Hi experts,
in oder to run saLoopBack example and edit it to built capture and display application, I follow these steps to built modules.
make clean
make components
make all
make install
make CROSS_COMPILE=/home/ernest/CodeSourcery/Sourcery_G++_Lite/bin/arm-none-linux-gnueabi- ARCH=arm ti8148_evm_defconfig
make CROSS_COMPILE=/home/ernest/CodeSourcery/Sourcery_G++_Lite/bin/arm-none-linux-gnueabi- ARCH=arm menuconfig
make CROSS_COMPILE=/home/ernest/CodeSourcery/Sourcery_G++_Lite/bin/arm-none-linux-gnueabi- ARCH=arm uImage
make syslink_clean
make syslink
make examples
make syslink_install
make install
make CROSS_COMPILE=/home/ernest/CodeSourcery/Sourcery_G++_Lite/bin/arm-none-linux-gnueabi- ARCH=arm modules
Copie modules to my targetfs (/lib/modules ...).
But after that, when I boot my board, I had this error : FATAL: syslink module not found.
I fix it by inserting in thee file /etc/init.d/rcS the line /sbin/depmod -a.
And then I have another error :
FIRMWARE: Memory map bin file not passed
Usage : firmware_loader <Processor Id> <Location of Firmware> <start|stop> [Location of Mem map bin file]
FIRMWARE: Default memory configuration is used
MemCfg: DCMM (Dynamically Configurable Memory Map) Version : 2.1.1.1
FIRMWARE: Could not open ProcMgr: ProcMgr status 0xfffffffe
Loading HDVPSS (V4L2) Firmware
FIRMWARE: Memory map bin file <-i2c> - not exists
notify_shm_drv_sendevent failed! status = 0xfffffff0
notify_send_event failed! status = 0xfffffff0
VPSS_CORE : Failed to init fvid2 interface,
vpss: probe of vpss failed with error -22
VPSS_CORE : failed to register ti81xx-vpss driver
FATAL: Error inserting vpss (/lib/modules/2.6.37/kernel/drivers/video/ti81xx/vpss/vpss.ko): No such device
FATAL: Error inserting ti81xxfb (/lib/modules/2.6.37/kernel/drivers/video/ti81xx/ti81xxfb/ti81xxfb.ko): No such devicetc/rc5.d/S01load-hd-firmware.sh: line 62: can't create /sys/devices/platform/vpss/display
1/enabled: nonexistent directory
/etc/init.d/rc: /etc/rc5.d/S01load-hd-firmware.sh: line 62: can't create /sys/devices/platform/vpss/display1/timings: nonexistent directory
/etc/init.d/rc: /etc/rc5.d/S01load-hd-firmware.sh: line 62: can't create /notify_shm_drv_sendevent failed! status = 0xfffffff0sys/devices/plat
notify_send_event failed! status = 0xfffffff0form/vpss/display1/output: nonexistent directory
/etc/init.d/rc: /etc/rc5.d/S01load-hd-firmware.sh: line 62: can't create /sys/devices/platform/vpss/display1/enabled: nonexistent directory
open /dev/fb0: No such file or directory
FATAL: Error inserting ti81xxvo (/lib/modules/2.6.37/kernel/drivers/media/video/ti81xx/ti81xxvo.ko): No such device
FATAL: Error inserting ti81xxvin (/lib/modules/2.6.37/kernel/drivers/media/video/ti81xx/ti81xxvin.ko): No such device
FATAL: Error inserting ti81xxhdmi (/lib/modules/2.6.37/kernel/drivers/video/ti81xx/ti81xxhdmi/ti81xxhdmi.ko): No such device
Starting system message bus: dbus.
Starting telnet daemon.
