Part Number: PROCESSOR-SDK-OMAPL138
Other Parts Discussed in Thread: OMAPL138
I have been trying to update the MessageQ example code with an additional requirement to obtain PCM samples from the ADC. The idea being that the DSP will handle all configuration of the ADC, and simple fire off results of analysis using RemoteProc calls...
The idea was to work backwards from the MCASP_Audio_lcdkOMAPL138_c674xExampleProject... Add the missing parts, with a few new MessageQ control messages...
Im currently stuck just trying to build the application... Im seeing errors when compiling "ti/drv/mcasp/soc/mcasp_soc.h" with undefined identifiers and "Unsupported SOC !!"
I have defined the following in app.cfg
var socType = "omapl138"; var osType = "tirtos"; var socName = "lcdkOMAPL138"; Csl.libProfile = "release"; Osal.osType = osType; Osal.socType = socType; Csl.deviceType = socType; McASP.Settings.socType = socType; Uart.Settings.socType = socType; I2C.Settings.socType = socType; Board.Settings.boardName = socName;
This results in the following build log
**** Clean-only build of configuration Debug for project dsp ****
/home/juan/ti_04.02.00.09/ccsv7/utils/bin/gmake -k -j 8 clean -O
cleaning ../src/ipc ...
cleaning ../src/utils ...
cleaning ../src/sysbios ...
rm -rf "dsp.hex" "configPkg/linker.cmd" "configPkg/compiler.opt" "dsp.out"
rm -rf "configPkg/"
rm -rf "main.obj" "server.obj"
rm -rf "main.d" "server.d"
Finished clean
**** Build Finished ****
**** Build of configuration Debug for project dsp ****
/home/juan/ti_04.02.00.09/ccsv7/utils/bin/gmake -k -j 8 all -O
Building file: "../app.cfg"
Invoking: XDCtools
"/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core/xs" --xdcpath="/home/juan/ti_04.02.00.09/bios_6_52_00_12/packages;/home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages;/home/juan/ti_04.02.00.09/pdk_omapl138_1_0_3/packages;/home/juan/ti_04.02.00.09/edma3_lld_2_12_05_30B/packages;/home/juan/ti_04.02.00.09/ndk_2_26_00_08/packages;/home/juan/ti_04.02.00.09/uia_2_21_02_07/packages;/home/juan/ti_04.02.00.09/ccsv7/ccs_base;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C674 -p ti.platforms.evmOMAPL138 -r release -b "/home/juan/code/messageq/dsp/config.bld" -c "/home/juan/ti_04.02.00.09/ti-cgt-c6000_8.2.2" --compileOptions "-g --optimize_with_debug" -v "../app.cfg"
# making package.mak (because of package.bld) ...
/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core/xs -Dxdc.path="/home/juan/ti_04.02.00.09/bios_6_52_00_12/packages;/home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages;/home/juan/ti_04.02.00.09/pdk_omapl138_1_0_3/packages;/home/juan/ti_04.02.00.09/edma3_lld_2_12_05_30B/packages;/home/juan/ti_04.02.00.09/ndk_2_26_00_08/packages;/home/juan/ti_04.02.00.09/uia_2_21_02_07/packages;/home/juan/ti_04.02.00.09/ccsv7/ccs_base;/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core/packages;.." -Dxdc.root=/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core -Dxdc.hostOS=Linux -Dconfig.importPath=".;/home/juan/ti_04.02.00.09/bios_6_52_00_12/packages;/home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages;/home/juan/ti_04.02.00.09/pdk_omapl138_1_0_3/packages;/home/juan/ti_04.02.00.09/edma3_lld_2_12_05_30B/packages;/home/juan/ti_04.02.00.09/ndk_2_26_00_08/packages;/home/juan/ti_04.02.00.09/uia_2_21_02_07/packages;/home/juan/ti_04.02.00.09/ccsv7/ccs_base;/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core/packages;..;/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core;/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core/etc" -Dxdc.bld.targets="" -DTOOLS= -f /home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core/packages/xdc/bld/bld.js ./config.bld package.bld package.mak
# generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core/xs -Dxdc.path="/home/juan/ti_04.02.00.09/bios_6_52_00_12/packages;/home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages;/home/juan/ti_04.02.00.09/pdk_omapl138_1_0_3/packages;/home/juan/ti_04.02.00.09/edma3_lld_2_12_05_30B/packages;/home/juan/ti_04.02.00.09/ndk_2_26_00_08/packages;/home/juan/ti_04.02.00.09/uia_2_21_02_07/packages;/home/juan/ti_04.02.00.09/ccsv7/ccs_base;/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core/packages;.." -Dxdc.root=/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core -Dxdc.hostOS=Linux -Dconfig.importPath=".;/home/juan/ti_04.02.00.09/bios_6_52_00_12/packages;/home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages;/home/juan/ti_04.02.00.09/pdk_omapl138_1_0_3/packages;/home/juan/ti_04.02.00.09/edma3_lld_2_12_05_30B/packages;/home/juan/ti_04.02.00.09/ndk_2_26_00_08/packages;/home/juan/ti_04.02.00.09/uia_2_21_02_07/packages;/home/juan/ti_04.02.00.09/ccsv7/ccs_base;/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core/packages;..;/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core;/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core/etc" -Dxdc.bld.targets="" -DTOOLS= -f xdc/services/intern/cmd/build.xs -m package/package.xdc.dep -i package/package.xdc.inc package.xdc
# configuring app.xe674 from package/cfg/app_pe674.cfg ...
/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core/xs -Dxdc.path="/home/juan/ti_04.02.00.09/bios_6_52_00_12/packages;/home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages;/home/juan/ti_04.02.00.09/pdk_omapl138_1_0_3/packages;/home/juan/ti_04.02.00.09/edma3_lld_2_12_05_30B/packages;/home/juan/ti_04.02.00.09/ndk_2_26_00_08/packages;/home/juan/ti_04.02.00.09/uia_2_21_02_07/packages;/home/juan/ti_04.02.00.09/ccsv7/ccs_base;/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core/packages;.." -Dxdc.root=/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core -Dxdc.hostOS=Linux -Dconfig.importPath=".;/home/juan/ti_04.02.00.09/bios_6_52_00_12/packages;/home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages;/home/juan/ti_04.02.00.09/pdk_omapl138_1_0_3/packages;/home/juan/ti_04.02.00.09/edma3_lld_2_12_05_30B/packages;/home/juan/ti_04.02.00.09/ndk_2_26_00_08/packages;/home/juan/ti_04.02.00.09/uia_2_21_02_07/packages;/home/juan/ti_04.02.00.09/ccsv7/ccs_base;/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core/packages;..;/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core;/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core/etc" -Dxdc.bld.targets="" -DTOOLS= xdc.cfg app.xe674 package/cfg/app_pe674.cfg package/cfg/app_pe674
generating custom ti.sysbios library makefile ...
generating custom ti.sdo.utils library makefile ...
generating custom ti.sdo.ipc library makefile ...
Linking with library ti.drv.i2c:./lib/omapl138/c674/release/ti.drv.i2c.ae674
Linking with library ti.drv.uart:./lib/omapl138/c674/release/ti.drv.uart.ae674
Linking with library ti.drv.mcasp:./lib/omapl138/c674/release/ti.drv.mcasp.ae674
Linking with library ti.board:./lib/lcdkOMAPL138/c674/release/ti.board.ae674
Inside EDMA3 Drv getLibs
will link with ti.sdo.edma3.drv:lib/674/release/edma3_lld_drv.ae674
Inside EDMA3 RM getLibs
will link with ti.sdo.edma3.rm:lib/omapl138-evm/674/release/edma3_lld_rm.ae674
Linking with library ti.csl:./lib/omapl138/c674/release/ti.csl.ae674
Linking with library ti.osal:./lib/tirtos/omapl138/c674/release/ti.osal.ae674
Starting build of library sources ...
making /home/juan/code/messageq/dsp/src/ipc.ae674 ...
