Linux/AM3354: Screen capture with Qt5
Part Number: AM3354
Tool/software: Linux
Hi
    we are using AM3354 with processor SDK 03.02.00.05 and 04.02.00.09.
    we have a Qt5 application running on a 320x240 LCD screen.
    Now we want to take a screenshot of the current screen.
    But without sucess.
    Here's couple of things i tried:
    1.cat /dev/fb0 > xxx.bmp
    2./usr/bin/screenshot xxx.bmp
    these 2 methods ends up taking a screenshot of our kernel bootup logo.Not the realtime screen display of our running Qt5 app.
   3./usr/libexec/weston-screenshooter
     i don't know how to start this...but it seems it's also some kind of screenshot taker?
   4./usr/share/qt5/examples/widgets/desktop/screenshot
    i can run this application.But it will fail when i try to save the screenshot.
could you help?
thank you
  • Hello semiyd,
    Please use this method to take a screenshot.
    Kemal
  • Thanks Kemal!
    i will refer to the thread you sent.
  • Hi kemal:
      in that thread.i saw you explained as folloows:
    On Wayland use the MOD+S shortcut to take a screenshot and MOD+R to take a rapid screenshots (video). You can find these command's source codes in weston-<version>/clients/screenshot.c and weston-<version>/src/screenshooter.c files.
      Could you explain it in more detail as to exactly what a re the steps i should take in order to take the screenshot?
      I did found screenshooter.c in my arago build environment:
    /home/yandong/tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/weston/1.9.0-r0.arago15.tisdk0/weston-1.9.0/src
      I suppose this is the source file that builds /usr/libexec/weston-screenshooter. Right?
      Here's the steps i took
      1.systemctl stop matrix-gui-2.0.service
      2.systemctl disable matrix-gui-2.0.service
      by now.matrix-gui is stopped.but weston is up and running.
      3.root@am335x-evm:/usr/libexec# /usr/libexec/weston-screenshooter
    weston-screenshooter must be launched by weston.
    Use the MOD+S shortcut to take a screenshot.
     I don't know how to launch weston-screenshooter by weston.Can you tell me?
     i also don't know what's MOD+S means.Is that some kind of keypad combination? what is MOD+s?
    thanks
    yandong
  • Just attach a keyboard to your board and press MOD+S. You will find the wayland-screenshot.png in board's root directory.
