Other Parts Discussed in Thread: TVP5146
what is wrong with my board when I run the demo decode ?
root@192.168.1.3:/opt/dvevm# ./decode -v data/videos/davincieffect_ntsc.264
Decode demo started.
DaVinci I2C WARNING: i2c: NACK detected
Decode Error: Failed to initialize msp430lib.
Total I-frames: 0, P-frames: 2, B-frames: 0, IDR-frames: 1 rejected: 0
And the boot message there is
fb0: dm_osd0_fb frame buffer device
fb1: dm_vid0_fb frame buffer device
fb2: dm_osd1_fb frame buffer device
fb3: dm_vid1_fb frame buffer device
Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
Registering platform device 'serial8250'. Parent at platform
ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
io scheduler noop registered
io scheduler anticipatory registered
RAMDISK driver initialized: 1 RAM disks of 32768K size 1024 blocksize
Registering platform device 'ti_davinci_emac'. Parent at platform
TI DaVinci EMAC: MAC address is deadbeaf
TI DaVinci EMAC Linux version updated 4.0
TI DaVinci EMAC: Installed 1 instances.
netconsole: not configured, aborting
i2c /dev entries driver
Linux video capture interface: v1.00
Registering platform device 'vpfe.1'. Parent at platform
DaVinci v4l2 capture driver V1.0 loaded
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
Palm Chip BK3710 IDE Register Fail
elevator: using anticipatory as default io schedule
what is the problem, is there any IIC device that dosent work?
I boot it from TVP5146, and NFS
Any help is appreciated.
koomac.
