RTOS/TDA3XEVM: TFDTP network stream termination
Part Number: TDA3XEVM
Tool/software: TI-RTOS
Hi all,
we try to implement a video streaming application on our TDA3 board with VSDK 2.12.
The application is 3D surroundview with nullLink and HDMI as video sink in parallel.
We use the TFDTP protocol and have adapted the nullLink and network_ctrl tool.
The TCP handshake in the TFDTP is disabled/commented out and we are just sending the UDP packets
when the video starts.
Curious is now, that everything works fine on my PC (Win10 i5-660, 16GB Ram) but not on any
other PC (Win7 or Win10 with respective HW). When the TDA3 Board with Surround View application is connected
to any other PC and starts, the UDP stream stopps exactly with the last UDP packet
of the second picture.
I found out, that the delay between each UDP packet is about 1..~3ms in the fault case. So one YUV Image needs
~1 Second to be transmitted (video in is 30fps). This causes to hang the whole video pipeline because the framebuffer
is blocked too long by the network stack (I think).
I can't see any network message from PC to our TDA3 board in Wireshark, that could cause a termination in our
TDA3 application. (Just UDP packets from TDA3). Our Application just stops without any visible influence of the PC.
But there must be an influence.
Can someone please give a hint how to debug this issue?
Thanks in Advance!
Best wishes,
Sebastian
  • Hello Sebastian,
    The current TFDTP network tools enable retransmit mechanism by default. This uses TCP/IP handshake for correct frame transmission.
    Have you disabled this in tool and null link code?  When the freeze happens, can you connect the core running TFDTP and see where it is stuck?
    Also as it works on one PC, could you check if any of the network setting (Autoneg, flow control etc) are same? Also please check if PC's get configured at 1Gig speed.
    Please share logs of failing as well as working case.
  • Hello Prasad,
    yes the retransmit is also disabled in null link. There is no handshake any more, because the video stream should just send. The datarate is very high (300-400 MBit) so a retransmit would increase it further. Videostreams are often UDP streams without any retransmit functionality.
    I have disabled the Rx channel as mentioned in the other thread and the behavior is the same! So it seems to be not on Ethernet protocol level. I guess it has something to do with the network card settings!? I've compared these settings with my working system and another one, where the stream stucks. The available settings differ but the settings that are same are set identical (e.g. Flow Control enabled for Rx &Tx; Speed = Auto Nego etc).
    At the moment I have no logs because on the console there is no output when it hangs. Also Wireshark shows nothing but the UDP packets that just stop.
    I can see, that the selected channel 0 which should be transmitted via null link isn't present any more when, SYSTEM_CMD_NEW_DATA event triggers in the null link -> bufList.buffers[bufId]->chNum == nullLinkActiveChId is not true in nullLink_tsk.c, when network stream is enabled.
    But the oder chn are available (1-3), Just chn 0 disapperas afte enabling network. I guess it is blocked by the network layer?
    I will debug with JTAG to get further information. Is it possible to enable a verbose or debug mode of the GMACSW or NSP?
    Regards and thank you for your help!
    Sebastian
  • Hello Sebastian,
    Thansk for detailed reply.
    1. As you have disabled TCP/IP from link, there should not be any freeze as it is UDP only and connection less and should stream no matter what. Can you confirm when system freezes, you are not able to take any logs (through network)
    2. When freeze happens, does other links in the system work? Can you please check performance statistics of each logs through CCS?
    Also can you check below register contents for GMAC
    1. Statistics - 0x48484900 to 498C
    2. RGMII control register - 0x4848_5288 - this shows speed, duplex setting for each port.
    3. SL control register- 0x4848_4d84 (Port0), 4dC8(port1)
    4. SL status register - 0x48484_4d88(port0) and 4dc8(port1)
    3. You can enable "instrumentation" mode through NDK_cfg.mk for NSP verbose mode where it stores instrumentation logs.
  • [IPU1-0]    214.499725 s:  CPU [IPU1-0 ] Statistics,
    [IPU1-0]    214.499847 s:  *************************
    [IPU1-0]    214.499969 s:
    [IPU1-0]    214.500091 s:  LOAD: CPU: 45.4% HWI: 8.5%, SWI:1.1%, Low Power: 155.2%
    [IPU1-0]    214.500427 s:
    [IPU1-0]    214.500518 s:  LOAD: TSK: SYSTEM              : 0.1%
    [IPU1-0]    214.500701 s:  LOAD: TSK: ISSCAPTURE          : 0.5%
    [IPU1-0]    214.500915 s:  LOAD: TSK: ISSM2MISP           : 7.2%
    [IPU1-0]    214.501128 s:  LOAD: TSK: DUP0                : 0.3%
    [IPU1-0]    214.501494 s:  LOAD: TSK: DUP1                : 0.4%
    [IPU1-0]    214.501738 s:  LOAD: TSK: MERGE0              : 0.3%
    [IPU1-0]    214.501952 s:  LOAD: TSK: SYNC0               : 0.7%
    [IPU1-0]    214.502165 s:  LOAD: TSK: IPC_OUT_0           : 0.5%
    [IPU1-0]    214.502348 s:  LOAD: TSK: IPC_OUT_1           : 1.6%
    [IPU1-0]    214.502562 s:  LOAD: TSK: IPC_IN_0            : 0.3%
    [IPU1-0]    214.502775 s:  LOAD: TSK: DISPLAY0            : 0.9%
    [IPU1-0]    214.502989 s:  LOAD: TSK: ALGORITHM0          : 5.4%
    [IPU1-0]    214.503172 s:  LOAD: TSK: ALGORITHM1          : 8.0%
    [IPU1-0]    214.503416 s:  LOAD: TSK: GrpxSrc0            : 4.1%
    [IPU1-0]    214.503629 s:  LOAD: TSK: STAT_COLL           : 2.3%
    [IPU1-0]    214.508875 s:  LOAD: TSK: 3D_SRV_MEDIA_TSK    : 1.6%
    [IPU1-0]    214.509241 s:  LOAD: TSK: MISC                : 1.6%
    [IPU1-0]    214.509516 s:
    [IPU1-0]    214.510858 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1021
    [IPU1-0]    214.511102 s:
    [IPU1-0]    214.511193 s:  SYSTEM: Sempahores Objects,  157 of 1000 free
    [IPU1-0]    214.511407 s:  SYSTEM: Task Objects      ,   21 of  100 free
    [IPU1-0]    214.511834 s:  SYSTEM: Clock Objects     ,   93 of  100 free
    [IPU1-0]    214.512047 s:  SYSTEM: Hwi Objects       ,   87 of  100 free
    [IPU1-0]    214.512322 s:
    [IPU1-0]    214.512901 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 151256 B (147 KB)
    [IPU1-0]    214.513328 s:  SYSTEM: Heap = SR_OCMC              @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
    [IPU1-0]    214.513999 s:  SYSTEM: Heap = SR_DDR_CACHED        @ 0x85483000, Total size = 367001600 B (350 MB), Free size = 230517248 B (219 MB)
    [IPU1-0]    214.515341 s:  SYSTEM: Heap = SR_DDR_NON_CACHED    @ 0xbfe00000, Total size = 1046784 B (0 MB), Free size = 1039104 B (0 MB)
    [IPU1-0]    214.515799 s:
    [IPU1-0]    214.515890 s:
    [IPU1-0]    214.517141 s:  CPU [IPU1-1 ] Statistics,
    [IPU1-0]    214.517354 s:  *************************
    [IPU1-0]    214.517507 s:
    [IPU1-0]    214.519002 s:  LOAD: CPU: 7.8% HWI: 1.8%, SWI:0.7%, Low Power: 155.6%
    [IPU1-0]    214.519398 s:
    [IPU1-0]    214.519795 s:  LOAD: TSK: NULL0               : 0.8%
    [IPU1-0]    214.520069 s:  LOAD: TSK: IPC_IN_0            : 1.2%
    [IPU1-0]    214.520313 s:  LOAD: TSK: MISC                : 3.3%
    [IPU1-0]    214.520496 s:
    [IPU1-0]    214.521716 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [IPU1-0]    214.521991 s:
    [IPU1-0]    214.522082 s:  SYSTEM: Sempahores Objects,  429 of 1000 free
    [IPU1-0]    214.522265 s:  SYSTEM: Task Objects      ,   41 of  100 free
    [IPU1-0]    214.522479 s:  SYSTEM: Clock Objects     ,   99 of  100 free
    [IPU1-0]    214.522753 s:  SYSTEM: Hwi Objects       ,   99 of  100 free
    [IPU1-0]    214.522997 s:
    [IPU1-0]    214.523089 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 239616 B (234 KB)
    [IPU1-0]    214.523424 s:
    [IPU1-0]    214.523546 s:
    [IPU1-0]    214.526535 s:  CPU [DSP1   ] Statistics,
    [IPU1-0]    214.528487 s:  *************************
    [IPU1-0]    214.528762 s:
    [IPU1-0]    214.528884 s:  LOAD: CPU: 42.8% HWI: 0.3%, SWI:0.1%, Low Power: 166.1%
    [IPU1-0]    214.529341 s:
    [IPU1-0]    214.529494 s:  LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 42.1%
    [IPU1-0]    214.530653 s:  LOAD: TSK: MISC                : 0.3%
    [IPU1-0]    214.530958 s:
    [IPU1-0]    214.531049 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1020
    [IPU1-0]    214.531415 s:
    [IPU1-0]    214.531537 s:  SYSTEM: Sempahores Objects,  444 of 1000 free
    [IPU1-0]    214.531781 s:  SYSTEM: Task Objects      ,   92 of  100 free
    [IPU1-0]    214.532025 s:  SYSTEM: Clock Objects     ,   98 of  100 free
    [IPU1-0]    214.532269 s:  SYSTEM: Hwi Objects       ,  100 of  100 free
    [IPU1-0]    214.532513 s:
    [IPU1-0]    214.532605 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 96192 B (93 KB)
    [IPU1-0]    214.533032 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 519424 B (507 KB)
    [IPU1-0]    214.533581 s:
    [IPU1-0]    214.533733 s:
    [IPU1-0]    214.533825 s:  CPU [DSP2   ] Statistics,
    [IPU1-0]    214.534008 s:  *************************
    [IPU1-0]    214.534160 s:
    [IPU1-0]    214.534282 s:  LOAD: CPU: 0.3% HWI: 0.1%, SWI:0.0%, Low Power: 208.2%
    [IPU1-0]    214.534648 s:
    [IPU1-0]    214.534801 s:  LOAD: TSK: MISC                : 0.2%
    [IPU1-0]    214.534984 s:
    [IPU1-0]    214.535075 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1020
    [IPU1-0]    214.535350 s:
    [IPU1-0]    214.536021 s:  SYSTEM: Sempahores Objects,  446 of 1000 free
    [IPU1-0]    214.536326 s:  SYSTEM: Task Objects      ,   92 of  100 free
    [IPU1-0]    214.536570 s:  SYSTEM: Clock Objects     ,   99 of  100 free
    [IPU1-0]    214.540230 s:  SYSTEM: Hwi Objects       ,  100 of  100 free
    [IPU1-0]    214.540566 s:
    [IPU1-0]    214.541206 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
    [IPU1-0]    214.541786 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 519424 B (507 KB)
    [IPU1-0]    214.542213 s:
    [IPU1-0]    214.542335 s:
    [IPU1-0]    214.542457 s:  CPU [EVE1   ] Statistics,
    [IPU1-0]    214.542609 s:  *************************
    [IPU1-0]    214.542731 s:
    [IPU1-0]    214.542853 s:  LOAD: CPU: 0.9% HWI: 0.2%, SWI:0.2%, Low Power: 197.4%
    [IPU1-0]    214.543250 s:
    [IPU1-0]    214.543341 s:  LOAD: TSK: SYSTEM              : 0.3%
    [IPU1-0]    214.543616 s:  LOAD: TSK: MISC                : 0.2%
    [IPU1-0]    214.543921 s:
    [IPU1-0]    214.544012 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1021
    [IPU1-0]    214.544256 s:
    [IPU1-0]    214.544378 s:  SYSTEM: Sempahores Objects,  487 of 1000 free
    [IPU1-0]    214.544592 s:  SYSTEM: Task Objects      ,   97 of  100 free
    [IPU1-0]    214.544836 s:  SYSTEM: Clock Objects     ,   99 of  100 free
    [IPU1-0]    214.545080 s:  SYSTEM: Hwi Objects       ,   99 of  100 free
    [IPU1-0]    214.545324 s:
    [IPU1-0]    214.545415 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 24576 B (24 KB), Free size = 24576 B (24 KB)
    [IPU1-0]    214.545934 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 257448 B (251 KB)
    [IPU1-0]    214.546361 s:
    [IPU1-0]    214.547337 s:
    [IPU1-0]    214.547459 s:  UTILS_PRCM_STATS:  Current Temperature,
    [IPU1-0]    214.547642 s:
    [IPU1-0]    214.547733 s:   Voltage Rail         ||   Curr Temp Min - Max
    [IPU1-0]    214.548282 s:  ---------------------------------------------------------
    [IPU1-0]    214.548557 s:     PMHAL_PRCM_VD_CORE ||     [61.200 , 61.600]
    [IPU1-0]    214.548831 s:
    [IPU1-0]    214.549594 s:
    [IPU1-0]    214.552400 s:  Statistics Collector,
    [IPU1-0]    214.552644 s:
    [IPU1-0]    214.552735 s:        STATISTIC          Avg Data        Peak Data
    [IPU1-0]    214.552949 s:        COLLECTOR          MB/s            MB/s
    [IPU1-0]    214.553132 s:  --------------------------------------------------
    [IPU1-0]    214.553345 s:  SCI_EMIF_SYS         |    830.405667   1077.523159
    [IPU1-0]    214.553589 s:  SCI_IPU              |     15.726505     47.497688
    [IPU1-0]    214.554687 s:  SCI_DSP1_MDMA        |      4.752215     22.445918
    [IPU1-0]    214.555114 s:  SCI_DSP2_MDMA        |      0.018534      0.112802
    [IPU1-0]    214.555358 s:  SCI_DSS              |    152.845081    172.952380
    [IPU1-0]    214.555572 s:  SCI_MMU              |      0.000000      0.000000
    [IPU1-0]    214.555816 s:  SCI_EDMA_TC0_RD      |      0.000000      0.000000
    [IPU1-0]    214.556030 s:  SCI_EDMA_TC0_WR      |      0.000000      0.000000
    [IPU1-0]    214.556243 s:  SCI_VIP_P1           |      0.000000      0.000000
    [IPU1-0]    214.556518 s:  SCI_VIP_P2           |      0.000000      0.000000
    [IPU1-0]    214.556762 s:  SCI_ISS_RT           |    105.134146    143.499213
    [IPU1-0]    214.557006 s:  SCI_ISS_NRT2         |    213.272377    366.724954
    [IPU1-0]    214.557219 s:  SCI_EVE_P1           |      1.582133      4.213380
    [IPU1-0]    214.557463 s:  SCI_EVE_P2           |      0.000000      0.000000
    [IPU1-0]    214.557707 s:  SCI_GMAC_SW          |     19.824893     49.735705
    [IPU1-0]    214.557921 s:  SCI_ISS_NRT1         |    241.696315    646.023932
    [IPU1-0]    214.558165 s:  SCI_DSP2_CFG         |      0.000000      0.000000
    [IPU1-0]    214.558378 s:  SCI_DSP2_EDMA        |      0.000000      0.000000
    [IPU1-0]    214.558683 s:  SCI_OCMC_RAM         |     17.159861     42.528870
    [IPU1-0]    214.558927 s:  SCI_DSP1_CFG         |      0.000000      0.000000
    [IPU1-0]    214.559171 s:  SCI_DSP1_EDMA        |     96.763213    353.165981
    [IPU1-0]    214.559385 s:  SCI_GPMC             |      0.000000      0.000000
    [IPU1-0]    214.559629 s:  SCI_MCASP            |      0.000000      0.000000
    [IPU1-0]    214.559842 s:  SCI_EDMA_TC1_RD      |      8.777219     70.434483
    [IPU1-0]    214.560086 s:  SCI_EDMA_TC1_WR      |      8.777219     70.434483
    [IPU1-0]    214.771335 s:
    [IPU1-0]    214.771487 s:  ### CPU [IPU1-0], LinkID [ 72],
    [IPU1-0]    214.771640 s:
    [IPU1-0]    214.771731 s:  [ ISSCAPTURE ] Link Statistics,
    [IPU1-0]    214.771884 s:  ******************************
    [IPU1-0]    214.772006 s:
    [IPU1-0]    214.772097 s:  Elapsed time       = 137960 msec
    [IPU1-0]    214.772311 s:
    [IPU1-0]    214.772433 s:  Get Full Buf Cb    =  57.7 fps
    [IPU1-0]    214.772768 s:  Put Empty Buf Cb   =  22.76 fps
    [IPU1-0]    214.772921 s:  Driver/Notify Cb   =  57.6 fps
    [IPU1-0]    214.774324 s:
    [IPU1-0]    214.774476 s:  Input Statistics,
    [IPU1-0]    214.774568 s:
    [IPU1-0]    214.774659 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    214.774842 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    214.774995 s:  --------------------------------------------------
    [IPU1-0]    214.775300 s:   0 |  14.26      0. 0      0. 0          14.26
    [IPU1-0]    214.775757 s:   1 |  14.26      0. 0      0. 0          14.26
    [IPU1-0]    214.776062 s:   2 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]    214.776367 s:   3 |  14.26      0. 0      0. 0          14.26
    [IPU1-0]    214.776672 s:
    [IPU1-0]    214.776764 s:  Output Statistics,
    [IPU1-0]    214.776855 s:
    [IPU1-0]    214.776947 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    214.777130 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    214.777343 s:  ---------------------------------------------
    [IPU1-0]    214.777526 s:   0 |  0     14.27     0. 0      0. 0
    [IPU1-0]    214.777770 s:   1 |  0     14.27     0. 0      0. 0
    [IPU1-0]    214.778045 s:   2 |  0     14.27     0. 0      0. 0
    [IPU1-0]    214.778320 s:   3 |  0     14.27     0. 0      0. 0
    [IPU1-0]    214.778564 s:
    [IPU1-0]    214.778655 s:  [ ISSCAPTURE ] LATENCY,
    [IPU1-0]    214.778808 s:  ********************
    [IPU1-0]    214.778930 s:
    [IPU1-0]    214.779174 s:
    [IPU1-0]    214.779265 s:  ### CPU [IPU1-0], LinkID [ 73],
    [IPU1-0]    214.779479 s:
    [IPU1-0]    214.779601 s:  [ ISSM2MISP ] Link Statistics,
    [IPU1-0]    214.779723 s:  ******************************
    [IPU1-0]    214.779875 s:
    [IPU1-0]    214.779967 s:  Elapsed time       = 137968 msec
    [IPU1-0]    214.780119 s:
    [IPU1-0]    214.780180 s:  New data Recv      =  57.7 fps
    [IPU1-0]    214.780363 s:  Get Full Buf Cb    =  44.17 fps
    [IPU1-0]    214.780516 s:  Driver/Notify Cb   =  57.7 fps
    [IPU1-0]    214.780699 s:
    [IPU1-0]    214.780790 s:  Input Statistics,
    [IPU1-0]    214.780882 s:
    [IPU1-0]    214.780973 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    214.781156 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    214.781309 s:  --------------------------------------------------
    [IPU1-0]    214.781858 s:   0 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]    214.782163 s:   1 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]    214.782468 s:   2 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]    214.782742 s:   3 |  14.27      0. 0      0. 0          14.26
    [IPU1-0]    214.783047 s:
    [IPU1-0]    214.783139 s:  Output Statistics,
    [IPU1-0]    214.783230 s:
    [IPU1-0]    214.783322 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    214.783474 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    214.783688 s:  ---------------------------------------------
    [IPU1-0]    214.783871 s:   0 |  0     14.27     0. 0      0. 0
    [IPU1-0]    214.784359 s:   1 |  0     14.27     0. 0      0. 0
    [IPU1-0]    214.784633 s:   2 |  0     14.27     0. 0      0. 0
    [IPU1-0]    214.784877 s:   3 |  0     14.26     0. 0      0. 0
    [IPU1-0]    214.790947 s:
    [IPU1-0]    214.791099 s:  [ ISSM2MISP ] LATENCY,
    [IPU1-0]    214.791252 s:  ********************
    [IPU1-0]    214.791374 s:  Local Link Latency     : Avg =  12110 us, Min =  11712 us, Max =  13543 us,
    [IPU1-0]    214.791648 s:  Source to Link Latency : Avg =  30476 us, Min =  12078 us, Max =  49777 us,
    [IPU1-0]    214.792350 s:
    [IPU1-0]    214.792685 s:
    [IPU1-0]    214.792777 s:  ### CPU [IPU1-0], LinkID [ 45],
    [IPU1-0]    214.792960 s:
    [IPU1-0]    214.793051 s:  [ ALG_ISS_AEWB ] Link Statistics,
    [IPU1-0]    214.793204 s:  ******************************
    [IPU1-0]    214.793387 s:
    [IPU1-0]    214.793478 s:  Elapsed time       = 137929 msec
    [IPU1-0]    214.793661 s:
    [IPU1-0]    214.793753 s:  New data Recv      =  21.42 fps
    [IPU1-0]    214.793936 s:
    [IPU1-0]    214.794119 s:  Input Statistics,
    [IPU1-0]    214.794241 s:
    [IPU1-0]    214.794332 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    214.795003 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    214.795278 s:  --------------------------------------------------
    [IPU1-0]    214.795461 s:   0 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]    214.795796 s:
    [IPU1-0]    214.795888 s:  Output Statistics,
    [IPU1-0]    214.796010 s:
    [IPU1-0]    214.796590 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    214.796803 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    214.796956 s:  ---------------------------------------------
    [IPU1-0]    214.797139 s:   0 |  0     14.27     0. 0      0. 0
    [IPU1-0]    214.797413 s:
    [IPU1-0]    214.797505 s:  [ ALG_ISS_AEWB ] LATENCY,
    [IPU1-0]    214.798481 s:  ********************
    [IPU1-0]    214.798664 s:  Local Link Latency     : Avg =  14735 us, Min =    427 us, Max =  97694 us,
    [IPU1-0]    214.798938 s:  Source to Link Latency : Avg =  67982 us, Min =  50997 us, Max = 137529 us,
    [IPU1-0]    214.799213 s:
    [IPU1-0]    214.799365 s:  CPU [  IPU1-0], LinkID [ 24], Link Statistics not available !
