DSP Link / DSP Boot Issue
Basically we built a custom board and I’ve got it pretty far along, I’ve written the device drivers for the encoder and decoder have them integrated into the kernel and linux is booting and I’m performing video loopback tests.
I also wrote some  IUNIVERSAL algorithms for the DSP and have them running via the codec server on the EVM board. The issue is that the board hangs when I run the exact same code from our custom board. I figured this would be straight forward because the DSP and ARM are obviously on the same chip.  My assumptions were that the DSP/Link boots the DSP with the codec server I have created when I call CERuntime_init(). Is it correct that the DSP is taken out of reset when the CERuntime_init() is called and DSP/Link loads the codec server?  I’m stumbling around a little here searching for some registers I may have configured incorrectly and what not, any help would be greatly appreciated.  I’m not sure what the difference between my board and the EVM is in terms of configuration. Granted the EVM is 1 GHz and our board is currently the 594 MHz, but everything else seems to be configured properly and working. I must be missing something here.
    Do you have more information on the point in the processing at which it hangs? Does it hang while booting the DSP (In PROC_start)? Can you enable some Codec Engine traces to get more information?
    This might help:
    http://processors.wiki.ti.com/index.php/TraceUtil
    Or this (to enable DSPLink trace):
    http://processors.wiki.ti.com/index.php/Enabling_trace_in_DSPLink
    http://processors.wiki.ti.com/index.php/Debugging_DSPLink_using_SET_FAILURE_REASON_prints
    Mugdha
    Close.  That happens at Engine_open.
  • I've attached a traces with CE_DEBUG=2 for the EVM and for my custom board. I hangs when I make my first _control() call. I'll see what other debugging I can enable...
    EVM CE_DEBUG:
    @0,564,527us: [+4 T:0x4001ea50] OG - Global_init> This program was built with the following packages:
    @0,565,126us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.h2641080p60vdec (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/) [1, 0, 0]
    @0,565,268us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.h264dec (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264dec/) [1, 0, 0]
    @0,565,359us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.h264enc (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264enc/) [1, 0, 0]
    @0,565,445us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.h264fhdvenc (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/) [1, 0, 0]
    @0,565,531us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.mpeg2dec (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg2dec/) [1, 0, 0]
    @0,565,614us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.mpeg4dec (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4dec/) [1, 0, 0]
    @0,565,696us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.mpeg4enc (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4enc/) [1, 0, 0]
    @0,565,779us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.global (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/global/) [1, 0, 0]
    @0,565,860us: [+4 T:0x4001ea50] OG -     package ti.xdais.dm (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdais_6_25_02_11/packages/ti/xdais/dm/) [1, 0, 5]
    @0,565,941us: [+4 T:0x4001ea50] OG -     package ti.sdo.utils.trace (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/utils/trace/) [1, 0, 0]
    @0,566,025us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.utils.xdm (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/utils/xdm/) [1, 0, 2]
    @0,566,177us: [+4 T:0x4001ea50] OG -     package dsplink.gpp (/home/bbergan/dvsdk/dvsdk_3_10_00_19/dsplink_linux_1_64/dsplink/gpp/) [5, 0, 0]
    @0,566,265us: [+4 T:0x4001ea50] OG -     package ti.sdo.linuxutils.cmem (/home/bbergan/dvsdk/dvsdk_3_10_00_19/linuxutils_2_25_04_10/packages/ti/sdo/linuxutils/cmem/) [2, 2, 0]
    @0,566,352us: [+4 T:0x4001ea50] OG -     package ti.xdais (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdais_6_25_02_11/packages/ti/xdais/) [1, 2.0, 1]
    @0,566,435us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.node (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/node/) [1, 0, 0]
    @0,566,517us: [+4 T:0x4001ea50] OG -     package ti.sdo.fc.global (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/global/) [1, 0, 0]
    @0,566,601us: [+4 T:0x4001ea50] OG -     package ti.sdo.fc.memutils (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/memutils/) [1, 0, 0]
    @0,566,685us: [+4 T:0x4001ea50] OG -     package ti.sdo.fc.utils (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/utils/) [1, 0, 2]
    @0,566,769us: [+4 T:0x4001ea50] OG -     package ti.sdo.fc.dman3 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/dman3/) [1, 0, 4]
    @0,566,853us: [+4 T:0x4001ea50] OG -     package ti.sdo.fc.acpy3 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/acpy3/) [1, 0, 4]
    @0,567,014us: [+4 T:0x4001ea50] OG -     package gnu.targets (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/gnu/targets/) [1, 0, 1]
    @0,567,109us: [+4 T:0x4001ea50] OG -     package gnu.targets.arm (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/gnu/targets/arm/) [1, 0, 0, 0]
    @0,567,196us: [+4 T:0x4001ea50] OG -     package ti.catalog.arm (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/catalog/arm/) [1, 0, 1, 0]
    @0,567,280us: [+4 T:0x4001ea50] OG -     package ti.catalog (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/catalog/) [1, 0, 0]
    @0,567,463us: [+4 T:0x4001ea50] OG -     package ti.catalog.c6000 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/catalog/c6000/) [1, 0, 0, 0]
    @0,567,560us: [+4 T:0x4001ea50] OG -     package ti.platforms.evmDM6467T (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/platforms/evmDM6467T/) [1, 0, 0, 0]
    @0,567,647us: [+4 T:0x4001ea50] OG -     package gnu.targets.arm.rtsv5T (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/gnu/targets/arm/rtsv5T/) [1, 0, 0, 0]
    @0,567,733us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.osal (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/osal/) [2, 0, 2]
    @0,567,826us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.ipc (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/ipc/) [2, 0, 1]
    @0,567,912us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.osal.linux (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/osal/linux/) [2, 0, 1]
    @0,567,997us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.ipc.dsplink (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/ipc/dsplink/) [2, 0, 1]
    @0,568,080us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.alg (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/alg/) [1, 0, 1]
    @0,568,165us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/) [1, 0, 6]
    @0,568,248us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.universal (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/universal/) [1, 0, 0]
    @0,568,332us: [+4 T:0x4001ea50] OG -     package adsys.insight (/home/bbergan/projects/Insight/cetest/adsys/insight/) [1, 0, 0]
    @0,568,412us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.video2 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/video2/) [1, 0, 2]
    @0,568,497us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.h2641080p60vdec.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/ce/) [1, 0, 0]
    @0,568,582us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.h264dec.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264dec/ce/) [1, 0, 0]
    @0,568,667us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.video1 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/video1/) [1, 0, 2]
    @0,568,750us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.h264enc.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264enc/ce/) [1, 0, 0]
    @0,568,835us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.h264fhdvenc.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/ce/) [1, 0, 0]
    @0,568,920us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.mpeg2dec.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg2dec/ce/) [1, 0, 0]
    @0,569,004us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.mpeg4dec.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4dec/ce/) [1, 0, 0]
    @0,569,091us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.mpeg4enc.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4enc/ce/) [1, 0, 0]
    @0,569,177us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.speech (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/speech/) [1, 0, 2]
    @0,569,261us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.speech1 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/speech1/) [1, 0, 1]
    @0,569,347us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.audio (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/audio/) [1, 0, 2]
    @0,569,430us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.audio1 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/audio1/) [1, 0, 1]
    @0,569,561us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.video (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/video/) [1, 0, 3]
    @0,569,653us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.image (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/image/) [1, 0, 3]
    @0,569,737us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.image1 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/image1/) [1, 0, 1]
    @0,569,822us: [+4 T:0x4001ea50] OG -     package ti.sdo.dmai (/home/bbergan/dvsdk/dvsdk_3_10_00_19/dmai_2_10_00_12/packages/ti/sdo/dmai/) [1, 0, 0]
    @0,569,904us: [+4 T:0x4001ea50] OG -     package ipm (/home/bbergan/projects/Insight/ipm_v0.0.5/ipm/) []
    @0,570,363us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @0,570,509us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x5b1c0]
    @0,570,611us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @0,570,703us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x5b1d8]
    @0,570,797us: [+0 T:0x4001ea50] OT - Thread_create> Enter (fxn=0x24174, attrs=0x0)
    @0,571,315us: [+0 T:0x4001ea50] OT - Thread_create> Exit (task=0x5b210)
    @0,571,543us: [+0 T:0x4001ea50] ti.sdo.ce.alg - ALG_init> Enter
    @0,571,647us: [+0 T:0x4001ea50] ti.sdo.ce.alg - ALG_init> Exit
    @0,571,818us: [+6 T:0x4001ea50] CE - Engine_init> CE debugging on (CE_DEBUG=2; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
    @0,571,995us: [+0 T:0x4001ea50] CS - Server_init()
    @0,572,091us: [+0 T:0x4001ea50] CS - Server_init> Global_useLinkArbiter = 0
    @0,572,237us: [+0 T:0x4001ea50] CE - Engine_open> Enter('InSightEngine', 0x0, 0xbe910b20)
    @0,572,351us: [+0 T:0x4001ea50] CE - rserverOpen('ias.x64P'), count = 0
    @0,572,477us: [+0 T:0x4001ea50] OP - Processor_create> Enter(imageName='ias.x64P', linkCfg='(null)', attrs=0xbe9108d8)
    @0,572,939us: [+1 T:0x40b03490] OP - daemon> thread created.
    @0,573,057us: [+0 T:0x40b03490] OP - getCmd_d> Enter (proc=0x40b02dd8)
    @0,573,157us: [+0 T:0x40b03490] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5b1c0] timeout[0xffffffff]
    @0,574,041us: [+0 T:0x4001ea50] OP - doCmd> Enter (cmdId=1, proc=0x5b4e0)
    @0,574,164us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x5b1c0]
    @0,574,319us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x5b1c0]
    @0,574,424us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5b1d8] timeout[0xffffffff]
    @0,574,554us: [+0 T:0x40b03490] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x5b1c0] status[0]
    @0,574,659us: [+0 T:0x40b03490] OP - getCmd_d> Exit (result=1)
    @0,574,753us: [+0 T:0x40b03490] OP - Processor_create_d> Enter(proc=0x5b4e0)
    @0,574,845us: [+2 T:0x40b03490] OP - Processor_create_d> Initializing DSP PROC...
    @0,574,939us: [+2 T:0x40b03490] OP - Processor_create_d> Using DspLink config data for entry #0 [server 'ias.x64P']
    @0,575,085us: [+2 T:0x40b03490] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0x8fa00000, sizeInBytes=0x400000, shared=1, syncd=0
    @0,575,210us: [+2 T:0x40b03490] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x8fe00000, sizeInBytes=0x100000, shared=1, syncd=0
    @0,575,321us: [+2 T:0x40b03490] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESET_VECTOR', startAddress=0x8ff00000, sizeInBytes=0x80, shared=1, syncd=0
    @0,575,427us: [+2 T:0x40b03490] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='DDRALGHEAP', startAddress=0x88000000, sizeInBytes=0x7a00000, shared=0, syncd=0
    @0,575,531us: [+2 T:0x40b03490] OP - Processor_create_d> DODSPCTRL was=1; now=0
    @0,575,658us: [+3 T:0x40b03490] OP - LINKCFG_Object generated for PROC_setup(0x596bc) ...
