = 2                                                               *
        result = AIC3254_Write(  0, 0x00, hi2c );      // Select page 0
            return result;
        result = AIC3254_Write(  1, 0x01, hi2c );      // Reset codec
            return result;
        result = AIC3254_Write(  0, 0x01, hi2c );      // Select page 1
            return result;
        result = AIC3254_Write(  1, 0x08, hi2c );      // Disable crude AVDD generation from DVDD
            return result;
    #ifdef C5535_EZDSP
        result = AIC3254_Write(  2, 0x01, hi2c );      // Disable Analog Blocks
            return result;
    #else
        result = AIC3254_Write(  2, 0x00, hi2c );      // Enable Analog Blocks
            return result;
    #endif
        // PLL and Clocks config and Power Up
            return result;
    #ifdef USE_32BIT_SAMPLE
        result = AIC3254_Write( 27, 0x30, hi2c );      // BCLK and WCLK is set as i/p to AIC3204(Slave), 32 bit per sample
    #else
        result = AIC3254_Write( 27, 0x00, hi2c );      // BCLK and WCLK is set as i/p to AIC3204(Slave), 16 bit per sample
    #endif
            return result;
        result = AIC3254_Write(  4, 0x07, hi2c );      // PLL setting: PLLCLK <- BCLK and CODEC_CLKIN <-PLL CLK
        //result = AIC3254_Write(  4, 0x03, hi2c );      // PLL setting: PLLCLK <- BCLK and CODEC_CLKIN <-PLL CLK
            return result;
        result = AIC3254_Write(  6, 0x20, hi2c );      // PLL setting: J = 32
            return result;
        result = AIC3254_Write(  7, 0, hi2c );         // PLL setting: HI_BYTE(D)
            return result;
        result = AIC3254_Write(  8, 0, hi2c );         // PLL setting: LO_BYTE(D)
            return result;
        // For 16 KHz sampling
        result = AIC3254_Write(  5, 0x92, hi2c );      // PLL setting: Power up PLL, P=1 and R=2
            return result;
        result = AIC3254_Write( 13, 0x01, hi2c );      // Hi_Byte(DOSR) for DOSR = 256 decimal or 0x0100 DAC oversamppling
            return result;
        result = AIC3254_Write( 14, 0x00, hi2c );      // Lo_Byte(DOSR) for DOSR = 256 decimal or 0x0100
            return result;
        result = AIC3254_Write( 20, 0x00, hi2c );      // AOSR for AOSR = 256 decimal or 0x0100 for decimation filters 1 to 6
            return result;
        result = AIC3254_Write( 11, 0x88, hi2c );      // Power up NDAC and set NDAC value to 8
            return result;
        result = AIC3254_Write( 12, 0x82, hi2c );      // Power up MDAC and set MDAC value to 2
            return result;
        result = AIC3254_Write( 18, 0x88, hi2c );      // Power up NADC and set NADC value to 8
            return result;
        result = AIC3254_Write( 19, 0x82, hi2c );      // Power up MADC and set MADC value to 2
            return result;
        // DAC ROUTING and Power Up
            return result;
        //result = AIC3254_Write( 20, 0x25, hi2c );      // LDAC AFIR routed to HPL
            return result;
        //result = AIC3254_Write( 10, 0x00, hi2c );      // RDAC AFIR routed to HPR
            return result;
        //result = AIC3254_Write( 3, 0x08, hi2c );      // Power up NADC and set NADC value to 4
            return result;
        //result = AIC3254_Write( 4, 0x08, hi2c );      // Power up MADC and set MADC value to 2
            return result;
        result = AIC3254_Write( 12, 0x08, hi2c );      // LDAC AFIR routed to HPL
            return result;
        result = AIC3254_Write( 13, 0x08, hi2c );      // RDAC AFIR routed to HPR
            return result;
        //result = AIC3254_Write( 14, 0x08, hi2c );      // LDAC AFIR routed to HPL
        //result = AIC3254_Write( 14, 0x00, hi2c );      // LDAC AFIR routed to HPL
            return result;
        //result = AIC3254_Write( 15, 0x08, hi2c );      // RDAC AFIR routed to HPR
        //result = AIC3254_Write( 15, 0x00, hi2c );      // RDAC AFIR routed to HPR
            return result;
            return result;
