Part Number: AM5718
Other Parts Discussed in Thread: AM5728
Tool/software: Linux
HI TI,
A custom board(reference to AM5718 and AM5728) having with USB hub.
while in the booting process am able to see hub detection.
but, in ls /sys/class/udc there is no controller respect to usb1(0x48890000).
am able to see usb2 controller(0x488d0000).
I am expecting after ls /sys/class/udc there should two usb controller
48890000.usb 488d0000.usb
Please find the attached booting log.
Please suggest me if am missing anything.
Anil
[ 5.063605] PRM: I/O chain clock line assertion timed out
[ OK ] Started Rebuild Hardware Database.
[ 5.774530] PRM: I/O chain clock line assertion timed out
Starting udev Coldplug all Devices...
[ 5.803634] PRM: I/O chain clock line assertion timed out
Starting Update is Completed...
[ 5.843648] PRM: I/O chain clock line assertion timed out
[ OK ] Started Update is Completed.
[ 5.883615] PRM: I/O chain clock line assertion timed out
[ 6.499155] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
[ 6.549565] remoteproc0: 58820000.ipu is available
[ 6.581006] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ OK ] Found device /dev/ttyS2.
[ 6.620768] PRM: I/O chain clock line assertion timed out
[ 6.644187] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 6.702053] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
[ OK ] Started udev Coldplug all Devices.[ 6.746830] remoteproc1: 55020000.ipu is available
[ 6.753443] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659 as rtc0
[ 6.766243] PRM: I/O chain clock line assertion timed out
[ 6.800520] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ OK ] Reached target System Initialization.
[ 6.838801] PRM: I/O chain clock line assertion timed out
[ 6.858059] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 6.869975] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: USB-HOST cable is attached
[ OK ] Listening on RPCbind Server Activation Socket.
[ 6.903612] PRM: I/O chain clock line assertion timed out
[ 6.925977] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ OK ] Started Daily Cleanup of Temporary Directories.[ 6.951466] alg: skcipher: setkey failed on test 5 for ecb-des-omap: flags=100
[ 6.963105] PRM: I/O chain clock line assertion timed out
[ OK ] Reached target Timers.
[ 7.003898] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
[ 7.013844] PRM: I/O chain clock line assertion timed out
[ 7.034611] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
[ OK ] Listening on D-Bus System Message Bus Socket.
[ 7.063601] PRM: I/O chain clock line assertion timed out
[ 7.070460] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[ 7.085294] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
[ 7.101403] remoteproc2: 40800000.dsp is available
[ OK ] Reached target Sockets.[ 7.115964] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 7.140340] remoteproc0: registered virtio0 (type 7)
[ 7.145766] PRM: I/O chain clock line assertion timed out
[ OK ] Reached target Basic System.[ 7.163868] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 7.193614] PRM: I/O chain clock line assertion timed out
[ OK ] Started Serial Getty on ttyS2.
[ 7.243626] PRM: I/O chain clock line assertion timed out
[ OK ] Started D-Bus System Message Bus.
[ 7.303628] PRM: I/O chain clock line assertion timed out
[ 7.399533] vip 48970000.vip: loading firmware vpdma-1b8.bin
[ 7.443434] vip 48970000.vip: VPDMA firmware loaded
[ 7.501175] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ 7.555198] SCSI subsystem initialized
[ 7.615704] remoteproc1: registered virtio1 (type 7)
[ 8.035669] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[ 8.053650] vpe 489d0000.vpe: Device registered as /dev/video0
[ 8.060488] ti-pruss 4b200000.pruss: creating PRU cores and other child platform devices
[ 8.133374] davinci_mdio 4b232400.mdio: davinci mdio revision 1.6
[ 8.139504] libphy: 4b232400.mdio: probed
[ 8.161263] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 8.169819] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 8.251144] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 8.264673] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[ 8.271432] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 8.311655] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[ 8.350137] scsi host0: ahci
[ 8.358762] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 349
Starting Network Service...
[ 8.400066] ti-pruss 4b280000.pruss: creating PRU cores and other child platform devices
[ 8.408547] PRM: I/O chain clock line assertion timed out
[ OK ] Reached target Containers.