    @0,575,760us: [+3 T:0x40b03490] OP - linkCfg->gppObject->
    @0,575,848us: [+3 T:0x40b03490] OP -   name = "ARM9"
    @0,575,934us: [+3 T:0x40b03490] OP -   maxMsgqs = 0x82
    @0,576,018us: [+3 T:0x40b03490] OP -   maxChnlQueue = 0x10
    @0,576,105us: [+3 T:0x40b03490] OP -   poolTableId = 0xffffffff
    @0,576,233us: [+3 T:0x40b03490] OP -   numPools = 0x0
    @0,576,326us: [+3 T:0x40b03490] OP -
    @0,576,409us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->dspObject->
    @0,576,496us: [+3 T:0x40b03490] OP -   name = "DM6467GEM"
    @0,576,580us: [+3 T:0x40b03490] OP -   dspArch = 0x2
    @0,576,665us: [+3 T:0x40b03490] OP -   loaderName = "COFF"
    @0,576,750us: [+3 T:0x40b03490] OP -   autoStart = FALSE
    @0,576,833us: [+3 T:0x40b03490] OP -   execName = "DEFAULT.OUT"
    @0,576,995us: [+3 T:0x40b03490] OP -   doDspCtrl = DSP_BootMode_Boot_NoPwr
    @0,577,089us: [+3 T:0x40b03490] OP -   resumeAddr = 0x8ff00020
    @0,577,181us: [+3 T:0x40b03490] OP -   resetVector = 0x8ff00000
    @0,577,269us: [+3 T:0x40b03490] OP -   resetCodeSize = 0x80
    @0,577,355us: [+3 T:0x40b03490] OP -   maduSize = 0x1
    @0,577,439us: [+3 T:0x40b03490] OP -   cpuFreq = 0x91050
    @0,577,525us: [+3 T:0x40b03490] OP -   endian = 0x3
    @0,577,609us: [+3 T:0x40b03490] OP -   wordSwap = 0x0
    @0,577,696us: [+3 T:0x40b03490] OP -   memTableId = 0x0
    @0,577,781us: [+3 T:0x40b03490] OP -   memEntries = 0x4
    @0,577,866us: [+3 T:0x40b03490] OP -   linkDrvId = 0x0
    @0,577,950us: [+3 T:0x40b03490] OP -   arg1 = 0xffffffff
    @0,578,036us: [+3 T:0x40b03490] OP -   arg2 = 0xffffffff
    @0,578,123us: [+3 T:0x40b03490] OP -   arg3 = 0x0
    @0,578,208us: [+3 T:0x40b03490] OP -   arg4 = 0x0
    @0,578,292us: [+3 T:0x40b03490] OP -   arg5 = 0xffffffff
    @0,578,376us: [+3 T:0x40b03490] OP -
    @0,578,458us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->linkDrvObjects->
    @0,578,544us: [+3 T:0x40b03490] OP -   name = "SHMDRV"
    @0,578,628us: [+3 T:0x40b03490] OP -   hshkPollCount = 0x5f5e100
    @0,578,715us: [+3 T:0x40b03490] OP -   memEntry = 0x1
    @0,578,799us: [+3 T:0x40b03490] OP -   ipsTableId = 0x0
    @0,578,885us: [+3 T:0x40b03490] OP -   numIpsEntries = 0x1
    @0,578,970us: [+3 T:0x40b03490] OP -   poolTableId = 0x0
    @0,579,055us: [+3 T:0x40b03490] OP -   numPools = 0x1
    @0,579,141us: [+3 T:0x40b03490] OP -   dataTableId = 0x0
    @0,579,227us: [+3 T:0x40b03490] OP -   numDataDrivers = 0x1
    @0,579,313us: [+3 T:0x40b03490] OP -   mqtId = 0x0
    @0,579,398us: [+3 T:0x40b03490] OP -   ringIoTableId = 0x0
    @0,579,483us: [+3 T:0x40b03490] OP -   mplistTableId = 0x0
    @0,579,570us: [+3 T:0x40b03490] OP -   mpcsTableId = 0x0
    @0,579,654us: [+3 T:0x40b03490] OP -
    @0,579,734us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->memTables[0][i].
    @0,579,822us: [+3 T:0x40b03490] OP - entry #0:
    @0,579,907us: [+3 T:0x40b03490] OP -   entry = 0x0
    @0,579,993us: [+3 T:0x40b03490] OP -   name = "DDR2"
    @0,580,077us: [+3 T:0x40b03490] OP -   physAddr = 0x8fa00000
    @0,580,165us: [+3 T:0x40b03490] OP -   dspVirtAddr = 0x8fa00000
    @0,580,249us: [+3 T:0x40b03490] OP -   gppVirtAddr = 0xffffffff
    @0,580,335us: [+3 T:0x40b03490] OP -   size = 0x400000
    @0,580,420us: [+3 T:0x40b03490] OP -   shared = TRUE
    @0,580,504us: [+3 T:0x40b03490] OP -   syncd = FALSE
    @0,580,589us: [+3 T:0x40b03490] OP - entry #1:
    @0,580,674us: [+3 T:0x40b03490] OP -   entry = 0x1
    @0,580,759us: [+3 T:0x40b03490] OP -   name = "DSPLINKMEM"
    @0,580,844us: [+3 T:0x40b03490] OP -   physAddr = 0x8fe00000
    @0,580,929us: [+3 T:0x40b03490] OP -   dspVirtAddr = 0x8fe00000
    @0,581,016us: [+3 T:0x40b03490] OP -   gppVirtAddr = 0xffffffff
    @0,581,105us: [+3 T:0x40b03490] OP -   size = 0x100000
    @0,581,191us: [+3 T:0x40b03490] OP -   shared = TRUE
    @0,581,274us: [+3 T:0x40b03490] OP -   syncd = FALSE
    @0,581,360us: [+3 T:0x40b03490] OP - entry #2:
    @0,581,442us: [+3 T:0x40b03490] OP -   entry = 0x2
    @0,581,526us: [+3 T:0x40b03490] OP -   name = "RESET_VECTOR"
    @0,581,609us: [+3 T:0x40b03490] OP -   physAddr = 0x8ff00000
    @0,581,695us: [+3 T:0x40b03490] OP -   dspVirtAddr = 0x8ff00000
    @0,581,781us: [+3 T:0x40b03490] OP -   gppVirtAddr = 0xffffffff
    @0,581,867us: [+3 T:0x40b03490] OP -   size = 0x80
    @0,581,951us: [+3 T:0x40b03490] OP -   shared = TRUE
    @0,582,035us: [+3 T:0x40b03490] OP -   syncd = FALSE
    @0,582,121us: [+3 T:0x40b03490] OP - entry #3:
    @0,582,206us: [+3 T:0x40b03490] OP -   entry = 0x3
    @0,582,290us: [+3 T:0x40b03490] OP -   name = "DDRALGHEAP"
    @0,582,374us: [+3 T:0x40b03490] OP -   physAddr = 0x88000000
    @0,582,460us: [+3 T:0x40b03490] OP -   dspVirtAddr = 0x88000000
    @0,582,592us: [+3 T:0x40b03490] OP -   gppVirtAddr = 0xffffffff
    @0,582,684us: [+3 T:0x40b03490] OP -   size = 0x7a00000
    @0,582,774us: [+3 T:0x40b03490] OP -   shared = FALSE
    @0,582,861us: [+3 T:0x40b03490] OP -   syncd = FALSE
    @0,582,948us: [+3 T:0x40b03490] OP -
    @0,583,032us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->ipsTables[0][i].
    @0,583,123us: [+3 T:0x40b03490] OP - entry #0:
    @0,583,206us: [+3 T:0x40b03490] OP -   name = "IPS"
    @0,583,291us: [+3 T:0x40b03490] OP -   numIpsEvents = 0x20
    @0,583,378us: [+3 T:0x40b03490] OP -   memEntry = 0x1
    @0,583,463us: [+3 T:0x40b03490] OP -   gppIntId = 0x2d
    @0,583,549us: [+3 T:0x40b03490] OP -   dspIntId = 0x10
    @0,583,634us: [+3 T:0x40b03490] OP -   dspIntVectorId = 0x4
    @0,583,721us: [+3 T:0x40b03490] OP -   arg1 = 0x2faf080
    @0,583,805us: [+3 T:0x40b03490] OP -   arg2 = 0x0
    @0,583,890us: [+3 T:0x40b03490] OP -
    @0,583,971us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->poolTables[0][i].
    @0,584,058us: [+3 T:0x40b03490] OP -
    @0,584,141us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->dataTables[0][i].
    @0,584,230us: [+3 T:0x40b03490] OP - entry #0:
    @0,584,313us: [+3 T:0x40b03490] OP -   name = "ZCPYDATA"
    @0,584,398us: [+3 T:0x40b03490] OP -   baseChnlId = 0x0
    @0,584,483us: [+3 T:0x40b03490] OP -   numChannels = 0x10
    @0,584,570us: [+3 T:0x40b03490] OP -   maxBufSize = 0x4000
    @0,584,655us: [+3 T:0x40b03490] OP -   memEntry = 0x1
    @0,584,742us: [+3 T:0x40b03490] OP -   poolId = 0x0
    @0,584,827us: [+3 T:0x40b03490] OP -   queuePerChnl = 0x1
    @0,584,912us: [+3 T:0x40b03490] OP -   ipsId = 0x0
    @0,584,998us: [+3 T:0x40b03490] OP -   ipsEventNo = 0x2
    @0,585,084us: [+3 T:0x40b03490] OP -   arg1 = 0x0
    @0,585,172us: [+3 T:0x40b03490] OP -   arg2 = 0x0
    @0,585,258us: [+3 T:0x40b03490] OP -
    @0,585,339us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->mqtObjects->
    @0,585,425us: [+3 T:0x40b03490] OP -   name = "ZCPYMQT"
    @0,585,510us: [+3 T:0x40b03490] OP -   memEntry = 0x1
    @0,585,596us: [+3 T:0x40b03490] OP -   maxMsgSize = 0xffffffff
    @0,585,680us: [+3 T:0x40b03490] OP -   ipsId = 0x0
    @0,585,765us: [+3 T:0x40b03490] OP -   ipsEventNo = 0x1
    @0,585,851us: [+3 T:0x40b03490] OP -   arg1 = 0x0
    @0,585,937us: [+3 T:0x40b03490] OP -   arg2 = 0x0
    @0,586,020us: [+3 T:0x40b03490] OP -
    @0,586,103us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->ringIoObjects->
    @0,586,189us: [+3 T:0x40b03490] OP -   name = "RINGIOTABLE"
    @0,586,274us: [+3 T:0x40b03490] OP -   memEntry = 0x1
    @0,586,361us: [+3 T:0x40b03490] OP -   maxEntries = 0x40
    @0,586,448us: [+3 T:0x40b03490] OP -   ipsId = 0x0
    @0,586,535us: [+3 T:0x40b03490] OP -   ipsEventNo = 0x0
    @0,586,621us: [+3 T:0x40b03490] OP -
    @0,586,702us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->mplistObjects->
    @0,586,789us: [+3 T:0x40b03490] OP -   name = "MPLISTTABLE"
    @0,586,938us: [+3 T:0x40b03490] OP -   memEntry = 0x1
    @0,587,039us: [+3 T:0x40b03490] OP -   maxEntries = 0x40
    @0,587,133us: [+3 T:0x40b03490] OP -   ipsId = 0xffffffff
    @0,587,221us: [+3 T:0x40b03490] OP -   ipsEventNo = 0xffffffff
    @0,587,310us: [+3 T:0x40b03490] OP -
    @0,587,390us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->mpcsObjects->
    @0,587,478us: [+3 T:0x40b03490] OP -   name = "MPCS"
    @0,587,563us: [+3 T:0x40b03490] OP -   memEntry = 0x1
    @0,587,648us: [+3 T:0x40b03490] OP -   maxEntries = 0x100
    @0,587,734us: [+3 T:0x40b03490] OP -   ipsId = 0xffffffff
    @0,587,819us: [+3 T:0x40b03490] OP -   ipsEventNo = 0xffffffff
    @0,592,865us: [+2 T:0x40b03490] OP - Processor_create_d> Attaching to DSP PROC...
    @0,605,592us: [+2 T:0x40b03490] OP - Processor_create_d> Opening MSGQ pool...
