Linux/AM4378: Adding Java runtime support
Part Number: AM4378
Tool/software: Linux
Dear,
We have successfully designed a board based on AM437x and using texas based operating system. Now I wanted to use Java run time. I found in the forum, stated that X11 supportable SDK requires to use java run time. But there is no SDK available with X11 support it seems. So I followed below method to build X11 support SDK for AM4378
$ git clone git://arago-project.org/git/projects/oe-layersetup.git tisdk
$ cd tisdk
$ ./oe-layertool-setup.sh -f configs/processor-sdk/processor-sdk-04.01.00.06-x11-config.txt
$ cd build
$ . conf/setenv
$ export PATH=$HOME/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin:$PATH
$ MACHINE=am437x-evm bitbake arago-core-tisdk-image
It built with  errors and find attached terminal messages .
HEAD is now at fe5c833... libdnet: Update SRC_URI to fix checksum errors
cloning repo meta-ti
Cloning into '/home/futura/tisdk/sources/meta-ti'...
remote: Counting objects: 23992, done.
remote: Compressing objects: 100% (7906/7906), done.
remote: Total 23992 (delta 15341), reused 23626 (delta 15023)
Receiving objects: 100% (23992/23992), 8.14 MiB | 415.00 KiB/s, done.
Resolving deltas: 100% (15341/15341), done.
Checking connectivity... done.
Branch morty set up to track remote branch morty from origin.
Switched to a new branch 'morty'
Already up-to-date.
Note: checking out 'a18d57af8384ced25996739bb66d197c69efb77b'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
  git checkout -b new_branch_name
HEAD is now at a18d57a... ti-ipc-rtos: add default symlinks for Keystone DSP firmware images
cloning repo meta-linaro
Cloning into '/home/futura/tisdk/sources/meta-linaro'...
remote: Counting objects: 9613, done.
remote: Compressing objects: 100% (5772/5772), done.
remote: Total 9613 (delta 5072), reused 6615 (delta 3320)
Receiving objects: 100% (9613/9613), 2.90 MiB | 5.14 MiB/s, done.
Resolving deltas: 100% (5072/5072), done.
Already up-to-date.
Note: checking out '49b0f32d7e955f250b0022d1b2f403f45a2c2d9c'.
HEAD is now at 49b0f32... meta-linaro: move genericarmv8*.conf machines
cloning repo oe-core
Cloning into '/home/futura/tisdk/sources/oe-core'...
remote: Counting objects: 304181, done.
remote: Compressing objects: 100% (79513/79513), done.
remote: Total 304181 (delta 219866), reused 303608 (delta 219382)
Receiving objects: 100% (304181/304181), 101.28 MiB | 2.16 MiB/s, done.
Resolving deltas: 100% (219866/219866), done.
Already up-to-date.
Note: checking out 'e3911133ee9aad7cc3ae89faea80a097f6614fab'.
HEAD is now at e391113... libgcrypt: fix CVE-2017-7526
The bblayers.conf configuration file has been created for you with some
default values.  Please verify the contents of your conf/bblayers.conf
file for correctness.
NOTE: Any additional entries to this file will be lost if the ./oe-layertool-setup.sh
      script is run again.  To add entries permanently to this file
      please add them to the config file used and rerun the
      ./oe-layertool-setup.sh script.
The local.conf configuration file has been created for you with some
default values.  Please verify the contents of your conf/local.conf
By default the number of threads used by the build is set to the number
of CPUs found on your system.
NOTE: You will probably want to change the default MACHINE setting in the
      local.conf file to the machine you are trying to build.
A setenv file has been created for you in the conf directory.  Please verify
The contents of this file.  Once you have verified the contents please source
this file to configure your environment for building:
    . conf/setenv
You can then start building using the bitbake command.  You will likely want
to set the MACHINE option if you have not done so in your local.conf file.
