Tool/software: TI-RTOS
Hello ,
I have algorithm link for DSP performing sobel 3x3 edge detection.
This works fine in case of edges.
But output on display screen is getting trapped after 1 or 2 seconds,
I thought there will be a frame drop because of processing time. So i increased no.of output frames. still the issue is same.
Why this is happening??
Attached statics for the reference.
[IPU1-0] 36.281949 s: [IPU1-0] 36.286921 s: CAPTURE: Create in progress !!! [IPU1-0] 36.287134 s: CAPTURE: VIP1 Slice0 PortA capture mode is [16-bit] !!! [IPU1-0] 36.473830 s: CAPTURE: Create Done !!! [IPU1-0] 36.474196 s: IPC_OUT_0 : Create in progress !!! [IPU1-0] 36.474562 s: IPC_OUT_0 : Create Done !!! [DSP1 ] 36.474775 s: IPC_IN_0 : Create in progress !!! [DSP1 ] 36.475233 s: IPC_IN_0 : Create Done !!! [DSP1 ] 36.475416 s: ALGORITHM: Create in progress (algId = 44) !!! [IPU1-0] 36.850545 s: IPC_IN_0 : Create in progress !!! [IPU1-0] 36.851582 s: IPC_IN_0 : Create Done !!! [IPU1-0] 36.851735 s: DISPLAY: Create in progress !!! [IPU1-0] 36.852284 s: DISPLAY: Create Done !!! [IPU1-0] 36.852437 s: GRPXSRC: Create in progress !!! [IPU1-0] 38.401329 s: GRPXSRC: Create Done !!! [IPU1-0] 38.401726 s: DISPLAY: Create in progress !!! [IPU1-0] 38.402183 s: DISPLAY: Create Done !!! [IPU1-0] 38.402397 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022 [IPU1-0] 38.402549 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 250744 B (244 KB) [IPU1-0] 38.402732 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB) [IPU1-0] 38.402885 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x89d03000, Total size = 368037888 B (350 MB), Free size = 268505088 B (256 MB) [IPU1-0] 38.403068 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xbfc00000, Total size = 129152 B (0 MB), Free size = 117632 B (0 MB) [IPU1-0] 38.407582 s: CHAINS: Sensor create in progress !!! [IPU1-0] 38.409504 s: *** UTILS: CPU KHz = 20000 Khz *** [IPU1-0] 38.497590 s: CHAINS: Sensor create ... DONE !!! [IPU1-0] 38.497712 s: DISPLAY: Start in progress !!! [IPU1-0] 38.497773 s: DISPLAY: Start Done !!! [IPU1-0] 38.499694 s: DISPLAY: Start in progress !!! [IPU1-0] 38.499755 s: DISPLAY: Start Done !!! [IPU1-0] 38.500213 s: CAPTURE: Start in progress !!! [IPU1-0] 38.501708 s: CAPTURE: Start Done !!! [IPU1-0] 38.502806 s: [IPU1-0] [IPU1-0] ==================== [IPU1-0] Chains Run-time Menu [IPU1-0] ==================== [IPU1-0] [IPU1-0] 0: Stop Chain [IPU1-0] [IPU1-0] 2: Pause Capture [IPU1-0] 3: Resume Capture [IPU1-0] [IPU1-0] p: Print Performance Statistics [IPU1-0] [IPU1-0] Enter Choice: [IPU1-0] [IPU1-0] 38.503111 s: [IPU1-0] Unsupported option ' [IPU1-0] '. Please try again [IPU1-0] 38.503172 s: [IPU1-0] [IPU1-0] ==================== [IPU1-0] Chains Run-time Menu [IPU1-0] ==================== [IPU1-0] [IPU1-0] 0: Stop Chain [IPU1-0] [IPU1-0] 2: Pause Capture [IPU1-0] 3: Resume Capture [IPU1-0] [IPU1-0] p: Print Performance Statistics [IPU1-0] [IPU1-0] Enter Choice: [IPU1-0] [IPU1-1] 38.403922 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [IPU1-1] 38.404044 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 655360 B (640 KB), Free size = 624024 B (609 KB) [HOST ] 38.404501 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [HOST ] 38.404501 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 6291456 B (6144 KB), Free size = 6279992 B (6132 KB) [DSP1 ] 36.850149 s: ALGORITHM: Create Done (algId = 44) !!! [DSP1 ] 36.850332 s: IPC_OUT_0 : Create in progress !!! [DSP1 ] 36.850423 s: IPC_OUT_0 : Create Done !!! [DSP1 ] 38.404715 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [DSP1 ] 38.404776 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB) [DSP1 ] 38.404806 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 503640 B (491 KB) [DSP2 ] 38.405050 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [DSP2 ] 38.405111 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB) [DSP2 ] 38.405142 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 518328 B (506 KB) [EVE1 ] 38.406057 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [EVE1 ] 38.406362 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [EVE1 ] 38.406911 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 256200 B (250 KB) [IPU1-0] 54.257853 s: [IPU1-0] 54.257914 s: CPU [IPU1-0 ] Statistics, [IPU1-0] 54.257975 s: ************************* [IPU1-0] 54.258036 s: [IPU1-0] 54.258097 s: LOAD: CPU: 7.4% HWI: 1.8%, SWI:0.5%, Low Power: 88.5% [IPU1-0] 54.258250 s: [IPU1-0] 54.258311 s: LOAD: TSK: IPC_OUT_0 : 0.2% [IPU1-0] 54.258433 s: LOAD: TSK: DISPLAY0 : 0.1% [IPU1-0] 54.258524 s: LOAD: TSK: CAPTURE : 0.2% [IPU1-0] 54.258646 s: LOAD: TSK: GrpxSrc0 : 0.5% [IPU1-0] 54.258738 s: LOAD: TSK: STAT_COLL : 2.8% [IPU1-0] 54.259043 s: LOAD: TSK: MISC : 1.3% [IPU1-0] 54.259134 s: [IPU1-0] 54.259165 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [IPU1-0] 54.259256 s: [IPU1-0] 54.259287 s: SYSTEM: Sempahores Objects, 157 of 1000 free [IPU1-0] 54.259379 s: SYSTEM: Task Objects , 20 of 100 free [IPU1-0] 54.259470 s: SYSTEM: Clock Objects , 97 of 100 free [IPU1-0] 54.259562 s: SYSTEM: Hwi Objects , 89 of 100 free [IPU1-0] 54.259623 s: [IPU1-0] 54.259684 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 250744 B (244 KB) [IPU1-0] 54.259867 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB) [IPU1-0] 54.260019 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x89d03000, Total size = 368037888 B (350 MB), Free size = 268505088 B (256 MB) [IPU1-0] 54.260202 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xbfc00000, Total size = 129152 B (0 MB), Free size = 117632 B (0 MB) [IPU1-0] 54.260355 s: [IPU1-0] 54.260416 s: [IPU1-0] 54.260446 s: CPU [IPU1-1 ] Statistics, [IPU1-0] 54.260599 s: ************************* [IPU1-0] 54.260660 s: [IPU1-0] 54.260721 s: LOAD: CPU: 2.2% HWI: 0.5%, SWI:0.3%, Low Power: 88.4% [IPU1-0] 54.260873 s: [IPU1-0] 54.260995 s: