Other Parts Discussed in Thread: DM3730
We have a need for 720p video thru an HDMI port. Is there a linux driver for an HDMI controller? If so, is it in a board support package?
Ken
Ken
Ken,
Other resolutions are already supported through sys/fs entries.
Have a look at the following web pages...
http://processors.wiki.ti.com/index.php/Adding_new_DVI_resolutions
http://processors.wiki.ti.com/index.php/UserGuideDisplayDrivers_PSP_03.00.00.05
http://processors.wiki.ti.com/index.php/Display_Subsystem
If you are only concerned about video through the HDMI port then the existing DVI drivers should work. If you want audio too, or want to support some of the other HDMI features such as YUV color space etc... then you will need to modify the drivers yourself based on the specific HDMI transmitter you ultimately decide to use.
BR,
Steve
Hi Steve,
I have a similar question. Now I have a Beagleboard-xM Rev-B which contains DM3730. I also wanna use HDMI which have both video and audio feature. Does that mean that I need to modify the current DVI driver to make it work?
BTW, can you tell me where can I get the open source DVI driver which currently works on my BBXM board? Thank you so much for your help!
Best regards!
Unfortunately the Beagle boards do not have HDMI transmitters, only DVI transmitters so you will not be able to do HDMI with audio without building your own daughter card containing a HDMI transmitter.
I have asked our software team to let you know about software releases.
BR,
Steve
Xing,
Beagleboard is not actually a TI product, so you will really need to check http://beagleboard.org/ to see what might be available in the community.
BR,
Steve
