Linux/AM5728: DSS error
Part Number: AM5728
Tool/software: Linux
I'm writing to get your suggestion related to "omapdss_dss 58000000.dss: master bind failed: -517" at Linux Kernel error on our custom AM5728 board design. I'm using Ubuntu 16.04 and latest version of SDK(04.02.00.09). dmesg File is attached. Do you have any suggestions to fix this problem?
Thank you in advance
Alican
root@am57xx-evm:~# dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.59-ga75d8e9305 (alicanlinux@alicanlinux) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP PREEMPT Tue Apr 3 11:45:31 +03 2018
[    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt:Machine model: TI AM572x EVM Rev A3
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[    0.000000] OF: reserved mem: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 24 MiB at 0x00000000fd400000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] OMAP4: Map 0x00000000fed00000 to fe600000 for dram barrier
[    0.000000] On node 0 totalpages: 470272
[    0.000000] free_area_init_node: node 0, pgdat c104c040, node_mem_map eedc6000
[    0.000000]   DMA zone: 1728 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 147456 pages, LIFO batch:31
[    0.000000]   HighMem zone: 322816 pages, LIFO batch:31
[    0.000000] DRA752 ES2.0
[    0.000000] percpu: Embedded 13 pages/cpu @eed59000 s22156 r8192 d22900 u53248
[    0.000000] pcpu-alloc: s22156 r8192 d22900 u53248 alloc=13*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 468544
[    0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=6a7f9feb-02 rw rootfstype=ext4 rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1659436K/1881088K available (8192K kernel code, 315K rwdata, 2428K rodata, 2048K init, 304K bss, 33236K reserved, 188416K cma-reserved, 1266688K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
                   pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                   modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                     .text : 0xc0008000 - 0xc0a00000   (10208 kB)
                     .init : 0xc0e00000 - 0xc1000000   (2048 kB)
                     .data : 0xc1000000 - 0xc104ef80   ( 316 kB)
                      .bss : 0xc1050000 - 0xc109c130   ( 305 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] OMAP clockevent source: timer1 at 32786 Hz
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 6.14MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[    0.000004] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[    0.000016] Switching to timer-based delay loop, resolution 162ns
[    0.000323] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000331] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000730] Console: colour dummy device 80x30
[    0.000746] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[    0.000752] This ensures that you still see kernel messages. Please
[    0.000758] update your kernel commandline.
[    0.000775] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[    0.000788] pid_max: default: 32768 minimum: 301
[    0.000888] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000898] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001519] CPU: Testing write buffer coherency: ok
[    0.001725] /cpus/cpu@0 missing clock-frequency property
[    0.001741] /cpus/cpu@1 missing clock-frequency property
[    0.001752] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.001769] Setting up static identity map for 0x80200000 - 0x80200060
[    0.080076] EFI services will not be available.
[    0.170305] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.170392] Brought up 2 CPUs
[    0.170406] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[    0.170413] CPU: All CPU(s) started in HYP mode.
[    0.170419] CPU: Virtualization extensions available.
[    0.170918] devtmpfs: initialized
[    0.197941] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.198183] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.198199] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.201553] pinctrl core: initialized pinctrl subsystem
[    0.202367] NET: Registered protocol family 16
[    0.203231] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.204273] omap_hwmod: l3_main_2 using broken dt data from ocp
[    0.316544] omap_hwmod: dcan2: _wait_target_disable failed
[    0.440403] cpuidle: using governor ladder
[    0.470432] cpuidle: using governor menu
[    0.478104] gpio gpiochip0: (gpio): added GPIO chardev (254:0)
[    0.478336] gpiochip_setup_dev: registered GPIOs 0 to 31 on device: gpiochip0 (gpio)
[    0.479796] OMAP GPIO hardware version 0.1
[    0.480362] omap_gpio 48055000.gpio: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/pinmux_emmc_reset_pins, deferring probe
[    0.480949] gpio gpiochip1: (gpio): added GPIO chardev (254:1)
[    0.481163] gpiochip_setup_dev: registered GPIOs 32 to 63 on device: gpiochip1 (gpio)
[    0.482987] gpio gpiochip2: (gpio): added GPIO chardev (254:2)
[    0.483196] gpiochip_setup_dev: registered GPIOs 64 to 95 on device: gpiochip2 (gpio)
[    0.484934] omap_gpio 4805b000.gpio: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/pinmux_phy_reset_pwrdown_pins, deferring probe
[    0.485451] gpio gpiochip3: (gpio): added GPIO chardev (254:3)
[    0.485663] gpiochip_setup_dev: registered GPIOs 96 to 127 on device: gpiochip3 (gpio)
[    0.487459] gpio gpiochip4: (gpio): added GPIO chardev (254:4)
[    0.487663] gpiochip_setup_dev: registered GPIOs 128 to 159 on device: gpiochip4 (gpio)
[    0.489478] gpio gpiochip5: (gpio): added GPIO chardev (254:5)
[    0.489682] gpiochip_setup_dev: registered GPIOs 160 to 191 on device: gpiochip5 (gpio)
[    0.491340] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[    0.491786] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[    0.517052] No ATAGs?
