Other Parts Discussed in Thread: PCF8574A, THS7303, THS8200, THS7353, TVP7002
I'm trying to do 1080p video capture with a dm6467t EVM using the dvsdk_3_10_11_19 release. I'm using the h264fhdvenc encoder. When the encoder is created, more often than not, it causes a kernel crash. The problem can be reproduced by running the digital video test bed, using the h264fhdvenc encoder parameters described in the dvtb users manual. I need to find a way to create this encoder, because my application requires 1080p capture and encode. Thanks for looking into this!
Steps to reproduce the problem:
1. Download all required software from the TI site:
http://software-dl.ti.com/dsps/dsps_public_sw/sdo_sb/targetcontent/dvsdk/DVSDK_3_10/latest/index_FDS.html
2. Install the dvsdk_3_10_11_19 software (dvsdk_3_10_00_19_Setup.bin).
3. Install the cs2dm6467_1_00_00_10 codec server (cs2dm6467_1_00_00_10_Setup.bin).
4. Build the dvsdk for target dm6467.
5. Setup an nfs filesystem using the Arago demo rootfs and the dm6467 demo overlay (arago-demo-image-dm6467t-evm.tar.gz, dvsdk_3_10_00_19_overlay_dm6467.tar.gz)
6. Use the recommended boot arguments (mem=76M console=ttyS0,115200n8 root=/dev/nfs nfsroot=172.16.1.49:/home/jimk/workdir/filesys6467t,nolock ip=dhcp vpif_display.ch2_numbuffers=0 vpif_display.ch3_numbuffers=0)
7. Boot with the released kernel (uImage-dm6467t-evm.bin)
8. cd to the demo directory (/opt/dvsdk/dm6467). Run loadmodules.sh.
9. copy the dvtb binary from the dvsdk build to the demo directory. (dvsdk_3_10_00_19/dvtb_4_20_10/packages/ti/sdo/dvtb/dm6467/bin/dvtb-d)
10. copy a yuv video file to the demo directory (frame.yuv).
11. Crash the kernel by running the dvtb with the following parameters:
setp engine name encodedecode
setp h264fhdenc1 codec h264fhdvenc
setp h264fhdenc1 encodingPreset 0
setp h264fhdenc1 rateControlPreset 2
setp h264fhdenc1 maxHeight 1088
setp h264fhdenc1 maxWidth 1920
setp h264fhdenc1 maxFrameRate 30000
setp h264fhdenc1 maxBitRate 10000000
setp h264fhdenc1 dataEndianness 3
setp h264fhdenc1 maxInterFrameInterval 0
setp h264fhdenc1 inputChromaFormat 9
setp h264fhdenc1 inputContentType 0
setp h264fhdenc1 reconChromaFormat -1
setp h264fhdenc1 profileIdc 66
setp h264fhdenc1 levelIdc 40
setp h264fhdenc1 EntropyCodingMode 0
setp h264fhdenc1 inputHeight 1088
setp h264fhdenc1 inputWidth 1920
setp h264fhdenc1 refFrameRate 30000
setp h264fhdenc1 targetFrameRate 30000
setp h264fhdenc1 targetBitRate 10000000
setp h264fhdenc1 intraFrameInterval 30
setp h264fhdenc1 generateHeader 0
setp h264fhdenc1 captureWidth 0
setp h264fhdenc1 forceFrame -1
setp h264fhdenc1 interFrameInterval 0
setp h264fhdenc1 mbDataFlag 0
setp h264fhdenc1 sliceCodingPreset 0
setp h264fhdenc1 sliceMode 2
setp h264fhdenc1 sliceUnitSize 1500
setp h264fhdenc1 sliceStartOffset[0] 0
setp h264fhdenc1 sliceStartOffset[1] 0
setp h264fhdenc1 sliceStartOffset[2] 0
setp h264fhdenc1 sliceStartOffset[3] 0
setp h264fhdenc1 streamFormat 0
setp h264fhdenc1 OutBufSize -1
setp h264fhdenc1 QPISlice 28
setp h264fhdenc1 QPSlice 28
setp h264fhdenc1 RateCtrlQpMax 51
setp h264fhdenc1 RateCtrlQpMin 0
setp h264fhdenc1 NumRowsInSlice 0
setp h264fhdenc1 LfDisableIdc 0
setp h264fhdenc1 LFAlphaC0Offset 0
setp h264fhdenc1 LFBetaOffset 0
setp h264fhdenc1 ChromaQPOffset 0
setp h264fhdenc1 SecChromaQPOffset 0
setp h264fhdenc1 PicAFFFlag 0
setp h264fhdenc1 PicOrderCountType 0
setp h264fhdenc1 AdaptiveMBs 0
setp h264fhdenc1 SEIParametersFlag 0
setp h264fhdenc1 VUIParametersFlag 0
setp h264fhdenc1 SkipStartCodesInCallback 1
setp h264fhdenc1 Intra4x4EnableFlag 3
setp h264fhdenc1 BlockingCallFlag 0
setp h264fhdenc1 MESelect 1
setp h264fhdenc1 ME1080iMode 0
setp h264fhdenc1 MVDataFlag 0
setp h264fhdenc1 Transform8x8DisableFlag 1
setp h264fhdenc1 Intra8x8EnableFlag 0
setp h264fhdenc1 InterlaceReferenceMode 1
setp h264fhdenc1 ChromaConversionMode 1
setp h264fhdenc1 maxDelay 1000
setp h264fhdenc1 MaxSlicesSupported 90
setp h264fhdenc1 framePitch 1920
setp h264fhdenc1 numFrames 2
func h264fhdenc1 -s frame.yuv -t encode.264
Here is a full log of booting, creating the codec engine, and crashing:
U-Boot 2009.08-00002-gcab1855 (Jan 20 2010 - 04:20:31)
I2C: ready
DRAM: 256 MB
NAND: 128 MiB
In: serial
Out: serial
Err: serial
ARM Clock :- 495MHz
DDR Clock :- 396MHz
Net: Ethernet PHY: GENERIC @ 0x01
DaVinci EMAC
Hit any key to stop autoboot: 0
Loading from NAND 128MiB 3,3V 8-bit, offset 0x160000
Image Name: Arago/2.6.31+2.6.32-rc1-r31+gitr
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2061256 Bytes = 2 MB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 80700000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux....................................................................................................................................
