Part Number: TMDSICE3359
Other Parts Discussed in Thread: LAUNCHXL-F28379D, AM4379, TIDM-DELFINO-ETHERCAT
I successfully launched EtherCAT master project with Acontis master stack on tmdsice3359. I used that document from TI:
My simple network is TMDSICE3359 <-> LaunchXL-F28379D. And it's working. Here is log from putty:
TI Industrial SDK Version - IASDK 1.1.0.8 Device name : AM3359 Chip Revision : AM335x ES1.2 [PG2.1] SYS/BIOS EcMaster Sample application running on ICE V2 Full command line: -auxclk 2000 -v 2 -t 100000 -perf -cpsw 1 1 1 m custom am33XX 1 1 0 001151 : Run demo now with cycle time 2000 usec 001151 : Using AuxClock 001151 : ========================== 001151 : Initialize EtherCAT Master 001151 : ========================== 001151 : EC-Master V2.9.0.06 (Protected) for SYSBIOS Copyright acontis technologies GmbH @ 2016 001152 : CPSW INF: Port 1, Prio 1, Flags [Polling] [Master], Phy 1, PhyInterface 32, MAC 38:d2:69:5f:69:49 001153 : CPSW INF: CPSW3G found. CPSW INF: HW-Id: 0x0019, RTL: 0, Major: 1, Minor: 0xc 001154 : CPSW INF: PHY found. Id=0x2000a211 001154 : CPSW INF: Restart PHY auto negotiation 002814 : CPSW INF: PHY auto negotiation completed 002832 : Unlicensed version, stop sending ethernet frames after 60 minutes! 002908 : Bus scan successful - 1 slaves found 002947 : 1 identical messages skipped 002947 : ****************************************************************************** 002947 : Slave ID............: 0x00000000 002947 : Bus Index...........: 0 002947 : Bus AutoInc Address.: 0x0000 002947 : Bus Station Address.: 0x03e9 (1001) 002947 : Bus Alias Address...: 0x0000 ( 0) 002947 : Vendor ID...........: 0x000A4D7A = ---- 002947 : Product Code........: 0x10001101 = Unknown 002947 : Revision............: 0x00000001 Serial Number: 0 002947 : ESC Type............: Beckhoff ET1100 (0x11) Revision: 0 Build: 3 002947 : Connection at Port A: yes (to 0x00010000) 002947 : Connection at Port D: no (to 0xFFFFFFFF) 002947 : Connection at Port B: no (to 0xFFFFFFFF) 002947 : Connection at Port C: no (to 0xFFFFFFFF) 002947 : Line Crossed........: no 002947 : Cfg Station Address.: 0x03e9 (1001) 002947 : PD IN Byte.Bit offset: 0.0 Size: 88 bits 002947 : PD OUT Byte.Bit offset: 0.0 Size: 88 bits 003066 : EtherCAT network adapter MAC: 38-D2-69-5F-69-49 003066 : ===================== 003066 : Start EtherCAT Master 003066 : ===================== 003073 : Master state changed from <UNKNOWN> to <INIT> 003218 : Master state changed from <INIT> to <PREOP> 003242 : Master state changed from <PREOP> to <SAFEOP> 003258 : Master state changed from <SAFEOP> to <OP> 003263 : 003263 : Job times during startup <INIT> to <OP>: 003263 : ================================================================ 003263 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 13.0/ 39.9 003263 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 6.0/ 14.8 003263 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 7.1/ 72.0 003263 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 3.6/ 27.7 003263 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1657.2/2009.1 003263 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.7/ 4.3 003263 : 005267 : ================================================================ 005267 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 19.2 005267 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 14.2 005267 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 5.9/ 11.1 005267 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 6.4 005267 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.2 005267 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 1.3 007269 : ================================================================ 007269 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 007269 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 14.2 007269 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 11.1 007269 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.0 007269 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.2 007269 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 1.3 009271 : ================================================================ 009271 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 009271 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 14.5 009271 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 11.1 009271 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.0 009271 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.8 009271 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 1.3 011273 : ================================================================ 011273 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 011273 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 14.5 011273 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 11.3 011273 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.0 011273 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.8 011273 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 013275 : ================================================================ 013275 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 013275 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 14.5 013275 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 5.9/ 11.8 013275 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.0 013275 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.8 013275 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 015277 : ================================================================ 015277 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 015277 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 14.7 015277 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 11.8 015277 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.0 015277 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.9 015277 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 017279 : ================================================================ 017279 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 017279 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 14.7 017279 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 11.8 017279 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.0 017279 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.9 017279 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 019281 : ================================================================ 019281 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 019281 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 14.7 019281 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 019281 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.0 019281 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.9 019281 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 021283 : ================================================================ 021283 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.6/ 21.4 021283 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 14.7 021283 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 021283 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.0 021283 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.9 021283 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 023285 : ================================================================ 023285 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.6/ 21.4 023285 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 14.7 023285 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 023285 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 023285 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.9 023285 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 025287 : ================================================================ 025287 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 025287 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 14.7 025287 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 025287 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 025287 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.9 025287 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 027289 : ================================================================ 027289 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 027289 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 14.7 027289 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 027289 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 027289 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.9 027289 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 029291 : ================================================================ 029291 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 029291 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 14.7 029291 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 029291 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 029291 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.9 029291 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 031293 : ================================================================ 031293 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 031293 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 14.7 031293 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 031293 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 031293 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.9 031293 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 033295 : ================================================================ 033295 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 033295 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 14.7 033295 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 033295 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 033295 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.9 033295 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 035297 : ================================================================ 035297 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 035297 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 14.7 035297 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 035297 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 035297 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.9 035297 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 037299 : ================================================================ 037299 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.6/ 21.4 037299 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 14.7 037299 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 037299 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 037299 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.9 037299 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 039301 : ================================================================ 039301 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 039301 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 14.7 039301 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 039301 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 039301 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.9 039301 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 041303 : ================================================================ 041303 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 041303 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 14.7 041303 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 041303 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 041303 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.9 041303 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 043305 : ================================================================ 043305 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 043305 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 14.7 043305 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 043305 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 043305 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.9 043305 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 045307 : ================================================================ 045307 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 045307 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 14.7 045307 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 5.9/ 12.2 045307 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 045307 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2003.9 045307 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 047309 : ================================================================ 047309 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 047309 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 14.7 047309 