    [IPU1-0]    214.799731 s:
    [IPU1-0]    214.799823 s:  ### CPU [IPU1-0], LinkID [ 52],
    [IPU1-0]    214.800006 s:
    [IPU1-0]    214.800097 s:  [ NULL_SRC ] Link Statistics,
    [IPU1-0]    214.800250 s:  ******************************
    [IPU1-0]    214.800494 s:
    [IPU1-0]    214.800646 s:  Elapsed time       = 200279 msec
    [IPU1-0]    214.800799 s:
    [IPU1-0]    214.800921 s:
    [IPU1-0]    214.801012 s:  Input Statistics,
    [IPU1-0]    214.801104 s:
    [IPU1-0]    214.801195 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    214.801378 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    214.801561 s:  --------------------------------------------------
    [IPU1-0]    214.801744 s:
    [IPU1-0]    214.801866 s:  Output Statistics,
    [IPU1-0]    214.801988 s:
    [IPU1-0]    214.802080 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    214.802232 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    214.802415 s:  ---------------------------------------------
    [IPU1-0]    214.802995 s:
    [IPU1-0]    214.803117 s:  [ NULL_SRC ] LATENCY,
    [IPU1-0]    214.803239 s:  ********************
    [IPU1-0]    214.803391 s:
    [IPU1-0]    214.803635 s:
    [IPU1-0]    214.806960 s:  ### CPU [IPU1-0], LinkID [  2],
    [IPU1-0]    214.807356 s:
    [IPU1-0]    214.807478 s:  [ IPC_OUT_2 ] Link Statistics,
    [IPU1-0]    214.808698 s:  ******************************
    [IPU1-0]    214.809095 s:
    [IPU1-0]    214.809186 s:  Elapsed time       = 200286 msec
    [IPU1-0]    214.809369 s:
    [IPU1-0]    214.809461 s:  Driver/Notify Cb   =  46.43 fps
    [IPU1-0]    214.809644 s:
    [IPU1-0]    214.809766 s:  Input Statistics,
    [IPU1-0]    214.810772 s:
    [IPU1-0]    214.811108 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    214.811321 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    214.811535 s:  --------------------------------------------------
    [IPU1-0]    214.811748 s:
    [IPU1-0]    214.811840 s:  Output Statistics,
    [IPU1-0]    214.811992 s:
    [IPU1-0]    214.812084 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    214.812267 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    214.812480 s:  ---------------------------------------------
    [IPU1-0]    214.812724 s:
    [IPU1-0]    214.812846 s:  [ IPC_OUT_2 ] LATENCY,
    [IPU1-0]    214.813487 s:  ********************
    [IPU1-0]    214.813700 s:
    [IPU1-0]    215.865003 s:
    [IPU1-0]    215.865186 s:  ### CPU [  DSP1], LinkID [ 11],
    [IPU1-0]    215.865369 s:
    [IPU1-0]    215.866040 s:  [ IPC_IN_1 ] Link Statistics,
    [IPU1-0]    215.866284 s:  ******************************
    [IPU1-0]    215.866436 s:
    [IPU1-0]    215.866558 s:  Elapsed time       = 201343 msec
    [IPU1-0]    215.866741 s:
    [IPU1-0]    215.867900 s:
    [IPU1-0]    215.868083 s:  Input Statistics,
    [IPU1-0]    215.868205 s:
    [IPU1-0]    215.868297 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    215.871713 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    215.872018 s:  --------------------------------------------------
    [IPU1-0]    215.872232 s:
    [IPU1-0]    215.872323 s:  Output Statistics,
    [IPU1-0]    215.872445 s:
    [IPU1-0]    215.872537 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    215.872720 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    215.872933 s:  ---------------------------------------------
    [IPU1-0]    215.873299 s:
    [IPU1-0]    215.873391 s:  [ IPC_IN_1 ] LATENCY,
    [IPU1-0]    215.873543 s:  ********************
    [IPU1-0]    215.873696 s:
    [IPU1-0]    216.925333 s:
    [IPU1-0]    216.925547 s:  ### CPU [IPU1-0], LinkID [ 33],
    [IPU1-0]    216.925730 s:
    [IPU1-0]    216.925821 s:  [ SYNC_0 ] Link Statistics,
    [IPU1-0]    216.925974 s:  ******************************
    [IPU1-0]    216.926645 s:
    [IPU1-0]    216.926798 s:  Elapsed time       = 137963 msec
    [IPU1-0]    216.927103 s:
    [IPU1-0]    216.927225 s:  New data Recv      =  37.31 fps
    [IPU1-0]    216.927408 s:  Get Full Buf Cb    =  14.27 fps
    [IPU1-0]    216.927621 s:  Put Empty Buf Cb   =  14.26 fps
    [IPU1-0]    216.927804 s:  Driver/Notify Cb   =  14.40 fps
    [IPU1-0]    216.928018 s:
    [IPU1-0]    216.928109 s:  Input Statistics,
    [IPU1-0]    216.928231 s:
    [IPU1-0]    216.929604 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    216.929848 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    216.930000 s:  --------------------------------------------------
    [IPU1-0]    216.930183 s:   0 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]    216.930671 s:   1 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]    216.930976 s:   2 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]    216.931342 s:   3 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]    216.931678 s:
    [IPU1-0]    216.931769 s:  Output Statistics,
    [IPU1-0]    216.931891 s:
    [IPU1-0]    216.932013 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    216.932166 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    216.932349 s:  ---------------------------------------------
    [IPU1-0]    216.932532 s:   0 |  0     14.27     0. 0      0. 0
    [IPU1-0]    216.932837 s:
    [IPU1-0]    216.932959 s:  [ SYNC_0 ] LATENCY,
    [IPU1-0]    216.933081 s:  ********************
    [IPU1-0]    216.933203 s:  Local Link Latency     : Avg =   5999 us, Min =     61 us, Max =  39285 us,
    [IPU1-0]    216.934880 s:  Source to Link Latency : Avg =  49609 us, Min =  48550 us, Max =  51013 us,
    [IPU1-0]    216.935216 s:
    [IPU1-0]    216.935673 s:
    [IPU1-0]    216.935795 s:  ### CPU [IPU1-0], LinkID [ 44],
    [IPU1-0]    216.935978 s:
    [IPU1-0]    216.936070 s:  [ ALG_DEWARP ] Link Statistics,
    [IPU1-0]    216.936253 s:  ******************************
    [IPU1-0]    216.936405 s:
    [IPU1-0]    216.936497 s:  Elapsed time       = 137971 msec
    [IPU1-0]    216.936649 s:
    [IPU1-0]    216.936741 s:  New data Recv      =  14.27 fps
    [IPU1-0]    216.936924 s:
    [IPU1-0]    216.937015 s:  Input Statistics,
    [IPU1-0]    216.937137 s:
    [IPU1-0]    216.937229 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    216.937412 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    216.937656 s:  --------------------------------------------------
    [IPU1-0]    216.937869 s:   0 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]    216.938174 s:
    [IPU1-0]    216.938266 s:  Output Statistics,
    [IPU1-0]    216.938388 s:
    [IPU1-0]    216.938479 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    216.938632 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    216.938815 s:  ---------------------------------------------
    [IPU1-0]    216.939486 s:   0 |  0     14.27     0. 0      0. 0
    [IPU1-0]    216.940218 s:
    [IPU1-0]    216.940309 s:  [ ALG_DEWARP ] LATENCY,
    [IPU1-0]    216.940462 s:  ********************
    [IPU1-0]    216.940584 s:  Local Link Latency     : Avg =  35374 us, Min =  32514 us, Max =  45934 us,
    [IPU1-0]    216.940858 s:  Source to Link Latency : Avg =  88608 us, Min =  85242 us, Max =  98823 us,
    [IPU1-0]    216.941133 s:
    [IPU1-0]    216.941377 s:
    [IPU1-0]    216.941468 s:  ### CPU [IPU1-0], LinkID [  0],
    [IPU1-0]    216.941621 s:
    [IPU1-0]    216.941773 s:  [ IPC_OUT_0 ] Link Statistics,
    [IPU1-0]    216.941926 s:  ******************************
    [IPU1-0]    216.942078 s:
    [IPU1-0]    216.942170 s:  Elapsed time       = 137942 msec
    [IPU1-0]    216.942322 s:
    [IPU1-0]    216.942383 s:  New data Recv      =  14.27 fps
    [IPU1-0]    216.942566 s:  Release data Recv  =  14.44 fps
    [IPU1-0]    216.942749 s:  Driver/Notify Cb   =  61.80 fps
    [IPU1-0]    216.942902 s:
    [IPU1-0]    216.942993 s:  Input Statistics,
    [IPU1-0]    216.943115 s:
    [IPU1-0]    216.943207 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    216.943359 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    216.943542 s:  --------------------------------------------------
    [IPU1-0]    216.943725 s:   0 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]    216.944061 s:
    [IPU1-0]    216.944152 s:  Output Statistics,
    [IPU1-0]    216.944274 s:
    [IPU1-0]    216.944366 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    216.944519 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    216.944702 s:  ---------------------------------------------
    [IPU1-0]    216.944854 s:   0 |  0     14.27     0. 0      0. 0
    [IPU1-0]    216.945129 s:
    [IPU1-0]    216.945190 s:  [ IPC_OUT_0 ] LATENCY,
    [IPU1-0]    216.945342 s:  ********************
    [IPU1-0]    216.945434 s:  Local Link Latency     : Avg =     14 us, Min =      0 us, Max =    123 us,
    [IPU1-0]    216.947172 s:  Source to Link Latency : Avg =  88777 us, Min =  85395 us, Max =  99006 us,
    [IPU1-0]    216.947477 s:
    [IPU1-0]    217.998444 s:
    [IPU1-0]    217.998596 s:  ### CPU [  DSP1], LinkID [ 10],
    [IPU1-0]    217.998779 s:
    [IPU1-0]    217.998871 s:  [ IPC_IN_0 ] Link Statistics,
    [IPU1-0]    217.998993 s:  ******************************
    [IPU1-0]    217.999145 s:
    [IPU1-0]    217.999237 s:  Elapsed time       = 137946 msec
    [IPU1-0]    217.999389 s:
    [IPU1-0]    217.999481 s:  Get Full Buf Cb    =  28.54 fps
    [IPU1-0]    217.999633 s:  Put Empty Buf Cb   =  14.26 fps
    [IPU1-0]    217.999847 s:  Driver/Notify Cb   =  14.26 fps
    [IPU1-0]    218.000030 s:
    [IPU1-0]    218.000122 s:  Input Statistics,
    [IPU1-0]    218.000244 s:
    [IPU1-0]    218.000335 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    218.000488 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    218.000671 s:  --------------------------------------------------
    [IPU1-0]    218.000854 s:   0 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]    218.001159 s:
    [IPU1-0]    218.001250 s:  Output Statistics,
    [IPU1-0]    218.001372 s:
    [IPU1-0]    218.001433 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    218.001616 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    218.001769 s:  ---------------------------------------------
    [IPU1-0]    218.002013 s:   0 |  0     14.27     0. 0      0. 0
    [IPU1-0]    218.002287 s:
    [IPU1-0]    218.002379 s:  [ IPC_IN_0 ] LATENCY,
    [IPU1-0]    218.002501 s:  ********************
    [IPU1-0]    218.002623 s:  Local Link Latency     : Avg =     29 us, Min =      0 us, Max =     61 us,
    [IPU1-0]    218.002867 s:  Source to Link Latency : Avg =  89122 us, Min =  85669 us, Max =  99280 us,
    [IPU1-0]    218.003141 s:
    [IPU1-0]    218.003355 s:
    [IPU1-0]    218.003446 s:  ### CPU [  DSP1], LinkID [ 44],
    [IPU1-0]    218.003629 s:
    [IPU1-0]    218.003721 s:  [ ALG_SYNTHESIS ] Link Statistics,
    [IPU1-0]    218.003873 s:  ******************************
    [IPU1-0]    218.004056 s:
    [IPU1-0]    218.004148 s:  Elapsed time       = 137993 msec
    [IPU1-0]    218.004300 s:
    [IPU1-0]    218.004514 s:  New data Recv      =  28.53 fps
    [IPU1-0]    218.004666 s:
    [IPU1-0]    218.004758 s:  Input Statistics,
    [IPU1-0]    218.004880 s:
    [IPU1-0]    218.004941 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    218.005124 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    218.005276 s:  --------------------------------------------------
    [IPU1-0]    218.005459 s:   0 |   0. 0      0. 0      0. 0          14.26
    [IPU1-0]    218.005734 s:
    [IPU1-0]    218.005825 s:  Output Statistics,
    [IPU1-0]    218.005917 s:
    [IPU1-0]    218.006008 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    218.006435 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    218.006649 s:  ---------------------------------------------
    [IPU1-0]    218.006801 s:   0 |  0     14.26     0. 0      0. 0
    [IPU1-0]    218.007045 s:
    [IPU1-0]    218.007137 s:  [ ALG_SYNTHESIS ] LATENCY,
    [IPU1-0]    218.007289 s:  ********************
    [IPU1-0]    218.007411 s:  Local Link Latency     : Avg =  23699 us, Min =  23546 us, Max =  24584 us,
    [IPU1-0]    218.007655 s:  Source to Link Latency : Avg = 114991 us, Min = 111534 us, Max = 125709 us,
    [IPU1-0]    218.007899 s:
    [IPU1-0]    218.008113 s:
    [IPU1-0]    218.014243 s:  ### CPU [  DSP1], LinkID [  0],
    [IPU1-0]    218.014579 s:
    [IPU1-0]    218.014670 s:  [ IPC_OUT_0 ] Link Statistics,
    [IPU1-0]    218.014823 s:  ******************************
    [IPU1-0]    218.014975 s:
    [IPU1-0]    218.015067 s:  Elapsed time       = 137933 msec
    [IPU1-0]    218.015219 s:
    [IPU1-0]    218.015311 s:  New data Recv      =  14.26 fps
    [IPU1-0]    218.015494 s:  Release data Recv  =  14.42 fps
    [IPU1-0]    218.015646 s:  Driver/Notify Cb   =  61.79 fps
    [IPU1-0]    218.015860 s:
    [IPU1-0]    218.015951 s:  Input Statistics,
    [IPU1-0]    218.016073 s:
    [IPU1-0]    218.016195 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    218.016409 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    218.016653 s:  --------------------------------------------------
    [IPU1-0]    218.016866 s:   0 |  14.26      0. 0      0. 0          14.26
    [IPU1-0]    218.017171 s:
    [IPU1-0]    218.017263 s:  Output Statistics,
    [IPU1-0]    218.017385 s:
    [IPU1-0]    218.017446 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    218.017629 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    218.018239 s:  ---------------------------------------------
    [IPU1-0]    218.018452 s:   0 |  0     14.26     0. 0      0. 0
    [IPU1-0]    218.019063 s:
    [IPU1-0]    218.019185 s:  [ IPC_OUT_0 ] LATENCY,
    [IPU1-0]    218.019764 s:  ********************
    [IPU1-0]    218.019947 s:  Local Link Latency     : Avg =      6 us, Min =      0 us, Max =     61 us,
    [IPU1-0]    218.020222 s:  Source to Link Latency : Avg = 118622 us, Min = 115133 us, Max = 129522 us,
    [IPU1-0]    218.020496 s:
    [IPU1-0]    219.110504 s:
    [IPU1-0]    219.110656 s:  ### CPU [IPU1-0], LinkID [ 10],
    [IPU1-0]    219.110809 s:
    [IPU1-0]    219.110900 s:  [ IPC_IN_0 ] Link Statistics,
    [IPU1-0]    219.111053 s:  ******************************
    [IPU1-0]    219.111175 s:
    [IPU1-0]    219.111267 s:  Elapsed time       = 137977 msec
    [IPU1-0]    219.111419 s:
    [IPU1-0]    219.111511 s:  Get Full Buf Cb    =  37.49 fps
    [IPU1-0]    219.111694 s:  Put Empty Buf Cb   =  14.27 fps
    [IPU1-0]    219.111877 s:  Driver/Notify Cb   =  14.26 fps
    [IPU1-0]    219.112029 s:
    [IPU1-0]    219.112121 s:  Input Statistics,
    [IPU1-0]    219.112761 s:
    [IPU1-0]    219.112914 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    219.113097 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    219.113280 s:  --------------------------------------------------
    [IPU1-0]    219.113432 s:   0 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]    219.113737 s:
    [IPU1-0]    219.113829 s:  Output Statistics,
    [IPU1-0]    219.113951 s:
    [IPU1-0]    219.114042 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    219.114195 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    219.114347 s:  ---------------------------------------------
    [IPU1-0]    219.114530 s:   0 |  0     14.27     0. 0      0. 0
    [IPU1-0]    219.114835 s:
    [IPU1-0]    219.114957 s:  [ IPC_IN_0 ] LATENCY,
    [IPU1-0]    219.115079 s:  ********************
    [IPU1-0]    219.115201 s:  Local Link Latency     : Avg =     41 us, Min =     30 us, Max =    335 us,
    [IPU1-0]    219.115476 s:  Source to Link Latency : Avg = 119034 us, Min = 115407 us, Max = 129903 us,
    [IPU1-0]    219.115750 s:
    [IPU1-0]    219.115903 s:  CPU [  IPU1-0], LinkID [ 37], Link Statistics not available !
    [IPU1-0]    219.116147 s:  CPU [  IPU1-0], LinkID [ 25], Link Statistics not available !
    [IPU1-0]    219.116513 s:
    [IPU1-0]    219.116604 s:  ### CPU [IPU1-0], LinkID [  1],
    [IPU1-0]    219.118373 s:
    [IPU1-0]    219.118526 s:  [ IPC_OUT_1 ] Link Statistics,
    [IPU1-0]    219.118648 s:  ******************************
    [IPU1-0]    219.118800 s:
    [IPU1-0]    219.119136 s:  Elapsed time       = 137984 msec
    [IPU1-0]    219.119319 s:
    [IPU1-0]    219.119410 s:  New data Recv      =  37.17 fps
    [IPU1-0]    219.119654 s:  Release data Recv  =  72.10 fps
    [IPU1-0]    219.119990 s:  Driver/Notify Cb   = 118.89 fps
    [IPU1-0]    219.120173 s:
    [IPU1-0]    219.120264 s:  Input Statistics,
    [IPU1-0]    219.120386 s:
    [IPU1-0]    219.120447 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    219.120630 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    219.120783 s:  --------------------------------------------------
    [IPU1-0]    219.121027 s:   0 |  14.26      0. 0      0. 0          14.26
    [IPU1-0]    219.121332 s:   1 |  14.26      0. 0      0. 0          14.26
    [IPU1-0]    219.121637 s:   2 |  14.26      0. 0      0. 0          14.26
    [IPU1-0]    219.121942 s:   3 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]    219.122216 s:   4 |  14.26      0. 0      0. 0          14.26
    [IPU1-0]    219.122521 s:
    [IPU1-0]    219.122613 s:  Output Statistics,
    [IPU1-0]    219.122735 s:
    [IPU1-0]    219.122796 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    219.122979 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    219.123223 s:  ---------------------------------------------
    [IPU1-0]    219.123406 s:   0 |  0     14.26     0. 0      0. 0
    [IPU1-0]    219.123650 s:   1 |  0     14.26     0. 0      0. 0
    [IPU1-0]    219.123924 s:   2 |  0     14.26     0. 0      0. 0
    [IPU1-0]    219.124168 s:   3 |  0     14.27     0. 0      0. 0
    [IPU1-0]    219.124443 s:   4 |  0     14.26     0. 0      0. 0
    [IPU1-0]    219.124687 s:
    [IPU1-0]    219.124778 s:  [ IPC_OUT_1 ] LATENCY,
    [IPU1-0]    219.124900 s:  ********************
    [IPU1-0]    219.125022 s:  Local Link Latency     : Avg =     13 us, Min =      0 us, Max =    244 us,
    [IPU1-0]    219.125327 s:  Source to Link Latency : Avg =  59191 us, Min =  13054 us, Max = 130300 us,
    [IPU1-0]    219.125602 s:
    [IPU1-0]    220.177362 s:
    [IPU1-0]    220.177514 s:  ### CPU [IPU1-1], LinkID [ 10],
    [IPU1-0]    220.177697 s:
    [IPU1-0]    220.177789 s:  [ IPC_IN_0 ] Link Statistics,
    [IPU1-0]    220.177941 s:  ******************************
    [IPU1-0]    220.178063 s:
    [IPU1-0]    220.178155 s:  Elapsed time       = 137992 msec
    [IPU1-0]    220.178307 s:
    [IPU1-0]    220.178399 s:  Get Full Buf Cb    =  36.3 fps
    [IPU1-0]    220.178582 s:  Put Empty Buf Cb   =  71.35 fps
    [IPU1-0]    220.178734 s:  Driver/Notify Cb   =  37.27 fps
    [IPU1-0]    220.178887 s:
    [IPU1-0]    220.179039 s:  Input Statistics,
    [IPU1-0]    220.179161 s:
    [IPU1-0]    220.179253 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    220.179436 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    220.179588 s:  --------------------------------------------------
    [IPU1-0]    220.179771 s:   0 |  14.26      0. 0      0. 0          14.26
    [IPU1-0]    220.180076 s:   1 |  14.26      0. 0      0. 0          14.26
    [IPU1-0]    220.180351 s:   2 |  14.26      0. 0      0. 0          14.26
    [IPU1-0]    220.180625 s:   3 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]    220.187214 s:   4 |  14.26      0. 0      0. 0          14.26
    [IPU1-0]    220.188037 s:
    [IPU1-0]    220.188159 s:  Output Statistics,
    [IPU1-0]    220.188281 s:
    [IPU1-0]    220.188373 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    220.188556 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    220.188739 s:  ---------------------------------------------
    [IPU1-0]    220.188922 s:   0 |  0     14.26     0. 0      0. 0
    [IPU1-0]    220.189196 s:   1 |  0     14.26     0. 0      0. 0
    [IPU1-0]    220.189471 s:   2 |  0     14.26     0. 0      0. 0
    [IPU1-0]    220.189806 s:   3 |  0     14.27     0. 0      0. 0
    [IPU1-0]    220.190111 s:   4 |  0     14.26     0. 0      0. 0
    [IPU1-0]    220.191026 s:
    [IPU1-0]    220.191423 s:  [ IPC_IN_0 ] LATENCY,
    [IPU1-0]    220.191606 s:  ********************
    [IPU1-0]    220.191880 s:  Local Link Latency     : Avg =     37 us, Min =      0 us, Max =    305 us,
    [IPU1-0]    220.192673 s:  Source to Link Latency : Avg =  59724 us, Min =  13116 us, Max = 130666 us,
    [IPU1-0]    220.193009 s:
    [IPU1-0]    220.193131 s:  CPU [  IPU1-1], LinkID [ 20], Link Statistics not available !
    [IPU1-0]    221.244891 s:
    [IPU1-0]    221.245074 s:  ### CPU [IPU1-0], LinkID [ 62],
    [IPU1-0]    221.246507 s:
    [IPU1-0]    221.246660 s:  [ DISPLAY ] Link Statistics,
    [IPU1-0]    221.246812 s:  ******************************
    [IPU1-0]    221.246934 s:
    [IPU1-0]    221.247026 s:  Elapsed time       = 138011 msec
    [IPU1-0]    221.247209 s:
    [IPU1-0]    221.247941 s:  New data Recv      =  29.77 fps
    [IPU1-0]    221.248185 s:  Driver/Notify Cb   =  28.51 fps
    [IPU1-0]    221.248368 s:
    [IPU1-0]    221.248459 s:  Input Statistics,
    [IPU1-0]    221.248886 s:
    [IPU1-0]    221.249008 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    221.249496 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    221.255108 s:  --------------------------------------------------
    [IPU1-0]    221.255413 s:   0 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]    221.255749 s:   1 |  14.27     14.27      0. 0           0. 0
    [IPU1-0]    221.256725 s:   2 |  14.27     14.27      0. 0           0. 0
    [IPU1-0]    221.257152 s:   3 |  14.27     14.27      0. 0           0. 0
    [IPU1-0]    221.257518 s:   4 |  14.27     14.27      0. 0           0. 0
    [IPU1-0]    221.259684 s:
    [IPU1-0]    221.259897 s:  Output Statistics,
    [IPU1-0]    221.260050 s:
    [IPU1-0]    221.260141 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    221.260446 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    221.260690 s:  ---------------------------------------------
    [IPU1-0]    221.260934 s:
    [IPU1-0]    221.261056 s:  [ DISPLAY ] LATENCY,
    [IPU1-0]    221.261209 s:  ********************
    [IPU1-0]    221.261361 s:  Local Link Latency     : Avg =    192 us, Min =     91 us, Max =   2501 us,
    [IPU1-0]    221.261666 s:  Source to Link Latency : Avg = 120878 us, Min = 116078 us, Max = 130582 us,
    [IPU1-0]    221.261971 s:
    [IPU1-0]    222.312358 s:
    [IPU1-0]    222.312602 s:  ### CPU [  DSP1], LinkID [ 45],
    [IPU1-0]    222.312816 s:
    [IPU1-0]    222.312938 s:  [ ALG_PALIGN ] Link Statistics,
    [IPU1-0]    222.313121 s:  ******************************
    [IPU1-0]    222.313304 s:
    [IPU1-0]    222.313426 s:  Elapsed time       = 138030 msec
    [IPU1-0]    222.313639 s:
    [IPU1-0]    222.313761 s:  New data Recv      =  14.27 fps
    [IPU1-0]    222.313975 s:
    [IPU1-0]    222.314188 s:  Input Statistics,
    [IPU1-0]    222.314371 s:
    [IPU1-0]    222.314463 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    222.314676 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    222.315043 s:  --------------------------------------------------
    [IPU1-0]    222.315256 s:   0 |   0. 0      0. 0      0. 0          14.27
    [IPU1-0]    222.315561 s:
    [IPU1-0]    222.315653 s:  Output Statistics,
    [IPU1-0]    222.319191 s:
    [IPU1-0]    222.319435 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    222.319648 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    222.319831 s:  ---------------------------------------------
    [IPU1-0]    222.320685 s:   0 |  0     14.27     0. 0      0. 0
    [IPU1-0]    222.321082 s:
    [IPU1-0]    222.321722 s:  [ ALG_PALIGN ] LATENCY,
    [IPU1-0]    222.321936 s:  ********************
    [IPU1-0]    222.322088 s:  Local Link Latency     : Avg =   3218 us, Min =   3172 us, Max =   3355 us,
    [IPU1-0]    222.322393 s:  Source to Link Latency : Avg = 118681 us, Min = 115019 us, Max = 130117 us,
    [IPU1-0]    222.323034 s:
    [IPU1-0]    223.374367 s:  CPU [  IPU1-1], LinkID [ 56], Link Statistics not available !
    [IPU1-0]    224.426188 s:  CPU [  IPU1-0], LinkID [ 22], Link Statistics not available !
