Other Parts Discussed in Thread: OMAP-L137
I'm using a custom board with a OMAP-L137 and I'm trying to use the USB ports.
I've tried to use the "usbhostmsc" example in RTFS (\rtfs_1_10_02_32\packages\ti\rtfs\examples\usbhostmsc\bios5\evm6747\ccs3\usbhostmsc.pjt).
The compilation works well, then I plug a USB drive in one of the ports on the board and I run the program.
If the USB drive is in the USB 2.0 port I get the following messages in the console:
USB Application Task 0 Starting
Initializing usb host stack
ohci_local0: OHCI version 1.0
ohci_local0: USB revision 1.0
ohci_local0: new device port=0 depth=0 speed=full
uhub0 Jungo Generic Root Hub, class 9/0, rev 0.11/af.00, addr 1
uhub0: 2 ports with 2 removable, self powered
musbhshc0: USB revision 2.0
musbhshc0: new device port=0 depth=0 speed=high
uhub1 Jungo Generic Root Hub, class 9/0, rev 0.20/af.00, addr 1
uhub1: 1 port with 1 removable, self powered
polling for storage media
uhub0: new device port=1 depth=1 speed=full
USB Device Not available
uhub0: device problem, disabling port 1
If the USB drive is in the USB 1.0 port I get this:
So something is not working properly. Could somebody please help?
(I get the same results if I load the file provided "usbhostmsc.x674" directly instead of compiling)
I'm using the following products:
RTFS 1.10.02.32
EDMA 3 LDD 01.11.00.02
BIOS PSP 01.30.00.05
BIOS USB 01.10.03
DSP/BIOS 5.41.07.24
Code Composer Studio 3.3.81.11
Code Generation Tools 6.1.9
Any help will be appreciated.
Thanks.
