Part Number: TDA3XEVM
Tool/software: TI-RTOS
Hi Team,
we are facing some video stuck/crash issue in TDA3xx board. when issue happened at that time we are not able to see any video frame changes in Display.
I am using OV10640 camera sensor, serializer UB913, Deserializer UB960 with TDA3xx board. we are displaying stitched video over 24bit RGB parallel interface. we are running Rear view Panorama usecase.
Sometimes the video get stuck over display. when video got stuck/stop at that time IPC communication stop and some thread become free in DSP and EVE core. Please see the attached statistics logs(log when normal video running and video got stuck).
we are suspecting as a board temperature issue(Thermal issue). So we try to run setup in different ambient temperature use case. many times we are getting issue within 10 minutes. but same setup with same temperature running for more than 3 hours also. If issue started then frequency of getting issue increase with in 3 minute.
we are also thinking like it was some kind of interrupt subroutine running on the TDA3X firmware or self protection happening inside the CPU core. We are also suspecting like it was some kind of clock and PLL lock changes happened in the processor.
please help on the root cause of issue and how can i solve this problem.
[IPU1-0] Enter Choice: [IPU1-0] [IPU1-0] 688.595010 s: [IPU1-0] 688.595101 s: UTILS_PRCM_STATS: Current Temperature, [IPU1-0] 688.595162 s: [IPU1-0] 688.595223 s: Voltage Rail || Curr Temp Min - Max [IPU1-0] 688.595284 s: --------------------------------------------------------- [IPU1-0] 688.595498 s: PMHAL_PRCM_VD_CORE || [48.800 , 49.200] [IPU1-0] 688.595620 s: [IPU1-0] 688.595650 s: UTILS_TEMP: Voltage Domain [ PMHAL_PRCM_VD_CORE ] HOT Threshold = [0.0] [IPU1-0] 688.595833 s: UTILS_TEMP: Voltage Domain [ PMHAL_PRCM_VD_CORE ] COLD Threshold = [0.0] [IPU1-0] 688.604953 s: [IPU1-0] [IPU1-0] ==================== [IPU1-0] Chains Run-time Menu [IPU1-0] ==================== [IPU1-0] [IPU1-0] 0: Stop Chain [IPU1-0] [IPU1-0] 1: Change Display Channel (Support 4CH LVDS + Mosaic use-case only) [IPU1-0] [IPU1-0] p: Print Performance Statistics [IPU1-0] [IPU1-0] t: Test Case for TEMPERATURE SENSOR TMP102 [IPU1-0] [IPU1-0] a: Test Case for AMBIENT LIGHT SENSOR [IPU1-0] [IPU1-0] g: Test Case for GPIO SWITCH [IPU1-0] [IPU1-0] n: Thermal Tests [IPU1-0] [IPU1-0] Enter Choice: [IPU1-0] [IPU1-0] 691.627798 s: [IPU1-0] 691.627859 s: CPU [IPU1-0 ] Statistics, [IPU1-0] 691.627920 s: ************************* [IPU1-0] 691.627981 s: [IPU1-0] 691.628042 s: LOAD: CPU: 24.4% HWI: 3.4%, SWI:1.0%, Low Power: 72.0% [IPU1-0] 691.628164 s: [IPU1-0] 691.628225 s: LOAD: TSK: DUP0 : 0.3% [IPU1-0] 691.628316 s: LOAD: TSK: IPC_IN_0 : 0.1% [IPU1-0] 691.628408 s: LOAD: TSK: IPC_IN_1 : 0.1% [IPU1-0] 691.628499 s: LOAD: TSK: IPC_OUT_0 : 0.1% [IPU1-0] 691.628591 s: LOAD: TSK: IPC_OUT_1 : 0.3% [IPU1-0] 691.628682 s: LOAD: TSK: IPC_OUT_2 : 0.1% [IPU1-0] 691.628774 s: LOAD: TSK: IPC_OUT_3 : 0.1% [IPU1-0] 691.628896 s: LOAD: TSK: MERGE0 : 0.1% [IPU1-0] 691.628987 s: LOAD: TSK: SELECT0 : 0.1% [IPU1-0] 691.629079 s: LOAD: TSK: SELECT1 : 0.1% [IPU1-0] 691.629170 s: LOAD: TSK: SELECT2 : 0.1% [IPU1-0] 691.629262 s: LOAD: TSK: SELECT3 : 0.1% [IPU1-0] 691.629353 s: LOAD: TSK: SYNC0 : 0.4% [IPU1-0] 691.629445 s: LOAD: TSK: SYNC1 : 0.3% [IPU1-0] 691.629506 s: LOAD: TSK: DISPLAY0 : 0.1% [IPU1-0] 691.629628 s: LOAD: TSK: ISSCAPTURE : 0.4% [IPU1-0] 691.629720 s: LOAD: TSK: ISSM2MISP : 3.7% [IPU1-0] 691.629933 s: LOAD: TSK: ALGORITHM0 : 0.4% [IPU1-0] 691.630025 s: LOAD: TSK: ALGORITHM1 : 0.7% [IPU1-0] 691.630116 s: LOAD: TSK: ALGORITHM2 : 7.9% [IPU1-0] 691.630238 s: LOAD: TSK: GrpxSrc0 : 0.3% [IPU1-0] 691.630330 s: LOAD: TSK: STAT_COLL : 1.9% [IPU1-0] 691.630421 s: LOAD: TSK: MISC : 2.3% [IPU1-0] 691.630482 s: [IPU1-0] 691.630543 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022 [IPU1-0] 691.630604 s: [IPU1-0] 691.630665 s: SYSTEM: Sempahores Objects, 69 of 1000 free [IPU1-0] 691.630726 s: SYSTEM: Task Objects , 14 of 100 free [IPU1-0] 691.630848 s: SYSTEM: Clock Objects , 91 of 100 free [IPU1-0] 691.630940 s: SYSTEM: Hwi Objects , 87 of 100 free [IPU1-0] 691.631031 s: [IPU1-0] 691.631062 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 140960 B (137 KB) [IPU1-0] 691.631214 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB) [IPU1-0] 691.631367 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x85703000, Total size = 369086464 B (351 MB), Free size = 159840256 B (152 MB) [IPU1-0] 691.631550 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xbfc00000, Total size = 1046784 B (0 MB), Free size = 1039104 B (0 MB) [IPU1-0] 691.631702 s: [IPU1-0] 691.631733 s: [IPU1-0] 691.632495 s: CPU [IPU1-1 ] Statistics, [IPU1-0] 691.632587 s: ************************* [IPU1-0] 691.632648 s: [IPU1-0] 691.632709 s: LOAD: CPU: 1.2% HWI: 0.6%, SWI:0.3%, Low Power: 72.3% [IPU1-0] 691.632922 s: [IPU1-0] 691.633014 s: LOAD: TSK: MISC : 0.3% [IPU1-0] 691.633105 s: [IPU1-0] 691.633136 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022 [IPU1-0] 691.633227 s: [IPU1-0] 691.633288 s: SYSTEM: Sempahores Objects, 407 of 1000 free [IPU1-0] 691.633349 s: SYSTEM: Task Objects , 40 of 100 free [IPU1-0] 691.633441 s: SYSTEM: Clock Objects , 99 of 100 free [IPU1-0] 691.633532 s: SYSTEM: Hwi Objects , 99 of 100 free [IPU1-0] 691.633624 s: [IPU1-0] 691.633654 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 255168 B (249 KB) [IPU1-0] 691.633837 s: [IPU1-0] 691.633898 s: [IPU1-0] 691.633929 s: CPU [DSP1 ] Statistics, [IPU1-0] 691.633990 s: ************************* [IPU1-0] 691.634051 s: [IPU1-0] 691.634081 s: LOAD: CPU: 26.8% HWI: 0.2%, SWI:0.1%, Low Power: 72.7% [IPU1-0] 691.634234 s: [IPU1-0] 691.634295 s: LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 26.3% [IPU1-0] 691.634386 s: LOAD: TSK: MISC : 0.2% [IPU1-0] 691.634478 s: [IPU1-0] 691.634508 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022 [IPU1-0] 691.634600 s: [IPU1-0] 691.634630 s: SYSTEM: Sempahores Objects, 410 of 1000 free [IPU1-0] 691.635088 s: SYSTEM: Task Objects , 92 of 100 free [IPU1-0] 691.635210 s: SYSTEM: Clock Objects , 98 of 100 free [IPU1-0] 691.635301 s: SYSTEM: Hwi Objects , 100 of 100 free [IPU1-0] 691.635393 s: [IPU1-0] 691.635423 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 201984 B (197 KB) [IPU1-0] 691.635606 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 511704 B (499 KB) [IPU1-0] 691.635789 s: [IPU1-0] 691.635850 s: [IPU1-0] 691.635881 s: CPU [DSP2 ] Statistics, [IPU1-0] 691.635942 s: ************************* [IPU1-0] 691.636003 s: [IPU1-0] 691.636033 s: LOAD: CPU: 10.1% HWI: 0.1%, SWI:0.1%, Low Power: 89.2% [IPU1-0] 691.636186 s: [IPU1-0] 691.636247 s: LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 9.7% [IPU1-0] 691.636338 s: LOAD: TSK: MISC : 0.2% [IPU1-0] 691.636430 s: [IPU1-0] 691.636460 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022 [IPU1-0] 691.636552 s: [IPU1-0] 691.636613 s: SYSTEM: Sempahores Objects, 409 of 1000 free [IPU1-0] 691.636704 s: SYSTEM: Task Objects , 92 of 100 free [IPU1-0] 691.636796 s: SYSTEM: Clock Objects , 98 of 100 free [IPU1-0] 691.636887 s: SYSTEM: Hwi Objects , 100 of 100 free [IPU1-0] 691.636979 s: [IPU1-0] 691.637009 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 27264 B (26 KB) [IPU1-0] 691.637162 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 519408 B (507 KB) [IPU1-0] 691.637589 s: [IPU1-0] 691.637650 s: [IPU1-0] 691.637680 s: CPU [EVE1 ] Statistics, [IPU1-0] 691.637741 s: ************************* [IPU1-0] 691.637833 s: [IPU1-0] 691.637894 s: LOAD: CPU: 22.5% HWI: 0.3%, SWI:0.2%, Low Power: 73.2% [IPU1-0] 691.638016 s: [IPU1-0] 691.638077 s: LOAD: TSK: SYSTEM : 0.2% [IPU1-0] 691.638168 s: LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 21.5% [IPU1-0] 691.638260 s: LOAD: TSK: MISC : 0.3% [IPU1-0] 691.638351 s: [IPU1-0] 691.638382 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022 [IPU1-0] 691.638473 s: [IPU1-0] 691.638504 s: SYSTEM: Sempahores Objects, 411 of 1000 free [IPU1-0] 691.638595 s: SYSTEM: Task Objects , 93 of 100 free [IPU1-0] 691.638687 s: SYSTEM: Clock Objects , 98 of 100 free [IPU1-0] 691.638778 s: SYSTEM: Hwi Objects , 99 of 100 free [IPU1-0] 691.638870 s: [IPU1-0] 691.638900 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 17632 B (17 KB) [IPU1-0] 691.639053 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 245456 B (239 KB) [IPU1-0] 691.639236 s: [IPU1-0] 691.639541 s: [IPU1-0] 691.639602 s: UTILS_PRCM_STATS: Current Temperature, [IPU1-0] 691.639663 s: [IPU1-0] 691.639724 s: Voltage Rail || Curr Temp Min - Max [IPU1-0] 691.640181 s: --------------------------------------------------------- [IPU1-0] 691.640303 s: PMHAL_PRCM_VD_CORE || [48.800 , 49.200] [IPU1-0] 691.640395 s: [IPU1-0] 692.638961 s: [IPU1-0] 692.639053 s: Statistics Collector, [IPU1-0] 692.639114 s: [IPU1-0] 692.639144 s: STATISTIC Avg Data Peak Data [IPU1-0] 692.639236 s: COLLECTOR MB/s MB/s [IPU1-0] 692.639297 s: -------------------------------------------------- [IPU1-0] 692.639388 s: SCI_EMIF_SYS | 1009.841295 2268.656382 [IPU1-0] 692.639510 s: SCI_IPU | 17.072800 55.127962 [IPU1-0] 692.639632 s: SCI_DSP1_MDMA | 20.616044 289.321999 [IPU1-0] 692.639724 s: SCI_DSP2_MDMA | 27.549428 442.799680 [IPU1-0] 692.640029 s: SCI_DSS | 211.085436 350.818931 [IPU1-0] 692.640120 s: SCI_MMU | 0.000000 0.000000 [IPU1-0] 692.640242 s: SCI_EDMA_TC0_RD | 0.000000 0.000000 [IPU1-0] 692.640334 s: SCI_EDMA_TC0_WR | 0.000000 0.000000 [IPU1-0] 692.640425 s: SCI_VIP_P1 | 0.000000 0.000000 [IPU1-0] 692.640517 s: SCI_VIP_P2 | 0.000000 0.000000 [IPU1-0] 692.640639 s: SCI_ISS_RT | 220.927227 339.067390 [IPU1-0] 692.640730 s: SCI_ISS_NRT2 | 109.719583 1144.927241 [IPU1-0] 692.640974 s: SCI_EVE_P1 | 60.649632 333.910886 [IPU1-0] 692.642987 s: SCI_EVE_P2 | 61.518955 505.613027 [IPU1-0] 692.643140 s: SCI_GMAC_SW | 0.000000 0.000000 [IPU1-0] 692.643262 s: SCI_ISS_NRT1 | 187.759246 692.467555 [IPU1-0] 692.643353 s: SCI_DSP2_CFG | 0.000000 0.000000 [IPU1-0] 692.643475 s: SCI_DSP2_EDMA | 40.660706 887.532786 [IPU1-0] 692.643902 s: SCI_OCMC_RAM | 0.000000 0.000000 [IPU1-0] 692.644024 s: SCI_DSP1_CFG | 0.000000 0.000000 [IPU1-0] 692.644116 s: SCI_DSP1_EDMA | 54.449027 378.412391 [IPU1-0] 692.644238 s: SCI_GPMC | 0.000000 0.000000 [IPU1-0] 692.644329 s: SCI_MCASP | 0.000000 0.000000 [IPU1-0] 692.644451 s: SCI_EDMA_TC1_RD | 0.000000 0.000000 [IPU1-0] 692.644543 s: SCI_EDMA_TC1_WR | 0.000000 0.000000 [IPU1-0] 692.744982 s: [IPU1-0] 692.745074 s: [IPU1-0] 692.745196 s: [IPU1-0] 692.745226 s: ### CPU [IPU1-0], LinkID [ 77], [IPU1-0] 692.745318 s: [IPU1-0] 692.745348 s: [ ISSCAPTURE ] Link Statistics, [IPU1-0] 692.745440 s: ****************************** [IPU1-0] 692.745501 s: [IPU1-0] 692.745531 s: Elapsed time = 675312 msec [IPU1-0] 692.746263 s: [IPU1-0] 692.746324 s: Get Full Buf Cb = 119.97 fps [IPU1-0] 692.746385 s: Put Empty Buf Cb = 29.99 fps [IPU1-0] 692.746477 s: Driver/Notify Cb = 119.96 fps [IPU1-0] 692.746538 s: [IPU1-0] 692.746599 s: Input Statistics, [IPU1-0] 692.746660 s: [IPU1-0] 692.746690 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 692.746782 s: | FPS | FPS | FPS | FPS [IPU1-0] 692.746904 s: -------------------------------------------------- [IPU1-0] 692.746995 s: 0 | 29.99 0. 0 0. 0 29.99 [IPU1-0] 692.747148 s: 1 | 29.99 0. 0 0. 0 29.99 [IPU1-0] 692.747270 s: 2 | 29.99 0. 0 0. 0 29.99 [IPU1-0] 692.747422 s: 3 | 29.98 0. 0 0. 0 29.98 [IPU1-0] 692.747544 s: [IPU1-0] 692.747605 s: Output Statistics, [IPU1-0] 692.747666 s: [IPU1-0] 692.747697 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 692.747758 s: | ID | FPS | FPS | FPS [IPU1-0] 692.747849 s: --------------------------------------------- [IPU1-0] 692.747941 s: 0 | 0 29.99 0. 0 0. 0 [IPU1-0] 692.748063 s: 1 | 0 29.99 0. 0 0. 0 [IPU1-0] 692.748185 s: 2 | 0 29.99 0. 0 0. 0 [IPU1-0] 692.748307 s: 3 | 0 29.98 0. 0 0. 0 [IPU1-0] 692.748520 s: [IPU1-0] 692.748551 s: [ ISSCAPTURE ] LATENCY, [IPU1-0] 692.748642 s: ******************** [IPU1-0] 692.748673 s: [IPU1-0] 692.748825 s: [IPU1-0] 692.748886 s: ### CPU [IPU1-0], LinkID [ 78], [IPU1-0] 692.748947 s: [IPU1-0] 692.749008 s: [ ISSM2MISP ] Link Statistics, [IPU1-0] 692.749069 s: ****************************** [IPU1-0] 692.749130 s: [IPU1-0] 692.749161 s: Elapsed time = 675314 msec [IPU1-0] 692.749252 s: [IPU1-0] 692.749283 s: New data Recv = 119.97 fps [IPU1-0] 692.749344 s: Get Full Buf Cb = 59.71 fps [IPU1-0] 692.749557 s: Driver/Notify Cb = 79.8 fps [IPU1-0] 692.749618 s: [IPU1-0] 692.749679 s: Input Statistics, [IPU1-0] 692.749710 s: [IPU1-0] 692.749771 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 692.750015 s: | FPS | FPS | FPS | FPS [IPU1-0] 692.750106 s: -------------------------------------------------- [IPU1-0] 692.750167 s: 0 | 29.99 13.63 0. 