Part Number: DRA746
Tool/software: Linux
Hello Team,
We use custom h/w and software based on DRA746 and SDK 3.03.
We are trying to play High resolution(2560x1442) videos.
We have two different files with same codec properties one is playing properly with both pipeline and media player, but one is only playable with pipeline and failing with media player and causing weston crash.
Also getting these kind of logs:
log info verbose 1 T2511 GSTLogs FIXME playbin gstplaybin2.c(3182):_uridecodebin_event_probe:<uridecodebin0:src_0> Consider implementing group-id handling on stream-start event
log info verbose 1 T2510 GSTLogs WARN default mp4_interface.c(1150):gst_update_creation_data:<ittmp4parser0> Can't handle datetimes before 1970 yet
log info verbose 1 T2511 GSTLogs WARN ducati gstducatividdec.c(1472):gst_ducati_viddec_chain:<decoder> push from codec_process failed flushing
log info verbose 1 T2511 GSTLogs WARN ducati gstducatih264dec.c(402):gst_ducati_h264dec_set_sink_caps:<decoder> num-reorder-frames not found on caps, calculation from stream parameters gives 5
log info verbose 1 T2511 GSTLogs WARN ducati gstducatih264dec.c(410):gst_ducati_h264dec_set_sink_caps:<decoder> Using 0 frames for reordering
log info verbose 1 T2511 GSTLogs WARN ducati gstducatividdec.c(590):codec_process:<decoder> changing max-ref-frames in caps to 13
log info verbose 1 T2511 GSTLogs WARN waylandsink wlvideoformat.c(102):gst_wl_shm_format_to_video_format: gst video format not found
log info verbose 1 T2511 GSTLogs WARN ducati gstducatividdec.c(753):codec_process:<decoder> push failed flushing
log info verbose 1 T2530 GSTLogs WARN ducati gstducatividdec.c(590):codec_process:<decoder> changing max-ref-frames in caps to 16
log info verbose 1 T1951 GSTLogs FIXME bin gstbin.c(4075):gst_bin_query: implement duration caching in GstBin again
log info verbose 1 T2526 GSTLogs FIXME bin gstbin.c(4075):gst_bin_query: implement duration caching in GstBin again
log info verbose 1 T2321 GSTLogs WARN ducati gstducatividdec.c(570):codec_process:<decoder> err=-1, extendedError=00040000
log info verbose 1 T2321 GSTLogs ERROR ducati gstducati.c(61):gst_ducati_log_extended_error_info: Bit 18 (00040000): stream end
log info verbose 1 T2321 GSTLogs WARN basesrc gstbasesrc.c(3481):gst_base_src_start_complete:<source> pad not activated yet
Could you please suggest what is went wrong here?
Thanks & Regards,
Ikshwaku
