RTOS: Vision SDK Blank screen ( UC: M4-Display Server + camera )
Tool/software: TI-RTOS
Hi all,
We are using Vision_SDK3dot1 version . We have the below usecase with display-server & camera.
UseCase: weston_m4camera
Capture -> Display_Video
//Capture -> Display_Video
//GrpxSrc -> Display_Grpx
DefLink_dispDist (A15) -> Display_Gfx
While booting xem4 image, there is sometimes  we find the following error ( from /sys/kernel/debug/remoteproc/remoteproc0/trace0).  At this time, we see the blank screen in the display.
9.037] [t=0x0acf6dbc] ti.ipc.family.vayu.VirtQueue: VirtQueue_kick: Sending interrupt to proc 0 with payload 0x0
[0][ 9.040]
[0][ 9.040] 24.131977 s: SYSTEM: ERROR: No link registered at link ID [84] !!!
[0][ 9.041]
How to  print all links with  link-id numbers ?
Gokul
root@mmt2020-a880:~# cat /sys/kernel/debug/remoteproc/remoteproc0/trace0
[0][      0.000] 18 Resource entries at 0x3000
[0][      0.000]     15.091685 s:  SYSTEM: System Common Init in progress !!!
[0][      0.010]     15.101415 s:  SYSTEM: IPC init in progress !!!
[0][      0.010]     15.101689 s:  SYSTEM: Notify init done !!!
[0][      0.012]     15.103550 s:  SYSTEM: MsgQ init done !!!
[0][      0.013]     15.104617 s: RpmsgInit in progress...
[0][      0.014]     15.104861 s: Connection established with HLOS, calling rpmsgInit
[0][      0.014] [t=0x000db469] ti.ipc.family.vayu.VirtQueue: vring: 0 0x60000000 (0x3000)
[0][      0.014]
[0][      0.014] [t=0x000dcd0e] ti.ipc.family.vayu.VirtQueue: vring: 1 0x60004000 (0x3000)
[0][      0.014]
[0][      0.015] [t=0x000de112] ti.ipc.family.vayu.VirtQueue: VirtQueue_startup: VDEV status: 0x7
[0][      0.015]
[0][      0.015] [t=0x000df7c8] ti.ipc.family.vayu.VirtQueue: VirtQueue_startup: Polling VDEV status...
[0][      0.015]
[0][      0.015] [t=0x000e0cf8] ti.ipc.family.vayu.VirtQueue: VirtQueue_startup: VDEV status: 0x7
[0][      0.015]
[0][      0.015] [t=0x000e28b5] ti.ipc.family.vayu.VirtQueue: VirtQueue_isr received msg = 0x0
[0][      0.015]
[0][      0.015] [t=0x000e3d9d] ti.ipc.rpmsg.RPMessage: callback_availBufReady: virtQueue_toHost kicked
[0][      0.016] [t=0x000e5336] ti.ipc.family.vayu.VirtQueue: Passed VirtQueue_startup
[0][      0.016]
[0][      0.016] [t=0x000e68b7] ti.ipc.rpmsg.RPMessage: RPMessage_create: endPt created: 80
[0][      0.016] registering rpmsg-proto:rpmsg-proto service on 80 with HOST
[0][      0.017] [t=0x000e8765] xdc.runtime.Main: NameMap_sendMessage: HOST 53, port=80
[0][      0.017] [t=0x000e9b18] ti.ipc.family.vayu.VirtQueue: getAvailBuf vq: 0x9ec51d00 0 256 256 0x9ec51d10 0x60001000
[0][      0.017]
[0][      0.017] [t=0x000eb768] ti.ipc.family.vayu.VirtQueue: VirtQueue_kick: Sending interrupt to proc 0 with payload 0x0
[0][      0.017]
[0][      0.018]     15.108979 s:  SYSTEM: IPC init DONE !!!
[0][      0.025]     15.116116 s:  SYSTEM: System Common Init Done !!!
[0][      0.025]     15.116391 s:  SYSTEM: System Init in progress !!!
[0][      0.025]     15.116604 s:  SYSTEM: BSP Common Init in progress !!!
[0][      0.025]     15.116818 s:  SYSTEM: BSP Common Init Done !!!
[0][      0.026]     15.117062 s:  SYSTEM: BSP Platform Init in progress !!!
[0][      0.026]     15.117306 s:  SYSTEM: BSP Platform Init Done !!!
[0][      0.026]     15.117519 s:  SYSTEM: FVID2 Init in progress !!!
[0][      0.026]     15.117824 s:  SYSTEM: FVID2 Init Done !!!
[0][      0.027]     15.118068 s:  SYSTEM: VPS Init in progress !!!