0 16.36 [IPU1-0] 692.750320 s: 1 | 29.99 13.63 0. 0 16.36 [IPU1-0] 692.750442 s: 2 | 29.99 0. 0 0. 0 29.99 [IPU1-0] 692.750564 s: 3 | 29.98 13.62 0. 0 16.36 [IPU1-0] 692.750716 s: [IPU1-0] 692.750747 s: Output Statistics, [IPU1-0] 692.750808 s: [IPU1-0] 692.750869 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 692.750930 s: | ID | FPS | FPS | FPS [IPU1-0] 692.750991 s: --------------------------------------------- [IPU1-0] 692.751082 s: 0 | 0 16.36 13.63 0. 0 [IPU1-0] 692.751204 s: 0 | 1 16.36 13.63 0. 0 [IPU1-0] 692.751296 s: 0 | 2 0. 0 29.99 0. 0 [IPU1-0] 692.751418 s: 0 | 3 0. 0 29.99 0. 0 [IPU1-0] 692.751540 s: 1 | 0 16.36 13.63 0. 0 [IPU1-0] 692.751662 s: 1 | 1 16.36 13.63 0. 0 [IPU1-0] 692.751784 s: 1 | 2 0. 0 29.99 0. 0 [IPU1-0] 692.751906 s: 1 | 3 0. 0 29.99 0. 0 [IPU1-0] 692.752028 s: 2 | 0 29.99 0. 0 0. 0 [IPU1-0] 692.752150 s: 2 | 1 29.99 0. 0 0. 0 [IPU1-0] 692.752272 s: 2 | 2 0. 0 29.99 0. 0 [IPU1-0] 692.752363 s: 2 | 3 0. 0 29.99 0. 0 [IPU1-0] 692.753492 s: 3 | 0 16.36 13.62 0. 0 [IPU1-0] 692.753644 s: 3 | 1 16.36 13.62 0. 0 [IPU1-0] 692.753766 s: 3 | 2 0. 0 29.98 0. 0 [IPU1-0] 692.753919 s: 3 | 3 0. 0 29.98 0. 0 [IPU1-0] 692.754041 s: [IPU1-0] 692.754102 s: [ ISSM2MISP ] LATENCY, [IPU1-0] 692.754163 s: ******************** [IPU1-0] 692.754224 s: Local Link Latency : Avg = 5431 us, Min = 5276 us, Max = 7076 us, [IPU1-0] 692.754346 s: Source to Link Latency : Avg = 12237 us, Min = 5429 us, Max = 28243 us, [IPU1-0] 692.754468 s: [IPU1-0] 692.754590 s: [IPU1-0] 692.754620 s: ### CPU [IPU1-0], LinkID [ 51], [IPU1-0] 692.754681 s: [IPU1-0] 692.754742 s: [ ALG_ISS_AEWB ] Link Statistics, [IPU1-0] 692.755017 s: ****************************** [IPU1-0] 692.755108 s: [IPU1-0] 692.755230 s: Elapsed time = 675291 msec [IPU1-0] 692.755322 s: [IPU1-0] 692.755352 s: New data Recv = 29.71 fps [IPU1-0] 692.755413 s: [IPU1-0] 692.755474 s: Input Statistics, [IPU1-0] 692.755535 s: [IPU1-0] 692.755566 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 692.755627 s: | FPS | FPS | FPS | FPS [IPU1-0] 692.755718 s: -------------------------------------------------- [IPU1-0] 692.755840 s: 0 | 16.36 0. 0 0. 0 16.36 [IPU1-0] 692.755962 s: [IPU1-0] 692.756023 s: Output Statistics, [IPU1-0] 692.756054 s: [IPU1-0] 692.756115 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 692.756176 s: | ID | FPS | FPS | FPS [IPU1-0] 692.756267 s: --------------------------------------------- [IPU1-0] 692.756328 s: 0 | 0 16.36 0. 0 0. 0 [IPU1-0] 692.756450 s: [IPU1-0] 692.756511 s: [ ALG_ISS_AEWB ] LATENCY, [IPU1-0] 692.756572 s: ******************** [IPU1-0] 692.756633 s: Local Link Latency : Avg = 2668 us, Min = 61 us, Max = 34710 us, [IPU1-0] 692.756755 s: Source to Link Latency : Avg = 27063 us, Min = 6130 us, Max = 158146 us, [IPU1-0] 692.756908 s: [IPU1-0] 692.756969 s: CPU [ IPU1-0], LinkID [ 25], Link Statistics not available ! [IPU1-0] 692.757091 s: CPU [ IPU1-0], LinkID [ 46], Link Statistics not available ! [IPU1-0] 692.757182 s: CPU [ IPU1-0], LinkID [ 43], Link Statistics not available ! [IPU1-0] 692.757365 s: [IPU1-0] 692.757396 s: ### CPU [IPU1-0], LinkID [ 34], [IPU1-0] 692.757487 s: [IPU1-0] 692.757518 s: [ SYNC_0 ] Link Statistics, [IPU1-0] 692.757609 s: ****************************** [IPU1-0] 692.757670 s: [IPU1-0] 692.757701 s: Elapsed time = 675381 msec [IPU1-0] 692.757762 s: [IPU1-0] 692.757823 s: New data Recv = 60.5 fps [IPU1-0] 692.757914 s: Get Full Buf Cb = 16.35 fps [IPU1-0] 692.757975 s: Put Empty Buf Cb = 16.35 fps [IPU1-0] 692.758067 s: Driver/Notify Cb = 30.30 fps [IPU1-0] 692.758158 s: [IPU1-0] 692.758189 s: Input Statistics, [IPU1-0] 692.758250 s: [IPU1-0] 692.758280 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 692.759379 s: | FPS | FPS | FPS | FPS [IPU1-0] 692.759501 s: -------------------------------------------------- [IPU1-0] 692.759562 s: 0 | 29.99 13.63 0. 0 16.35 [IPU1-0] 692.759714 s: 1 | 16.36 0. 0 0. 0 16.35 [IPU1-0] 692.760050 s: [IPU1-0] 692.760111 s: Output Statistics, [IPU1-0] 692.760172 s: [IPU1-0] 692.760202 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 692.760263 s: | ID | FPS | FPS | FPS [IPU1-0] 692.760355 s: --------------------------------------------- [IPU1-0] 692.760416 s: 0 | 0 16.35 0. 0 0. 0 [IPU1-0] 692.760538 s: [IPU1-0] 692.760599 s: [ SYNC_0 ] LATENCY, [IPU1-0] 692.760629 s: ******************** [IPU1-0] 692.760690 s: Local Link Latency : Avg = 45 us, Min = 0 us, Max = 336 us, [IPU1-0] 692.760843 s: Source to Link Latency : Avg = 22272 us, Min = 16715 us, Max = 28823 us, [IPU1-0] 692.760965 s: [IPU1-0] 692.761087 s: [IPU1-0] 692.761117 s: ### CPU [IPU1-0], LinkID [ 49], [IPU1-0] 692.761209 s: [IPU1-0] 692.761239 s: [ ALG_DEWARP ] Link Statistics, [IPU1-0] 692.761300 s: ****************************** [IPU1-0] 692.761361 s: [IPU1-0] 692.761392 s: Elapsed time = 675298 msec [IPU1-0] 692.761483 s: [IPU1-0] 692.761514 s: New data Recv = 16.35 fps [IPU1-0] 692.761605 s: [IPU1-0] 692.761636 s: Input Statistics, [IPU1-0] 692.761697 s: [IPU1-0] 692.761727 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 692.761819 s: | FPS | FPS | FPS | FPS [IPU1-0] 692.761910 s: -------------------------------------------------- [IPU1-0] 692.761971 s: 0 | 16.35 0. 0 0. 0 16.35 [IPU1-0] 692.762124 s: [IPU1-0] 692.762154 s: Output Statistics, [IPU1-0] 692.762215 s: [IPU1-0] 692.762246 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 692.762307 s: | ID | FPS | FPS | FPS [IPU1-0] 692.762398 s: --------------------------------------------- [IPU1-0] 692.762459 s: 0 | 0 16.35 0. 0 0. 0 [IPU1-0] 692.762581 s: [IPU1-0] 692.762612 s: [ ALG_DEWARP ] LATENCY, [IPU1-0] 692.762673 s: ******************** [IPU1-0] 692.762734 s: Local Link Latency : Avg = 9142 us, Min = 3202 us, Max = 22815 us, [IPU1-0] 692.762856 s: Source to Link Latency : Avg = 31806 us, Min = 20390 us, Max = 46316 us, [IPU1-0] 692.762978 s: [IPU1-0] 692.763039 s: CPU [ IPU1-0], LinkID [ 26], Link Statistics not available ! [IPU1-0] 692.763191 s: [IPU1-0] 692.763222 s: ### CPU [IPU1-0], LinkID [ 0], [IPU1-0] 692.763313 s: [IPU1-0] 692.763344 s: [ IPC_OUT_0 ] Link Statistics, [IPU1-0] 692.763405 s: ****************************** [IPU1-0] 692.763466 s: [IPU1-0] 692.763527 s: Elapsed time = 675286 msec [IPU1-0] 692.763588 s: [IPU1-0] 692.763618 s: New data Recv = 16.35 fps [IPU1-0] 692.763710 s: Release data Recv = 16.37 fps [IPU1-0] 692.763771 s: Driver/Notify Cb = 116.35 fps [IPU1-0] 692.763862 s: [IPU1-0] 692.763893 s: Input Statistics, [IPU1-0] 692.763954 s: [IPU1-0] 692.763984 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 692.764076 s: | FPS | FPS | FPS | FPS [IPU1-0] 692.764137 s: -------------------------------------------------- [IPU1-0] 692.764228 s: 0 | 16.35 0. 0 0. 0 16.35 [IPU1-0] 692.764350 s: [IPU1-0] 692.764411 s: Output Statistics, [IPU1-0] 692.764442 s: [IPU1-0] 692.764503 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 692.764564 s: | ID | FPS | FPS | FPS [IPU1-0] 692.764625 s: --------------------------------------------- [IPU1-0] 692.764716 s: 0 | 0 16.35 0. 0 0. 0 [IPU1-0] 692.764960 s: [IPU1-0] 692.765021 s: [ IPC_OUT_0 ] LATENCY, [IPU1-0] 692.765082 s: ******************** [IPU1-0] 692.765113 s: Local Link Latency : Avg = 8 us, Min = 0 us, Max = 244 us, [IPU1-0] 692.765235 s: Source to Link Latency : Avg = 31987 us, Min = 20634 us, Max = 46468 us, [IPU1-0] 692.765357 s: [IPU1-0] 693.265052 s: [IPU1-0] 693.265143 s: ### CPU [ EVE1], LinkID [ 10], [IPU1-0] 693.265204 s: [IPU1-0] 693.265235 s: [ IPC_IN_0 ] Link Statistics, [IPU1-0] 693.265326 s: ****************************** [IPU1-0] 693.265387 s: [IPU1-0] 693.265418 s: Elapsed time = 675788 msec [IPU1-0] 693.265479 s: [IPU1-0] 693.265540 s: Get Full Buf Cb = 16.35 fps [IPU1-0] 693.265601 s: Put Empty Buf Cb = 16.35 fps [IPU1-0] 693.265662 s: Driver/Notify Cb = 16.35 fps [IPU1-0] 693.265753 s: [IPU1-0] 693.265784 s: Input Statistics, [IPU1-0] 693.265967 s: [IPU1-0] 693.265997 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 693.266089 s: | FPS | FPS | FPS | FPS [IPU1-0] 693.266150 s: -------------------------------------------------- [IPU1-0] 693.266241 s: 0 | 16.35 0. 0 0. 0 16.35 [IPU1-0] 693.266363 s: [IPU1-0] 693.266394 s: Output Statistics, [IPU1-0] 693.266455 s: [IPU1-0] 693.266485 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 693.266577 s: | ID | FPS | FPS | FPS [IPU1-0] 693.266638 s: --------------------------------------------- [IPU1-0] 693.266729 s: 0 | 0 16.35 0. 0 0. 0 [IPU1-0] 693.266851 s: [IPU1-0] 693.266912 s: [ IPC_IN_0 ] LATENCY, [IPU1-0] 693.266973 s: ******************** [IPU1-0] 693.267034 s: Local Link Latency : Avg = 40 us, Min = 30 us, Max = 183 us, [IPU1-0] 693.267126 s: Source to Link Latency : Avg = 32399 us, Min = 20908 us, Max = 46773 us, [IPU1-0] 693.267248 s: [IPU1-0] 693.267339 s: [IPU1-0] 693.267400 s: ### CPU [ EVE1], LinkID [ 50], [IPU1-0] 693.267461 s: [IPU1-0] 693.267492 s: [ ALG_CENSUS ] Link Statistics, [IPU1-0] 693.267583 s: ****************************** [IPU1-0] 693.267644 s: [IPU1-0] 693.267675 s: Elapsed time = 675789 msec [IPU1-0] 693.267736 s: [IPU1-0] 693.267797 s: New data Recv = 16.35 fps [IPU1-0] 693.267980 s: [IPU1-0] 693.268041 s: Input Statistics, [IPU1-0] 693.268071 s: [IPU1-0] 693.268102 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 693.268193 s: | FPS | FPS | FPS | FPS [IPU1-0] 693.268254 s: -------------------------------------------------- [IPU1-0] 693.268346 s: 0 | 16.35 0. 0 0. 0 16.35 [IPU1-0] 693.268468 s: 1 | 16.35 0. 0 0. 0 16.35 [IPU1-0] 693.268681 s: [IPU1-0] 693.268712 s: Output Statistics, [IPU1-0] 693.268773 s: [IPU1-0] 693.268834 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 693.268925 s: | ID | FPS | FPS | FPS [IPU1-0] 693.268986 s: --------------------------------------------- [IPU1-0] 693.269047 s: 0 | 0 16.35 0. 0 0. 0 [IPU1-0] 693.269169 s: 1 | 0 16.35 0. 0 0. 0 [IPU1-0] 693.270054 s: [IPU1-0] 693.270145 s: [ ALG_CENSUS ] LATENCY, [IPU1-0] 693.270206 s: ******************** [IPU1-0] 693.270237 s: Local Link Latency : Avg = 3040 us, Min = 2806 us, Max = 4483 us, [IPU1-0] 693.270359 s: Source to Link Latency : Avg = 35598 us, Min = 23867 us, Max = 50525 us, [IPU1-0] 693.270481 s: [IPU1-0] 693.270603 s: [IPU1-0] 693.270633 s: ### CPU [ EVE1], LinkID [ 49], [IPU1-0] 693.270694 s: [IPU1-0] 693.270755 s: [ ALG_DISPARITY ] Link Statistics, [IPU1-0] 693.270847 s: ****************************** [IPU1-0] 693.270908 s: [IPU1-0] 693.270969 s: Elapsed time = 675789 msec [IPU1-0] 693.271030 s: [IPU1-0] 693.271060 s: New data Recv = 16.35 fps [IPU1-0] 693.271152 s: [IPU1-0] 693.271182 s: Input Statistics, [IPU1-0] 693.271243 s: [IPU1-0] 693.271274 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 693.271335 s: | FPS | FPS | FPS | FPS [IPU1-0] 693.271426 s: -------------------------------------------------- [IPU1-0] 693.271518 s: 0 | 16.35 0. 0 0. 0 16.35 [IPU1-0] 693.271640 s: [IPU1-0] 693.271670 s: Output Statistics, [IPU1-0] 693.271731 s: [IPU1-0] 693.271762 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 693.271853 s: | ID | FPS | FPS | FPS [IPU1-0] 693.271945 s: --------------------------------------------- [IPU1-0] 693.272006 s: 0 | 0 16.35 0. 0 0. 0 [IPU1-0] 693.272128 s: [IPU1-0] 693.272158 s: [ ALG_DISPARITY ] LATENCY, [IPU1-0] 693.272219 s: ******************** [IPU1-0] 693.272280 s: Local Link Latency : Avg = 20069 us, Min = 19642 us, Max = 20924 us, [IPU1-0] 693.272402 s: Source to Link Latency : Avg = 55863 us, Min = 43814 us, Max = 71540 us, [IPU1-0] 693.272524 s: [IPU1-0] 693.272616 s: [IPU1-0] 693.272646 s: ### CPU [ EVE1], LinkID [ 0], [IPU1-0] 693.272738 s: [IPU1-0] 693.272768 s: [ IPC_OUT_0 ] Link Statistics, [IPU1-0] 693.272860 s: ****************************** [IPU1-0] 693.272921 s: [IPU1-0] 693.272951 s: Elapsed time = 675771 msec [IPU1-0] 693.273043 s: [IPU1-0] 693.273073 s: New data Recv = 16.35 fps [IPU1-0] 693.273134 s: Release data Recv = 16.35 fps [IPU1-0] 693.273226 s: Driver/Notify Cb = 26.35 fps [IPU1-0] 693.273287 s: [IPU1-0] 693.273317 s: Input Statistics, [IPU1-0] 693.273378 s: [IPU1-0] 693.273409 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 693.273531 s: | FPS | FPS | FPS | FPS [IPU1-0] 693.273622 s: -------------------------------------------------- [IPU1-0] 693.273714 s: 0 | 16.35 0. 0 0. 0 16.35 [IPU1-0] 693.274049 s: [IPU1-0] 693.274110 s: Output Statistics, [IPU1-0] 693.274171 s: [IPU1-0] 693.274202 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 693.274263 s: | ID | FPS | FPS | FPS [IPU1-0] 693.274354 s: --------------------------------------------- [IPU1-0] 693.274415 s: 0 | 0 16.35 0. 