TSIF details for parallel synch use case
Is there documentation that gives detailed descriptions of the TSIF module  control signals (more details than SPRUEQ2E)?
Specifically, I need to know  how to generate the pkt_start  signal for the synchronous parallel interface using 188 byte transport packets.
Should pkt_start coincide with the sync_byte in each packet . . . or does it just need to occur every 188 bytes . . . or as Figure 13 in SPRUEQ2E implies is pkt_start only required once at the beginning of time??