[0][      0.027]     15.118282 s:  SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0x80000000 -> 0x80000000]
[0][      0.030]     15.121667 s: *** VPDMA Firmware Loading... ***
[0][      0.031]     15.121972 s: VPDMA Firmware Address = 0xa035ba40
[0][      0.031]     15.122247 s: VPDMA Load Address     = 0x4897d004
[0][      0.031]     15.122491 s: VPDMA Firmware Version = 0x4d0001b8
[0][      0.031]     15.122735 s: VPDMA List Busy Status = 0x00000000
[0][      0.032]     15.122979 s: *** VPDMA Firmware Load Success ***
[0][      0.032]
[0][      0.032]     15.123497 s: *** VPDMA Firmware Loading... ***
[0][      0.032]     15.123772 s: VPDMA Firmware Address = 0xa035ba40
[0][      0.033]     15.123985 s: VPDMA Load Address     = 0x4899d004
[0][      0.033]     15.124290 s: VPDMA Firmware Version = 0x4d0001b8
[0][      0.033]     15.124504 s: VPDMA List Busy Status = 0x00000000
[0][      0.033]     15.124748 s: *** VPDMA Firmware Load Success ***
[0][      0.033]
[0][      0.034]     15.125266 s: *** VPDMA Firmware Loading... ***
[0][      0.034]     15.125510 s: VPDMA Firmware Address = 0xa035ba40
[0][      0.034]     15.125754 s: VPDMA Load Address     = 0x489bd004
[0][      0.035]     15.125998 s: VPDMA Firmware Version = 0x4d0001b8
[0][      0.035]     15.126273 s: VPDMA List Busy Status = 0x00000000
[0][      0.035]     15.126517 s: *** VPDMA Firmware Load Success ***
[0][      0.035]
[0][      0.036]     15.127066 s: *** VPDMA Firmware Loading... ***
[0][      0.036]     15.127310 s: VPDMA Firmware Address = 0xa035ba40
[0][      0.036]     15.127523 s: VPDMA Load Address     = 0x489dd004
[0][      0.036]     15.127798 s: VPDMA Firmware Version = 0x4d0001b8
[0][      0.037]     15.128042 s: VPDMA List Busy Status = 0x00000000
[0][      0.037]     15.128286 s: *** VPDMA Firmware Load Success ***
[0][      0.037]
[0][      0.093]     15.184285 s:  SYSTEM: VPS Init Done !!!
[0][      0.095]     15.186177 s:  UTILS: DMA: HWI Create for INT34 !!!
[0][      0.095]     15.186604 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[0][      0.096]     15.186909 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 260664 B (254 KB)
[0][      0.096]     15.187427 s:  SYSTEM: Heap = SR_OCMC              @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[0][      0.097]     15.187885 s:  SYSTEM: Heap = SR_DDR_CACHED        @ 0x84203000, Total size = 16777216 B (16 MB), Free size = 16777216 B (16 MB)
[0][      0.097]     15.188434 s:  SYSTEM: Heap = SR_DDR_NON_CACHED    @ 0xa0100000, Total size = 1047168 B (0 MB), Free size = 1047168 B (0 MB)
[0][      0.098]     15.188922 s:  SYSTEM: Initializing Links !!!
[0][      0.371]     15.462209 s:  SYSTEM: Initializing Links ... DONE !!!
[0][      0.371]     15.462514 s:  BOARD: Board Init in progress !!!
[0][      0.372]     15.463155 s:  BOARD: Board Init Done !!!
[0][      0.379]     15.470841 s:
[0][      0.380]     15.470993 s:  CHAINS: Sensor create in progress
[0][      0.380]     15.471237 s:  VIDEO_DECODER: ********** CREATE **********
[0][      0.390]     15.481058 s:  gpiopin power on : [10]
[0][      0.390]     15.481241 s: gpiopin power on : [1]
[0][      0.390]     15.481424 s:  gpiopin reset : [40000]
[0][      0.390]     15.481608 s:  gpiopin reset : [1]
[0][      5.495]
[0][      5.495]  i2cMdSubmitChan: i2c transfer Timeout IRQ not received
[0][      5.496]     20.587323 s: src/bsp_deviceI2c.c @ Line 580:     20.587537 s:  I2C1: DEV 0x20: WR 0x0f = 0x80 ... ERROR !!!
[0][      5.497]     20.587842 s: src/bsp_deviceI2c.c @ Line 602:     20.588025 s:  I2C1: Error timeout 5002 ms!!!
