Part Number: TDA2EXEVM
First I runned semantic segmentation usecase completly correct with your test data files:inData and inHeader.
As suggestion ,I generate test data for semantic segmentation usecase as follow:
1、ffmpeg -i in3.mp4 -y -c libx264 -vf setsar=0:1 -refs:v 3 -r:v 15 -b 10M -threads 6 out2.h264 , the out2.h264 is inData for semantic segmentation usecase
2、PAT=size
sed -n "/$PAT/p" index.idx | cut -d' ' -f3 >> size_extracted.txt
3、delete all strings in size_exatracted.txt,then
cat size_extracted.txt | perl -n -e 'printf("%08x\n",$_)' | sed 's/\(..\)\(..\)\(..\)\(..\)/0x\4\n0x\3\n0x\2\n0x\1/' | xxd -r -p > Size_test.bin the Size_test.bin is inHeader for semantic segmentation usecase
the out2.h264 could play correct on PC,and when I use those tow files for semantic segmentation usecase,they can display and show results;
but the result show sequence is not correct,for examples,may be the frame 30 dispaly before the frame 29.
Is I misss some args for the command "ffmpeg" ?
Or what is the detail args for the "ffmpeg"?
Pls help me!It confuse me several days.
Best regards