    @0,606,300us: [+2 T:0x40b03490] OP - Processor_create_d> Loading ias.x64P on DSP (1 args)...
    @0,777,653us: [+2 T:0x40b03490] OP - Processor_create_d> Starting DSP PROC...
    @0,802,450us: [+2 T:0x40b03490] OP - Processor_create_d> Opening remote transport...
    @0,803,920us: [+2 T:0x40b03490] OP - Processor_create_d> return (1)
    @0,804,041us: [+0 T:0x40b03490] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x5b1d8]
    @0,804,186us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x5b1d8] status[0]
    @0,804,349us: [+0 T:0x4001ea50] OP - doCmd> Exit (result=1)
    @0,804,447us: [+0 T:0x4001ea50] OP - Processor_create> return (0x5b4e0)
    @0,804,539us: [+0 T:0x4001ea50] CE - rserverOpen('ias.x64P'): 0x59e24 done.
    @0,806,501us: [+0 T:0x40b03490] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x5b1d8]
    @0,806,623us: [+0 T:0x40b03490] OP - getCmd_d> Enter (proc=0x40b02dd8)
    @0,806,720us: [+0 T:0x40b03490] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5b1c0] timeout[0xffffffff]
    @0,807,047us: [+0 T:0x4001ea50] CE - checkServer(0x5b4b0)
    @0,807,424us: [+0 T:0x4001ea50] CE - rmsInit> RMS initialized(0x5b4b0); CE_DEBUG on, setting DSP trace mask to *+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_time=3
    @0,807,549us: [+0 T:0x4001ea50] CE - Engine_setTrace> Enter(engine=0x5b4b0, mask='*+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_time=3')
    @0,807,664us: [+1 T:0x4001ea50] CE - Engine_setTrace> Requesting DSP set trace ...
    @0,809,133us: [+0 T:0x4001ea50] CE - Engine_setTrace> return(0)
    [DSP] @0x0000043d:[T:0x00000000] server - main> Welcome to DSP server's main().
    [DSP] @0,020,922tk: [+0 T:0x8faee8ac] OG - Global_setSpecialTrace> enter(mask='*+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_time=3')
    [DSP] @0,021,015tk: [+4 T:0x8faee8ac] OG - Global_setSpecialTrace> This program was built with the following packages:
    [DSP] @0,021,069tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.h2641080p60vdec (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/) [1, 0, 0]
    [DSP] @0,021,151tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.h264dec (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264dec/) [1, 0, 0]
    [DSP] @0,021,227tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.h264enc (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264enc/) [1, 0, 0]
    [DSP] @0,021,304tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.h264fhdvenc (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/) [1, 0, 0]
    [DSP] @0,021,382tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.mpeg2dec (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg2dec/) [1, 0, 0]
    [DSP] @0,021,459tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.mpeg4dec (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4dec/) [1, 0, 0]
    [DSP] @0,021,535tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.mpeg4enc (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4enc/) [1, 0, 0]
    [DSP] @0,021,612tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.hdvicp (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/hdvicp/) [1, 0, 0]
    [DSP] @0,021,687tk: [+4 T:0x8faee8ac] OG -     package ti.xdais (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdais_6_25_02_11/packages/ti/xdais/) [1, 2.0, 1]
    [DSP] @0,021,753tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.global (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/global/) [1, 0, 0]
    [DSP] @0,021,829tk: [+4 T:0x8faee8ac] OG -     package ti.rtdx (/home/bbergan/dvsdk/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/rtdx/) [2, 0, 0, 5]
    [DSP] @0,021,894tk: [+4 T:0x8faee8ac] OG -     package ti.psl (/home/bbergan/dvsdk/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/psl/) [5, 0, 0, 0]
    [DSP] @0,021,958tk: [+4 T:0x8faee8ac] OG -     package ti.pmi (/home/bbergan/dvsdk/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/pmi/) [1, 0, 0, 0]
    [DSP] @0,022,022tk: [+4 T:0x8faee8ac] OG -     package ti.pscl (/home/bbergan/dvsdk/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/pscl/) [1, 0, 0, 0]
    [DSP] @0,022,087tk: [+4 T:0x8faee8ac] OG -     package ti.bios (/home/bbergan/dvsdk/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/bios/) [5, 2, 5, 19]
    [DSP] @0,022,152tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.ires (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/ires/) [1, 0, 0]
    [DSP] @0,022,226tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.ires.hdvicp (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/ires/hdvicp/) [1, 0, 1]
    [DSP] @0,022,306tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.hdintc (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/hdintc/) [1, 0, 4]
    [DSP] @0,022,383tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.edma3.rm (/home/bbergan/dvsdk/dvsdk_3_10_00_19/edma3_lld_01_11_00_03/packages/ti/sdo/edma3/rm/) [01, 03, 07]
    [DSP] @0,022,456tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.ires.nullresource (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/ires/nullresource/) [1, 0, 0]
    [DSP] @0,022,541tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.utils.trace (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/utils/trace/) [1, 0, 0]
    [DSP] @0,022,618tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.dskt2 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/dskt2/) [1, 0, 4]
    [DSP] @0,022,695tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.rman (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/rman/) [2, 0, 0]
    [DSP] @0,022,769tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.edma3 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/edma3/) [3, 0, 0]
    [DSP] @0,022,845tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.ires.edma3chan (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/ires/edma3chan/) [1, 0, 0]
    [DSP] @0,022,927tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.global (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/global/) [1, 0, 0]
    [DSP] @0,023,001tk: [+4 T:0x8faee8ac] OG -     package ti.xdais.dm (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdais_6_25_02_11/packages/ti/xdais/dm/) [1, 0, 5]
    [DSP] @0,023,068tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.node (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/node/) [1, 0, 0]
    [DSP] @0,023,139tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.ipc.dsplink.dsp (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/ipc/dsplink/dsp/) [2, 0, 1]
    [DSP] @0,023,219tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.utils.xdm (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/utils/xdm/) [1, 0, 2]
    [DSP] @0,023,295tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.dman3 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/dman3/) [1, 0, 4]
    [DSP] @0,023,370tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.memutils (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/memutils/) [1, 0, 0]
    [DSP] @0,023,448tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.acpy3 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/acpy3/) [1, 0, 4]
    [DSP] @0,023,523tk: [+4 T:0x8faee8ac] OG -     package dsplink.dsp (/home/bbergan/dvsdk/dvsdk_3_10_00_19/dsplink_linux_1_64/dsplink/dsp/) [1, 4, 0]
    [DSP] @0,023,589tk: [+4 T:0x8faee8ac] OG -     package ti.bios.utils (/home/bbergan/dvsdk/dvsdk_3_10_00_19/biosutils_1_02_02/packages/ti/bios/utils/) [2, 0, 2, 02]
    [DSP] @0,023,659tk: [+4 T:0x8faee8ac] OG -     package ti.catalog.c6000 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/catalog/c6000/) [1, 0, 0, 0]
    [DSP] @0,023,732tk: [+4 T:0x8faee8ac] OG -     package ti.catalog (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/catalog/) [1, 0, 0]
    [DSP] @0,023,800tk: [+4 T:0x8faee8ac] OG -     package ti.platforms.evmDM6467 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/platforms/evmDM6467/) [1, 0, 0, 0]
    [DSP] @0,023,877tk: [+4 T:0x8faee8ac] OG -     package ti.targets.rts6000 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/targets/rts6000/) [1, 0, 0, 0]
    [DSP] @0,023,951tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.osal (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/osal/) [2, 0, 2]
    [DSP] @0,024,023tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.osal.bios (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/osal/bios/) [2, 0, 1]
    [DSP] @0,024,098tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.ipc (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/ipc/) [2, 0, 1]
    [DSP] @0,024,169tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.ipc.bios (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/ipc/bios/) [2, 0, 1]
    [DSP] @0,024,243tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.alg (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/alg/) [1, 0, 1]
    [DSP] @0,024,315tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/) [1, 0, 6]
    [DSP] @0,024,383tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.bioslog (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/bioslog/) [1, 0, 1]
    [DSP] @0,024,458tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.universal (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/universal/) [1, 0, 0]
    [DSP] @0,024,533tk: [+4 T:0x8faee8ac] OG -     package adsys.insight (/home/bbergan/projects/Insight/cetest/adsys/insight/) [1, 0, 0]
    [DSP] @0,024,593tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.video2 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/video2/) [1, 0, 2]
    [DSP] @0,024,666tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.h2641080p60vdec.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/ce/) [1, 0, 0]