gmake[1]: Entering directory `/home/juan/code/messageq/dsp/src/ipc'
cle674 /home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages/ti/ipc/transports/TransportRpmsg.c ...
remark #24038-D: --optimize_with_debug is deprecated and will be removed in a
subsequent release. The behavior is enabled by default.
remark #24038-D: --gcc is deprecated and will be removed in a subsequent
release. GCC compatibility is implemented through the --relaxed_ansi option
and is the default behavior of the compiler.
asme674 /home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages/ti/sdo/ipc/gates/GateAAMonitor_asm.s64P ...
are674 Ipc.obj gates_GateAAMonitor_asm.obj ...
gmake[1]: Leaving directory `/home/juan/code/messageq/dsp/src/ipc'
making /home/juan/code/messageq/dsp/src/utils.ae674 ...
gmake[1]: Entering directory `/home/juan/code/messageq/dsp/src/utils'
cle674 /home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages/ti/sdo/utils/UTILS.c ...
are674 UTILS.obj ...
gmake[1]: Leaving directory `/home/juan/code/messageq/dsp/src/utils'
making /home/juan/code/messageq/dsp/src/sysbios/sysbios.ae674 ...
gmake[1]: Entering directory `/home/juan/code/messageq/dsp/src/sysbios'
cle674 /home/juan/ti_04.02.00.09/bios_6_52_00_12/packages/ti/sysbios/BIOS.c ...
asme674 /home/juan/ti_04.02.00.09/bios_6_52_00_12/packages/ti/sysbios/family/c64p/Exception_asm.s64P ...
asme674 /home/juan/ti_04.02.00.09/bios_6_52_00_12/packages/ti/sysbios/family/c64p/Hwi_asm.s62 ...
asme674 /home/juan/ti_04.02.00.09/bios_6_52_00_12/packages/ti/sysbios/family/c64p/Hwi_asm_switch.s62 ...
asme674 /home/juan/ti_04.02.00.09/bios_6_52_00_12/packages/ti/sysbios/family/c64p/Hwi_disp_always.s64P ...
asme674 /home/juan/ti_04.02.00.09/bios_6_52_00_12/packages/ti/sysbios/timers/timer64/Timer_asm.s64P ...
asme674 /home/juan/ti_04.02.00.09/bios_6_52_00_12/packages/ti/sysbios/rts/ti/tls_get_tp.asm ...
asme674 /home/juan/ti_04.02.00.09/bios_6_52_00_12/packages/ti/sysbios/family/c62/TaskSupport_asm.s62 ...
are674 BIOS.obj c64p_Exception_asm.obj c64p_Hwi_asm.obj c64p_Hwi_asm_switch.obj c64p_Hwi_disp_always.obj timer64_Timer_asm.obj ti_tls_get_tp.obj c62_TaskSupport_asm.obj ...
gmake[1]: Leaving directory `/home/juan/code/messageq/dsp/src/sysbios'
Build of libraries done.
sed 's"^\"\(package/cfg/app_pe674cfg.cmd\)\""\"/home/juan/code/messageq/dsp/Debug/configPkg/\1\""' package/cfg/app_pe674.xdl > linker.cmd
/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core/bin/setdate -r:max package/cfg/app_pe674.h compiler.opt compiler.opt.defs