Starting syslogd/klogd: done
Starting thttpd.
expr: syntax error
Linux Frame Buffer Device Configuration Version 2.1 (23/06/1999)
(C) Copyright 1995-1999 by Geert Uytterhoeven
Usage: fbset [options] [mode]
Valid options:
General options:
-h, --help : display this usage information
--test : don't change, just test whether the mode is valid
-s, --show : display video mode settings
-i, --info : display all frame buffer information
-v, --verbose : verbose mode
-V, --version : print version information
-x, --xfree86 : XFree86 compatibility mode
-a, --all : change all virtual consoles on this device
Frame buffer special device nodes:
-fb <device> : processed frame buffer device
(default is /dev/fb0)
Video mode database:
-db <file> : video> : horizontal resolution (in pixels)
-yres <value> : vertical resolution (in pixels)
-vxres <value> : virtual horizontal resolution (in pixels)
-vyres <value> : virtual vertical resolution (in pixels)
-depth <value> : display depth (in bits per pixel)
-nonstd <value> : select nonstandard video mode
-g, --geometry ... : set all geometry parameters at once
-match : set virtual vertical resolution by virtual resolution
Display timings:
-pixclock <value> : pixel clock (in picoseconds)
-left <value> : left margin (in pixels)
-right <value> : right margin (in pixels)
-upper <value> : upper margin (in pixel lines)
-lower <value> : lower margin (in pixel lines)
-hslen <value> : horizontal sync length (in pixels)
-vslen <value> : vertical sync length (in pixel lines)
-t, --timings ... : set all timing parameters aity (low or high)
-csync <value> : composite sync polarity (low or high)
-gsync <value> : synch on green (false or true)
-extsync <value> : external sync enable (false or true)
-bcast <value> : broadcast enable (false or true)
-laced <value> : interlace enable (false or true)
-double <value> : doublescan enable (false or true)
-rgba <r,g,b,a> : recommended length of color entries
-grnotify_shm_drv_sendevent failed! status = 0xfffffff0ayscale <value>
notify_send_event failed! status = 0xfffffff0: grayscale enable (false or true)
Display positioning:
-move <direction> : move the visible part (left, right, up or
FATAL: Error inserting omaplfb (/lib/modules/2.6.37/kernel/drivers/gpu/pvr/omaplfb.ko): No such device
/dev/mem opened.
Memory mapped at address 0x4018b000.
Read at address 0x48180F04 (0x4018bf04): 0x00000001
Write at address 0x48180F04 (0x4018bf04): 0x00000000, readback 0x00000000
/dev/mem opened.
Memory mapped at address 0x40226000.
Read at address 0x48180900 (0x40226900): 0x00000102
Write at address 0x48180900 (0x40226900): 0x00000002, readback 0x00000002
/dev/mem opened.
Memory mapped at address 0x402b1000.
Read at address 0x48180920 (0x402b1920): 0x00040002
Write at address 0x48180920 (0x402b1920): 0x00000002, readback 0x00000002
Starting Matrix GUI application.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org dm814x-evm ttyO0
Arago 2011.09 dm814x-evm ttyO0
dm814x
I need help please.
I use EZSDK 5.05 in ubuntu 10.04 LTS and this is my bootargs :
TI8148_EVM#print
bootdelay=3
baudrate=115200
verify=yes
ramdisk_file=ramdisk.gz
loadaddr=0x81000000
script_addr=0x80900000
loadbootscript=fatload mmc 0 ${script_addr} boot.scr
bootscript= echo Running bootscript from MMC/SD to set the ENV...; source ${script_addr}
ethact=cpsw
ethaddr=08:11:23:32:12:77
autoload=no
nfsserver=10.0.2.15
gatewayip=10.192.78.129
netmask=255.255.255.128
dnsip=10.192.22.5
dnsip2=10.192.57.10
bootfile=uImage-dm814x-evm.bin
ipaddr=192.168.0.10
serverip=192.168.0.20
bootcmd=mmc rescan 0;fatload mmc 0 0x82000000 uImage;bootm 0x82000000
bootargs=console=ttyO0,115200n8 rootwait rw mem=256M earlyprintk notifyk.vpssm3_sva=0xBF900000 vram=50M ti814xfb.vram=0:16M,1:16M,2:6M root=/dev/nfs nfsroot=192.168.0.20:/home/ernest/targetfs ip=192.168.0.10
rootdelay=15
stdin=serial
stdout=serial
stderr=serial
Environment size: 809/8188 bytes
Thanks in advance !