Linux version 2.6.32-rc2-davinci1 (denis@elrond) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 PREEMPT Mon Jan 11 21:45:54 EST 2010
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: DaVinci DM646x EVM
Memory policy: ECC disabled, Data cache writeback
DaVinci dm6467_rev3.x variant 0x1
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 19304
Kernel command line: mem=76M console=ttyS0,115200n8 root=/dev/nfs nfsroot=172.16.1.49:/home/jimk/workdir/filesys6467t,nolock ip=dhcp vpif_display.ch2_0
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 76MB = 76MB total
Memory: 72628KB available (3876K code, 335K data, 144K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:245
Console: colour dummy device 80x30
Calibrating delay loop... 246.57 BogoMIPS (lpj=1232896)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
DaVinci: 43 gpio irqs
NET: Registered protocol family 16
MUX: Setting register STSOMUX_DISABLE
PINMUX0 (0x00000000) = 0x00000000 -> 0x00000000
MUX: Setting register STSIMUX_DISABLE
MUX: Setting register PTSOMUX_DISABLE
MUX: Setting register PTSIMUX_DISABLE
MUX: initialized CIR_UART2
MUX: Setting register CIR_UART2
PINMUX1 (0x00000004) = 0x00000000 -> 0x00000020
MUX: initialized ATAEN
MUX: Setting register ATAEN
PINMUX0 (0x00000000) = 0x00000000 -> 0x00000001
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
pcf857x 1-0038: gpios 145..152 on a pcf8574a
pcf857x 1-0038: setup --> -38
vpif vpif: vpif probe success
Switching to clocksource timer0_1
musb_hdrc: version 6.0, pio, peripheral, debug=0
musb_hdrc: USB Peripheral mode controller at fec64000 using PIO, IRQ 13
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
msgmni has been set to 141
io scheduler noop registered
io scheduler anticipatory registered (default)
CIR device registered successfully (Major = 252, Minor = 0)
Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a ST16654
console [ttyS0] enabled
serial8250 serial8250.0: unable to register port at index 1 (IO0 MEM1c20400 IRQ41): -22
serial8250 serial8250.0: unable to register port at index 2 (IO0 MEM1c20800 IRQ42): -22
brd: module loaded
loop: module loaded
at24 1-0050: 32768 byte 24c256 EEPROM (writable)
Read MAC addr from EEPROM: 00:0e:99:02:b7:6a
Uniform Multi-Platform E-IDE driver
ide-gd driver 1.18
ide0: MMIO-DMA
hda: TOSHIBA MK4032GAX, ATA DISK drive
hda: UDMA/100 mode selected
ide0 at 0xfec661f0-0xfec661f7,0xfec663f6 on irq 22
hda: max request size: 512KiB
hda: 78140160 sectors (40007 MB), CHS=16383/255/63
hda: cache flushes supported
hda: hda1 hda2
NAND device: Manufacturer ID: 0x20, Chip ID: 0xf1 (ST Micro NAND 128MiB 3,3V 8-bit)
Scanning device for bad blocks
Creating 4 MTD partitions on "davinci_nand.0":
0x000000000000-0x000000020000 : "params"
0x000000020000-0x000000160000 : "bootloader"
0x000000160000-0x000000560000 : "kernel"
0x000000560000-0x000008000000 : "filesystem"
davinci_nand davinci_nand.0: controller rev. 2.2
spi_davinci spi_davinci.0: DaVinci SPI driver in EDMA mode
Using RX channel = 17 , TX channel = 16 and event queue = 3
at25 spi0.0: 32 KByte at25640a eeprom, pagesize 64
spi_davinci spi_davinci.0: Controller at 0xfec66800
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
dm9000 Ethernet Driver, V1.31
console [netcon0] enabled
netconsole: network logging started
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbtest
g_ether gadget: using random self ethernet address
g_ether gadget: using random host ethernet address
usb0: MAC 3e:c2:85:ad:fc:11
usb0: HOST MAC 2a:8b:d0:ef:d4:ce
g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
g_ether gadget: g_ether ready
i2c /dev entries driver
Linux video capture interface: v2.00
ths7303 1-002c: chip found @ 0x58 (DaVinci I2C adapter)
ths8200 1-0020: chip found @ 0x40 (DaVinci I2C adapter)
ths7353 1-002e: chip found @ 0x5c (DaVinci I2C adapter)
vpif_capture vpif_capture: registered sub device ths7353
tvp7002 1-005d: tvp7002 1-005d decoder driver registered !!
