Other Parts Discussed in Thread: OMAP3530
Hi, all
I find the disk(NandFlash) read speed is very slow on EVM2 board based on bsp6.15.00, about 2.8MB/S,
in other platforms, the average speed is about 6.3MB/S.
Is there anything to improve this issue?
Hi, all
What tests are you using to do this comparison? Do you have File system cache manager enabled or disabled? Is other platform using same NAND chip as the EVM?
thanks
Atul
Atul,
I enabled file cache manager before. Now, I disable it, and the read speed improve to 13M/S or so, while the write speed becomes slower from 2.7M/S to 2.1M/S
From the text files I received in email, it appears that you are comparing SD
perf on one platform versus NAND perf on EVM2? Is this correct? If so, the comparison
is wrong. Also, do you have CETK perf data from two platforms (and for the same medium) - that is one way to make fair comparison
Atul
Atul,
sorry to send text file by mistake. the nand Perf on our custom platform is as below:
**** Start of Report *****
<<< General >>>
Test Tools: CETestContainer Ver 1.0
Done: by ___ on 2003.01.02 at 01.04.25
<<< Storage Read & Write Performance >>>
<< ResidentFlash Read Test >>
< Test Parameter >
FileSize: 5MB
BufferSize: 1024KB
Times: 1
< Test Result >
Read Average Speed: 6424KB/S
Read Max Speed: 6424KB/S
Read Min Speed: 6424KB/S
<< ResidentFlash Write Test >>
< Test Parameter >
FileSize: 5MB
BufferSize: 1024KB
Times: 1
< Test Result >
Write Average Speed: 2315KB/S
Write Max Speed: 2315KB/S
Write Min Speed: 2315KB/S
<< Note >>
Test End Time: on 2003.01.02 at 01.04.31
***** End of Report *****
So what is the latest comparison summary? You are ok with Read performance but write performance is 2.1 MB/s versus 2.3 MB/s on the other platform? Is this correct?
Atul
Below is the latest test for Omap3530, disable file cache manager:
***** Start of Report *****
<<< General >>>
Done: by ___ on 2006.01.01 at 12.06.10
< Test Parameter >
FileSize: 5MB
BufferSize: 1024KB
Times: 1
< Test Result >
Read Average Speed: 13950KB/S
Read Max Speed: 13950KB/S
Read Min Speed: 13950KB/S
< Test Parameter >
FileSize: 5MB
BufferSize: 1024KB
Times: 1
< Test Result >
Write Average Speed: 2159KB/S
Write Max Speed: 2159KB/S
Write Min Speed: 2159KB/S
<< Note >>
Test End Time: on 2006.01.01 at 12.06.16
and, then the latest test results for omap3530, enable file cache manager:
<<< General >>>
Done: by ___ on 2006.01.01 at 12.20.27
< Test Parameter >
FileSize: 5MB
BufferSize: 1024KB
Times: 1
< Test Result >
Read Average Speed: 2813KB/S
Read Max Speed: 2813KB/S
Read Min Speed: 2813KB/S
< Test Parameter >
FileSize: 5MB
BufferSize: 1024KB
Times: 1
< Test Result >
Write Average Speed: 2723KB/S
Write Max Speed: 2723KB/S
Write Min Speed: 2723KB/S
<< Note >>
Test End Time: on 2006.01.01 at 12.20.38
So, we can see that, when disable file cache manager, the read speed increase verus the write speed increase decrease.
My confusion is why this happens, how to improve the write speed?
I don't know what all your test app does - random read/writes or sequential? In any case, these numbers would change depending upon datasize and read/write patterns. Did you get a chance to run File System perf test from CETK (with cache manager enabled/disabled). This CETK test varies several parameter and you may be able to get better picture of what is going on
Atul
What is the CETestContainer ? How does it work, or can you provide one copy to let us to use it to test SDCard performance?
It is a disk read/write test tool.
when run the tool, you can select 'storage' in the menu, and next 'auto read/write' item, when you select one or more of the target devices and click the 'start' button,
the test results will be saved in root path of ResidentFlash automatically, where ResidentFlash is the name of Flash device.
Of course, if your flash device folder name is not ResidentFlash, you can make a new folder named ResidentFlash in the same level as Windows, to save the test results
