Part Number: TDA2EXEVM
Hi:
I changed the input size of SSD model from 768x320 to 420x240 ,retrained it,and convert to tidl formart.
It work success in the "TIDL File I/O Usecase".
Then I change the input size in file "chains_tidlOD.c" as:
#define TIDL_OD_INPUT_WIDTH (420)
#define TIDL_OD_INPUT_HEIGHT (240)
#define DEC_OUT_WIDTH (420)
#define DEC_OUT_HEIGHT (240)
#define TIDL_OD_DISPLAY_WIDTH (TIDL_OD_INPUT_WIDTH*2)
#define TIDL_OD_DISPLAY_HEIGHT (TIDL_OD_INPUT_HEIGHT*2)
#define TIDL_OD_DISPLAY_STARTX (1920 - TIDL_OD_DISPLAY_WIDTH)/2
#define TIDL_OD_DISPLAY_STARTY (64)
But when I run it in the "3: TIDL OD Usecase",there has an error,the print log is below:
[IPU1-0] TIDL Usecases
[IPU1-0] ---------------
[IPU1-0] 1: TIDL File I/O Usecase
[IPU1-0] 2: Semantic Segmentation Usecase
[IPU1-0] 3: TIDL OD Usecase
[IPU1-0]
[IPU1-0] x: Exit
[IPU1-0]
[IPU1-0] Enter Choice:
[IPU1-0]
[IPU1-0] 18.415085 s:
[IPU1-0] 20.241841 s: FILE: Reading file [inHeader_OD] ...
[IPU1-0] 20.249161 s: FILE: File read Done. [15600 bytes]
[IPU1-0] 20.261758 s: DECODE: Create in progress ... !!!
[IPU1-0] 20.394528 s: DECODE: Creating CH0 of 420 x 240 [1] [0],target bitrate = 10000 Kbps ...
[IPU1-0] 20.395321 s: DECODE: All CH Create ... DONE !!!
[IPU1-0] 20.397151 s: DECODE: Create ... DONE !!!
[IPU1-0] 20.397517 s: VPE: Create in progress !!!
[IPU1-0] 20.472152 s: VPE: Loading Down-scaling Co-effs
[IPU1-0] 20.472396 s: VPE: Co-effs Loading ... DONE !!!
[IPU1-0] 20.472579 s: VPE: Create Done !!!
[IPU1-0] 20.473677 s: IPC_OUT_0 : Create in progress !!!
[IPU1-0] 20.474074 s: IPC_OUT_0 : Create Done !!!
[HOST ] 20.474257 s: IPC_IN_0 : Create in progress !!!
[HOST ] 20.474562 s: IPC_IN_0 : Create Done !!!
[HOST ] 20.474684 s: ALGORITHM: Create in progress (algId = 12) !!!
[HOST ] 20.479594 s: UTILS: DMA: Allocated CH (TCC) = 0 (0)
[HOST ] 20.479625 s: UTILS: DMA: 0 of 1: Allocated PaRAM = 0 (0x43305600)
[HOST ] 20.479625 s: ALGORITHM: Create Done (algId = 12) !!!
[HOST ] 20.479716 s: IPC_OUT_3 : Create in progress !!!
[HOST ] 20.479777 s: IPC_OUT_3 : Create Done !!!
[EVE4 ] 20.480052 s: IPC_IN_0 : Create in progress !!!
[EVE4 ] 20.480936 s: IPC_IN_0 : Create Done !!!
[EVE4 ] 20.481760 s: ALGORITHM: Create in progress (algId = 14) !!!
[HOST ] 23.134539 s: IPC_OUT_2 : Create in progress !!!
[HOST ] 23.134569 s: IPC_OUT_2 : Create Done !!!
[DSP1 ] 23.133837 s: IPC_IN_3 : Create in progress !!!
[DSP1 ] 23.134386 s: IPC_IN_3 : Create Done !!!
[EVE3 ] 23.134874 s: IPC_IN_0 : Create in progress !!!
[EVE3 ] 23.135759 s: IPC_IN_0 : Create Done !!!
[EVE3 ] 23.136491 s: ALGORITHM: Create in progress (algId = 14) !!!
[EVE4 ] 23.132343 s: ALGORITHM: Create Done (algId = 14) !!!