rm -f package/cfg/app_pe674.oe674
# cle674 package/cfg/app_pe674.c ...
/home/juan/ti_04.02.00.09/ti-cgt-c6000_8.2.2/bin/cl6x -c -g --optimize_with_debug -qq -pdsw225 -mo -mv6740 --abi=eabi -eo.oe674 -ea.se674 -mi10 -mo -Dxdc_cfg__xheader__='"configPkg/package/cfg/app_pe674.h"' -Dxdc_target_name__=C674 -Dxdc_target_types__=ti/targets/elf/std.h -Dxdc_bld__profile_release -Dxdc_bld__vers_1_0_8_2_2 -O2 -I. -I/home/juan/ti_04.02.00.09/bios_6_52_00_12/packages -I/home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages -I/home/juan/ti_04.02.00.09/pdk_omapl138_1_0_3/packages -I/home/juan/ti_04.02.00.09/edma3_lld_2_12_05_30B/packages -I/home/juan/ti_04.02.00.09/ndk_2_26_00_08/packages -I/home/juan/ti_04.02.00.09/uia_2_21_02_07/packages -I/home/juan/ti_04.02.00.09/ccsv7/ccs_base -I/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core/packages -I.. -I/home/juan/ti_04.02.00.09/ti-cgt-c6000_8.2.2/include -fs=./package/cfg -fr=./package/cfg -fc package/cfg/app_pe674.c
/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core/bin/mkdep -a package/cfg/app_pe674.oe674.dep -p package/cfg -s oe674 package/cfg/app_pe674.c -C -g --optimize_with_debug -qq -pdsw225 -mo -mv6740 --abi=eabi -eo.oe674 -ea.se674 -mi10 -mo -Dxdc_cfg__xheader__='"configPkg/package/cfg/app_pe674.h"' -Dxdc_target_name__=C674 -Dxdc_target_types__=ti/targets/elf/std.h -Dxdc_bld__profile_release -Dxdc_bld__vers_1_0_8_2_2 -O2 -I. -I/home/juan/ti_04.02.00.09/bios_6_52_00_12/packages -I/home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages -I/home/juan/ti_04.02.00.09/pdk_omapl138_1_0_3/packages -I/home/juan/ti_04.02.00.09/edma3_lld_2_12_05_30B/packages -I/home/juan/ti_04.02.00.09/ndk_2_26_00_08/packages -I/home/juan/ti_04.02.00.09/uia_2_21_02_07/packages -I/home/juan/ti_04.02.00.09/ccsv7/ccs_base -I/home/juan/ti_04.02.00.09/xdctools_3_50_04_43_core/packages -I.. -I/home/juan/ti_04.02.00.09/ti-cgt-c6000_8.2.2/include -fs=./package/cfg -fr=./package/cfg
"/home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages/ti/ipc/remoteproc/Resource.c", line 119: remark #2142-D: comparison between signed and unsigned operands
"/home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages/ti/sdo/ipc/GateMP.c", line 662: remark #2142-D: comparison between signed and unsigned operands
"/home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages/ti/sdo/ipc/GateMP.c", line 693: remark #2142-D: comparison between signed and unsigned operands
"/home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages/ti/sdo/ipc/GateMP.c", line 728: remark #2142-D: comparison between signed and unsigned operands
"/home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages/ti/sdo/ipc/GateMP.c", line 1565: remark #2142-D: comparison between signed and unsigned operands
"/home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages/ti/sdo/ipc/Ipc.c", line 323: remark #2142-D: comparison between signed and unsigned operands
"/home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages/ti/sdo/ipc/Ipc.c", line 502: remark #2142-D: comparison between signed and unsigned operands
"/home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages/ti/sdo/ipc/notifyDrivers/NotifyDriverShm.c", line 239: remark #2142-D: comparison between signed and unsigned operands
"/home/juan/ti_04.02.00.09/ipc_3_47_00_00/packages/ti/sdo/ipc/notifyDrivers/NotifyDriverShm.c", line 327: remark #2142-D: comparison between signed and unsigned operands
Finished building: "../app.cfg"
making ../src/sysbios/sysbios.ae674 ...
making ../src/ipc.ae674 ...
making ../src/utils.ae674 ...
gmake[1]: Nothing to be done for 'all'.