0 0. 0 [IPU1-0] 693.274537 s: [IPU1-0] 693.274568 s: [ IPC_OUT_0 ] LATENCY, [IPU1-0] 693.274629 s: ******************** [IPU1-0] 693.276672 s: Local Link Latency : Avg = 23 us, Min = 0 us, Max = 183 us, [IPU1-0] 693.276886 s: Source to Link Latency : Avg = 56084 us, Min = 43997 us, Max = 72165 us, [IPU1-0] 693.277008 s: [IPU1-0] 693.776947 s: [IPU1-0] 693.777008 s: ### CPU [IPU1-0], LinkID [ 10], [IPU1-0] 693.777282 s: [IPU1-0] 693.777343 s: [ IPC_IN_0 ] Link Statistics, [IPU1-0] 693.777404 s: ****************************** [IPU1-0] 693.777435 s: [IPU1-0] 693.777496 s: Elapsed time = 676276 msec [IPU1-0] 693.777557 s: [IPU1-0] 693.777587 s: Get Full Buf Cb = 32.69 fps [IPU1-0] 693.777679 s: Put Empty Buf Cb = 16.34 fps [IPU1-0] 693.777740 s: Driver/Notify Cb = 16.34 fps [IPU1-0] 693.777801 s: [IPU1-0] 693.777893 s: Input Statistics, [IPU1-0] 693.777923 s: [IPU1-0] 693.777984 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 693.778045 s: | FPS | FPS | FPS | FPS [IPU1-0] 693.778137 s: -------------------------------------------------- [IPU1-0] 693.778198 s: 0 | 16.34 0. 0 0. 0 16.34 [IPU1-0] 693.778320 s: [IPU1-0] 693.778381 s: Output Statistics, [IPU1-0] 693.778411 s: [IPU1-0] 693.778472 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 693.778533 s: | ID | FPS | FPS | FPS [IPU1-0] 693.778594 s: --------------------------------------------- [IPU1-0] 693.778686 s: 0 | 0 16.34 0. 0 0. 0 [IPU1-0] 693.778777 s: [IPU1-0] 693.778838 s: [ IPC_IN_0 ] LATENCY, [IPU1-0] 693.778899 s: ******************** [IPU1-0] 693.778960 s: Local Link Latency : Avg = 19 us, Min = 0 us, Max = 397 us, [IPU1-0] 693.779052 s: Source to Link Latency : Avg = 56315 us, Min = 44241 us, Max = 72409 us, [IPU1-0] 693.779174 s: [IPU1-0] 693.779235 s: CPU [ IPU1-0], LinkID [ 39], Link Statistics not available ! [IPU1-0] 693.779387 s: [IPU1-0] 693.779418 s: ### CPU [IPU1-0], LinkID [ 1], [IPU1-0] 693.779509 s: [IPU1-0] 693.779540 s: [ IPC_OUT_1 ] Link Statistics, [IPU1-0] 693.779601 s: ****************************** [IPU1-0] 693.779662 s: [IPU1-0] 693.779692 s: Elapsed time = 676302 msec [IPU1-0] 693.779753 s: [IPU1-0] 693.779814 s: New data Recv = 32.67 fps [IPU1-0] 693.780028 s: Release data Recv = 16.36 fps [IPU1-0] 693.780119 s: Driver/Notify Cb = 116.34 fps [IPU1-0] 693.780180 s: [IPU1-0] 693.780241 s: Input Statistics, [IPU1-0] 693.780272 s: [IPU1-0] 693.780333 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 693.780394 s: | FPS | FPS | FPS | FPS [IPU1-0] 693.780455 s: -------------------------------------------------- [IPU1-0] 693.780546 s: 0 | 16.34 0. 0 0. 0 16.34 [IPU1-0] 693.780668 s: 1 | 16.34 0. 0 0. 0 16.34 [IPU1-0] 693.780790 s: [IPU1-0] 693.780943 s: Output Statistics, [IPU1-0] 693.781004 s: [IPU1-0] 693.781034 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 693.781095 s: | ID | FPS | FPS | FPS [IPU1-0] 693.781187 s: --------------------------------------------- [IPU1-0] 693.781248 s: 0 | 0 16.34 0. 0 0. 0 [IPU1-0] 693.781370 s: 1 | 0 16.34 0. 0 0. 0 [IPU1-0] 693.781492 s: [IPU1-0] 693.781522 s: [ IPC_OUT_1 ] LATENCY, [IPU1-0] 693.781583 s: ******************** [IPU1-0] 693.781614 s: Local Link Latency : Avg = 7 us, Min = 0 us, Max = 305 us, [IPU1-0] 693.781736 s: Source to Link Latency : Avg = 44333 us, Min = 20786 us, Max = 73004 us, [IPU1-0] 693.781888 s: [IPU1-0] 694.281919 s: [IPU1-0] 694.282010 s: ### CPU [ DSP1], LinkID [ 10], [IPU1-0] 694.282071 s: [IPU1-0] 694.282102 s: [ IPC_IN_0 ] Link Statistics, [IPU1-0] 694.282163 s: ****************************** [IPU1-0] 694.282224 s: [IPU1-0] 694.282285 s: Elapsed time = 676805 msec [IPU1-0] 694.282346 s: [IPU1-0] 694.282376 s: Get Full Buf Cb = 26.42 fps [IPU1-0] 694.282529 s: Put Empty Buf Cb = 32.68 fps [IPU1-0] 694.282590 s: Driver/Notify Cb = 32.65 fps [IPU1-0] 694.282651 s: [IPU1-0] 694.282712 s: Input Statistics, [IPU1-0] 694.282742 s: [IPU1-0] 694.282803 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 694.282895 s: | FPS | FPS | FPS | FPS [IPU1-0] 694.282956 s: -------------------------------------------------- [IPU1-0] 694.283047 s: 0 | 16.34 0. 0 0. 0 16.34 [IPU1-0] 694.283169 s: 1 | 16.34 0. 0 0. 0 16.34 [IPU1-0] 694.283322 s: [IPU1-0] 694.283352 s: Output Statistics, [IPU1-0] 694.283383 s: [IPU1-0] 694.283444 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 694.283505 s: | ID | FPS | FPS | FPS [IPU1-0] 694.283566 s: --------------------------------------------- [IPU1-0] 694.283657 s: 0 | 0 16.34 0. 0 0. 0 [IPU1-0] 694.283779 s: 1 | 0 16.34 0. 0 0. 0 [IPU1-0] 694.283901 s: [IPU1-0] 694.283962 s: [ IPC_IN_0 ] LATENCY, [IPU1-0] 694.283993 s: ******************** [IPU1-0] 694.284054 s: Local Link Latency : Avg = 10 us, Min = 0 us, Max = 92 us, [IPU1-0] 694.284176 s: Source to Link Latency : Avg = 50453 us, Min = 20878 us, Max = 73340 us, [IPU1-0] 694.284298 s: [IPU1-0] 694.284389 s: [IPU1-0] 694.284420 s: ### CPU [ DSP1], LinkID [ 49], [IPU1-0] 694.284511 s: [IPU1-0] 694.284542 s: [ ALG_STEREO_POSTPROCESS ] Link Statistics, [IPU1-0] 694.284603 s: ****************************** [IPU1-0] 694.284664 s: [IPU1-0] 694.284725 s: Elapsed time = 676806 msec [IPU1-0] 694.284786 s: [IPU1-0] 694.284816 s: New data Recv = 26.42 fps [IPU1-0] 694.285060 s: [IPU1-0] 694.285091 s: Input Statistics, [IPU1-0] 694.285152 s: [IPU1-0] 694.285182 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 694.285243 s: | FPS | FPS | FPS | FPS [IPU1-0] 694.285335 s: -------------------------------------------------- [IPU1-0] 694.285396 s: 0 | 16.34 0. 0 0. 0 16.34 [IPU1-0] 694.285548 s: [IPU1-0] 694.285579 s: Output Statistics, [IPU1-0] 694.285640 s: [IPU1-0] 694.285670 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 694.285731 s: | ID | FPS | FPS | FPS [IPU1-0] 694.285823 s: --------------------------------------------- [IPU1-0] 694.286860 s: 0 | 0 16.34 0. 0 0. 0 [IPU1-0] 694.287012 s: [IPU1-0] 694.287073 s: [ ALG_STEREO_POSTPROCESS ] LATENCY, [IPU1-0] 694.287134 s: ******************** [IPU1-0] 694.287195 s: Local Link Latency : Avg = 30629 us, Min = 28548 us, Max = 35350 us, [IPU1-0] 694.287378 s: Source to Link Latency : Avg = 91085 us, Min = 73187 us, Max = 106433 us, [IPU1-0] 694.287500 s: [IPU1-0] 694.287592 s: [IPU1-0] 694.287653 s: ### CPU [ DSP1], LinkID [ 0], [IPU1-0] 694.287714 s: [IPU1-0] 694.287775 s: [ IPC_OUT_0 ] Link Statistics, [IPU1-0] 694.287866 s: ****************************** [IPU1-0] 694.287927 s: [IPU1-0] 694.287958 s: Elapsed time = 676755 msec [IPU1-0] 694.288019 s: [IPU1-0] 694.288080 s: New data Recv = 16.34 fps [IPU1-0] 694.288141 s: Release data Recv = 16.43 fps [IPU1-0] 694.288232 s: Driver/Notify Cb = 116.33 fps [IPU1-0] 694.288293 s: [IPU1-0] 694.288324 s: Input Statistics, [IPU1-0] 694.288385 s: [IPU1-0] 694.288415 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 694.288507 s: | FPS | FPS | FPS | FPS [IPU1-0] 694.288568 s: -------------------------------------------------- [IPU1-0] 694.288659 s: 0 | 16.34 0. 0 0. 0 16.34 [IPU1-0] 694.288812 s: [IPU1-0] 694.288934 s: Output Statistics, [IPU1-0] 694.288995 s: [IPU1-0] 694.289056 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 694.289117 s: | ID | FPS | FPS | FPS [IPU1-0] 694.289178 s: --------------------------------------------- [IPU1-0] 694.289269 s: 0 | 0 16.34 0. 0 0. 0 [IPU1-0] 694.289391 s: [IPU1-0] 694.289422 s: [ IPC_OUT_0 ] LATENCY, [IPU1-0] 694.289483 s: ******************** [IPU1-0] 694.289544 s: Local Link Latency : Avg = 3 us, Min = 0 us, Max = 61 us, [IPU1-0] 694.289666 s: Source to Link Latency : Avg = 91221 us, Min = 73278 us, Max = 106646 us, [IPU1-0] 694.289788 s: [IPU1-0] 694.789971 s: [IPU1-0] 694.790032 s: ### CPU [IPU1-0], LinkID [ 11], [IPU1-0] 694.790123 s: [IPU1-0] 694.790154 s: [ IPC_IN_1 ] Link Statistics, [IPU1-0] 694.790245 s: ****************************** [IPU1-0] 694.790306 s: [IPU1-0] 694.790337 s: Elapsed time = 677258 msec [IPU1-0] 694.790428 s: [IPU1-0] 694.790459 s: Get Full Buf Cb = 65.35 fps [IPU1-0] 694.790550 s: Put Empty Buf Cb = 16.33 fps [IPU1-0] 694.790611 s: Driver/Notify Cb = 16.33 fps [IPU1-0] 694.790703 s: [IPU1-0] 694.790733 s: Input Statistics, [IPU1-0] 694.790794 s: [IPU1-0] 694.790825 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 694.790947 s: | FPS | FPS | FPS | FPS [IPU1-0] 694.791008 s: -------------------------------------------------- [IPU1-0] 694.791099 s: 0 | 16.33 0. 0 0. 0 16.33 [IPU1-0] 694.791252 s: [IPU1-0] 694.791282 s: Output Statistics, [IPU1-0] 694.791374 s: [IPU1-0] 694.791435 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 694.791496 s: | ID | FPS | FPS | FPS [IPU1-0] 694.791557 s: --------------------------------------------- [IPU1-0] 694.791648 s: 0 | 0 16.33 0. 0 0. 0 [IPU1-0] 694.800799 s: [IPU1-0] 694.800890 s: [ IPC_IN_1 ] LATENCY, [IPU1-0] 694.800951 s: ******************** [IPU1-0] 694.801012 s: Local Link Latency : Avg = 19 us, Min = 0 us, Max = 396 us, [IPU1-0] 694.801226 s: Source to Link Latency : Avg = 91473 us, Min = 73553 us, Max = 106890 us, [IPU1-0] 694.801348 s: [IPU1-0] 694.801409 s: CPU [ IPU1-0], LinkID [ 45], Link Statistics not available ! [IPU1-0] 694.801531 s: CPU [ IPU1-0], LinkID [ 44], Link Statistics not available ! [IPU1-0] 694.801714 s: CPU [ IPU1-0], LinkID [ 38], Link Statistics not available ! [IPU1-0] 694.802171 s: [IPU1-0] 694.802232 s: ### CPU [IPU1-0], LinkID [ 35], [IPU1-0] 694.802293 s: [IPU1-0] 694.802354 s: [ SYNC_1 ] Link Statistics, [IPU1-0] 694.802415 s: ****************************** [IPU1-0] 694.802476 s: [IPU1-0] 694.802507 s: Elapsed time = 677428 msec [IPU1-0] 694.802568 s: [IPU1-0] 694.802629 s: New data Recv = 63.52 fps [IPU1-0] 694.802690 s: Get Full Buf Cb = 16.33 fps [IPU1-0] 694.802781 s: Put Empty Buf Cb = 16.33 fps [IPU1-0] 694.803208 s: Driver/Notify Cb = 30.30 fps [IPU1-0] 694.803300 s: [IPU1-0] 694.803361 s: Input Statistics, [IPU1-0] 694.803391 s: [IPU1-0] 694.803422 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 694.803513 s: | FPS | FPS | FPS | FPS [IPU1-0] 694.803574 s: -------------------------------------------------- [IPU1-0] 694.803666 s: 0 | 16.33 0. 0 0. 0 16.33 [IPU1-0] 694.803788 s: 1 | 16.33 0. 0 0. 0 16.33 [IPU1-0] 694.803971 s: 2 | 16.33 0. 0 0. 0 16.33 [IPU1-0] 694.804093 s: 3 | 16.33 0. 0 0. 0 16.33 [IPU1-0] 694.804215 s: [IPU1-0] 694.804276 s: Output Statistics, [IPU1-0] 694.804306 s: [IPU1-0] 694.804367 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 694.804428 s: | ID | FPS | FPS | FPS [IPU1-0] 694.804489 s: --------------------------------------------- [IPU1-0] 694.804581 s: 0 | 0 16.33 0. 0 0. 0 [IPU1-0] 694.804703 s: [IPU1-0] 694.804733 s: [ SYNC_1 ] LATENCY, [IPU1-0] 694.804794 s: ******************** [IPU1-0] 694.804855 s: Local Link Latency : Avg = 139852 us, Min = 30 us, Max = 424114 us, [IPU1-0] 694.804977 s: Source to Link Latency : Avg = 179543 us, Min = 73054 us, Max = 354809 us, [IPU1-0] 694.805099 s: [IPU1-0] 694.805191 s: [IPU1-0] 694.805221 s: ### CPU [IPU1-0], LinkID [ 50], [IPU1-0] 694.805313 s: [IPU1-0] 694.805343 s: [ ALG_DEWARP ] Link Statistics, [IPU1-0] 694.805404 s: ****************************** [IPU1-0] 694.805465 s: [IPU1-0] 694.805526 s: Elapsed time = 677265 msec [IPU1-0] 694.805587 s: [IPU1-0] 694.805618 s: New data Recv = 16.33 fps [IPU1-0] 694.805709 s: [IPU1-0] 694.805740 s: Input Statistics, [IPU1-0] 694.805801 s: [IPU1-0] 694.805831 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 694.805923 s: | FPS | FPS | FPS | FPS [IPU1-0] 694.805984 s: -------------------------------------------------- [IPU1-0] 694.806075 s: 0 | 16.33 0. 0 0. 0 16.33 [IPU1-0] 694.806197 s: [IPU1-0] 694.806228 s: Output Statistics, [IPU1-0] 694.806289 s: [IPU1-0] 694.806319 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 694.806411 s: | ID | FPS | FPS | FPS [IPU1-0] 694.806472 s: --------------------------------------------- [IPU1-0] 694.806533 s: 0 | 0 16.33 0. 0 0. 0 [IPU1-0] 694.806655 s: [IPU1-0] 694.806685 s: [ ALG_DEWARP ] LATENCY, [IPU1-0] 694.806746 s: ******************** [IPU1-0] 694.806807 s: Local Link Latency : Avg = 12094 us, Min = 9699 us, Max = 28396 us, [IPU1-0] 694.807082 s: Source to Link Latency : Avg = 192700 us, Min = 86573 us, Max = 366659 us, [IPU1-0] 694.807204 s: [IPU1-0] 694.807265 s: CPU [ IPU1-0], LinkID [ 27], Link Statistics not available ! [IPU1-0] 694.807387 s: [IPU1-0] 694.807448 s: ### CPU [IPU1-0], LinkID [ 3], [IPU1-0] 694.807509 s: [IPU1-0] 694.807539 s: [ IPC_OUT_3 ] Link Statistics, [IPU1-0] 694.807600 s: ****************************** [IPU1-0] 694.807661 s: [IPU1-0] 694.807722 s: Elapsed time = 677255 msec [IPU1-0] 694.807783 s: [IPU1-0] 694.807814 s: New data Recv = 16.33 fps [IPU1-0] 694.807905 s: Release data Recv = 16.35 fps [IPU1-0] 694.807997 s: Driver/Notify Cb = 116.33 fps [IPU1-0] 694.808058 s: [IPU1-0] 694.808088 s: Input Statistics, [IPU1-0] 694.808149 s: [IPU1-0] 694.808180 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 694.808271 s: | FPS | FPS | FPS | FPS [IPU1-0] 694.808332 s: -------------------------------------------------- [IPU1-0] 694.808424 s: 0 | 16.33 0. 