EVM Mistral Rev G Audio Problem
Other Parts Discussed in Thread: AM3715
I have an eval board EVM3715. While the Audio Playback is working the Audio Recording (using the arecord command in linux) is not.
I've followed the userguide Audio driver PSP 03.00.00.05 but no luck. I've tried all the obvious things (like new mic, etc).
Any ideas as what could be the issue? Anyone has similar problem?
  • Hi
    I also have similar problem. Am using AM3715 kit, 'Audio IN' is not working in my kit .When i use sound recorder am getting some noise but am not getting actual recorded speech.
    On this AM37kit am using Android gingerbread.
    Did you find any solution for your problem?
    If u find any solution please help me...
    Thanks in Advance
    chandu...:)
  • chandrashekar palle said:
    Hi
    Chandrashekar,
    Which revision of Am3715 evm are you using? Audio Capture and Playback is  tested and working to be working in the TI Android 2.3 Gingerbread 1.0 release on the AM/DM37xRevG evm.
  • HI Vishveshwar
    Am using  AM3715 from mistral solutions.
    Android version: 2.3 Gingerbread 1.0
    I dont know which revision am using..How to find which revision am using?
    Today I connected laptop audio-out port to EVM kit Audio-In port. I played some music in laptop and able to record that in EVM kit by using this setup. But when am connecting microphone to EVM Audio-In port am unable record speech.
    Do you have any idea about this problem??
    Thanks and Regards
    Chandrashekar
    It appears that the evm supports only Line-in (Amplified audio signal) and not Mic-in. We will check and get back to you.