        //result = AIC3254_Write( 60, 0x07, hi2c );      // Left vol=right vol
            return result;
        result = AIC3254_Write( 64, 0x02, hi2c );      // Left vol=right vol
            return result;
        //result = AIC3254_Write( 65, 0x2F, hi2c );      // Left DAC gain to 0dB VOL; Right tracks Left
        result = AIC3254_Write( 65, 0x00, hi2c );      // Left DAC gain to 0dB VOL; Right tracks Left
            return result;
        //result = AIC3254_Write( 66, 0x2F, hi2c );      // Left DAC gain to 0dB VOL; Right tracks Left
        result = AIC3254_Write( 66, 0x00, hi2c );      // Left DAC gain to 0dB VOL; Right tracks Left
            return result;
        result = AIC3254_Write( 63, 0xd4, hi2c );      // Power up left,right data paths and set channel
            return result;
            return result;
        //result = AIC3254_Write( 16, 0x00, hi2c );      // Unmute HPL , 0dB gain
        result = AIC3254_Write( 16, 0x06, hi2c );      // Unmute HPL , 6dB gain
            return result;
        //result = AIC3254_Write( 17, 0x00, hi2c );      // Unmute HPR , 0dB gain
        result = AIC3254_Write( 17, 0x06, hi2c );      // Unmute HPR , 6dB gain
            return result;
        result = AIC3254_Write(  9, 0x30, hi2c );      // Power up HPL,HPR
            return result;
            return result;
        for (looper = 0; looper < 500; looper++)
            ; // Wait
        // ADC ROUTING and Power Up
            return result;
        result = AIC3254_Write( 52, 0x30, hi2c );      // STEREO 1 Jack
            return result;
                                       // IN2_L to LADC_P through 40 kohm
        result = AIC3254_Write( 55, 0x30, hi2c );      // IN2_R to RADC_P through 40 kohmm
            return result;
        result = AIC3254_Write( 54, 0x03, hi2c );      // CM_1 (common mode) to LADC_M through 40 kohm
            return result;
        result = AIC3254_Write( 57, 0xC0, hi2c );      // CM_1 (common mode) to RADC_M through 40 kohm
            return result;
        result = AIC3254_Write( 59, 0x0f, hi2c );      // MIC_PGA_L unmute
            return result;
        result = AIC3254_Write( 60, 0x0f, hi2c );      // MIC_PGA_R unmute
            return result;
            return result;
        result = AIC3254_Write( 81, 0xc0, hi2c );      // Powerup Left and Right ADC
            return result;
        result = AIC3254_Write( 82, 0x00, hi2c );      // Unmute Left and Right ADC
            return result;
            return result;
        //result = AIC3254_Write( 61,  0x02, hi2c );
            return result;
        for (looper = 0; looper < 200; looper++)
            ; // Wait
    #if 0
        printf("\nPage1\n");
        AIC3254_Write(0,0x1,hi2c);
        AIC3254_Read(1,&data,hi2c);
        printf("\n0x%x\n",data);
        AIC3254_Read(2,&data,hi2c);
        printf("\nPage0\n");
        AIC3254_Write(0,0x0,hi2c);
        AIC3254_Read(27,&data,hi2c);
        AIC3254_Read(4,&data,hi2c);
        AIC3254_Read(6,&data,hi2c);
        AIC3254_Read(7,&data,hi2c);
        AIC3254_Read(8,&data,hi2c);
        AIC3254_Read(5,&data,hi2c);
        AIC3254_Read(13,&data,hi2c);
        AIC3254_Read(14,&data,hi2c);
        AIC3254_Read(20,&data,hi2c);
        AIC3254_Read(11,&data,hi2c);
        AIC3254_Read(12,&data,hi2c);
        AIC3254_Read(18,&data,hi2c);
        AIC3254_Read(19,&data,hi2c);
        AIC3254_Read(64,&data,hi2c);
        AIC3254_Read(65,&data,hi2c);
        AIC3254_Read(63,&data,hi2c);
        AIC3254_Read(16,&data,hi2c);
        AIC3254_Read(17,&data,hi2c);
        AIC3254_Read(9,&data,hi2c);
        AIC3254_Read(52,&data,hi2c);
        AIC3254_Read(55,&data,hi2c);
        AIC3254_Read(54,&data,hi2c);
        AIC3254_Read(57,&data,hi2c);
        AIC3254_Read(59,&data,hi2c);
        AIC3254_Read(60,&data,hi2c);
        AIC3254_Read(81,&data,hi2c);
        AIC3254_Read(82,&data,hi2c);
    #endif
        return result;
     *  \brief Codec write function
     *  Function to write a byte of data to a codec register.