0 0. 0 16.33 [IPU1-0] 694.808546 s: [IPU1-0] 694.808576 s: Output Statistics, [IPU1-0] 694.808637 s: [IPU1-0] 694.808668 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 694.808729 s: | ID | FPS | FPS | FPS [IPU1-0] 694.808820 s: --------------------------------------------- [IPU1-0] 694.808881 s: 0 | 0 16.33 0. 0 0. 0 [IPU1-0] 694.809003 s: [IPU1-0] 694.809064 s: [ IPC_OUT_3 ] LATENCY, [IPU1-0] 694.809125 s: ******************** [IPU1-0] 694.809156 s: Local Link Latency : Avg = 6 us, Min = 0 us, Max = 305 us, [IPU1-0] 694.809278 s: Source to Link Latency : Avg = 193022 us, Min = 87000 us, Max = 366933 us, [IPU1-0] 694.809400 s: [IPU1-0] 695.309796 s: [IPU1-0] 695.309949 s: ### CPU [ DSP2], LinkID [ 11], [IPU1-0] 695.310101 s: [IPU1-0] 695.310132 s: [ IPC_IN_1 ] Link Statistics, [IPU1-0] 695.310223 s: ****************************** [IPU1-0] 695.310284 s: [IPU1-0] 695.310315 s: Elapsed time = 677750 msec [IPU1-0] 695.310650 s: [IPU1-0] 695.310711 s: Get Full Buf Cb = 32.61 fps [IPU1-0] 695.310803 s: Put Empty Buf Cb = 16.33 fps [IPU1-0] 695.310925 s: Driver/Notify Cb = 16.33 fps [IPU1-0] 695.310986 s: [IPU1-0] 695.311047 s: Input Statistics, [IPU1-0] 695.311077 s: [IPU1-0] 695.311138 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 695.311230 s: | FPS | FPS | FPS | FPS [IPU1-0] 695.311291 s: -------------------------------------------------- [IPU1-0] 695.311382 s: 0 | 16.33 0. 0 0. 0 16.33 [IPU1-0] 695.311504 s: [IPU1-0] 695.311565 s: Output Statistics, [IPU1-0] 695.311626 s: [IPU1-0] 695.311657 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 695.311718 s: | ID | FPS | FPS | FPS [IPU1-0] 695.311809 s: --------------------------------------------- [IPU1-0] 695.312694 s: 0 | 0 16.33 0. 0 0. 0 [IPU1-0] 695.312846 s: [IPU1-0] 695.312938 s: [ IPC_IN_1 ] LATENCY, [IPU1-0] 695.313029 s: ******************** [IPU1-0] 695.313060 s: Local Link Latency : Avg = 13 us, Min = 0 us, Max = 61 us, [IPU1-0] 695.313212 s: Source to Link Latency : Avg = 200791 us, Min = 91644 us, Max = 374131 us, [IPU1-0] 695.313334 s: [IPU1-0] 695.813212 s: [IPU1-0] 695.813273 s: ### CPU [IPU1-0], LinkID [ 2], [IPU1-0] 695.813334 s: [IPU1-0] 695.813395 s: [ IPC_OUT_2 ] Link Statistics, [IPU1-0] 695.813456 s: ****************************** [IPU1-0] 695.813517 s: [IPU1-0] 695.813548 s: Elapsed time = 678261 msec [IPU1-0] 695.813609 s: [IPU1-0] 695.813670 s: New data Recv = 16.32 fps [IPU1-0] 695.813731 s: Release data Recv = 16.33 fps [IPU1-0] 695.813822 s: Driver/Notify Cb = 116.32 fps [IPU1-0] 695.813914 s: [IPU1-0] 695.813975 s: Input Statistics, [IPU1-0] 695.814005 s: [IPU1-0] 695.814066 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 695.814127 s: | FPS | FPS | FPS | FPS [IPU1-0] 695.814219 s: -------------------------------------------------- [IPU1-0] 695.814280 s: 0 | 16.32 0. 0 0. 0 16.32 [IPU1-0] 695.814432 s: [IPU1-0] 695.814463 s: Output Statistics, [IPU1-0] 695.814524 s: [IPU1-0] 695.814554 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 695.814615 s: | ID | FPS | FPS | FPS [IPU1-0] 695.814707 s: --------------------------------------------- [IPU1-0] 695.814768 s: 0 | 0 16.32 0. 0 0. 0 [IPU1-0] 695.814921 s: [IPU1-0] 695.814951 s: [ IPC_OUT_2 ] LATENCY, [IPU1-0] 695.815012 s: ******************** [IPU1-0] 695.815073 s: Local Link Latency : Avg = 8 us, Min = 0 us, Max = 275 us, [IPU1-0] 695.815256 s: Source to Link Latency : Avg = 192995 us, Min = 86817 us, Max = 366834 us, [IPU1-0] 695.816110 s: [IPU1-0] 696.315988 s: [IPU1-0] 696.316049 s: ### CPU [ DSP2], LinkID [ 10], [IPU1-0] 696.316141 s: [IPU1-0] 696.316171 s: [ IPC_IN_0 ] Link Statistics, [IPU1-0] 696.316232 s: ****************************** [IPU1-0] 696.316293 s: [IPU1-0] 696.316354 s: Elapsed time = 678764 msec [IPU1-0] 696.316415 s: [IPU1-0] 696.316446 s: Get Full Buf Cb = 16.32 fps [IPU1-0] 696.316537 s: Put Empty Buf Cb = 16.32 fps [IPU1-0] 696.316598 s: Driver/Notify Cb = 16.32 fps [IPU1-0] 696.316690 s: [IPU1-0] 696.316720 s: Input Statistics, [IPU1-0] 696.316781 s: [IPU1-0] 696.316812 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 696.317300 s: | FPS | FPS | FPS | FPS [IPU1-0] 696.317391 s: -------------------------------------------------- [IPU1-0] 696.317483 s: 0 | 16.32 0. 0 0. 0 16.32 [IPU1-0] 696.317605 s: [IPU1-0] 696.317666 s: Output Statistics, [IPU1-0] 696.317788 s: [IPU1-0] 696.317818 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 696.317910 s: | ID | FPS | FPS | FPS [IPU1-0] 696.318001 s: --------------------------------------------- [IPU1-0] 696.318093 s: 0 | 0 16.32 0. 0 0. 0 [IPU1-0] 696.318184 s: [IPU1-0] 696.318245 s: [ IPC_IN_0 ] LATENCY, [IPU1-0] 696.318306 s: ******************** [IPU1-0] 696.318367 s: Local Link Latency : Avg = 13 us, Min = 0 us, Max = 31 us, [IPU1-0] 696.318459 s: Source to Link Latency : Avg = 193196 us, Min = 86970 us, Max = 366933 us, [IPU1-0] 696.318581 s: [IPU1-0] 696.318703 s: [IPU1-0] 696.318733 s: ### CPU [ DSP2], LinkID [ 49], [IPU1-0] 696.318825 s: [IPU1-0] 696.318855 s: [ ALG_SEAMDETECTION ] Link Statistics, [IPU1-0] 696.318947 s: ****************************** [IPU1-0] 696.319008 s: [IPU1-0] 696.319038 s: Elapsed time = 678766 msec [IPU1-0] 696.319130 s: [IPU1-0] 696.319160 s: New data Recv = 16.32 fps [IPU1-0] 696.319252 s: [IPU1-0] 696.319282 s: Input Statistics, [IPU1-0] 696.319343 s: [IPU1-0] 696.320533 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 696.320655 s: | FPS | FPS | FPS | FPS [IPU1-0] 696.320716 s: -------------------------------------------------- [IPU1-0] 696.320807 s: 0 | 0. 0 0. 0 0. 0 16.32 [IPU1-0] 696.320990 s: [IPU1-0] 696.321051 s: Output Statistics, [IPU1-0] 696.321112 s: [IPU1-0] 696.321143 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 696.321204 s: | ID | FPS | FPS | FPS [IPU1-0] 696.321295 s: --------------------------------------------- [IPU1-0] 696.321387 s: 0 | 0 16.32 0. 0 0. 0 [IPU1-0] 696.321509 s: [IPU1-0] 696.321539 s: [ ALG_SEAMDETECTION ] LATENCY, [IPU1-0] 696.321600 s: ******************** [IPU1-0] 696.321661 s: Local Link Latency : Avg = 7148 us, Min = 6222 us, Max = 9578 us, [IPU1-0] 696.321814 s: Source to Link Latency : Avg = 200824 us, Min = 95632 us, Max = 374039 us, [IPU1-0] 696.322119 s: [IPU1-0] 696.322241 s: [IPU1-0] 696.322271 s: ### CPU [ DSP2], LinkID [ 50], [IPU1-0] 696.322363 s: [IPU1-0] 696.322393 s: [ ALG_STITCHING ] Link Statistics, [IPU1-0] 696.322485 s: ****************************** [IPU1-0] 696.322546 s: [IPU1-0] 696.322668 s: Elapsed time = 678762 msec [IPU1-0] 696.323034 s: [IPU1-0] 696.323095 s: New data Recv = 32.59 fps [IPU1-0] 696.323186 s: [IPU1-0] 696.323217 s: Input Statistics, [IPU1-0] 696.323278 s: [IPU1-0] 696.323339 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 696.323400 s: | FPS | FPS | FPS | FPS [IPU1-0] 696.323491 s: -------------------------------------------------- [IPU1-0] 696.323583 s: 0 | 0. 0 0. 0 0. 0 32.64 [IPU1-0] 696.323705 s: [IPU1-0] 696.323766 s: Output Statistics, [IPU1-0] 696.323796 s: [IPU1-0] 696.323857 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 696.323979 s: | ID | FPS | FPS | FPS [IPU1-0] 696.324040 s: --------------------------------------------- [IPU1-0] 696.324162 s: 0 | 0 32.64 0. 0 0. 0 [IPU1-0] 696.324284 s: [IPU1-0] 696.324406 s: [ ALG_STITCHING ] LATENCY, [IPU1-0] 696.324467 s: ******************** [IPU1-0] 696.324528 s: Local Link Latency : Avg = 2919 us, Min = 2532 us, Max = 5551 us, [IPU1-0] 696.324650 s: Source to Link Latency : Avg = 204268 us, Min = 98957 us, Max = 377272 us, [IPU1-0] 696.324772 s: [IPU1-0] 696.324925 s: [IPU1-0] 696.324986 s: ### CPU [ DSP2], LinkID [ 0], [IPU1-0] 696.325047 s: [IPU1-0] 696.325108 s: [ IPC_OUT_0 ] Link Statistics, [IPU1-0] 696.325169 s: ****************************** [IPU1-0] 696.326846 s: [IPU1-0] 696.327121 s: Elapsed time = 678762 msec [IPU1-0] 696.327182 s: [IPU1-0] 696.327243 s: New data Recv = 16.32 fps [IPU1-0] 696.327304 s: Release data Recv = 16.33 fps [IPU1-0] 696.327365 s: Driver/Notify Cb = 116.31 fps [IPU1-0] 696.327456 s: [IPU1-0] 696.327487 s: Input Statistics, [IPU1-0] 696.327548 s: [IPU1-0] 696.327578 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 696.327670 s: | FPS | FPS | FPS | FPS [IPU1-0] 696.327731 s: -------------------------------------------------- [IPU1-0] 696.327822 s: 0 | 16.32 0. 0 0. 0 16.32 [IPU1-0] 696.327975 s: [IPU1-0] 696.328005 s: Output Statistics, [IPU1-0] 696.328066 s: [IPU1-0] 696.328097 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 696.328188 s: | ID | FPS | FPS | FPS [IPU1-0] 696.328249 s: --------------------------------------------- [IPU1-0] 696.328341 s: 0 | 0 16.32 0. 0 0. 0 [IPU1-0] 696.328432 s: [IPU1-0] 696.328493 s: [ IPC_OUT_0 ] LATENCY, [IPU1-0] 696.328554 s: ******************** [IPU1-0] 696.328615 s: Local Link Latency : Avg = 3 us, Min = 0 us, Max = 31 us, [IPU1-0] 696.328707 s: Source to Link Latency : Avg = 204351 us, Min = 99048 us, Max = 377338 us, [IPU1-0] 696.328829 s: [IPU1-0] 696.828005 s: [IPU1-0] 696.828066 s: ### CPU [IPU1-0], LinkID [ 12], [IPU1-0] 696.828158 s: [IPU1-0] 696.828188 s: [ IPC_IN_2 ] Link Statistics, [IPU1-0] 696.828249 s: ****************************** [IPU1-0] 696.828310 s: [IPU1-0] 696.828341 s: Elapsed time = 679264 msec [IPU1-0] 696.828432 s: [IPU1-0] 696.828463 s: Get Full Buf Cb = 16.31 fps [IPU1-0] 696.828524 s: Put Empty Buf Cb = 16.31 fps [IPU1-0] 696.828615 s: Driver/Notify Cb = 16.31 fps [IPU1-0] 696.828676 s: [IPU1-0] 696.828737 s: Input Statistics, [IPU1-0] 696.828768 s: [IPU1-0] 696.828798 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 696.828890 s: | FPS | FPS | FPS | FPS [IPU1-0] 696.828981 s: -------------------------------------------------- [IPU1-0] 696.829073 s: 0 | 16.31 0. 0 0. 0 16.31 [IPU1-0] 696.829195 s: [IPU1-0] 696.829225 s: Output Statistics, [IPU1-0] 696.829286 s: [IPU1-0] 696.829317 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 696.829408 s: | ID | FPS | FPS | FPS [IPU1-0] 696.829469 s: --------------------------------------------- [IPU1-0] 696.829561 s: 0 | 0 16.31 0. 0 0. 0 [IPU1-0] 696.829683 s: [IPU1-0] 696.829713 s: [ IPC_IN_2 ] LATENCY, [IPU1-0] 696.829774 s: ******************** [IPU1-0] 696.829835 s: Local Link Latency : Avg = 20 us, Min = 0 us, Max = 336 us, [IPU1-0] 696.830049 s: Source to Link Latency : Avg = 204638 us, Min = 99262 us, Max = 377521 us, [IPU1-0] 696.830171 s: [IPU1-0] 696.830293 s: [IPU1-0] 696.830323 s: ### CPU [IPU1-0], LinkID [ 67], [IPU1-0] 696.830415 s: [IPU1-0] 696.830445 s: [ DISPLAY ] Link Statistics, [IPU1-0] 696.830506 s: ****************************** [IPU1-0] 696.830567 s: [IPU1-0] 696.830598 s: Elapsed time = 679266 msec [IPU1-0] 696.830659 s: [IPU1-0] 696.830720 s: New data Recv = 16.31 fps [IPU1-0] 696.830781 s: Driver/Notify Cb = 65.56 fps [IPU1-0] 696.830872 s: [IPU1-0] 696.830933 s: Input Statistics, [IPU1-0] 696.830994 s: [IPU1-0] 696.831025 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 696.831116 s: | FPS | FPS | FPS | FPS [IPU1-0] 696.831177 s: -------------------------------------------------- [IPU1-0] 696.831269 s: 0 | 16.31 0. 0 0. 0 16.31 [IPU1-0] 696.831391 s: [IPU1-0] 696.831421 s: [ DISPLAY ] LATENCY, [IPU1-0] 696.831482 s: ******************** [IPU1-0] 696.831543 s: Local Link Latency : Avg = 67 us, Min = 30 us, Max = 1159 us, [IPU1-0] 696.831665 s: Source to Link Latency : Avg = 204905 us, Min = 99414 us, Max = 377669 us, [IPU1-0] 696.831757 s: [IPU1-0] 696.831818 s: Display UnderFlow Count = 0 [IPU1-0] 696.831879 s: [IPU1-0] 696.832977 s: CPU [ IPU1-0], LinkID [ 23], Link Statistics not available ! [IPU1-0] 696.833190 s: [IPU1-0] 696.833221 s: ### CPU [IPU1-0], LinkID [ 68], [IPU1-0] 696.833282 s: [IPU1-0] 696.833343 s: [ DISPLAY ] Link Statistics, [IPU1-0] 696.833404 s: ****************************** [IPU1-0] 696.833465 s: [IPU1-0] 696.833496 s: Elapsed time = 679493 msec [IPU1-0] 696.833587 s: [IPU1-0] 696.833618 s: Driver/Notify Cb = 65.56 fps [IPU1-0] 696.833709 s: [IPU1-0] 696.833740 s: Input Statistics, [IPU1-0] 696.833801 s: [IPU1-0] 696.833831 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 696.833923 s: | FPS | FPS | FPS | FPS [IPU1-0] 696.834014 s: -------------------------------------------------- [IPU1-0] 696.834075 s: 0 | 0. 0 0. 0 0. 0 0. 0 [IPU1-0] 696.834228 s: [IPU1-0] 696.834258 s: [ DISPLAY ] LATENCY, [IPU1-0] 696.834319 s: ******************** [IPU1-0] 696.834380 s: Local Link Latency : Avg = 30 us, Min = 30 us, Max = 30 us, [IPU1-0] 696.834502 s: Source to Link Latency : Avg = 1166748 us, Min = 1166748 us, Max = 1166748 us, [IPU1-0] 696.834624 s: [IPU1-0] 696.834655 s: Display UnderFlow Count = 0 [IPU1-0] 696.834716 s: [IPU1-0] 697.333953 s: [IPU1-0] [IPU1-0] ==================== [IPU1-0] Chains Run-time Menu [IPU1-0] ==================== [IPU1-0] [IPU1-0] 0: Stop Chain [IPU1-0] [IPU1-0] 1: Change Display Channel (Support 4CH LVDS + Mosaic use-case only) [IPU1-0] [IPU1-0] p: Print Performance Statistics [IPU1-0] [IPU1-0] t: Test Case for TEMPERATURE SENSOR TMP102 [IPU1-0] [IPU1-0] a: Test Case for AMBIENT LIGHT SENSOR [IPU1-0] [IPU1-0] g: Test Case for GPIO SWITCH [IPU1-0] [IPU1-0] n: Thermal Tests [IPU1-0] [IPU1-0] Enter Choice: [IPU1-0]
