Linux/AM3352: USB Device settings
Guru 10305 points
Other Parts Discussed in Thread: AM3352
art Number: AM3352
Tool/software: Linux
Dear Sitara support Team,
My customer uses linux SDK from this site at March-2017.
processors.wiki.ti.com/.../Processor_SDK_Building_The_SDK
meta-yocto-bsp    = "HEAD:a3fa5ce87619e81d7acfa43340dd18d8f2b2d7dc"
meta-ti           = "HEAD:430ef4bcbd5f392c5e110c96072ae20ecbced04e"
He changes the kernel configration for the custom board to operate as a USB device.
The config file is here.zcat_proc_config.gz.log
When he checks by "lsusb" command, there is no display at all
such as " Bus ... ... root hub" on a console.
The custom board can be work as a USB host.
We suppose that the circuit diagram is no problem.
Could you point out that my customer' s configration is something wrong?
If you need more information to solve this issue, please let me know.
Kanae
  • Hi Biser,
    Thank you for your reply.
    My customer has checked these site in your post.
    He would like to have the reply to the config setting from linux expert member.
    He could not find the reason that there is no display with "lsusb".
    Could you please request to linux support team?
    Kanae
  • I have done this, but please expect some delay in our responses due to Christmas holidays, we will come back to you as soon as we can.
  • Please run the attached script on your board, it might give any clue.
    #!/bin/bash
    # Util to check USB subsystem for Linux kernel 3.12+ on TI Sitara devices
    # Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/
    #  Redistribution and use in source and binary forms, with or without
    #  modification, are permitted provided that the following conditions
    #  are met:
    #    Redistributions of source code must retain the above copyright
    #    notice, this list of conditions and the following disclaimer.
    #    Redistributions in binary form must reproduce the above copyright
    #    notice, this list of conditions and the following disclaimer in the
    #    documentation and/or other materials provided with the
    #    distribution.
    #    Neither the name of Texas Instruments Incorporated nor the names of
    #    its contributors may be used to endorse or promote products derived
    #    from this software without specific prior written permission.
    #  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    #  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    #  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    #  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    #  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    #  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    #  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    #  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    #  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    #  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    #  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    VERSION=0.2.4
    ### functions ###
    # $1 command to be checked
    check_command() {
        local _cmd=$1
        which $_cmd > /dev/null || {
            echo "Error: $_cmd command not found"
            exit 1
    # check if the kernel is supported
    # this tool only runs on v3.12+ kernel
    # return 0 - if kernel version >= 3.12
    #        1 - if kernel version < 3.12
    has_supported_kernel() {
    	local _ver
    	local _t
        check_command uname
        uname -a
    	_ver=`uname -r`
        _t=${_ver%%.*}
        # 2.x.x, unsupported
        [ $_t -ge 3 ] || return 1
        # 4.x.x, supported
        [ $_t -lt 4 ] || return 0
        _ver=${_ver#*.}
        _t=${_ver%%.*}
        # < 3.12.x, unsupported
        [ $_t -ge 12 ] || return 1
        return 0
    # check if the platform is supported
    #    $PLATFORM - global variable
    # return 0 - if platform is supported
    #        1 - if platform is not supported
    check_platform () {
    	local _hw
        check_command grep
        [ "$PLATFORM" != "" ] || {
    	    _hw=`grep '^Hardware' /proc/cpuinfo`
    	    DBG_PRINT $_hw
            if [ "${_hw#*AM33XX}" != "$_hw" ]; then
                PLATFORM="am335x"
            elif [ "${_hw#*AM43}" != "$_hw" ]; then
                PLATFORM="am437x"
            elif [ "${_hw#*DRA7}" != "$_hw" ]; then
                PLATFORM="am57x"
            elif [ "${_hw#*Keystone}" != "$_hw" ]; then
                PLATFORM="keystone"
            else
                PLATFORM="unknown"
            fi
        DBG_PRINT $PLATFORM
        case $PLATFORM in
            "am335x")
                USB0='usb@47400000/usb@47401000'
                USB1='usb@47400000/usb@47401800'
                return 0;;
            "am437x")
                USB0='omap_dwc3@48380000/usb@48390000'
                USB1='omap_dwc3@483c0000/usb@483d0000'
                return 0;;
            "am57x")
                USB0='omap_dwc3_1@48880000/usb@48890000'
                USB1='omap_dwc3_2@488c0000/usb@488d0000'
                return 0;;
            "keystone")
                return 0;;
                echo "Unsupported $PLATFORM"
                return 1;;
        esac
    # check a kernel CONFIG option
    # params $1 - the config option
    #        $2 = '-q', quiet output
    # return 0 - undefined
    #        1 - defined as 'm', kernel module
    #        2 - defined as 'y', kernel builtin
    check_kernel_config() {
        local _cfg
        [ -n "$1" ] || return 0
        check_command zcat
        _cfg=`zcat /proc/config.gz | grep "^$1\>"`
        case ${_cfg#*=} in
            "y") return 2;;
            "m") return 1;;
              *) [ "$2" = "-q" ] ||
                  echo "Error: $1 is undefined in kernel config"
              return 0;;
        esac
    # check a kernel module
    # $1 - module name, relative path from drivers/, with .ko surfix
    # return 0 - found
    #        1 - error
    check_module() {
        local _modname
        local _moddep
        [ -n "$1" ] || return 1
        _modname="/lib/modules/`uname -r`/kernel/drivers/${1}.ko"
        _moddep="/lib/modules/`uname -r`/modules.dep"
        DBG_PRINT 1
        [ -f $_modname ] || {
            echo "Error: $_modname not found."