[EVE4 ] 23.132953 s: IPC_OUT_0 : Create in progress !!!
[EVE4 ] 23.133410 s: IPC_OUT_0 : Create Done !!!
[HOST ] 25.789452 s: IPC_OUT_1 : Create in progress !!!
[HOST ] 25.789483 s: IPC_OUT_1 : Create Done !!!
[DSP1 ] 25.788629 s: IPC_IN_2 : Create in progress !!!
[DSP1 ] 25.789300 s: IPC_IN_2 : Create Done !!!
[EVE2 ] 25.789757 s: IPC_IN_0 : Create in progress !!!
[EVE2 ] 25.790672 s: IPC_IN_0 : Create Done !!!
[EVE2 ] 25.791435 s: ALGORITHM: Create in progress (algId = 14) !!!
[EVE3 ] 25.787104 s: ALGORITHM: Create Done (algId = 14) !!!
[EVE3 ] 25.787714 s: IPC_OUT_0 : Create in progress !!!
[EVE3 ] 25.788171 s: IPC_OUT_0 : Create Done !!!
[HOST ] 28.463338 s: IPC_OUT_0 : Create in progress !!!
[HOST ] 28.463399 s: IPC_OUT_0 : Create Done !!!
[DSP1 ] 28.462544 s: IPC_IN_1 : Create in progress !!!
[DSP1 ] 28.463185 s: IPC_IN_1 : Create Done !!!
[EVE1 ] 28.463673 s: IPC_IN_0 : Create in progress !!!
[EVE1 ] 28.464558 s: IPC_IN_0 : Create Done !!!
[EVE1 ] 28.465320 s: ALGORITHM: Create in progress (algId = 14) !!!
[EVE2 ] 28.460928 s: ALGORITHM: Create Done (algId = 14) !!!
[EVE2 ] 28.461538 s: IPC_OUT_0 : Create in progress !!!
[EVE2 ] 28.462087 s: IPC_OUT_0 : Create Done !!!
[DSP1 ] 31.134386 s: IPC_IN_0 : Create in progress !!!
[DSP1 ] 31.134874 s: IPC_IN_0 : Create Done !!!
[DSP1 ] 31.135301 s: ALGORITHM: Create in progress (algId = 36) !!!
[EVE1 ] 31.132678 s: ALGORITHM: Create Done (algId = 14) !!!
[EVE1 ] 31.133471 s: IPC_OUT_0 : Create in progress !!!
[EVE1 ] 31.133929 s: IPC_OUT_0 : Create Done !!!
[IPU1-0] 31.154090 s: IPC_IN_0 : Create in progress !!!
[IPU1-0] 31.155127 s: IPC_IN_0 : Create Done !!!
[IPU1-0] 31.156225 s: ALGORITHM: Create in progress (algId = 1) !!!
[IPU1-0] 31.157262 s: UTILS: DMA: Allocated CH (TCC) = 48 (48)
[IPU1-0] 31.157384 s: UTILS: DMA: 0 of 1: Allocated PaRAM = 48 (0x63304800)
[IPU1-0] 31.164765 s: ALGORITHM: Create Done (algId = 1) !!!
[IPU1-0] 31.164978 s: DISPLAY: Create in progress !!!
[IPU1-0] 31.165314 s: dispcore/src/vpscore_dss.c @ Line 1053:
[IPU1-0] 31.165405 s: Pitch less than Width
[IPU1-0] 31.165497 s: dispdrv/src/vpsdrv_displayCore.c @ Line 304:
[IPU1-0] 31.165558 s: Set DSS parameter failed
[IPU1-0] 31.165619 s: Assertion @ Line: 459 in displayLink_drv.c: status==SYSTEM_LINK_STATUS_SOK : failed !!!
[IPU1-0] 31.166076 s: Assertion @ Line: 459 in displayLink_drv.c: status==SYSTEM_LINK_STATUS_SOK : failed !!!
[DSP1 ] 31.153693 s: ALGORITHM: Create Done (algId = 36) !!!
[DSP1 ] 31.153907 s: IPC_OUT_0 : Create in progress !!!
[DSP1 ] 31.153968 s: IPC_OUT_0 : Create Done !!!
What I missing?Pls help me!