[IPU1-0] [IPU1-0] 1351.669859 s: [IPU1-0] 1351.669950 s: UTILS_PRCM_STATS: Current Temperature, [IPU1-0] 1351.670011 s: [IPU1-0] 1351.670042 s: Voltage Rail || Curr Temp Min - Max [IPU1-0] 1351.670133 s: --------------------------------------------------------- [IPU1-0] 1351.670225 s: PMHAL_PRCM_VD_CORE || [65.200 , 65.600] [IPU1-0] 1351.670316 s: [IPU1-0] 1351.670347 s: UTILS_TEMP: Voltage Domain [ PMHAL_PRCM_VD_CORE ] HOT Threshold = [0.0] [IPU1-0] 1351.670469 s: UTILS_TEMP: Voltage Domain [ PMHAL_PRCM_VD_CORE ] COLD Threshold = [0.0] [IPU1-0] 1351.670560 s: [IPU1-0] [IPU1-0] ==================== [IPU1-0] Chains Run-time Menu [IPU1-0] ==================== [IPU1-0] [IPU1-0] 0: Stop Chain [IPU1-0] [IPU1-0] 1: Change Display Channel (Support 4CH LVDS + Mosaic use-case only) [IPU1-0] [IPU1-0] p: Print Performance Statistics [IPU1-0] [IPU1-0] t: Test Case for TEMPERATURE SENSOR TMP102 [IPU1-0] [IPU1-0] a: Test Case for AMBIENT LIGHT SENSOR [IPU1-0] [IPU1-0] g: Test Case for GPIO SWITCH [IPU1-0] [IPU1-0] n: Thermal Tests [IPU1-0] [IPU1-0] Enter Choice: [IPU1-0] [IPU1-0] 1354.797718 s: [IPU1-0] 1354.797779 s: CPU [IPU1-0 ] Statistics, [IPU1-0] 1354.797840 s: ************************* [IPU1-0] 1354.797901 s: [IPU1-0] 1354.797932 s: LOAD: CPU: 13.4% HWI: 2.1%, SWI:0.9%, Low Power: 83.5% [IPU1-0] 1354.798084 s: [IPU1-0] 1354.798115 s: LOAD: TSK: DUP0 : 0.3% [IPU1-0] 1354.798267 s: LOAD: TSK: SELECT0 : 0.1% [IPU1-0] 1354.798359 s: LOAD: TSK: SELECT1 : 0.1% [IPU1-0] 1354.798450 s: LOAD: TSK: SYNC0 : 0.3% [IPU1-0] 1354.798511 s: LOAD: TSK: SYNC1 : 0.1% [IPU1-0] 1354.798603 s: LOAD: TSK: ISSCAPTURE : 0.4% [IPU1-0] 1354.798725 s: LOAD: TSK: ISSM2MISP : 2.2% [IPU1-0] 1354.798816 s: LOAD: TSK: ALGORITHM2 : 3.4% [IPU1-0] 1354.798938 s: LOAD: TSK: GrpxSrc0 : 0.1% [IPU1-0] 1354.798999 s: LOAD: TSK: STAT_COLL : 2.0% [IPU1-0] 1354.799091 s: LOAD: TSK: MISC : 1.4% [IPU1-0] 1354.800097 s: [IPU1-0] 1354.800158 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1019 [IPU1-0] 1354.800250 s: [IPU1-0] 1354.800280 s: SYSTEM: Sempahores Objects, 69 of 1000 free [IPU1-0] 1354.800372 s: SYSTEM: Task Objects , 14 of 100 free [IPU1-0] 1354.800463 s: SYSTEM: Clock Objects , 91 of 100 free [IPU1-0] 1354.800555 s: SYSTEM: Hwi Objects , 87 of 100 free [IPU1-0] 1354.800616 s: [IPU1-0] 1354.800707 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 140960 B (137 KB) [IPU1-0] 1354.800890 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB) [IPU1-0] 1354.801012 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x85703000, Total size = 369086464 B (351 MB), Free size = 159840256 B (152 MB) [IPU1-0] 1354.801195 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xbfc00000, Total size = 1046784 B (0 MB), Free size = 1039104 B (0 MB) [IPU1-0] 1354.801348 s: [IPU1-0] 1354.801409 s: [IPU1-0] 1354.801439 s: CPU [IPU1-1 ] Statistics, [IPU1-0] 1354.801500 s: ************************* [IPU1-0] 1354.801561 s: [IPU1-0] 1354.801592 s: LOAD: CPU: 0.9% HWI: 0.5%, SWI:0.3%, Low Power: 83.5% [IPU1-0] 1354.801988 s: [IPU1-0] 1354.802110 s: LOAD: TSK: MISC : 0.1% [IPU1-0] 1354.802202 s: [IPU1-0] 1354.802232 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1019 [IPU1-0] 1354.802324 s: [IPU1-0] 1354.802354 s: SYSTEM: Sempahores Objects, 407 of 1000 free [IPU1-0] 1354.802446 s: SYSTEM: Task Objects , 40 of 100 free [IPU1-0] 1354.802537 s: SYSTEM: Clock Objects , 99 of 100 free [IPU1-0] 1354.802629 s: SYSTEM: Hwi Objects , 99 of 100 free [IPU1-0] 1354.802720 s: [IPU1-0] 1354.802781 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 255168 B (249 KB) [IPU1-0] 1354.802934 s: [IPU1-0] 1354.802964 s: [IPU1-0] 1354.803025 s: CPU [DSP1 ] Statistics, [IPU1-0] 1354.803086 s: ************************* [IPU1-0] 1354.803147 s: [IPU1-0] 1354.803178 s: LOAD: CPU: 0.3% HWI: 0.0%, SWI:0.0%, Low Power: 99.0% [IPU1-0] 1354.803330 s: [IPU1-0] 1354.803361 s: LOAD: TSK: MISC : 0.3% [IPU1-0] 1354.803452 s: [IPU1-0] 1354.803483 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1019 [IPU1-0] 1354.803574 s: [IPU1-0] 1354.803605 s: SYSTEM: Sempahores Objects, 410 of 1000 free [IPU1-0] 1354.803818 s: SYSTEM: Task Objects , 92 of 100 free [IPU1-0] 1354.803940 s: SYSTEM: Clock Objects , 98 of 100 free [IPU1-0] 1354.804032 s: SYSTEM: Hwi Objects , 100 of 100 free [IPU1-0] 1354.804093 s: [IPU1-0] 1354.804154 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 201984 B (197 KB) [IPU1-0] 1354.804306 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 511704 B (499 KB) [IPU1-0] 1354.804459 s: [IPU1-0] 1354.804489 s: [IPU1-0] 1354.804550 s: CPU [DSP2 ] Statistics, [IPU1-0] 1354.804611 s: ************************* [IPU1-0] 1354.804642 s: [IPU1-0] 1354.804733 s: LOAD: CPU: 0.3% HWI: 0.0%, SWI:0.0%, Low Power: 99.1% [IPU1-0] 1354.804886 s: [IPU1-0] 1354.805770 s: LOAD: TSK: MISC : 0.3% [IPU1-0] 1354.805892 s: [IPU1-0] 1354.805923 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022 [IPU1-0] 1354.806014 s: [IPU1-0] 1354.806045 s: SYSTEM: Sempahores Objects, 409 of 1000 free [IPU1-0] 1354.806136 s: SYSTEM: Task Objects , 92 of 100 free [IPU1-0] 1354.806197 s: SYSTEM: Clock Objects , 98 of 100 free [IPU1-0] 1354.806289 s: SYSTEM: Hwi Objects , 100 of 100 free [IPU1-0] 1354.806380 s: [IPU1-0] 1354.806411 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 27264 B (26 KB) [IPU1-0] 1354.806563 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 519408 B (507 KB) [IPU1-0] 1354.806899 s: [IPU1-0] 1354.806960 s: [IPU1-0] 1354.806990 s: CPU [EVE1 ] Statistics, [IPU1-0] 1354.807143 s: ************************* [IPU1-0] 1354.807204 s: [IPU1-0] 1354.807265 s: LOAD: CPU: 0.7% HWI: 0.1%, SWI:0.2%, Low Power: 94.8% [IPU1-0] 1354.807387 s: [IPU1-0] 1354.807448 s: LOAD: TSK: SYSTEM : 0.2% [IPU1-0] 1354.807539 s: LOAD: TSK: MISC : 0.2% [IPU1-0] 1354.807600 s: [IPU1-0] 1354.807661 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022 [IPU1-0] 1354.807783 s: [IPU1-0] 1354.807814 s: SYSTEM: Sempahores Objects, 411 of 1000 free [IPU1-0] 1354.807905 s: SYSTEM: Task Objects , 93 of 100 free [IPU1-0] 1354.807997 s: SYSTEM: Clock Objects , 98 of 100 free [IPU1-0] 1354.808058 s: SYSTEM: Hwi Objects , 99 of 100 free [IPU1-0] 1354.808149 s: [IPU1-0] 1354.808180 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 17632 B (17 KB) [IPU1-0] 1354.808332 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 245456 B (239 KB) [IPU1-0] 1354.808515 s: [IPU1-0] 1354.808881 s: [IPU1-0] 1354.808942 s: UTILS_PRCM_STATS: Current Temperature, [IPU1-0] 1354.809003 s: [IPU1-0] 1354.809034 s: Voltage Rail || Curr Temp Min - Max [IPU1-0] 1354.809125 s: --------------------------------------------------------- [IPU1-0] 1354.809217 s: PMHAL_PRCM_VD_CORE || [65.600 , 66. 0] [IPU1-0] 1354.809308 s: [IPU1-0] 1354.809461 s: [IPU1-0] 1354.809491 s: Statistics Collector, [IPU1-0] 1354.809552 s: [IPU1-0] 1354.809644 s: STATISTIC Avg Data Peak Data [IPU1-0] 1354.809766 s: COLLECTOR MB/s MB/s [IPU1-0] 1354.809857 s: -------------------------------------------------- [IPU1-0] 1354.809949 s: SCI_EMIF_SYS | 541.131053 1394.020546 [IPU1-0] 1354.810040 s: SCI_IPU | 10.220202 36.366454 [IPU1-0] 1354.810162 s: SCI_DSP1_MDMA | 0.068832 10.842063 [IPU1-0] 1354.810254 s: SCI_DSP2_MDMA | 0.069095 11.482606 [IPU1-0] 1354.810376 s: SCI_DSS | 211.152533 350.584070 [IPU1-0] 1354.810467 s: SCI_MMU | 0.000000 0.000000 [IPU1-0] 1354.810650 s: SCI_EDMA_TC0_RD | 0.000000 0.000000 [IPU1-0] 1354.810772 s: SCI_EDMA_TC0_WR | 0.000000 0.000000 [IPU1-0] 1354.810864 s: SCI_VIP_P1 | 0.000000 0.000000 [IPU1-0] 1354.810955 s: SCI_VIP_P2 | 0.000000 0.000000 [IPU1-0] 1354.811077 s: SCI_ISS_RT | 220.705268 339.007877 [IPU1-0] 1354.811169 s: SCI_ISS_NRT2 | 0.000000 0.000000 [IPU1-0] 1354.811291 s: SCI_EVE_P1 | 3.228687 20.422231 [IPU1-0] 1354.811382 s: SCI_EVE_P2 | 0.000000 0.000000 [IPU1-0] 1354.811474 s: SCI_GMAC_SW | 0.000000 0.000000 [IPU1-0] 1354.811565 s: SCI_ISS_NRT1 | 96.783832 690.168042 [IPU1-0] 1354.811840 s: SCI_DSP2_CFG | 0.000000 0.000000 [IPU1-0] 1354.811962 s: SCI_DSP2_EDMA | 0.000000 0.000000 [IPU1-0] 1354.812053 s: SCI_OCMC_RAM | 0.000000 0.000000 [IPU1-0] 1354.812145 s: SCI_DSP1_CFG | 0.000000 0.000000 [IPU1-0] 1354.812236 s: SCI_DSP1_EDMA | 0.000000 0.000000 [IPU1-0] 1354.812328 s: SCI_GPMC | 0.000000 0.000000 [IPU1-0] 1354.812450 s: SCI_MCASP | 0.000000 0.000000 [IPU1-0] 1354.812541 s: SCI_EDMA_TC1_RD | 0.000000 0.000000 [IPU1-0] 1354.812633 s: SCI_EDMA_TC1_WR | 0.000000 0.000000 [IPU1-0] 1354.912706 s: [IPU1-0] 1354.912767 s: [IPU1-0] 1354.912859 s: [IPU1-0] 1354.912920 s: ### CPU [IPU1-0], LinkID [ 77], [IPU1-0] 1354.912981 s: [IPU1-0] 1354.913011 s: [ ISSCAPTURE ] Link Statistics, [IPU1-0] 1354.913072 s: ****************************** [IPU1-0] 1354.913133 s: [IPU1-0] 1354.913194 s: Elapsed time = 662160 msec [IPU1-0] 1354.913255 s: [IPU1-0] 1354.913286 s: Get Full Buf Cb = 119.98 fps [IPU1-0] 1354.913377 s: Put Empty Buf Cb = 29.99 fps [IPU1-0] 1354.913438 s: Driver/Notify Cb = 119.98 fps [IPU1-0] 1354.913530 s: [IPU1-0] 1354.913560 s: Input Statistics, [IPU1-0] 1354.913621 s: [IPU1-0] 1354.913713 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1354.913865 s: | FPS | FPS | FPS | FPS [IPU1-0] 1354.913926 s: -------------------------------------------------- [IPU1-0] 1354.914018 s: 0 | 29.99 0. 0 0. 0 29.99 [IPU1-0] 1354.914201 s: 1 | 29.99 0. 0 0. 0 29.99 [IPU1-0] 1354.914353 s: 2 | 29.99 0. 0 0. 0 29.99 [IPU1-0] 1354.914475 s: 3 | 29.99 0. 0 0. 0 29.99 [IPU1-0] 1354.914597 s: [IPU1-0] 1354.914628 s: Output Statistics, [IPU1-0] 1354.914719 s: [IPU1-0] 1354.914750 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1354.914811 s: | ID | FPS | FPS | FPS [IPU1-0] 1354.914902 s: --------------------------------------------- [IPU1-0] 1354.914963 s: 0 | 0 29.99 0. 0 0. 0 [IPU1-0] 1354.915085 s: 1 | 0 29.99 0. 0 0. 0 [IPU1-0] 1354.915207 s: 2 | 0 29.99 0. 0 0. 0 [IPU1-0] 1354.915329 s: 3 | 0 29.99 0. 0 0. 0 [IPU1-0] 1354.915451 s: [IPU1-0] 1354.915482 s: [ ISSCAPTURE ] LATENCY, [IPU1-0] 1354.915543 s: ******************** [IPU1-0] 1354.915604 s: [IPU1-0] 1354.915695 s: [IPU1-0] 1354.915756 s: ### CPU [IPU1-0], LinkID [ 78], [IPU1-0] 1354.915817 s: [IPU1-0] 1354.915878 s: [ ISSM2MISP ] Link Statistics, [IPU1-0] 1354.915939 s: ****************************** [IPU1-0] 1354.916000 s: [IPU1-0] 1354.916031 s: Elapsed time = 662156 msec [IPU1-0] 1354.916092 s: [IPU1-0] 1354.916153 s: New data Recv = 119.98 fps [IPU1-0] 1354.916214 s: Get Full Buf Cb = 59.98 fps [IPU1-0] 1354.916305 s: Driver/Notify Cb = 57.11 fps [IPU1-0] 1354.916366 s: [IPU1-0] 1354.916397 s: Input Statistics, [IPU1-0] 1354.916458 s: [IPU1-0] 1354.916488 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1354.916580 s: | FPS | FPS | FPS | FPS [IPU1-0] 1354.916641 s: -------------------------------------------------- [IPU1-0] 1354.916854 s: 0 | 29.99 20.95 0. 0 9. 4 [IPU1-0] 1354.917007 s: 1 | 29.99 20.95 0. 0 9. 4 [IPU1-0] 1354.917159 s: 2 | 29.99 0. 0 0. 0 29.99 [IPU1-0] 1354.917281 s: 3 | 29.99 20.95 0. 0 9. 4 [IPU1-0] 1354.917403 s: [IPU1-0] 1354.917434 s: Output Statistics, [IPU1-0] 1354.917495 s: [IPU1-0] 1354.917556 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1354.917617 s: | ID | FPS | FPS | FPS [IPU1-0] 1354.917708 s: --------------------------------------------- [IPU1-0] 1354.917800 s: 0 | 0 9. 4 20.95 0. 0 [IPU1-0] 1354.917922 s: 1 | 0 9. 4 20.95 0. 0 [IPU1-0] 1354.918044 s: 2 | 0 29.99 0. 0 0. 0 [IPU1-0] 1354.918166 s: 3 | 0 9. 4 20.95 0. 