[ 8.453620] PRM: I/O chain clock line assertion timed out
[ 8.483634] davinci_mdio 4b2b2400.mdio: davinci mdio revision 1.6
[ 8.489764] libphy: 4b2b2400.mdio: probed
[ 8.555935] remoteproc3: 4b234000.pru0 is available
[ 8.560931] remoteproc3: Note: remoteproc is still under development and considered experimental.
[ 8.614454] remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ OK ] Started Network Service.
[ 8.630111] PRM: I/O chain clock line assertion timed out
[ 8.663835] pru-rproc 4b234000.pru0: PRU rproc node /ocp/pruss@4b200000/pru0@4b234000 probed successfully
[ 8.692374] remoteproc4: 4b238000.pru1 is available
[ 8.711833] remoteproc4: Note: remoteproc is still under development and considered experimental.
[ OK ] Reached target Network.
[ 8.726059] PRM: I/O chain clock line assertion timed out
[ 8.749957] remoteproc4: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
Starting Network Name Resolution...
[ 8.783649] PRM: I/O chain clock line assertion timed out
[ 8.792406] pru-rproc 4b238000.pru1: PRU rproc node /ocp/pruss@4b200000/pru1@4b238000 probed successfully
Starting Dropbear SSH daemon...
[ 8.833980] PRM: I/O chain clock line assertion timed out
[ 8.853749] remoteproc5: 4b2b4000.pru0 is available
[ 8.870793] remoteproc5: Note: remoteproc is still under development and considered experimental.
[ 8.912124] remoteproc5: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 8.943820] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 8.958085] pru-rproc 4b2b4000.pru0: PRU rproc node /ocp/pruss@4b280000/pru0@4b2b4000 probed successfully
[ 8.976181] ata1.00: HPA detected: current 61857727, native 61865984
[ 9.004430] ata1.00: ATA-9: ATP SATA III mSATA, N0516B, max UDMA/133
[ 9.023496] remoteproc6: 4b2b8000.pru1 is available
[ OK ] Started Network Name Resolution.
[ 9.055125] ata1.00: 61857727 sectors, multi 1: LBA48 NCQ (depth 31/32)
[ 9.062444] remoteproc2: registered virtio2 (type 7)
[ 9.072182] remoteproc6: Note: remoteproc is still under development and considered experimental.
[ 9.081721] PRM: I/O chain clock line assertion timed out
[ 9.126969] ata1.00: configured for UDMA/133
[ OK ] Started Dropbear SSH daemon.[ 9.141986] remoteproc6: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 9.174337] PRM: I/O chain clock line assertion timed out
[ 9.201279] scsi 0:0:0:0: Direct-Access ATA ATP SATA III mSA 6B PQ: 0 ANSI: 5
[ 9.233629] pru-rproc 4b2b8000.pru1: PRU rproc node /ocp/pruss@4b280000/pru1@4b2b8000 probed successfully
[ 9.302681] prueth pruss2_eth: port 1: using random MAC addr: 2a:aa:ed:d4:6d:50
[ 9.331687] prueth pruss2_eth: couldn't connect to phy /ocp/pruss@4b280000/mdio@4b2b2400/ethernet-phy@0
[ 9.385556] prueth pruss2_eth: netdev init ethernet-mii0 failed: -19
[ 9.392134] prueth pruss2_eth: port 2: using random MAC addr: aa:f3:49:d2:c6:1b
[ 9.465768] prueth pruss2_eth: couldn't connect to phy /ocp/pruss@4b280000/mdio@4b2b2400/ethernet-phy@1
[ 9.520133] prueth pruss2_eth: netdev init ethernet-mii1 failed: -19
[ 9.558257] prueth pruss2_eth: TI PRU ethernet driver initialized
[ 9.591922] prueth pruss1_eth: port 1: using random MAC addr: f6:b9:dc:2a:1a:62
[ 9.637006] prueth pruss1_eth: couldn't connect to phy /ocp/pruss@4b200000/mdio@4b232400/ethernet-phy@0
[ 9.689203] prueth pruss1_eth: netdev init ethernet-mii0 failed: -19
[ 9.726947] prueth pruss1_eth: port 2: using random MAC addr: 0a:63:af:9d:c0:e3
[ 9.768912] prueth pruss1_eth: couldn't connect to phy /ocp/pruss@4b200000/mdio@4b232400/ethernet-phy@1
[ 9.820716] prueth pruss1_eth: netdev init ethernet-mii1 failed: -19
[ 9.852329] remoteproc0: powering up 58820000.ipu
[ 9.861537] prueth pruss1_eth: TI PRU ethernet driver initialized
[ 9.916192] remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 4890352
[ 9.923197] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