    [DSP] @0,024,750tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.h264dec.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264dec/ce/) [1, 0, 0]
    [DSP] @0,024,829tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.video1 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/video1/) [1, 0, 2]
    [DSP] @0,024,902tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.h264enc.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264enc/ce/) [1, 0, 0]
    [DSP] @0,024,980tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.h264fhdvenc.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/ce/) [1, 0, 0]
    [DSP] @0,025,061tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.mpeg2dec.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg2dec/ce/) [1, 0, 0]
    [DSP] @0,025,140tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.mpeg4dec.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4dec/ce/) [1, 0, 0]
    [DSP] @0,025,218tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.mpeg4enc.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4enc/ce/) [1, 0, 0]
    [DSP] @0,025,297tk: [+4 T:0x8faee8ac] OG -     package adsys.insight.servers.ias (/home/bbergan/projects/Insight/cstest2/adsys/insight/servers/ias/) [1, 0, 0]
    [DSP] @0,025,366tk: [+0 T:0x8faee8ac] OG - Global_setSpecialTrace> return
    @0,819,386us: [+0 T:0x4001ea50] CE - Engine_fwriteTrace> returning count [10522]
    @0,819,488us: [+0 T:0x4001ea50] CE - Engine_open> return(373936)
    @0,819,594us: [+0 T:0x4001ea50] ti.sdo.ce.universal.UNIVERSAL - UNIVERSAL_create> Enter (engine=0x5b4b0, name='insight', params=0x0 (size=0x0))
    @0,819,709us: [+0 T:0x4001ea50] CV - VISA_create(0x5b4b0, 'insight', 0x0, 0x648, 'ti.sdo.ce.universal.IUNIVERSAL')
    @0,819,811us: [+0 T:0x4001ea50] CV - VISA_create2(0x5b4b0, 'insight', 0x0, 0x0, 0x648, 'ti.sdo.ce.universal.IUNIVERSAL')
    @0,819,963us: [+0 T:0x4001ea50] CE - Engine_createNode(0x5b4b0, 'insight', 648, 0x0, 0x0, 0xbe910880)
    @0,820,074us: [+0 T:0x4001ea50] CE - Engine> allocNode Enter(engine=0x5b4b0, impId='insight')
    @0,820,243us: [+0 T:0x4001ea50] CE - Engine> allocNode(). Calling (Comm_create(gppfromnode_2348_1, 0x5b828, NULL)
    @0,822,515us: [+4 T:0x4001ea50] CE - Engine_createNode> created node(stdIn=0x2, stdOut=0x10001, msgq=0x5b848, algName='insight', rmsNode=0x8faff380, algHandle=0x8faff468)
    [DSP] @0,074,448tk: [+0 T:0x8faee8ac] OM - Memory_alloc> Enter(size=0x18)
    [DSP] @0,074,500tk: [+0 T:0x8faee8ac] OM - Memory_alloc> return (0x8faff380)
    [DSP] @0,074,547tk: [+0 T:0x8faee8ac] OM - Memory_alloc> Enter(size=0xa)
    [DSP] @0,074,584tk: [+0 T:0x8faee8ac] OM - Memory_alloc> return (0x8faff398)
    [DSP] @0,074,637tk: [+0 T:0x8faee8ac] OM - Memory_alloc> Enter(size=0x20)
    [DSP] @0,074,680tk: [+0 T:0x8faee8ac] OM - Memory_alloc> return (0x8faff3a8)
    [DSP] @0,074,725tk: [+0 T:0x8faee8ac] OM - Memory_alloc> Enter(size=0x24)
    [DSP] @0,074,764tk: [+0 T:0x8faee8ac] OM - Memory_alloc> return (0x8faff3c8)
    [DSP] @0,074,832tk: [+0 T:0x8faee8ac] ti.sdo.ce.universal.UNIVERSAL - UNIVERSAL_create> Enter (engine=0x0, name='insight', params=0x0 (size=0x0))
    [DSP] @0,074,913tk: [+0 T:0x8faee8ac] CV - VISA_create(0x0, 'insight', 0x0, 0x648, 'ti.sdo.ce.universal.IUNIVERSAL')
    [DSP] @0,074,981tk: [+0 T:0x8faee8ac] CV - VISA_create2(0x0, 'insight', 0x0, 0x0, 0x648, 'ti.sdo.ce.universal.IUNIVERSAL')
    [DSP] @0,075,058tk: [+0 T:0x8faee8ac] CE - Engine_open> Enter('local', 0x8fafe584, 0x0)
    [DSP] @0,075,110tk: [+0 T:0x8faee8ac] OM - Memory_alloc> Enter(size=0x2c)
    [DSP] @0,075,148tk: [+0 T:0x8faee8ac] OM - Memory_alloc> return (0x8faff438)
    [DSP] @0,075,205tk: [+0 T:0x8faee8ac] CE - Engine_open> return(-1884294088)
    [DSP] @0,075,273tk: [+0 T:0x8faee8ac] OM - Memory_alloc> Enter(size=0x34)
    [DSP] @0,075,312tk: [+0 T:0x8faee8ac] OM - Memory_alloc> return (0x8faff468)
    [DSP] @0,075,358tk: [+0 T:0x8faee8ac] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0x8faaac84, idma3Fxns=0x0, iresFxns=0x0, params=0x0, attrs=0x8fafe6a0)
    [DSP] @0,075,437tk: [+0 T:0x8faee8ac] OM - Memory_alloc> Enter(size=0x10)
    [DSP] @0,075,476tk: [+0 T:0x8faee8ac] OM - Memory_alloc> return (0x8faff4a0)
    [DSP] @0,075,593tk: [+4 T:0x8faee8ac] INSIGHT - INSIGHT_ADSYS_alloc
    [DSP] @0,075,670tk: [+4 T:0x8faee8ac] INSIGHT - INSIGHT_ADSYS_initObj
    [DSP] @0,075,710tk: [+4 T:0x8faee8ac] INSIGHT -     Tracker Initialized
    [DSP] @0,075,770tk: [+4 T:0x8faee8ac] Insight_Alg - Tracker_Initialize
    [DSP] @0,075,820tk: [+0 T:0x8faee8ac] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x8faff4a0)
    [DSP] @0,075,880tk: [+5 T:0x8faee8ac] CV - VISA_create> local codec created (name='insight', handle=0x8faff4a0)
    [DSP] @0,075,940tk: [+0 T:0x8faee8ac] ti.sdo.ce.universal.UNIVERSAL - UNIVERSAL_create> return (0x8faff468)
    [DSP] @0,076,000tk: [+4 T:0x8faee8ac] OT - Thread_create > name: "insight#0", pri:  -1, stack size:  37024, stack seg: 0
    @0,825,465us: [+0 T:0x4001ea50] CE - Engine_fwriteTrace> returning count [2494]
    @0,825,604us: [+2 T:0x4001ea50] CE - Engine_createNode> Returning 0x5b820
    @0,825,711us: [+5 T:0x4001ea50] CV - VISA_create> remote codec created (name='insight', localQueueID=0x10001, remoteQueueID=0x0002)
    @0,825,815us: [+0 T:0x4001ea50] ti.sdo.ce.universal.UNIVERSAL - UNIVERSAL_create> return (0x5b7d8)
    Capture GFX Buffer Dimensions: x=0, y=0, width=1280, height=720, lineLength=1280
    Capture Buffer Size: 1843200
    cAttrs.numBufs 			= 3
    cAttrs.videoInput 		= 2
    cAttrs.cropWidth 		= -1
    cAttrs.cropHeight 		= -1
    cAttrs.cropX 			= -1
    cAttrs.cropY 			= -1
    cAttrs.captureDevice 	= /dev/video0
    cAttrs.decoderIdx 		= -1
    cAttrs.colorSpace 		= 1
    cAttrs.captureDimension = 0
    @0,826,695us: [+2 T:0x4001ea50] ti.sdo.dmai - [BufTab] Allocating BufTab for 3 buffers
    @0,827,035us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(1843200) = 0x41381000.
    @0,827,173us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x41381000) = 0x885df000.
    @0,827,288us: [+2 T:0x4001ea50] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1843200 at 0x41381000 (0x885df000 phys)
    @0,827,548us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(1843200) = 0x41543000.
    @0,827,684us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x41543000) = 0x8841d000.
    @0,827,844us: [+2 T:0x4001ea50] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1843200 at 0x41543000 (0x8841d000 phys)
    @0,828,108us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(1843200) = 0x41705000.
    @0,828,246us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x41705000) = 0x8825b000.
    @0,828,362us: [+2 T:0x4001ea50] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1843200 at 0x41705000 (0x8825b000 phys)
    @0,828,627us: [+2 T:0x4001ea50] ti.sdo.dmai - [Capture] Component input selected
    @0,835,640us: [+2 T:0x4001ea50] ti.sdo.dmai - [Capture] Capture input set to Component:9
    @0,835,822us: [+2 T:0x4001ea50] ti.sdo.dmai - [Capture] Video input connected size 1280x720 pitch 1280
    dAttrs.videoStd = 5
    dAttrs.videoOutput = 1
    dAttrs.colorSpace = 1
    Display GFX Buffer Dimensions: x=0, y=0, width=720, height=480, lineLength=720
    @0,864,003us: [+2 T:0x4001ea50] ti.sdo.dmai - [BufTab] Allocating BufTab for 3 buffers
    @0,864,220us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(691200) = 0x418c7000.
    @0,864,356us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x418c7000) = 0x8ed1f000.
    @0,864,472us: [+2 T:0x4001ea50] ti.sdo.dmai - [Buffer] Alloc Buffer of size 691200 at 0x418c7000 (0x8ed1f000 phys)
    @0,864,704us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(691200) = 0x419a8000.
    @0,864,840us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x419a8000) = 0x8ec3e000.
    @0,864,957us: [+2 T:0x4001ea50] ti.sdo.dmai - [Buffer] Alloc Buffer of size 691200 at 0x419a8000 (0x8ec3e000 phys)
    @0,865,177us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(691200) = 0x41a89000.
    @0,865,314us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x41a89000) = 0x8eacd000.
    @0,865,431us: [+2 T:0x4001ea50] ti.sdo.dmai - [Buffer] Alloc Buffer of size 691200 at 0x41a89000 (0x8eacd000 phys)
    @0,865,681us: [+2 T:0x4001ea50] ti.sdo.dmai - [Display] Output detected Composite
    @0,894,703us: [+2 T:0x4001ea50] ti.sdo.dmai - [Display] Display Output set to Composite; Display Standard is set to 5
    @0,894,902us: [+2 T:0x4001ea50] ti.sdo.dmai - [Display] Video output set to size 720x480 pitch 720 imageSize 691200
    hDisplay: 376120
    [0] @ 0x41381000 (0x885df000 phys) numBytes 921600 (1843200) useMask 1 (1) ref no vSize 0
    	Width 1280, Height 720, LineLength 1280
    [0] @ 0x418c7000 (0x8ed1f000 phys) numBytes 691200 (691200) useMask 1 (1) ref no vSize 0
    	Width 720, Height 480, LineLength 720
    cBufSize=1843200
    dBufSize=691200
    @0,980,251us: [+2 T:0x4001ea50] ti.sdo.dmai - [Resize] Configuring resize from 1280x720 (pitch 1280) to 720x480 (pitch 720)
    Resizer Configured properly... 0
    @0,980,600us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(12000) = 0x41b89000.
    @0,980,742us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x41b89000) = 0x8ea62000.
    @0,980,940us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(12000) = 0x41b9f000.
    @0,981,081us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x41b9f000) = 0x8ea4c000.
    bufIn : virt addr: 0x41b89000, phys addr: 0x8ea62000
    bufOut: virt addr: 0x41b9f000, phys addr: 0x8ea4c000
    @0,981,448us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(76) = 0x41bb5000.
    @0,981,588us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x41bb5000) = 0x8ea78000.
    @0,981,797us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(204) = 0x41c0a000.
    @0,981,938us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x41c0a000) = 0x8ebcd000.