    [IPU1-0]    224.426767 s:
    [IPU1-0]    224.426889 s:  ### CPU [IPU1-0], LinkID [ 63],
    [IPU1-0]    224.427774 s:
    [IPU1-0]    224.427957 s:  [ DISPLAY ] Link Statistics,
    [IPU1-0]    224.428536 s:  ******************************
    [IPU1-0]    224.428750 s:
    [IPU1-0]    224.428841 s:  Elapsed time       = 190563 msec
    [IPU1-0]    224.429024 s:
    [IPU1-0]    224.429116 s:  Driver/Notify Cb   =  28.52 fps
    [IPU1-0]    224.429299 s:
    [IPU1-0]    224.430366 s:  Input Statistics,
    [IPU1-0]    224.430549 s:
    [IPU1-0]    224.430641 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    224.430793 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    224.430976 s:  --------------------------------------------------
    [IPU1-0]    224.431159 s:   0 |   0. 0      0. 0      0. 0           0. 0
    [IPU1-0]    224.431434 s:
    [IPU1-0]    224.431525 s:  [ DISPLAY ] LATENCY,
    [IPU1-0]    224.431647 s:  ********************
    [IPU1-0]    224.431769 s:  Local Link Latency     : Avg =     91 us, Min =     91 us, Max =     91 us,
    [IPU1-0]    224.432044 s:  Source to Link Latency : Avg =  21900 us, Min =  21900 us, Max =  21900 us,
    [IPU1-0]     76.488775 s:  CPU [IPU1-0 ] Statistics,
    [IPU1-0]     76.488897 s:  *************************
    [IPU1-0]     76.489050 s:
    [IPU1-0]     76.489141 s:  LOAD: CPU: 57.9% HWI: 8.6%, SWI:1.0%, Low Power: 144.3%
    [IPU1-0]     76.489477 s:
    [IPU1-0]     76.489568 s:  LOAD: TSK: SYSTEM              : 0.3%
    [IPU1-0]     76.489782 s:  LOAD: TSK: ISSCAPTURE          : 0.4%
    [IPU1-0]     76.489965 s:  LOAD: TSK: ISSM2MISP           : 6.9%
    [IPU1-0]     76.490178 s:  LOAD: TSK: DUP0                : 0.3%
    [IPU1-0]     76.490361 s:  LOAD: TSK: DUP1                : 0.4%
    [IPU1-0]     76.490575 s:  LOAD: TSK: MERGE0              : 0.2%
    [IPU1-0]     76.491124 s:  LOAD: TSK: SYNC0               : 0.6%
    [IPU1-0]     76.491337 s:  LOAD: TSK: IPC_OUT_0           : 0.5%
    [IPU1-0]     76.491520 s:  LOAD: TSK: IPC_OUT_1           : 1.4%
    [IPU1-0]     76.491764 s:  LOAD: TSK: IPC_IN_0            : 0.3%
    [IPU1-0]     76.491978 s:  LOAD: TSK: DISPLAY0            : 0.8%
    [IPU1-0]     76.492191 s:  LOAD: TSK: ALGORITHM0          : 5.4%
    [IPU1-0]     76.492405 s:  LOAD: TSK: ALGORITHM1          : 7.8%
    [IPU1-0]     76.492649 s:  LOAD: TSK: GrpxSrc0            : 13.7%
    [IPU1-0]     76.492893 s:  LOAD: TSK: STAT_COLL           : 2.3%
    [IPU1-0]     76.493106 s:  LOAD: TSK: 3D_SRV_MEDIA_TSK    : 5.7%
    [IPU1-0]     76.493320 s:  LOAD: TSK: MISC                : 1.3%
    [IPU1-0]     76.493503 s:
    [IPU1-0]     76.493594 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1020
    [IPU1-0]     76.493808 s:
    [IPU1-0]     76.493869 s:  SYSTEM: Sempahores Objects,  157 of 1000 free
    [IPU1-0]     76.494082 s:  SYSTEM: Task Objects      ,   21 of  100 free
    [IPU1-0]     76.494265 s:  SYSTEM: Clock Objects     ,   93 of  100 free
    [IPU1-0]     76.494448 s:  SYSTEM: Hwi Objects       ,   87 of  100 free
    [IPU1-0]     76.494631 s:
    [IPU1-0]     76.494723 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 151256 B (147 KB)
    [IPU1-0]     76.495150 s:  SYSTEM: Heap = SR_OCMC              @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
    [IPU1-0]     76.495455 s:  SYSTEM: Heap = SR_DDR_CACHED        @ 0x85483000, Total size = 367001600 B (350 MB), Free size = 230517248 B (219 MB)
    [IPU1-0]     76.495851 s:  SYSTEM: Heap = SR_DDR_NON_CACHED    @ 0xbfe00000, Total size = 1046784 B (0 MB), Free size = 1039104 B (0 MB)
    [IPU1-0]     76.496217 s:
    [IPU1-0]     76.496309 s:
    [IPU1-0]     76.496370 s:  CPU [IPU1-1 ] Statistics,
    [IPU1-0]     76.496492 s:  *************************
    [IPU1-0]     76.496644 s:
    [IPU1-0]     76.496736 s:  LOAD: CPU: 4.9% HWI: 1.6%, SWI:0.7%, Low Power: 145.7%
    [IPU1-0]     76.498291 s:
    [IPU1-0]     76.498505 s:  LOAD: TSK: NULL0               : 0.6%
    [IPU1-0]     76.498749 s:  LOAD: TSK: IPC_IN_0            : 1.1%
    [IPU1-0]     76.498993 s:  LOAD: TSK: MISC                : 0.9%
    [IPU1-0]     76.499267 s:
    [IPU1-0]     76.499389 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1020
    [IPU1-0]     76.499572 s:
    [IPU1-0]     76.499664 s:  SYSTEM: Sempahores Objects,  431 of 1000 free
    [IPU1-0]     76.499847 s:  SYSTEM: Task Objects      ,   41 of  100 free
    [IPU1-0]     76.500030 s:  SYSTEM: Clock Objects     ,   99 of  100 free
    [IPU1-0]     76.500244 s:  SYSTEM: Hwi Objects       ,   99 of  100 free
    [IPU1-0]     76.500427 s:
    [IPU1-0]     76.500518 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 241888 B (236 KB)
    [IPU1-0]     76.500854 s:
    [IPU1-0]     76.500945 s:
    [IPU1-0]     76.501037 s:  CPU [DSP1   ] Statistics,
    [IPU1-0]     76.501159 s:  *************************
    [IPU1-0]     76.501586 s:
    [IPU1-0]     76.501708 s:  LOAD: CPU: 42.8% HWI: 0.3%, SWI:0.1%, Low Power: 165.7%
    [IPU1-0]     76.502257 s:
    [IPU1-0]     76.502379 s:  LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 42.1%
    [IPU1-0]     76.502592 s:  LOAD: TSK: MISC                : 0.3%
    [IPU1-0]     76.502775 s:
    [IPU1-0]     76.503080 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1020
    [IPU1-0]     76.503263 s:
    [IPU1-0]     76.503416 s:  SYSTEM: Sempahores Objects,  444 of 1000 free
    [IPU1-0]     76.503629 s:  SYSTEM: Task Objects      ,   92 of  100 free
    [IPU1-0]     76.503812 s:  SYSTEM: Clock Objects     ,   98 of  100 free
    [IPU1-0]     76.503995 s:  SYSTEM: Hwi Objects       ,  100 of  100 free
    [IPU1-0]     76.504178 s:
    [IPU1-0]     76.504239 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 96192 B (93 KB)
    [IPU1-0]     76.504575 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 519424 B (507 KB)
    [IPU1-0]     76.504910 s:
    [IPU1-0]     76.505002 s:
    [IPU1-0]     76.505093 s:  CPU [DSP2   ] Statistics,
    [IPU1-0]     76.505215 s:  *************************
    [IPU1-0]     76.505337 s:
    [IPU1-0]     76.505490 s:  LOAD: CPU: 0.3% HWI: 0.1%, SWI:0.0%, Low Power: 207.8%
    [IPU1-0]     76.505795 s:
    [IPU1-0]     76.505917 s:  LOAD: TSK: MISC                : 0.2%
    [IPU1-0]     76.506100 s:
    [IPU1-0]     76.506161 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1020
    [IPU1-0]     76.507289 s:
    [IPU1-0]     76.507411 s:  SYSTEM: Sempahores Objects,  446 of 1000 free
    [IPU1-0]     76.507960 s:  SYSTEM: Task Objects      ,   92 of  100 free
    [IPU1-0]     76.508204 s:  SYSTEM: Clock Objects     ,   99 of  100 free
    [IPU1-0]     76.508387 s:  SYSTEM: Hwi Objects       ,  100 of  100 free
    [IPU1-0]     76.508570 s:
    [IPU1-0]     76.508631 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
    [IPU1-0]     76.508997 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 519424 B (507 KB)
    [IPU1-0]     76.551942 s:
    [IPU1-0]     76.552095 s:
    [IPU1-0]     76.552186 s:  CPU [EVE1   ] Statistics,
    [IPU1-0]     76.552339 s:  *************************
    [IPU1-0]     76.552461 s:
    [IPU1-0]     76.552583 s:  LOAD: CPU: 0.9% HWI: 0.2%, SWI:0.2%, Low Power: 197.6%
    [IPU1-0]     76.552888 s:
    [IPU1-0]     76.552979 s:  LOAD: TSK: SYSTEM              : 0.3%
    [IPU1-0]     76.553193 s:  LOAD: TSK: MISC                : 0.2%
    [IPU1-0]     76.553376 s:
    [IPU1-0]     76.553467 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1019
    [IPU1-0]     76.553650 s:
    [IPU1-0]     76.553742 s:  SYSTEM: Sempahores Objects,  487 of 1000 free
    [IPU1-0]     76.554291 s:  SYSTEM: Task Objects      ,   97 of  100 free
    [IPU1-0]     76.554474 s:  SYSTEM: Clock Objects     ,   99 of  100 free
    [IPU1-0]     76.554687 s:  SYSTEM: Hwi Objects       ,   99 of  100 free
    [IPU1-0]     76.554870 s:
    [IPU1-0]     76.556335 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 24576 B (24 KB), Free size = 24576 B (24 KB)
    [IPU1-0]     76.556762 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 257448 B (251 KB)
    [IPU1-0]     76.557128 s:
    [IPU1-0]     76.557738 s:
    [IPU1-0]     76.557860 s:  UTILS_PRCM_STATS:  Current Temperature,
    [IPU1-0]     76.558073 s:
    [IPU1-0]     76.558165 s:   Voltage Rail         ||   Curr Temp Min - Max
    [IPU1-0]     76.558348 s:  ---------------------------------------------------------
    [IPU1-0]     76.558592 s:     PMHAL_PRCM_VD_CORE ||     [59.200 , 59.600]
    [IPU1-0]     76.558836 s:
    [IPU1-0]     76.558988 s:
    [IPU1-0]     76.559110 s:  Statistics Collector,
    [IPU1-0]     76.559232 s:
    [IPU1-0]     76.559324 s:        STATISTIC          Avg Data        Peak Data
    [IPU1-0]     76.559507 s:        COLLECTOR          MB/s            MB/s
    [IPU1-0]     76.559659 s:  --------------------------------------------------
    [IPU1-0]     76.559873 s:  SCI_EMIF_SYS         |    828.663668   1089.060271
    [IPU1-0]     76.560178 s:  SCI_IPU              |     14.106077     36.461808
    [IPU1-0]     76.560422 s:  SCI_DSP1_MDMA        |      4.758417     24.320204
    [IPU1-0]     76.560666 s:  SCI_DSP2_MDMA        |      0.018531      0.137853
    [IPU1-0]     76.560910 s:  SCI_DSS              |    152.926593    210.430638
    [IPU1-0]     76.561154 s:  SCI_MMU              |      0.000000      0.000000
    [IPU1-0]     76.561489 s:  SCI_EDMA_TC0_RD      |      0.000000      0.000000
    [IPU1-0]     76.561733 s:  SCI_EDMA_TC0_WR      |      0.000000      0.000000
    [IPU1-0]     76.561947 s:  SCI_VIP_P1           |      0.000000      0.000000
    [IPU1-0]     76.562221 s:  SCI_VIP_P2           |      0.000000      0.000000
    [IPU1-0]     76.562465 s:  SCI_ISS_RT           |    105.202170    161.108512
    [IPU1-0]     76.562740 s:  SCI_ISS_NRT2         |    213.249915    382.175062
    [IPU1-0]     76.562953 s:  SCI_EVE_P1           |      1.547498      3.890301
    [IPU1-0]     76.563197 s:  SCI_EVE_P2           |      0.000000      0.000000
    [IPU1-0]     76.563411 s:  SCI_GMAC_SW          |      0.000000      0.000000
    [IPU1-0]     76.563655 s:  SCI_ISS_NRT1         |    241.937342    667.502636
    [IPU1-0]     76.563868 s:  SCI_DSP2_CFG         |      0.000000      0.000000
    [IPU1-0]     76.564112 s:  SCI_DSP2_EDMA        |      0.000000      0.000000
    [IPU1-0]     76.564661 s:  SCI_OCMC_RAM         |     17.162366     44.624277
    [IPU1-0]     76.564905 s:  SCI_DSP1_CFG         |      0.000000      0.000000
    [IPU1-0]     76.565149 s:  SCI_DSP1_EDMA        |     96.924165    326.199197
    [IPU1-0]     76.565363 s:  SCI_GPMC             |      0.000000      0.000000
    [IPU1-0]     76.565576 s:  SCI_MCASP            |      0.000000      0.000000
    [IPU1-0]     76.565820 s:  SCI_EDMA_TC1_RD      |      8.752071     64.153701
    [IPU1-0]     76.566064 s:  SCI_EDMA_TC1_WR      |      8.752071     64.153701
    [IPU1-0]     76.777160 s:
    [IPU1-0]     76.777313 s:  ### CPU [IPU1-0], LinkID [ 72],
    [IPU1-0]     76.777465 s:
    [IPU1-0]     76.777557 s:  [ ISSCAPTURE ] Link Statistics,
    [IPU1-0]     76.779113 s:  ******************************
    [IPU1-0]     76.779296 s:
    [IPU1-0]     76.779387 s:  Elapsed time       = 57505 msec
    [IPU1-0]     76.779540 s:
    [IPU1-0]     76.779631 s:  Get Full Buf Cb    =  57.5 fps
    [IPU1-0]     76.779784 s:  Put Empty Buf Cb   =  14.25 fps
    [IPU1-0]     76.779967 s:  Driver/Notify Cb   =  57.3 fps
    [IPU1-0]     76.780119 s:
    [IPU1-0]     76.780211 s:  Input Statistics,
    [IPU1-0]     76.780302 s:
    [IPU1-0]     76.780394 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     76.780546 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     76.780729 s:  --------------------------------------------------
    [IPU1-0]     76.780912 s:   0 |  14.25      0. 0      0. 0          14.25
    [IPU1-0]     76.781248 s:   1 |  14.25      0. 0      0. 0          14.25
    [IPU1-0]     76.781553 s:   2 |  14.25      0. 0      0. 0          14.25
    [IPU1-0]     76.781827 s:   3 |  14.25      0. 0      0. 0          14.25
    [IPU1-0]     76.782132 s:
    [IPU1-0]     76.782193 s:  Output Statistics,
    [IPU1-0]     76.782376 s:
    [IPU1-0]     76.782468 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     76.782773 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     76.782925 s:  ---------------------------------------------
    [IPU1-0]     76.783139 s:   0 |  0     14.27     0. 0      0. 0
    [IPU1-0]     76.783657 s:   1 |  0     14.27     0. 0      0. 0
    [IPU1-0]     76.783901 s:   2 |  0     14.27     0. 0      0. 0
    [IPU1-0]     76.784145 s:   3 |  0     14.27     0. 0      0. 0
    [IPU1-0]     76.784420 s:
    [IPU1-0]     76.784481 s:  [ ISSCAPTURE ] LATENCY,
    [IPU1-0]     76.784633 s:  ********************
    [IPU1-0]     76.784725 s:
    [IPU1-0]     76.784969 s:
    [IPU1-0]     76.785030 s:  ### CPU [IPU1-0], LinkID [ 73],
    [IPU1-0]     76.785274 s:
    [IPU1-0]     76.785365 s:  [ ISSM2MISP ] Link Statistics,
    [IPU1-0]     76.785518 s:  ******************************
    [IPU1-0]     76.785640 s:
    [IPU1-0]     76.785731 s:  Elapsed time       = 57512 msec
    [IPU1-0]     76.785884 s:
    [IPU1-0]     76.785945 s:  New data Recv      =  57.4 fps
    [IPU1-0]     76.786128 s:  Get Full Buf Cb    =  28.27 fps
    [IPU1-0]     76.786280 s:  Driver/Notify Cb   =  57.8 fps
    [IPU1-0]     76.786433 s:
    [IPU1-0]     76.786524 s:  Input Statistics,
    [IPU1-0]     76.786616 s:
    [IPU1-0]     76.786707 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     76.788446 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     76.788659 s:  --------------------------------------------------
    [IPU1-0]     76.788842 s:   0 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]     76.789117 s:   1 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]     76.789483 s:   2 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]     76.794759 s:   3 |  14.27      0. 0      0. 0          14.25
    [IPU1-0]     76.795125 s:
    [IPU1-0]     76.795217 s:  Output Statistics,
    [IPU1-0]     76.795339 s:
    [IPU1-0]     76.795400 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     76.795583 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     76.795827 s:  ---------------------------------------------
    [IPU1-0]     76.796040 s:   0 |  0     14.27     0. 0      0. 0
    [IPU1-0]     76.796284 s:   0 |  1     14.27     0. 0      0. 0
    [IPU1-0]     76.796559 s:   0 |  2      0. 0    14.27      0. 0
    [IPU1-0]     76.796803 s:   0 |  3      0. 0    14.27      0. 0
    [IPU1-0]     76.797078 s:   1 |  0     14.27     0. 0      0. 0
    [IPU1-0]     76.797352 s:   1 |  1     14.27     0. 0      0. 0
    [IPU1-0]     76.797596 s:   1 |  2      0. 0    14.27      0. 0
    [IPU1-0]     76.798206 s:   1 |  3      0. 0    14.27      0. 0
    [IPU1-0]     76.798908 s:   2 |  0     14.27     0. 0      0. 0
    [IPU1-0]     76.799182 s:   2 |  1     14.27     0. 0      0. 0
    [IPU1-0]     76.799457 s:   2 |  2      0. 0    14.27      0. 0
    [IPU1-0]     76.799731 s:   2 |  3      0. 0    14.27      0. 0
    [IPU1-0]     76.800433 s:   3 |  0     14.25     0. 0      0. 0
    [IPU1-0]     76.800738 s:   3 |  1     14.25     0. 0      0. 0
    [IPU1-0]     76.801012 s:   3 |  2      0. 0    14.25      0. 0
    [IPU1-0]     76.801256 s:   3 |  3      0. 0    14.25      0. 0
    [IPU1-0]     76.802263 s:
    [IPU1-0]     76.802415 s:  [ ISSM2MISP ] LATENCY,
    [IPU1-0]     76.802537 s:  ********************
    [IPU1-0]     76.802659 s:  Local Link Latency     : Avg =  11960 us, Min =  11682 us, Max =  15190 us,
    [IPU1-0]     76.802903 s:  Source to Link Latency : Avg =  30328 us, Min =  11987 us, Max =  60971 us,
    [IPU1-0]     76.803178 s:
    [IPU1-0]     76.803452 s:
    [IPU1-0]     76.803544 s:  ### CPU [IPU1-0], LinkID [ 45],
    [IPU1-0]     76.803727 s:
    [IPU1-0]     76.803788 s:  [ ALG_ISS_AEWB ] Link Statistics,
    [IPU1-0]     76.803940 s:  ******************************
    [IPU1-0]     76.804184 s:
    [IPU1-0]     76.804306 s:  Elapsed time       = 57466 msec
    [IPU1-0]     76.804459 s:
    [IPU1-0]     76.804520 s:  New data Recv      =  14.4 fps
    [IPU1-0]     76.804703 s:
    [IPU1-0]     76.804794 s:  Input Statistics,
    [IPU1-0]     76.804886 s:
    [IPU1-0]     76.804977 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     76.805160 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     76.805313 s:  --------------------------------------------------
    [IPU1-0]     76.805496 s:   0 |  14.28      0. 0      0. 0          14.28
    [IPU1-0]     76.805801 s:
    [IPU1-0]     76.805892 s:  Output Statistics,
    [IPU1-0]     76.805984 s:
    [IPU1-0]     76.806075 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     76.806289 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     76.806472 s:  ---------------------------------------------
    [IPU1-0]     76.806624 s:   0 |  0     14.28     0. 0      0. 0
    [IPU1-0]     76.806868 s:
    [IPU1-0]     76.806960 s:  [ ALG_ISS_AEWB ] LATENCY,
    [IPU1-0]     76.807112 s:  ********************
    [IPU1-0]     76.807234 s:  Local Link Latency     : Avg =  16189 us, Min =    305 us, Max = 154426 us,
    [IPU1-0]     76.807936 s:  Source to Link Latency : Avg =  71324 us, Min =  51303 us, Max = 206795 us,
    [IPU1-0]     76.808241 s:
    [IPU1-0]     76.809125 s:  CPU [  IPU1-0], LinkID [ 24], Link Statistics not available !