     *  \param regAddr  [IN]  Address of the register to write the data
     *  \param regData  [IN]  Data to write into the register
     *  \return CSL_SOK - if successful, else suitable error code
    CSL_Status AIC3254_Write(Uint16 regAddr, Uint16 regData, pI2cHandle hi2c)
        CSL_Status    status;
        Uint16        writeCount;
        volatile Uint16 looper;
        Uint16        writeBuff[2];
        Uint16        readBuff[2];
        Uint16 startStop = ((CSL_I2C_START) | (CSL_I2C_STOP));
        status = CSL_ESYS_INVPARAMS;
        if(hi2c != NULL)
            writeCount  =  2;
            /* Initialize the buffer          */
            /* First byte is Register Address */
            /* Second byte is register data   */
            writeBuff[0] = (regAddr & 0x00FF);
            writeBuff[1] = (regData & 0x00FF);
            /* Write the data */
            status = I2C_write(writeBuff,
                            writeCount,
                            I2C_CODEC_ADDR,
                            TRUE,
                            startStop,
                            CSL_I2C_MAX_TIMEOUT);
            if (status!=CSL_SOK)
                return status;
            /* Give some delay */
            for(looper = 0; looper < CSL_I2C_MAX_TIMEOUT; looper++){;}
    #if 1
            // read the data
            status = I2C_read(readBuff,
                            1,
                            I2C_CODEC_ADDR,
                            &regAddr,
                            1,
                            TRUE,
                            startStop,
                            CSL_I2C_MAX_TIMEOUT,
                            FALSE);
                return status;
            if ((readBuff[0]!=writeBuff[1])&&(regAddr>=2))
                status |= (-1);
    #endif
        return status;
    CSL_Status AIC3254_Write_Two(Uint16 regAddr1, Uint16 regData1, Uint16 regAddr2, Uint16 regData2, pI2cHandle hi2c)
        CSL_Status    status;
        Uint16        writeCount;
        Uint16        writeBuff1[2];
        Uint16        writeBuff2[2];
        Uint16        readBuff1[2];
        Uint16        readBuff2[2];
        if(hi2c != NULL)
            writeCount  =  2;
            writeBuff1[0] = (regAddr1 & 0x00FF);
            writeBuff1[1] = (regData1 & 0x00FF);
            status = I2C_write(writeBuff1,
                            writeCount,
                            I2C_CODEC_ADDR,
                            TRUE,
                            startStop,
                return status;
            writeBuff2[0] = (regAddr2 & 0x00FF);
            writeBuff2[1] = (regData2 & 0x00FF);
            status |= I2C_write(writeBuff2,
                            writeCount,
                            I2C_CODEC_ADDR,
                            TRUE,
                            startStop,
                return status;
    #if 1
            // read the data
            status = I2C_read(readBuff1,
                            1,
                            I2C_CODEC_ADDR,
                            &regAddr1,
                            1,
                            TRUE,
                            startStop,
                            FALSE);
                return status;
            if ((readBuff1[0]!=writeBuff1[1])&&(regAddr1>=2))
                status |= (-1);
            // read the data
            status = I2C_read(readBuff2,
                            1,
                            I2C_CODEC_ADDR,
                            &regAddr2,
                            1,
                            TRUE,
                            startStop,
                            FALSE);
                return status;
            if ((readBuff2[0]!=writeBuff2[1])&&(regAddr2>=2))
                status |= (-1);
    #endif
        return status;
     *  \brief Codec read function
     *  Function to read a byte of data from a codec register.