    Setting User Target
    @0,982,187us: [+0 T:0x4001ea50] ti.sdo.ce.universal.UNIVERSAL - UNIVERSAL_control> Enter (handle=0x5b7d8, id=258, dynParams=0x41bb5000 (size=0x4c), status=0x41c0a000 (size=0xcc)
    @0,982,342us: [+4 T:0x4001ea50] CV - VISA_getMaxMsgSize(0x5b7d8): returning 0x1000
    @0,982,446us: [+5 T:0x4001ea50] CV - VISA_allocMsg> Allocating message for messageId=0x000201f4
    @0,982,550us: [+0 T:0x4001ea50] CV - VISA_call(visa=0x5b7d8, msg=0x41311880): messageId=0x000201f4, command=0x1
    [DSP] @0,697,240tk: [+5 T:0x8faff8cc] CN - NODE> 0x8faff3a8(insight#0) call(algHandle=0x8faff468, msg=0x8fe04880); messageId=0x000201f4
    [DSP] @0,697,339tk: [+0 T:0x8faff8cc] OM - Memory_cacheInv> Enter(addr=0x8ea4c000, sizeInBytes=12000)
    [DSP] @0,697,405tk: [+0 T:0x8faff8cc] OM - Memory_cacheInv> return
    [DSP] @0,697,444tk: [+0 T:0x8faff8cc] ti.sdo.ce.universal.UNIVERSAL - UNIVERSAL_control> Enter (handle=0x8faff468, id=258, dynParams=0x8fe048b4 (size=0x4c), status=0x8fe04900 (size=0xcc)
    [DSP] @0,697,544tk: [+5 T:0x8faff8cc] CV - VISA_enter(visa=0x8faff468): algHandle = 0x8faff4a0
    [DSP] @0,697,602tk: [+0 T:0x8faff8cc] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x8faff4a0)
    [DSP] @0,697,663tk: [+0 T:0x8faff8cc] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Exit
    [DSP] @0,697,714tk: [+4 T:0x8faff8cc] INSIGHT - INSIGHT_ADSYS_control
    [DSP] @0,697,758tk: [+5 T:0x8faff8cc] CV - VISA_exit(visa=0x8faff468): algHandle = 0x8faff4a0
    [DSP] @0,697,811tk: [+0 T:0x8faff8cc] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x8faff4a0)
    [DSP] @0,697,868tk: [+0 T:0x8faff8cc] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Exit
    [DSP] @0,697,914tk: [+0 T:0x8faff8cc] ti.sdo.ce.universal.UNIVERSAL - UNIVERSAL_control> Exit (handle=0x8faff468, retVal=0x0)
    [DSP] @0,697,977tk: [+5 T:0x8faff8cc] CN - NODE> returned from call(algHandle=0x8faff468, msg=0x8fe04880); messageId=0x000201f4
    @0,984,762us: [+0 T:0x4001ea50] CE - Engine_fwriteTrace> returning count [1399]
    @0,984,867us: [+0 T:0x4001ea50] CV - VISA_call Completed: messageId=0x000201f4, command=0x1, return(status=0)
    @0,984,978us: [+5 T:0x4001ea50] CV - VISA_freeMsg(0x5b7d8, 0x41311880): Freeing message with messageId=0x000201f4
    @0,985,079us: [+0 T:0x4001ea50] ti.sdo.ce.universal.UNIVERSAL - UNIVERSAL_control> Exit (handle=0x5b7d8, retVal=0x0)
    @6,572,935us: [+0 T:0x4001ea50] OP - doCmd> Enter (cmdId=3, proc=0x0)
    @6,573,066us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x5b1c0]
    @6,573,193us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x5b1c0]
    @6,573,292us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5b1d8] timeout[0xffffffff]
    @6,573,424us: [+0 T:0x40b03490] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x5b1c0] status[0]
    @6,573,533us: [+0 T:0x40b03490] OP - getCmd_d> Exit (result=3)
    @6,573,631us: [+0 T:0x40b03490] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x5b1d8]
    @6,573,749us: [+0 T:0x40b03490] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x5b1d8]
    @6,574,056us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x5b1d8] status[0]
    @6,574,184us: [+0 T:0x4001ea50] OP - doCmd> Exit (result=1)
    @6,574,279us: [+0 T:0x4001ea50] OT - Thread_delete> Enter (task=0x5b210)
    @6,574,419us: [+4 T:0x4001ea50] OT - Thread_delete> pthread_cancel (0x3)
    @6,574,553us: [+4 T:0x4001ea50] OT - Thread_delete> pthread_join (0x0)
    @6,574,660us: [+0 T:0x4001ea50] OT - Thread_delete> Exit (task=0x5b210)
    @6,574,755us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x5b1c0]
    @6,574,877us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
    @6,574,976us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x5b1d8]
    @6,575,071us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
    Custom Board CE_DEBUG:
    @0,225,915us: [+4 T:0x4001ea50] OG - Global_init> This program was built with the following packages:
    @0,227,565us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.h2641080p60vdec (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/) [1, 0, 0]
    @0,227,983us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.h264dec (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264dec/) [1, 0, 0]
    @0,228,252us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.h264enc (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264enc/) [1, 0, 0]
    @0,228,505us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.h264fhdvenc (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/) [1, 0, 0]
    @0,228,748us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.mpeg2dec (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg2dec/) [1, 0, 0]
    @0,228,990us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.mpeg4dec (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4dec/) [1, 0, 0]
    @0,229,232us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.mpeg4enc (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4enc/) [1, 0, 0]
    @0,229,467us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.global (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/global/) [1, 0, 0]
    @0,229,704us: [+4 T:0x4001ea50] OG -     package ti.xdais.dm (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdais_6_25_02_11/packages/ti/xdais/dm/) [1, 0, 5]
    @0,229,941us: [+4 T:0x4001ea50] OG -     package ti.sdo.utils.trace (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/utils/trace/) [1, 0, 0]
    @0,230,180us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.utils.xdm (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/utils/xdm/) [1, 0, 2]
    @0,230,419us: [+4 T:0x4001ea50] OG -     package dsplink.gpp (/home/bbergan/dvsdk/dvsdk_3_10_00_19/dsplink_linux_1_64/dsplink/gpp/) [5, 0, 0]
    @0,230,875us: [+4 T:0x4001ea50] OG -     package ti.sdo.linuxutils.cmem (/home/bbergan/dvsdk/dvsdk_3_10_00_19/linuxutils_2_25_04_10/packages/ti/sdo/linuxutils/cmem/) [2, 2, 0]
    @0,231,159us: [+4 T:0x4001ea50] OG -     package ti.xdais (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdais_6_25_02_11/packages/ti/xdais/) [1, 2.0, 1]
    @0,231,406us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.node (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/node/) [1, 0, 0]
    @0,231,654us: [+4 T:0x4001ea50] OG -     package ti.sdo.fc.global (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/global/) [1, 0, 0]
    @0,231,889us: [+4 T:0x4001ea50] OG -     package ti.sdo.fc.memutils (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/memutils/) [1, 0, 0]
    @0,232,128us: [+4 T:0x4001ea50] OG -     package ti.sdo.fc.utils (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/utils/) [1, 0, 2]
    @0,232,369us: [+4 T:0x4001ea50] OG -     package ti.sdo.fc.dman3 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/dman3/) [1, 0, 4]
    @0,232,601us: [+4 T:0x4001ea50] OG -     package ti.sdo.fc.acpy3 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/acpy3/) [1, 0, 4]
    @0,232,834us: [+4 T:0x4001ea50] OG -     package gnu.targets (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/gnu/targets/) [1, 0, 1]
    @0,233,065us: [+4 T:0x4001ea50] OG -     package gnu.targets.arm (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/gnu/targets/arm/) [1, 0, 0, 0]
    @0,233,515us: [+4 T:0x4001ea50] OG -     package ti.catalog.arm (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/catalog/arm/) [1, 0, 1, 0]
    @0,233,762us: [+4 T:0x4001ea50] OG -     package ti.catalog (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/catalog/) [1, 0, 0]
    @0,234,255us: [+4 T:0x4001ea50] OG -     package ti.catalog.c6000 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/catalog/c6000/) [1, 0, 0, 0]
    @0,234,534us: [+4 T:0x4001ea50] OG -     package ti.platforms.evmDM6467T (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/platforms/evmDM6467T/) [1, 0, 0, 0]
    @0,234,784us: [+4 T:0x4001ea50] OG -     package gnu.targets.arm.rtsv5T (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/gnu/targets/arm/rtsv5T/) [1, 0, 0, 0]
    @0,235,024us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.osal (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/osal/) [2, 0, 2]
    @0,235,267us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.ipc (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/ipc/) [2, 0, 1]
    @0,235,501us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.osal.linux (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/osal/linux/) [2, 0, 1]
    @0,235,742us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.ipc.dsplink (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/ipc/dsplink/) [2, 0, 1]
    @0,235,984us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.alg (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/alg/) [1, 0, 1]
    @0,236,215us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/) [1, 0, 6]
    @0,236,463us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.universal (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/universal/) [1, 0, 0]
    @0,236,698us: [+4 T:0x4001ea50] OG -     package adsys.insight (/home/bbergan/projects/Insight/cetest/adsys/insight/) [1, 0, 0]
    @0,236,929us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.video2 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/video2/) [1, 0, 2]
    @0,237,171us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.h2641080p60vdec.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/ce/) [1, 0, 0]
    @0,237,412us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.h264dec.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264dec/ce/) [1, 0, 0]
    @0,237,652us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.video1 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/video1/) [1, 0, 2]
    @0,237,894us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.h264enc.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264enc/ce/) [1, 0, 0]
    @0,238,133us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.h264fhdvenc.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/ce/) [1, 0, 0]
    @0,238,370us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.mpeg2dec.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg2dec/ce/) [1, 0, 0]
    @0,238,615us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.mpeg4dec.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4dec/ce/) [1, 0, 0]
    @0,238,857us: [+4 T:0x4001ea50] OG -     package ti.sdo.codecs.mpeg4enc.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4enc/ce/) [1, 0, 0]
    @0,239,096us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.speech (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/speech/) [1, 0, 2]
    @0,239,347us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.speech1 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/speech1/) [1, 0, 1]
    @0,239,583us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.audio (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/audio/) [1, 0, 2]
    @0,239,822us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.audio1 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/audio1/) [1, 0, 1]
    @0,240,199us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.video (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/video/) [1, 0, 3]
    @0,240,464us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.image (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/image/) [1, 0, 3]
    @0,240,920us: [+4 T:0x4001ea50] OG -     package ti.sdo.ce.image1 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/image1/) [1, 0, 1]
    @0,241,194us: [+4 T:0x4001ea50] OG -     package ti.sdo.dmai (/home/bbergan/dvsdk/dvsdk_3_10_00_19/dmai_2_10_00_12/packages/ti/sdo/dmai/) [1, 0, 0]
    @0,241,445us: [+4 T:0x4001ea50] OG -     package ipm (/home/bbergan/projects/Insight/ipm_v0.0.5/ipm/) []
    @0,242,837us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @0,243,274us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x5b1c0]
    @0,243,566us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @0,243,827us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x5b1d8]
    @0,244,097us: [+0 T:0x4001ea50] OT - Thread_create> Enter (fxn=0x24174, attrs=0x0)
    @0,245,608us: [+0 T:0x4001ea50] OT - Thread_create> Exit (task=0x5b210)
    @0,246,267us: [+0 T:0x4001ea50] ti.sdo.ce.alg - ALG_init> Enter
    @0,246,570us: [+0 T:0x4001ea50] ti.sdo.ce.alg - ALG_init> Exit
    @0,247,062us: [+6 T:0x4001ea50] CE - Engine_init> CE debugging on (CE_DEBUG=2; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
    @0,247,573us: [+0 T:0x4001ea50] CS - Server_init()
    @0,247,851us: [+0 T:0x4001ea50] CS - Server_init> Global_useLinkArbiter = 0
    @0,248,267us: [+0 T:0x4001ea50] CE - Engine_open> Enter('InSightEngine', 0x0, 0xbed56b30)
    @0,248,593us: [+0 T:0x4001ea50] CE - rserverOpen('ias.x64P'), count = 0
    @0,248,950us: [+0 T:0x4001ea50] OP - Processor_create> Enter(imageName='ias.x64P', linkCfg='(null)', attrs=0xbed568e8)
    @0,249,776us: [+0 T:0x4001ea50] OP - doCmd> Enter (cmdId=1, proc=0x5b4e0)
    @0,250,112us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x5b1c0]
    @0,250,580us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x5b1c0]
    @0,251,613us: [+1 T:0x40b03490] OP - daemon> thread created.
    @0,251,923us: [+0 T:0x40b03490] OP - getCmd_d> Enter (proc=0x40b02dd8)
    @0,252,190us: [+0 T:0x40b03490] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5b1c0] timeout[0xffffffff]
    @0,252,546us: [+0 T:0x40b03490] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x5b1c0] status[0]
    @0,252,837us: [+0 T:0x40b03490] OP - getCmd_d> Exit (result=1)
    @0,253,105us: [+0 T:0x40b03490] OP - Processor_create_d> Enter(proc=0x5b4e0)
    @0,253,357us: [+2 T:0x40b03490] OP - Processor_create_d> Initializing DSP PROC...
    @0,253,623us: [+2 T:0x40b03490] OP - Processor_create_d> Using DspLink config data for entry #0 [server 'ias.x64P']
    @0,254,040us: [+2 T:0x40b03490] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0x8fa00000, sizeInBytes=0x400000, shared=1, syncd=0
    @0,254,382us: [+2 T:0x40b03490] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x8fe00000, sizeInBytes=0x100000, shared=1, syncd=0
    @0,254,680us: [+2 T:0x40b03490] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESET_VECTOR', startAddress=0x8ff00000, sizeInBytes=0x80, shared=1, syncd=0
    @0,254,975us: [+2 T:0x40b03490] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='DDRALGHEAP', startAddress=0x88000000, sizeInBytes=0x7a00000, shared=0, syncd=0
    @0,255,263us: [+2 T:0x40b03490] OP - Processor_create_d> DODSPCTRL was=1; now=0
    @0,255,626us: [+3 T:0x40b03490] OP - LINKCFG_Object generated for PROC_setup(0x596bc) ...