LOAD: TSK: MISC : 1.4% [IPU1-0] 54.261087 s: [IPU1-0] 54.261117 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [IPU1-0] 54.261209 s: [IPU1-0] 54.261239 s: SYSTEM: Sempahores Objects, 407 of 1000 free [IPU1-0] 54.261331 s: SYSTEM: Task Objects , 39 of 100 free [IPU1-0] 54.261422 s: SYSTEM: Clock Objects , 99 of 100 free [IPU1-0] 54.261514 s: SYSTEM: Hwi Objects , 99 of 100 free [IPU1-0] 54.261575 s: [IPU1-0] 54.261636 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 655360 B (640 KB), Free size = 624024 B (609 KB) [IPU1-0] 54.261788 s: [IPU1-0] 54.261849 s: [IPU1-0] 54.261880 s: CPU [HOST ] Statistics, [IPU1-0] 54.261941 s: ************************* [IPU1-0] 54.262002 s: [IPU1-0] 54.262063 s: LOAD: CPU: 0.3% HWI: 0.1%, SWI:0.0%, Low Power: 98.6% [IPU1-0] 54.262215 s: [IPU1-0] 54.262276 s: LOAD: TSK: MISC : 0.2% [IPU1-0] 54.262368 s: [IPU1-0] 54.262398 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [IPU1-0] 54.262490 s: [IPU1-0] 54.262520 s: SYSTEM: Sempahores Objects, 408 of 1000 free [IPU1-0] 54.262612 s: SYSTEM: Task Objects , 41 of 100 free [IPU1-0] 54.262703 s: SYSTEM: Clock Objects , 99 of 100 free [IPU1-0] 54.262795 s: SYSTEM: Hwi Objects , 99 of 100 free [IPU1-0] 54.262886 s: [IPU1-0] 54.262947 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 6291456 B (6144 KB), Free size = 6279992 B (6132 KB) [IPU1-0] 54.263100 s: [IPU1-0] 54.263130 s: [IPU1-0] 54.263191 s: CPU [DSP1 ] Statistics, [IPU1-0] 54.263252 s: ************************* [IPU1-0] 54.263313 s: CPU: DSP1: Unable to get CPU statistics !!! [IPU1-0] 54.263374 s: [IPU1-0] 54.263405 s: [IPU1-0] 54.263435 s: [IPU1-0] 54.263496 s: CPU [DSP2 ] Statistics, [IPU1-0] 54.263557 s: ************************* [IPU1-0] 54.263618 s: [IPU1-0] 54.263649 s: LOAD: CPU: 0.3% HWI: 0.1%, SWI:0.1%, Low Power: 98.2% [IPU1-0] 54.263801 s: [IPU1-0] 54.264015 s: LOAD: TSK: MISC : 0.1% [IPU1-0] 54.264106 s: [IPU1-0] 54.264167 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [IPU1-0] 54.264228 s: [IPU1-0] 54.264289 s: SYSTEM: Sempahores Objects, 411 of 1000 free [IPU1-0] 54.264381 s: SYSTEM: Task Objects , 92 of 100 free [IPU1-0] 54.264442 s: SYSTEM: Clock Objects , 99 of 100 free [IPU1-0] 54.264533 s: SYSTEM: Hwi Objects , 100 of 100 free [IPU1-0] 54.264625 s: [IPU1-0] 54.264655 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB) [IPU1-0] 54.264869 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 518328 B (506 KB) [IPU1-0] 54.265021 s: [IPU1-0] 54.265082 s: [IPU1-0] 54.265113 s: CPU [EVE1 ] Statistics, [IPU1-0] 54.265174 s: ************************* [IPU1-0] 54.265235 s: [IPU1-0] 54.265296 s: LOAD: CPU: 0.5% HWI: 0.2%, SWI:0.1%, Low Power: 93.9% [IPU1-0] 54.265418 s: [IPU1-0] 54.265479 s: LOAD: TSK: MISC : 0.2% [IPU1-0] 54.265570 s: [IPU1-0] 54.265601 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [IPU1-0] 54.265692 s: [IPU1-0] 54.265723 s: SYSTEM: Sempahores Objects, 412 of 1000 free [IPU1-0] 54.265814 s: SYSTEM: Task Objects , 93 of 100 free [IPU1-0] 54.265936 s: SYSTEM: Clock Objects , 99 of 100 free [IPU1-0] 54.266028 s: SYSTEM: Hwi Objects , 99 of 100 free [IPU1-0] 54.266119 s: [IPU1-0] 54.266150 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [IPU1-0] 54.266302 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 256200 B (250 KB) [IPU1-0] 54.266455 s: [IPU1-0] 54.266546 s: [IPU1-0] 54.266607 s: UTILS_PRCM_STATS: Current Temperature, [IPU1-0] 54.266668 s: [IPU1-0] 54.266699 s: Voltage Rail || Curr Temp Min - Max [IPU1-0] 54.266790 s: --------------------------------------------------------- [IPU1-0] 54.266912 s: PMHAL_PRCM_VD_MPU || [35.600 , 36. 0] [IPU1-0] 54.267034 s: PMHAL_PRCM_VD_CORE || [36. 0 , 36.400] [IPU1-0] 54.267126 s: PMHAL_PRCM_VD_IVAHD || [36. 0 , 36.400] [IPU1-0] 54.267248 s: PMHAL_PRCM_VD_DSPEVE || [34.800 , 35.200] [IPU1-0] 54.267370 s: PMHAL_PRCM_VD_GPU || [35.200 , 35.600] [IPU1-0] 54.267461 s: [IPU1-0] 54.267492 s: ============================================================================ [IPU1-0] 54.267614 s: Name | Bus (mV) | Res (mOhm) | Shunt (uV) | Current (mA) | Power (mW) [IPU1-0] 54.267705 s: ---------------------------------------------------------------------------- [IPU1-0] 54.273287 s: UTILS_PRCM_STATS: Reading the regulator data failed [IPU1-0] 54.273409 s: UTILS_PRCM_STATS: PM INA226 Power Read Failed !! [IPU1-0] 54.273744 s: [IPU1-0] 54.273775 s: Statistics Collector, [IPU1-0] 54.274049 s: [IPU1-0] 54.274080 s: STATISTIC Avg Data Peak Data [IPU1-0] 54.274171 s: COLLECTOR MB/s MB/s [IPU1-0] 54.274263 s: -------------------------------------------------- [IPU1-0] 54.274354 s: SCI_EMIF1 RD+WR | 417.941858 770.182257 [IPU1-0] 54.274446 s: SCI_EMIF2 RD+WR | 0.000000 0.000000 [IPU1-0] 54.274568 s: SCI_EMIF1 RD ONLY | 347.807255 552.227109 [IPU1-0] 54.274659 s: SCI_EMIF1 WR ONLY | 70.360781 364.829611 [IPU1-0] 54.274781 s: SCI_EMIF2 RD ONLY | 0.000000 0.000000 [IPU1-0] 54.274903 s: SCI_EMIF2 WR ONLY | 0.000000 0.000000 [IPU1-0] 54.275025 s: SCI_MA_MPU_P1 | 0.005199 2.427954 [IPU1-0] 54.275117 s: SCI_MA_MPU_P2 | 0.000000 0.000000 [IPU1-0] 54.275239 s: SCI_DSS | 274.086831 455.888281 [IPU1-0] 54.275330 s: SCI_IPU1 | 22.520959 145.202245 [IPU1-0] 54.275513 s: SCI_VIP1_P1 | 8.603701 65.094347 [IPU1-0] 54.275635 s: SCI_VIP1_P2 | 17.210176 130.059533 [IPU1-0] 54.275727 s: SCI_VPE_P1 | 0.000000 0.000000 [IPU1-0] 54.275849 s: SCI_VPE_P2 | 0.000000 0.000000 [IPU1-0] 54.275971 s: SCI_DSP1_MDMA | 87.946954 722.546771 [IPU1-0] 54.276093 s: SCI_DSP1_EDMA | 0.000000 0.000000 [IPU1-0] 54.276184 s: SCI_DSP2_MDMA | 0.718434 18.406753 [IPU1-0] 54.276306 s: SCI_DSP2_EDMA | 0.000000 0.000000 [IPU1-0] 54.276398 s: SCI_EVE1_TC0 | 2.100311 32.244208 [IPU1-0] 54.276489 s: SCI_EVE1_TC1 | 0.000000 0.000000 [IPU1-0] 54.276611 s: SCI_EVE2_TC0 | 0.000000 0.000000 [IPU1-0] 54.276703 s: SCI_EVE2_TC1 | 0.000000 0.000000 [IPU1-0] 54.276825 s: SCI_EDMA_TC0_RD | 0.000000 0.000000 [IPU1-0] 