vpif_capture vpif_capture: registered sub device tvp7002
vpif_capture vpif_capture: DM646x VPIF Capture driver initialized
watchdog watchdog: heartbeat 60 sec
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.21.
No device for DAI tlv320aic3x
asoc: tlv320aic3x <-> davinci-i2s mapping ok
asoc: DIT <-> davinci-dit mapping ok
ALSA device list:
#0: DaVinci DM6467 EVM (tlv320aic3x)
TCP cubic registered
NET: Registered protocol family 17
Clocks: disable unused uart1
Clocks: disable unused emac
Clocks: disable unused timer1
emac-mii: probed
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
eth0: attached PHY driver [ET1011C] (mii_bus:phy_addr=1:01, id=282f013)
Sending DHCP requests ..
PHY: 1:01 - Link is Up - 1000/Full
, OK
IP-Config: Got DHCP answer from 0.0.0.0, my address is 172.16.1.24
IP-Config: Complete:
device=eth0, addr=172.16.1.24, mask=255.255.0.0, gw=172.16.0.1,
host=172.16.1.24, domain=toyon.corp, nis-domain=(none),
bootserver=0.0.0.0, rootserver=172.16.1.49, rootpath=
Looking up port of RPC 100003/2 on 172.16.1.49
Looking up port of RPC 100005/1 on 172.16.1.49
VFS: Mounted root (nfs filesystem) on device 0:13.
Freeing init memory: 144K
INIT: version 2.86 booting
Please wait: booting...
Starting udev
udev: starting version 141
udevd[1032]: inotify_add_watch(3, (null), 10) failed: Bad address
snd_page_alloc: exports duplicate symbol snd_free_pages (owned by kernel)
soundcore: exports duplicate symbol sound_class (owned by kernel)
snd: module is already loaded
ide_core: exports duplicate symbol generic_ide_ioctl (owned by kernel)
snd_timer: module is already loaded
ide_gd_mod: module is already loaded
snd_pcm: module is already loaded
snd_soc_core: exports duplicate symbol snd_soc_unregister_codec (owned by kernel)
snd_soc_tlv320aic3x: exports duplicate symbol soc_codec_dev_aic3x (owned by kernel)
Remounting root file system...
mount: mounting /dev/root on / failed: Invalid argument
root: mount: mounting rootfs on / failed: No such file or directory
EXT2-fs warning (device hda1): ext2_fill_super: mounting ext3 filesystem as ext2
EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
EXT2-fs warning (device hda2): ext2_fill_super: mounting ext3 filesystem as ext2
ALSA: Restoring mixer settings...
Setting up IP spoofing protection: rp_filter.
Configuring network interfaces... udhcpc (v1.13.2) started
Sending discover...
Sending select for 172.16.1.24...
Lease of 172.16.1.24 obtained, lease time 172800
adding dns 172.17.0.4
adding dns 172.17.0.5
done.
Tue Jun 22 11:52:00 UTC 2010
INIT: Entering runlevel: 5
Starting telnet daemon.
Starting syslogd/klogd: done
Starting thttpdNET: Registered protocol family 10
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org dm6467t-evm ttyS0
Arago 2009.11 dm6467t-evm ttyS0
dm6467t-evm login: root
root@dm6467t-evm:~# cd /opt/dvsdk/dm6467/
root@dm6467t-evm:/opt/dvsdk/dm6467# cp /opt/vStream/dvtb-d .
root@dm6467t-evm:/opt/dvsdk/dm6467# ./loadmodules.sh
CMEMK module: built on Jul 14 2010 at 15:49:56
Reference Linux version 2.6.32
File /sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/linuxutils_2_25_04_10/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
allocated heap buffer 0xc9000000 of size 0x99000
cmemk initialized
DSPLINK Module (1.64) created on Date: Jul 14 2010 Time: 15:39:32
root@dm6467t-evm:/opt/dvsdk/dm6467# ./dvtb-d
Digital Video Test Bench ( DVTB )
[DVTB-DEBUG]: ../core/linux/dvtbEngine.c: Codec Engine Runtime initialized
<DVTB> $ exit
Exiting .......