    [IPU1-0]     76.809522 s:
    [IPU1-0]     76.809613 s:  ### CPU [IPU1-0], LinkID [ 52],
    [IPU1-0]     76.809766 s:
    [IPU1-0]     76.809857 s:  [ NULL_SRC ] Link Statistics,
    [IPU1-0]     76.812785 s:  ******************************
    [IPU1-0]     76.813060 s:
    [IPU1-0]     76.813121 s:  Elapsed time       = 62289 msec
    [IPU1-0]     76.813304 s:
    [IPU1-0]     76.813395 s:
    [IPU1-0]     76.813487 s:  Input Statistics,
    [IPU1-0]     76.813639 s:
    [IPU1-0]     76.813731 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     76.813914 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     76.814127 s:  --------------------------------------------------
    [IPU1-0]     76.814341 s:
    [IPU1-0]     76.814432 s:  Output Statistics,
    [IPU1-0]     76.814585 s:
    [IPU1-0]     76.814737 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     76.814951 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     76.815165 s:  ---------------------------------------------
    [IPU1-0]     76.815378 s:
    [IPU1-0]     76.815470 s:  [ NULL_SRC ] LATENCY,
    [IPU1-0]     76.815622 s:  ********************
    [IPU1-0]     76.815744 s:
    [IPU1-0]     76.816080 s:
    [IPU1-0]     76.816171 s:  ### CPU [IPU1-0], LinkID [  2],
    [IPU1-0]     76.816324 s:
    [IPU1-0]     76.816415 s:  [ IPC_OUT_2 ] Link Statistics,
    [IPU1-0]     76.816568 s:  ******************************
    [IPU1-0]     76.816781 s:
    [IPU1-0]     76.816873 s:  Elapsed time       = 62295 msec
    [IPU1-0]     76.817025 s:
    [IPU1-0]     76.818306 s:  Driver/Notify Cb   =  44.0 fps
    [IPU1-0]     76.819374 s:
    [IPU1-0]     76.819526 s:  Input Statistics,
    [IPU1-0]     76.819648 s:
    [IPU1-0]     76.819740 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     76.819923 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     76.820533 s:  --------------------------------------------------
    [IPU1-0]     76.820746 s:
    [IPU1-0]     76.820838 s:  Output Statistics,
    [IPU1-0]     76.821082 s:
    [IPU1-0]     76.821204 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     76.821387 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     76.821539 s:  ---------------------------------------------
    [IPU1-0]     76.821753 s:
    [IPU1-0]     76.821844 s:  [ IPC_OUT_2 ] LATENCY,
    [IPU1-0]     76.821997 s:  ********************
    [IPU1-0]     76.822119 s:
    [IPU1-0]     77.872964 s:
    [IPU1-0]     77.873147 s:  ### CPU [  DSP1], LinkID [ 11],
    [IPU1-0]     77.873330 s:
    [IPU1-0]     77.873421 s:  [ IPC_IN_1 ] Link Statistics,
    [IPU1-0]     77.873574 s:  ******************************
    [IPU1-0]     77.873726 s:
    [IPU1-0]     77.873970 s:  Elapsed time       = 63351 msec
    [IPU1-0]     77.874123 s:
    [IPU1-0]     77.874214 s:
    [IPU1-0]     77.874306 s:  Input Statistics,
    [IPU1-0]     77.874428 s:
    [IPU1-0]     77.876349 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     77.876654 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     77.876837 s:  --------------------------------------------------
    [IPU1-0]     77.877203 s:
    [IPU1-0]     77.877325 s:  Output Statistics,
    [IPU1-0]     77.877478 s:
    [IPU1-0]     77.877996 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     77.878210 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     77.878393 s:  ---------------------------------------------
    [IPU1-0]     77.878606 s:
    [IPU1-0]     77.878698 s:  [ IPC_IN_1 ] LATENCY,
    [IPU1-0]     77.878850 s:  ********************
    [IPU1-0]     77.879064 s:
    [IPU1-0]     78.930976 s:
    [IPU1-0]     78.931129 s:  ### CPU [IPU1-0], LinkID [ 33],
    [IPU1-0]     78.931281 s:
    [IPU1-0]     78.931373 s:  [ SYNC_0 ] Link Statistics,
    [IPU1-0]     78.931495 s:  ******************************
    [IPU1-0]     78.931617 s:
    [IPU1-0]     78.931708 s:  Elapsed time       = 59719 msec
    [IPU1-0]     78.931861 s:
    [IPU1-0]     78.931952 s:  New data Recv      =  28.61 fps
    [IPU1-0]     78.932105 s:  Get Full Buf Cb    =  14.25 fps
    [IPU1-0]     78.932288 s:  Put Empty Buf Cb   =  14.25 fps
    [IPU1-0]     78.932440 s:  Driver/Notify Cb   =  14.40 fps
    [IPU1-0]     78.932623 s:
    [IPU1-0]     78.932684 s:  Input Statistics,
    [IPU1-0]     78.932806 s:
    [IPU1-0]     78.933081 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     78.933264 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     78.933447 s:  --------------------------------------------------
    [IPU1-0]     78.933630 s:   0 |  14.25      0. 0      0. 0          14.25
    [IPU1-0]     78.933904 s:   1 |  14.25      0. 0      0. 0          14.25
    [IPU1-0]     78.934209 s:   2 |  14.25      0. 0      0. 0          14.25
    [IPU1-0]     78.934514 s:   3 |  14.25      0. 0      0. 0          14.25
    [IPU1-0]     78.934789 s:
    [IPU1-0]     78.934880 s:  Output Statistics,
    [IPU1-0]     78.935033 s:
    [IPU1-0]     78.935155 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     78.935307 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     78.935460 s:  ---------------------------------------------
    [IPU1-0]     78.935643 s:   0 |  0     14.25     0. 0      0. 0
    [IPU1-0]     78.935887 s:
    [IPU1-0]     78.935978 s:  [ SYNC_0 ] LATENCY,
    [IPU1-0]     78.936131 s:  ********************
    [IPU1-0]     78.936253 s:  Local Link Latency     : Avg =    124 us, Min =     91 us, Max =    458 us,
    [IPU1-0]     78.936497 s:  Source to Link Latency : Avg =  49055 us, Min =  48459 us, Max =  61719 us,
    [IPU1-0]     78.936771 s:
    [IPU1-0]     78.937015 s:
    [IPU1-0]     78.937137 s:  ### CPU [IPU1-0], LinkID [ 44],
    [IPU1-0]     78.937351 s:
    [IPU1-0]     78.937412 s:  [ ALG_DEWARP ] Link Statistics,
    [IPU1-0]     78.937564 s:  ******************************
    [IPU1-0]     78.937717 s:
    [IPU1-0]     78.937808 s:  Elapsed time       = 59601 msec
    [IPU1-0]     78.937961 s:
    [IPU1-0]     78.939699 s:  New data Recv      =  14.27 fps
    [IPU1-0]     78.939943 s:
    [IPU1-0]     78.940035 s:  Input Statistics,
    [IPU1-0]     78.940157 s:
    [IPU1-0]     78.940248 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     78.940401 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     78.940584 s:  --------------------------------------------------
    [IPU1-0]     78.940767 s:   0 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]     78.941072 s:
    [IPU1-0]     78.941133 s:  Output Statistics,
    [IPU1-0]     78.941316 s:
    [IPU1-0]     78.941438 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     78.941621 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     78.941773 s:  ---------------------------------------------
    [IPU1-0]     78.941956 s:   0 |  0     14.27     0. 0      0. 0
    [IPU1-0]     78.942200 s:
    [IPU1-0]     78.942292 s:  [ ALG_DEWARP ] LATENCY,
    [IPU1-0]     78.942414 s:  ********************
    [IPU1-0]     78.942536 s:  Local Link Latency     : Avg =  35909 us, Min =  31965 us, Max =  87751 us,
    [IPU1-0]     78.942810 s:  Source to Link Latency : Avg =  90213 us, Min =  83871 us, Max = 141974 us,
    [IPU1-0]     78.943054 s:
    [IPU1-0]     78.943329 s:
    [IPU1-0]     78.943451 s:  ### CPU [IPU1-0], LinkID [  0],
    [IPU1-0]     78.943664 s:
    [IPU1-0]     78.943756 s:  [ IPC_OUT_0 ] Link Statistics,
    [IPU1-0]     78.943878 s:  ******************************
    [IPU1-0]     78.944030 s:
    [IPU1-0]     78.944122 s:  Elapsed time       = 59569 msec
    [IPU1-0]     78.944274 s:
    [IPU1-0]     78.944335 s:  New data Recv      =  14.28 fps
    [IPU1-0]     78.944519 s:  Release data Recv  =  14.42 fps
    [IPU1-0]     78.944671 s:  Driver/Notify Cb   =  61.79 fps
    [IPU1-0]     78.944854 s:
    [IPU1-0]     78.944915 s:  Input Statistics,
    [IPU1-0]     78.945037 s:
    [IPU1-0]     78.945129 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     78.945312 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     78.945525 s:  --------------------------------------------------
    [IPU1-0]     78.945739 s:   0 |  14.28      0. 0      0. 0          14.28
    [IPU1-0]     78.946013 s:
    [IPU1-0]     78.946105 s:  Output Statistics,
    [IPU1-0]     78.946227 s:
    [IPU1-0]     78.946288 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     78.946471 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     78.946623 s:  ---------------------------------------------
    [IPU1-0]     78.946806 s:   0 |  0     14.28     0. 0      0. 0
    [IPU1-0]     78.947050 s:
    [IPU1-0]     78.947142 s:  [ IPC_OUT_0 ] LATENCY,
    [IPU1-0]     78.947264 s:  ********************
    [IPU1-0]     78.947386 s:  Local Link Latency     : Avg =     14 us, Min =      0 us, Max =    122 us,
    [IPU1-0]     78.947691 s:  Source to Link Latency : Avg =  90380 us, Min =  84023 us, Max = 142157 us,
    [IPU1-0]     78.947965 s:
    [IPU1-0]     79.999511 s:
    [IPU1-0]     79.999664 s:  ### CPU [  DSP1], LinkID [ 10],
    [IPU1-0]     79.999847 s:
    [IPU1-0]     79.999938 s:  [ IPC_IN_0 ] Link Statistics,
    [IPU1-0]     80.000091 s:  ******************************
    [IPU1-0]     80.000213 s:
    [IPU1-0]     80.000305 s:  Elapsed time       = 60624 msec
    [IPU1-0]     80.000457 s:
    [IPU1-0]     80.000549 s:  Get Full Buf Cb    =  28.55 fps
    [IPU1-0]     80.000701 s:  Put Empty Buf Cb   =  14.26 fps
    [IPU1-0]     80.000854 s:  Driver/Notify Cb   =  14.26 fps
    [IPU1-0]     80.001037 s:
    [IPU1-0]     80.001128 s:  Input Statistics,
    [IPU1-0]     80.001220 s:
    [IPU1-0]     80.001311 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     80.002989 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     80.003233 s:  --------------------------------------------------
    [IPU1-0]     80.003416 s:   0 |  14.28      0. 0      0. 0          14.28
    [IPU1-0]     80.003782 s:
    [IPU1-0]     80.003904 s:  Output Statistics,
    [IPU1-0]     80.003995 s:
    [IPU1-0]     80.004087 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     80.004239 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     80.004422 s:  ---------------------------------------------
    [IPU1-0]     80.004575 s:   0 |  0     14.28     0. 0      0. 0
    [IPU1-0]     80.004849 s:
    [IPU1-0]     80.004910 s:  [ IPC_IN_0 ] LATENCY,
    [IPU1-0]     80.005063 s:  ********************
    [IPU1-0]     80.005185 s:  Local Link Latency     : Avg =     29 us, Min =      0 us, Max =     61 us,
    [IPU1-0]     80.005429 s:  Source to Link Latency : Avg =  90588 us, Min =  84267 us, Max = 142432 us,
    [IPU1-0]     80.005703 s:
    [IPU1-0]     80.005978 s:
    [IPU1-0]     80.006069 s:  ### CPU [  DSP1], LinkID [ 44],
    [IPU1-0]     80.006222 s:
    [IPU1-0]     80.006283 s:  [ ALG_SYNTHESIS ] Link Statistics,
    [IPU1-0]     80.006435 s:  ******************************
    [IPU1-0]     80.006588 s:
    [IPU1-0]     80.006649 s:  Elapsed time       = 60631 msec
    [IPU1-0]     80.006801 s:
    [IPU1-0]     80.006893 s:  New data Recv      =  28.54 fps
    [IPU1-0]     80.007045 s:
    [IPU1-0]     80.007137 s:  Input Statistics,
    [IPU1-0]     80.007228 s:
    [IPU1-0]     80.007320 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     80.007472 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     80.008265 s:  --------------------------------------------------
    [IPU1-0]     80.008479 s:   0 |   0. 0      0. 0      0. 0          14.26
    [IPU1-0]     80.008753 s:
    [IPU1-0]     80.008814 s:  Output Statistics,
    [IPU1-0]     80.008936 s:
    [IPU1-0]     80.008997 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     80.009150 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     80.009302 s:  ---------------------------------------------
    [IPU1-0]     80.009455 s:   0 |  0     14.26     0. 0      0. 0
    [IPU1-0]     80.009729 s:
    [IPU1-0]     80.009790 s:  [ ALG_SYNTHESIS ] LATENCY,
    [IPU1-0]     80.010004 s:  ********************
    [IPU1-0]     80.010156 s:  Local Link Latency     : Avg =  23797 us, Min =  23546 us, Max =  27451 us,
    [IPU1-0]     80.010400 s:  Source to Link Latency : Avg = 116560 us, Min = 110010 us, Max = 171895 us,
    [IPU1-0]     80.010644 s:
    [IPU1-0]     80.010888 s:
    [IPU1-0]     80.010949 s:  ### CPU [  DSP1], LinkID [  0],
    [IPU1-0]     80.012718 s:
    [IPU1-0]     80.012871 s:  [ IPC_OUT_0 ] Link Statistics,
    [IPU1-0]     80.013023 s:  ******************************
    [IPU1-0]     80.013145 s:
    [IPU1-0]     80.013237 s:  Elapsed time       = 60607 msec
    [IPU1-0]     80.013359 s:
    [IPU1-0]     80.018452 s:  New data Recv      =  14.27 fps
    [IPU1-0]     80.018697 s:  Release data Recv  =  15.14 fps
    [IPU1-0]     80.018880 s:  Driver/Notify Cb   =  61.79 fps
    [IPU1-0]     80.019032 s:
    [IPU1-0]     80.019124 s:  Input Statistics,
    [IPU1-0]     80.019246 s:
    [IPU1-0]     80.019307 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     80.019490 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     80.019673 s:  --------------------------------------------------
    [IPU1-0]     80.019856 s:   0 |  14.27      0. 0      0. 0          14.27
    [IPU1-0]     80.020161 s:
    [IPU1-0]     80.020222 s:  Output Statistics,
    [IPU1-0]     80.020588 s:
    [IPU1-0]     80.020710 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     80.020862 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     80.021045 s:  ---------------------------------------------
    [IPU1-0]     80.021198 s:   0 |  0     14.27     0. 0      0. 0
    [IPU1-0]     80.021472 s:
    [IPU1-0]     80.021564 s:  [ IPC_OUT_0 ] LATENCY,
    [IPU1-0]     80.021686 s:  ********************
    [IPU1-0]     80.021808 s:  Local Link Latency     : Avg =      6 us, Min =      0 us, Max =     61 us,
    [IPU1-0]     80.022845 s:  Source to Link Latency : Avg = 120202 us, Min = 113639 us, Max = 175799 us,
    [IPU1-0]     80.023180 s:
    [IPU1-0]     81.075123 s:
    [IPU1-0]     81.075276 s:  ### CPU [IPU1-0], LinkID [ 10],
    [IPU1-0]     81.075459 s:
    [IPU1-0]     81.075550 s:  [ IPC_IN_0 ] Link Statistics,
    [IPU1-0]     81.075703 s:  ******************************
    [IPU1-0]     81.075825 s:
    [IPU1-0]     81.076984 s:  Elapsed time       = 61670 msec
    [IPU1-0]     81.077197 s:
    [IPU1-0]     81.077289 s:  Get Full Buf Cb    =  28.55 fps
    [IPU1-0]     81.077441 s:  Put Empty Buf Cb   =  14.25 fps
    [IPU1-0]     81.077624 s:  Driver/Notify Cb   =  14.26 fps
    [IPU1-0]     81.077777 s:
    [IPU1-0]     81.077868 s:  Input Statistics,
    [IPU1-0]     81.077990 s:
    [IPU1-0]     81.078051 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     81.078234 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     81.078448 s:  --------------------------------------------------
    [IPU1-0]     81.078661 s:   0 |  14.28      0. 0      0. 0          14.28
    [IPU1-0]     81.078966 s:
    [IPU1-0]     81.079058 s:  Output Statistics,
    [IPU1-0]     81.079149 s:
    [IPU1-0]     81.079241 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     81.079393 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     81.079576 s:  ---------------------------------------------
    [IPU1-0]     81.079729 s:   0 |  0     14.28     0. 0      0. 0
    [IPU1-0]     81.080003 s:
    [IPU1-0]     81.080095 s:  [ IPC_IN_0 ] LATENCY,
    [IPU1-0]     81.080217 s:  ********************
    [IPU1-0]     81.080339 s:  Local Link Latency     : Avg =     37 us, Min =     30 us, Max =    396 us,
    [IPU1-0]     81.080644 s:  Source to Link Latency : Avg = 120451 us, Min = 113975 us, Max = 176227 us,
    [IPU1-0]     81.080918 s:
    [IPU1-0]     81.081040 s:  CPU [  IPU1-0], LinkID [ 37], Link Statistics not available !
    [IPU1-0]     81.081284 s:  CPU [  IPU1-0], LinkID [ 25], Link Statistics not available !
    [IPU1-0]     81.081650 s:
    [IPU1-0]     81.081711 s:  ### CPU [IPU1-0], LinkID [  1],
    [IPU1-0]     81.081894 s:
    [IPU1-0]     81.081955 s:  [ IPC_OUT_1 ] Link Statistics,
    [IPU1-0]     81.082504 s:  ******************************
    [IPU1-0]     81.082779 s:
    [IPU1-0]     81.082901 s:  Elapsed time       = 61746 msec
    [IPU1-0]     81.083053 s:
    [IPU1-0]     81.083145 s:  New data Recv      =  28.50 fps
    [IPU1-0]     81.083663 s:  Release data Recv  =  71.89 fps
    [IPU1-0]     81.083877 s:  Driver/Notify Cb   = 118.93 fps
    [IPU1-0]     81.084029 s:
    [IPU1-0]     81.084121 s:  Input Statistics,
    [IPU1-0]     81.084243 s:
    [IPU1-0]     81.084304 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     81.084487 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     81.085402 s:  --------------------------------------------------
    [IPU1-0]     81.088177 s:   0 |  14.26      0. 0      0. 0          14.26
    [IPU1-0]     81.088574 s:   1 |  14.28      0. 0      0. 0          14.28
    [IPU1-0]     81.088879 s:   2 |  14.28      0. 0      0. 0          14.28
    [IPU1-0]     81.089763 s:   3 |  14.28      0. 0      0. 0          14.28
    [IPU1-0]     81.090160 s:   4 |  14.28      0. 0      0. 0          14.28
    [IPU1-0]     81.090465 s:
    [IPU1-0]     81.090556 s:  Output Statistics,
    [IPU1-0]     81.091166 s:
    [IPU1-0]     81.091288 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     81.091471 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     81.091654 s:  ---------------------------------------------
    [IPU1-0]     81.092264 s:   0 |  0     14.26     0. 0      0. 0
    [IPU1-0]     81.092569 s:   1 |  0     14.28     0. 0      0. 0
    [IPU1-0]     81.092844 s:   2 |  0     14.28     0. 0      0. 0
    [IPU1-0]     81.093119 s:   3 |  0     14.28     0. 0      0. 0
    [IPU1-0]     81.093485 s:   4 |  0     14.28     0. 0      0. 0
    [IPU1-0]     81.093790 s:
    [IPU1-0]     81.093881 s:  [ IPC_OUT_1 ] LATENCY,
    [IPU1-0]     81.094034 s:  ********************
    [IPU1-0]     81.094156 s:  Local Link Latency     : Avg =     12 us, Min =      0 us, Max =    244 us,
    [IPU1-0]     81.094430 s:  Source to Link Latency : Avg =  63877 us, Min =  48954 us, Max = 176776 us,
    [IPU1-0]     81.095467 s:
    [IPU1-0]     82.147349 s:
    [IPU1-0]     82.147532 s:  ### CPU [IPU1-1], LinkID [ 10],
    [IPU1-0]     82.147715 s:
    [IPU1-0]     82.147806 s:  [ IPC_IN_0 ] Link Statistics,
    [IPU1-0]     82.147959 s:  ******************************
    [IPU1-0]     82.148111 s:
    [IPU1-0]     82.148203 s:  Elapsed time       = 62812 msec
    [IPU1-0]     82.148356 s:
    [IPU1-0]     82.148447 s:  Get Full Buf Cb    =  27.14 fps
    [IPU1-0]     82.148630 s:  Put Empty Buf Cb   =  71.38 fps
    [IPU1-0]     82.148783 s:  Driver/Notify Cb   =  28.48 fps
    [IPU1-0]     82.148966 s:
    [IPU1-0]     82.151101 s:  Input Statistics,
    [IPU1-0]     82.151497 s:
    [IPU1-0]     82.151619 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     82.151833 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     82.152016 s:  --------------------------------------------------
    [IPU1-0]     82.152199 s:   0 |  14.26      0. 0      0. 0          14.26
    [IPU1-0]     82.152931 s:   1 |  14.28      0. 0      0. 0          14.28
    [IPU1-0]     82.153388 s:   2 |  14.28      0. 0      0. 0          14.28
    [IPU1-0]     82.153724 s:   3 |  14.28      0. 0      0. 0          14.28
    [IPU1-0]     82.154029 s:   4 |  14.28      0. 0      0. 0          14.28
    [IPU1-0]     82.154334 s:
    [IPU1-0]     82.154425 s:  Output Statistics,
    [IPU1-0]     82.155279 s:
    [IPU1-0]     82.155493 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     82.155676 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     82.155828 s:  ---------------------------------------------
    [IPU1-0]     82.155981 s:   0 |  0     14.26     0. 0      0. 0
    [IPU1-0]     82.156255 s:   1 |  0     14.28     0. 0      0. 0
    [IPU1-0]     82.156499 s:   2 |  0     14.28     0. 0      0. 0
    [IPU1-0]     82.156743 s:   3 |  0     14.28     0. 0      0. 0
    [IPU1-0]     82.157018 s:   4 |  0     14.28     0. 0      0. 0
    [IPU1-0]     82.157262 s:
    [IPU1-0]     82.157353 s:  [ IPC_IN_0 ] LATENCY,
    [IPU1-0]     82.157475 s:  ********************
    [IPU1-0]     82.157628 s:  Local Link Latency     : Avg =     35 us, Min =      0 us, Max =    183 us,
    [IPU1-0]     82.157933 s:  Source to Link Latency : Avg =  64499 us, Min =  49625 us, Max = 177477 us,
    [IPU1-0]     82.158177 s:
    [IPU1-0]     82.158299 s:  CPU [  IPU1-1], LinkID [ 20], Link Statistics not available !
    [IPU1-0]     83.209510 s:
    [IPU1-0]     83.209662 s:  ### CPU [IPU1-0], LinkID [ 62],
    [IPU1-0]     83.209845 s:
    [IPU1-0]     83.209937 s:  [ DISPLAY ] Link Statistics,
    [IPU1-0]     83.210089 s:  ******************************
    [IPU1-0]     83.210211 s:
    [IPU1-0]     83.210303 s:  Elapsed time       = 63874 msec
    [IPU1-0]     83.210455 s:
    [IPU1-0]     83.210516 s:  New data Recv      =  26.14 fps
    [IPU1-0]     83.210699 s:  Driver/Notify Cb   =  28.47 fps
    [IPU1-0]     83.210852 s:
    [IPU1-0]     83.210943 s:  Input Statistics,
    [IPU1-0]     83.211065 s:
    [IPU1-0]     83.211157 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     83.211340 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     83.211553 s:  --------------------------------------------------
    [IPU1-0]     83.211736 s:   0 |  14.26      0. 0      0. 0          14.26
    [IPU1-0]     83.212041 s:   1 |  14.27     14.27      0. 0           0. 0
    [IPU1-0]     83.212346 s:   2 |  14.27     14.27      0. 0           0. 0
    [IPU1-0]     83.212621 s:   3 |  14.27     14.27      0. 0           0. 0
    [IPU1-0]     83.212926 s:   4 |  14.27     14.27      0. 0           0. 0
    [IPU1-0]     83.214847 s:
    [IPU1-0]     83.215000 s:  [ DISPLAY ] LATENCY,
    [IPU1-0]     83.215152 s:  ********************
    [IPU1-0]     83.215274 s:  Local Link Latency     : Avg =    235 us, Min =     61 us, Max =   2410 us,
    [IPU1-0]     83.215518 s:  Source to Link Latency : Avg = 121437 us, Min = 114646 us, Max = 179429 us,
    [IPU1-0]     83.215945 s:
    [IPU1-0]     84.267644 s:
    [IPU1-0]     84.267827 s:  ### CPU [  DSP1], LinkID [ 45],
    [IPU1-0]     84.267980 s:
    [IPU1-0]     84.268071 s:  [ ALG_PALIGN ] Link Statistics,
    [IPU1-0]     84.268224 s:  ******************************
    [IPU1-0]     84.268376 s:
    [IPU1-0]     84.268468 s:  Elapsed time       = 64866 msec
    [IPU1-0]     84.268620 s:
    [IPU1-0]     84.268712 s:  New data Recv      =  14.27 fps
    [IPU1-0]     84.268864 s:
    [IPU1-0]     84.268956 s:  Input Statistics,
    [IPU1-0]     84.269078 s:
    [IPU1-0]     84.269169 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     84.269322 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     84.269535 s:  --------------------------------------------------
    [IPU1-0]     84.269749 s:   0 |   0. 0      0. 0      0. 0          14.27
    [IPU1-0]     84.270023 s:
    [IPU1-0]     84.270115 s:  Output Statistics,
    [IPU1-0]     84.270237 s:
    [IPU1-0]     84.270328 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     84.270481 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     84.270633 s:  ---------------------------------------------
    [IPU1-0]     84.270816 s:   0 |  0     14.27     0. 0      0. 0
    [IPU1-0]     84.271091 s:
    [IPU1-0]     84.271152 s:  [ ALG_PALIGN ] LATENCY,
    [IPU1-0]     84.271304 s:  ********************
    [IPU1-0]     84.271426 s:  Local Link Latency     : Avg =   3222 us, Min =   3172 us, Max =   3446 us,
    [IPU1-0]     84.271731 s:  Source to Link Latency : Avg = 119755 us, Min = 113456 us, Max = 175525 us,
    [IPU1-0]     84.272006 s:
    [IPU1-0]     85.323339 s:  CPU [  IPU1-1], LinkID [ 56], Link Statistics not available !
    [IPU1-0]     86.375099 s:  CPU [  IPU1-0], LinkID [ 22], Link Statistics not available !