For example:
    MACHINE=xxxxx bitbake <target>
Common targets are:
    core-image-minimal
    core-image-sato
    meta-toolchain
    meta-toolchain-sdk
    adt-installer
    meta-ide-support
futura@futura:~/tisdk$ cd build/
futura@futura:~/tisdk/build$ . conf /setenv
bash: .: conf: is a directory
futura@futura:~/tisdk/build$ . conf/setenv
futura@futura:~/tisdk/build$ export PATH=$HOME/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin:$PATH
futura@futura:~/tisdk/build$ MACHINE=am437x-evm bitbake arago-core-tisdk-image
NOTE: Your conf/bblayers.conf has been automatically updated.
ERROR:  OE-core's config sanity checker detected a potential misconfiguration.
    Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
    Following is the list of potential problems / advisories:
    Please install the following missing utilities: makeinfo,gawk,chrpath
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
futura@futura:~/tisdk/build$ sudo apt-get install makeinfo
[sudo] password for futura:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package makeinfo
futura@futura:~/tisdk/build$ sudo apt-get install gawk
Suggested packages:
  gawk-doc
The following NEW packages will be installed:
  gawk
0 upgraded, 1 newly installed, 0 to remove and 3 not upgraded.
Need to get 781 kB of archives.
After this operation, 1,937 kB of additional disk space will be used.
Get:1 http://in.archive.ubuntu.com/ubuntu/ trusty/main gawk amd64 1:4.0.1+dfsg-2.1ubuntu2 [781 kB]
Fetched 781 kB in 1s (405 kB/s)
Selecting previously unselected package gawk.
(Reading database ... 205235 files and directories currently installed.)
Preparing to unpack .../gawk_1%3a4.0.1+dfsg-2.1ubuntu2_amd64.deb ...
Unpacking gawk (1:4.0.1+dfsg-2.1ubuntu2) ...
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
Setting up gawk (1:4.0.1+dfsg-2.1ubuntu2) ...
futura@futura:~/tisdk/build$ sudo apt-get install chrpath
  chrpath
Need to get 12.5 kB of archives.
After this operation, 62.5 kB of additional disk space will be used.
Get:1 http://in.archive.ubuntu.com/ubuntu/ trusty/main chrpath amd64 0.14-3ubuntu1 [12.5 kB]
Fetched 12.5 kB in 0s (38.4 kB/s)
Selecting previously unselected package chrpath.
(Reading database ... 205333 files and directories currently installed.)
Preparing to unpack .../chrpath_0.14-3ubuntu1_amd64.deb ...
Unpacking chrpath (0.14-3ubuntu1) ...
Setting up chrpath (0.14-3ubuntu1) ...
futura@futura:~/tisdk/build$ sudo apt-get install texinfo
The following extra packages will be installed:
  libencode-locale-perl libfile-listing-perl libfont-afm-perl
  libhtml-form-perl libhtml-format-perl libhtml-parser-perl
  libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl
  libhttp-daemon-perl libhttp-date-perl libhttp-message-perl
  libhttp-negotiate-perl libintl-perl libio-html-perl liblwp-mediatypes-perl
  liblwp-protocol-https-perl libnet-http-perl libtext-unidecode-perl
  libwww-perl libwww-robotrules-perl libxml-libxml-perl
  libxml-namespacesupport-perl libxml-parser-perl libxml-sax-base-perl
  libxml-sax-expat-perl libxml-sax-perl
Suggested packages:
  libdata-dump-perl libintl-xs-perl libcrypt-ssleay-perl libauthen-ntlm-perl
  texlive-base texlive-latex-base texlive-generic-recommended
  texinfo-doc-nonfree
  libxml-sax-expat-perl libxml-sax-perl texinfo
0 upgraded, 28 newly installed, 0 to remove and 3 not upgraded.
Need to get 3,424 kB of archives.