54.276947 s: SCI_EDMA_TC0_WR | 0.000000 0.000000 [IPU1-0] 54.277038 s: SCI_EDMA_TC1_RD | 0.000000 0.000000 [IPU1-0] 54.277130 s: SCI_EDMA_TC1_WR | 0.000000 0.000000 [IPU1-0] 54.277313 s: SCI_VIP2_P1 | 0.000000 0.000000 [IPU1-0] 54.277435 s: SCI_VIP2_P2 | 0.000000 0.000000 [IPU1-0] 54.277526 s: SCI_VIP3_P1 | 0.000000 0.000000 [IPU1-0] 54.277648 s: SCI_VIP3_P2 | 0.000000 0.000000 [IPU1-0] 54.277740 s: SCI_EVE3_TC0 | 0.000000 0.000000 [IPU1-0] 54.277862 s: SCI_EVE3_TC1 | 0.000000 0.000000 [IPU1-0] 54.277984 s: SCI_EVE4_TC0 | 0.000000 0.000000 [IPU1-0] 54.278076 s: SCI_EVE4_TC1 | 0.000000 0.000000 [IPU1-0] 54.278167 s: SCI_IVA | 0.000000 0.000000 [IPU1-0] 54.278289 s: SCI_GPU_P1 | 0.000000 0.000000 [IPU1-0] 54.278381 s: SCI_GPU_P2 | 0.000000 0.000000 [IPU1-0] 54.278472 s: SCI_GMAC_SW | 0.000000 0.000000 [IPU1-0] 54.278594 s: SCI_OCMC_RAM1 | 0.000000 0.000000 [IPU1-0] 54.278686 s: SCI_OCMC_RAM2 | 0.000000 0.000000 [IPU1-0] 54.278777 s: SCI_OCMC_RAM3 | 0.000000 0.000000 [IPU1-0] 54.379338 s: [IPU1-0] 54.379399 s: ### CPU [IPU1-0], LinkID [ 64], [IPU1-0] 54.379491 s: [IPU1-0] 54.379521 s: [ CAPTURE ] Link Statistics, [IPU1-0] 54.379582 s: ****************************** [IPU1-0] 54.379643 s: [IPU1-0] 54.379704 s: Elapsed time = 15864 msec [IPU1-0] 54.379765 s: [IPU1-0] 54.379796 s: New data Recv = 60.26 fps [IPU1-0] 54.379918 s: Get Full Buf Cb = 14.12 fps [IPU1-0] 54.380009 s: Put Empty Buf Cb = 13.99 fps [IPU1-0] 54.380101 s: Driver/Notify Cb = 60.26 fps [IPU1-0] 54.380162 s: [IPU1-0] 54.380192 s: Input Statistics, [IPU1-0] 54.380253 s: [IPU1-0] 54.380284 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 54.380375 s: | FPS | FPS | FPS | FPS [IPU1-0] 54.380467 s: -------------------------------------------------- [IPU1-0] 54.380528 s: 0 | 13.99 0. 0 0. 0 13.99 [IPU1-0] 54.380680 s: [IPU1-0] 54.380711 s: Output Statistics, [IPU1-0] 54.380772 s: [IPU1-0] 54.380802 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 54.380894 s: | ID | FPS | FPS | FPS [IPU1-0] 54.380985 s: --------------------------------------------- [IPU1-0] 54.381046 s: 0 | 0 14.12 0. 0 0. 0 [IPU1-0] 54.381168 s: [IPU1-0] 54.381199 s: [ CAPTURE ] LATENCY, [IPU1-0] 54.381260 s: ******************** [IPU1-0] 54.381321 s: [IPU1-0] 54.381443 s: [IPU1-0] 54.381473 s: ### CPU [IPU1-0], LinkID [ 0], [IPU1-0] 54.381565 s: [IPU1-0] 54.381595 s: [ IPC_OUT_0 ] Link Statistics, [IPU1-0] 54.381656 s: ****************************** [IPU1-0] 54.381717 s: [IPU1-0] 54.381748 s: Elapsed time = 15866 msec [IPU1-0] 54.381839 s: [IPU1-0] 54.381900 s: New data Recv = 14.11 fps [IPU1-0] 54.381961 s: Release data Recv = 13.99 fps [IPU1-0] 54.382053 s: Driver/Notify Cb = 114.1 fps [IPU1-0] 54.382114 s: [IPU1-0] 54.382144 s: Input Statistics, [IPU1-0] 54.382205 s: [IPU1-0] 54.382236 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 54.382327 s: | FPS | FPS | FPS | FPS [IPU1-0] 54.382419 s: -------------------------------------------------- [IPU1-0] 54.382480 s: 0 | 14.11 0. 