    [IPU1-0]     86.375556 s:
    [IPU1-0]     86.375617 s:  ### CPU [IPU1-0], LinkID [ 63],
    [IPU1-0]     86.375800 s:
    [IPU1-0]     86.375892 s:  [ DISPLAY ] Link Statistics,
    [IPU1-0]     86.376044 s:  ******************************
    [IPU1-0]     86.376166 s:
    [IPU1-0]     86.376227 s:  Elapsed time       = 52511 msec
    [IPU1-0]     86.376410 s:
    [IPU1-0]     86.376502 s:  Driver/Notify Cb   =  28.50 fps
    [IPU1-0]     86.376654 s:
    [IPU1-0]     86.376746 s:  Input Statistics,
    [IPU1-0]     86.376868 s:
    [IPU1-0]     86.376959 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     86.377112 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     86.377325 s:  --------------------------------------------------
    [IPU1-0]     86.377539 s:   0 |   0. 1      0. 0      0. 0           0. 1
    [IPU1-0]     86.377813 s:
    [IPU1-0]     86.377905 s:  [ DISPLAY ] LATENCY,
    [IPU1-0]     86.378027 s:  ********************
    [IPU1-0]     86.378149 s:  Local Link Latency     : Avg =     91 us, Min =     91 us, Max =     91 us,
    [IPU1-0]     86.378393 s:  Source to Link Latency : Avg =  21900 us, Min =  21900 us, Max =  21900 us,
    [IPU1-0]     79.110687 s:  CPU [IPU1-0 ] Statistics,
    [IPU1-0]     79.110870 s:  *************************
    [IPU1-0]     79.111022 s:
    [IPU1-0]     79.111175 s:  LOAD: CPU: 64.4% HWI: 8.7%, SWI:1.0%, Low Power: 188.8%
    [IPU1-0]     79.111724 s:
    [IPU1-0]     79.111846 s:  LOAD: TSK: SYSTEM              : 0.4%
    [IPU1-0]     79.112090 s:  LOAD: TSK: ISSCAPTURE          : 0.4%
    [IPU1-0]     79.112365 s:  LOAD: TSK: ISSM2MISP           : 6.9%
    [IPU1-0]     79.114622 s:  LOAD: TSK: DUP0                : 0.3%
    [IPU1-0]     79.114957 s:  LOAD: TSK: DUP1                : 0.4%
    [IPU1-0]     79.115232 s:  LOAD: TSK: MERGE0              : 0.2%
    [IPU1-0]     79.115506 s:  LOAD: TSK: SYNC0               : 0.6%
    [IPU1-0]     79.115781 s:  LOAD: TSK: IPC_OUT_0           : 0.5%
    [IPU1-0]     79.115994 s:  LOAD: TSK: IPC_OUT_1           : 1.4%
    [IPU1-0]     79.116299 s:  LOAD: TSK: IPC_IN_0            : 0.3%
    [IPU1-0]     79.116635 s:  LOAD: TSK: DISPLAY0            : 0.8%
    [IPU1-0]     79.116909 s:  LOAD: TSK: ALGORITHM0          : 5.4%
    [IPU1-0]     79.117184 s:  LOAD: TSK: ALGORITHM1          : 7.8%
    [IPU1-0]     79.117519 s:  LOAD: TSK: GrpxSrc0            : 18.1%
    [IPU1-0]     79.117763 s:  LOAD: TSK: STAT_COLL           : 2.3%
    [IPU1-0]     79.118038 s:  LOAD: TSK: 3D_SRV_MEDIA_TSK    : 7.6%
    [IPU1-0]     79.118312 s:  LOAD: TSK: MISC                : 1.3%
    [IPU1-0]     79.118526 s:
    [IPU1-0]     79.118648 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1019
    [IPU1-0]     79.118892 s:
    [IPU1-0]     79.119014 s:  SYSTEM: Sempahores Objects,  157 of 1000 free
    [IPU1-0]     79.119319 s:  SYSTEM: Task Objects      ,   21 of  100 free
    [IPU1-0]     79.119593 s:  SYSTEM: Clock Objects     ,   93 of  100 free
    [IPU1-0]     79.119807 s:  SYSTEM: Hwi Objects       ,   87 of  100 free
    [IPU1-0]     79.120051 s:
    [IPU1-0]     79.120173 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 151256 B (147 KB)
    [IPU1-0]     79.120600 s:  SYSTEM: Heap = SR_OCMC              @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
    [IPU1-0]     79.121027 s:  SYSTEM: Heap = SR_DDR_CACHED        @ 0x85483000, Total size = 367001600 B (350 MB), Free size = 230517248 B (219 MB)
    [IPU1-0]     79.121484 s:  SYSTEM: Heap = SR_DDR_NON_CACHED    @ 0xbfe00000, Total size = 1046784 B (0 MB), Free size = 1039104 B (0 MB)
    [IPU1-0]     79.122003 s:
    [IPU1-0]     79.122155 s:
    [IPU1-0]     79.122247 s:  CPU [IPU1-1 ] Statistics,
    [IPU1-0]     79.122430 s:  *************************
    [IPU1-0]     79.122582 s:
    [IPU1-0]     79.122704 s:  LOAD: CPU: 4.9% HWI: 1.6%, SWI:0.7%, Low Power: 190.5%
    [IPU1-0]     79.123101 s:
    [IPU1-0]     79.123284 s:  LOAD: TSK: NULL0               : 0.6%
    [IPU1-0]     79.123711 s:  LOAD: TSK: IPC_IN_0            : 1.1%
    [IPU1-0]     79.124168 s:  LOAD: TSK: MISC                : 0.9%
    [IPU1-0]     79.124473 s:
    [IPU1-0]     79.124595 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1019
    [IPU1-0]     79.124809 s:
    [IPU1-0]     79.124931 s:  SYSTEM: Sempahores Objects,  431 of 1000 free
    [IPU1-0]     79.125144 s:  SYSTEM: Task Objects      ,   41 of  100 free
    [IPU1-0]     79.125388 s:  SYSTEM: Clock Objects     ,   99 of  100 free
    [IPU1-0]     79.125632 s:  SYSTEM: Hwi Objects       ,   99 of  100 free
    [IPU1-0]     79.125846 s:
    [IPU1-0]     79.125968 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 241888 B (236 KB)
    [IPU1-0]     79.126395 s:
    [IPU1-0]     79.126517 s:
    [IPU1-0]     79.126608 s:  CPU [DSP1   ] Statistics,
    [IPU1-0]     79.126761 s:  *************************
    [IPU1-0]     79.126913 s:
    [IPU1-0]     79.127432 s:  LOAD: CPU: 42.8% HWI: 0.3%, SWI:0.1%, Low Power: 217.2%
    [IPU1-0]     79.129353 s:
    [IPU1-0]     79.129536 s:  LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 42.1%
    [IPU1-0]     79.129964 s:  LOAD: TSK: MISC                : 0.3%
    [IPU1-0]     79.130208 s:
    [IPU1-0]     79.130330 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1019
    [IPU1-0]     79.130574 s:
    [IPU1-0]     79.130696 s:  SYSTEM: Sempahores Objects,  444 of 1000 free
    [IPU1-0]     79.130909 s:  SYSTEM: Task Objects      ,   92 of  100 free
    [IPU1-0]     79.131153 s:  SYSTEM: Clock Objects     ,   98 of  100 free
    [IPU1-0]     79.131397 s:  SYSTEM: Hwi Objects       ,  100 of  100 free
    [IPU1-0]     79.131641 s:
    [IPU1-0]     79.131763 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 96192 B (93 KB)
    [IPU1-0]     79.132190 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 519424 B (507 KB)
    [IPU1-0]     79.132709 s:
    [IPU1-0]     79.132831 s:
    [IPU1-0]     79.132922 s:  CPU [DSP2   ] Statistics,
    [IPU1-0]     79.133105 s:  *************************
    [IPU1-0]     79.133258 s:
    [IPU1-0]     79.133380 s:  LOAD: CPU: 0.3% HWI: 0.1%, SWI:0.0%, Low Power: 259.5%
    [IPU1-0]     79.133807 s:
    [IPU1-0]     79.133959 s:  LOAD: TSK: MISC                : 0.2%
    [IPU1-0]     79.134173 s:
    [IPU1-0]     79.134295 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1019
    [IPU1-0]     79.134508 s:
    [IPU1-0]     79.134630 s:  SYSTEM: Sempahores Objects,  446 of 1000 free
    [IPU1-0]     79.134844 s:  SYSTEM: Task Objects      ,   92 of  100 free
    [IPU1-0]     79.135149 s:  SYSTEM: Clock Objects     ,   99 of  100 free
    [IPU1-0]     79.135393 s:  SYSTEM: Hwi Objects       ,  100 of  100 free
    [IPU1-0]     79.135606 s:
    [IPU1-0]     79.135728 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
    [IPU1-0]     79.136155 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 519424 B (507 KB)
    [IPU1-0]     79.136582 s:
    [IPU1-0]     79.136704 s:
    [IPU1-0]     79.136796 s:  CPU [EVE1   ] Statistics,
    [IPU1-0]     79.136948 s:  *************************
    [IPU1-0]     79.137406 s:
    [IPU1-0]     79.137589 s:  LOAD: CPU: 0.9% HWI: 0.2%, SWI:0.2%, Low Power: 247.3%
    [IPU1-0]     79.138016 s:
    [IPU1-0]     79.138107 s:  LOAD: TSK: SYSTEM              : 0.3%
    [IPU1-0]     79.138382 s:  LOAD: TSK: MISC                : 0.2%
    [IPU1-0]     79.138595 s:
    [IPU1-0]     79.138687 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1019
    [IPU1-0]     79.138931 s:
    [IPU1-0]     79.139022 s:  SYSTEM: Sempahores Objects,  487 of 1000 free
    [IPU1-0]     79.139266 s:  SYSTEM: Task Objects      ,   97 of  100 free
    [IPU1-0]     79.139480 s:  SYSTEM: Clock Objects     ,   99 of  100 free
    [IPU1-0]     79.139724 s:  SYSTEM: Hwi Objects       ,   99 of  100 free
    [IPU1-0]     79.139937 s:
    [IPU1-0]     79.140059 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 24576 B (24 KB), Free size = 24576 B (24 KB)
    [IPU1-0]     79.140852 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 257448 B (251 KB)
    [IPU1-0]     79.141310 s:
    [IPU1-0]     79.149911 s:
    [IPU1-0]     79.150094 s:  UTILS_PRCM_STATS:  Current Temperature,
    [IPU1-0]     79.150277 s:
    [IPU1-0]     79.150369 s:   Voltage Rail         ||   Curr Temp Min - Max
    [IPU1-0]     79.150582 s:  ---------------------------------------------------------
    [IPU1-0]     79.151192 s:     PMHAL_PRCM_VD_CORE ||     [58.800 , 59.200]
    [IPU1-0]     79.151528 s:
    [IPU1-0]     79.151741 s:
    [IPU1-0]     79.151863 s:  Statistics Collector,
    [IPU1-0]     79.152504 s:
    [IPU1-0]     79.152626 s:        STATISTIC          Avg Data        Peak Data
    [IPU1-0]     79.153053 s:        COLLECTOR          MB/s            MB/s
    [IPU1-0]     79.154578 s:  --------------------------------------------------
    [IPU1-0]     79.155432 s:  SCI_EMIF_SYS         |    667.753002    946.291685
    [IPU1-0]     79.155767 s:  SCI_IPU              |     15.410746     62.156309
    [IPU1-0]     79.156957 s:  SCI_DSP1_MDMA        |      3.784078     19.545611
    [IPU1-0]     79.157323 s:  SCI_DSP2_MDMA        |      0.014896      0.096904
    [IPU1-0]     79.157628 s:  SCI_DSS              |    122.255029    138.304153
    [IPU1-0]     79.159366 s:  SCI_MMU              |      0.000000      0.000000
    [IPU1-0]     79.159732 s:  SCI_EDMA_TC0_RD      |      0.000000      0.000000
    [IPU1-0]     79.160007 s:  SCI_EDMA_TC0_WR      |      0.000000      0.000000
    [IPU1-0]     79.160525 s:  SCI_VIP_P1           |      0.000000      0.000000
    [IPU1-0]     79.160800 s:  SCI_VIP_P2           |      0.000000      0.000000
    [IPU1-0]     79.161105 s:  SCI_ISS_RT           |     83.888082    113.604712
    [IPU1-0]     79.162538 s:  SCI_ISS_NRT2         |    170.176952    304.803600
    [IPU1-0]     79.162935 s:  SCI_EVE_P1           |      1.246533      2.959434
    [IPU1-0]     79.163209 s:  SCI_EVE_P2           |      0.000000      0.000000
    [IPU1-0]     79.163514 s:  SCI_GMAC_SW          |      0.000000      0.000000
    [IPU1-0]     79.163789 s:  SCI_ISS_NRT1         |    193.402757    531.314940
    [IPU1-0]     79.164216 s:  SCI_DSP2_CFG         |      0.000000      0.000000
    [IPU1-0]     79.164521 s:  SCI_DSP2_EDMA        |      0.000000      0.000000
    [IPU1-0]     79.164795 s:  SCI_OCMC_RAM         |     13.727582     34.790473
    [IPU1-0]     79.165070 s:  SCI_DSP1_CFG         |      0.000000      0.000000
    [IPU1-0]     79.165375 s:  SCI_DSP1_EDMA        |     77.319500    259.540983
    [IPU1-0]     79.166229 s:  SCI_GPMC             |      0.000000      0.000000
    [IPU1-0]     79.167022 s:  SCI_MCASP            |      0.000000      0.000000
    [IPU1-0]     79.168425 s:  SCI_EDMA_TC1_RD      |      6.998119     49.862035
    [IPU1-0]     79.168791 s:  SCI_EDMA_TC1_WR      |      6.998119     49.862035
    [IPU1-0]     79.435063 s:
    [IPU1-0]     79.435307 s:  ### CPU [IPU1-0], LinkID [ 72],
    [IPU1-0]     79.435521 s:
    [IPU1-0]     79.435643 s:  [ ISSCAPTURE ] Link Statistics,
    [IPU1-0]     79.436466 s:  ******************************
    [IPU1-0]     79.436710 s:
    [IPU1-0]     79.436832 s:  Elapsed time       = 55106 msec
    [IPU1-0]     79.437046 s:
    [IPU1-0]     79.437168 s:  Get Full Buf Cb    =  45.67 fps
    [IPU1-0]     79.438022 s:  Put Empty Buf Cb   =  11.41 fps
    [IPU1-0]     79.438327 s:  Driver/Notify Cb   =  45.65 fps
    [IPU1-0]     79.438571 s:
    [IPU1-0]     79.438693 s:  Input Statistics,
    [IPU1-0]     79.439333 s:
    [IPU1-0]     79.439486 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     79.439730 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     79.440309 s:  --------------------------------------------------
    [IPU1-0]     79.440614 s:   0 |  11.41      0. 0      0. 0          11.41
    [IPU1-0]     79.440980 s:   1 |  11.41      0. 0      0. 0          11.41
    [IPU1-0]     79.441377 s:   2 |  11.41      0. 0      0. 0          11.41
    [IPU1-0]     79.441773 s:   3 |  11.41      0. 0      0. 0          11.41
    [IPU1-0]     79.442170 s:
    [IPU1-0]     79.442261 s:  Output Statistics,
    [IPU1-0]     79.442414 s:
    [IPU1-0]     79.443054 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     79.443329 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     79.443573 s:  ---------------------------------------------
    [IPU1-0]     79.443817 s:   0 |  0     11.43     0. 0      0. 0
    [IPU1-0]     79.444183 s:   1 |  0     11.43     0. 0      0. 0
    [IPU1-0]     79.444732 s:   2 |  0     11.43     0. 0      0. 0
    [IPU1-0]     79.445098 s:   3 |  0     11.43     0. 0      0. 0
    [IPU1-0]     79.445556 s:
    [IPU1-0]     79.445678 s:  [ ISSCAPTURE ] LATENCY,
    [IPU1-0]     79.445891 s:  ********************
    [IPU1-0]     79.446044 s:
    [IPU1-0]     79.446440 s:
    [IPU1-0]     79.446562 s:  ### CPU [IPU1-0], LinkID [ 73],
    [IPU1-0]     79.446776 s:
    [IPU1-0]     79.446898 s:  [ ISSM2MISP ] Link Statistics,
    [IPU1-0]     79.447111 s:  ******************************
    [IPU1-0]     79.447294 s:
    [IPU1-0]     79.447416 s:  Elapsed time       = 55116 msec
    [IPU1-0]     79.447599 s:
    [IPU1-0]     79.447721 s:  New data Recv      =  45.66 fps
    [IPU1-0]     79.449978 s:  Get Full Buf Cb    =  22.57 fps
    [IPU1-0]     79.450344 s:  Driver/Notify Cb   =  45.64 fps
    [IPU1-0]     79.450741 s:
    [IPU1-0]     79.450924 s:  Input Statistics,
    [IPU1-0]     79.451076 s:
    [IPU1-0]     79.451198 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     79.451991 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     79.452296 s:  --------------------------------------------------
    [IPU1-0]     79.452540 s:   0 |  11.43      0. 0      0. 0          11.41
    [IPU1-0]     79.452937 s:   1 |  11.41      0. 0      0. 0          11.41
    [IPU1-0]     79.453455 s:   2 |  11.41      0. 0      0. 0          11.41
    [IPU1-0]     79.453882 s:   3 |  11.41      0. 0      0. 0          11.41
    [IPU1-0]     79.455163 s:
    [IPU1-0]     79.455316 s:  Output Statistics,
    [IPU1-0]     79.455468 s:
    [IPU1-0]     79.455560 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     79.456200 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     79.456444 s:  ---------------------------------------------
    [IPU1-0]     79.456627 s:   0 |  0     11.41     0. 0      0. 0
    [IPU1-0]     79.456963 s:   0 |  1     11.41     0. 0      0. 0
    [IPU1-0]     79.457268 s:   0 |  2      0. 0    11.41      0. 0
    [IPU1-0]     79.457603 s:   0 |  3      0. 0    11.41      0. 0
    [IPU1-0]     79.457908 s:   1 |  0     11.41     0. 0      0. 0
    [IPU1-0]     79.458244 s:   1 |  1     11.41     0. 0      0. 0
    [IPU1-0]     79.458640 s:   1 |  2      0. 0    11.41      0. 0
    [IPU1-0]     79.458976 s:   1 |  3      0. 0    11.41      0. 0
    [IPU1-0]     79.459311 s:   2 |  0     11.41     0. 0      0. 0
    [IPU1-0]     79.459647 s:   2 |  1     11.41     0. 0      0. 0
    [IPU1-0]     79.459952 s:   2 |  2      0. 0    11.41      0. 0
    [IPU1-0]     79.460287 s:   2 |  3      0. 0    11.41      0. 0
    [IPU1-0]     79.460623 s:   3 |  0     11.41     0. 0      0. 0
    [IPU1-0]     79.460958 s:   3 |  1     11.41     0. 0      0. 0
    [IPU1-0]     79.461355 s:   3 |  2      0. 0    11.41      0. 0
    [IPU1-0]     79.461690 s:   3 |  3      0. 0    11.41      0. 0
    [IPU1-0]     79.462026 s:
    [IPU1-0]     79.462117 s:  [ ISSM2MISP ] LATENCY,
    [IPU1-0]     79.462300 s:  ********************
    [IPU1-0]     79.462422 s:  Local Link Latency     : Avg =  14961 us, Min =  14640 us, Max =  19154 us,
    [IPU1-0]     79.462758 s:  Source to Link Latency : Avg =  37937 us, Min =  15036 us, Max =  76404 us,
    [IPU1-0]     79.464771 s:
    [IPU1-0]     79.465168 s:
    [IPU1-0]     79.465259 s:  ### CPU [IPU1-0], LinkID [ 45],
    [IPU1-0]     79.465473 s:
    [IPU1-0]     79.465595 s:  [ ALG_ISS_AEWB ] Link Statistics,
    [IPU1-0]     79.465808 s:  ******************************
    [IPU1-0]     79.465961 s:
    [IPU1-0]     79.466083 s:  Elapsed time       = 55057 msec
    [IPU1-0]     79.466388 s:
    [IPU1-0]     79.466510 s:  New data Recv      =  11.17 fps
    [IPU1-0]     79.466754 s:
    [IPU1-0]     79.466845 s:  Input Statistics,
    [IPU1-0]     79.466998 s:
    [IPU1-0]     79.467089 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     79.467333 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     79.467547 s:  --------------------------------------------------
    [IPU1-0]     79.467760 s:   0 |  11.42      0. 0      0. 0          11.42
    [IPU1-0]     79.468126 s:
    [IPU1-0]     79.468248 s:  Output Statistics,
    [IPU1-0]     79.468370 s:
    [IPU1-0]     79.468492 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     79.468706 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     79.469346 s:  ---------------------------------------------
    [IPU1-0]     79.469590 s:   0 |  0     11.42     0. 0      0. 0
    [IPU1-0]     79.469926 s:
    [IPU1-0]     79.470017 s:  [ ALG_ISS_AEWB ] LATENCY,
    [IPU1-0]     79.470200 s:  ********************
    [IPU1-0]     79.470353 s:  Local Link Latency     : Avg =  21075 us, Min =    396 us, Max = 193009 us,
    [IPU1-0]     79.470658 s:  Source to Link Latency : Avg =  90935 us, Min =  64540 us, Max = 257793 us,
    [IPU1-0]     79.470993 s:
    [IPU1-0]     79.471146 s:  CPU [  IPU1-0], LinkID [ 24], Link Statistics not available !