[    0.517076] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.517085] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.517448] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[    0.517457] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[    0.517995] OMAP DMA hardware revision 0.0
[    0.561612] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[    0.562876] edma 43300000.edma: memcpy is disabled
[    0.567631] edma 43300000.edma: TI EDMA DMA engine driver
[    0.567992] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-pwr_3v3[0]'
[    0.568262] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-pwr_1v8[0]'
[    0.568535] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-pwr_vtt_0v675[0]'
[    0.568907] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator@2[0]' - status (0)
[    0.571943] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[    0.572115] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[    0.572268] omap-iommu 58882000.mmu: 58882000.mmu registered
[    0.572418] omap-iommu 55082000.mmu: 55082000.mmu registered
[    0.572679] omap-iommu 41501000.mmu: 41501000.mmu registered
[    0.572863] omap-iommu 41502000.mmu: 41502000.mmu registered
[    0.574799] omap_i2c 48070000.i2c: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/i2c1_pins_default, deferring probe
[    0.574836] omap_i2c 48060000.i2c: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/i2c3_pins_default, deferring probe
[    0.574869] omap_i2c 4807c000.i2c: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/i2c5_pins_default, deferring probe
[    0.575005] media: Linux media interface: v0.10
[    0.575047] Linux video capture interface: v2.00
[    0.575079] pps_core: LinuxPPS API ver. 1 registered
[    0.575087] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.575105] PTP clock support registered
[    0.575135] EDAC MC: Ver: 3.0.0
[    0.575839] omap-mailbox 4883c000.mailbox: omap mailbox rev 0x400
[    0.576131] omap-mailbox 4883e000.mailbox: omap mailbox rev 0x400
[    0.576413] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    0.576698] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[    0.577013] Advanced Linux Sound Architecture Driver Initialized.
[    0.577817] clocksource: Switched to clocksource arch_sys_counter
[    0.588057] NET: Registered protocol family 2
[    0.588543] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.588606] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.588731] TCP: Hash tables configured (established 8192 bind 8192)
[    0.588778] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.588808] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.588935] NET: Registered protocol family 1
[    0.589303] RPC: Registered named UNIX socket transport module.
[    0.589312] RPC: Registered udp transport module.
[    0.589319] RPC: Registered tcp transport module.
[    0.589325] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.589335] PCI: CLS 0 bytes, default 64
[    0.590216] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.593127] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    0.600515] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.601226] NFS: Registering the id_resolver key type
[    0.601246] Key type id_resolver registered
[    0.601254] Key type id_legacy registered
[    0.601291] ntfs: driver 2.1.32 [Flags: R/O].