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 047309 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 047309 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 047309 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 049311 : ================================================================ 049311 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 049311 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 14.7 049311 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 049311 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 049311 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 049311 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 051313 : ================================================================ 051313 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 051313 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 14.7 051313 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 051313 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 051313 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 051313 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 053315 : ================================================================ 053315 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 053315 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 14.7 053315 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 053315 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 053315 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 053315 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 055317 : ================================================================ 055317 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 055317 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 14.7 055317 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 5.9/ 12.2 055317 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 055317 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 055317 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 057319 : ================================================================ 057319 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 057319 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 15.1 057319 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 5.9/ 12.2 057319 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 057319 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 057319 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 059321 : ================================================================ 059321 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 059321 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 15.1 059321 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 059321 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 059321 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 059321 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 061323 : ================================================================ 061323 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 061323 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 15.1 061323 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 061323 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 061323 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 061323 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 063325 : ================================================================ 063325 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 063325 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 15.1 063325 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 063325 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.2/ 7.3 063325 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 063325 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 065327 : ================================================================ 065327 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 065327 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 15.1 065327 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 065327 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.2/ 7.3 065327 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 065327 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 067329 : ================================================================ 067329 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.6/ 21.4 067329 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 15.1 067329 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 067329 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 067329 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 067329 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 069331 : ================================================================ 069331 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 069331 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 15.1 069331 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 069331 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 069331 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 069331 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 071333 : ================================================================ 071333 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 071333 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 15.1 071333 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 071333 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 071333 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 071333 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 073335 : ================================================================ 073335 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 073335 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 15.1 073335 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 073335 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 073335 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 073335 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 075337 : ================================================================ 075337 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.6/ 21.4 075337 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 15.1 075337 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 075337 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 075337 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 075337 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 077339 : ================================================================ 077339 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 077339 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 15.1 077339 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 077339 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 077339 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 077339 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 079341 : ================================================================ 079341 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 079341 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 15.1 079341 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 079341 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 079341 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 079341 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 081343 : ================================================================ 081343 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.6/ 21.4 081343 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 15.1 081343 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 081343 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 081343 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 081343 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 083345 : ================================================================ 083345 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.6/ 21.4 083345 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 15.1 083345 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 083345 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.2/ 7.3 083345 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 083345 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 085347 : ================================================================ 085347 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.6/ 21.4 085347 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 15.1 085347 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 085347 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.2/ 7.3 085347 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 085347 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 087349 : ================================================================ 087349 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 087349 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 15.1 087349 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 087349 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 087349 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 087349 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 089351 : ================================================================ 089351 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 089351 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 15.1 089351 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 089351 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 089351 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 089351 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 091353 : ================================================================ 091353 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 091353 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 15.1 091353 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 091353 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 091353 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 091353 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 093355 : ================================================================ 093355 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 093355 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 15.1 093355 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 093355 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 093355 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 093355 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 095357 : ================================================================ 095357 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 095357 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 15.1 095357 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 095357 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 095357 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 095357 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 097359 : ================================================================ 097359 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 097359 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 15.1 097359 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 097359 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 097359 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 097359 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 099361 : ================================================================ 099361 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 099361 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.1/ 15.1 099361 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 099361 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.3/ 7.3 099361 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 099361 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 101363 : ================================================================ 101363 : PerfMsmt 'JOB_ProcessAllRxFrames' (avg/max) [usec]: 14.5/ 21.4 101363 : PerfMsmt 'JOB_SendAllCycFrames ' (avg/max) [usec]: 9.0/ 15.1 101363 : PerfMsmt 'JOB_MasterTimer ' (avg/max) [usec]: 6.0/ 12.2 101363 : PerfMsmt 'JOB_SendAcycFrames ' (avg/max) [usec]: 1.2/ 7.3 101363 : PerfMsmt 'Cycle Time ' (avg/max) [usec]: 1999.4/2004.0 101363 : PerfMsmt 'myAppWorkPd ' (avg/max) [usec]: 0.8/ 5.7 103265 : 103265 : Job times before shutdown 103265 : ======================== 103265 : Shutdown EtherCAT Master 103265 : ======================== 103286 : Master state changed from <OP> to <INIT> 103553 : CPSW INF: Disable running RX-DMA 103553 : CPSW INF: RX+TX DMA disabled. Delay 500 103554 : EcMasterDemo stop.
We can see times in log:
And here is my question - Cycle Time is quite long, it's about 2 msec. I would like to decrease it to e.g. 100us. What changes should I make to change cycle time?
I appreciate any help.
BR,
Dawid.