After this operation, 13.0 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
WARNING: The following packages cannot be authenticated!
  liblwp-protocol-https-perl libxml-libxml-perl
Install these packages without verification? [y/N] y
Get:1 http://in.archive.ubuntu.com/ubuntu/ trusty/main libencode-locale-perl all 1.03-1 [12.4 kB]
Get:2 http://in.archive.ubuntu.com/ubuntu/ trusty/main libhttp-date-perl all 6.02-1 [10.4 kB]
Get:3 http://in.archive.ubuntu.com/ubuntu/ trusty/main libfile-listing-perl all 6.04-1 [9,774 B]
Get:4 http://in.archive.ubuntu.com/ubuntu/ trusty/main libfont-afm-perl all 1.20-1 [14.3 kB]
Get:5 http://in.archive.ubuntu.com/ubuntu/ trusty/main libhtml-tagset-perl all 3.20-2 [13.5 kB]
Get:6 http://in.archive.ubuntu.com/ubuntu/ trusty/main libhtml-parser-perl amd64 3.71-1build1 [98.2 kB]
Get:7 http://in.archive.ubuntu.com/ubuntu/ trusty/main libio-html-perl all 1.00-1 [15.7 kB]
Get:8 http://in.archive.ubuntu.com/ubuntu/ trusty/main liblwp-mediatypes-perl all 6.02-1 [21.7 kB]
Get:9 http://in.archive.ubuntu.com/ubuntu/ trusty/main libhttp-message-perl all 6.06-1 [78.7 kB]
Get:10 http://in.archive.ubuntu.com/ubuntu/ trusty/main libhtml-form-perl all 6.03-1 [23.5 kB]
Get:11 http://in.archive.ubuntu.com/ubuntu/ trusty/main libhtml-tree-perl all 5.03-1 [215 kB]
Get:12 http://in.archive.ubuntu.com/ubuntu/ trusty/main libhtml-format-perl all 2.11-1 [44.7 kB]
Get:13 http://in.archive.ubuntu.com/ubuntu/ trusty/main libhttp-cookies-perl all 6.00-2 [23.3 kB]
Get:14 http://in.archive.ubuntu.com/ubuntu/ trusty/main libhttp-daemon-perl all 6.01-1 [17.0 kB]
Get:15 http://in.archive.ubuntu.com/ubuntu/ trusty/main libhttp-negotiate-perl all 6.00-2 [13.4 kB]
Get:16 http://in.archive.ubuntu.com/ubuntu/ trusty/main libintl-perl all 1.23-1build1 [1,204 kB]
Get:17 http://in.archive.ubuntu.com/ubuntu/ trusty/main libnet-http-perl all 6.06-1 [24.2 kB]
Get:18 http://in.archive.ubuntu.com/ubuntu/ trusty/main libwww-robotrules-perl all 6.01-1 [14.1 kB]
Get:19 http://in.archive.ubuntu.com/ubuntu/ trusty/main libwww-perl all 6.05-2 [146 kB]
Get:20 http://in.archive.ubuntu.com/ubuntu/ trusty-updates/main liblwp-protocol-https-perl all 6.04-2ubuntu0.1 [7,644 B]
Get:21 http://in.archive.ubuntu.com/ubuntu/ trusty/main libtext-unidecode-perl all 0.04-2 [115 kB]
Get:22 http://in.archive.ubuntu.com/ubuntu/ trusty/main libxml-namespacesupport-perl all 1.11-1 [13.2 kB]
Get:23 http://in.archive.ubuntu.com/ubuntu/ trusty/main libxml-sax-base-perl all 1.07-1 [21.5 kB]
Get:24 http://in.archive.ubuntu.com/ubuntu/ trusty/main libxml-sax-perl all 0.99+dfsg-2ubuntu1 [64.6 kB]
Get:25 http://in.archive.ubuntu.com/ubuntu/ trusty-updates/main libxml-libxml-perl amd64 2.0108+dfsg-1ubuntu0.2 [336 kB]
Get:26 http://in.archive.ubuntu.com/ubuntu/ trusty/main libxml-parser-perl amd64 2.41-1build3 [294 kB]
Get:27 http://in.archive.ubuntu.com/ubuntu/ trusty/main libxml-sax-expat-perl all 0.40-2 [11.5 kB]
Get:28 http://in.archive.ubuntu.com/ubuntu/ trusty/main texinfo amd64 5.2.0.dfsg.1-2 [561 kB]
Fetched 3,424 kB in 14s (232 kB/s)
Selecting previously unselected package libencode-locale-perl.
