Linux/PROCESSOR-SDK-AM335X: Qt compilation error
Part Number: PROCESSOR-SDK-AM335X
Tool/software: Linux
/work/4.9.41_sdk/qt/qt-everywhere-opensource-src-5.1.1$ sudo ./configure -prefix /home1/madhu/qt5.1.1_install -release -make libs -xplatform linux-arm-gnueabi-ti-g++ -opengl es2 -confirm-license -opensource -no-xcb -no-pch -make examples -verbose
  • cd qtbase
  • /home/ninad/work/4.9.41_sdk/qt/qt-everywhere-opensource-src-5.1.1/qtbase/configure -prefix /home1/madhu/qt5.1.1_install -release -make libs -xplatform linux-arm-gnueabi-ti-g++ -opengl es2 -confirm-license -opensource -no-xcb -no-pch -make examples -verbose
    /home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -fvisibility=hidden fvisibility.c
    Symbol visibility control enabled.
    /home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -o libtest.so -shared -Wl,-Bsymbolic-functions -fPIC bsymbolic_functions.c
    /home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/../lib/gcc/arm-linux-gnueabihf/6.2.1/../../../../arm-linux-gnueabihf/bin/ld: cannot find crti.o: No such file or directory
    /home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/../lib/gcc/arm-linux-gnueabihf/6.2.1/../../../../arm-linux-gnueabihf/bin/ld: cannot find -lm
    collect2: error: ld returned 1 exit status
    Symbolic function binding disabled.
This is the Qt Open Source Edition.
You are licensed to use this software under the terms of
the Lesser GNU General Public License (LGPL) versions 2.1.
You have already accepted the terms of the license.
Creating qmake...
make: Nothing to be done for `first'.
Running configuration tests...
Warning: Disabling pkg-config since PKG_CONFIG_LIBDIR is not set.
Warning: Disabling pkg-config since PKG_CONFIG_SYSROOT_DIR is not set.
Determining architecture... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -g -Wall -W -fPIE -I../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o arch.o arch.cpp
arch.cpp:45:19: fatal error: stdio.h: No such file or directory
#include <stdio.h>
compilation terminated.
make: *** [arch.o] Error 1
Unable to determine architecture!
Could not determine the target architecture!
Turn on verbose messaging (-v) to see the final report.
g++ -c -pipe -g -Wall -W -fPIE -I../../mkspecs/linux-g++ -I. -o arch.o arch.cpp
g++ -o arch arch.o
{ test -n "" && DESTDIR="" || DESTDIR=.; } && test $(gdb --version | sed -e 's,[^0-9]+([0-9]).([0-9]).*,\1\2,;q') -gt 72 && gdb --nx --batch --quiet -ex 'set confirm off' -ex "save gdb-index $DESTDIR" -ex quit 'arch' && test -f arch.gdb-index && objcopy --add-section '.gdb_index=arch.gdb-index' --set-section-flags '.gdb_index=readonly' 'arch' 'arch' && rm -f arch.gdb-index || true
Found architecture in binary
CFG_HOST_ARCH="x86_64"
CFG_HOST_CPUFEATURES=" mmx sse sse2"
System architecture: 'unknown'
Host architecture: 'x86_64'
C++11 auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -std=c++0x -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o c++11.o c++11.cpp
c++11.cpp:48:19: fatal error: utility: No such file or directory
#include <utility>
make: *** [c++11.o] Error 1
C++11 disabled.
floatmath auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o floatmath.o floatmath.cpp
floatmath.cpp:42:18: fatal error: math.h: No such file or directory
#include <math.h>
make: *** [floatmath.o] Error 1
floatmath disabled.
sse2 auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -msse2 -g -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o sse2.o sse2.cpp
arm-linux-gnueabihf-g++: error: unrecognized command line option '-msse2'
make: *** [sse2.o] Error 1
sse2 disabled.
sse3 auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -msse3 -g -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o sse3.o sse3.cpp
arm-linux-gnueabihf-g++: error: unrecognized command line option '-msse3'
make: *** [sse3.o] Error 1
sse3 disabled.
ssse3 auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -mssse3 -g -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o ssse3.o ssse3.cpp
arm-linux-gnueabihf-g++: error: unrecognized command line option '-mssse3'
make: *** [ssse3.o] Error 1
ssse3 disabled.
sse4_1 auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -msse4.1 -g -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o sse4_1.o sse4_1.cpp
arm-linux-gnueabihf-g++: error: unrecognized command line option '-msse4.1'
make: *** [sse4_1.o] Error 1
sse4_1 disabled.
sse4_2 auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -msse4.2 -g -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o sse4_2.o sse4_2.cpp
arm-linux-gnueabihf-g++: error: unrecognized command line option '-msse4.2'
make: *** [sse4_2.o] Error 1
sse4_2 disabled.
avx auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -mavx -g -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o avx.o avx.cpp
arm-linux-gnueabihf-g++: error: unrecognized command line option '-mavx'; did you mean '-marm'?
make: *** [avx.o] Error 1
avx disabled.
zlib auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o zlib.o zlib.cpp
zlib.cpp:42:18: fatal error: zlib.h: No such file or directory
#include <zlib.h>
make: *** [zlib.o] Error 1
zlib disabled.
libjpeg auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o libjpeg.o libjpeg.cpp
libjpeg.cpp:42:23: fatal error: sys/types.h: No such file or directory
#include <sys/types.h>
make: *** [libjpeg.o] Error 1
libjpeg disabled.
libpng auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o libpng.o libpng.cpp
libpng.cpp:42:17: fatal error: png.h: No such file or directory
#include <png.h>
make: *** [libpng.o] Error 1
libpng disabled.
