Are there any known issues with HDMI/DVI driving various monitors that present different impedance?
If monitor momentarily Ground TMDS signals, can this cause device damage?
Marc
Marc
Marc,
pathfinder said:Are there any known issues with HDMI/DVI driving various monitors that present different impedance?
I am not aware of such known issue. AM387x HDMI is 1.3a standard compatible and should work fine with every monitor that is compatible with this 1.3a standard.
pathfinder said:If monitor momentarily Ground TMDS signals, can this cause device damage?
You should check the 1.3a HDMI standard. If this standard does not allow "monitor momentarily Ground TMDS signals", then probably AM387x device will be damaged.
Pavel
Pavel,
Can you verify that HDMI controller and TMDS control can be disabled or 'turned off'? What actually happens to the TMDS lines if it disabled?
According to Technical Reference Manual for AM3874, here are some registers that relate to TMDS:
I assume AM3874 can disable TMDS driver if set those bits in the registers to 0. Please help us to verify.
Thanks.
Marc
