Part Number: AM3354
Champs,
AM3354 based system is using NAND (Toshiba) device for booting.
There are some noise pattern signal with the IO lines as below picture.
The same pattern is also shown with AM335x GP EVM which is using Micron NAND.
So, can you explain about the noise pattern at IO lines between AM335x and NAND?
Can you check if the noise pattern of NAND IO lines can be ignored?
Hayden