    @0,255,921us: [+3 T:0x40b03490] OP - linkCfg->gppObject->
    @0,256,176us: [+3 T:0x40b03490] OP -   name = "ARM9"
    @0,256,416us: [+3 T:0x40b03490] OP -   maxMsgqs = 0x82
    @0,256,662us: [+3 T:0x40b03490] OP -   maxChnlQueue = 0x10
    @0,256,906us: [+3 T:0x40b03490] OP -   poolTableId = 0xffffffff
    @0,257,150us: [+3 T:0x40b03490] OP -   numPools = 0x0
    @0,257,389us: [+3 T:0x40b03490] OP -
    @0,257,766us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->dspObject->
    @0,258,035us: [+3 T:0x40b03490] OP -   name = "DM6467GEM"
    @0,258,290us: [+3 T:0x40b03490] OP -   dspArch = 0x2
    @0,258,530us: [+3 T:0x40b03490] OP -   loaderName = "COFF"
    @0,258,772us: [+3 T:0x40b03490] OP -   autoStart = FALSE
    @0,259,011us: [+3 T:0x40b03490] OP -   execName = "DEFAULT.OUT"
    @0,259,269us: [+3 T:0x40b03490] OP -   doDspCtrl = DSP_BootMode_Boot_NoPwr
    @0,259,515us: [+3 T:0x40b03490] OP -   resumeAddr = 0x8ff00020
    @0,259,762us: [+3 T:0x40b03490] OP -   resetVector = 0x8ff00000
    @0,260,005us: [+3 T:0x40b03490] OP -   resetCodeSize = 0x80
    @0,260,253us: [+3 T:0x40b03490] OP -   maduSize = 0x1
    @0,260,497us: [+3 T:0x40b03490] OP -   cpuFreq = 0x91050
    @0,261,240us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5b1d8] timeout[0xffffffff]
    @0,261,662us: [+3 T:0x40b03490] OP -   endian = 0x3
    @0,261,961us: [+3 T:0x40b03490] OP -   wordSwap = 0x0
    @0,262,224us: [+3 T:0x40b03490] OP -   memTableId = 0x0
    @0,262,478us: [+3 T:0x40b03490] OP -   memEntries = 0x4
    @0,262,719us: [+3 T:0x40b03490] OP -   linkDrvId = 0x0
    @0,262,959us: [+3 T:0x40b03490] OP -   arg1 = 0xffffffff
    @0,263,200us: [+3 T:0x40b03490] OP -   arg2 = 0xffffffff
    @0,263,446us: [+3 T:0x40b03490] OP -   arg3 = 0x0
    @0,263,692us: [+3 T:0x40b03490] OP -   arg4 = 0x0
    @0,263,935us: [+3 T:0x40b03490] OP -   arg5 = 0xffffffff
    @0,264,176us: [+3 T:0x40b03490] OP -
    @0,264,417us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->linkDrvObjects->
    @0,264,665us: [+3 T:0x40b03490] OP -   name = "SHMDRV"
    @0,264,906us: [+3 T:0x40b03490] OP -   hshkPollCount = 0x5f5e100
    @0,265,152us: [+3 T:0x40b03490] OP -   memEntry = 0x1
    @0,265,397us: [+3 T:0x40b03490] OP -   ipsTableId = 0x0
    @0,265,636us: [+3 T:0x40b03490] OP -   numIpsEntries = 0x1
    @0,265,880us: [+3 T:0x40b03490] OP -   poolTableId = 0x0
    @0,266,120us: [+3 T:0x40b03490] OP -   numPools = 0x1
    @0,266,364us: [+3 T:0x40b03490] OP -   dataTableId = 0x0
    @0,266,612us: [+3 T:0x40b03490] OP -   numDataDrivers = 0x1
    @0,266,854us: [+3 T:0x40b03490] OP -   mqtId = 0x0
    @0,267,096us: [+3 T:0x40b03490] OP -   ringIoTableId = 0x0
    @0,267,343us: [+3 T:0x40b03490] OP -   mplistTableId = 0x0
    @0,267,584us: [+3 T:0x40b03490] OP -   mpcsTableId = 0x0
    @0,267,823us: [+3 T:0x40b03490] OP -
    @0,268,060us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->memTables[0][i].
    @0,268,540us: [+3 T:0x40b03490] OP - entry #0:
    @0,268,845us: [+3 T:0x40b03490] OP -   entry = 0x0
    @0,269,099us: [+3 T:0x40b03490] OP -   name = "DDR2"
    @0,269,362us: [+3 T:0x40b03490] OP -   physAddr = 0x8fa00000
    @0,269,612us: [+3 T:0x40b03490] OP -   dspVirtAddr = 0x8fa00000
    @0,269,855us: [+3 T:0x40b03490] OP -   gppVirtAddr = 0xffffffff
    @0,270,092us: [+3 T:0x40b03490] OP -   size = 0x400000
    @0,270,343us: [+3 T:0x40b03490] OP -   shared = TRUE
    @0,270,756us: [+3 T:0x40b03490] OP -   syncd = FALSE
    @0,271,054us: [+3 T:0x40b03490] OP - entry #1:
    @0,271,323us: [+3 T:0x40b03490] OP -   entry = 0x1
    @0,271,575us: [+3 T:0x40b03490] OP -   name = "DSPLINKMEM"
    @0,271,823us: [+3 T:0x40b03490] OP -   physAddr = 0x8fe00000
    @0,272,073us: [+3 T:0x40b03490] OP -   dspVirtAddr = 0x8fe00000
    @0,272,323us: [+3 T:0x40b03490] OP -   gppVirtAddr = 0xffffffff
    @0,272,571us: [+3 T:0x40b03490] OP -   size = 0x100000
    @0,272,820us: [+3 T:0x40b03490] OP -   shared = TRUE
    @0,273,056us: [+3 T:0x40b03490] OP -   syncd = FALSE
    @0,273,303us: [+3 T:0x40b03490] OP - entry #2:
    @0,273,541us: [+3 T:0x40b03490] OP -   entry = 0x2
    @0,273,788us: [+3 T:0x40b03490] OP -   name = "RESET_VECTOR"
    @0,274,023us: [+3 T:0x40b03490] OP -   physAddr = 0x8ff00000
    @0,274,277us: [+3 T:0x40b03490] OP -   dspVirtAddr = 0x8ff00000
    @0,274,519us: [+3 T:0x40b03490] OP -   gppVirtAddr = 0xffffffff
    @0,274,762us: [+3 T:0x40b03490] OP -   size = 0x80
    @0,275,000us: [+3 T:0x40b03490] OP -   shared = TRUE
    @0,275,260us: [+3 T:0x40b03490] OP -   syncd = FALSE
    @0,275,500us: [+3 T:0x40b03490] OP - entry #3:
    @0,275,748us: [+3 T:0x40b03490] OP -   entry = 0x3
    @0,275,990us: [+3 T:0x40b03490] OP -   name = "DDRALGHEAP"
    @0,276,243us: [+3 T:0x40b03490] OP -   physAddr = 0x88000000
    @0,276,481us: [+3 T:0x40b03490] OP -   dspVirtAddr = 0x88000000
    @0,276,879us: [+3 T:0x40b03490] OP -   gppVirtAddr = 0xffffffff
    @0,277,151us: [+3 T:0x40b03490] OP -   size = 0x7a00000
    @0,277,403us: [+3 T:0x40b03490] OP -   shared = FALSE
    @0,277,654us: [+3 T:0x40b03490] OP -   syncd = FALSE
    @0,277,898us: [+3 T:0x40b03490] OP -
    @0,278,135us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->ipsTables[0][i].
    @0,278,391us: [+3 T:0x40b03490] OP - entry #0:
    @0,278,632us: [+3 T:0x40b03490] OP -   name = "IPS"
    @0,278,878us: [+3 T:0x40b03490] OP -   numIpsEvents = 0x20
    @0,279,132us: [+3 T:0x40b03490] OP -   memEntry = 0x1
    @0,279,370us: [+3 T:0x40b03490] OP -   gppIntId = 0x2d
    @0,279,617us: [+3 T:0x40b03490] OP -   dspIntId = 0x10
    @0,279,859us: [+3 T:0x40b03490] OP -   dspIntVectorId = 0x4
    @0,280,114us: [+3 T:0x40b03490] OP -   arg1 = 0x2faf080
    @0,280,358us: [+3 T:0x40b03490] OP -   arg2 = 0x0
    @0,280,772us: [+3 T:0x40b03490] OP -
    @0,281,066us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->poolTables[0][i].
    @0,281,336us: [+3 T:0x40b03490] OP -
    @0,281,575us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->dataTables[0][i].
    @0,281,825us: [+3 T:0x40b03490] OP - entry #0:
    @0,282,074us: [+3 T:0x40b03490] OP -   name = "ZCPYDATA"
    @0,282,323us: [+3 T:0x40b03490] OP -   baseChnlId = 0x0
    @0,282,571us: [+3 T:0x40b03490] OP -   numChannels = 0x10
    @0,282,821us: [+3 T:0x40b03490] OP -   maxBufSize = 0x4000
    @0,283,061us: [+3 T:0x40b03490] OP -   memEntry = 0x1
    @0,283,314us: [+3 T:0x40b03490] OP -   poolId = 0x0
    @0,283,555us: [+3 T:0x40b03490] OP -   queuePerChnl = 0x1
    @0,283,800us: [+3 T:0x40b03490] OP -   ipsId = 0x0
    @0,284,043us: [+3 T:0x40b03490] OP -   ipsEventNo = 0x2
    @0,284,286us: [+3 T:0x40b03490] OP -   arg1 = 0x0
    @0,284,527us: [+3 T:0x40b03490] OP -   arg2 = 0x0
    @0,284,772us: [+3 T:0x40b03490] OP -
    @0,285,005us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->mqtObjects->
    @0,285,270us: [+3 T:0x40b03490] OP -   name = "ZCPYMQT"
    @0,285,510us: [+3 T:0x40b03490] OP -   memEntry = 0x1
    @0,285,756us: [+3 T:0x40b03490] OP -   maxMsgSize = 0xffffffff
    @0,286,002us: [+3 T:0x40b03490] OP -   ipsId = 0x0
    @0,286,248us: [+3 T:0x40b03490] OP -   ipsEventNo = 0x1
    @0,286,491us: [+3 T:0x40b03490] OP -   arg1 = 0x0
    @0,286,736us: [+3 T:0x40b03490] OP -   arg2 = 0x0
    @0,286,978us: [+3 T:0x40b03490] OP -
    @0,287,211us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->ringIoObjects->
    @0,287,454us: [+3 T:0x40b03490] OP -   name = "RINGIOTABLE"
    @0,287,693us: [+3 T:0x40b03490] OP -   memEntry = 0x1
    @0,287,937us: [+3 T:0x40b03490] OP -   maxEntries = 0x40
    @0,288,179us: [+3 T:0x40b03490] OP -   ipsId = 0x0
    @0,288,421us: [+3 T:0x40b03490] OP -   ipsEventNo = 0x0
    @0,288,660us: [+3 T:0x40b03490] OP -
    @0,288,890us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->mplistObjects->
    @0,289,146us: [+3 T:0x40b03490] OP -   name = "MPLISTTABLE"
    @0,289,390us: [+3 T:0x40b03490] OP -   memEntry = 0x1
    @0,289,634us: [+3 T:0x40b03490] OP -   maxEntries = 0x40
    @0,289,874us: [+3 T:0x40b03490] OP -   ipsId = 0xffffffff
    @0,290,110us: [+3 T:0x40b03490] OP -   ipsEventNo = 0xffffffff
    @0,290,356us: [+3 T:0x40b03490] OP -
    @0,290,581us: [+3 T:0x40b03490] OP - linkCfg->dspConfigs[0]->mpcsObjects->
    @0,291,051us: [+3 T:0x40b03490] OP -   name = "MPCS"
    @0,291,325us: [+3 T:0x40b03490] OP -   memEntry = 0x1
    @0,291,582us: [+3 T:0x40b03490] OP -   maxEntries = 0x100
    @0,291,828us: [+3 T:0x40b03490] OP -   ipsId = 0xffffffff
    @0,292,076us: [+3 T:0x40b03490] OP -   ipsEventNo = 0xffffffff
    @0,299,259us: [+2 T:0x40b03490] OP - Processor_create_d> Attaching to DSP PROC...