(Reading database ... 205341 files and directories currently installed.)
Preparing to unpack .../libencode-locale-perl_1.03-1_all.deb ...
Unpacking libencode-locale-perl (1.03-1) ...
Selecting previously unselected package libhttp-date-perl.
Preparing to unpack .../libhttp-date-perl_6.02-1_all.deb ...
Unpacking libhttp-date-perl (6.02-1) ...
Selecting previously unselected package libfile-listing-perl.
Preparing to unpack .../libfile-listing-perl_6.04-1_all.deb ...
Unpacking libfile-listing-perl (6.04-1) ...
Selecting previously unselected package libfont-afm-perl.
Preparing to unpack .../libfont-afm-perl_1.20-1_all.deb ...
Unpacking libfont-afm-perl (1.20-1) ...
Selecting previously unselected package libhtml-tagset-perl.
Preparing to unpack .../libhtml-tagset-perl_3.20-2_all.deb ...
Unpacking libhtml-tagset-perl (3.20-2) ...
Selecting previously unselected package libhtml-parser-perl.
Preparing to unpack .../libhtml-parser-perl_3.71-1build1_amd64.deb ...
Unpacking libhtml-parser-perl (3.71-1build1) ...
Selecting previously unselected package libio-html-perl.
Preparing to unpack .../libio-html-perl_1.00-1_all.deb ...
Unpacking libio-html-perl (1.00-1) ...
Selecting previously unselected package liblwp-mediatypes-perl.
Preparing to unpack .../liblwp-mediatypes-perl_6.02-1_all.deb ...
Unpacking liblwp-mediatypes-perl (6.02-1) ...
Selecting previously unselected package libhttp-message-perl.
Preparing to unpack .../libhttp-message-perl_6.06-1_all.deb ...
Unpacking libhttp-message-perl (6.06-1) ...
Selecting previously unselected package libhtml-form-perl.
Preparing to unpack .../libhtml-form-perl_6.03-1_all.deb ...
Unpacking libhtml-form-perl (6.03-1) ...
Selecting previously unselected package libhtml-tree-perl.
Preparing to unpack .../libhtml-tree-perl_5.03-1_all.deb ...
Unpacking libhtml-tree-perl (5.03-1) ...
Selecting previously unselected package libhtml-format-perl.
Preparing to unpack .../libhtml-format-perl_2.11-1_all.deb ...
Unpacking libhtml-format-perl (2.11-1) ...
Selecting previously unselected package libhttp-cookies-perl.
Preparing to unpack .../libhttp-cookies-perl_6.00-2_all.deb ...
Unpacking libhttp-cookies-perl (6.00-2) ...
Selecting previously unselected package libhttp-daemon-perl.
Preparing to unpack .../libhttp-daemon-perl_6.01-1_all.deb ...
Unpacking libhttp-daemon-perl (6.01-1) ...
Selecting previously unselected package libhttp-negotiate-perl.
Preparing to unpack .../libhttp-negotiate-perl_6.00-2_all.deb ...
Unpacking libhttp-negotiate-perl (6.00-2) ...
Selecting previously unselected package libintl-perl.
Preparing to unpack .../libintl-perl_1.23-1build1_all.deb ...
Unpacking libintl-perl (1.23-1build1) ...
Selecting previously unselected package libnet-http-perl.
Preparing to unpack .../libnet-http-perl_6.06-1_all.deb ...
Unpacking libnet-http-perl (6.06-1) ...
Selecting previously unselected package libwww-robotrules-perl.
Preparing to unpack .../libwww-robotrules-perl_6.01-1_all.deb ...
Unpacking libwww-robotrules-perl (6.01-1) ...
Selecting previously unselected package libwww-perl.