0 [IPU1-0] 1354.918257 s: [IPU1-0] 1354.918318 s: [ ISSM2MISP ] LATENCY, [IPU1-0] 1354.918379 s: ******************** [IPU1-0] 1354.918410 s: Local Link Latency : Avg = 5377 us, Min = 5276 us, Max = 5826 us, [IPU1-0] 1354.918532 s: Source to Link Latency : Avg = 10549 us, Min = 5429 us, Max = 22174 us, [IPU1-0] 1354.918654 s: [IPU1-0] 1354.918776 s: [IPU1-0] 1354.918806 s: ### CPU [IPU1-0], LinkID [ 51], [IPU1-0] 1354.918867 s: [IPU1-0] 1354.918928 s: [ ALG_ISS_AEWB ] Link Statistics, [IPU1-0] 1354.918989 s: ****************************** [IPU1-0] 1354.919050 s: [IPU1-0] 1354.919081 s: Elapsed time = 662159 msec [IPU1-0] 1354.919142 s: [IPU1-0] 1354.919203 s: New data Recv = 29.99 fps [IPU1-0] 1354.919264 s: [IPU1-0] 1354.919325 s: Input Statistics, [IPU1-0] 1354.919355 s: [IPU1-0] 1354.919386 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1354.919477 s: | FPS | FPS | FPS | FPS [IPU1-0] 1354.919538 s: -------------------------------------------------- [IPU1-0] 1354.919630 s: 0 | 9. 4 0. 0 0. 0 9. 4 [IPU1-0] 1354.919782 s: 1 | 9. 4 0. 0 0. 0 9. 4 [IPU1-0] 1354.919904 s: 2 | 29.99 0. 0 0. 0 29.99 [IPU1-0] 1354.920026 s: 3 | 9. 4 0. 0 0. 0 9. 4 [IPU1-0] 1354.920179 s: [IPU1-0] 1354.920209 s: Output Statistics, [IPU1-0] 1354.920270 s: [IPU1-0] 1354.920301 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1354.920362 s: | ID | FPS | FPS | FPS [IPU1-0] 1354.920453 s: --------------------------------------------- [IPU1-0] 1354.920514 s: 0 | 0 9. 4 0. 0 0. 0 [IPU1-0] 1354.920636 s: 1 | 0 9. 4 0. 0 0. 0 [IPU1-0] 1354.920758 s: 2 | 0 29.99 0. 0 0. 0 [IPU1-0] 1354.920880 s: 3 | 0 9. 4 0. 0 0. 0 [IPU1-0] 1354.921002 s: [IPU1-0] 1354.921033 s: [ ALG_ISS_AEWB ] LATENCY, [IPU1-0] 1354.921094 s: ******************** [IPU1-0] 1354.921155 s: Local Link Latency : Avg = 1635 us, Min = 61 us, Max = 12749 us, [IPU1-0] 1354.921277 s: Source to Link Latency : Avg = 19976 us, Min = 6100 us, Max = 54444 us, [IPU1-0] 1354.921368 s: [IPU1-0] 1354.921429 s: CPU [ IPU1-0], LinkID [ 25], Link Statistics not available ! [IPU1-0] 1354.921551 s: CPU [ IPU1-0], LinkID [ 46], Link Statistics not available ! [IPU1-0] 1354.921643 s: CPU [ IPU1-0], LinkID [ 43], Link Statistics not available ! [IPU1-0] 1354.921917 s: [IPU1-0] 1354.921948 s: ### CPU [IPU1-0], LinkID [ 34], [IPU1-0] 1354.922039 s: [IPU1-0] 1354.922070 s: [ SYNC_0 ] Link Statistics, [IPU1-0] 1354.922131 s: ****************************** [IPU1-0] 1354.922192 s: [IPU1-0] 1354.922222 s: Elapsed time = 662150 msec [IPU1-0] 1354.922314 s: [IPU1-0] 1354.922344 s: New data Recv = 60.6 fps [IPU1-0] 1354.922405 s: Get Full Buf Cb = 9.4 fps [IPU1-0] 1354.922497 s: Put Empty Buf Cb = 9.4 fps [IPU1-0] 1354.922558 s: Driver/Notify Cb = 30.30 fps [IPU1-0] 1354.922619 s: [IPU1-0] 1354.922680 s: Input Statistics, [IPU1-0] 1354.922741 s: [IPU1-0] 1354.922771 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1354.922863 s: | FPS | FPS | FPS | FPS [IPU1-0] 1354.922924 s: -------------------------------------------------- [IPU1-0] 1354.923015 s: 0 | 29.99 20.95 0. 0 9. 4 [IPU1-0] 1354.923137 s: 1 | 9. 4 0. 0 0. 0 9. 4 [IPU1-0] 1354.923259 s: [IPU1-0] 1354.923320 s: Output Statistics, [IPU1-0] 1354.923351 s: [IPU1-0] 1354.923381 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1354.923473 s: | ID | FPS | FPS | FPS [IPU1-0] 1354.923534 s: --------------------------------------------- [IPU1-0] 1354.923625 s: 0 | 0 9. 4 0. 0 0. 0 [IPU1-0] 1354.923747 s: [IPU1-0] 1354.923778 s: [ SYNC_0 ] LATENCY, [IPU1-0] 1354.923839 s: ******************** [IPU1-0] 1354.923900 s: Local Link Latency : Avg = 42 us, Min = 0 us, Max = 183 us, [IPU1-0] 1354.923991 s: Source to Link Latency : Avg = 21978 us, Min = 11407 us, Max = 22739 us, [IPU1-0] 1354.924113 s: [IPU1-0] 1354.924205 s: [IPU1-0] 1354.924235 s: ### CPU [IPU1-0], LinkID [ 49], [IPU1-0] 1354.924327 s: [IPU1-0] 1354.924357 s: [ ALG_DEWARP ] Link Statistics, [IPU1-0] 1354.924418 s: ****************************** [IPU1-0] 1354.924479 s: [IPU1-0] 1354.924510 s: Elapsed time = 662082 msec [IPU1-0] 1354.924601 s: [IPU1-0] 1354.924632 s: New data Recv = 9.4 fps [IPU1-0] 1354.924723 s: [IPU1-0] 1354.924754 s: Input Statistics, [IPU1-0] 1354.924815 s: [IPU1-0] 1354.924845 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1354.924906 s: | FPS | FPS | FPS | FPS [IPU1-0] 1354.924998 s: -------------------------------------------------- [IPU1-0] 1354.925059 s: 0 | 9. 4 0. 0 0. 0 9. 4 [IPU1-0] 1354.925181 s: [IPU1-0] 1354.925242 s: Output Statistics, [IPU1-0] 1354.925272 s: [IPU1-0] 1354.925333 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1354.925394 s: | ID | FPS | FPS | FPS [IPU1-0] 1354.925455 s: --------------------------------------------- [IPU1-0] 1354.925547 s: 0 | 0 9. 4 0. 0 0. 0 [IPU1-0] 1354.925638 s: [IPU1-0] 1354.925699 s: [ ALG_DEWARP ] LATENCY, [IPU1-0] 1354.925760 s: ******************** [IPU1-0] 1354.925821 s: Local Link Latency : Avg = 7452 us, Min = 3202 us, Max = 20283 us, [IPU1-0] 1354.925913 s: Source to Link Latency : Avg = 29755 us, Min = 15220 us, Max = 42747 us, [IPU1-0] 1354.926035 s: [IPU1-0] 1354.926096 s: CPU [ IPU1-0], LinkID [ 26], Link Statistics not available ! [IPU1-0] 1354.926249 s: [IPU1-0] 1354.926279 s: ### CPU [IPU1-0], LinkID [ 0], [IPU1-0] 1354.926340 s: [IPU1-0] 1354.926401 s: [ IPC_OUT_0 ] Link Statistics, [IPU1-0] 1354.926462 s: ****************************** [IPU1-0] 1354.926523 s: [IPU1-0] 1354.926554 s: Elapsed time = 662081 msec [IPU1-0] 1354.926615 s: [IPU1-0] 1354.926645 s: New data Recv = 9.4 fps [IPU1-0] 1354.926859 s: Release data Recv = 9.4 fps [IPU1-0] 1354.926920 s: Driver/Notify Cb = 109.3 fps [IPU1-0] 1354.927011 s: [IPU1-0] 1354.927042 s: Input Statistics, [IPU1-0] 1354.927103 s: [IPU1-0] 1354.927133 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1354.927225 s: | FPS | FPS | FPS | FPS [IPU1-0] 1354.927286 s: -------------------------------------------------- [IPU1-0] 1354.927377 s: 0 | 9. 4 0. 0 0. 0 9. 4 [IPU1-0] 1354.927499 s: [IPU1-0] 1354.927530 s: Output Statistics, [IPU1-0] 1354.927591 s: [IPU1-0] 1354.927621 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1354.927743 s: | ID | FPS | FPS | FPS [IPU1-0] 1354.927804 s: --------------------------------------------- [IPU1-0] 1354.927865 s: 0 | 0 9. 4 0. 0 0. 0 [IPU1-0] 1354.927987 s: [IPU1-0] 1354.928048 s: [ IPC_OUT_0 ] LATENCY, [IPU1-0] 1354.928079 s: ******************** [IPU1-0] 1354.928140 s: Local Link Latency : Avg = 7 us, Min = 0 us, Max = 92 us, [IPU1-0] 1354.928262 s: Source to Link Latency : Avg = 29920 us, Min = 15373 us, Max = 42899 us, [IPU1-0] 1354.928353 s: [IPU1-0] 1355.427774 s: [IPU1-0] 1355.427835 s: ### CPU [ EVE1], LinkID [ 10], [IPU1-0] 1355.427926 s: [IPU1-0] 1355.427957 s: [ IPC_IN_0 ] Link Statistics, [IPU1-0] 1355.428018 s: ****************************** [IPU1-0] 1355.428079 s: [IPU1-0] 1355.428109 s: Elapsed time = 662148 msec [IPU1-0] 1355.428201 s: [IPU1-0] 1355.428231 s: Get Full Buf Cb = 9.3 fps [IPU1-0] 1355.428292 s: Put Empty Buf Cb = 9.3 fps [IPU1-0] 1355.428384 s: Driver/Notify Cb = 9.3 fps [IPU1-0] 1355.428445 s: [IPU1-0] 1355.428475 s: Input Statistics, [IPU1-0] 1355.428536 s: [IPU1-0] 1355.428567 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1355.428658 s: | FPS | FPS | FPS | FPS [IPU1-0] 1355.428841 s: -------------------------------------------------- [IPU1-0] 1355.428902 s: 0 | 9. 3 0. 0 0. 0 9. 3 [IPU1-0] 1355.429116 s: [IPU1-0] 1355.429146 s: Output Statistics, [IPU1-0] 1355.429207 s: [IPU1-0] 1355.429238 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1355.429299 s: | ID | FPS | FPS | FPS [IPU1-0] 1355.429390 s: --------------------------------------------- [IPU1-0] 1355.429451 s: 0 | 0 9. 3 0. 0 0. 0 [IPU1-0] 1355.429573 s: [IPU1-0] 1355.429604 s: [ IPC_IN_0 ] LATENCY, [IPU1-0] 1355.429665 s: ******************** [IPU1-0] 1355.429756 s: Local Link Latency : Avg = 38 us, Min = 30 us, Max = 122 us, [IPU1-0] 1355.429878 s: Source to Link Latency : Avg = 30205 us, Min = 15647 us, Max = 43235 us, [IPU1-0] 1355.429970 s: [IPU1-0] 1355.430061 s: [IPU1-0] 1355.430122 s: ### CPU [ EVE1], LinkID [ 50], [IPU1-0] 1355.430183 s: [IPU1-0] 1355.430214 s: [ ALG_CENSUS ] Link Statistics, [IPU1-0] 1355.430305 s: ****************************** [IPU1-0] 1355.430366 s: [IPU1-0] 1355.430397 s: Elapsed time = 662151 msec [IPU1-0] 1355.430458 s: [IPU1-0] 1355.430488 s: New data Recv = 9.3 fps [IPU1-0] 1355.430580 s: [IPU1-0] 1355.430610 s: Input Statistics, [IPU1-0] 1355.430671 s: [IPU1-0] 1355.430793 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1355.430885 s: | FPS | FPS | FPS | FPS [IPU1-0] 1355.430946 s: -------------------------------------------------- [IPU1-0] 1355.431037 s: 0 | 9. 3 0. 0 0. 0 9. 3 [IPU1-0] 1355.431159 s: 1 | 9. 3 0. 0 0. 0 9. 3 [IPU1-0] 1355.431281 s: [IPU1-0] 1355.431312 s: Output Statistics, [IPU1-0] 1355.431373 s: [IPU1-0] 1355.431403 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1355.431495 s: | ID | FPS | FPS | FPS [IPU1-0] 1355.431556 s: --------------------------------------------- [IPU1-0] 1355.431617 s: 0 | 0 9. 3 0. 0 0. 0 [IPU1-0] 1355.431891 s: 1 | 0 9. 3 0. 0 0. 0 [IPU1-0] 1355.432013 s: [IPU1-0] 1355.432044 s: [ ALG_CENSUS ] LATENCY, [IPU1-0] 1355.432105 s: ******************** [IPU1-0] 1355.432196 s: Local Link Latency : Avg = 2849 us, Min = 2776 us, Max = 3172 us, [IPU1-0] 1355.432318 s: Source to Link Latency : Avg = 33201 us, Min = 18606 us, Max = 46224 us, [IPU1-0] 1355.432501 s: [IPU1-0] 1355.433508 s: [IPU1-0] 1355.433569 s: ### CPU [ EVE1], LinkID [ 49], [IPU1-0] 1355.433660 s: [IPU1-0] 1355.433721 s: [ ALG_DISPARITY ] Link Statistics, [IPU1-0] 1355.433813 s: ****************************** [IPU1-0] 1355.433874 s: [IPU1-0] 1355.433904 s: Elapsed time = 662151 msec [IPU1-0] 1355.433996 s: [IPU1-0] 1355.434026 s: New data Recv = 9.3 fps [IPU1-0] 1355.434087 s: [IPU1-0] 1355.434148 s: Input Statistics, [IPU1-0] 1355.434179 s: [IPU1-0] 1355.434240 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1355.434301 s: | FPS | FPS | FPS | FPS [IPU1-0] 1355.434392 s: -------------------------------------------------- [IPU1-0] 1355.434484 s: 0 | 9. 3 0. 0 0. 0 9. 3 [IPU1-0] 1355.434606 s: [IPU1-0] 1355.434636 s: Output Statistics, [IPU1-0] 1355.434697 s: [IPU1-0] 1355.434758 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1355.434819 s: | ID | FPS | FPS | FPS [IPU1-0] 1355.434911 s: --------------------------------------------- [IPU1-0] 1355.434972 s: 0 | 0 9. 3 0. 0 0. 0 [IPU1-0] 1355.435094 s: [IPU1-0] 1355.435124 s: [ ALG_DISPARITY ] LATENCY, [IPU1-0] 1355.435216 s: ******************** [IPU1-0] 1355.435246 s: Local Link Latency : Avg = 19764 us, Min = 19642 us, Max = 19948 us, [IPU1-0] 1355.435368 s: Source to Link Latency : Avg = 53143 us, Min = 38553 us, Max = 66141 us, [IPU1-0] 1355.435490 s: [IPU1-0] 1355.435612 s: [IPU1-0] 1355.435643 s: ### CPU [ EVE1], LinkID [ 0], [IPU1-0] 1355.435734 s: [IPU1-0] 1355.435765 s: [ IPC_OUT_0 ] Link Statistics, [IPU1-0] 1355.435856 s: ****************************** [IPU1-0] 1355.435917 s: [IPU1-0] 1355.435948 s: Elapsed time = 662133 msec [IPU1-0] 1355.436009 s: [IPU1-0] 1355.436070 s: New data Recv = 9.3 fps [IPU1-0] 1355.436131 s: Release data Recv = 9.3 fps [IPU1-0] 1355.436222 s: Driver/Notify Cb = 19.3 fps [IPU1-0] 1355.436283 s: [IPU1-0] 1355.436314 s: Input Statistics, [IPU1-0] 1355.436375 s: [IPU1-0] 1355.436405 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1355.436497 s: | FPS | FPS | FPS | FPS [IPU1-0] 1355.436558 s: -------------------------------------------------- [IPU1-0] 1355.436649 s: 0 | 9. 3 0. 0 0. 0 9. 3 [IPU1-0] 1355.436954 s: [IPU1-0] 1355.436985 s: Output Statistics, [IPU1-0] 1355.437046 s: [IPU1-0] 1355.437076 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1355.437168 s: | ID | FPS | FPS | FPS [IPU1-0] 1355.437229 s: --------------------------------------------- [IPU1-0] 1355.437320 s: 0 | 0 9. 3 0. 0 0. 0 [IPU1-0] 1355.437442 s: [IPU1-0] 1355.437473 s: [ IPC_OUT_0 ] LATENCY, [IPU1-0] 1355.437534 s: ******************** [IPU1-0] 1355.437595 s: Local Link Latency : Avg = 23 us, Min = 0 us, Max = 92 us, [IPU1-0] 1355.437747 s: Source to Link Latency : Avg = 53329 us, Min = 38736 us, Max = 66324 us, [IPU1-0] 1355.437869 s: [IPU1-0] 1355.937808 s: [IPU1-0] 1355.937900 s: ### CPU [IPU1-0], LinkID [ 10], [IPU1-0] 1355.937961 s: [IPU1-0] 1355.938022 s: [ IPC_IN_0 ] Link Statistics, [IPU1-0] 1355.938083 s: ****************************** [IPU1-0] 1355.938144 s: [IPU1-0] 1355.939150 s: Elapsed time = 662086 msec [IPU1-0] 1355.939242 s: [IPU1-0] 1355.939272 s: Get Full Buf Cb = 18.5 fps [IPU1-0] 1355.939364 s: Put Empty Buf Cb = 9.2 fps [IPU1-0] 1355.939425 s: Driver/Notify Cb = 9.2 fps [IPU1-0] 1355.939516 s: [IPU1-0] 1355.939547 s: Input Statistics, [IPU1-0] 1355.939608 s: [IPU1-0] 1355.939638 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1355.939760 s: | FPS | FPS | FPS | FPS [IPU1-0] 1355.939852 s: -------------------------------------------------- [IPU1-0] 1355.939913 s: 0 | 9. 