[    0.602462] bounce: pool size: 64 pages
[    0.602603] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.602613] io scheduler noop registered
[    0.602622] io scheduler deadline registered
[    0.602751] io scheduler cfq registered (default)
[    0.607190] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[    0.667313] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    0.670679] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 235, base_baud = 3000000) is a 8250
[    1.563538] console [ttyS2] enabled
[    1.568048] 48066000.serial: ttyS4 at MMIO 0x48066000 (irq = 236, base_baud = 3000000) is a 8250
[    1.578685] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[    1.585437] [drm] Initialized
[    1.589820] omapdss_dss 58000000.dss: master bind failed: -517
[    1.596328] connector-hdmi connector: failed to find video source
[    1.612866] brd: module loaded
[    1.621123] loop: module loaded
[    1.627450] m25p80 spi0.0: n25q00 (131072 Kbytes)
[    1.632262] 7 ofpart partitions found on MTD device spi0.0
[    1.637773] Creating 7 MTD partitions on "spi0.0":
[    1.642630] 0x000000000000-0x000000040000 : "QSPI.SPL"
[    1.648796] 0x000000040000-0x000000140000 : "QSPI.u-boot"
[    1.655119] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
[    1.662115] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
[    1.668828] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
[    1.676206] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
[    1.682572] 0x0000009e0000-0x000002000000 : "QSPI.file-system"
[    1.689994] libphy: Fixed MDIO Bus: probed
[    1.747853] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[    1.753978] libphy: 48485000.mdio: probed
[    1.760301] davinci_mdio 48485000.mdio: phy[0]: device 48485000.mdio:00, driver TI DP83867
[    1.769149] cpsw 48484000.ethernet: No slave[1] phy_id, phy-handle, or fixed-link property
[    1.777474] cpsw 48484000.ethernet: Detected MACID = a4:d5:78:e3:8d:14
[    1.784105] cpsw 48484000.ethernet: device node lookup for pps timer failed
[    1.791172] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[    1.799881] mousedev: PS/2 mouse device common for all mice
[    1.805772] i2c /dev entries driver
[    1.812901] cpu cpu0: dev_pm_opp_set_regulators: no regulator (vdd) found: -19
[    1.821380] omap_hsmmc 4809c000.mmc: GPIO lookup for consumer cd
[    1.821387] omap_hsmmc 4809c000.mmc: using device tree for GPIO lookup
[    1.821396] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@4809c000[0]'
[    1.821403] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@4809c000[0]'
[    1.821410] omap_hsmmc 4809c000.mmc: using lookup tables for GPIO lookup
[    1.821416] omap_hsmmc 4809c000.mmc: lookup for GPIO cd failed
[    1.821425] omap_hsmmc 4809c000.mmc: GPIO lookup for consumer wp
[    1.821431] omap_hsmmc 4809c000.mmc: using device tree for GPIO lookup
[    1.821438] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@4809c000[0]'
[    1.821444] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@4809c000[0]'
[    1.821450] omap_hsmmc 4809c000.mmc: using lookup tables for GPIO lookup
[    1.821456] omap_hsmmc 4809c000.mmc: lookup for GPIO wp failed
[    1.822162] omap_hsmmc 480b4000.mmc: GPIO lookup for consumer cd
[    1.822169] omap_hsmmc 480b4000.mmc: using device tree for GPIO lookup
[    1.822177] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@480b4000[0]'
[    1.822184] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@480b4000[0]'
[    1.822191] omap_hsmmc 480b4000.mmc: using lookup tables for GPIO lookup
[    1.822197] omap_hsmmc 480b4000.mmc: lookup for GPIO cd failed
[    1.822206] omap_hsmmc 480b4000.mmc: GPIO lookup for consumer wp
[    1.822211] omap_hsmmc 480b4000.mmc: using device tree for GPIO lookup
[    1.822218] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@480b4000[0]'
[    1.822224] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@480b4000[0]'
[    1.822230] omap_hsmmc 480b4000.mmc: using lookup tables for GPIO lookup
[    1.822236] omap_hsmmc 480b4000.mmc: lookup for GPIO wp failed
[    1.822413] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[    1.828824] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[    1.835863] omap_hsmmc 480d1000.mmc: GPIO lookup for consumer cd
[    1.835869] omap_hsmmc 480d1000.mmc: using device tree for GPIO lookup
[    1.835877] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@480d1000[0]'
[    1.835884] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@480d1000[0]'
[    1.835890] omap_hsmmc 480d1000.mmc: using lookup tables for GPIO lookup
[    1.835896] omap_hsmmc 480d1000.mmc: lookup for GPIO cd failed
[    1.835904] omap_hsmmc 480d1000.mmc: GPIO lookup for consumer wp
[    1.835910] omap_hsmmc 480d1000.mmc: using device tree for GPIO lookup
[    1.835917] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@480d1000[0]'
[    1.835923] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@480d1000[0]'
[    1.835928] omap_hsmmc 480d1000.mmc: using lookup tables for GPIO lookup
[    1.835935] omap_hsmmc 480d1000.mmc: lookup for GPIO wp failed
[    1.981771] ledtrig-cpu: registered to indicate activity on CPUs
[    1.988186] omap_hsmmc 480d1000.mmc: card claims to support voltages below defined range
[    1.997767] NET: Registered protocol family 10
[    1.998595] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.999139] NET: Registered protocol family 17
[    1.999321] Key type dns_resolver registered
[    1.999439] omap_voltage_late_init: Voltage driver support not added
[    1.999544] Power Management for TI OMAP4+ devices.
