Part Number: AM3352
Other Parts Discussed in Thread: UNIFLASH,
We are developing a board with the AM3352 CPU. For programming we are hoping to use the USB0 boot-mode and then UniFlash to program over "Ethernet over USB"/RNDIS. To test this out before sending the final PCBA for production we are using a Beaglebone Black.
Our production programming and test environment use Windows 10 as OS.
When we connect the BBB over USB to our computer (pressing button S2 on the BBB board and have no SD-card attached) W10 enumerates the CPU as a serial device and we get a COM-port. I have seen others with this issue while searching the Internet (but no solution). On an old Windows 7 somputer I found stored away it works. W7 enumerates the CPU as "other device" and I can install the correct driver. And later on UniFlash will recognize the CPU and we are able to program it.
Is it possible to get this working on Windows 10? Have anyone made it work? Should we rethink our programming strategy and program the eMMC onboard some other way? In worst case we could use UART0, but that would take for ever to program the board.
Thanks in advance!
Jonas