Preparing to unpack .../libwww-perl_6.05-2_all.deb ...
Unpacking libwww-perl (6.05-2) ...
Selecting previously unselected package liblwp-protocol-https-perl.
Preparing to unpack .../liblwp-protocol-https-perl_6.04-2ubuntu0.1_all.deb ...
Unpacking liblwp-protocol-https-perl (6.04-2ubuntu0.1) ...
Selecting previously unselected package libtext-unidecode-perl.
Preparing to unpack .../libtext-unidecode-perl_0.04-2_all.deb ...
Unpacking libtext-unidecode-perl (0.04-2) ...
Selecting previously unselected package libxml-namespacesupport-perl.
Preparing to unpack .../libxml-namespacesupport-perl_1.11-1_all.deb ...
Unpacking libxml-namespacesupport-perl (1.11-1) ...
Selecting previously unselected package libxml-sax-base-perl.
Preparing to unpack .../libxml-sax-base-perl_1.07-1_all.deb ...
Unpacking libxml-sax-base-perl (1.07-1) ...
Selecting previously unselected package libxml-sax-perl.
Preparing to unpack .../libxml-sax-perl_0.99+dfsg-2ubuntu1_all.deb ...
Unpacking libxml-sax-perl (0.99+dfsg-2ubuntu1) ...
Selecting previously unselected package libxml-libxml-perl.
Preparing to unpack .../libxml-libxml-perl_2.0108+dfsg-1ubuntu0.2_amd64.deb ...
Unpacking libxml-libxml-perl (2.0108+dfsg-1ubuntu0.2) ...
Selecting previously unselected package libxml-parser-perl.
Preparing to unpack .../libxml-parser-perl_2.41-1build3_amd64.deb ...
Unpacking libxml-parser-perl (2.41-1build3) ...
Selecting previously unselected package libxml-sax-expat-perl.
Preparing to unpack .../libxml-sax-expat-perl_0.40-2_all.deb ...
Unpacking libxml-sax-expat-perl (0.40-2) ...
Selecting previously unselected package texinfo.
Preparing to unpack .../texinfo_5.2.0.dfsg.1-2_amd64.deb ...
Unpacking texinfo (5.2.0.dfsg.1-2) ...
Processing triggers for doc-base (0.10.5) ...
Processing 1 added doc-base file...
Setting up libencode-locale-perl (1.03-1) ...
Setting up libhttp-date-perl (6.02-1) ...
Setting up libfile-listing-perl (6.04-1) ...
Setting up libfont-afm-perl (1.20-1) ...
Setting up libhtml-tagset-perl (3.20-2) ...
Setting up libhtml-parser-perl (3.71-1build1) ...
Setting up libio-html-perl (1.00-1) ...
Setting up liblwp-mediatypes-perl (6.02-1) ...
Setting up libhttp-message-perl (6.06-1) ...
Setting up libhtml-form-perl (6.03-1) ...
Setting up libhtml-tree-perl (5.03-1) ...
Setting up libhtml-format-perl (2.11-1) ...
Setting up libhttp-cookies-perl (6.00-2) ...
Setting up libhttp-daemon-perl (6.01-1) ...
Setting up libhttp-negotiate-perl (6.00-2) ...
Setting up libintl-perl (1.23-1build1) ...
Setting up libnet-http-perl (6.06-1) ...
Setting up libwww-robotrules-perl (6.01-1) ...
Setting up libtext-unidecode-perl (0.04-2) ...
Setting up libxml-namespacesupport-perl (1.11-1) ...
Setting up libxml-sax-base-perl (1.07-1) ...
Setting up libxml-sax-perl (0.99+dfsg-2ubuntu1) ...
update-perl-sax-parsers: Registering Perl SAX parser XML::SAX::PurePerl with priority 10...
update-perl-sax-parsers: Updating overall Perl SAX parser modules info file...