2 0. 0 0. 0 9. 2 [IPU1-0] 1355.940065 s: [IPU1-0] 1355.940096 s: Output Statistics, [IPU1-0] 1355.940157 s: [IPU1-0] 1355.940187 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1355.940248 s: | ID | FPS | FPS | FPS [IPU1-0] 1355.940340 s: --------------------------------------------- [IPU1-0] 1355.940401 s: 0 | 0 9. 2 0. 0 0. 0 [IPU1-0] 1355.940523 s: [IPU1-0] 1355.940553 s: [ IPC_IN_0 ] LATENCY, [IPU1-0] 1355.940614 s: ******************** [IPU1-0] 1355.940675 s: Local Link Latency : Avg = 18 us, Min = 0 us, Max = 122 us, [IPU1-0] 1355.940797 s: Source to Link Latency : Avg = 53533 us, Min = 38980 us, Max = 66690 us, [IPU1-0] 1355.940919 s: [IPU1-0] 1355.940980 s: CPU [ IPU1-0], LinkID [ 39], Link Statistics not available ! [IPU1-0] 1355.941133 s: [IPU1-0] 1355.941163 s: ### CPU [IPU1-0], LinkID [ 1], [IPU1-0] 1355.941255 s: [IPU1-0] 1355.941285 s: [ IPC_OUT_1 ] Link Statistics, [IPU1-0] 1355.941346 s: ****************************** [IPU1-0] 1355.941407 s: [IPU1-0] 1355.941438 s: Elapsed time = 662113 msec [IPU1-0] 1355.941529 s: [IPU1-0] 1355.941560 s: New data Recv = 18.5 fps [IPU1-0] 1355.941621 s: Release data Recv = 9.4 fps [IPU1-0] 1355.941865 s: Driver/Notify Cb = 109.2 fps [IPU1-0] 1355.941956 s: [IPU1-0] 1355.941987 s: Input Statistics, [IPU1-0] 1355.942048 s: [IPU1-0] 1355.942078 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1355.942170 s: | FPS | FPS | FPS | FPS [IPU1-0] 1355.942231 s: -------------------------------------------------- [IPU1-0] 1355.942322 s: 0 | 9. 2 0. 0 0. 0 9. 2 [IPU1-0] 1355.942444 s: 1 | 9. 2 0. 0 0. 0 9. 2 [IPU1-0] 1355.942566 s: [IPU1-0] 1355.942597 s: Output Statistics, [IPU1-0] 1355.942658 s: [IPU1-0] 1355.942719 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1355.942810 s: | ID | FPS | FPS | FPS [IPU1-0] 1355.942871 s: --------------------------------------------- [IPU1-0] 1355.942932 s: 0 | 0 9. 2 0. 0 0. 0 [IPU1-0] 1355.943054 s: 1 | 0 9. 2 0. 0 0. 0 [IPU1-0] 1355.943176 s: [IPU1-0] 1355.943207 s: [ IPC_OUT_1 ] LATENCY, [IPU1-0] 1355.943268 s: ******************** [IPU1-0] 1355.943329 s: Local Link Latency : Avg = 7 us, Min = 0 us, Max = 92 us, [IPU1-0] 1355.943451 s: Source to Link Latency : Avg = 41889 us, Min = 15525 us, Max = 66842 us, [IPU1-0] 1355.943542 s: [IPU1-0] 1356.442810 s: [IPU1-0] 1356.442871 s: ### CPU [ DSP1], LinkID [ 10], [IPU1-0] 1356.442963 s: [IPU1-0] 1356.442993 s: [ IPC_IN_0 ] Link Statistics, [IPU1-0] 1356.443054 s: ****************************** [IPU1-0] 1356.443115 s: [IPU1-0] 1356.443146 s: Elapsed time = 662080 msec [IPU1-0] 1356.443237 s: [IPU1-0] 1356.443268 s: Get Full Buf Cb = 18.4 fps [IPU1-0] 1356.443329 s: Put Empty Buf Cb = 18.4 fps [IPU1-0] 1356.443420 s: Driver/Notify Cb = 18.3 fps [IPU1-0] 1356.443481 s: [IPU1-0] 1356.443512 s: Input Statistics, [IPU1-0] 1356.443573 s: [IPU1-0] 1356.443603 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1356.443695 s: | FPS | FPS | FPS | FPS [IPU1-0] 1356.443786 s: -------------------------------------------------- [IPU1-0] 1356.443878 s: 0 | 9. 2 0. 0 0. 0 9. 2 [IPU1-0] 1356.444000 s: 1 | 9. 2 0. 0 0. 0 9. 2 [IPU1-0] 1356.444122 s: [IPU1-0] 1356.444152 s: Output Statistics, [IPU1-0] 1356.444274 s: [IPU1-0] 1356.444305 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1356.444366 s: | ID | FPS | FPS | FPS [IPU1-0] 1356.444458 s: --------------------------------------------- [IPU1-0] 1356.444519 s: 0 | 0 9. 2 0. 0 0. 0 [IPU1-0] 1356.444641 s: 1 | 0 9. 2 0. 0 0. 0 [IPU1-0] 1356.444793 s: [IPU1-0] 1356.444824 s: [ IPC_IN_0 ] LATENCY, [IPU1-0] 1356.444885 s: ******************** [IPU1-0] 1356.444946 s: Local Link Latency : Avg = 9 us, Min = 0 us, Max = 31 us, [IPU1-0] 1356.445037 s: Source to Link Latency : Avg = 41990 us, Min = 15617 us, Max = 66934 us, [IPU1-0] 1356.445159 s: [IPU1-0] 1356.445251 s: [IPU1-0] 1356.445312 s: ### CPU [ DSP1], LinkID [ 49], [IPU1-0] 1356.445373 s: [IPU1-0] 1356.445403 s: [ ALG_STEREO_POSTPROCESS ] Link Statistics, [IPU1-0] 1356.445495 s: ****************************** [IPU1-0] 1356.445556 s: [IPU1-0] 1356.445586 s: Elapsed time = 662083 msec [IPU1-0] 1356.445678 s: [IPU1-0] 1356.445708 s: New data Recv = 18.4 fps [IPU1-0] 1356.445800 s: [IPU1-0] 1356.445830 s: Input Statistics, [IPU1-0] 1356.445891 s: [IPU1-0] 1356.445922 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1356.445983 s: | FPS | FPS | FPS | FPS [IPU1-0] 1356.446074 s: -------------------------------------------------- [IPU1-0] 1356.446166 s: 0 | 9. 2 0. 0 0. 0 9. 2 [IPU1-0] 1356.446288 s: [IPU1-0] 1356.446318 s: Output Statistics, [IPU1-0] 1356.446379 s: [IPU1-0] 1356.446410 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1356.446471 s: | ID | FPS | FPS | FPS [IPU1-0] 1356.446562 s: --------------------------------------------- [IPU1-0] 1356.446623 s: 0 | 0 9. 2 0. 0 0. 0 [IPU1-0] 1356.446867 s: [IPU1-0] 1356.446928 s: [ ALG_STEREO_POSTPROCESS ] LATENCY, [IPU1-0] 1356.446989 s: ******************** [IPU1-0] 1356.447050 s: Local Link Latency : Avg = 28656 us, Min = 28487 us, Max = 28824 us, [IPU1-0] 1356.447172 s: Source to Link Latency : Avg = 82484 us, Min = 67803 us, Max = 95574 us, [IPU1-0] 1356.447294 s: [IPU1-0] 1356.447386 s: [IPU1-0] 1356.447416 s: ### CPU [ DSP1], LinkID [ 0], [IPU1-0] 1356.447508 s: [IPU1-0] 1356.447538 s: [ IPC_OUT_0 ] Link Statistics, [IPU1-0] 1356.447599 s: ****************************** [IPU1-0] 1356.447660 s: [IPU1-0] 1356.447691 s: Elapsed time = 662149 msec [IPU1-0] 1356.447813 s: [IPU1-0] 1356.447843 s: New data Recv = 9.2 fps [IPU1-0] 1356.447935 s: Release data Recv = 9.2 fps [IPU1-0] 1356.447996 s: Driver/Notify Cb = 109.1 fps [IPU1-0] 1356.448057 s: [IPU1-0] 1356.448118 s: Input Statistics, [IPU1-0] 1356.448148 s: [IPU1-0] 1356.448209 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1356.448270 s: | FPS | FPS | FPS | FPS [IPU1-0] 1356.448362 s: -------------------------------------------------- [IPU1-0] 1356.448423 s: 0 | 9. 2 0. 0 0. 0 9. 2 [IPU1-0] 1356.448545 s: [IPU1-0] 1356.448606 s: Output Statistics, [IPU1-0] 1356.448636 s: [IPU1-0] 1356.448697 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1356.448758 s: | ID | FPS | FPS | FPS [IPU1-0] 1356.448850 s: --------------------------------------------- [IPU1-0] 1356.448911 s: 0 | 0 9. 2 0. 0 0. 0 [IPU1-0] 1356.449033 s: [IPU1-0] 1356.449063 s: [ IPC_OUT_0 ] LATENCY, [IPU1-0] 1356.449124 s: ******************** [IPU1-0] 1356.449185 s: Local Link Latency : Avg = 3 us, Min = 0 us, Max = 31 us, [IPU1-0] 1356.449307 s: Source to Link Latency : Avg = 82572 us, Min = 67895 us, Max = 95666 us, [IPU1-0] 1356.449399 s: [IPU1-0] 1356.948941 s: [IPU1-0] 1356.949002 s: ### CPU [IPU1-0], LinkID [ 11], [IPU1-0] 1356.949094 s: [IPU1-0] 1356.949124 s: [ IPC_IN_1 ] Link Statistics, [IPU1-0] 1356.949185 s: ****************************** [IPU1-0] 1356.949246 s: [IPU1-0] 1356.949307 s: Elapsed time = 662117 msec [IPU1-0] 1356.949368 s: [IPU1-0] 1356.949399 s: Get Full Buf Cb = 36.5 fps [IPU1-0] 1356.949490 s: Put Empty Buf Cb = 9.1 fps [IPU1-0] 1356.949551 s: Driver/Notify Cb = 9.1 fps [IPU1-0] 1356.949612 s: [IPU1-0] 1356.949673 s: Input Statistics, [IPU1-0] 1356.949704 s: [IPU1-0] 1356.949795 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1356.949856 s: | FPS | FPS | FPS | FPS [IPU1-0] 1356.949948 s: -------------------------------------------------- [IPU1-0] 1356.950009 s: 0 | 9. 1 0. 0 0. 0 9. 1 [IPU1-0] 1356.950161 s: [IPU1-0] 1356.950192 s: Output Statistics, [IPU1-0] 1356.950253 s: [IPU1-0] 1356.950283 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1356.950344 s: | ID | FPS | FPS | FPS [IPU1-0] 1356.950405 s: --------------------------------------------- [IPU1-0] 1356.950497 s: 0 | 0 9. 1 0. 0 0. 0 [IPU1-0] 1356.950619 s: [IPU1-0] 1356.950649 s: [ IPC_IN_1 ] LATENCY, [IPU1-0] 1356.950710 s: ******************** [IPU1-0] 1356.950771 s: Local Link Latency : Avg = 17 us, Min = 0 us, Max = 92 us, [IPU1-0] 1356.950893 s: Source to Link Latency : Avg = 82822 us, Min = 68169 us, Max = 95879 us, [IPU1-0] 1356.951015 s: [IPU1-0] 1356.951076 s: CPU [ IPU1-0], LinkID [ 45], Link Statistics not available ! [IPU1-0] 1356.951168 s: CPU [ IPU1-0], LinkID [ 44], Link Statistics not available ! [IPU1-0] 1356.951259 s: CPU [ IPU1-0], LinkID [ 38], Link Statistics not available ! [IPU1-0] 1356.951412 s: [IPU1-0] 1356.951442 s: ### CPU [IPU1-0], LinkID [ 35], [IPU1-0] 1356.951534 s: [IPU1-0] 1356.951564 s: [ SYNC_1 ] Link Statistics, [IPU1-0] 1356.951625 s: ****************************** [IPU1-0] 1356.951686 s: [IPU1-0] 1356.951869 s: Elapsed time = 662135 msec [IPU1-0] 1356.951930 s: [IPU1-0] 1356.951991 s: New data Recv = 48.67 fps [IPU1-0] 1356.952052 s: Get Full Buf Cb = 9.1 fps [IPU1-0] 1356.952144 s: Put Empty Buf Cb = 9.1 fps [IPU1-0] 1356.952205 s: Driver/Notify Cb = 30.30 fps [IPU1-0] 1356.952266 s: [IPU1-0] 1356.952327 s: Input Statistics, [IPU1-0] 1356.952357 s: [IPU1-0] 1356.952418 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1356.952479 s: | FPS | FPS | FPS | FPS [IPU1-0] 1356.952540 s: -------------------------------------------------- [IPU1-0] 1356.952632 s: 0 | 9. 1 0. 0 0. 0 9. 1 [IPU1-0] 1356.952784 s: 1 | 9. 1 0. 0 0. 0 9. 1 [IPU1-0] 1356.952906 s: 2 | 9. 1 0. 0 0. 0 9. 1 [IPU1-0] 1356.953059 s: 3 | 9. 1 0. 0 0. 0 9. 1 [IPU1-0] 1356.953181 s: [IPU1-0] 1356.953211 s: Output Statistics, [IPU1-0] 1356.953272 s: [IPU1-0] 1356.953303 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1356.953364 s: | ID | FPS | FPS | FPS [IPU1-0] 1356.953455 s: --------------------------------------------- [IPU1-0] 1356.953516 s: 0 | 0 9. 1 0. 0 0. 0 [IPU1-0] 1356.953638 s: [IPU1-0] 1356.953669 s: [ SYNC_1 ] LATENCY, [IPU1-0] 1356.953760 s: ******************** [IPU1-0] 1356.953791 s: Local Link Latency : Avg = 285508 us, Min = 30 us, Max = 428903 us, [IPU1-0] 1356.953913 s: Source to Link Latency : Avg = 322808 us, Min = 303884 us, Max = 354569 us, [IPU1-0] 1356.954035 s: [IPU1-0] 1356.954126 s: [IPU1-0] 1356.954157 s: ### CPU [IPU1-0], LinkID [ 50], [IPU1-0] 1356.954248 s: [IPU1-0] 1356.954279 s: [ ALG_DEWARP ] Link Statistics, [IPU1-0] 1356.954340 s: ****************************** [IPU1-0] 1356.954401 s: [IPU1-0] 1356.954462 s: Elapsed time = 662122 msec [IPU1-0] 1356.954523 s: [IPU1-0] 1356.954553 s: New data Recv = 9.1 fps [IPU1-0] 1356.954614 s: [IPU1-0] 1356.954675 s: Input Statistics, [IPU1-0] 1356.954706 s: [IPU1-0] 1356.954767 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1356.954858 s: | FPS | FPS | FPS | FPS [IPU1-0] 1356.954919 s: -------------------------------------------------- [IPU1-0] 1356.954980 s: 0 | 9. 1 0. 0 0. 0 9. 1 [IPU1-0] 1356.955133 s: [IPU1-0] 1356.955163 s: Output Statistics, [IPU1-0] 1356.955224 s: [IPU1-0] 1356.955255 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1356.955316 s: | ID | FPS | FPS | FPS [IPU1-0] 1356.955377 s: --------------------------------------------- [IPU1-0] 1356.955468 s: 0 | 0 9. 1 0. 0 0. 0 [IPU1-0] 1356.955590 s: [IPU1-0] 1356.955621 s: [ ALG_DEWARP ] LATENCY, [IPU1-0] 1356.955682 s: ******************** [IPU1-0] 1356.955743 s: Local Link Latency : Avg = 10028 us, Min = 9699 us, Max = 11591 us, [IPU1-0] 1356.955865 s: Source to Link Latency : Avg = 333181 us, Min = 313754 us, Max = 366914 us, [IPU1-0] 1356.955956 s: [IPU1-0] 1356.956017 s: CPU [ IPU1-0], LinkID [ 27], Link Statistics not available ! [IPU1-0] 1356.956170 s: [IPU1-0] 1356.956200 s: ### CPU [IPU1-0], LinkID [ 3], [IPU1-0] 1356.956292 s: [IPU1-0] 1356.956322 s: [ IPC_OUT_3 ] Link Statistics, [IPU1-0] 1356.956383 s: ****************************** [IPU1-0] 1356.956444 s: [IPU1-0] 1356.956475 s: Elapsed time = 662114 msec [IPU1-0] 1356.956536 s: [IPU1-0] 1356.956597 s: New data Recv = 9.1 fps [IPU1-0] 1356.956658 s: Release data Recv = 9.2 fps [IPU1-0] 1356.956871 s: Driver/Notify Cb = 109.1 fps [IPU1-0] 1356.956932 s: [IPU1-0] 1356.956993 s: Input Statistics, [IPU1-0] 1356.957024 s: [IPU1-0] 1356.957085 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1356.957146 s: | FPS | FPS | FPS | FPS [IPU1-0] 1356.957237 s: -------------------------------------------------- [IPU1-0] 1356.957298 s: 0 | 9. 1 0. 0 0. 0 9. 1 [IPU1-0] 1356.957420 s: [IPU1-0] 1356.957481 s: Output Statistics, [IPU1-0] 1356.957542 s: [IPU1-0] 1356.957573 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1356.957664 s: | ID | FPS | FPS | FPS [IPU1-0] 1356.957817 s: --------------------------------------------- [IPU1-0] 1356.957908 s: 0 | 0 9. 1 0. 0 0. 