[0][      5.497]     20.588299 s: I2C write failed
[0][      5.507]     20.598334 s: I2C write Passed
[0][      5.512]     20.603428 s: read PASSfor Address 0x10, REG VALUE IS 0x4a
[0][      5.512]     20.603946 s: read PASSfor Address 0x12, REG VALUE IS 0x0
[0][      5.513]     20.604465 s: read PASSfor Address 0x13, REG VALUE IS 0x2c
[0][      5.513]     20.604953 s: read PASSfor Address 0xc, REG VALUE IS 0x36
[0][      5.514]     20.605380 s: I2C write Passed
[0][      5.514]     20.605776 s: read PASSfor Address 0x14, REG VALUE IS 0x11
[0][      5.515]     20.606203 s: I2C write Passed
[0][      5.515]     20.606508 s: I2C write Passed
[0][      5.515]     20.606844 s: I2C write Passed
[0][      5.516]     20.607149 s: I2C write Passed
[0][      5.516]     20.607484 s: I2C write Passed
[0][      5.516]     20.607881 s: read PASSfor Address 0x1d, REG VALUE IS 0x40
[0][      5.517]     20.608308 s: I2C write Passed
[0][      5.517]     20.608704 s: read PASSfor Address 0xf4, REG VALUE IS 0x4
[0][      5.518]     20.609101 s: I2C write Passed
[0][      5.518]     20.609528 s: read PASSfor Address 0x18, REG VALUE IS 0x93
[0][      5.518]     20.609955 s: I2C write Passed
[0][      5.519]     20.610321 s: read PASSfor Address 0x19, REG VALUE IS 0xf1
[0][      5.519]     20.610748 s: I2C write Passed
[0][      5.520]     20.611145 s: read PASSfor Address 0x2d, REG VALUE IS 0xf2
[0][      5.530]     20.621179 s:  adv2 gpiopin power on : [2]
[0][      5.530]     20.621393 s: adv2 gpiopin power on : [1]
[0][      5.530]     20.621606 s:  adv2 gpiopin reset : [10000000]
[0][      5.530]     20.621789 s: Adv2  gpiopin reset : [0]
[0][      5.635]     20.726194 s:  do probe
[0][      5.645]      20.736442 s: I2C1: Passed for address 0xc !!!
[0][      9.034] [t=0x0ace964f] ti.ipc.family.vayu.VirtQueue: VirtQueue_isr received msg = 0x1
[0][      9.034]
[0][      9.034] [t=0x0acead05] ti.ipc.rpmsg.RPMessage: callback_availBufReady: virtQueue_fromHost kicked
[0][      9.035] [t=0x0acec2f2] ti.ipc.family.vayu.VirtQueue: getAvailBuf vq: 0x9ec51d40 0 1 256 0x9ec51d50 0x60005000
[0][      9.035]
[0][      9.036] [t=0x0acede9d] ti.ipc.rpmsg.RPMessage: RPMessage_swiFxn: Received msg from: 0x400, to: 0x50, dataLen: 4
[0][      9.036] [t=0x0acef61f] ti.ipc.rpmsg.RPMessage: RPMessage_send: calling callback with data len: 4, from: 1024
[0][      9.036] [t=0x0acf0d5f] ti.ipc.family.vayu.VirtQueue: getAvailBuf vq: 0x9ec51d40 1 1 256 0x9ec51d50 0x60005000
[0][      9.036]
[0][      9.037] [t=0x0acf2874] ti.ipc.family.vayu.VirtQueue: VirtQueue_kick: no kick because of VRING_AVAIL_F_NO_INTERRUPT
[0][      9.037]
[0][      9.037] [t=0x0acf4fd7] ti.ipc.family.vayu.VirtQueue: getAvailBuf vq: 0x9ec51d00 1 257 256 0x9ec51d10 0x60001000
[0][      9.037]
[0][      9.037] [t=0x0acf6dbc] ti.ipc.family.vayu.VirtQueue: VirtQueue_kick: Sending interrupt to proc 0 with payload 0x0
[0][      9.037]
[0][      9.038] [t=0x0acfaeba] ti.ipc.family.vayu.VirtQueue: VirtQueue_isr received msg = 0x1
[0][      9.038]
[0][      9.038] [t=0x0acfc35a] ti.ipc.rpmsg.RPMessage: callback_availBufReady: virtQueue_fromHost kicked
[0][      9.039] [t=0x0acfd8c6] ti.ipc.family.vayu.VirtQueue: getAvailBuf vq: 0x9ec51d40 1 2 256 0x9ec51d50 0x60005000
[0][      9.039]
[0][      9.039] [t=0x0acff453] ti.ipc.rpmsg.RPMessage: RPMessage_swiFxn: Received msg from: 0x400, to: 0x50, dataLen: 4
[0][      9.039] [t=0x0ad00afd] ti.ipc.rpmsg.RPMessage: RPMessage_send: calling callback with data len: 4, from: 1024
[0][      9.039] [t=0x0ad0218c] ti.ipc.family.vayu.VirtQueue: getAvailBuf vq: 0x9ec51d40 2 2 256 0x9ec51d50 0x60005000
[0][      9.039]
[0][      9.040] [t=0x0ad03d4c] ti.ipc.family.vayu.VirtQueue: VirtQueue_kick: no kick because of VRING_AVAIL_F_NO_INTERRUPT
[0][      9.040]
[0][      9.041] [t=0x0ad074c6] ti.ipc.family.vayu.VirtQueue: getAvailBuf vq: 0x9ec51d00 2 258 256 0x9ec51d10 0x60001000
[0][      9.041]
[0][      9.041] [t=0x0ad09206] ti.ipc.family.vayu.VirtQueue: VirtQueue_kick: Sending interrupt to proc 0 with payload 0x0
[0][      9.041]
[0][     10.741]
[0][     10.741]  i2cMdSubmitChan: i2c transfer Timeout IRQ not received
[0][     10.742]     25.833496 s: src/bsp_deviceI2c.c @ Line 580:     25.833709 s:  I2C1: DEV 0x21: WR 0x0f = 0x80 ... ERROR !!!