Creating config file /etc/perl/XML/SAX/ParserDetails.ini with new version
Setting up libxml-libxml-perl (2.0108+dfsg-1ubuntu0.2) ...
update-perl-sax-parsers: Registering Perl SAX parser XML::LibXML::SAX::Parser with priority 50...
update-perl-sax-parsers: Registering Perl SAX parser XML::LibXML::SAX with priority 50...
Replacing config file /etc/perl/XML/SAX/ParserDetails.ini with new version
Setting up texinfo (5.2.0.dfsg.1-2) ...
Setting up libwww-perl (6.05-2) ...
Setting up liblwp-protocol-https-perl (6.04-2ubuntu0.1) ...
Setting up libxml-parser-perl (2.41-1build3) ...
Setting up libxml-sax-expat-perl (0.40-2) ...
update-perl-sax-parsers: Registering Perl SAX parser XML::SAX::Expat with priority 50...
Parsing recipes: 100% |##########################################| Time: 0:02:20
Parsing of 2511 .bb files complete (0 cached, 2511 parsed). 3259 targets, 545 skipped, 0 masked, 0 errors.
WARNING: No recipes available for:
  /home/futura/tisdk/sources/meta-openamp/recipes-bsp/device-tree/device-tree-generation_%.bbappend
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION        = "1.32.0"
BUILD_SYS         = "x86_64-linux"
NATIVELSBSTRING   = "Ubuntu-14.04"
TARGET_SYS        = "arm-linux-gnueabi"
MACHINE           = "am437x-evm"
DISTRO            = "arago"
DISTRO_VERSION    = "2017.06"
TUNE_FEATURES     = "arm armv7a vfp thumb neon       callconvention-hard"
TARGET_FPU        = "hard"
meta-processor-sdk = "HEAD:25e37e074b3a5f43588b3979c84e8684efb49c85"
meta-arago-distro
meta-arago-extras = "HEAD:8f49ed67d0627a04ac72fd388fda7756273ba2d7"
meta-browser      = "HEAD:08576b03af624b65ad949c410d84c11c7d1f2e39"
meta-openamp      = "HEAD:8a214032bfb7e8124bc1485c70c69f7d60abb819"
meta-qt5          = "HEAD:2c9f0e4eb0e9097f6f872ec1e1d81768a8ab5f1b"
meta-networking
meta-ruby
meta-python
meta-oe
meta-gnome        = "HEAD:fe5c83312de11e80b85680ef237f8acb04b4b26e"
meta-ti           = "HEAD:a18d57af8384ced25996739bb66d197c69efb77b"
meta-linaro-toolchain
meta-optee        = "HEAD:49b0f32d7e955f250b0022d1b2f403f45a2c2d9c"
meta              = "HEAD:e3911133ee9aad7cc3ae89faea80a097f6614fab"
Initialising tasks: 100% |#######################################| Time: 0:00:14
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
WARNING: byacc-native-20160606-r0 do_fetch: Failed to fetch URL ftp://invisible-island.net/byacc/byacc-20160606.tgz, attempting MIRRORS if available
WARNING: libpng-native-1.6.24-r0 do_fetch: Failed to fetch URL http://distfiles.gentoo.org/distfiles/libpng-1.6.24.tar.xz, attempting MIRRORS if available
WARNING: ti-sysbios-6_46_05_55-r0 do_unpack: TI installer requires 32bit glibc libraries for proper operation
run 'yum install glibc.i686' on Fedora or 'apt-get install libc6:i386' on Ubuntu/Debian
WARNING: ti-cgt-pru-native-2.1.5-r0 do_unpack: TI installer requires 32bit glibc libraries for proper operation
WARNING: ti-cg-xml-native-2_41_00-r0 do_unpack: TI installer requires 32bit glibc libraries for proper operation
ERROR: ti-sysbios-6_46_05_55-r0 do_install: Function failed: do_install (log file is located at /home/futura/tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/ti-sysbios/6_46_05_55-r0/temp/log.do_install.26289)
ERROR: Logfile of failure stored in: /home/futura/tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/ti-sysbios/6_46_05_55-r0/temp/log.do_install.26289
Log data follows:
| DEBUG: Executing shell function do_install
| cp: cannot stat ‘/home/futura/tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/ti-sysbios/6_46_05_55-r0/bios_6_46_05_55/*’: No such file or directory
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_install (log file is located at /home/futura/tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/ti-sysbios/6_46_05_55-r0/temp/log.do_install.26289)
ERROR: Task (/home/futura/tisdk/sources/meta-ti/recipes-ti/bios/ti-sysbios_6.46.05.55.bb:do_install) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1728 tasks of which 0 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 6 WARNING messages shown.