    @0,317,969us: [+2 T:0x40b03490] OP - Processor_create_d> Opening MSGQ pool...
    @0,319,416us: [+2 T:0x40b03490] OP - Processor_create_d> Loading ias.x64P on DSP (1 args)...
    @3,297,341us: [+2 T:0x40b03490] OP - Processor_create_d> Starting DSP PROC...
    @3,379,294us: [+2 T:0x40b03490] OP - Processor_create_d> Opening remote transport...
    @3,383,711us: [+2 T:0x40b03490] OP - Processor_create_d> return (1)
    @3,384,080us: [+0 T:0x40b03490] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x5b1d8]
    @3,384,743us: [+0 T:0x4001ea50] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x5b1d8] status[0]
    @3,385,758us: [+0 T:0x4001ea50] OP - doCmd> Exit (result=1)
    @3,386,105us: [+0 T:0x4001ea50] OP - Processor_create> return (0x5b4e0)
    @3,386,390us: [+0 T:0x4001ea50] CE - rserverOpen('ias.x64P'): 0x59e24 done.
    @3,394,108us: [+0 T:0x4001ea50] CE - checkServer(0x5b4b0)
    @3,395,482us: [+0 T:0x4001ea50] CE - rmsInit> RMS initialized(0x5b4b0); CE_DEBUG on, setting DSP trace mask to *+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_time=3
    @3,396,750us: [+0 T:0x4001ea50] CE - Engine_setTrace> Enter(engine=0x5b4b0, mask='*+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_time=3')
    @3,397,364us: [+1 T:0x4001ea50] CE - Engine_setTrace> Requesting DSP set trace ...
    @3,397,940us: [+0 T:0x40b03490] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x5b1d8]
    @3,398,509us: [+0 T:0x40b03490] OP - getCmd_d> Enter (proc=0x40b02dd8)
    @3,398,827us: [+0 T:0x40b03490] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5b1c0] timeout[0xffffffff]
    @3,401,061us: [+0 T:0x4001ea50] CE - Engine_setTrace> return(0)
    [DSP] @0x00000785:[T:0x00000000] server - main> Welcome to DSP server's main().
    [DSP] @0,054,742tk: [+0 T:0x8faee8ac] OG - Global_setSpecialTrace> enter(mask='*+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_time=3')
    [DSP] @0,054,852tk: [+4 T:0x8faee8ac] OG - Global_setSpecialTrace> This program was built with the following packages:
    [DSP] @0,054,911tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.h2641080p60vdec (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/) [1, 0, 0]
    [DSP] @0,054,997tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.h264dec (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264dec/) [1, 0, 0]
    [DSP] @0,055,077tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.h264enc (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264enc/) [1, 0, 0]
    [DSP] @0,055,156tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.h264fhdvenc (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/) [1, 0, 0]
    [DSP] @0,055,238tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.mpeg2dec (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg2dec/) [1, 0, 0]
    [DSP] @0,055,321tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.mpeg4dec (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4dec/) [1, 0, 0]
    [DSP] @0,055,400tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.mpeg4enc (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4enc/) [1, 0, 0]
    [DSP] @0,055,480tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.hdvicp (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/hdvicp/) [1, 0, 0]
    [DSP] @0,055,559tk: [+4 T:0x8faee8ac] OG -     package ti.xdais (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdais_6_25_02_11/packages/ti/xdais/) [1, 2.0, 1]
    [DSP] @0,055,627tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.global (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/global/) [1, 0, 0]
    [DSP] @0,055,707tk: [+4 T:0x8faee8ac] OG -     package ti.rtdx (/home/bbergan/dvsdk/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/rtdx/) [2, 0, 0, 5]
    [DSP] @0,055,776tk: [+4 T:0x8faee8ac] OG -     package ti.psl (/home/bbergan/dvsdk/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/psl/) [5, 0, 0, 0]
    [DSP] @0,055,845tk: [+4 T:0x8faee8ac] OG -     package ti.pmi (/home/bbergan/dvsdk/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/pmi/) [1, 0, 0, 0]
    [DSP] @0,055,911tk: [+4 T:0x8faee8ac] OG -     package ti.pscl (/home/bbergan/dvsdk/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/pscl/) [1, 0, 0, 0]
    [DSP] @0,055,979tk: [+4 T:0x8faee8ac] OG -     package ti.bios (/home/bbergan/dvsdk/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/bios/) [5, 2, 5, 19]
    [DSP] @0,056,046tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.ires (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/ires/) [1, 0, 0]
    [DSP] @0,056,124tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.ires.hdvicp (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/ires/hdvicp/) [1, 0, 1]
    [DSP] @0,056,207tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.hdintc (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/hdintc/) [1, 0, 4]
    [DSP] @0,056,287tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.edma3.rm (/home/bbergan/dvsdk/dvsdk_3_10_00_19/edma3_lld_01_11_00_03/packages/ti/sdo/edma3/rm/) [01, 03, 07]
    [DSP] @0,056,363tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.ires.nullresource (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/ires/nullresource/) [1, 0, 0]
    [DSP] @0,056,450tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.utils.trace (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/utils/trace/) [1, 0, 0]
    [DSP] @0,056,534tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.dskt2 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/dskt2/) [1, 0, 4]
    [DSP] @0,056,611tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.rman (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/rman/) [2, 0, 0]
    [DSP] @0,056,689tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.edma3 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/edma3/) [3, 0, 0]
    [DSP] @0,056,767tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.ires.edma3chan (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/ires/edma3chan/) [1, 0, 0]
    [DSP] @0,056,853tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.global (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/global/) [1, 0, 0]
    [DSP] @0,056,929tk: [+4 T:0x8faee8ac] OG -     package ti.xdais.dm (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdais_6_25_02_11/packages/ti/xdais/dm/) [1, 0, 5]
    [DSP] @0,056,999tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.node (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/node/) [1, 0, 0]
    [DSP] @0,057,075tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.ipc.dsplink.dsp (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/ipc/dsplink/dsp/) [2, 0, 1]
    [DSP] @0,057,158tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.utils.xdm (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/utils/xdm/) [1, 0, 2]
    [DSP] @0,057,240tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.dman3 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/dman3/) [1, 0, 4]
    [DSP] @0,057,320tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.memutils (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/memutils/) [1, 0, 0]
    [DSP] @0,057,401tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.fc.acpy3 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/acpy3/) [1, 0, 4]
    [DSP] @0,057,481tk: [+4 T:0x8faee8ac] OG -     package dsplink.dsp (/home/bbergan/dvsdk/dvsdk_3_10_00_19/dsplink_linux_1_64/dsplink/dsp/) [1, 4, 0]
    [DSP] @0,057,548tk: [+4 T:0x8faee8ac] OG -     package ti.bios.utils (/home/bbergan/dvsdk/dvsdk_3_10_00_19/biosutils_1_02_02/packages/ti/bios/utils/) [2, 0, 2, 02]
    [DSP] @0,057,621tk: [+4 T:0x8faee8ac] OG -     package ti.catalog.c6000 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/catalog/c6000/) [1, 0, 0, 0]
    [DSP] @0,057,696tk: [+4 T:0x8faee8ac] OG -     package ti.catalog (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/catalog/) [1, 0, 0]
    [DSP] @0,057,767tk: [+4 T:0x8faee8ac] OG -     package ti.platforms.evmDM6467 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/platforms/evmDM6467/) [1, 0, 0, 0]
    [DSP] @0,057,847tk: [+4 T:0x8faee8ac] OG -     package ti.targets.rts6000 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/targets/rts6000/) [1, 0, 0, 0]
    [DSP] @0,057,924tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.osal (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/osal/) [2, 0, 2]
    [DSP] @0,057,998tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.osal.bios (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/osal/bios/) [2, 0, 1]
    [DSP] @0,058,078tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.ipc (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/ipc/) [2, 0, 1]
    [DSP] @0,058,152tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.ipc.bios (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/ipc/bios/) [2, 0, 1]
    [DSP] @0,058,229tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.alg (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/alg/) [1, 0, 1]
    [DSP] @0,058,304tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/) [1, 0, 6]
    [DSP] @0,058,375tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.bioslog (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/bioslog/) [1, 0, 1]
    [DSP] @0,058,452tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.universal (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/universal/) [1, 0, 0]
    [DSP] @0,058,530tk: [+4 T:0x8faee8ac] OG -     package adsys.insight (/home/bbergan/projects/Insight/cetest/adsys/insight/) [1, 0, 0]
    [DSP] @0,058,592tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.video2 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/video2/) [1, 0, 2]
    [DSP] @0,058,669tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.h2641080p60vdec.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/ce/) [1, 0, 0]
    [DSP] @0,058,756tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.h264dec.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264dec/ce/) [1, 0, 0]
    [DSP] @0,058,837tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.ce.video1 (/home/bbergan/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/video1/) [1, 0, 2]
    [DSP] @0,058,913tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.h264enc.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264enc/ce/) [1, 0, 0]
    [DSP] @0,058,994tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.h264fhdvenc.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/ce/) [1, 0, 0]
    [DSP] @0,059,080tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.mpeg2dec.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg2dec/ce/) [1, 0, 0]
    [DSP] @0,059,161tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.mpeg4dec.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4dec/ce/) [1, 0, 0]
    [DSP] @0,059,243tk: [+4 T:0x8faee8ac] OG -     package ti.sdo.codecs.mpeg4enc.ce (/home/bbergan/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4enc/ce/) [1, 0, 0]