0 0. 0 14.11 [IPU1-0] 54.382602 s: [IPU1-0] 54.382663 s: Output Statistics, [IPU1-0] 54.382693 s: [IPU1-0] 54.382754 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 54.382815 s: | ID | FPS | FPS | FPS [IPU1-0] 54.382907 s: --------------------------------------------- [IPU1-0] 54.382998 s: 0 | 0 14.11 0. 0 0. 0 [IPU1-0] 54.383120 s: [IPU1-0] 54.383151 s: [ IPC_OUT_0 ] LATENCY, [IPU1-0] 54.383273 s: ******************** [IPU1-0] 54.383334 s: Local Link Latency : Avg = 6 us, Min = 0 us, Max = 31 us, [IPU1-0] 54.383456 s: Source to Link Latency : Avg = 79 us, Min = 61 us, Max = 244 us, [IPU1-0] 54.383578 s: [IPU1-0] 54.882937 s: [IPU1-0] 54.883029 s: ### CPU [ DSP1], LinkID [ 10], [IPU1-0] 54.883181 s: [IPU1-0] 54.883212 s: [ IPC_IN_0 ] Link Statistics, [IPU1-0] 54.883273 s: ****************************** [IPU1-0] 54.883334 s: [IPU1-0] 54.883364 s: Elapsed time = 16368 msec [IPU1-0] 54.883456 s: [IPU1-0] 54.883486 s: Get Full Buf Cb = 5.68 fps [IPU1-0] 54.883578 s: Put Empty Buf Cb = 13.99 fps [IPU1-0] 54.883639 s: Driver/Notify Cb = 14.5 fps [IPU1-0] 54.883730 s: [IPU1-0] 54.883761 s: Input Statistics, [IPU1-0] 54.883822 s: [IPU1-0] 54.884035 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 54.884127 s: | FPS | FPS | FPS | FPS [IPU1-0] 54.884218 s: -------------------------------------------------- [IPU1-0] 54.884279 s: 0 | 14.11 0. 0 0. 0 14.11 [IPU1-0] 54.884432 s: [IPU1-0] 54.884462 s: Output Statistics, [IPU1-0] 54.884523 s: [IPU1-0] 54.884554 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 54.884645 s: | ID | FPS | FPS | FPS [IPU1-0] 54.884706 s: --------------------------------------------- [IPU1-0] 54.884798 s: 0 | 0 14.11 0. 0 0. 0 [IPU1-0] 54.884950 s: [IPU1-0] 54.884981 s: [ IPC_IN_0 ] LATENCY, [IPU1-0] 54.885042 s: ******************** [IPU1-0] 54.885103 s: Local Link Latency : Avg = 8 us, Min = 0 us, Max = 31 us, [IPU1-0] 54.885225 s: Source to Link Latency : Avg = 89330 us, Min = 213 us, Max = 164217 us, [IPU1-0] 54.885347 s: [IPU1-0] 54.885438 s: [IPU1-0] 54.885499 s: ### CPU [ DSP1], LinkID [ 49], [IPU1-0] 54.885560 s: [IPU1-0] 54.885621 s: [ ALG_sobelDsp ] Link Statistics, [IPU1-0] 54.885682 s: ****************************** [IPU1-0] 54.885743 s: [IPU1-0] 54.885774 s: Elapsed time = 16369 msec [IPU1-0] 54.885865 s: [IPU1-0] 54.885926 s: New data Recv = 5.62 fps [IPU1-0] 54.885987 s: [IPU1-0] 54.886048 s: Input Statistics, [IPU1-0] 54.886079 s: [IPU1-0] 54.886140 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 54.886201 s: | FPS | FPS | FPS | FPS [IPU1-0] 54.886292 s: -------------------------------------------------- [IPU1-0] 54.886353 s: 0 | 14. 5 0. 0 0. 0 13.98 [IPU1-0] 54.886506 s: [IPU1-0] 54.886536 s: Output Statistics, [IPU1-0] 54.886597 s: [IPU1-0] 54.886628 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 54.886689 s: | ID | FPS | FPS | FPS [IPU1-0] 54.886780 s: --------------------------------------------- [IPU1-0] 54.886872 s: 0 | 0 13.98 0. 