TDA2: [TDA / opencv / usecase modification] want to implement my code by modifying the opencvopencldilation usecase
Part Number: TDA2
(vision SDK version : PROCESSOR_SDK_VISION_03_03_00_00)
Hi
I'm newbie of using TDA2x evb board and vision App board
I'd like to implement my algorithm which is using openCV and implement it by modifying the sample usecase&alg_plugins ( vip_single_cam_opencvopencldilation / opencvopencldilation)
[ Question ]
I want to apply my alogirhtm code and display it to the monitor.
Where the points that I should modify the code?
I started modifying like below, however when I remove the "cv::dilate" code, it displays black image with processor usage.
prior code
<openclDilation.cpp>
modified code
void* openclDilationThreadFunc(void* args)
    while(1)
        cv::Mat openCLDilationInputMat;
        cv::Mat openCLDilationOutputMat;
        cv::UMat openCLDilationInputUMat;
        cv::UMat openCLDilationOutputUMat;
        if(!gOpenCLDilationThreadStarted)
            cv::ocl::setUseOpenCL(1);
            gOpenCLDilationThreadStarted = 1;
        /* wait for the produce thread to point to the current input
         * and output buffers
        while(!g_cac)
            usleep(1000);
        pthread_mutex_lock(&gOpenCLDilationMtx);
         * \brief Compute using OpenCV
        openCLDilationInputMat  = cv::cvarrToMat(gOpenCLDilationKernelArgs.inputImage, false);
        openCLDilationOutputMat = cv::cvarrToMat(gOpenCLDilationKernelArgs.outputImage, false);
        openCLDilationInputUMat = openCLDilationInputMat.getUMat(cv::ACCESS_RW);
        openCLDilationOutputUMat = openCLDilationOutputMat.getUMat(cv::ACCESS_RW);
        cv::dilate(openCLDilationInputUMat, openCLDilationOutputUMat, cv::Mat());
        openCLDilationInputUMat.release();
        openCLDilationOutputUMat.release();
        openCLDilationInputMat.release();
        openCLDilationOutputMat.release();
        g_cac = 0;
        pthread_mutex_unlock(&gOpenCLDilationMtx);
    pthread_exit(&gOpenCLDilationThreadRtn);
    return ((void*) 0);
    while(1)
        while(!g_cac)
            usleep(1000);
  openCLDilationOutputUMat = openCLDilationInputUMat;
  openCLDilationOutputMat = openCLDilationInputMat;
        g_cac = 0;
    return ((void*) 0);