    [DSP] @0,059,326tk: [+4 T:0x8faee8ac] OG -     package adsys.insight.servers.ias (/home/bbergan/projects/Insight/cstest2/adsys/insight/servers/ias/) [1, 0, 0]
    [DSP] @0,059,399tk: [+0 T:0x8faee8ac] OG - Global_setSpecialTrace> return
    @3,434,053us: [+0 T:0x4001ea50] CE - Engine_fwriteTrace> returning count [10522]
    @3,434,359us: [+0 T:0x4001ea50] CE - Engine_open> return(373936)
    @3,434,677us: [+0 T:0x4001ea50] ti.sdo.ce.universal.UNIVERSAL - UNIVERSAL_create> Enter (engine=0x5b4b0, name='insight', params=0x0 (size=0x0))
    @3,435,013us: [+0 T:0x4001ea50] CV - VISA_create(0x5b4b0, 'insight', 0x0, 0x648, 'ti.sdo.ce.universal.IUNIVERSAL')
    @3,435,304us: [+0 T:0x4001ea50] CV - VISA_create2(0x5b4b0, 'insight', 0x0, 0x0, 0x648, 'ti.sdo.ce.universal.IUNIVERSAL')
    @3,435,746us: [+0 T:0x4001ea50] CE - Engine_createNode(0x5b4b0, 'insight', 648, 0x0, 0x0, 0xbed56890)
    @3,436,063us: [+0 T:0x4001ea50] CE - Engine> allocNode Enter(engine=0x5b4b0, impId='insight')
    @3,436,598us: [+0 T:0x4001ea50] CE - Engine> allocNode(). Calling (Comm_create(gppfromnode_1336_1, 0x5b828, NULL)
    @3,441,832us: [+4 T:0x4001ea50] CE - Engine_createNode> created node(stdIn=0x2, stdOut=0x10001, msgq=0x5b848, algName='insight', rmsNode=0x8faff380, algHandle=0x8faff468)
    [DSP] @0,151,362tk: [+0 T:0x8faee8ac] OM - Memory_alloc> Enter(size=0x18)
    [DSP] @0,151,431tk: [+0 T:0x8faee8ac] OM - Memory_alloc> return (0x8faff380)
    [DSP] @0,151,485tk: [+0 T:0x8faee8ac] OM - Memory_alloc> Enter(size=0xa)
    [DSP] @0,151,524tk: [+0 T:0x8faee8ac] OM - Memory_alloc> return (0x8faff398)
    [DSP] @0,151,597tk: [+0 T:0x8faee8ac] OM - Memory_alloc> Enter(size=0x20)
    [DSP] @0,151,648tk: [+0 T:0x8faee8ac] OM - Memory_alloc> return (0x8faff3a8)
    [DSP] @0,151,700tk: [+0 T:0x8faee8ac] OM - Memory_alloc> Enter(size=0x24)
    [DSP] @0,151,743tk: [+0 T:0x8faee8ac] OM - Memory_alloc> return (0x8faff3c8)
    [DSP] @0,151,837tk: [+0 T:0x8faee8ac] ti.sdo.ce.universal.UNIVERSAL - UNIVERSAL_create> Enter (engine=0x0, name='insight', params=0x0 (size=0x0))
    [DSP] @0,151,934tk: [+0 T:0x8faee8ac] CV - VISA_create(0x0, 'insight', 0x0, 0x648, 'ti.sdo.ce.universal.IUNIVERSAL')
    [DSP] @0,152,021tk: [+0 T:0x8faee8ac] CV - VISA_create2(0x0, 'insight', 0x0, 0x0, 0x648, 'ti.sdo.ce.universal.IUNIVERSAL')
    [DSP] @0,152,122tk: [+0 T:0x8faee8ac] CE - Engine_open> Enter('local', 0x8fafe584, 0x0)
    [DSP] @0,152,183tk: [+0 T:0x8faee8ac] OM - Memory_alloc> Enter(size=0x2c)
    [DSP] @0,152,225tk: [+0 T:0x8faee8ac] OM - Memory_alloc> return (0x8faff438)
    [DSP] @0,152,300tk: [+0 T:0x8faee8ac] CE - Engine_open> return(-1884294088)
    [DSP] @0,152,398tk: [+0 T:0x8faee8ac] OM - Memory_alloc> Enter(size=0x34)
    [DSP] @0,152,441tk: [+0 T:0x8faee8ac] OM - Memory_alloc> return (0x8faff468)
    [DSP] @0,152,496tk: [+0 T:0x8faee8ac] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0x8faaac84, idma3Fxns=0x0, iresFxns=0x0, params=0x0, attrs=0x8fafe6a0)
    [DSP] @0,152,580tk: [+0 T:0x8faee8ac] OM - Memory_alloc> Enter(size=0x10)
    [DSP] @0,152,622tk: [+0 T:0x8faee8ac] OM - Memory_alloc> return (0x8faff4a0)
    [DSP] @0,152,810tk: [+4 T:0x8faee8ac] INSIGHT - INSIGHT_ADSYS_alloc
    [DSP] @0,152,933tk: [+4 T:0x8faee8ac] INSIGHT - INSIGHT_ADSYS_initObj
    [DSP] @0,152,985tk: [+4 T:0x8faee8ac] INSIGHT -     Tracker Initialized
    [DSP] @0,153,066tk: [+4 T:0x8faee8ac] Insight_Alg - Tracker_Initialize
    [DSP] @0,153,135tk: [+0 T:0x8faee8ac] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x8faff4a0)
    [DSP] @0,153,210tk: [+5 T:0x8faee8ac] CV - VISA_create> local codec created (name='insight', handle=0x8faff4a0)
    [DSP] @0,153,279tk: [+0 T:0x8faee8ac] ti.sdo.ce.universal.UNIVERSAL - UNIVERSAL_create> return (0x8faff468)
    [DSP] @0,153,351tk: [+4 T:0x8faee8ac] OT - Thread_create > name: "insight#0", pri:  -1, stack size:  37024, stack seg: 0
    @3,450,372us: [+0 T:0x4001ea50] CE - Engine_fwriteTrace> returning count [2494]
    @3,450,972us: [+2 T:0x4001ea50] CE - Engine_createNode> Returning 0x5b820
    @3,451,305us: [+5 T:0x4001ea50] CV - VISA_create> remote codec created (name='insight', localQueueID=0x10001, remoteQueueID=0x0002)
    @3,451,615us: [+0 T:0x4001ea50] ti.sdo.ce.universal.UNIVERSAL - UNIVERSAL_create> return (0x5b7d8)
    cAttrs.numBufs 			= 3
    cAttrs.cropX 			= -1
    cAttrs.cropY 			= -1
    @3,454,244us: [+2 T:0x4001ea50] ti.sdo.dmai - [BufTab] Allocating BufTab for 3 buffers
    @3,455,013us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(1843200) = 0x41381000.
    @3,455,428us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x41381000) = 0x885df000.
    @3,455,772us: [+2 T:0x4001ea50] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1843200 at 0x41381000 (0x885df000 phys)
    @3,456,463us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(1843200) = 0x41543000.
    @3,456,873us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x41543000) = 0x8841d000.
    @3,457,353us: [+2 T:0x4001ea50] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1843200 at 0x41543000 (0x8841d000 phys)
    @3,458,069us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(1843200) = 0x41705000.
    @3,458,487us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x41705000) = 0x8825b000.
    @3,458,842us: [+2 T:0x4001ea50] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1843200 at 0x41705000 (0x8825b000 phys)
    @3,459,693us: [+2 T:0x4001ea50] ti.sdo.dmai - [Capture] Component input selected
    @3,472,116us: [+2 T:0x4001ea50] ti.sdo.dmai - [Capture] Capture input set to Component:9
    @3,472,812us: [+2 T:0x4001ea50] ti.sdo.dmai - [Capture] Video input connected size 1280x720 pitch 1280
    dAttrs.videoStd = 5
    @3,540,437us: [+2 T:0x4001ea50] ti.sdo.dmai - [BufTab] Allocating BufTab for 3 buffers
    @3,551,053us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(691200) = 0x418c7000.
    @3,551,489us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x418c7000) = 0x8ed1f000.
    @3,551,838us: [+2 T:0x4001ea50] ti.sdo.dmai - [Buffer] Alloc Buffer of size 691200 at 0x418c7000 (0x8ed1f000 phys)
    @3,552,502us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(691200) = 0x419a8000.
    @3,552,928us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x419a8000) = 0x8ec3e000.
    @3,553,283us: [+2 T:0x4001ea50] ti.sdo.dmai - [Buffer] Alloc Buffer of size 691200 at 0x419a8000 (0x8ec3e000 phys)
    @3,553,913us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(691200) = 0x41a89000.
    @3,554,337us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x41a89000) = 0x8eacd000.
    @3,554,679us: [+2 T:0x4001ea50] ti.sdo.dmai - [Buffer] Alloc Buffer of size 691200 at 0x41a89000 (0x8eacd000 phys)
    @3,555,457us: [+2 T:0x4001ea50] ti.sdo.dmai - [Display] Output detected Composite
    @3,611,351us: [+2 T:0x4001ea50] ti.sdo.dmai - [Display] Display Output set to Composite; Display Standard is set to 5
    @3,611,980us: [+2 T:0x4001ea50] ti.sdo.dmai - [Display] Video output set to size 720x480 pitch 720 imageSize 691200
    hDisplay: 376120
    cBufSize=1843200
    dBufSize=691200
    @3,714,896us: [+2 T:0x4001ea50] ti.sdo.dmai - [Resize] Configuring resize from 1280x720 (pitch 1280) to 720x480 (pitch 720)
    @3,716,110us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(12000) = 0x41b89000.
    @3,716,540us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x41b89000) = 0x8ea62000.
    @3,717,142us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(12000) = 0x41b9f000.
    @3,717,569us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x41b9f000) = 0x8ea4c000.
    @3,718,636us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(76) = 0x41bb5000.
    @3,719,056us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x41bb5000) = 0x8ea78000.
    @3,719,670us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_alloc(204) = 0x41c0a000.
    @3,720,096us: [+4 T:0x4001ea50] OM - Memory_contigAlloc> CMEM_getPhys(0x41c0a000) = 0x8ebcd000.
    Setting User Target
    @3,724,501us: [+0 T:0x4001ea50] ti.sdo.ce.universal.UNIVERSAL - UNIVERSAL_control> Enter (handle=0x5b7d8, id=258, dynParams=0x41bb5000 (size=0x4c), status=0x41c0a000 (size=0xcc)
    @3,724,955us: [+4 T:0x4001ea50] CV - VISA_getMaxMsgSize(0x5b7d8): returning 0x1000
    @3,725,275us: [+5 T:0x4001ea50] CV - VISA_allocMsg> Allocating message for messageId=0x0002eaab
    @3,725,577us: [+0 T:0x4001ea50] CV - VISA_call(visa=0x5b7d8, msg=0x41311880): messageId=0x0002eaab, command=0x1
  • I've also done a CE_DEBUG=3 on the custom board to get more detail:
    @4,239,125us: [+1 T:0x4001ea50 S:0xbea9284c] OM - Memory__addContigBuf> returning: cb->phys=0x8b7cd000, cb->size=204, cb->virt=0x41c0a000
    @4,239,454us: [+0 T:0x4001ea50 S:0xbea92894] OM - Memory_contigAlloc> return (0x41c0a000)
    @4,239,750us: [+0 T:0x4001ea50 S:0xbea928dc] OM - Memory_alloc> return (0x41c0a000)
    Setting User Target
    @4,240,243us: [+0 T:0x4001ea50 S:0xbea92894] ti.sdo.ce.universal.UNIVERSAL - UNIVERSAL_control> Enter (handle=0x5b7d8, id=258, dynParams=0x41bb5000 (size=0x4c), status=0x41c0a000 (size=0xcc)
    @4,240,708us: [+4 T:0x4001ea50 S:0xbea92804] CV - VISA_getMaxMsgSize(0x5b7d8): returning 0x1000
    @4,241,051us: [+5 T:0x4001ea50 S:0xbea9280c] CV - VISA_allocMsg> Allocating message for messageId=0x000266a7
    @4,242,028us: [+0 T:0x4001ea50 S:0xbea927ec] CV - VISA_call(visa=0x5b7d8, msg=0x41311880): messageId=0x000266a7, command=0x1
    @4,242,392us: [+0 T:0x4001ea50 S:0xbea927b4] OC - Comm_put> Enter(queue=0x2, msg=0x41311880)
    @4,243,285us: [+0 T:0x4001ea50 S:0xbea927b4] OC - Comm_put> return (0)
    @4,243,626us: [+0 T:0x4001ea50 S:0xbea927ac] OC - Comm_get> Enter(queue=0x10001, msg=0xbea928a4, timeout=-1)
    It appears like it is waiting on a queue for the DSP to return from the UNIVERSAL_control() call.
  • Thanks, this looks like something has gone wrong on the DSP-side. But the booting was successful because PROC_start succeeded. Something else went wrong after that because of which the MSGQ_get call within Comm_get did not return (essentially the DSP-side did not respond back as expected).
    Can you debug on DSP-side by connecting CCS and seeing what's going on there?
    Mugdha
  • I had seen something similar sometime back but I am not sure if you are facing the same issue. The issue in my setup was that the ARM application was overwritting  some memory locations in CMEM where the codec server was placed due to an error in the loadmodules script. You should check to see if the CMEM configuration in your loadmodules script excludes the memory locations assigned for the codec server. If possible,scale down the memory allocations on ARM side(work with smaller data or free unwanted allocation) to see if the control call is made.
    If this does not help you can place a break point in your Universal_control code on the DSP to check if the call does actually reach the DSP. Follow the steps mentioned in the following wiki to identify the exact point in your code where the application hangs on the DSP side.
    http://processors.wiki.ti.com/index.php/Debugging_the_DSP_side_of_a_CE_application_on_DaVinci_using_CCS
    Rahul
