Part Number: AM5728
Tool/software: Linux
I want to capture and encode a video with the AM5728 EVM using sdk 4.01
Here is my code :
#include <stdio.h>
#include <gst/gst.h>
#include <time.h>
#include <string.h>
#include <stdlib.h>
#include<glib.h>
#define FRAME_264 (1280*720)
#include <sys/time.h>
��·ͨ�������źſ�ʼͬʱ�ɼ����룬��������������룬���Բ�ͬ�ļ�������
FILE *pFile[4];
unsigned int *dataPtr = NULL;
GstElement *pipeline[6];
GstBus *bus[6];
GstMessage *msg[6];
GstElement *src, *video_queue, *video_convert, *q1, *video_enc, *parse, *q3, *mux, *video_sink;
GstElement *tee, *pic_queue, *pic_convert, *q2, *pic_enc, *pic_sink;
GstPad *tee_video_pad, *tee_picture_pad;
GstPad *queue_video_pad, *queue_picture_pad;
static int i=0;
static void new_sample (GstElement *sink) {
GstSample *sample = NULL;
GstBuffer *buffer = NULL;
/* Retrieve the buffer */
g_signal_emit_by_name (pic_sink, "pull-sample", &sample);
buffer = gst_sample_get_buffer (sample);
int size = gst_buffer_get_size (buffer);
i++;
g_print("i:%d\n",i);
if (i>50)
i=0;
if (buffer) {
FILE *fp = NULL;
//fp = fopen("/opt/image/deviceid/tunnel_1/image.jpg","wb+");
fp = fopen("image.jpg","wb+");
gst_buffer_extract (buffer,0,dataPtr,size);
fwrite(dataPtr, sizeof(unsigned int), size, fp);
gst_buffer_unref (buffer);
fclose(fp);
fp = NULL;
g_print("have buffer!");
//system("/opt/uploadoss/main image deviceid tunnel_1 image.jpg");
else
//gst_sample_unref(sample);
sample = NULL;
buffer = NULL;
static gboolean link_source_element_with_filter(GstElement *element1,
GstElement *element2, int width, int height, int framerate)
/* CAPS to be link:
* 'video/x-raw, format=(string)YUY2, width=(int)800, height=(int)600, framerate=5/1'
gboolean link_ok;
GstCaps *caps;
caps = gst_caps_new_simple("video/x-raw",
"format", G_TYPE_STRING, "YUY2",
"width", G_TYPE_INT, width,
"height", G_TYPE_INT, height,
"framerate", GST_TYPE_FRACTION, framerate, 1,
NULL);
link_ok = gst_element_link_filtered(element1, element2, caps);
gst_caps_unref(caps);
if (!link_ok) {
g_warning("Failed to link element1 and element2!(v4l2src->convert)");
return link_ok;
void link_to_multiplexer(
GstElement *tolink_element,
GstElement *mux)
GstCaps *pad_caps = NULL;
GstPad *pad;
GstPad *tolink_pad;
GstPadLinkReturn ret;
tolink_pad = gst_element_get_static_pad(tolink_element, "src");
pad_caps = gst_pad_query_caps(tolink_pad, NULL);
pad = gst_element_get_compatible_pad(mux, tolink_pad, pad_caps);
gst_caps_unref(pad_caps);
ret = gst_pad_link(tolink_pad, pad);
if (ret==0)
g_print("aaa\n");
gst_object_unref(GST_OBJECT(pad));
g_print("A new pad %s was created and linked to %s\n", gst_pad_get_name(tolink_pad), gst_pad_get_name(pad));
/* Main function does atual processing */
void record_start(int channel, char * filename)
//gst-launch-1.0 -e videotestsrc ! 'video/x-raw, format=(string)NV12, width=(int)1280, height=(int)720, framerate=(fraction)30/1' ! vpe num-input-buffers=8 ! queue ! ducatih264enc bitrate=4000 ! queue ! h264parse ! qtmux ! filesink location=x.mov
// GstElement *src, *video_queue, *video_convert, *q1, *video_enc, *parse, *q3, *mux, *video_sink;
// GstElement *tee, *pic_queue, *pic_convert, *pic_enc, *pic_sink;
gst_init(NULL, NULL);
/* Create the empty pipeline */
pipeline[channel] = gst_pipeline_new("test-pipeline");
/* Create the elements */
src = gst_element_factory_make("v4l2src", "video_source");
g_object_set(G_OBJECT(src), "device", "/dev/video1", NULL);
g_object_set(G_OBJECT(src), "io-mode", 4, NULL);
g_object_set(G_OBJECT(src), "num-buffers", -1, NULL);
src = gst_element_factory_make("videotestsrc", "video_source");
video_convert = gst_element_factory_make("vpe", "video_convert");
g_object_set(G_OBJECT(video_convert), "num-input-buffers", 8, NULL);
q1 = gst_element_factory_make("queue", "q1");
video_enc = gst_element_factory_make("ducatih264enc", "video_enc");
g_object_set(G_OBJECT(video_enc), "profile", 100, NULL);//10000��������⣿��
g_object_set(G_OBJECT(video_enc), "level", 41, NULL);//10000��������⣿��
g_object_set(G_OBJECT(video_enc), "bitrate", 10000, NULL);//10000��������⣿��
parse = gst_element_factory_make("h264parse", "parser");