futura@futura:~/tisdk/build$ ^C
Please find attached Log file which is created while building SDK.
Finally It created processor sdk 4.01.00.06. I have followed the following steps to build kernel file.
cd /home/rajatrao/ti-processor-sdk-linux-am437x-evm-04.01.00.06/board-support/linux-4..9.41+gitAUTOINC+e3a80a1c5c-ge3a80a1c5c
export PATH=/home/winiston/ti-processor-sdk-linux-am437x-evm-04.01.00.06/linux-devkit/sysroots/x86_64-arago-linux/usr/bin:$PATH
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- distclean
I got errors while doing "distclean". Error report files attached .
 CC      lib/dynamic_queue_limits.o
  CC      lib/glob.o
  CC      lib/strncpy_from_user.o
  CC      lib/strnlen_user.o
  CC      lib/net_utils.o
  CC      lib/sg_split.o
  CC      lib/sg_pool.o
  GEN     lib/oid_registry_data.c
Can't locate strict.pm in @INC (you may need to install the strict module) (@INC contains: //usr/lib/perl/site_perl/5.22.1 //usr/lib/perl/vendor_perl/5.22.1 //usr/lib/perl/5.22.1 /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/site_perl/5.22.1/ /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/site_perl/5.22.1 /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/vendor_perl/5.22.1/ /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/vendor_perl/5.22.1 /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/5.22.1/ /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/5.22.1 /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/5.22.1 .) at ./lib/build_OID_registry line 14.
BEGIN failed--compilation aborted at ./lib/build_OID_registry line 14.
make[1]: *** [lib/oid_registry_data.c] Error 2
make: *** [lib] Error 2
futura@futura:~/ti-processor-sdk-linux-am437x-evm-04.01.00.06/board-support/linux-4.9.41+gitAUTOINC+e3a80a1c5c-ge3a80a1c5c$
and i execute command to build zImage as given below.
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- tisdk_am437x-evm_defconfig
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- zImage
After execute this command , I got errors. Please find attached error report.
futura@futura:~/ti-processor-sdk-linux-am437x-evm-04.01.00.06/board-support/linux-4.9.41+gitAUTOINC+e3a80a1c5c-ge3a80a1c5c$ make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- zImage
  CHK     include/config/kernel.release
  CHK     include/generated/uapi/linux/version.h
  CHK     include/generated/utsrelease.h
  CHK     include/generated/bounds.h
  CHK     include/generated/timeconst.h
  CHK     include/generated/asm-offsets.h
  CALL    scripts/checksyscalls.sh
  CHK     include/generated/compile.h
  CHK     kernel/config_data.h
  DTC     drivers/gpu/drm/tilcdc/tilcdc_slave_compat.dtb
  DTB     drivers/gpu/drm/tilcdc/tilcdc_slave_compat.dtb.S
  AS      drivers/gpu/drm/tilcdc/tilcdc_slave_compat.dtb.o
  LD      drivers/gpu/drm/tilcdc/built-in.o
rm drivers/gpu/drm/tilcdc/tilcdc_slave_compat.dtb drivers/gpu/drm/tilcdc/tilcdc_slave_compat.dtb.S
  LD      drivers/gpu/drm/built-in.o
  LD      drivers/gpu/built-in.o
  LD      drivers/built-in.o
zImage is also not created now.
How do I use JAVA run time(JAVA based application) in AM4378 texas based operating system?
How do i solve above error to build X11 based SDK?
Winiston.P