[    1.999797] Registering SWP/SWPB emulation handler
[    2.042037] dmm 4e000000.dmm: workaround for errata i878 in use
[    2.053902] dmm 4e000000.dmm: initialized all PAT entries
[    2.060096] GPIO line 216 (gpio_eMMC_RSTn) hogged as output/high
[    2.066140] gpio gpiochip6: (gpio): added GPIO chardev (254:6)
[    2.066394] gpiochip_setup_dev: registered GPIOs 192 to 223 on device: gpiochip6 (gpio)
[    2.068005] GPIO line 242 (gpio_Phy_INT_PWDn) hogged as output/high
[    2.074312] GPIO line 243 (gpio_Phy_RSTn) hogged as output/high
[    2.080299] gpio gpiochip7: (gpio): added GPIO chardev (254:7)
[    2.080575] gpiochip_setup_dev: registered GPIOs 224 to 255 on device: gpiochip7 (gpio)
[    2.091319] mmc0: new high speed SDIO card at address 0001
[    2.108383] lm75 0-0048: hwmon0: sensor 'tmp101'
[    2.113059] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[    2.119524] palmas 2-0058: Irq flag is 0x00000008
[    2.150189] palmas 2-0058: Muxing GPIO 2f, PWM 0, LED 0
[    2.158115] random: fast init done
[    2.186658] pwr_3v3: supplied by regen1
[    2.190770] pwr_1v8: supplied by regen1
[    2.194847] pwr_vtt_0v675: supplied by pwr_3v3
[    2.202338] gpiochip_find_base: found new base at 504
[    2.202354] gpio gpiochip8: (48060000.i2c:tps659038@58:tps659038_gpio): added GPIO chardev (254:8)
[    2.202585] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip8 (48060000.i2c:tps659038@58:tps659038_gpio)
[    2.202639] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[    2.249509] rtc rtc0: alarm rollover: day
[    2.249971] rtc rtc0: ds3232: dev (253:0)
[    2.249987] rtc-ds3232 4-0068: rtc core: registered ds3232 as rtc0
[    2.256348] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
[    2.263773] OMAP DSS rev 6.1
[    2.267088] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[    2.275463] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
[    2.283743] of_get_named_gpiod_flags: parsed 'hpd-gpios' property of node '/connector[0]' - status (0)
[    2.284530] omap_hsmmc 4809c000.mmc: GPIO lookup for consumer cd
[    2.284537] omap_hsmmc 4809c000.mmc: using device tree for GPIO lookup
[    2.284545] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@4809c000[0]'
[    2.284552] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@4809c000[0]'
[    2.284558] omap_hsmmc 4809c000.mmc: using lookup tables for GPIO lookup
[    2.284565] omap_hsmmc 4809c000.mmc: lookup for GPIO cd failed
[    2.284573] omap_hsmmc 4809c000.mmc: GPIO lookup for consumer wp
[    2.284579] omap_hsmmc 4809c000.mmc: using device tree for GPIO lookup
[    2.284586] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@4809c000[0]'
[    2.284592] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@4809c000[0]'
[    2.284598] omap_hsmmc 4809c000.mmc: using lookup tables for GPIO lookup
[    2.284603] omap_hsmmc 4809c000.mmc: lookup for GPIO wp failed
[    2.338289] omap_hsmmc 480b4000.mmc: GPIO lookup for consumer cd
[    2.338297] omap_hsmmc 480b4000.mmc: using device tree for GPIO lookup
[    2.338304] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@480b4000[0]'
[    2.338311] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@480b4000[0]'
[    2.338317] omap_hsmmc 480b4000.mmc: using lookup tables for GPIO lookup
[    2.338323] omap_hsmmc 480b4000.mmc: lookup for GPIO cd failed
[    2.338332] omap_hsmmc 480b4000.mmc: GPIO lookup for consumer wp
[    2.338337] omap_hsmmc 480b4000.mmc: using device tree for GPIO lookup
[    2.338344] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@480b4000[0]'
[    2.338350] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@480b4000[0]'
[    2.338355] omap_hsmmc 480b4000.mmc: using lookup tables for GPIO lookup
[    2.338362] omap_hsmmc 480b4000.mmc: lookup for GPIO wp failed
[    2.338551] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[    2.344935] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[    2.408117] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led@0[0]' - status (0)
[    2.408262] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led@1[0]' - status (0)
[    2.408394] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led@2[0]' - status (0)
[    2.408514] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led@3[0]' - status (0)
[    2.409610] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.416253] [drm] No driver support for vblank timestamp query.