0 0. 0 [IPU1-0] 54.886994 s: [IPU1-0] 54.887024 s: [ ALG_sobelDsp ] LATENCY, [IPU1-0] 54.887116 s: ******************** [IPU1-0] 54.887146 s: Local Link Latency : Avg = 71291 us, Min = 71037 us, Max = 71555 us, [IPU1-0] 54.887268 s: Source to Link Latency : Avg = 217505 us, Min = 71311 us, Max = 240285 us, [IPU1-0] 54.887390 s: [IPU1-0] 54.887512 s: [IPU1-0] 54.887543 s: ### CPU [ DSP1], LinkID [ 0], [IPU1-0] 54.887634 s: [IPU1-0] 54.887665 s: [ IPC_OUT_0 ] Link Statistics, [IPU1-0] 54.887726 s: ****************************** [IPU1-0] 54.887787 s: [IPU1-0] 54.887848 s: Elapsed time = 16300 msec [IPU1-0] 54.887939 s: [IPU1-0] 54.887970 s: New data Recv = 13.92 fps [IPU1-0] 54.888061 s: Release data Recv = 13.80 fps [IPU1-0] 54.888122 s: Driver/Notify Cb = 113.80 fps [IPU1-0] 54.888214 s: [IPU1-0] 54.888244 s: Input Statistics, [IPU1-0] 54.888305 s: [IPU1-0] 54.888336 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 54.888397 s: | FPS | FPS | FPS | FPS [IPU1-0] 54.888488 s: -------------------------------------------------- [IPU1-0] 54.888580 s: 0 | 14. 4 0. 0 0. 0 14. 4 [IPU1-0] 54.888702 s: [IPU1-0] 54.888732 s: Output Statistics, [IPU1-0] 54.888793 s: [IPU1-0] 54.888824 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 54.889068 s: | ID | FPS | FPS | FPS [IPU1-0] 54.889160 s: --------------------------------------------- [IPU1-0] 54.889251 s: 0 | 0 14. 4 0. 0 0. 0 [IPU1-0] 54.889373 s: [IPU1-0] 54.889404 s: [ IPC_OUT_0 ] LATENCY, [IPU1-0] 54.889465 s: ******************** [IPU1-0] 54.889922 s: Local Link Latency : Avg = 2 us, Min = 0 us, Max = 31 us, [IPU1-0] 54.890075 s: Source to Link Latency : Avg = 274662 us, Min = 71494 us, Max = 374764 us, [IPU1-0] 54.890197 s: [IPU1-0] 55.389983 s: [IPU1-0] 55.390075 s: ### CPU [IPU1-0], LinkID [ 10], [IPU1-0] 55.390136 s: [IPU1-0] 55.390197 s: [ IPC_IN_0 ] Link Statistics, [IPU1-0] 55.390258 s: ****************************** [IPU1-0] 55.390319 s: [IPU1-0] 55.390349 s: Elapsed time = 16803 msec [IPU1-0] 55.390410 s: [IPU1-0] 55.390471 s: Get Full Buf Cb = 5.65 fps [IPU1-0] 55.390532 s: Put Empty Buf Cb = 13.80 fps [IPU1-0] 55.390624 s: Driver/Notify Cb = 5.59 fps [IPU1-0] 55.390685 s: [IPU1-0] 55.390715 s: Input Statistics, [IPU1-0] 55.390776 s: [IPU1-0] 55.390807 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 55.390959 s: | FPS | FPS | FPS | FPS [IPU1-0] 55.391051 s: -------------------------------------------------- [IPU1-0] 55.391142 s: 0 | 14. 4 0. 0 0. 0 14. 4 [IPU1-0] 55.391264 s: [IPU1-0] 55.391325 s: Output Statistics, [IPU1-0] 55.391356 s: [IPU1-0] 55.391386 s: CH | Out | Out | Out Drop | Out User Drop [IPU1-0] 55.391478 s: | ID | FPS | FPS | FPS [IPU1-0] 55.391539 s: --------------------------------------------- [IPU1-0] 55.391630 s: 0 | 0 14. 4 0. 0 0. 