[ 9.974286] sd 0:0:0:0: [sda] 61857727 512-byte logical blocks: (31.7 GB/29.5 GiB)
[ 10.003994] sd 0:0:0:0: [sda] Write Protect is off
[ 10.023436] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 10.044976] remoteproc0: remote processor 58820000.ipu is now up
[ 10.065105] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 10.070749] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x32
[ 10.080235] sda: sda1 sda2
[ 10.095215] sd 0:0:0:0: [sda] Attached SCSI disk
[ 10.104173] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x33
[ 10.132902] virtio_rpmsg_bus virtio0: creating channel rpmsg-omx addr 0x3c
[ 10.174159] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x65
[ 10.224666] remoteproc1: powering up 55020000.ipu
[ 10.236087] remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3743116
[ 10.243084] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ 10.474586] remoteproc1: remote processor 55020000.ipu is now up
[ 10.484529] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 10.490076] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x65
[ 10.514011] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x66
[ 10.544256] remoteproc2: powering up 40800000.dsp
[ 10.636037] remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 21914156
[ 10.650239] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 10.656131] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 10.662105] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[ 10.765618] remoteproc2: remote processor 40800000.dsp is now up
[ 10.813671] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 10.819220] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x3d
[ 10.835402] rpmsg_rpc rpmsg3: probing service rpc_example_2 with src 1024 dst 101
[ 10.865145] rpmsg_rpc rpmsg4: probing service dce-callback with src 1024 dst 101
[ 10.872622] rpmsg_rpc rpmsg3: published functions = 8
[ 10.881910] NET: Registered protocol family 41
[ 10.905168] rpmsg_rpc rpmsg5: probing service rpmsg-dce with src 1025 dst 102
[ 10.912375] rpmsg_rpc rpmsg4: published functions = 4
[ 10.927018] rpmsg_rpc rpmsg5: published functions = 9
[ 11.077011] usbcore: registered new interface driver usbfs
[ 11.083138] usbcore: registered new interface driver hub
[ 11.089787] usbcore: registered new device driver usb
[ 11.108301] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 11.114076] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 11.122144] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
[ 11.132694] xhci-hcd xhci-hcd.0.auto: irq 432, io mem 0x48890000
[ 11.141034] hub 1-0:1.0: USB hub found
[ 11.145680] hub 1-0:1.0: 1 port detected
[ 11.150006] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 11.156715] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 11.165123] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 11.175009] hub 2-0:1.0: USB hub found
[ 11.178809] hub 2-0:1.0: 1 port detected
[ 11.183224] dwc3 488d0000.usb: otg: primary host xhci-hcd.1.auto registered
[ 11.192087] dwc3 488d0000.usb: otg: shared host xhci-hcd.1.auto registered
[ 11.199609] dwc3 488d0000.usb: otg: can't start till gadget registers
[ 11.463319] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 11.493375] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 11.517337] hub 2-1:1.0: USB hub found
[ 11.521539] hub 2-1:1.0: 4 ports detected
[ 11.613376] hub 1-1:1.0: USB hub found
[ 11.617556] hub 1-1:1.0: 4 ports detected
[ 12.224585] PRM: I/O chain clock line assertion timed out
[ 12.230996] PRM: I/O chain clock line assertion timed out
Welcome to Tester-Master
r-master login: root
Password:
# ls
mk-eMMC-boot.sh
# lsusb
Bus 001 Device 002: ID 0451:8142
Bus 002 Device 002: ID 0451:8140
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0003
# ls /sys/class/udc
488d0000.usb