Building file: "../main.cpp"
Invoking: C6000 Compiler
"/home/juan/ti_04.02.00.09/ti-cgt-c6000_8.2.2/bin/cl6x" -mv6740 --include_path="/home/juan/ti/pdk_omapl138_1_0_3/packages/ti/drv/mcasp" --include_path="/home/juan/code/messageq/dsp" --include_path="/home/juan/code/messageq/common" --include_path="/home/juan/ti_04.02.00.09/ti-cgt-c6000_8.2.2/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --preproc_with_compile --preproc_dependency="main.d_raw" --cmd_file="configPkg/compiler.opt" "../main.cpp"
>> Compilation failure
subdir_rules.mk:22: recipe for target 'main.obj' failed
"/home/juan/ti_04.02.00.09/pdk_omapl138_1_0_3/packages/ti/drv/mcasp/soc/mcasp_soc.h", line 125: error #20: identifier "CSL_McaspRegs" is undefined
"/home/juan/ti_04.02.00.09/pdk_omapl138_1_0_3/packages/ti/drv/mcasp/soc/mcasp_soc.h", line 128: error #20: identifier "CSL_AfifoRegs" is undefined
"/home/juan/ti_04.02.00.09/pdk_omapl138_1_0_3/packages/ti/drv/mcasp/soc/mcasp_soc.h", line 131: error #20: identifier "CSL_AdataRegs" is undefined
"/home/juan/ti_04.02.00.09/pdk_omapl138_1_0_3/packages/ti/drv/mcasp/soc/mcasp_soc.h", line 188: fatal error #35: #error directive: "Unsupported SOC !! "
3 errors and 1 catastrophic error detected in the compilation of "../main.cpp".
Compilation terminated.
gmake: *** [main.obj] Error 1
Building file: "../server.cpp"
"/home/juan/ti_04.02.00.09/ti-cgt-c6000_8.2.2/bin/cl6x" -mv6740 --include_path="/home/juan/ti/pdk_omapl138_1_0_3/packages/ti/drv/mcasp" --include_path="/home/juan/code/messageq/dsp" --include_path="/home/juan/code/messageq/common" --include_path="/home/juan/ti_04.02.00.09/ti-cgt-c6000_8.2.2/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --preproc_with_compile --preproc_dependency="server.d_raw" --cmd_file="configPkg/compiler.opt" "../server.cpp"
Finished building: "../server.cpp"
gmake: Target 'all' not remade because of errors.
If I manually define SOC_OMAP138 through project configuration, I see errors regarding missing I2C header files...
rm -rf "configPkg/"
Finished clean
Invoking: XDCtools
"/home/juan/ti_04.02.00.09/ti-cgt-c6000_8.2.2/bin/cl6x" -mv6740 --include_path="/home/juan/ti/pdk_omapl138_1_0_3/packages/ti/drv/mcasp" --include_path="/home/juan/code/messageq/dsp" --include_path="/home/juan/code/messageq/common" --include_path="/home/juan/ti_04.02.00.09/ti-cgt-c6000_8.2.2/include" --define=SOC_OMAPL138 -g --diag_warning=225 --diag_wrap=off --display_error_number --preproc_with_compile --preproc_dependency="server.d_raw" --cmd_file="configPkg/compiler.opt" "../server.cpp"
>> Compilation failure
subdir_rules.mk:29: recipe for target 'server.obj' failed
"/home/juan/ti_04.02.00.09/pdk_omapl138_1_0_3/packages/ti/csl/csl_i2c.h", line 54: fatal error #1965: cannot open source file "ti/csl/src/ip/i2c/V0/csl_i2c.h"
1 catastrophic error detected in the compilation of "../server.cpp".
gmake: *** [server.obj] Error 1
"/home/juan/ti_04.02.00.09/ti-cgt-c6000_8.2.2/bin/cl6x" -mv6740 --include_path="/home/juan/ti/pdk_omapl138_1_0_3/packages/ti/drv/mcasp" --include_path="/home/juan/code/messageq/dsp" --include_path="/home/juan/code/messageq/common" --include_path="/home/juan/ti_04.02.00.09/ti-cgt-c6000_8.2.2/include" --define=SOC_OMAPL138 -g --diag_warning=225 --diag_wrap=off --display_error_number --preproc_with_compile --preproc_dependency="main.d_raw" --cmd_file="configPkg/compiler.opt" "../main.cpp"
Finished building: "../main.cpp"
My filesystem includes ti/csl/src/ip/i2c/V0/cslr_i2c.h...
Can someone either...
- Help me solve this issue, so I can offload ALL audio handling to the DSP, and leave Linux for user application only... or,
- Convince me to use Linux to provide audio packets to the DSP...
Juan
