Other Parts Discussed in Thread: CCSTUDIO
hi,
i'm working on evmDM648 and got such errors while building a project:
undefined first referenced
symbol in file
SWI_D_rdytab C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_EXC_init C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_GBL_procId C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
__HOOK_knlId C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_KNL_exit C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
TSK_VCREATEFXN C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_UTL_doError C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
PIP_F_start C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
GBL_boot C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
TSK_VDELETEFXN C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
KNL_glue C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_UTL_doAbort C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_HSRTDX_xmt C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
IDL_F_loop C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_CLK_DFLTMICROSECS C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_GBL_cacheInit64P C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_EXC_dispatch C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_CLK_htimePerLtime C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
GBL_stackbeg C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_CLK_D_tddr C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_UTL_doPutc C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
PRD_F_tick C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
__HOOK_NUMHOOKS C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_CLK_D_microseconds C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
RTA_F_or C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
TRC_R_mask C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
GBL_stackend C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_c_int00 C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_TSK_config C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_OBJ_table C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
HWI_A_VECS C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_FXN_F_nop C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_CLK_D_prd C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
IDL_D_calibrate C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_TSK C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_KNL_run C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
LNK_dspFrameRequestMask C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
CLK_F_isr C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
PIP_D_tabbeg C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
TRC_cinit C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_UTL_halt C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
RTA_F_dispatch C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_TSK_startup C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_TSK_setup C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_KNL_queues C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
CLK_A_TABBEG C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
LNK_F_dataPump C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
TSK_VEXITFXN C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
HWI_F_dispatch C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_RTDX_Poll C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_TSK_init C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
IDL_D_busyObj C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_TSK_exit C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
SWI_F_enable C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
FXN_F_run C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_HSRTDX_rec C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_GBL_getVersion C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_CLK_inputClock C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
GBL_initdone C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
_HWI_dispatchTab C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
LNK_dspFrameReadyMask C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
IDL_F_busy C:\\CCStudio_v3.3\\MyProjects\\test\\Debug\\oscfg.obj
>> error: symbol referencing errors - './Debug/test.out' not built
>> Compilation failure
please help. thanks!