     *  \param regAddr  [IN]  Address of the register to read the data
     *  \param data     [IN]  Pointer to the data read from codec register
    CSL_Status AIC3254_Read(Uint16 regAddr, Uint16 *data, pI2cHandle  hi2c)
        CSL_Status status  = CSL_ESYS_INVPARAMS;
        Uint16 readCount = 1;
        Uint16 readBuff[1];
        regAddr = (regAddr & 0x00FF);
        if(hi2c)
            // read the data
                            readCount,
                            I2C_CODEC_ADDR,
                            &regAddr,
                            1,
                            TRUE,
                            startStop,
                            FALSE);
                return status;
            *data = readBuff[0];
            return status;
        } else
            // illegal I2C handle
            return CSL_ESYS_BADHANDLE;
    CSL_Status EEPROM_Write(Uint16 regAddr, Uint16 regData, pI2cHandle hi2c)
        CSL_Status    status;
        Uint16        writeCount;
        Uint16        writeBuff[4];
        Uint16        readBuff[4];
        if(hi2c != NULL)
            writeCount  =  4;
            /* First two bytes are Register Address */
            /* Second two bytes are register data   */
            writeBuff[1] = ((regAddr>>8) & 0x00FF);
            writeBuff[2] = (regData & 0x00FF);
            writeBuff[3] = ((regData>>8) & 0x00FF);
            readBuff[0] = (regAddr & 0x00FF);
            readBuff[1] = ((regAddr>>8) & 0x00FF);
            readBuff[2] = 0;
            readBuff[3] = 0;
                            writeCount,
                            I2C_EEPROM_ADDR,
                            TRUE,
                            startStop,
                return status;
            // read the data
            status = I2C_read(&readBuff[2],
                            2,
                            I2C_EEPROM_ADDR,
                            &readBuff[0],
                            1,
                            TRUE,
                            startStop,
                            FALSE);
                return status;
            if ((readBuff[2]!=writeBuff[2])||(readBuff[3]!=writeBuff[3]))
                status |= (-1);
        return status;
  • Hi Ming,
    Thanks for that.
    What about AudioCodec_DMA.c file? Any changes needs to done here?
    Kindly let me know.
  • Hi Abhinandan,
    No changes needed for AudioCodec_DMA.c.
    Ming
  • Hi Ming,
    Thanks for that. The project got compiled successfully. But I dont hear any output sound, maybe its because of the PIN connections. I am using the expansion slot for this.
    I tried to follow the connections here: processors.wiki.ti.com/.../C55x_CSL_Audio_Pre-Processing
    But its confusing since its given for C5517.
    Please give the PIN connections for C5535EZDSP.
    Update:
    I2S_INSTANCE3 is being used in AudioCodec_DMA.c file.It is not valid for C5535 right? Since the link mentions 4 Mic can be connected, I got this doubt.
  • Hi Ming,
    Please reply.
  • Hi Ming,
    Here's Methods I tried:
    1. Connected wires as per the link for Audio Pre-processing.
       Audio output from Pre-processing module is there only in Right channel. In left channel I hear Gaussian noise, not even the input audio.
    2. I changed the I2S3 to I2S1 config and tried again. This time I am getting processed audio from both channels. But the left channel has low amplitude.
       I tried this setup with TIESR. The detection was good, but not better than when tried with TIESR module alone. For this setup, I used
       "WakeGram ---> ( Phrase ) | _Fill." in my build_files.sh file, since "WakeGram ---> ( [_Fill] Phrase [_Fill] ) | _Fill." doesnt work and keeps showing "_Fill" always.
    Problems faced in Method 2:
    1. False detections: I have words like "vent windows" and "open door". Without the Pre-processing module, saying "vent door" actually shows "_Fill", which is correct. But when I connect pre-processing module and do the same, it shows "vent windows". This happens only with pre-processing module interfaced. Instead of removing noise, its kind of adding noise. I do not know the reason for this.
    Kindly let me know what I can do to improve this.