[0][     10.743]     25.834014 s: src/bsp_deviceI2c.c @ Line 602:     25.834167 s:  I2C1: Error timeout 5001 ms!!!
[0][     10.743]     25.834441 s: I2C write failed
[0][     10.753]     25.844476 s: I2C write Passed
[0][     10.758]     25.849325 s: Adv2 do read
[0][     10.758]      25.849722 s: read PASSfor Address 0x10, REG VALUE IS 0x4a
[0][     10.758]     25.849996 s: Adv2 do read
[0][     10.759]      25.850362 s: read PASSfor Address 0x12, REG VALUE IS 0x0
[0][     10.759]     25.850637 s: Adv2 do read
[0][     10.759]      25.851003 s: read PASSfor Address 0x13, REG VALUE IS 0x2c
[0][     10.760]     25.851277 s: Adv2 do read
[0][     10.760]      25.851674 s: read PASSfor Address 0xc, REG VALUE IS 0x36
[0][     10.760]     25.852071 s: I2C write Passed
[0][     10.761]     25.852467 s: read PASSfor Address 0x14, REG VALUE IS 0x11
[0][     10.761]     25.852894 s: I2C write Passed
[0][     10.762]     25.853199 s: I2C write Passed
[0][     10.762]     25.853565 s: I2C write Passed
[0][     10.762]     25.853870 s: I2C write Passed
[0][     10.762]     25.854175 s: I2C write Passed
[0][     10.763]     25.854602 s: read PASSfor Address 0x1d, REG VALUE IS 0x40
[0][     10.763]     25.855029 s: I2C write Passed
[0][     10.764]     25.855426 s: read PASSfor Address 0xf4, REG VALUE IS 0x4
[0][     10.764]     25.855853 s: I2C write Passed
[0][     10.765]     25.856249 s: read PASSfor Address 0x18, REG VALUE IS 0x93
[0][     10.765]     25.856676 s: I2C write Passed
[0][     10.765]     25.857073 s: read PASSfor Address 0x19, REG VALUE IS 0xf1
[0][     10.766]     25.857530 s: I2C write Passed
[0][     10.766]     25.857896 s: read PASSfor Address 0x2d, REG VALUE IS 0xf2
[0][     10.767]     25.858415 s: read PASSfor Address 0x0, REG VALUE IS 0x18
[0][     10.767]     25.858811 s: I2C write Passed
[0][     10.817]     25.908497 s: I2C write Passed
[0][     10.818]     25.909504 s: I2C write Passed
[0][     10.819]     25.910480 s: I2C write Passed
[0][     10.820]     25.911578 s: read PASSfor Address 0xc, REG VALUE IS 0x1
[0][     10.831]     25.922436 s: I2C1: Passed for address 0xc !!!
[0][     10.865]     25.957024 s: I2C1: Passed for address 0x35 !!!
[0][     10.928]     26.019490 s: read PASSfor Address 0x0, REG VALUE IS 0x6a
[0][     10.929]     26.020496 s: I2C write Passed
[0][     10.979]     26.070487 s: I2C write Passed
[0][     10.980]     26.071493 s: I2C write Passed
[0][     10.981]     26.072500 s: I2C write Passed
[0][     10.986]     26.077563 s: read PASSfor Address 0x1c, REG VALUE IS 0x3
[0][     10.989]     26.080583 s: read PASSfor Address 0x22, REG VALUE IS 0x4a
[0][     10.990]     26.081559 s: read PASSfor Address 0xc, REG VALUE IS 0x3
[0][     10.991]     26.082352 s:  CHAINS: Sensor create ... DONE !!!