            echo "       Please ensure 'make module_install' is done properly."
            return 1
        DBG_PRINT 2
        [ -f $_moddep ] || $moddep_checked || {
            echo "Error: $_moddep not found."
            moddep_checked=true
        DBG_PRINT 3
        check_command lsmod
        check_command basename
        check_command tr
        lsmod | grep `basename $1 | tr '-' '_'` > /dev/null || {
            DBG_PRINT ">>>> ${1}.ko:"
            if grep "${1}.ko:" $_moddep > /dev/null; then
                DBG_PRINT 5
                echo "Error: $_moddep seems to be valid,"
                echo "       but `basename $1`.ko is not loaded."
                echo "       Please provide /proc/config.gz and /lib/module/`uname -r`/*"
                echo "       for further investigation."
            else
                DBG_PRINT 6
                echo "Error: `basename $1`: $_moddep is invalid."
                echo "       Please run command 'depmod' on the target to re-generate it,"
                echo "       then reboot the target. If the issue still exists, please"
                echo "       ensure 'make module_install' is done properly."
            fi
            DBG_PRINT 7
            return 1
        DBG_PRINT 8
        return 0
    # check kernel config, and modules (if CONFIG_*=M) for musb
    check_musb_drivers() {
        check_kernel_config CONFIG_USB_MUSB_HDRC
        [ $? != 1 ] || check_module 'usb/musb/musb_hdrc'
        check_kernel_config CONFIG_USB_MUSB_DUAL_ROLE -q
        [ $? != 0 ] || echo "Warning: CONFIG_USB_MUSB_DUAL_ROLE undefined."
        check_kernel_config CONFIG_USB_MUSB_DSPS
        [ $? != 1 ] || {
            check_module 'usb/musb/musb_dsps'
            check_module 'usb/musb/musb_am335x'
        check_kernel_config CONFIG_AM335X_PHY_USB
        [ $? != 1 ] || {
            check_module 'usb/phy/phy-am335x'
            check_module 'usb/phy/phy-am335x-control'
        check_kernel_config CONFIG_MUSB_PIO_ONLY -q
        [ $? != 0 ] || {
           if check_kernel_config CONFIG_TI_CPPI41 -q; then
               echo "Error: MUSB CPPI DMA mode is enabled, but CPPI moudle is not enabled in DMA Engine."
               echo "       Please enable CONFIG_TI_CPPI41 under DMA Engine Support in kernel config."
           fi
    # check kernel config, and modules (if CONFIG_*=M) for dwc3
    check_dwc3_drivers() {
        check_kernel_config CONFIG_USB_DWC3
        [ $? != 1 ] || check_module 'usb/dwc3/dwc3'
        check_kernel_config CONFIG_USB_DWC3_DUAL_ROLE -q
        [ $? != 0 ] || echo "Warning: CONFIG_USB_DWC3_DUAL_ROLE undefined."
        check_kernel_config CONFIG_USB_OTG -q
        [ $? != 0 ] || echo "Warning: CONFIG_USB_OTG undefined, which is required for DRD mode."