DB2 auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o db2.o db2.cpp
db2.cpp:42:20: fatal error: sqlcli.h: No such file or directory
#include <sqlcli.h>
make: *** [db2.o] Error 1
DB2 disabled.
InterBase auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o ibase.o ibase.cpp
ibase.cpp:42:19: fatal error: ibase.h: No such file or directory
#include <ibase.h>
make: *** [ibase.o] Error 1
InterBase disabled.
MySQL (thread-safe) auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o mysql.o ../mysql/mysql.cpp
../mysql/mysql.cpp:42:19: fatal error: mysql.h: No such file or directory
#include "mysql.h"
make: *** [mysql.o] Error 1
MySQL (thread-safe) disabled.
MySQL (thread-unsafe) auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o mysql.o mysql.cpp
#include "mysql.h"
MySQL (thread-unsafe) disabled.
OCI auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o oci.o oci.cpp
oci.cpp:42:17: fatal error: oci.h: No such file or directory
#include <oci.h>
make: *** [oci.o] Error 1
OCI disabled.
ODBC auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o odbc.o odbc.cpp
odbc.cpp:45:17: fatal error: sql.h: No such file or directory
#include <sql.h>
make: *** [odbc.o] Error 1
ODBC disabled.
iODBC auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o iodbc.o iodbc.cpp
iodbc.cpp:42:17: fatal error: sql.h: No such file or directory
#include <sql.h>
make: *** [iodbc.o] Error 1
iODBC disabled.
PostgreSQL auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o psql.o psql.cpp
psql.cpp:42:22: fatal error: libpq-fe.h: No such file or directory
#include "libpq-fe.h"
make: *** [psql.o] Error 1
PostgreSQL disabled.
SQLite2 auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o sqlite2.o sqlite2.cpp
sqlite2.cpp:42:20: fatal error: sqlite.h: No such file or directory
#include <sqlite.h>
make: *** [sqlite2.o] Error 1
SQLite2 disabled.
TDS auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o tds.o tds.cpp
tds.cpp:42:22: fatal error: sybfront.h: No such file or directory
#include <sybfront.h>
make: *** [tds.o] Error 1
TDS disabled.
NIS auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o nis.o nis.cpp
nis.cpp:42:23: fatal error: sys/types.h: No such file or directory
make: *** [nis.o] Error 1
NIS disabled.
Cups auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o cups.o cups.cpp
cups.cpp:42:23: fatal error: cups/cups.h: No such file or directory
#include <cups/cups.h>
make: *** [cups.o] Error 1
Cups disabled.
POSIX iconv auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o iconv.o iconv.cpp
iconv.cpp:45:19: fatal error: iconv.h: No such file or directory
#include <iconv.h>
make: *** [iconv.o] Error 1
POSIX iconv disabled.
SUN libiconv auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o gnu-libiconv.o ../gnu-libiconv/gnu-libiconv.cpp
../gnu-libiconv/gnu-libiconv.cpp:45:19: fatal error: iconv.h: No such file or directory
#include <iconv.h>
make: *** [gnu-libiconv.o] Error 1
SUN libiconv disabled.
GNU libiconv auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o gnu-libiconv.o gnu-libiconv.cpp
#include <iconv.h>
GNU libiconv disabled.
D-Bus auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o dbus.o dbus.cpp
dbus.cpp:43:23: fatal error: dbus/dbus.h: No such file or directory
#include <dbus/dbus.h>
make: *** [dbus.o] Error 1
D-Bus disabled.
Glib auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o glib.o glib.cpp
glib.cpp:44:18: fatal error: glib.h: No such file or directory
#include <glib.h>
make: *** [glib.o] Error 1
Glib disabled.
ICU auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o icu.o icu.cpp
icu.cpp:42:28: fatal error: unicode/utypes.h: No such file or directory
#include <unicode/utypes.h>
make: *** [icu.o] Error 1
ICU disabled.
PulseAudio auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o pulseaudio.o pulseaudio.cpp
pulseaudio.cpp:42:30: fatal error: pulse/pulseaudio.h: No such file or directory
#include <pulse/pulseaudio.h>
make: *** [pulseaudio.o] Error 1
PulseAudio disabled.