root@dm6467t-evm:/opt/dvsdk/dm6467# export CE_DEBUG=2
@0,905,045us: [+4 T:0x4001f390] OG - Global_init> This program was built with the following packages:
@0,905,348us: [+4 T:0x4001f390] OG - package gnu.targets.arm.rtsv5T (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/xdctools_3_16_01_27/pack]
@0,905,452us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.aachedec (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/pac]
@0,905,542us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.g711dec (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/pack]
@0,905,626us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.g711enc (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/pack]
@0,905,711us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.h264dec (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/pack]
@0,905,794us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.h2641080p60vdec (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00]
@0,905,878us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.h264enc (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/pack]
@0,905,961us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.h264fhdvenc (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/]
@0,906,047us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.mpeg2dec (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/pac]
@0,906,132us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.jpegdec (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/pack]
@0,906,217us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.jpegenc (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/pack]
@0,906,301us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.mpeg4dec (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/pac]
@0,906,384us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.mpeg4enc (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/pac]
@0,906,468us: [+4 T:0x4001f390] OG - package ti.sdo.ce.global (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packag]
@0,906,550us: [+4 T:0x4001f390] OG - package dsplink.gpp (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/dsplink_linux_1_64/dsplink/gpp/) [5]
@0,906,630us: [+4 T:0x4001f390] OG - package ti.sdo.linuxutils.cmem (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/linuxutils_2_25_04_10/pa]
@0,906,712us: [+4 T:0x4001f390] OG - package gnu.targets (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/gnu/ta]
@0,906,792us: [+4 T:0x4001f390] OG - package gnu.targets.arm (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/gn]
@0,906,873us: [+4 T:0x4001f390] OG - package ti.sdo.utils.trace (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_components_2_25_02]
@0,906,987us: [+4 T:0x4001f390] OG - package ti.xdais.dm (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/xdais_6_25_02_11/packages/ti/xdais/]
@1,242,923us: [+4 T:0x4001f390] OG - package ti.sdo.ce.utils.xdm (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/pac]
@1,243,032us: [+4 T:0x4001f390] OG - package ti.xdais (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/xdais_6_25_02_11/packages/ti/xdais/) []
@1,243,123us: [+4 T:0x4001f390] OG - package ti.sdo.ce.node (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages]
@1,243,207us: [+4 T:0x4001f390] OG - package ti.sdo.fc.global (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_components_2_25_02_0]
@1,243,292us: [+4 T:0x4001f390] OG - package ti.sdo.fc.memutils (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_components_2_25_02]
@1,243,377us: [+4 T:0x4001f390] OG - package ti.sdo.fc.utils (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_components_2_25_02_06]
@1,243,524us: [+4 T:0x4001f390] OG - package ti.sdo.fc.dman3 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_components_2_25_02_06]
@1,243,622us: [+4 T:0x4001f390] OG - package ti.sdo.fc.acpy3 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_components_2_25_02_06]
@1,243,710us: [+4 T:0x4001f390] OG - package ti.catalog.arm (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/]
@1,243,794us: [+4 T:0x4001f390] OG - package ti.catalog (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/cata]
@1,243,874us: [+4 T:0x4001f390] OG - package ti.catalog.c6000 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/t]
@1,243,955us: [+4 T:0x4001f390] OG - package ti.platforms.evmDM6467 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/xdctools_3_16_01_27/pack]
@1,244,037us: [+4 T:0x4001f390] OG - package ti.sdo.ce.osal (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages]
@1,244,119us: [+4 T:0x4001f390] OG - package ti.sdo.ce.osal.linux (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/pa]