        check_kernel_config CONFIG_USB_DWC3_OMAP
        [ $? != 1 ] || check_module 'usb/dwc3/dwc3-omap'
        check_kernel_config CONFIG_USB_XHCI_HCD
        [ $? != 1 ] || {
            check_module 'usb/host/xhci-plat-hcd'
            check_module 'usb/host/xhci-hcd'
        check_kernel_config CONFIG_OMAP_CONTROL_PHY
        [ $? != 1 ] || check_module 'phy/phy-omap-control'
        if [ $PLATFORM = am437x ]; then
            check_kernel_config CONFIG_OMAP_USB2
            [ $? != 1 ] || check_module 'phy/phy-omap-usb2'
        else
            check_kernel_config CONFIG_TI_PIPE3
            [ $? != 1 ] || check_module 'phy/phy-ti-pipe3'
        fi
    ### debug ###
    g_log_file=/tmp/chkusb.log
    DBG_ENABLE() { g_dbg_enabled=true; }
    DBG_DISABLE() { g_dbg_enabled=false; }
    DBG_LOG_RESET() { ! $g_dbg_enabled || echo > $g_log_file; }
    DBG_PRINT() { ! $g_dbg_enabled || echo "$(date +%H:%M:%S) [$(basename $0)]: $*"; }
    DBG_LOG() { DBG_PRINT $* >> $g_log_file; }
    DBG_LOG_MARK() { DBG_PRINT "----------------" >> $g_log_file; }
    ### main ####
    moddep_checked=false
    echo "chkusb.sh Version $VERSION"
    [ "$V" = "1" ] && DBG_ENABLE && DBG_LOG_RESET || DBG_DISABLE
    has_supported_kernel ||
        { echo "Unsupported kernel version: `uname -r`"; exit 1; }
    check_platform || exit 2
    DBG_PRINT device: $PLATFORM
    check_command lsusb
    if lsusb > /dev/null 2>&1; then
        echo "USB is initialized"
    else
        echo "USB initialization failed"
        # failed, continue checking
        [ -f /proc/config.gz ] ||
            { echo "Error: /proc/config.gz not found"; exit 4; }
        case $PLATFORM in
            am335x) check_musb_drivers;;
            am437x | am57x | keystone) check_dwc3_drivers;;
                echo "Error: unsupported platform $PLATFORM"
                exit 5;;
        esac
    fi
    # check dr_mode & gadget drivers
    [ -d /proc/device-tree ] || {
        echo "Warning: /proc/device-tree/ not found"
        if [ -d "/lib/modules/`uname -r`/" ]; then
            echo "The list of USB gadget drivers installed:"
            ls -1Rp "/lib/modules/`uname -r`/kernel/drivers/usb/gadget/"
        fi
        exit 0
    for _usb in "${USB0}" "${USB1}"; do
        _usb_dir="/proc/device-tree/ocp/${_usb}"
        _status=`cat $_usb_dir/status 2> /dev/null`
        _dr_mode=`cat $_usb_dir/dr_mode`
        echo `basename $_usb`: $_dr_mode, $_status
        [ "$_status" = "disabled" -o "$_dr_mode" = "host" ] || gadget_mode=true
    done
    DBG_PRINT $gadget_mode
    $gadget_mode || exit 0
    echo
    check_kernel_config CONFIG_USB_LIBCOMPOSITE
    case $? in
        0) echo "Error: no any gadget driver enabled"
           exit 6;;
        1) is_gadget_builtin=false;;
        2) echo "The gadget driver is built-in"
           is_gadget_builtin=true;;
    esac
    check_kernel_config CONFIG_USB_ZERO -q ||
        echo "Gadget Kernel Config: g_zero is enabled"
    check_kernel_config CONFIG_USB_AUDIO -q ||
        echo "Gadget Kernel Config: g_audio is enabled"
    check_kernel_config CONFIG_USB_ETH -q ||
        echo "Gadget Kernel Config: g_ether is enabled"
    check_kernel_config CONFIG_USB_G_NCM -q ||
        echo "Gadget Kernel Config: g_ncm is enabled"
    check_kernel_config CONFIG_USB_MASS_STORAGE -q ||
        echo "Gadget Kernel Config: g_mass_storage is enabled"
    check_kernel_config CONFIG_USB_G_SERIAL -q ||
        echo "Gadget Kernel Config: g_serial is enabled"
    check_kernel_config CONFIG_USB_G_PRINTER -q ||
        echo "Gadget Kernel Config: g_printer is enabled"
    g_driver=`grep '^DRIVER=' /sys/class/udc/*/uevent 2>/dev/null`
    echo "gadget driver loaded: ${g_driver:-(none)}"
    echo
    if ! $is_gadget_builtin; then
        else
            echo "Error: /lib/modules/`uname -r`/ not found"
            echo "       Please ensure 'make modules_install' is done properly."
            exit 7
        fi
    fi
    # vim: ft=sh:ts=4:sw=4:et
    What usb device function do you use? Please describe how you load the usb gadget driver.
    lsusb command is for usb host mode, it does nothing for usb device mode. So you shouldn't rely on this command for usb device mode.
  • Hi Bin,
    Here are additional information from my customer.
    1. Result of sunning chkusb.sh
    ### USB0 = peripheral
    root@am335x_XXXX:/usr/bin# ./chkusb.sh
    chkusb.sh Version 0.2.4
    Linux am335x_XXXX 4.4.41-g7c580a51af #5 PREEMPT Thu Jan 11 16:44:55 JST 2018 armv7l GNU/Linux
    USB is initialized
    usb@47401000: peripheral, okay
    usb@47401800: host, okay
    gadget driver loaded: (none)
    2. Customer's usecase
    Set USB0 as peripheral for the network interface to PC.
    It assigns IP address and connects to TELNET or SSH via USB cable.
    3. Customer would like to know how to load the usb gadget driver correctly.
    Therefore he cannot describe it.
    4. about "lsusb"
    # Case of USB0 is peripheral setting, and USB1 is host setting.
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    # Case of USB0 and USB1 are host setting (For reference)
    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Enable host setting can be displayed with lsusb.
    Do you think the above performances are no problem?
    If you need other information, please let me know.
    Kanae
    Built-in gadget driver is not functional. Please check the 'known issue' section in processors.wiki.ti.com/.../MUSB_Linux_Driver_Configuration
    So please build g_ether driver as a kernel module.
  • Hi Bin,
    I really appreciate your support.
    My customer's board could be set to USB device properly.
    Kanae