0 [IPU1-0] 55.391752 s: [IPU1-0] 55.391783 s: [ IPC_IN_0 ] LATENCY, [IPU1-0] 55.391844 s: ******************** [IPU1-0] 55.391935 s: Local Link Latency : Avg = 16 us, Min = 0 us, Max = 91 us, [IPU1-0] 55.392057 s: Source to Link Latency : Avg = 274688 us, Min = 71677 us, Max = 374947 us, [IPU1-0] 55.392179 s: [IPU1-0] 55.392271 s: [IPU1-0] 55.392332 s: ### CPU [IPU1-0], LinkID [ 67], [IPU1-0] 55.392393 s: [IPU1-0] 55.392454 s: [ DISPLAY ] Link Statistics, [IPU1-0] 55.392515 s: ****************************** [IPU1-0] 55.392576 s: [IPU1-0] 55.392606 s: Elapsed time = 16805 msec [IPU1-0] 55.392667 s: [IPU1-0] 55.392728 s: New data Recv = 5.59 fps [IPU1-0] 55.392789 s: Driver/Notify Cb = 59.92 fps [IPU1-0] 55.392881 s: [IPU1-0] 55.392942 s: Input Statistics, [IPU1-0] 55.392972 s: [IPU1-0] 55.393033 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 55.393094 s: | FPS | FPS | FPS | FPS [IPU1-0] 55.393186 s: -------------------------------------------------- [IPU1-0] 55.393338 s: 0 | 14. 4 0. 0 0. 0 14. 4 [IPU1-0] 55.393491 s: [IPU1-0] 55.393521 s: [ DISPLAY ] LATENCY, [IPU1-0] 55.393582 s: ******************** [IPU1-0] 55.393643 s: Local Link Latency : Avg = 25 us, Min = 0 us, Max = 366 us, [IPU1-0] 55.393765 s: Source to Link Latency : Avg = 274884 us, Min = 71799 us, Max = 375160 us, [IPU1-0] 55.394070 s: [IPU1-0] 55.394162 s: CPU [ IPU1-0], LinkID [ 23], Link Statistics not available ! [IPU1-0] 55.394345 s: [IPU1-0] 55.394375 s: ### CPU [IPU1-0], LinkID [ 68], [IPU1-0] 55.394436 s: [IPU1-0] 55.394497 s: [ DISPLAY ] Link Statistics, [IPU1-0] 55.394558 s: ****************************** [IPU1-0] 55.394619 s: [IPU1-0] 55.394650 s: Elapsed time = 16895 msec [IPU1-0] 55.394711 s: [IPU1-0] 55.394772 s: Driver/Notify Cb = 60.1 fps [IPU1-0] 55.394833 s: [IPU1-0] 55.394894 s: Input Statistics, [IPU1-0] 55.394985 s: [IPU1-0] 55.395016 s: CH | In Recv | In Drop | In User Drop | In Process [IPU1-0] 55.395107 s: | FPS | FPS | FPS | FPS [IPU1-0] 55.395168 s: -------------------------------------------------- [IPU1-0] 55.395260 s: 0 | 0. 5 0. 0 0. 0 0. 5 [IPU1-0] 55.395382 s: [IPU1-0] 55.395412 s: [ DISPLAY ] LATENCY, [IPU1-0] 55.395473 s: ******************** [IPU1-0] 55.395534 s: Local Link Latency : Avg = 31 us, Min = 31 us, Max = 31 us, [IPU1-0] 55.395656 s: Source to Link Latency : Avg = 98091 us, Min = 98091 us, Max = 98091 us, [IPU1-0] 55.395778 s: [IPU1-0] 55.894894 s: [IPU1-0] [IPU1-0] ==================== [IPU1-0] Chains Run-time Menu [IPU1-0] ==================== [IPU1-0] [IPU1-0] 0: Stop Chain [IPU1-0] [IPU1-0] 2: Pause Capture [IPU1-0] 3: Resume Capture [IPU1-0] [IPU1-0] p: Print Performance Statistics [IPU1-0] [IPU1-0] Enter Choice: [IPU1-0] [IPU1-0] 55.895199 s: [IPU1-0] Unsupported option ' [IPU1-0] '. Please try again [IPU1-0] 55.895321 s: [IPU1-0] [IPU1-0] ==================== [IPU1-0] Chains Run-time Menu [IPU1-0] ==================== [IPU1-0] [IPU1-0] 0: Stop Chain [IPU1-0] [IPU1-0] 2: Pause Capture [IPU1-0] 3: Resume Capture [IPU1-0] [IPU1-0] p: Print Performance Statistics [IPU1-0] [IPU1-0] Enter Choice: [IPU1-0]
Kajal