@1,244,203us: [+4 T:0x4001f390] OG - package ti.sdo.ce.ipc (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/]
@1,244,283us: [+4 T:0x4001f390] OG - package ti.sdo.ce.ipc.dsplink (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/p]
@1,244,367us: [+4 T:0x4001f390] OG - package ti.sdo.ce.alg (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/]
@1,244,448us: [+4 T:0x4001f390] OG - package ti.sdo.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/s]
@1,244,528us: [+4 T:0x4001f390] OG - package ti.sdo.ce.audio (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/package]
@1,244,609us: [+4 T:0x4001f390] OG - package ti.sdo.ce.audio1 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packag]
@1,244,691us: [+4 T:0x4001f390] OG - package ti.sdo.ce.video2 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packag]
@1,578,855us: [+4 T:0x4001f390] OG - package ti.sdo.ce.speech (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packag]
@1,578,964us: [+4 T:0x4001f390] OG - package ti.sdo.ce.speech1 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packa]
@1,579,055us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.aachedec.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/]
@1,579,146us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.g711dec.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/p]
@1,579,235us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.g711enc.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/p]
@1,579,321us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.h264dec.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/p]
@1,579,407us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.h2641080p60vdec.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00]
@1,579,495us: [+4 T:0x4001f390] OG - package ti.sdo.ce.video1 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packag]
@1,579,579us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.h264enc.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/p]
@1,579,662us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.h264fhdvenc.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_]
@1,579,747us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.mpeg2dec.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/]
@1,579,829us: [+4 T:0x4001f390] OG - package ti.sdo.ce.image1 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packag]
@1,579,911us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.jpegdec.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/p]
@1,579,997us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.jpegenc.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/p]
@1,580,153us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.mpeg4dec.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/]
@1,580,253us: [+4 T:0x4001f390] OG - package ti.sdo.codecs.mpeg4enc.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/]
@1,580,342us: [+4 T:0x4001f390] OG - package ti.sdo.ce.bioslog (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packa]
@1,580,429us: [+4 T:0x4001f390] OG - package ti.sdo.ce.utils.trace (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/p]
@1,580,514us: [+4 T:0x4001f390] OG - package dvtb_dm6467 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/dvtb_4_20_10/packages/ti/sdo/dvtb/d]
@1,581,034us: [+0 T:0x4001f390] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@1,581,167us: [+0 T:0x4001f390] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x148178]
@1,914,829us: [+0 T:0x4001f390] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@1,914,933us: [+0 T:0x4001f390] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x148190]
@1,915,027us: [+0 T:0x4001f390] OT - Thread_create> Enter (fxn=0x8f3f4, attrs=0x0)
@1,915,507us: [+0 T:0x4001f390] OT - Thread_create> Exit (task=0x1481c8)
@1,915,741us: [+0 T:0x4001f390] ti.sdo.ce.alg - ALG_init> Enter
@1,915,838us: [+0 T:0x4001f390] ti.sdo.ce.alg - ALG_init> Exit
@1,916,000us: [+6 T:0x4001f390] CE - Engine_init> CE debugging on (CE_DEBUG=2; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
@1,916,195us: [+0 T:0x4001f390] CS - Server_init()
@1,916,284us: [+0 T:0x4001f390] CS - Server_init> Global_useLinkArbiter = 0
@1,921,208us: [+1 T:0x40b47490] OP - daemon> thread created.
@1,922,534us: [+0 T:0x40b47490] OP - getCmd_d> Enter (proc=0x40b46dd8)
@1,922,628us: [+0 T:0x40b47490] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x148178] timeout[0xffffffff]
<DVTB> $ setp engine name encodedecode
PASS: setp
<DVTB> $ maxFrameRate 30000
func h264fhdenc1setp h264fhdenc1 codec h264fhdvenc
PASS: setp
<DVTB> $ setp h264fhdenc1 encodingPreset 0
PASS: setp