q3 = gst_element_factory_make("queue", "q3");
mux = gst_element_factory_make("avimux", "mux");
video_sink = gst_element_factory_make("filesink", "video_sink");
g_object_set(G_OBJECT(video_sink), "location", filename, NULL);
q2 = gst_element_factory_make("queue", "q2");
tee = gst_element_factory_make ("tee", "tee");
video_queue =gst_element_factory_make("queue","video_queue");
pic_queue = gst_element_factory_make("queue","pic_queue");
pic_convert = gst_element_factory_make("vpe", "pic_convert");
g_object_set(G_OBJECT(pic_convert), "num-input-buffers", 8, NULL);
pic_enc = gst_element_factory_make("ducatijpegenc", "pic_enc");
//g_object_set (pic_enc, "intra-interval", 100, NULL);
pic_sink = gst_element_factory_make("appsink", "pic_sink");
g_object_set (pic_sink, "emit-signals", TRUE, NULL);
g_signal_connect (pic_sink, "new-sample", G_CALLBACK (new_sample), NULL);
gst_bin_add_many(GST_BIN(pipeline[channel]), src, tee, video_queue, video_convert, q1, video_enc, parse, q3, mux, video_sink, pic_queue, pic_convert, q2,pic_enc, pic_sink, NULL);
tee_video_pad = gst_element_get_request_pad (tee, "src_%u");
g_print ("Obtained request pad %s for video branch.\n", gst_pad_get_name (tee_video_pad));
queue_video_pad = gst_element_get_static_pad (video_queue, "sink");
tee_picture_pad = gst_element_get_request_pad (tee, "src_%u");
g_print ("Obtained request pad %s for picture branch.\n", gst_pad_get_name (tee_picture_pad));
queue_picture_pad = gst_element_get_static_pad (pic_queue, "sink");
if (gst_pad_link (tee_picture_pad, queue_picture_pad) != GST_PAD_LINK_OK ||
gst_pad_link (tee_video_pad, queue_video_pad) != GST_PAD_LINK_OK) {
g_printerr ("Tee could not be linked.\n");
gst_object_unref (pipeline);
if (gst_element_link_many (src, tee, NULL) != TRUE)
g_printerr ("src and tee could not be linked.\n");
link_source_element_with_filter(video_queue, video_convert, 1280, 720, 30);
if (gst_element_link_pads(video_convert, "src", q1, "sink") != TRUE)
g_print("1\n");
if (gst_element_link_pads(q1, "src", video_enc, "sink") != TRUE)
g_print("2\n");
if (gst_element_link_pads(video_enc, "src", parse, "sink") != TRUE)
g_print("3\n");
if (gst_element_link_pads(parse, "src", q3, "sink") != TRUE)
g_print("4\n");
link_to_multiplexer(q3, mux);
if (gst_element_link_pads(mux, "src", video_sink, "sink") != TRUE)
g_print("5\n");
link_source_element_with_filter(pic_queue, pic_convert, 1280, 720, 30);
if(gst_element_link_pads(pic_convert, "src", q2, "sink")!= TRUE)
g_print("6\n");
if(gst_element_link_pads(q2, "src", pic_enc, "sink")!= TRUE)
g_print("66\n");
if(gst_element_link_pads(pic_enc, "src", pic_sink, "sink")!= TRUE)
g_print("7\n");
gst_object_unref (queue_picture_pad);
gst_object_unref (queue_video_pad);
gst_element_set_state(pipeline[channel], GST_STATE_PLAYING);
void record_stop(int channel)
gst_element_send_event(pipeline[channel],gst_event_new_eos());
/* Wait until error or EOS */
bus[channel] = gst_element_get_bus(pipeline[channel]);
msg[channel] = gst_bus_timed_pop_filtered(bus[channel], GST_CLOCK_TIME_NONE , GST_MESSAGE_ERROR | GST_MESSAGE_EOS);//GST_CLOCK_TIME_NONE
gst_element_release_request_pad (tee, tee_picture_pad);
gst_element_release_request_pad (tee, tee_video_pad);
gst_object_unref (tee_picture_pad);
gst_object_unref (tee_video_pad);
if (msg[channel] != NULL)
gst_message_unref(msg[channel]);
gst_object_unref(bus[channel]);
gst_element_set_state(pipeline[channel], GST_STATE_PAUSED);
gst_element_set_state(pipeline[channel], GST_STATE_READY);
gst_element_set_state(pipeline[channel], GST_STATE_NULL);
gst_object_unref(pipeline[channel]);
void main()
dataPtr=(unsigned int*)malloc(sizeof(unsigned int) * FRAME_264);
memset(dataPtr,0,FRAME_264);
record_start(0, "ch0.avi");
sleep(50);
record_stop(0);
free(dataPtr);
dataPtr = NULL;
And it always encountered a problem:
** (video_picture:1261): CRITICAL **: gst_fd_memory_get_fd: assertion 'GST_IS_FD_ALLOCATOR (mem->allocator)' failed
Could u give me some advice of my code?
And I have asked the question in this website:
But after tring the advice u gave before,I have not solved the problem.
So could give me some advice about the problem.
Thanks®ards!