0 [IPU1-0] 1356.958030 s: [IPU1-0] 1356.958061 s: [ IPC_OUT_3 ] LATENCY, [IPU1-0] 1356.958122 s: ******************** [IPU1-0] 1356.958183 s: Local Link Latency : Avg = 6 us, Min = 0 us, Max = 152 us, [IPU1-0] 1356.958274 s: Source to Link Latency : Avg = 333459 us, Min = 314029 us, Max = 367188 us, [IPU1-0] 1356.958396 s: [IPU1-0] 1357.457847 s: [IPU1-0] 1357.457908 s: ### CPU [ DSP2], LinkID [ 11], [IPU1-0] 1357.458000 s: [IPU1-0] 1357.458061 s: [ IPC_IN_1 ] Link Statistics, [IPU1-0] 1357.458122 s: ****************************** [IPU1-0] 1357.458183 s: [IPU1-0] 1357.458213 s: Elapsed time = 662076 msec [IPU1-0] 1357.458274 s: [IPU1-0] 1357.458335 s: Get Full Buf Cb = 18.1 fps [IPU1-0] 1357.458396 s: Put Empty Buf Cb = 9.0 fps [IPU1-0] 1357.458457 s: Driver/Notify Cb = 9.0 fps [IPU1-0] 1357.458549 s: [IPU1-0] 1357.458579 s: Input Statistics, [IPU1-0] 1357.458640 s: [IPU1-0] 1357.458671 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1357.458762 s: | FPS | FPS | FPS | FPS [IPU1-0] 1357.458854 s: -------------------------------------------------- [IPU1-0] 1357.458915 s: 0 | 9. 0 0. 0 0. 0 9. 0 [IPU1-0] 1357.459037 s: [IPU1-0] 1357.459098 s: Output Statistics, [IPU1-0] 1357.459128 s: [IPU1-0] 1357.459189 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1357.459250 s: | ID | FPS | FPS | FPS [IPU1-0] 1357.459311 s: --------------------------------------------- [IPU1-0] 1357.459403 s: 0 | 0 9. 0 0. 0 0. 0 [IPU1-0] 1357.459494 s: [IPU1-0] 1357.459555 s: [ IPC_IN_1 ] LATENCY, [IPU1-0] 1357.459616 s: ******************** [IPU1-0] 1357.459647 s: Local Link Latency : Avg = 12 us, Min = 0 us, Max = 61 us, [IPU1-0] 1357.459799 s: Source to Link Latency : Avg = 340717 us, Min = 321105 us, Max = 374478 us, [IPU1-0] 1357.459891 s: [IPU1-0] 1357.959830 s: [IPU1-0] 1357.959891 s: ### CPU [IPU1-0], LinkID [ 2], [IPU1-0] 1357.959982 s: [IPU1-0] 1357.960013 s: [ IPC_OUT_2 ] Link Statistics, [IPU1-0] 1357.960074 s: ****************************** [IPU1-0] 1357.960135 s: [IPU1-0] 1357.960196 s: Elapsed time = 662050 msec [IPU1-0] 1357.960287 s: [IPU1-0] 1357.960348 s: New data Recv = 8.99 fps [IPU1-0] 1357.960409 s: Release data Recv = 9.0 fps [IPU1-0] 1357.960501 s: Driver/Notify Cb = 108.99 fps [IPU1-0] 1357.960562 s: [IPU1-0] 1357.960592 s: Input Statistics, [IPU1-0] 1357.960653 s: [IPU1-0] 1357.960684 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1357.960775 s: | FPS | FPS | FPS | FPS [IPU1-0] 1357.960867 s: -------------------------------------------------- [IPU1-0] 1357.960928 s: 0 | 8.99 0. 0 0. 0 8.99 [IPU1-0] 1357.961080 s: [IPU1-0] 1357.961111 s: Output Statistics, [IPU1-0] 1357.961172 s: [IPU1-0] 1357.961202 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1357.961263 s: | ID | FPS | FPS | FPS [IPU1-0] 1357.961355 s: --------------------------------------------- [IPU1-0] 1357.961416 s: 0 | 0 8.99 0. 0 0. 0 [IPU1-0] 1357.961538 s: [IPU1-0] 1357.961568 s: [ IPC_OUT_2 ] LATENCY, [IPU1-0] 1357.961629 s: ******************** [IPU1-0] 1357.961690 s: Local Link Latency : Avg = 8 us, Min = 0 us, Max = 92 us, [IPU1-0] 1357.961934 s: Source to Link Latency : Avg = 333346 us, Min = 313907 us, Max = 367066 us, [IPU1-0] 1357.962056 s: [IPU1-0] 1358.461965 s: [IPU1-0] 1358.462026 s: ### CPU [ DSP2], LinkID [ 10], [IPU1-0] 1358.462087 s: [IPU1-0] 1358.462117 s: [ IPC_IN_0 ] Link Statistics, [IPU1-0] 1358.462209 s: ****************************** [IPU1-0] 1358.462270 s: [IPU1-0] 1358.462300 s: Elapsed time = 662136 msec [IPU1-0] 1358.462361 s: [IPU1-0] 1358.462392 s: Get Full Buf Cb = 8.99 fps [IPU1-0] 1358.462483 s: Put Empty Buf Cb = 8.99 fps [IPU1-0] 1358.462544 s: Driver/Notify Cb = 8.99 fps [IPU1-0] 1358.462636 s: [IPU1-0] 1358.462666 s: Input Statistics, [IPU1-0] 1358.462697 s: [IPU1-0] 1358.462758 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1358.462910 s: | FPS | FPS | FPS | FPS [IPU1-0] 1358.462972 s: -------------------------------------------------- [IPU1-0] 1358.463063 s: 0 | 8.99 0. 0 0. 0 8.99 [IPU1-0] 1358.463185 s: [IPU1-0] 1358.463216 s: Output Statistics, [IPU1-0] 1358.463277 s: [IPU1-0] 1358.463307 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1358.463399 s: | ID | FPS | FPS | FPS [IPU1-0] 1358.463460 s: --------------------------------------------- [IPU1-0] 1358.463521 s: 0 | 0 8.99 0. 0 0. 0 [IPU1-0] 1358.463643 s: [IPU1-0] 1358.463673 s: [ IPC_IN_0 ] LATENCY, [IPU1-0] 1358.463734 s: ******************** [IPU1-0] 1358.463826 s: Local Link Latency : Avg = 11 us, Min = 0 us, Max = 31 us, [IPU1-0] 1358.463917 s: Source to Link Latency : Avg = 333468 us, Min = 314029 us, Max = 367188 us, [IPU1-0] 1358.464039 s: [IPU1-0] 1358.464131 s: [IPU1-0] 1358.464161 s: ### CPU [ DSP2], LinkID [ 49], [IPU1-0] 1358.464253 s: [IPU1-0] 1358.464283 s: [ ALG_SEAMDETECTION ] Link Statistics, [IPU1-0] 1358.464344 s: ****************************** [IPU1-0] 1358.464405 s: [IPU1-0] 1358.464466 s: Elapsed time = 662138 msec [IPU1-0] 1358.464527 s: [IPU1-0] 1358.464558 s: New data Recv = 8.99 fps [IPU1-0] 1358.464619 s: [IPU1-0] 1358.464680 s: Input Statistics, [IPU1-0] 1358.464710 s: [IPU1-0] 1358.464863 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1358.464954 s: | FPS | FPS | FPS | FPS [IPU1-0] 1358.465015 s: -------------------------------------------------- [IPU1-0] 1358.465107 s: 0 | 0. 0 0. 0 0. 0 8.99 [IPU1-0] 1358.465229 s: [IPU1-0] 1358.465259 s: Output Statistics, [IPU1-0] 1358.465320 s: [IPU1-0] 1358.465351 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1358.465412 s: | ID | FPS | FPS | FPS [IPU1-0] 1358.465503 s: --------------------------------------------- [IPU1-0] 1358.465564 s: 0 | 0 8.99 0. 0 0. 0 [IPU1-0] 1358.465686 s: [IPU1-0] 1358.465717 s: [ ALG_SEAMDETECTION ] LATENCY, [IPU1-0] 1358.465808 s: ******************** [IPU1-0] 1358.465869 s: Local Link Latency : Avg = 6700 us, Min = 6374 us, Max = 7229 us, [IPU1-0] 1358.465991 s: Source to Link Latency : Avg = 340634 us, Min = 321013 us, Max = 374386 us, [IPU1-0] 1358.467242 s: [IPU1-0] 1358.467394 s: [IPU1-0] 1358.467425 s: ### CPU [ DSP2], LinkID [ 50], [IPU1-0] 1358.467547 s: [IPU1-0] 1358.467577 s: [ ALG_STITCHING ] Link Statistics, [IPU1-0] 1358.467669 s: ****************************** [IPU1-0] 1358.467852 s: [IPU1-0] 1358.467882 s: Elapsed time = 662134 msec [IPU1-0] 1358.467974 s: [IPU1-0] 1358.468004 s: New data Recv = 17.98 fps [IPU1-0] 1358.468096 s: [IPU1-0] 1358.468126 s: Input Statistics, [IPU1-0] 1358.468187 s: [IPU1-0] 1358.468218 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1358.468279 s: | FPS | FPS | FPS | FPS [IPU1-0] 1358.468370 s: -------------------------------------------------- [IPU1-0] 1358.468431 s: 0 | 0. 0 0. 0 0. 0 17.98 [IPU1-0] 1358.468584 s: [IPU1-0] 1358.468614 s: Output Statistics, [IPU1-0] 1358.468675 s: [IPU1-0] 1358.468706 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1358.468797 s: | ID | FPS | FPS | FPS [IPU1-0] 1358.468889 s: --------------------------------------------- [IPU1-0] 1358.468950 s: 0 | 0 17.98 0. 0 0. 0 [IPU1-0] 1358.469072 s: [IPU1-0] 1358.469102 s: [ ALG_STITCHING ] LATENCY, [IPU1-0] 1358.469163 s: ******************** [IPU1-0] 1358.469224 s: Local Link Latency : Avg = 2675 us, Min = 2532 us, Max = 3203 us, [IPU1-0] 1358.469346 s: Source to Link Latency : Avg = 343820 us, Min = 324094 us, Max = 377650 us, [IPU1-0] 1358.469468 s: [IPU1-0] 1358.469560 s: [IPU1-0] 1358.469621 s: ### CPU [ DSP2], LinkID [ 0], [IPU1-0] 1358.469682 s: [IPU1-0] 1358.469743 s: [ IPC_OUT_0 ] Link Statistics, [IPU1-0] 1358.469804 s: ****************************** [IPU1-0] 1358.469865 s: [IPU1-0] 1358.469926 s: Elapsed time = 662133 msec [IPU1-0] 1358.469987 s: [IPU1-0] 1358.470017 s: New data Recv = 8.99 fps [IPU1-0] 1358.470109 s: Release data Recv = 8.99 fps [IPU1-0] 1358.470170 s: Driver/Notify Cb = 108.99 fps [IPU1-0] 1358.470261 s: [IPU1-0] 1358.470292 s: Input Statistics, [IPU1-0] 1358.470353 s: [IPU1-0] 1358.470383 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1358.470475 s: | FPS | FPS | FPS | FPS [IPU1-0] 1358.470536 s: -------------------------------------------------- [IPU1-0] 1358.470627 s: 0 | 8.99 0. 0 0. 0 8.99 [IPU1-0] 1358.470749 s: [IPU1-0] 1358.470810 s: Output Statistics, [IPU1-0] 1358.470871 s: [IPU1-0] 1358.470902 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1358.470993 s: | ID | FPS | FPS | FPS [IPU1-0] 1358.471054 s: --------------------------------------------- [IPU1-0] 1358.471146 s: 0 | 0 8.99 0. 0 0. 0 [IPU1-0] 1358.471268 s: [IPU1-0] 1358.471298 s: [ IPC_OUT_0 ] LATENCY, [IPU1-0] 1358.471359 s: ******************** [IPU1-0] 1358.471420 s: Local Link Latency : Avg = 3 us, Min = 0 us, Max = 31 us, [IPU1-0] 1358.471512 s: Source to Link Latency : Avg = 343895 us, Min = 324155 us, Max = 377742 us, [IPU1-0] 1358.471634 s: [IPU1-0] 1358.970902 s: [IPU1-0] 1358.970993 s: ### CPU [IPU1-0], LinkID [ 12], [IPU1-0] 1358.971146 s: [IPU1-0] 1358.971176 s: [ IPC_IN_2 ] Link Statistics, [IPU1-0] 1358.971237 s: ****************************** [IPU1-0] 1358.971298 s: [IPU1-0] 1358.971359 s: Elapsed time = 662118 msec [IPU1-0] 1358.971420 s: [IPU1-0] 1358.971451 s: Get Full Buf Cb = 8.98 fps [IPU1-0] 1358.971542 s: Put Empty Buf Cb = 8.98 fps [IPU1-0] 1358.971603 s: Driver/Notify Cb = 8.98 fps [IPU1-0] 1358.971695 s: [IPU1-0] 1358.978374 s: Input Statistics, [IPU1-0] 1358.978435 s: [IPU1-0] 1358.978466 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1358.978557 s: | FPS | FPS | FPS | FPS [IPU1-0] 1358.978618 s: -------------------------------------------------- [IPU1-0] 1358.978832 s: 0 | 8.98 0. 0 0. 0 8.98 [IPU1-0] 1358.978954 s: [IPU1-0] 1358.978984 s: Output Statistics, [IPU1-0] 1358.979045 s: [IPU1-0] 1358.979076 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1358.979259 s: | ID | FPS | FPS | FPS [IPU1-0] 1358.979320 s: --------------------------------------------- [IPU1-0] 1358.979381 s: 0 | 0 8.98 0. 0 0. 0 [IPU1-0] 1358.979503 s: [IPU1-0] 1358.979564 s: [ IPC_IN_2 ] LATENCY, [IPU1-0] 1358.979686 s: ******************** [IPU1-0] 1358.979747 s: Local Link Latency : Avg = 19 us, Min = 0 us, Max = 366 us, [IPU1-0] 1358.979899 s: Source to Link Latency : Avg = 344149 us, Min = 324338 us, Max = 377986 us, [IPU1-0] 1358.980021 s: [IPU1-0] 1358.980113 s: [IPU1-0] 1358.980174 s: ### CPU [IPU1-0], LinkID [ 67], [IPU1-0] 1358.980235 s: [IPU1-0] 1358.980265 s: [ DISPLAY ] Link Statistics, [IPU1-0] 1358.980326 s: ****************************** [IPU1-0] 1358.980387 s: [IPU1-0] 1358.980448 s: Elapsed time = 662126 msec [IPU1-0] 1358.980509 s: [IPU1-0] 1358.980540 s: New data Recv = 8.98 fps [IPU1-0] 1358.980631 s: Driver/Notify Cb = 65.56 fps [IPU1-0] 1358.980692 s: [IPU1-0] 1358.980723 s: Input Statistics, [IPU1-0] 1358.980814 s: [IPU1-0] 1358.980845 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1358.980906 s: | FPS | FPS | FPS | FPS [IPU1-0] 1358.980997 s: -------------------------------------------------- [IPU1-0] 1358.981058 s: 0 | 8.98 0. 0 0. 0 8.98 [IPU1-0] 1358.981211 s: [IPU1-0] 1358.981241 s: Output Statistics, [IPU1-0] 1358.981302 s: [IPU1-0] 1358.981333 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 1358.981394 s: | ID | FPS | FPS | FPS [IPU1-0] 1358.981455 s: --------------------------------------------- [IPU1-0] 1358.981547 s: [IPU1-0] 1358.981577 s: [ DISPLAY ] LATENCY, [IPU1-0] 1358.981638 s: ******************** [IPU1-0] 1358.981699 s: Local Link Latency : Avg = 58 us, Min = 30 us, Max = 1037 us, [IPU1-0] 1358.981974 s: Source to Link Latency : Avg = 344649 us, Min = 324460 us, Max = 378108 us, [IPU1-0] 1358.982096 s: [IPU1-0] 1358.982126 s: Display UnderFlow Count = 0 [IPU1-0] 1358.982187 s: [IPU1-0] 1358.982248 s: CPU [ IPU1-0], LinkID [ 23], Link Statistics not available ! [IPU1-0] 1358.982401 s: [IPU1-0] 1358.982431 s: ### CPU [IPU1-0], LinkID [ 68], [IPU1-0] 1358.982492 s: [IPU1-0] 1358.982553 s: [ DISPLAY ] Link Statistics, [IPU1-0] 1358.982614 s: ****************************** [IPU1-0] 1358.982675 s: [IPU1-0] 1358.982706 s: Elapsed time = 1341642 msec [IPU1-0] 1358.982767 s: [IPU1-0] 1358.982828 s: Driver/Notify Cb = 65.56 fps [IPU1-0] 1358.982919 s: [IPU1-0] 1358.982950 s: Input Statistics, [IPU1-0] 1358.983011 s: [IPU1-0] 1358.983041 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 1358.983133 s: | FPS | FPS | FPS | FPS [IPU1-0] 1358.983194 s: -------------------------------------------------- [IPU1-0] 1358.983285 s: 0 | 0. 0 0. 0 0. 0 0. 0 [IPU1-0] 1358.983407 s: [IPU1-0] 1358.983438 s: [ DISPLAY ] LATENCY, [IPU1-0] 1358.983499 s: ******************** [IPU1-0] 1358.983560 s: Local Link Latency : Avg = 30 us, Min = 30 us, Max = 30 us, [IPU1-0] 1358.983651 s: Source to Link Latency : Avg = 1166748 us, Min = 1166748 us, Max = 1166748 us, [IPU1-0] 1358.983773 s: [IPU1-0] 1358.983834 s: Display UnderFlow Count = 0 [IPU1-0] 1358.983895 s: [IPU1-0] 1359.483804 s: [IPU1-0]