<DVTB> $ setp h264fhdenc1 rateControlPreset 2
PASS: setp
<DVTB> $ setp h264fhdenc1 maxHeight 1088
PASS: setp
<DVTB> $ setp h264fhdenc1 maxWidth 1920
PASS: setp
<DVTB> $ setp h264fhdenc1 maxFrameRate 30000
PASS: setp
<DVTB> $ setp h264fhdenc1 maxBitRate 10000000
PASS: setp
<DVTB> $ setp h264fhdenc1 dataEndianness 3
PASS: setp
<DVTB> $ setp h264fhdenc1 maxInterFrameInterval 0
PASS: setp
<DVTB> $ setp h264fhdenc1 inputChromaFormat 9
PASS: setp
<DVTB> $ setp h264fhdenc1 inputContentType 0
PASS: setp
<DVTB> $ setp h264fhdenc1 reconChromaFormat -1
PASS: setp
<DVTB> $ setp h264fhdenc1 profileIdc 66
PASS: setp
<DVTB> $ setp h264fhdenc1 levelIdc 40
PASS: setp
<DVTB> $ setp h264fhdenc1 EntropyCodingMode 0
PASS: setp
<DVTB> $ setp h264fhdenc1 inputHeight 1088
PASS: setp
<DVTB> $ setp h264fhdenc1 inputWidth 1920
PASS: setp
<DVTB> $ setp h264fhdenc1 refFrameRate 30000
PASS: setp
<DVTB> $ setp h264fhdenc1 targetFrameRate 30000
PASS: setp
<DVTB> $ setp h264fhdenc1 targetBitRate 10000000
PASS: setp
<DVTB> $ setp h264fhdenc1 intraFrameInterval 30
PASS: setp
<DVTB> $ setp h264fhdenc1 generateHeader 0
PASS: setp
<DVTB> $ setp h264fhdenc1 captureWidth 0
PASS: setp
<DVTB> $ setp h264fhdenc1 forceFrame -1
PASS: setp
<DVTB> $ setp h264fhdenc1 interFrameInterval 0
PASS: setp
<DVTB> $ setp h264fhdenc1 mbDataFlag 0
PASS: setp
<DVTB> $ setp h264fhdenc1 sliceCodingPreset 0
PASS: setp
<DVTB> $ setp h264fhdenc1 sliceMode 2
PASS: setp
<DVTB> $ setp h264fhdenc1 sliceUnitSize 1500
PASS: setp
<DVTB> $ setp h264fhdenc1 sliceStartOffset[0] 0
PASS: setp
<DVTB> $ setp h264fhdenc1 sliceStartOffset[1] 0
PASS: setp
<DVTB> $ setp h264fhdenc1 sliceStartOffset[2] 0
PASS: setp
<DVTB> $ setp h264fhdenc1 sliceStartOffset[3] 0
PASS: setp
<DVTB> $ setp h264fhdenc1 streamFormat 0
PASS: setp
<DVTB> $ setp h264fhdenc1 OutBufSize -1
PASS: setp
<DVTB> $ setp h264fhdenc1 QPISlice 28
PASS: setp
<DVTB> $ setp h264fhdenc1 QPSlice 28
PASS: setp
<DVTB> $ setp h264fhdenc1 RateCtrlQpMax 51
PASS: setp
<DVTB> $ setp h264fhdenc1 RateCtrlQpMin 0
PASS: setp
<DVTB> $ setp h264fhdenc1 NumRowsInSlice 0
PASS: setp
<DVTB> $ setp h264fhdenc1 LfDisableIdc 0
PASS: setp
<DVTB> $ setp h264fhdenc1 LFAlphaC0Offset 0
PASS: setp
<DVTB> $ setp h264fhdenc1 LFBetaOffset 0
PASS: setp
<DVTB> $ setp h264fhdenc1 ChromaQPOffset 0
PASS: setp
<DVTB> $ setp h264fhdenc1 SecChromaQPOffset 0
PASS: setp
<DVTB> $ setp h264fhdenc1 PicAFFFlag 0
PASS: setp
<DVTB> $ setp h264fhdenc1 PicOrderCountType 0
PASS: setp
<DVTB> $ setp h264fhdenc1 AdaptiveMBs 0
PASS: setp
<DVTB> $ setp h264fhdenc1 SEIParametersFlag 0
PASS: setp
<DVTB> $ setp h264fhdenc1 VUIParametersFlag 0
PASS: setp
<DVTB> $ setp h264fhdenc1 SkipStartCodesInCallback 1
PASS: setp
<DVTB> $ setp h264fhdenc1 Intra4x4EnableFlag 3
PASS: setp
<DVTB> $ setp h264fhdenc1 BlockingCallFlag 0
PASS: setp
<DVTB> $ setp h264fhdenc1 MESelect 1
PASS: setp
<DVTB> $ setp h264fhdenc1 ME1080iMode 0
PASS: setp
<DVTB> $ setp h264fhdenc1 MVDataFlag 0
PASS: setp
<DVTB> $ setp h264fhdenc1 Transform8x8DisableFlag 1
PASS: setp
<DVTB> $ setp h264fhdenc1 Intra8x8EnableFlag 0
PASS: setp
<DVTB> $ setp h264fhdenc1 InterlaceReferenceMode 1
PASS: setp
<DVTB> $ setp h264fhdenc1 ChromaConversionMode 1
PASS: setp
<DVTB> $ setp h264fhdenc1 maxDelay 1000
PASS: setp
<DVTB> $ setp h264fhdenc1 MaxSlicesSupported 90
PASS: setp
<DVTB> $ setp h264fhdenc1 framePitch 1920
PASS: setp
<DVTB> $ setp h264fhdenc1 numFrames 2
PASS: setp
<DVTB> $ func h264fhdenc1 -s /opt/vStream/frame.yuv -t out.264
[DVTB-LOG]: linux/dvtbFuncDispatcher.c: Starting Thread for command <h264fhdenc1>
[DVTB-LOG]: ../core/linux/dvtbUtils.c: H264FHD [File Read]+[encode] usecase started
@43,934,139us: [+0 T:0x41347490] CE - Engine_open> Enter('encodedecode', 0x0, 0x41346cb4)
@43,934,265us: [+0 T:0x41347490] CE - rserverOpen('cs.x64P'), count = 0
@43,934,354us: [+0 T:0x41347490] OP - Processor_create> Enter(imageName='cs.x64P', linkCfg='(null)', attrs=0x41346c58)
[DVTB-DEBUG]: linux/dvtbFuncDispatcher.c: Returning 2
@43,934,991us: [+0 T:0x41347490] OP - doCmd> Enter (cmdId=1, proc=0x159570)
@43,935,210us: [+0 T:0x41347490] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x148178]
@43,935,341us: [+0 T:0x41347490] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x148178]
@43,935,437us: [+0 T:0x41347490] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x148190] timeout[0xffffffff]
PNDG: func
<DVTB> $ @43,935,841us: [+0 T:0x40b47490] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x148178] status[0]
@43,935,959us: [+0 T:0x40b47490] OP - getCmd_d> Exit (result=1)
@43,936,045us: [+0 T:0x40b47490] OP - Processor_create_d> Enter(proc=0x159570)
@43,936,127us: [+2 T:0x40b47490] OP - Processor_create_d> Initializing DSP PROC...