[    2.431475] mmc1: host does not support reading read-only switch, assuming write-enable
[    2.442479] mmc1: new high speed SDHC card at address 59b4
[    2.448473] mmcblk1: mmc1:59b4 USD00 14.7 GiB
[    2.454892]  mmcblk1: p1 p2
[    2.485414] mmc2: new DDR MMC card at address 0001
[    2.490683] mmcblk2: mmc2:0001 MMC16G 14.6 GiB
[    2.495454] mmcblk2boot0: mmc2:0001 MMC16G partition 1 16.0 MiB
[    2.501656] mmcblk2boot1: mmc2:0001 MMC16G partition 2 16.0 MiB
[    2.515937]  mmcblk2:
[    2.731727] [drm] Enabling DMM ywrap scrolling
[    2.769639] Console: switching to colour frame buffer device 160x45
[    2.783865] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[    2.839214] rtc-ds3232 4-0068: setting system clock to 2017-12-25 16:01:39 UTC (1514217699)
[    2.849026] pwr_1v8: disabling
[    2.852114] wlan-en-regulator: disabling
[    2.856075] ALSA device list:
[    2.859082]   No soundcards found.
[    3.112549] random: crng init done
[    4.888542] EXT4-fs (mmcblk1p2): recovery complete
[    4.896010] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    4.904191] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    4.914349] devtmpfs: mounted
[    4.918686] Freeing unused kernel memory: 2048K
[    5.184569] systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[    5.203097] systemd[1]: Detected architecture arm.
[    5.239562] systemd[1]: Set hostname to <am57xx-evm>.
[    5.647468] systemd[1]: Reached target Swap.
[    5.678136] systemd[1]: Listening on Journal Socket.
[    5.709504] systemd[1]: Created slice System Slice.
[    5.740273] systemd[1]: Mounting POSIX Message Queue File System...
[    5.782587] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    5.838729] systemd[1]: Starting Load Kernel Modules...
[    5.868672] systemd[1]: Created slice system-getty.slice.
[    5.896609] cmemk: loading out-of-tree module taints kernel.
[    5.906148] CMEMK module: reference Linux version 4.9.59
[    5.919141] allocated heap buffer 0x40500000 of size 0x100000
[    5.925757] cmemk initialized
[    5.945375] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[    5.970709] cryptodev: driver 1.8 loaded.
[    7.138097] systemd-journald[133]: Received request to flush runtime journal from PID 1
[    8.388354] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
[    8.396248] remoteproc remoteproc0: 58820000.ipu is available
[    8.496109] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
[    8.560898] remoteproc remoteproc1: 55020000.ipu is available
[    8.664552] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
[    8.784086] remoteproc remoteproc2: 40800000.dsp is available
[    8.817155] remoteproc remoteproc0: powering up 58820000.ipu
[    8.817168] remoteproc remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 4687356
[    8.817271] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
[    8.925187] remoteproc remoteproc1: powering up 55020000.ipu
[    8.925199] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3738980
[    8.925293] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[    9.082983] rtc rtc1: 48060000.i2c:tps659: dev (253:1)
[    9.082992] palmas-rtc 48060000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48060000.i2c:tps659 as rtc1
[    9.393603] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[    9.422432] omap-des 480a5000.des: will run requests pump with realtime priority
[    9.581270] rtc rtc2: 48838000.rtc: dev (253:2)
[    9.581286] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc2
[    9.608428] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
[    9.656697] remoteproc remoteproc3: 41000000.dsp is available
[    9.744463] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[    9.958440] vpe 489d0000.vpe: Device registered as /dev/video0
[   10.339555] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[   10.528201] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[   10.566753] omap-aes 4b500000.aes: will run requests pump with realtime priority
[   10.734344] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[   10.757887] omap-aes 4b700000.aes: will run requests pump with realtime priority
[   10.845239] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[   10.899533] SCSI subsystem initialized
[   11.017349] libata version 3.00 loaded.