    [IPU1-0]     79.471664 s:
    [IPU1-0]     79.471786 s:  ### CPU [IPU1-0], LinkID [ 52],
    [IPU1-0]     79.472000 s:
    [IPU1-0]     79.472091 s:  [ NULL_SRC ] Link Statistics,
    [IPU1-0]     79.472274 s:  ******************************
    [IPU1-0]     79.472427 s:
    [IPU1-0]     79.472549 s:  Elapsed time       = 61084 msec
    [IPU1-0]     79.472732 s:
    [IPU1-0]     79.472854 s:
    [IPU1-0]     79.472945 s:  Input Statistics,
    [IPU1-0]     79.473098 s:
    [IPU1-0]     79.473189 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     79.473403 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     79.473616 s:  --------------------------------------------------
    [IPU1-0]     79.473830 s:
    [IPU1-0]     79.473952 s:  Output Statistics,
    [IPU1-0]     79.474196 s:
    [IPU1-0]     79.474592 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     79.474806 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     79.474989 s:  ---------------------------------------------
    [IPU1-0]     79.475202 s:
    [IPU1-0]     79.475324 s:  [ NULL_SRC ] LATENCY,
    [IPU1-0]     79.475477 s:  ********************
    [IPU1-0]     79.475629 s:
    [IPU1-0]     79.475904 s:
    [IPU1-0]     79.476026 s:  ### CPU [IPU1-0], LinkID [  2],
    [IPU1-0]     79.476209 s:
    [IPU1-0]     79.476331 s:  [ IPC_OUT_2 ] Link Statistics,
    [IPU1-0]     79.476514 s:  ******************************
    [IPU1-0]     79.476666 s:
    [IPU1-0]     79.476849 s:  Elapsed time       = 61088 msec
    [IPU1-0]     79.477063 s:
    [IPU1-0]     79.477154 s:  Driver/Notify Cb   =  34.42 fps
    [IPU1-0]     79.477368 s:
    [IPU1-0]     79.477459 s:  Input Statistics,
    [IPU1-0]     79.477612 s:
    [IPU1-0]     79.477703 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     79.477917 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     79.479777 s:  --------------------------------------------------
    [IPU1-0]     79.480113 s:
    [IPU1-0]     79.480204 s:  Output Statistics,
    [IPU1-0]     79.480357 s:
    [IPU1-0]     79.480448 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     79.480662 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     79.480875 s:  ---------------------------------------------
    [IPU1-0]     79.481089 s:
    [IPU1-0]     79.481211 s:  [ IPC_OUT_2 ] LATENCY,
    [IPU1-0]     79.481363 s:  ********************
    [IPU1-0]     79.481516 s:
    [IPU1-0]     80.794576 s:
    [IPU1-0]     80.794790 s:  ### CPU [  DSP1], LinkID [ 11],
    [IPU1-0]     80.795003 s:
    [IPU1-0]     80.795125 s:  [ IPC_IN_1 ] Link Statistics,
    [IPU1-0]     80.795308 s:  ******************************
    [IPU1-0]     80.795461 s:
    [IPU1-0]     80.795583 s:  Elapsed time       = 62405 msec
    [IPU1-0]     80.795766 s:
    [IPU1-0]     80.795857 s:
    [IPU1-0]     80.795979 s:  Input Statistics,
    [IPU1-0]     80.796132 s:
    [IPU1-0]     80.796223 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     80.796437 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     80.796651 s:  --------------------------------------------------
    [IPU1-0]     80.797291 s:
    [IPU1-0]     80.797444 s:  Output Statistics,
    [IPU1-0]     80.797596 s:
    [IPU1-0]     80.797688 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     80.797901 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     80.798084 s:  ---------------------------------------------
    [IPU1-0]     80.798328 s:
    [IPU1-0]     80.798450 s:  [ IPC_IN_1 ] LATENCY,
    [IPU1-0]     80.798603 s:  ********************
    [IPU1-0]     80.798755 s:
    [IPU1-0]     82.111663 s:
    [IPU1-0]     82.111846 s:  ### CPU [IPU1-0], LinkID [ 33],
    [IPU1-0]     82.112060 s:
    [IPU1-0]     82.112151 s:  [ SYNC_0 ] Link Statistics,
    [IPU1-0]     82.112334 s:  ******************************
    [IPU1-0]     82.112517 s:
    [IPU1-0]     82.112639 s:  Elapsed time       = 57858 msec
    [IPU1-0]     82.112822 s:
    [IPU1-0]     82.112944 s:  New data Recv      =  22.88 fps
    [IPU1-0]     82.113127 s:  Get Full Buf Cb    =  11.38 fps
    [IPU1-0]     82.113341 s:  Put Empty Buf Cb   =  11.38 fps
    [IPU1-0]     82.113554 s:  Driver/Notify Cb   =  11.51 fps
    [IPU1-0]     82.113737 s:
    [IPU1-0]     82.113859 s:  Input Statistics,
    [IPU1-0]     82.113981 s:
    [IPU1-0]     82.114500 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     82.114744 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     82.114957 s:  --------------------------------------------------
    [IPU1-0]     82.115140 s:   0 |  11.38      0. 0      0. 0          11.38
    [IPU1-0]     82.115659 s:   1 |  11.38      0. 0      0. 0          11.38
    [IPU1-0]     82.116299 s:   2 |  11.38      0. 0      0. 0          11.38
    [IPU1-0]     82.116757 s:   3 |  11.38      0. 0      0. 0          11.38
    [IPU1-0]     82.117153 s:
    [IPU1-0]     82.117245 s:  Output Statistics,
    [IPU1-0]     82.117397 s:
    [IPU1-0]     82.117489 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     82.117702 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     82.117885 s:  ---------------------------------------------
    [IPU1-0]     82.118099 s:   0 |  0     11.38     0. 0      0. 0
    [IPU1-0]     82.118404 s:
    [IPU1-0]     82.118495 s:  [ SYNC_0 ] LATENCY,
    [IPU1-0]     82.118648 s:  ********************
    [IPU1-0]     82.118800 s:  Local Link Latency     : Avg =    160 us, Min =     91 us, Max =    610 us,
    [IPU1-0]     82.119105 s:  Source to Link Latency : Avg =  61389 us, Min =  60522 us, Max =  77320 us,
    [IPU1-0]     82.119502 s:
    [IPU1-0]     82.119807 s:
    [IPU1-0]     82.119898 s:  ### CPU [IPU1-0], LinkID [ 44],
    [IPU1-0]     82.120112 s:
    [IPU1-0]     82.128469 s:  [ ALG_DEWARP ] Link Statistics,
    [IPU1-0]     82.128743 s:  ******************************
    [IPU1-0]     82.128926 s:
    [IPU1-0]     82.129048 s:  Elapsed time       = 57712 msec
    [IPU1-0]     82.129231 s:
    [IPU1-0]     82.129323 s:  New data Recv      =  11.41 fps
    [IPU1-0]     82.129536 s:
    [IPU1-0]     82.129659 s:  Input Statistics,
    [IPU1-0]     82.130116 s:
    [IPU1-0]     82.130269 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     82.130482 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     82.130696 s:  --------------------------------------------------
    [IPU1-0]     82.130940 s:   0 |  11.41      0. 0      0. 0          11.41
    [IPU1-0]     82.131306 s:
    [IPU1-0]     82.131397 s:  Output Statistics,
    [IPU1-0]     82.131550 s:
    [IPU1-0]     82.131641 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     82.131855 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     82.132068 s:  ---------------------------------------------
    [IPU1-0]     82.132282 s:   0 |  0     11.41     0. 0      0. 0
    [IPU1-0]     82.133227 s:
    [IPU1-0]     82.133380 s:  [ ALG_DEWARP ] LATENCY,
    [IPU1-0]     82.133563 s:  ********************
    [IPU1-0]     82.133715 s:  Local Link Latency     : Avg =  46452 us, Min =  40353 us, Max = 106661 us,
    [IPU1-0]     82.134081 s:  Source to Link Latency : Avg = 114992 us, Min = 106349 us, Max = 173581 us,
    [IPU1-0]     82.134417 s:
    [IPU1-0]     82.135240 s:
    [IPU1-0]     82.135423 s:  ### CPU [IPU1-0], LinkID [  0],
    [IPU1-0]     82.135637 s:
    [IPU1-0]     82.135759 s:  [ IPC_OUT_0 ] Link Statistics,
    [IPU1-0]     82.135942 s:  ******************************
    [IPU1-0]     82.136125 s:
    [IPU1-0]     82.136216 s:  Elapsed time       = 57678 msec
    [IPU1-0]     82.137284 s:
    [IPU1-0]     82.137436 s:  New data Recv      =  11.42 fps
    [IPU1-0]     82.137650 s:  Release data Recv  =  11.58 fps
    [IPU1-0]     82.137955 s:  Driver/Notify Cb   =  49.44 fps
    [IPU1-0]     82.138199 s:
    [IPU1-0]     82.138290 s:  Input Statistics,
    [IPU1-0]     82.138443 s:
    [IPU1-0]     82.138534 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     82.138748 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     82.138961 s:  --------------------------------------------------
    [IPU1-0]     82.139175 s:   0 |  11.42      0. 0      0. 0          11.42
    [IPU1-0]     82.139541 s:
    [IPU1-0]     82.139663 s:  Output Statistics,
    [IPU1-0]     82.139785 s:
    [IPU1-0]     82.139907 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     82.140120 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     82.140730 s:  ---------------------------------------------
    [IPU1-0]     82.140974 s:   0 |  0     11.42     0. 0      0. 0
    [IPU1-0]     82.141310 s:
    [IPU1-0]     82.141401 s:  [ IPC_OUT_0 ] LATENCY,
    [IPU1-0]     82.141584 s:  ********************
    [IPU1-0]     82.141706 s:  Local Link Latency     : Avg =     18 us, Min =      0 us, Max =    244 us,
    [IPU1-0]     82.142042 s:  Source to Link Latency : Avg = 115205 us, Min = 106562 us, Max = 173764 us,
    [IPU1-0]     82.142347 s:
    [IPU1-0]     83.455255 s:
    [IPU1-0]     83.455438 s:  ### CPU [  DSP1], LinkID [ 10],
    [IPU1-0]     83.455682 s:
    [IPU1-0]     83.455773 s:  [ IPC_IN_0 ] Link Statistics,
    [IPU1-0]     83.455956 s:  ******************************
    [IPU1-0]     83.456109 s:
    [IPU1-0]     83.456231 s:  Elapsed time       = 58998 msec
    [IPU1-0]     83.456414 s:
    [IPU1-0]     83.456536 s:  Get Full Buf Cb    =  22.84 fps
    [IPU1-0]     83.456719 s:  Put Empty Buf Cb   =  11.42 fps
    [IPU1-0]     83.456932 s:  Driver/Notify Cb   =  11.40 fps
    [IPU1-0]     83.457756 s:
    [IPU1-0]     83.457908 s:  Input Statistics,
    [IPU1-0]     83.458061 s:
    [IPU1-0]     83.458183 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     83.458396 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     83.459067 s:  --------------------------------------------------
    [IPU1-0]     83.459311 s:   0 |  11.42      0. 0      0. 0          11.42
    [IPU1-0]     83.459677 s:
    [IPU1-0]     83.459769 s:  Output Statistics,
    [IPU1-0]     83.459921 s:
    [IPU1-0]     83.460013 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     83.464893 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     83.465229 s:  ---------------------------------------------
    [IPU1-0]     83.465442 s:   0 |  0     11.42     0. 0      0. 0
    [IPU1-0]     83.466571 s:
    [IPU1-0]     83.466754 s:  [ IPC_IN_0 ] LATENCY,
    [IPU1-0]     83.466967 s:  ********************
    [IPU1-0]     83.467120 s:  Local Link Latency     : Avg =     35 us, Min =     30 us, Max =     61 us,
    [IPU1-0]     83.467486 s:  Source to Link Latency : Avg = 115416 us, Min = 106867 us, Max = 174099 us,
    [IPU1-0]     83.468492 s:
    [IPU1-0]     83.469011 s:
    [IPU1-0]     83.469133 s:  ### CPU [  DSP1], LinkID [ 44],
    [IPU1-0]     83.469895 s:
    [IPU1-0]     83.470048 s:  [ ALG_SYNTHESIS ] Link Statistics,
    [IPU1-0]     83.470292 s:  ******************************
    [IPU1-0]     83.470444 s:
    [IPU1-0]     83.470566 s:  Elapsed time       = 59012 msec
    [IPU1-0]     83.470902 s:
    [IPU1-0]     83.471054 s:  Out Buf Error Count = 4 frames
    [IPU1-0]     83.471268 s:  New data Recv      =  22.84 fps
    [IPU1-0]     83.471481 s:
    [IPU1-0]     83.471603 s:  Input Statistics,
    [IPU1-0]     83.471756 s:
    [IPU1-0]     83.471878 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     83.472091 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     83.472335 s:  --------------------------------------------------
    [IPU1-0]     83.472579 s:   0 |   0. 0      0. 0      0. 0          11.42
    [IPU1-0]     83.472976 s:
    [IPU1-0]     83.473067 s:  Output Statistics,
    [IPU1-0]     83.473220 s:
    [IPU1-0]     83.473342 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     83.474074 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     83.474348 s:  ---------------------------------------------
    [IPU1-0]     83.474592 s:   0 |  0     11.42     0. 0      0. 0
    [IPU1-0]     83.474958 s:
    [IPU1-0]     83.475080 s:  [ ALG_SYNTHESIS ] LATENCY,
    [IPU1-0]     83.475294 s:  ********************
    [IPU1-0]     83.475477 s:  Local Link Latency     : Avg =  29822 us, Min =  29402 us, Max =  34954 us,
    [IPU1-0]     83.475843 s:  Source to Link Latency : Avg = 148621 us, Min = 139076 us, Max = 229611 us,
    [IPU1-0]     83.476300 s:
    [IPU1-0]     83.476758 s:
    [IPU1-0]     83.476880 s:  ### CPU [  DSP1], LinkID [  0],
    [IPU1-0]     83.477124 s:
    [IPU1-0]     83.477215 s:  [ IPC_OUT_0 ] Link Statistics,
    [IPU1-0]     83.477429 s:  ******************************
    [IPU1-0]     83.477612 s:
    [IPU1-0]     83.477734 s:  Elapsed time       = 58983 msec
    [IPU1-0]     83.477917 s:
    [IPU1-0]     83.480265 s:  New data Recv      =  11.35 fps
    [IPU1-0]     83.480631 s:  Release data Recv  =  12.17 fps
    [IPU1-0]     83.480875 s:  Driver/Notify Cb   =  49.43 fps
    [IPU1-0]     83.481089 s:
    [IPU1-0]     83.481211 s:  Input Statistics,
    [IPU1-0]     83.481547 s:
    [IPU1-0]     83.481699 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     83.482462 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     83.482767 s:  --------------------------------------------------
    [IPU1-0]     83.483011 s:   0 |  11.42      0. 0      0. 0          11.42
    [IPU1-0]     83.483377 s:
    [IPU1-0]     83.483499 s:  Output Statistics,
    [IPU1-0]     83.483651 s:
    [IPU1-0]     83.483743 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     83.484109 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     83.484353 s:  ---------------------------------------------
    [IPU1-0]     83.485512 s:   0 |  0     11.42     0. 0      0. 0
    [IPU1-0]     83.485878 s:
    [IPU1-0]     83.485969 s:  [ IPC_OUT_0 ] LATENCY,
    [IPU1-0]     83.486152 s:  ********************
    [IPU1-0]     83.486274 s:  Local Link Latency     : Avg =      8 us, Min =      0 us, Max =     61 us,
    [IPU1-0]     83.487067 s:  Source to Link Latency : Avg = 153410 us, Min = 143621 us, Max = 272403 us,
    [IPU1-0]     83.487433 s:
    [IPU1-0]     84.801561 s:
    [IPU1-0]     84.801744 s:  ### CPU [IPU1-0], LinkID [ 10],
    [IPU1-0]     84.801958 s:
    [IPU1-0]     84.802080 s:  [ IPC_IN_0 ] Link Statistics,
    [IPU1-0]     84.802263 s:  ******************************
    [IPU1-0]     84.802415 s:
    [IPU1-0]     84.802507 s:  Elapsed time       = 60306 msec
    [IPU1-0]     84.802720 s:
    [IPU1-0]     84.802812 s:  Get Full Buf Cb    =  22.76 fps
    [IPU1-0]     84.803025 s:  Put Empty Buf Cb   =  11.40 fps
    [IPU1-0]     84.803239 s:  Driver/Notify Cb   =  11.34 fps
    [IPU1-0]     84.803452 s:
    [IPU1-0]     84.803544 s:  Input Statistics,
    [IPU1-0]     84.803696 s:
    [IPU1-0]     84.803788 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     84.804459 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     84.804703 s:  --------------------------------------------------
    [IPU1-0]     84.804947 s:   0 |  11.42      0. 0      0. 0          11.42
    [IPU1-0]     84.805465 s:
    [IPU1-0]     84.805587 s:  Output Statistics,
    [IPU1-0]     84.805740 s:
    [IPU1-0]     84.805831 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     84.806045 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     84.806258 s:  ---------------------------------------------
    [IPU1-0]     84.806472 s:   0 |  0     11.42     0. 0      0. 0
    [IPU1-0]     84.806868 s:
    [IPU1-0]     84.806990 s:  [ IPC_IN_0 ] LATENCY,
    [IPU1-0]     84.808698 s:  ********************
    [IPU1-0]     84.808942 s:  Local Link Latency     : Avg =     49 us, Min =     30 us, Max =    336 us,
    [IPU1-0]     84.809400 s:  Source to Link Latency : Avg = 153681 us, Min = 143956 us, Max = 273105 us,
    [IPU1-0]     84.809766 s:
    [IPU1-0]     84.809949 s:  CPU [  IPU1-0], LinkID [ 37], Link Statistics not available !
    [IPU1-0]     84.810284 s:  CPU [  IPU1-0], LinkID [ 25], Link Statistics not available !
    [IPU1-0]     84.810742 s:
    [IPU1-0]     84.810864 s:  ### CPU [IPU1-0], LinkID [  1],
    [IPU1-0]     84.811047 s:
    [IPU1-0]     84.811169 s:  [ IPC_OUT_1 ] Link Statistics,
    [IPU1-0]     84.811352 s:  ******************************
    [IPU1-0]     84.811535 s:
    [IPU1-0]     84.811626 s:  Elapsed time       = 60404 msec
    [IPU1-0]     84.811901 s:
    [IPU1-0]     84.812023 s:  New data Recv      =  22.63 fps
    [IPU1-0]     84.812236 s:  Release data Recv  =  57.39 fps
    [IPU1-0]     84.812450 s:  Driver/Notify Cb   =  95.12 fps
    [IPU1-0]     84.812663 s:
    [IPU1-0]     84.812755 s:  Input Statistics,
    [IPU1-0]     84.812907 s:
    [IPU1-0]     84.812999 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     84.813243 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     84.813456 s:  --------------------------------------------------
    [IPU1-0]     84.813670 s:   0 |  11.40      0. 0      0. 0          11.40
    [IPU1-0]     84.814036 s:   1 |  11.42      0. 0      0. 0          11.42
    [IPU1-0]     84.814463 s:   2 |  11.42      0. 0      0. 0          11.42
    [IPU1-0]     84.814829 s:   3 |  11.42      0. 0      0. 0          11.42
    [IPU1-0]     84.815195 s:   4 |  11.42      0. 0      0. 0          11.42
    [IPU1-0]     84.815561 s:
    [IPU1-0]     84.815653 s:  Output Statistics,
    [IPU1-0]     84.815805 s:
    [IPU1-0]     84.815927 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     84.816141 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     84.816354 s:  ---------------------------------------------
    [IPU1-0]     84.816537 s:   0 |  0     11.40     0. 0      0. 0
    [IPU1-0]     84.816873 s:   1 |  0     11.42     0. 0      0. 0
    [IPU1-0]     84.817635 s:   2 |  0     11.42     0. 0      0. 0
    [IPU1-0]     84.818001 s:   3 |  0     11.42     0. 0      0. 0
    [IPU1-0]     84.818306 s:   4 |  0     11.42     0. 0      0. 0
    [IPU1-0]     84.818642 s:
    [IPU1-0]     84.818733 s:  [ IPC_OUT_1 ] LATENCY,
    [IPU1-0]     84.818916 s:  ********************
    [IPU1-0]     84.819038 s:  Local Link Latency     : Avg =     15 us, Min =      0 us, Max =    305 us,
    [IPU1-0]     84.819374 s:  Source to Link Latency : Avg =  80546 us, Min =  61124 us, Max = 273959 us,
    [IPU1-0]     84.819953 s:
    [IPU1-0]     86.134600 s:
    [IPU1-0]     86.134783 s:  ### CPU [IPU1-1], LinkID [ 10],
    [IPU1-0]     86.134996 s:
    [IPU1-0]     86.135179 s:  [ IPC_IN_0 ] Link Statistics,
    [IPU1-0]     86.135423 s:  ******************************
    [IPU1-0]     86.135789 s:
    [IPU1-0]     86.135911 s:  Elapsed time       = 61726 msec
    [IPU1-0]     86.136094 s:
    [IPU1-0]     86.136186 s:  Get Full Buf Cb    =  20.93 fps
    [IPU1-0]     86.138199 s:  Put Empty Buf Cb   =  57.9 fps
    [IPU1-0]     86.138504 s:  Driver/Notify Cb   =  22.61 fps
    [IPU1-0]     86.138717 s:
    [IPU1-0]     86.138809 s:  Input Statistics,
    [IPU1-0]     86.138961 s:
    [IPU1-0]     86.139053 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     86.139266 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     86.139480 s:  --------------------------------------------------
    [IPU1-0]     86.139815 s:   0 |  11.40      0. 0      0. 0          11.40
    [IPU1-0]     86.140212 s:   1 |  11.42      0. 0      0. 0          11.42
    [IPU1-0]     86.140578 s:   2 |  11.42      0. 0      0. 0          11.42
    [IPU1-0]     86.140944 s:   3 |  11.42      0. 0      0. 0          11.42
    [IPU1-0]     86.141279 s:   4 |  11.42      0. 0      0. 0          11.42
    [IPU1-0]     86.141645 s:
    [IPU1-0]     86.141767 s:  Output Statistics,
    [IPU1-0]     86.141889 s:
    [IPU1-0]     86.142011 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     86.142286 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     86.142530 s:  ---------------------------------------------
    [IPU1-0]     86.142713 s:   0 |  0     11.40     0. 0      0. 0
    [IPU1-0]     86.143048 s:   1 |  0     11.42     0. 0      0. 0
    [IPU1-0]     86.143353 s:   2 |  0     11.42     0. 0      0. 0
    [IPU1-0]     86.143689 s:   3 |  0     11.42     0. 0      0. 0
    [IPU1-0]     86.144024 s:   4 |  0     11.42     0. 0      0. 0
    [IPU1-0]     86.144329 s:
    [IPU1-0]     86.144421 s:  [ IPC_IN_0 ] LATENCY,
    [IPU1-0]     86.144573 s:  ********************
    [IPU1-0]     86.144726 s:  Local Link Latency     : Avg =     44 us, Min =     30 us, Max =    244 us,
    [IPU1-0]     86.145641 s:  Source to Link Latency : Avg =  81326 us, Min =  61917 us, Max = 274874 us,
    [IPU1-0]     86.145976 s:
    [IPU1-0]     86.146129 s:  CPU [  IPU1-1], LinkID [ 20], Link Statistics not available !
    [IPU1-0]     87.460043 s:
    [IPU1-0]     87.460409 s:  ### CPU [IPU1-0], LinkID [ 62],
    [IPU1-0]     87.460623 s:
    [IPU1-0]     87.460714 s:  [ DISPLAY ] Link Statistics,
    [IPU1-0]     87.460897 s:  ******************************
    [IPU1-0]     87.461050 s:
    [IPU1-0]     87.461172 s:  Elapsed time       = 63052 msec
    [IPU1-0]     87.461355 s:
    [IPU1-0]     87.461446 s:  New data Recv      =  19.90 fps
    [IPU1-0]     87.461660 s:  Driver/Notify Cb   =  22.77 fps
    [IPU1-0]     87.461843 s:
    [IPU1-0]     87.461965 s:  Input Statistics,
    [IPU1-0]     87.462087 s:
    [IPU1-0]     87.462270 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     87.462483 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     87.462697 s:  --------------------------------------------------
    [IPU1-0]     87.462910 s:   0 |  11.40      0. 0      0. 0          11.40
    [IPU1-0]     87.463277 s:   1 |  11.41     11.41      0. 0           0. 0
    [IPU1-0]     87.463612 s:   2 |  11.41     11.41      0. 0           0. 0
    [IPU1-0]     87.520252 s:   3 |  11.41     11.41      0. 0           0. 0
    [IPU1-0]     87.520710 s:   4 |  11.41     11.41      0. 0           0. 0
    [IPU1-0]     87.521076 s:
    [IPU1-0]     87.521167 s:  [ DISPLAY ] LATENCY,
    [IPU1-0]     87.521320 s:  ********************
    [IPU1-0]     87.521472 s:  Local Link Latency     : Avg =    364 us, Min =     61 us, Max =   3081 us,
    [IPU1-0]     87.521808 s:  Source to Link Latency : Avg = 154971 us, Min = 144810 us, Max = 274599 us,
    [IPU1-0]     87.522113 s:
    [IPU1-0]     88.838467 s:
    [IPU1-0]     88.838681 s:  ### CPU [  DSP1], LinkID [ 45],
    [IPU1-0]     88.838925 s:
    [IPU1-0]     88.839016 s:  [ ALG_PALIGN ] Link Statistics,
    [IPU1-0]     88.839230 s:  ******************************
    [IPU1-0]     88.839413 s:
    [IPU1-0]     88.839504 s:  Elapsed time       = 64348 msec
    [IPU1-0]     88.839687 s:
    [IPU1-0]     88.839809 s:  New data Recv      =  11.42 fps
    [IPU1-0]     88.840175 s:
    [IPU1-0]     88.840297 s:  Input Statistics,
    [IPU1-0]     88.840450 s:
    [IPU1-0]     88.840572 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     88.840785 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     88.841029 s:  --------------------------------------------------
    [IPU1-0]     88.841243 s:   0 |   0. 0      0. 0      0. 0          11.42
    [IPU1-0]     88.841609 s:
    [IPU1-0]     88.841731 s:  Output Statistics,
    [IPU1-0]     88.841883 s:
    [IPU1-0]     88.841975 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]     88.842188 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]     88.842402 s:  ---------------------------------------------
    [IPU1-0]     88.842951 s:   0 |  0     11.42     0. 0      0. 0
    [IPU1-0]     88.843347 s:
    [IPU1-0]     88.843439 s:  [ ALG_PALIGN ] LATENCY,
    [IPU1-0]     88.843622 s:  ********************
    [IPU1-0]     88.843774 s:  Local Link Latency     : Avg =   4031 us, Min =   3965 us, Max =   4392 us,
    [IPU1-0]     88.844079 s:  Source to Link Latency : Avg = 152374 us, Min = 143377 us, Max = 233911 us,
    [IPU1-0]     88.844415 s:
    [IPU1-0]     90.157628 s:  CPU [  IPU1-1], LinkID [ 56], Link Statistics not available !
    [IPU1-0]     91.472335 s:  CPU [  IPU1-0], LinkID [ 22], Link Statistics not available !