@43,936,210us: [+2 T:0x40b47490] OP - Processor_create_d> Using DspLink config data for entry #0 [server 'cs.x64P']
@43,936,312us: [+2 T:0x40b47490] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0x8fb00000, sizeInByt0
@43,936,417us: [+2 T:0x40b47490] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x8ff00080, siz0
@43,936,518us: [+2 T:0x40b47490] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESET_VECTOR', startAddress=0x8ff00000, s0
@43,936,618us: [+2 T:0x40b47490] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='DDRALGHEAP', startAddress=0x8ba00000, siz0
@43,936,714us: [+2 T:0x40b47490] OP - Processor_create_d> DODSPCTRL was=1; now=0
@43,936,863us: [+3 T:0x40b47490] OP - LINKCFG_Object generated for PROC_setup(0x10157c) ...
@43,936,970us: [+3 T:0x40b47490] OP - linkCfg->gppObject->
@43,937,049us: [+3 T:0x40b47490] OP - name = "ARM9"
@43,937,127us: [+3 T:0x40b47490] OP - maxMsgqs = 0x82
@43,937,200us: [+3 T:0x40b47490] OP - maxChnlQueue = 0x10
@43,937,272us: [+3 T:0x40b47490] OP - poolTableId = 0xffffffff
@43,937,346us: [+3 T:0x40b47490] OP - numPools = 0x0
@43,937,419us: [+3 T:0x40b47490] OP -
@43,937,486us: [+3 T:0x40b47490] OP - linkCfg->dspConfigs[0]->dspObject->
@43,937,560us: [+3 T:0x40b47490] OP - name = "DM6467GEM"
@43,937,633us: [+3 T:0x40b47490] OP - dspArch = 0x2
@43,937,703us: [+3 T:0x40b47490] OP - loaderName = "COFF"
@43,937,774us: [+3 T:0x40b47490] OP - autoStart = FALSE
@43,937,846us: [+3 T:0x40b47490] OP - execName = "DEFAULT.OUT"
@43,937,918us: [+3 T:0x40b47490] OP - doDspCtrl = DSP_BootMode_Boot_NoPwr
@43,937,994us: [+3 T:0x40b47490] OP - resumeAddr = 0x8ff00020
@43,938,068us: [+3 T:0x40b47490] OP - resetVector = 0x8ff00000
@43,938,143us: [+3 T:0x40b47490] OP - resetCodeSize = 0x80
@43,938,218us: [+3 T:0x40b47490] OP - maduSize = 0x1
@43,938,290us: [+3 T:0x40b47490] OP - cpuFreq = 0x91050
@43,938,363us: [+3 T:0x40b47490] OP - endian = 0x3
@43,938,435us: [+3 T:0x40b47490] OP - wordSwap = 0x0
@43,938,505us: [+3 T:0x40b47490] OP - memTableId = 0x0
@43,938,577us: [+3 T:0x40b47490] OP - memEntries = 0x4
@43,938,648us: [+3 T:0x40b47490] OP - linkDrvId = 0x0
@43,938,719us: [+3 T:0x40b47490] OP - arg1 = 0xffffffff
@43,938,791us: [+3 T:0x40b47490] OP - arg2 = 0xffffffff
@43,938,862us: [+3 T:0x40b47490] OP - arg3 = 0x0
@43,938,935us: [+3 T:0x40b47490] OP - arg4 = 0x0
@43,939,006us: [+3 T:0x40b47490] OP - arg5 = 0xffffffff
@43,939,078us: [+3 T:0x40b47490] OP -
@43,939,148us: [+3 T:0x40b47490] OP - linkCfg->dspConfigs[0]->linkDrvObjects->
@43,939,222us: [+3 T:0x40b47490] OP - name = "SHMDRV"
@43,939,295us: [+3 T:0x40b47490] OP - hshkPollCount = 0x5f5e100
@43,939,369us: [+3 T:0x40b47490] OP - memEntry = 0x1
@44,272,885us: [+3 T:0x40b47490] OP - ipsTableId = 0x0
@44,272,982us: [+3 T:0x40b47490] OP - numIpsEntries = 0x1
@44,273,061us: [+3 T:0x40b47490] OP - poolTableId = 0x0
@44,273,137us: [+3 T:0x40b47490] OP - numPools = 0x1
@44,273,211us: [+3 T:0x40b47490] OP - dataTableId = 0x0
@44,273,283us: [+3 T:0x40b47490] OP - numDataDrivers = 0x1
@44,273,357us: [+3 T:0x40b47490] OP - mqtId = 0x0
@44,273,430us: [+3 T:0x40b47490] OP - ringIoTableId = 0x0
@44,273,501us: [+3 T:0x40b47490] OP - mplistTableId = 0x0
@44,273,575us: [+3 T:0x40b47490] OP - mpcsTableId = 0x0
@44,273,646us: [+3 T:0x40b47490] OP -
@44,273,713us: [+3 T:0x40b47490] OP - linkCfg->dspConfigs[0]->memTables[0][i].
