Disable preemption
If a function wants to protect itself against reentrancy, is it enough to simply disable HWI? Will that automatically disable SWIs and TSKs as well?
In other words, do I need to do this:
    TSK_disable();
    SWI_enable();
    oldmask = HWI_disable();
...... critical section ........
    HWI_restore(oldmask);
    SWI_enable();
    TSK_enable();
  • Depending on the content of your critical section, HWI_disable() is probably all that is required to protect it from SWI and TSK pre-emption.
    Hwi_disable() blocks asyncronous SWI and TSK pre-emption (ie interrupts that post a SWI or SEM).
    However, if your critical section directly readies a higher priority TSK (ie calls SEM_post()) or posts a SWI (SWI_post()), the critical section WILL be pre-empted.
    If your critical section will be posting SWIs or readying higher priority TSKs, then you will need the additional protection of TSK_disable() and SWI_disable().
    Alan DeMars