OpenGL ES 2.x auto-detection... ()
/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/sgx/OGLES2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/glib-2.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/lib/glib-2.0/include/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/libxml2/ -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/freetype2 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0 -I/home/ninad/work/4.9.41_sdk/qt/rfs/usr/include/dbus-1.0/dbus -o opengles2.o opengles2.cpp
opengles2.cpp:45:25: fatal error: GLES2/gl2.h: No such file or directory
#include <GLES2/gl2.h>
make: *** [opengles2.o] Error 1
OpenGL ES 2.x disabled.
The OpenGL ES 2.0 functionality test failed!
You might need to modify the include and library search paths by editing
QMAKE_INCDIR_OPENGL_ES2, QMAKE_LIBDIR_OPENGL_ES2 and QMAKE_LIBS_OPENGL_ES2 in
/home/work/4.9.41_sdk/qt/qt-everywhere-opensource-src-5.1.1/qtbase/mkspecs/linux-arm-gnueabi-ti-g++.
qmake configuration for building with arm-linux-gnueabi-g++
My qtbase/mkspecs/linux-arm-gnueabi-ti-g++/qmake.conf
MAKEFILE_GENERATOR = UNIX
CONFIG += incremental gdb_dwarf_index
QMAKE_INCREMENTAL_STYLE = sublib
include(../common/linux.conf)
include(../common/gcc-base-unix.conf)
include(../common/g++-unix.conf)
ROOTFS_PATH=/home/ninad/work/4.9.41_sdk/qt/rfs
TOOLCHAIN_PREFIX=/home/ninad/work/4.9.41_sdk/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf
Change the required paths here
QMAKE_INCDIR = $${ROOTFS_PATH}/usr/include $${ROOTFS_PATH}/usr/include/glib-2.0 $${ROOTFS_PATH}/usr/lib/glib-2.0/include/ $${ROOTFS_PATH}/usr/include/libxml2/ $${ROOTFS_PATH}/usr/include/freetype2 $${ROOTFS_PATH}/usr/include/dbus-1.0 $${ROOTFS_PATH}/usr/include/dbus-1.0/dbus
QMAKE_LIBDIR = $${ROOTFS_PATH}/usr/lib/arm-linux-gnueabi $${ROOTFS_PATH}/usr/lib/libpthread_nonshared.a
QMAKE_INCDIR_OPENGL_ES2 = $${ROOTFS_PATH}/usr/include/sgx/OGLES2
QMAKE_LIBDIR_OPENGL_ES2 = $${ROOTFS_PATH}/opt/gfxlibraries/gfx_rel_es8.x
QMAKE_INCDIR_EGL = $${QMAKE_INCDIR_OPENGL_ES2}
QMAKE_LIBDIR_EGL = $${QMAKE_LIBDIR_OPENGL_ES2}
libs
#QMAKE_LIBS = -lxml2 -lz -lts -lasound -lfreetype -lexpat
#-lfontconfig -lpng -lpthread -Wl,-rpath-link=$${ROOTFS_PATH}/usr/lib/arm-linux-gnueabi -Wl,-rpath-link=$${ROOTFS_PATH}/usr/lib -Wl,-rpath-#link=$${ROOTFS_PATH}/lib/arm-linux-gnueabi/
QMAKE_LIBS_OPENGL_ES2= -lEGL -lIMGegl -lsrv_um -lGLESv2 -lGLES_CM -lusc
QMAKE_LIBS_EGL= $${QMAKE_LIBS_OPENGL_ES2}
QMAKE_LIBS_THREAD = -lpthread
QMAKE_CFLAGS_RELEASE = -O3 -march=armv7-a -mfpu=neon -mfloat-abi=hard -fPIC
QMAKE_CXXFLAGS_RELEASE = $$QMAKE_CFLAGS_RELEASE
QMAKE_CC = $${TOOLCHAIN_PREFIX}-gcc
QMAKE_CXX = $${TOOLCHAIN_PREFIX}-g++
QMAKE_LINK = $${QMAKE_CXX}
QMAKE_LINK_SHLIB = $${QMAKE_CXX}
QMAKE_AR = $${TOOLCHAIN_PREFIX}-ar cqs
QMAKE_OBJCOPY = $${TOOLCHAIN_PREFIX}-objcopy
QMAKE_STRIP = $${TOOLCHAIN_PREFIX}-strip
load(qt_config)
Steps i followed
1. Applied patches
2. Modified qmake.conf,  qtbase/mkspecs/linux-arm-gnueabi-ti-g++/qmake.conf
3. sudo ./configure -prefix /home1/madhu/qt5.1.1_install -release -make libs -xplatform linux-arm-gnueabi-ti-g++ -opengl es2 -confirm-license -opensource -no-xcb -no-pch -make examples -verbose
Error seems like some linking problem with new sdk(ti-processor-sdk-linux-am335x-evm-04.01.00.06). I tried the same steps with ti-sdk-am335x-evm-07.00.00.00. It successfully cross-compiled.
Thanks in advance
I am new to Qt, kindly help me to resolve this issue..