[   11.181601] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
[   11.523453] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[   11.560769] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[   11.645028] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[   12.185516] remoteproc remoteproc2: powering up 40800000.dsp
[   12.192118] remoteproc remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 19467560
[   12.293997] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[   12.299902] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[   12.305871] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[   12.343143] remoteproc remoteproc3: powering up 41000000.dsp
[   12.348932] remoteproc remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 19467560
[   12.496961] Bluetooth: Core ver 2.22
[   12.497014] NET: Registered protocol family 31
[   12.497017] Bluetooth: HCI device and connection manager initialized
[   12.497030] Bluetooth: HCI socket layer initialized
[   12.497041] Bluetooth: L2CAP socket layer initialized
[   12.497074] Bluetooth: SCO socket layer initialized
[   12.559880] net eth0: initializing cpsw version 1.15 (0)
[   12.559888] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[   12.559894] cpsw 48484000.ethernet: ALE Table size 1024
[   12.636081] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   13.375454] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
[   13.381357] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[   13.387298] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[   13.404336] TI DP83867 48485000.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=48485000.mdio:00, irq=-1)
[   13.509681] libphy: PHY  not found
[   13.551742] net eth0: phy "" not found on slave 1, err -19
[   13.655781] cpts ptp bc clkid 0
[   13.714232] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   14.880928] NET: Registered protocol family 15
[   15.656854] Initializing XFRM netlink socket
[   15.681159] ti-pruss 4b200000.pruss: creating PRU cores and other child platform devices
[   15.683401] irq: no irq domain found for /ocp/pruss_soc_bus@4b226000/pruss@4b200000/intc@4b220000 !
[   15.684017] irq: no irq domain found for /ocp/pruss_soc_bus@4b226000/pruss@4b200000/intc@4b220000 !
[   15.684901] ti-pruss 4b280000.pruss: creating PRU cores and other child platform devices
[   15.713488] irq: no irq domain found for /ocp/pruss_soc_bus@4b2a6000/pruss@4b280000/intc@4b2a0000 !
[   15.714181] irq: no irq domain found for /ocp/pruss_soc_bus@4b2a6000/pruss@4b280000/intc@4b2a0000 !
[   15.949087] remoteproc remoteproc4: 4b234000.pru0 is available
[   15.949144] pru-rproc 4b234000.pru0: PRU rproc node /ocp/pruss_soc_bus@4b226000/pruss@4b200000/pru@4b234000 probed successfully
[   15.949510] remoteproc remoteproc5: 4b238000.pru1 is available
[   15.949558] pru-rproc 4b238000.pru1: PRU rproc node /ocp/pruss_soc_bus@4b226000/pruss@4b200000/pru@4b238000 probed successfully
[   15.949933] remoteproc remoteproc6: 4b2b4000.pru0 is available
[   15.949981] pru-rproc 4b2b4000.pru0: PRU rproc node /ocp/pruss_soc_bus@4b2a6000/pruss@4b280000/pru@4b2b4000 probed successfully
[   15.950334] remoteproc remoteproc7: 4b2b8000.pru1 is available
[   15.950391] pru-rproc 4b2b8000.pru1: PRU rproc node /ocp/pruss_soc_bus@4b2a6000/pruss@4b280000/pru@4b2b8000 probed successfully
[   16.088554] wl18xx_driver wl18xx.1.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
[   16.529327] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[   16.692823] wlcore: loaded
[   16.805678] cpsw 48484000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   16.861603] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   17.496684] wlcore: PHY firmware version: Rev 8.2.0.0.237
[   17.671854] wlcore: firmware booted (Rev 8.9.0.0.70)
[   19.040624] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[   81.115746] omapdss error: HDMI I2C Master Error
root@am57xx-evm:~#