    [IPU1-0]     91.472915 s:
    [IPU1-0]     91.473006 s:  ### CPU [IPU1-0], LinkID [ 63],
    [IPU1-0]     91.473220 s:
    [IPU1-0]     91.473342 s:  [ DISPLAY ] Link Statistics,
    [IPU1-0]     91.473525 s:  ******************************
    [IPU1-0]     91.473677 s:
    [IPU1-0]     91.473799 s:  Elapsed time       = 48829 msec
    [IPU1-0]     91.473982 s:
    [IPU1-0]     91.474104 s:  Driver/Notify Cb   =  22.79 fps
    [IPU1-0]     91.474287 s:
    [IPU1-0]     91.474409 s:  Input Statistics,
    [IPU1-0]     91.474531 s:
    [IPU1-0]     91.474714 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]     91.474958 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]     91.475172 s:  --------------------------------------------------
    [IPU1-0]     91.475385 s:   0 |   0. 2      0. 0      0. 0           0. 2
    [IPU1-0]     91.475751 s:
    [IPU1-0]     91.475843 s:  [ DISPLAY ] LATENCY,
    [IPU1-0]     91.476026 s:  ********************
    [IPU1-0]     91.476178 s:  Local Link Latency     : Avg =    122 us, Min =    122 us, Max =    122 us,
    [IPU1-0]     91.476483 s:  Source to Link Latency : Avg =  24522 us, Min =  24522 us, Max =  24522 us,
    [IPU1-0]    208.944030 s:  CPU [IPU1-0 ] Statistics,
    [IPU1-0]    208.944244 s:  *************************
    [IPU1-0]    208.944396 s:
    [IPU1-0]    208.944549 s:  LOAD: CPU: 45.7% HWI: 8.1%, SWI:1.0%, Low Power: 206.8%
    [IPU1-0]    208.945037 s:
    [IPU1-0]    208.945190 s:  LOAD: TSK: SYSTEM              : 0.2%
    [IPU1-0]    208.945434 s:  LOAD: TSK: ISSCAPTURE          : 0.5%
    [IPU1-0]    208.945678 s:  LOAD: TSK: ISSM2MISP           : 7.0%
    [IPU1-0]    208.945922 s:  LOAD: TSK: DUP0                : 0.3%
    [IPU1-0]    208.946135 s:  LOAD: TSK: DUP1                : 0.4%
    [IPU1-0]    208.946410 s:  LOAD: TSK: MERGE0              : 0.2%
    [IPU1-0]    208.946654 s:  LOAD: TSK: SYNC0               : 0.6%
    [IPU1-0]    208.946898 s:  LOAD: TSK: IPC_OUT_0           : 0.4%
    [IPU1-0]    208.947111 s:  LOAD: TSK: IPC_OUT_1           : 1.5%
    [IPU1-0]    208.947386 s:  LOAD: TSK: IPC_IN_0            : 0.2%
    [IPU1-0]    208.947721 s:  LOAD: TSK: DISPLAY0            : 0.9%
    [IPU1-0]    208.947965 s:  LOAD: TSK: ALGORITHM0          : 5.1%
    [IPU1-0]    208.948209 s:  LOAD: TSK: ALGORITHM1          : 7.8%
    [IPU1-0]    208.948514 s:  LOAD: TSK: GrpxSrc0            : 5.3%
    [IPU1-0]    208.948758 s:  LOAD: TSK: STAT_COLL           : 2.3%
    [IPU1-0]    208.949002 s:  LOAD: TSK: 3D_SRV_MEDIA_TSK    : 2.2%
    [IPU1-0]    208.949277 s:  LOAD: TSK: MISC                : 1.7%
    [IPU1-0]    208.949490 s:
    [IPU1-0]    208.949612 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1021
    [IPU1-0]    208.949826 s:
    [IPU1-0]    208.949948 s:  SYSTEM: Sempahores Objects,  157 of 1000 free
    [IPU1-0]    208.950222 s:  SYSTEM: Task Objects      ,   21 of  100 free
    [IPU1-0]    208.950466 s:  SYSTEM: Clock Objects     ,   93 of  100 free
    [IPU1-0]    208.950710 s:  SYSTEM: Hwi Objects       ,   87 of  100 free
    [IPU1-0]    208.950954 s:
    [IPU1-0]    208.951046 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 151256 B (147 KB)
    [IPU1-0]    208.951473 s:  SYSTEM: Heap = SR_OCMC              @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
    [IPU1-0]    208.951869 s:  SYSTEM: Heap = SR_DDR_CACHED        @ 0x85483000, Total size = 367001600 B (350 MB), Free size = 230517248 B (219 MB)
    [IPU1-0]    208.952296 s:  SYSTEM: Heap = SR_DDR_NON_CACHED    @ 0xbfe00000, Total size = 1046784 B (0 MB), Free size = 1039104 B (0 MB)
    [IPU1-0]    208.952784 s:
    [IPU1-0]    208.952906 s:
    [IPU1-0]    208.952998 s:  CPU [IPU1-1 ] Statistics,
    [IPU1-0]    208.953181 s:  *************************
    [IPU1-0]    208.953333 s:
    [IPU1-0]    208.953455 s:  LOAD: CPU: 4.9% HWI: 1.6%, SWI:0.6%, Low Power: 208.8%
    [IPU1-0]    208.953852 s:
    [IPU1-0]    208.954035 s:  LOAD: TSK: NULL0               : 0.6%
    [IPU1-0]    208.954309 s:  LOAD: TSK: IPC_IN_0            : 1.1%
    [IPU1-0]    208.954584 s:  LOAD: TSK: MISC                : 1.0%
    [IPU1-0]    208.954797 s:
    [IPU1-0]    208.954889 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1021
    [IPU1-0]    208.955133 s:
    [IPU1-0]    208.955224 s:  SYSTEM: Sempahores Objects,  429 of 1000 free
    [IPU1-0]    208.955773 s:  SYSTEM: Task Objects      ,   41 of  100 free
    [IPU1-0]    208.956017 s:  SYSTEM: Clock Objects     ,   99 of  100 free
    [IPU1-0]    208.956231 s:  SYSTEM: Hwi Objects       ,   99 of  100 free
    [IPU1-0]    208.956475 s:
    [IPU1-0]    208.956566 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 239616 B (234 KB)
    [IPU1-0]    208.956993 s:
    [IPU1-0]    208.957085 s:
    [IPU1-0]    208.957207 s:  CPU [DSP1   ] Statistics,
    [IPU1-0]    208.957359 s:  *************************
    [IPU1-0]    208.959006 s:
    [IPU1-0]    208.959220 s:  LOAD: CPU: 40.4% HWI: 0.3%, SWI:0.1%, Low Power: 220.4%
    [IPU1-0]    208.959586 s:
    [IPU1-0]    208.959708 s:  LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 39.8%
    [IPU1-0]    208.960013 s:  LOAD: TSK: MISC                : 0.2%
    [IPU1-0]    208.960226 s:
    [IPU1-0]    208.960318 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1021
    [IPU1-0]    208.960562 s:
    [IPU1-0]    208.960775 s:  SYSTEM: Sempahores Objects,  444 of 1000 free
    [IPU1-0]    208.961019 s:  SYSTEM: Task Objects      ,   92 of  100 free
    [IPU1-0]    208.961263 s:  SYSTEM: Clock Objects     ,   98 of  100 free
    [IPU1-0]    208.961507 s:  SYSTEM: Hwi Objects       ,  100 of  100 free
    [IPU1-0]    208.961721 s:
    [IPU1-0]    208.961812 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 96192 B (93 KB)
    [IPU1-0]    208.962239 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 519424 B (507 KB)
    [IPU1-0]    208.962666 s:
    [IPU1-0]    208.962788 s:
    [IPU1-0]    208.962880 s:  CPU [DSP2   ] Statistics,
    [IPU1-0]    208.963033 s:  *************************
    [IPU1-0]    208.963185 s:
    [IPU1-0]    208.963368 s:  LOAD: CPU: 0.3% HWI: 0.1%, SWI:0.0%, Low Power: 260.3%
    [IPU1-0]    208.963765 s:
    [IPU1-0]    208.963887 s:  LOAD: TSK: MISC                : 0.2%
    [IPU1-0]    208.964131 s:
    [IPU1-0]    208.964222 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1021
    [IPU1-0]    208.964466 s:
    [IPU1-0]    208.964558 s:  SYSTEM: Sempahores Objects,  446 of 1000 free
    [IPU1-0]    208.964771 s:  SYSTEM: Task Objects      ,   92 of  100 free
    [IPU1-0]    208.965015 s:  SYSTEM: Clock Objects     ,   99 of  100 free
    [IPU1-0]    208.965229 s:  SYSTEM: Hwi Objects       ,  100 of  100 free
    [IPU1-0]    208.965473 s:
    [IPU1-0]    208.965564 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
    [IPU1-0]    208.966052 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 519424 B (507 KB)
    [IPU1-0]    208.966479 s:
    [IPU1-0]    208.966571 s:
    [IPU1-0]    208.966693 s:  CPU [EVE1   ] Statistics,
    [IPU1-0]    208.966845 s:  *************************
    [IPU1-0]    208.966998 s:
    [IPU1-0]    208.967120 s:  LOAD: CPU: 0.9% HWI: 0.2%, SWI:0.2%, Low Power: 247.3%
    [IPU1-0]    208.967486 s:
    [IPU1-0]    208.967608 s:  LOAD: TSK: SYSTEM              : 0.3%
    [IPU1-0]    208.967852 s:  LOAD: TSK: MISC                : 0.2%
    [IPU1-0]    208.968065 s:
    [IPU1-0]    208.968157 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1021
    [IPU1-0]    208.968401 s:
    [IPU1-0]    208.968797 s:  SYSTEM: Sempahores Objects,  487 of 1000 free
    [IPU1-0]    208.969041 s:  SYSTEM: Task Objects      ,   97 of  100 free
    [IPU1-0]    208.969255 s:  SYSTEM: Clock Objects     ,   99 of  100 free
    [IPU1-0]    208.969499 s:  SYSTEM: Hwi Objects       ,   99 of  100 free
    [IPU1-0]    208.969712 s:
    [IPU1-0]    208.969804 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 24576 B (24 KB), Free size = 24576 B (24 KB)
    [IPU1-0]    208.970231 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 257448 B (251 KB)
    [IPU1-0]    208.970658 s:
    [IPU1-0]    208.971756 s:
    [IPU1-0]    208.971908 s:  UTILS_PRCM_STATS:  Current Temperature,
    [IPU1-0]    208.972091 s:
    [IPU1-0]    208.972183 s:   Voltage Rail         ||   Curr Temp Min - Max
    [IPU1-0]    208.972396 s:  ---------------------------------------------------------
    [IPU1-0]    208.976758 s:     PMHAL_PRCM_VD_CORE ||     [59.600 , 60.  0]
    [IPU1-0]    208.977093 s:
    [IPU1-0]    208.977490 s:
    [IPU1-0]    208.977612 s:  Statistics Collector,
    [IPU1-0]    208.977734 s:
    [IPU1-0]    208.977856 s:        STATISTIC          Avg Data        Peak Data
    [IPU1-0]    208.978039 s:        COLLECTOR          MB/s            MB/s
    [IPU1-0]    208.978252 s:  --------------------------------------------------
    [IPU1-0]    208.978466 s:  SCI_EMIF_SYS         |    392.013950    831.919745
    [IPU1-0]    208.978771 s:  SCI_IPU              |      8.427518     27.217081
    [IPU1-0]    208.979106 s:  SCI_DSP1_MDMA        |      0.635572     17.581627
    [IPU1-0]    208.979411 s:  SCI_DSP2_MDMA        |      0.014871      0.087428
    [IPU1-0]    208.979686 s:  SCI_DSS              |    122.447834    152.661952
    [IPU1-0]    208.979960 s:  SCI_MMU              |      0.000000      0.000000
    [IPU1-0]    208.980235 s:  SCI_EDMA_TC0_RD      |      0.000000      0.000000
    [IPU1-0]    208.980509 s:  SCI_EDMA_TC0_WR      |      0.000000      0.000000
    [IPU1-0]    208.980753 s:  SCI_VIP_P1           |      0.000000      0.000000
    [IPU1-0]    208.981028 s:  SCI_VIP_P2           |      0.000000      0.000000
    [IPU1-0]    208.981302 s:  SCI_ISS_RT           |     84.090188    119.011499
    [IPU1-0]    208.981577 s:  SCI_ISS_NRT2         |    128.724241    290.367861
    [IPU1-0]    208.982187 s:  SCI_EVE_P1           |      1.267105      3.026907
    [IPU1-0]    208.982462 s:  SCI_EVE_P2           |      0.000000      0.000000
    [IPU1-0]    208.982736 s:  SCI_GMAC_SW          |      0.000000      0.000000
    [IPU1-0]    208.983011 s:  SCI_ISS_NRT1         |    193.589831    531.016393
    [IPU1-0]    208.983285 s:  SCI_DSP2_CFG         |      0.000000      0.000000
    [IPU1-0]    208.983529 s:  SCI_DSP2_EDMA        |      0.000000      0.000000
    [IPU1-0]    208.983804 s:  SCI_OCMC_RAM         |     13.744809     34.635005
    [IPU1-0]    208.984078 s:  SCI_DSP1_CFG         |      0.000000      0.000000
    [IPU1-0]    208.984444 s:  SCI_DSP1_EDMA        |     77.327626    261.613579
    [IPU1-0]    208.984719 s:  SCI_GPMC             |      0.000000      0.000000
    [IPU1-0]    208.984993 s:  SCI_MCASP            |      0.000000      0.000000
    [IPU1-0]    208.985268 s:  SCI_EDMA_TC1_RD      |      7.063144     55.956284
    [IPU1-0]    208.985542 s:  SCI_EDMA_TC1_WR      |      7.063144     55.956284
    [IPU1-0]    209.247788 s:
    [IPU1-0]    209.247971 s:  ### CPU [IPU1-0], LinkID [ 72],
    [IPU1-0]    209.248185 s:
    [IPU1-0]    209.248276 s:  [ ISSCAPTURE ] Link Statistics,
    [IPU1-0]    209.248703 s:  ******************************
    [IPU1-0]    209.248856 s:
    [IPU1-0]    209.248978 s:  Elapsed time       = 129728 msec
    [IPU1-0]    209.249161 s:
    [IPU1-0]    209.249252 s:  Get Full Buf Cb    =  45.66 fps
    [IPU1-0]    209.249435 s:  Put Empty Buf Cb   =  16.34 fps
    [IPU1-0]    209.249649 s:  Driver/Notify Cb   =  45.63 fps
    [IPU1-0]    209.250808 s:
    [IPU1-0]    209.250960 s:  Input Statistics,
    [IPU1-0]    209.251113 s:
    [IPU1-0]    209.251204 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    209.251418 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    209.251601 s:  --------------------------------------------------
    [IPU1-0]    209.251814 s:   0 |  11.41      0. 0      0. 0          11.41
    [IPU1-0]    209.252180 s:   1 |  11.41      0. 0      0. 0          11.41
    [IPU1-0]    209.252607 s:   2 |  11.41      0. 0      0. 0          11.41
    [IPU1-0]    209.253004 s:   3 |  11.41      0. 0      0. 0          11.41
    [IPU1-0]    209.253339 s:
    [IPU1-0]    209.253461 s:  Output Statistics,
    [IPU1-0]    209.253583 s:
    [IPU1-0]    209.253675 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    209.253888 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    209.254071 s:  ---------------------------------------------
    [IPU1-0]    209.254254 s:   0 |  0     11.41     0. 0      0. 0
    [IPU1-0]    209.254590 s:   1 |  0     11.41     0. 0      0. 0
    [IPU1-0]    209.254895 s:   2 |  0     11.41     0. 0      0. 0
    [IPU1-0]    209.255261 s:   3 |  0     11.41     0. 0      0. 0
    [IPU1-0]    209.255596 s:
    [IPU1-0]    209.255688 s:  [ ISSCAPTURE ] LATENCY,
    [IPU1-0]    209.255840 s:  ********************
    [IPU1-0]    209.255993 s:
    [IPU1-0]    209.256237 s:
    [IPU1-0]    209.256328 s:  ### CPU [IPU1-0], LinkID [ 73],
    [IPU1-0]    209.256542 s:
    [IPU1-0]    209.256633 s:  [ ISSM2MISP ] Link Statistics,
    [IPU1-0]    209.256816 s:  ******************************
    [IPU1-0]    209.256969 s:
    [IPU1-0]    209.257060 s:  Elapsed time       = 129761 msec
    [IPU1-0]    209.257243 s:
    [IPU1-0]    209.257365 s:  New data Recv      =  45.67 fps
    [IPU1-0]    209.257548 s:  Get Full Buf Cb    =  31.55 fps
    [IPU1-0]    209.258036 s:  Driver/Notify Cb   =  45.9 fps
    [IPU1-0]    209.258280 s:
    [IPU1-0]    209.258372 s:  Input Statistics,
    [IPU1-0]    209.258524 s:
    [IPU1-0]    209.258616 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    209.258799 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    209.259012 s:  --------------------------------------------------
    [IPU1-0]    209.259226 s:   0 |  11.41      0.25      0. 0          11.15
    [IPU1-0]    209.259562 s:   1 |  11.41      0.10      0. 0          11.31
    [IPU1-0]    209.260050 s:   2 |  11.41      0.10      0. 0          11.31
    [IPU1-0]    209.260477 s:   3 |  11.41      0.10      0. 0          11.31
    [IPU1-0]    209.263618 s:
    [IPU1-0]    209.263801 s:  Output Statistics,
    [IPU1-0]    209.263954 s:
    [IPU1-0]    209.264045 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    209.264228 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    209.264442 s:  ---------------------------------------------
    [IPU1-0]    209.264655 s:   0 |  0     11.15     0.25      0. 0
    [IPU1-0]    209.264960 s:   1 |  0     11.31     0.10      0. 0
    [IPU1-0]    209.265296 s:   2 |  0     11.31     0.10      0. 0
    [IPU1-0]    209.265601 s:   3 |  0     11.31     0.10      0. 0
    [IPU1-0]    209.266028 s:
    [IPU1-0]    209.266150 s:  [ ISSM2MISP ] LATENCY,
    [IPU1-0]    209.266333 s:  ********************
    [IPU1-0]    209.266455 s:  Local Link Latency     : Avg =  15043 us, Min =  14640 us, Max =  16379 us,
    [IPU1-0]    209.266790 s:  Source to Link Latency : Avg =  37902 us, Min =  15067 us, Max =  61764 us,
    [IPU1-0]    209.267095 s:
    [IPU1-0]    209.267370 s:
    [IPU1-0]    209.267461 s:  ### CPU [IPU1-0], LinkID [ 45],
    [IPU1-0]    209.267675 s:
    [IPU1-0]    209.267766 s:  [ ALG_ISS_AEWB ] Link Statistics,
    [IPU1-0]    209.267949 s:  ******************************
    [IPU1-0]    209.268132 s:
    [IPU1-0]    209.268224 s:  Elapsed time       = 129769 msec
    [IPU1-0]    209.268468 s:
    [IPU1-0]    209.268590 s:  New data Recv      =  15.41 fps
    [IPU1-0]    209.268803 s:
    [IPU1-0]    209.268895 s:  Input Statistics,
    [IPU1-0]    209.269047 s:
    [IPU1-0]    209.269139 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    209.269352 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    209.269566 s:  --------------------------------------------------
    [IPU1-0]    209.269779 s:   0 |  11.16      0. 0      0. 0          11.16
    [IPU1-0]    209.270115 s:
    [IPU1-0]    209.270206 s:  Output Statistics,
    [IPU1-0]    209.270359 s:
    [IPU1-0]    209.270450 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    209.270664 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    209.270847 s:  ---------------------------------------------
    [IPU1-0]    209.271365 s:   0 |  0     11.16     0. 0      0. 0
    [IPU1-0]    209.271701 s:
    [IPU1-0]    209.271823 s:  [ ALG_ISS_AEWB ] LATENCY,
    [IPU1-0]    209.271975 s:  ********************
    [IPU1-0]    209.272128 s:  Local Link Latency     : Avg =  18323 us, Min =    488 us, Max = 117489 us,
    [IPU1-0]    209.272433 s:  Source to Link Latency : Avg =  84636 us, Min =  61672 us, Max = 169036 us,
    [IPU1-0]    209.272738 s:
    [IPU1-0]    209.272890 s:  CPU [  IPU1-0], LinkID [ 24], Link Statistics not available !
    [IPU1-0]    209.273287 s:
    [IPU1-0]    209.273378 s:  ### CPU [IPU1-0], LinkID [ 52],
    [IPU1-0]    209.273653 s:
    [IPU1-0]    209.273805 s:  [ NULL_SRC ] Link Statistics,
    [IPU1-0]    209.273958 s:  ******************************
    [IPU1-0]    209.274141 s:
    [IPU1-0]    209.274232 s:  Elapsed time       = 190886 msec
    [IPU1-0]    209.274415 s:
    [IPU1-0]    209.274507 s:
    [IPU1-0]    209.274629 s:  Input Statistics,
    [IPU1-0]    209.274751 s:
    [IPU1-0]    209.274873 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    209.275056 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    209.275269 s:  --------------------------------------------------
    [IPU1-0]    209.275483 s:
    [IPU1-0]    209.275574 s:  Output Statistics,
    [IPU1-0]    209.275727 s:
    [IPU1-0]    209.275818 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    209.276001 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    209.276276 s:  ---------------------------------------------
    [IPU1-0]    209.276520 s:
    [IPU1-0]    209.280363 s:  [ NULL_SRC ] LATENCY,
    [IPU1-0]    209.280577 s:  ********************
    [IPU1-0]    209.280729 s:
    [IPU1-0]    209.281004 s:
    [IPU1-0]    209.281126 s:  ### CPU [IPU1-0], LinkID [  2],
    [IPU1-0]    209.281309 s:
    [IPU1-0]    209.281522 s:  [ IPC_OUT_2 ] Link Statistics,
    [IPU1-0]    209.281736 s:  ******************************
    [IPU1-0]    209.281888 s:
    [IPU1-0]    209.282010 s:  Elapsed time       = 190893 msec
    [IPU1-0]    209.282193 s:
    [IPU1-0]    209.282285 s:  Driver/Notify Cb   =  36.87 fps
    [IPU1-0]    209.282498 s:
    [IPU1-0]    209.282590 s:  Input Statistics,
    [IPU1-0]    209.282742 s:
    [IPU1-0]    209.282834 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    209.283047 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    209.283230 s:  --------------------------------------------------
    [IPU1-0]    209.283444 s:
    [IPU1-0]    209.283566 s:  Output Statistics,
    [IPU1-0]    209.283688 s:
    [IPU1-0]    209.283779 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    209.283993 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    209.284481 s:  ---------------------------------------------
    [IPU1-0]    209.284725 s:
    [IPU1-0]    209.284816 s:  [ IPC_OUT_2 ] LATENCY,
    [IPU1-0]    209.284999 s:  ********************
    [IPU1-0]    209.285121 s:
    [IPU1-0]    210.599310 s:
    [IPU1-0]    210.599493 s:  ### CPU [  DSP1], LinkID [ 11],
    [IPU1-0]    210.599707 s:
    [IPU1-0]    210.599798 s:  [ IPC_IN_1 ] Link Statistics,
    [IPU1-0]    210.599981 s:  ******************************
    [IPU1-0]    210.600134 s:
    [IPU1-0]    210.600256 s:  Elapsed time       = 192209 msec
    [IPU1-0]    210.600439 s:
    [IPU1-0]    210.600530 s:
    [IPU1-0]    210.600652 s:  Input Statistics,
    [IPU1-0]    210.600774 s:
    [IPU1-0]    210.600866 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    210.601079 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    210.601293 s:  --------------------------------------------------
    [IPU1-0]    210.601567 s:
    [IPU1-0]    210.601689 s:  Output Statistics,
    [IPU1-0]    210.601842 s:
    [IPU1-0]    210.601933 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    210.602147 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    210.602330 s:  ---------------------------------------------
    [IPU1-0]    210.602543 s:
    [IPU1-0]    210.602635 s:  [ IPC_IN_1 ] LATENCY,
    [IPU1-0]    210.602787 s:  ********************
    [IPU1-0]    210.602940 s:
    [IPU1-0]    211.916275 s:
    [IPU1-0]    211.916458 s:  ### CPU [IPU1-0], LinkID [ 33],
    [IPU1-0]    211.916671 s:
    [IPU1-0]    211.916763 s:  [ SYNC_0 ] Link Statistics,
    [IPU1-0]    211.916946 s:  ******************************
    [IPU1-0]    211.917098 s:
    [IPU1-0]    211.917190 s:  Elapsed time       = 129794 msec
    [IPU1-0]    211.917373 s:
    [IPU1-0]    211.917495 s:  New data Recv      =  27.85 fps
    [IPU1-0]    211.917708 s:  Get Full Buf Cb    =  11.16 fps
    [IPU1-0]    211.917891 s:  Put Empty Buf Cb   =  11.16 fps
    [IPU1-0]    211.918105 s:  Driver/Notify Cb   =  11.52 fps
    [IPU1-0]    211.918288 s:
    [IPU1-0]    211.918410 s:  Input Statistics,
    [IPU1-0]    211.918532 s:
    [IPU1-0]    211.918654 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    211.918898 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    211.919142 s:  --------------------------------------------------
    [IPU1-0]    211.919355 s:   0 |  11.16      0. 0      0. 0          11.16
    [IPU1-0]    211.919721 s:   1 |  11.31      0.15      0. 0          11.16
    [IPU1-0]    211.920057 s:   2 |  11.32      0.15      0. 0          11.16
    [IPU1-0]    211.920423 s:   3 |  11.31      0.15      0. 0          11.16
    [IPU1-0]    211.920789 s:
    [IPU1-0]    211.920880 s:  Output Statistics,
    [IPU1-0]    211.921033 s:
    [IPU1-0]    211.923046 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    211.923290 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    211.923503 s:  ---------------------------------------------
    [IPU1-0]    211.923686 s:   0 |  0     11.16     0. 0      0. 0
    [IPU1-0]    211.924113 s:
    [IPU1-0]    211.924235 s:  [ SYNC_0 ] LATENCY,
    [IPU1-0]    211.924388 s:  ********************
    [IPU1-0]    211.924540 s:  Local Link Latency     : Avg =   5355 us, Min =     61 us, Max =  48710 us,
    [IPU1-0]    211.924845 s:  Source to Link Latency : Avg =  61691 us, Min =  60170 us, Max =  63640 us,
    [IPU1-0]    211.925181 s:
    [IPU1-0]    211.925455 s:
    [IPU1-0]    211.925547 s:  ### CPU [IPU1-0], LinkID [ 44],
    [IPU1-0]    211.925760 s:
    [IPU1-0]    211.925852 s:  [ ALG_DEWARP ] Link Statistics,
    [IPU1-0]    211.926035 s:  ******************************
    [IPU1-0]    211.926188 s:
    [IPU1-0]    211.926310 s:  Elapsed time       = 129713 msec
    [IPU1-0]    211.926493 s:
    [IPU1-0]    211.926645 s:  New data Recv      =  11.16 fps
    [IPU1-0]    211.926859 s:
    [IPU1-0]    211.926981 s:  Input Statistics,
    [IPU1-0]    211.927103 s:
    [IPU1-0]    211.927225 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    211.927408 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    211.927621 s:  --------------------------------------------------
    [IPU1-0]    211.927835 s:   0 |  11.16      1. 3      0. 0          10.13
    [IPU1-0]    211.928170 s:
    [IPU1-0]    211.928292 s:  Output Statistics,
    [IPU1-0]    211.928414 s:
    [IPU1-0]    211.928536 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    211.928719 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    211.928902 s:  ---------------------------------------------
    [IPU1-0]    211.929116 s:   0 |  0     10.13     1. 3      0. 0
    [IPU1-0]    211.929512 s:
    [IPU1-0]    211.929604 s:  [ ALG_DEWARP ] LATENCY,
    [IPU1-0]    211.929787 s:  ********************
    [IPU1-0]    211.929939 s:  Local Link Latency     : Avg =  43096 us, Min =  38217 us, Max =  46422 us,
    [IPU1-0]    211.930244 s:  Source to Link Latency : Avg = 109380 us, Min = 102087 us, Max = 113883 us,
    [IPU1-0]    211.930549 s:
    [IPU1-0]    211.930824 s:
    [IPU1-0]    211.930915 s:  ### CPU [IPU1-0], LinkID [  0],
    [IPU1-0]    211.931129 s:
    [IPU1-0]    211.931220 s:  [ IPC_OUT_0 ] Link Statistics,
    [IPU1-0]    211.931403 s:  ******************************
    [IPU1-0]    211.931556 s:
    [IPU1-0]    211.931678 s:  Elapsed time       = 129761 msec
    [IPU1-0]    211.931922 s:
    [IPU1-0]    211.932044 s:  New data Recv      =  10.13 fps
    [IPU1-0]    211.932257 s:  Release data Recv  =  10.18 fps
    [IPU1-0]    211.932471 s:  Driver/Notify Cb   =  48.14 fps
    [IPU1-0]    211.932654 s:
    [IPU1-0]    211.932745 s:  Input Statistics,
    [IPU1-0]    211.932898 s:
    [IPU1-0]    211.932989 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    211.933203 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    211.933447 s:  --------------------------------------------------
    [IPU1-0]    211.933660 s:   0 |  10.13      0. 0      0. 0          10.13
    [IPU1-0]    211.934026 s:
    [IPU1-0]    211.934118 s:  Output Statistics,
    [IPU1-0]    211.934270 s:
    [IPU1-0]    211.934362 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    211.934880 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    211.935124 s:  ---------------------------------------------
    [IPU1-0]    211.935307 s:   0 |  0     10.13     0. 0      0. 0
    [IPU1-0]    211.935643 s:
    [IPU1-0]    211.935734 s:  [ IPC_OUT_0 ] LATENCY,
    [IPU1-0]    211.935887 s:  ********************
    [IPU1-0]    211.937869 s:  Local Link Latency     : Avg =     19 us, Min =      0 us, Max =    122 us,
    [IPU1-0]    211.938235 s:  Source to Link Latency : Avg = 109587 us, Min = 102270 us, Max = 114096 us,
    [IPU1-0]    211.938571 s:
    [IPU1-0]    213.252058 s:
    [IPU1-0]    213.252241 s:  ### CPU [  DSP1], LinkID [ 10],
    [IPU1-0]    213.252455 s:
    [IPU1-0]    213.252577 s:  [ IPC_IN_0 ] Link Statistics,
    [IPU1-0]    213.252729 s:  ******************************
    [IPU1-0]    213.252912 s:
    [IPU1-0]    213.253004 s:  Elapsed time       = 129767 msec
    [IPU1-0]    213.253187 s:
    [IPU1-0]    213.253309 s:  Get Full Buf Cb    =  20.1 fps
    [IPU1-0]    213.253492 s:  Put Empty Buf Cb   =   9.99 fps
    [IPU1-0]    213.253858 s:  Driver/Notify Cb   =  10.1 fps
    [IPU1-0]    213.254071 s:
    [IPU1-0]    213.254163 s:  Input Statistics,
    [IPU1-0]    213.254315 s:
    [IPU1-0]    213.254468 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    213.254681 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    213.254895 s:  --------------------------------------------------
    [IPU1-0]    213.255108 s:   0 |  10. 1      0. 0      0. 0          10. 1
    [IPU1-0]    213.255474 s:
    [IPU1-0]    213.255566 s:  Output Statistics,
    [IPU1-0]    213.255718 s:
    [IPU1-0]    213.255810 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    213.255993 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    213.256206 s:  ---------------------------------------------
    [IPU1-0]    213.256389 s:   0 |  0     10. 1     0. 0      0. 0
    [IPU1-0]    213.256725 s:
    [IPU1-0]    213.256816 s:  [ IPC_IN_0 ] LATENCY,
    [IPU1-0]    213.256969 s:  ********************
    [IPU1-0]    213.257426 s:  Local Link Latency     : Avg =     37 us, Min =     30 us, Max =     92 us,
    [IPU1-0]    213.257792 s:  Source to Link Latency : Avg = 109930 us, Min = 102575 us, Max = 114432 us,
    [IPU1-0]    213.258097 s:
    [IPU1-0]    213.258372 s:
    [IPU1-0]    213.258463 s:  ### CPU [  DSP1], LinkID [ 44],
    [IPU1-0]    213.258646 s:
    [IPU1-0]    213.258768 s:  [ ALG_SYNTHESIS ] Link Statistics,
    [IPU1-0]    213.258951 s:  ******************************
    [IPU1-0]    213.259104 s:
    [IPU1-0]    213.259195 s:  Elapsed time       = 129773 msec
    [IPU1-0]    213.259379 s:
    [IPU1-0]    213.259501 s:  Out Buf Error Count = 3 frames
    [IPU1-0]    213.259745 s:  New data Recv      =  20.1 fps
    [IPU1-0]    213.259989 s:
    [IPU1-0]    213.260080 s:  Input Statistics,
    [IPU1-0]    213.260233 s:
    [IPU1-0]    213.260324 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    213.260538 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    213.260721 s:  --------------------------------------------------
    [IPU1-0]    213.260934 s:   0 |   0. 0      0. 0      0. 0           9.99
    [IPU1-0]    213.261300 s:
    [IPU1-0]    213.261392 s:  Output Statistics,
    [IPU1-0]    213.261544 s:
    [IPU1-0]    213.261636 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    213.261819 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    213.262032 s:  ---------------------------------------------
    [IPU1-0]    213.262215 s:   0 |  0      9.99     0. 0      0. 0
    [IPU1-0]    213.262612 s:
    [IPU1-0]    213.262703 s:  [ ALG_SYNTHESIS ] LATENCY,
    [IPU1-0]    213.262886 s:  ********************
    [IPU1-0]    213.263039 s:  Local Link Latency     : Avg =  29591 us, Min =  29433 us, Max =  29830 us,
    [IPU1-0]    213.263344 s:  Source to Link Latency : Avg = 142244 us, Min = 139207 us, Max = 146671 us,
    [IPU1-0]    213.263649 s:
    [IPU1-0]    213.263923 s:
    [IPU1-0]    213.264015 s:  ### CPU [  DSP1], LinkID [  0],
    [IPU1-0]    213.264228 s:
    [IPU1-0]    213.264320 s:  [ IPC_OUT_0 ] Link Statistics,
    [IPU1-0]    213.264503 s:  ******************************
    [IPU1-0]    213.264655 s:
    [IPU1-0]    213.268956 s:  Elapsed time       = 129742 msec
    [IPU1-0]    213.269200 s:
    [IPU1-0]    213.269291 s:  New data Recv      =   9.99 fps
    [IPU1-0]    213.269505 s:  Release data Recv  =  10.9 fps
    [IPU1-0]    213.269688 s:  Driver/Notify Cb   =  48.2 fps
    [IPU1-0]    213.269901 s:
    [IPU1-0]    213.269993 s:  Input Statistics,
    [IPU1-0]    213.270115 s:
    [IPU1-0]    213.270572 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    213.270816 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    213.270999 s:  --------------------------------------------------
    [IPU1-0]    213.271213 s:   0 |   9.99      0. 0      0. 0           9.99
    [IPU1-0]    213.271579 s:
    [IPU1-0]    213.271670 s:  Output Statistics,
    [IPU1-0]    213.271823 s:
    [IPU1-0]    213.271914 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    213.272097 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    213.272280 s:  ---------------------------------------------
    [IPU1-0]    213.272494 s:   0 |  0      9.99     0. 0      0. 0
    [IPU1-0]    213.272890 s:
    [IPU1-0]    213.273012 s:  [ IPC_OUT_0 ] LATENCY,
    [IPU1-0]    213.273165 s:  ********************
    [IPU1-0]    213.273317 s:  Local Link Latency     : Avg =      9 us, Min =      0 us, Max =     61 us,
    [IPU1-0]    213.273622 s:  Source to Link Latency : Avg = 146770 us, Min = 143751 us, Max = 151246 us,
    [IPU1-0]    213.273927 s:
    [IPU1-0]    214.587750 s:
    [IPU1-0]    214.587903 s:  ### CPU [IPU1-0], LinkID [ 10],
    [IPU1-0]    214.588116 s:
    [IPU1-0]    214.588208 s:  [ IPC_IN_0 ] Link Statistics,
    [IPU1-0]    214.588391 s:  ******************************
    [IPU1-0]    214.588543 s:
    [IPU1-0]    214.588665 s:  Elapsed time       = 129754 msec
    [IPU1-0]    214.588818 s:
    [IPU1-0]    214.588940 s:  Get Full Buf Cb    =  26.49 fps
    [IPU1-0]    214.589123 s:  Put Empty Buf Cb   =   9.88 fps
    [IPU1-0]    214.589336 s:  Driver/Notify Cb   =   9.87 fps
    [IPU1-0]    214.589519 s:
    [IPU1-0]    214.589641 s:  Input Statistics,
    [IPU1-0]    214.589763 s:
    [IPU1-0]    214.589855 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    214.590068 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    214.590343 s:  --------------------------------------------------
    [IPU1-0]    214.590556 s:   0 |   9.88      0. 0      0. 0           9.88
    [IPU1-0]    214.590892 s:
    [IPU1-0]    214.591014 s:  Output Statistics,
    [IPU1-0]    214.591136 s:
    [IPU1-0]    214.591258 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    214.591441 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    214.591624 s:  ---------------------------------------------
    [IPU1-0]    214.591837 s:   0 |  0      9.88     0. 0      0. 0
    [IPU1-0]    214.592142 s:
    [IPU1-0]    214.592234 s:  [ IPC_IN_0 ] LATENCY,
    [IPU1-0]    214.592386 s:  ********************
    [IPU1-0]    214.592539 s:  Local Link Latency     : Avg =     50 us, Min =     30 us, Max =    275 us,
    [IPU1-0]    214.592875 s:  Source to Link Latency : Avg = 147180 us, Min = 144124 us, Max = 151673 us,
    [IPU1-0]    214.593210 s:
    [IPU1-0]    214.593363 s:  CPU [  IPU1-0], LinkID [ 37], Link Statistics not available !
    [IPU1-0]    214.593637 s:  CPU [  IPU1-0], LinkID [ 25], Link Statistics not available !
    [IPU1-0]    214.594003 s:
    [IPU1-0]    214.594125 s:  ### CPU [IPU1-0], LinkID [  1],
    [IPU1-0]    214.594308 s:
    [IPU1-0]    214.594430 s:  [ IPC_OUT_1 ] Link Statistics,
    [IPU1-0]    214.594583 s:  ******************************
    [IPU1-0]    214.594735 s:
    [IPU1-0]    214.594949 s:  Elapsed time       = 129760 msec
    [IPU1-0]    214.595132 s:
    [IPU1-0]    214.595254 s:  New data Recv      =  26.34 fps
    [IPU1-0]    214.595498 s:  Release data Recv  =  54.10 fps
    [IPU1-0]    214.595711 s:  Driver/Notify Cb   =  91.71 fps
    [IPU1-0]    214.595925 s:
    [IPU1-0]    214.596016 s:  Input Statistics,
    [IPU1-0]    214.596138 s:
    [IPU1-0]    214.596260 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    214.596443 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    214.596657 s:  --------------------------------------------------
    [IPU1-0]    214.596840 s:   0 |   9.87      0. 0      0. 0           9.87
    [IPU1-0]    214.597206 s:   1 |  11.16      0.20      0. 0          10.95
    [IPU1-0]    214.597541 s:   2 |  11.32      0.36      0. 0          10.95
    [IPU1-0]    214.597907 s:   3 |  11.32      0.36      0. 0          10.95
    [IPU1-0]    214.598517 s:   4 |  11.32      0.36      0. 0          10.95
    [IPU1-0]    214.598914 s:
    [IPU1-0]    214.599005 s:  Output Statistics,
    [IPU1-0]    214.599158 s:
    [IPU1-0]    214.599249 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    214.599432 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    214.599615 s:  ---------------------------------------------
    [IPU1-0]    214.599829 s:   0 |  0      9.87     0. 0      0. 0
    [IPU1-0]    214.600134 s:   1 |  0     10.95     0. 0      0. 0
    [IPU1-0]    214.600439 s:   2 |  0     10.95     0. 0      0. 0
    [IPU1-0]    214.600835 s:   3 |  0     10.95     0. 0      0. 0
    [IPU1-0]    214.601171 s:   4 |  0     10.95     0. 0      0. 0
    [IPU1-0]    214.601476 s:
    [IPU1-0]    214.601567 s:  [ IPC_OUT_1 ] LATENCY,
    [IPU1-0]    214.601720 s:  ********************
    [IPU1-0]    214.601872 s:  Local Link Latency     : Avg =     16 us, Min =      0 us, Max =    244 us,
    [IPU1-0]    214.602177 s:  Source to Link Latency : Avg =  73048 us, Min =  16317 us, Max = 152154 us,
    [IPU1-0]    214.602482 s:
    [IPU1-0]    215.915543 s:
    [IPU1-0]    215.915695 s:  ### CPU [IPU1-1], LinkID [ 10],
    [IPU1-0]    215.915909 s:
    [IPU1-0]    215.916000 s:  [ IPC_IN_0 ] Link Statistics,
    [IPU1-0]    215.916183 s:  ******************************
    [IPU1-0]    215.916336 s:
    [IPU1-0]    215.916427 s:  Elapsed time       = 129764 msec
    [IPU1-0]    215.916610 s:
    [IPU1-0]    215.916732 s:  Get Full Buf Cb    =  24.56 fps
    [IPU1-0]    215.916915 s:  Put Empty Buf Cb   =  53.56 fps
    [IPU1-0]    215.917129 s:  Driver/Notify Cb   =  25.59 fps
    [IPU1-0]    215.917312 s:
    [IPU1-0]    215.917403 s:  Input Statistics,
    [IPU1-0]    215.917678 s:
    [IPU1-0]    215.917800 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    215.918044 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    215.918257 s:  --------------------------------------------------
    [IPU1-0]    215.918471 s:   0 |   9.75      0. 0      0. 0           9.75
    [IPU1-0]    215.921856 s:   1 |  10.95      0. 0      0. 0          10.95
    [IPU1-0]    215.922283 s:   2 |  10.95      0. 0      0. 0          10.95
    [IPU1-0]    215.922619 s:   3 |  10.95      0. 0      0. 0          10.95
    [IPU1-0]    215.922985 s:   4 |  10.95      0. 0      0. 0          10.95
    [IPU1-0]    215.923442 s:
    [IPU1-0]    215.923564 s:  Output Statistics,
    [IPU1-0]    215.923686 s:
    [IPU1-0]    215.923808 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    215.923991 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    215.924205 s:  ---------------------------------------------
    [IPU1-0]    215.924388 s:   0 |  0      9.75     0. 0      0. 0
    [IPU1-0]    215.924723 s:   1 |  0     10.95     0. 0      0. 0
    [IPU1-0]    215.925028 s:   2 |  0     10.95     0. 0      0. 0
    [IPU1-0]    215.925333 s:   3 |  0     10.95     0. 0      0. 0
    [IPU1-0]    215.925669 s:   4 |  0     10.95     0. 0      0. 0
    [IPU1-0]    215.926035 s:
    [IPU1-0]    215.926157 s:  [ IPC_IN_0 ] LATENCY,
    [IPU1-0]    215.926310 s:  ********************
    [IPU1-0]    215.926462 s:  Local Link Latency     : Avg =     46 us, Min =     30 us, Max =    214 us,
    [IPU1-0]    215.926798 s:  Source to Link Latency : Avg =  74213 us, Min =  16867 us, Max = 152642 us,
    [IPU1-0]    215.927103 s:
    [IPU1-0]    215.927225 s:  CPU [  IPU1-1], LinkID [ 20], Link Statistics not available !
    [IPU1-0]    217.240773 s:
    [IPU1-0]    217.240956 s:  ### CPU [IPU1-0], LinkID [ 62],
    [IPU1-0]    217.241170 s:
    [IPU1-0]    217.241261 s:  [ DISPLAY ] Link Statistics,
    [IPU1-0]    217.241444 s:  ******************************
    [IPU1-0]    217.241597 s:
    [IPU1-0]    217.241688 s:  Elapsed time       = 129690 msec
    [IPU1-0]    217.241871 s:
    [IPU1-0]    217.241993 s:  New data Recv      =  21.66 fps
    [IPU1-0]    217.242176 s:  Driver/Notify Cb   =  22.81 fps
    [IPU1-0]    217.242390 s:
    [IPU1-0]    217.242481 s:  Input Statistics,
    [IPU1-0]    217.242634 s:
    [IPU1-0]    217.242725 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    217.242939 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    217.243152 s:  --------------------------------------------------
    [IPU1-0]    217.243762 s:   0 |   9.64      0. 0      0. 0           9.64
    [IPU1-0]    217.244159 s:   1 |  11.16     11.16      0. 0           0. 0
    [IPU1-0]    217.244525 s:   2 |  11.31     11.31      0. 0           0. 0
    [IPU1-0]    217.244860 s:   3 |  11.31     11.31      0. 0           0. 0
    [IPU1-0]    217.245226 s:   4 |  11.31     11.31      0. 0           0. 0
    [IPU1-0]    217.245562 s:
    [IPU1-0]    217.245684 s:  Output Statistics,
    [IPU1-0]    217.245867 s:
    [IPU1-0]    217.245989 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    217.246202 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    217.246385 s:  ---------------------------------------------
    [IPU1-0]    217.246599 s:
    [IPU1-0]    217.246690 s:  [ DISPLAY ] LATENCY,
    [IPU1-0]    217.246843 s:  ********************
    [IPU1-0]    217.246995 s:  Local Link Latency     : Avg =    280 us, Min =     91 us, Max =   3386 us,
    [IPU1-0]    217.247300 s:  Source to Link Latency : Avg = 149228 us, Min = 145001 us, Max = 153077 us,
    [IPU1-0]    217.247605 s:
    [IPU1-0]    218.560971 s:
    [IPU1-0]    218.561123 s:  ### CPU [  DSP1], LinkID [ 45],
    [IPU1-0]    218.561337 s:
    [IPU1-0]    218.561459 s:  [ ALG_PALIGN ] Link Statistics,
    [IPU1-0]    218.561611 s:  ******************************
    [IPU1-0]    218.561794 s:
    [IPU1-0]    218.561886 s:  Elapsed time       = 129701 msec
    [IPU1-0]    218.562069 s:
    [IPU1-0]    218.562191 s:  New data Recv      =   9.52 fps
    [IPU1-0]    218.562374 s:
    [IPU1-0]    218.565912 s:  Input Statistics,
    [IPU1-0]    218.566125 s:
    [IPU1-0]    218.566217 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    218.566430 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    218.566644 s:  --------------------------------------------------
    [IPU1-0]    218.566857 s:   0 |   0. 0      0. 0      0. 0           9.52
    [IPU1-0]    218.567223 s:
    [IPU1-0]    218.567315 s:  Output Statistics,
    [IPU1-0]    218.567437 s:
    [IPU1-0]    218.567559 s:  CH | Out | Out     | Out Drop | Out User Drop
    [IPU1-0]    218.567742 s:     | ID  | FPS     | FPS      | FPS
    [IPU1-0]    218.567925 s:  ---------------------------------------------
    [IPU1-0]    218.568138 s:   0 |  0      9.52     0. 0      0. 0
    [IPU1-0]    218.568840 s:
    [IPU1-0]    218.568962 s:  [ ALG_PALIGN ] LATENCY,
    [IPU1-0]    218.569114 s:  ********************
    [IPU1-0]    218.569267 s:  Local Link Latency     : Avg =   4016 us, Min =   3965 us, Max =   4088 us,
    [IPU1-0]    218.569572 s:  Source to Link Latency : Avg = 146571 us, Min = 143507 us, Max = 150941 us,
    [IPU1-0]    218.569877 s:
    [IPU1-0]    219.883151 s:  CPU [  IPU1-1], LinkID [ 56], Link Statistics not available !
    [IPU1-0]    221.197858 s:  CPU [  IPU1-0], LinkID [ 22], Link Statistics not available !
    [IPU1-0]    221.198590 s:
    [IPU1-0]    221.198712 s:  ### CPU [IPU1-0], LinkID [ 63],
    [IPU1-0]    221.198895 s:
    [IPU1-0]    221.199017 s:  [ DISPLAY ] Link Statistics,
    [IPU1-0]    221.199170 s:  ******************************
    [IPU1-0]    221.199353 s:
    [IPU1-0]    221.199444 s:  Elapsed time       = 178554 msec
    [IPU1-0]    221.199627 s:
    [IPU1-0]    221.199719 s:  Driver/Notify Cb   =  22.81 fps
    [IPU1-0]    221.199932 s:
    [IPU1-0]    221.200024 s:  Input Statistics,
    [IPU1-0]    221.200176 s:
    [IPU1-0]    221.200268 s:  CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0]    221.200542 s:     | FPS     | FPS     | FPS          | FPS
    [IPU1-0]    221.200786 s:  --------------------------------------------------
    [IPU1-0]    221.201000 s:   0 |   0. 0      0. 0      0. 0           0. 0
    [IPU1-0]    221.201335 s:
    [IPU1-0]    221.201457 s:  [ DISPLAY ] LATENCY,
    [IPU1-0]    221.201610 s:  ********************
    [IPU1-0]    221.201732 s:  Local Link Latency     : Avg =    122 us, Min =    122 us, Max =    122 us,
    [IPU1-0]    221.202067 s:  Source to Link Latency : Avg =  24522 us, Min =  24522 us, Max =  24522 us,
    Hello Prasad,
    1. do you mean logs from Wireshark? No, nothing is to see anymore in Wireshark. UDP simply stops and nothing more is to see.
    The system not really freezes. Only the video freezes. The links are still active but the Framebuffer is not refreshed/renewed.
    I've dumped some logs on the working PC and on the not working PC with network stream enabled and disabled.
    nwork_PC_Stream_off.txt includes the stats of the not working PC with disabled network stream (only HDMI output)
    nwork_PC_Stream_on.txt includes the stats of the not working PC with enabled network stream (+ HDMI output)
    work_PC_Stream...... includes stats of the working PC where the video stream doesn't stuck.
    I can't see much difference here.
    I will check your other hints next, thank you very much!
    Sebastian
  • Hello Sebastian,
    Sorry for not asking this earlier, are you able to ping to board when freeze happens?
    Also in the logs you shared, i see no stats for NULL link in both network enabled and disabled case. Also why do you have null source in the use-case?
    Can you share your use-case image file? If you are not fine with sharing on public e2e, you can send via mail a0132233@ti.com
    Thanks.
  • Hello Prasad,
    sharing the image is ok, because it is almost the default TI UC. The null source link is used by the synthesis algo. I do not know why, it is the default TI setup. Maybe the synth algo needs a dummy buffer to be able to run.
    When the video freezes, the stack still responds to the ping.
    Sebastian
  • Registers.zip
    Hello Prasad,
    I catched the registers you have mentioned. Can you see something what's going on?
    To me it seems very similar.
    Sebastian
  • Hello Sebastian,
    From the register dump, as can be seen below, somehow on non-working PC the carrier sense errors are occurring very frequently which is causing video freeze in case of UDP.
    Also because the drop due to carrier sense error is handled in TCP/IP, ping works well.
    Can you share board schematic and PHY details (phy name, data manual) etc? Again please share via mail if NDA confidential.
  • Sebastian,
    As you are using VSDK2.12, there is one known issue in the TFDTP which may cause packet drop.
    Can you please change to below in the VISION_SDK_02_12_00_00\ti_components\networking\nsp_gmacsw_4_15_00_00\packages\ti\nsp\drv\tfdtp\tfdtp.c
    - /* Invalidate TFDTP packet header as it is updated here */
    - Cache_wbInv((Ptr)&tfdtpsp->tfdtp_bhdr, sizeof(tfdtp_stream_header_t), (Bits16)Cache_Type_ALLD, (Bool)1U);
    + /* Invalidate Eth Frame Header packet header as it is updated here */
    + Cache_wb((Ptr)pPacket->pHeader, TFDTP_PACKET_HEADER_SIZE, (Bits16)Cache_Type_ALLD, (Bool)1U);
  • Yes, that is what attracted my attention, too. I have checked the cables and changed them, but no change in behavior. (I use CAT6 cables)
    I will provide you your requested information.
    I have sent you a mail already!
    Sebastian
  • I will check that issue with the VSDK2.12, thank you!
    Sebastian
  • I have patched the tfdtp.c and there is no change in the behavior. Still the same :(
  • Sebastian,
    Ok. Please keep this change as it is needed in case header memory is cached.
    If you need patch for this for tracking purpose, I can create and share it. Let me know.
    i will review the schematic. Will let you know if find anything.
    Can you please share what is pGMACSWConfig->macInitCfg[i].macConnectionType set to in GMACSW_getConfig function?
    (vsdk_latest\vision_sdk\links_fw\src\rtos\utils_common\src\ndk\ndk_nsp_hooks.c)
  • Prasad,
    I did a printout in linkStatus() and got:
    for working and not working PC
    [IPU1-1] 26.861648 s: NDK: Link Status: 1000Mb/s Full Duplex on PHY 0
    [IPU1-1] 26.861739 s: NDK: macConnectionType 0 conT: 7
    [IPU1-1] 26.861800 s: NDK: macConnectionType 1 conT: 7
    Before and after streaming (I unplugged the eth connector/cable) is the same.
  • Hello Sebastian,
    Is prints same for both working and non-working PC?
  • Can you please share what is pGMACSWConfig->macInitCfg[i].macConnectionType set to in GMACSW_getConfig function?
  • That's what I have already posted (s. obove @12:52 PM). This is the printf code:
    static void LOCAL_linkStatus( uint32_t phy, uint32_t linkStatus )
    GMACSW_Config *pgSt = GMACSW_getConfig();
    Vps_printf(" NDK: Link Status: %s on PHY %" PRIu32 "\n",LinkStr[linkStatus],phy);
    Vps_printf(" NDK: macConnectionType 0 conT: %d\n", pgSt->macInitCfg[0].macConnectionType);
    Vps_printf(" NDK: macConnectionType 1 conT: %d\n", pgSt->macInitCfg[1].macConnectionType);
    The macConnectionType for working PC and not working PC is both 7 (MAC_CONNECTION_TYPE_RGMII_DETECT_INBAND)
  • Hello Sebastian,
    Can you please try setting it to MAC_CONNECTION_TYPE_RGMII_FORCE_1000_FULL?
    Maybe PHY on non-working PC is not able to auto-negotiation.
  • Prasad,
    it works!! Yeah! :)
    I see the UDP packets in wireshark!
    I have built the AppImage in debug mode, so the framerate is to low so my player software doesn't display it. I have to verify it in realease mode. But I think that's it! :)
    I wonder why it didn't work with auto-negotiation? All the PC's network cards and the Baseboard's phy supports it.
  • Hello Sebastian,
    Interesting!
    Yes, I agree, PC network cards should work with auto-neg. Also i need to check if this is an issue on TDA side or may be PHY side. So can't say if it is PC network card issue.
    Please check if any issue in release build.
    I may not be able to spend time to debug about mac config change so as setting to FORCE mode have no issues due to closed system.
    I will update on the root cause once get time to do it.
  • It works like it should work in release Build!
    Thank you very much for your great help, Prasad !! :)
    Maybe we find out what the root cause of the problem is, then we let you know!
    Have a nice day!
    Best wishes,
    Sebastian
  • Hello Sebastian,
    Glad could help. Hope you find root cause!