@44,273,790us: [+3 T:0x40b47490] OP - entry #0:
@44,273,860us: [+3 T:0x40b47490] OP - entry = 0x0
@44,273,931us: [+3 T:0x40b47490] OP - name = "DDR2"
@44,274,003us: [+3 T:0x40b47490] OP - physAddr = 0x8fb00000
@44,274,078us: [+3 T:0x40b47490] OP - dspVirtAddr = 0x8fb00000
@44,274,155us: [+3 T:0x40b47490] OP - gppVirtAddr = 0xffffffff
@44,274,228us: [+3 T:0x40b47490] OP - size = 0x400000
@44,274,301us: [+3 T:0x40b47490] OP - shared = TRUE
@44,274,374us: [+3 T:0x40b47490] OP - syncd = FALSE
@44,274,446us: [+3 T:0x40b47490] OP - entry #1:
@44,274,517us: [+3 T:0x40b47490] OP - entry = 0x1
@44,274,589us: [+3 T:0x40b47490] OP - name = "DSPLINKMEM"
@44,274,662us: [+3 T:0x40b47490] OP - physAddr = 0x8ff00080
@44,274,736us: [+3 T:0x40b47490] OP - dspVirtAddr = 0x8ff00080
@44,274,809us: [+3 T:0x40b47490] OP - gppVirtAddr = 0xffffffff
@44,274,882us: [+3 T:0x40b47490] OP - size = 0xfff80
@44,274,954us: [+3 T:0x40b47490] OP - shared = TRUE
@44,275,026us: [+3 T:0x40b47490] OP - syncd = FALSE
@44,275,100us: [+3 T:0x40b47490] OP - entry #2:
@44,275,171us: [+3 T:0x40b47490] OP - entry = 0x2
@44,275,243us: [+3 T:0x40b47490] OP - name = "RESET_VECTOR"
@44,275,315us: [+3 T:0x40b47490] OP - physAddr = 0x8ff00000
@44,275,389us: [+3 T:0x40b47490] OP - dspVirtAddr = 0x8ff00000
@44,275,462us: [+3 T:0x40b47490] OP - gppVirtAddr = 0xffffffff
@44,275,559us: [+3 T:0x40b47490] OP - size = 0x80
@44,275,637us: [+3 T:0x40b47490] OP - shared = TRUE
@44,275,709us: [+3 T:0x40b47490] OP - syncd = FALSE
@44,275,782us: [+3 T:0x40b47490] OP - entry #3:
@44,275,854us: [+3 T:0x40b47490] OP - entry = 0x3
@44,275,928us: [+3 T:0x40b47490] OP - name = "DDRALGHEAP"
@44,276,001us: [+3 T:0x40b47490] OP - physAddr = 0x8ba00000
@44,276,077us: [+3 T:0x40b47490] OP - dspVirtAddr = 0x8ba00000
@44,276,153us: [+3 T:0x40b47490] OP - gppVirtAddr = 0xffffffff
@44,276,228us: [+3 T:0x40b47490] OP - size = 0x4100000
@44,276,300us: [+3 T:0x40b47490] OP - shared = FALSE
@44,276,373us: [+3 T:0x40b47490] OP - syncd = FALSE
@44,276,446us: [+3 T:0x40b47490] OP -
@44,276,513us: [+3 T:0x40b47490] OP - linkCfg->dspConfigs[0]->ipsTables[0][i].
@44,276,588us: [+3 T:0x40b47490] OP - entry #0:
@44,276,657us: [+3 T:0x40b47490] OP - name = "IPS"
@44,276,729us: [+3 T:0x40b47490] OP - numIpsEvents = 0x20
@44,276,803us: [+3 T:0x40b47490] OP - memEntry = 0x1
@44,276,874us: [+3 T:0x40b47490] OP - gppIntId = 0x2d
@44,276,946us: [+3 T:0x40b47490] OP - dspIntId = 0x10
@44,277,017us: [+3 T:0x40b47490] OP - dspIntVectorId = 0x4
@44,277,094us: [+3 T:0x40b47490] OP - arg1 = 0x2faf080
@44,277,167us: [+3 T:0x40b47490] OP - arg2 = 0x0
@44,277,239us: [+3 T:0x40b47490] OP -
@44,277,307us: [+3 T:0x40b47490] OP - linkCfg->dspConfigs[0]->poolTables[0][i].
@44,277,382us: [+3 T:0x40b47490] OP -
@44,277,449us: [+3 T:0x40b47490] OP - linkCfg->dspConfigs[0]->dataTables[0][i].
@44,277,525us: [+3 T:0x40b47490] OP - entry #0:
@44,277,595us: [+3 T:0x40b47490] OP - name = "ZCPYDATA"
@44,277,665us: [+3 T:0x40b47490] OP - baseChnlId = 0x0
@44,277,736us: [+3 T:0x40b47490] OP - numChannels = 0x10
@44,611,668us: [+3 T:0x40b47490] OP - maxBufSize = 0x4000
@44,611,766us: [+3 T:0x40b47490] OP - memEntry = 0x1
@44,611,844us: [+3 T:0x40b47490] OP - poolId = 0x0
@44,611,919us: [+3 T:0x40b47490] OP - queuePerChnl = 0x1
@44,611,993us: [+3 T:0x40b47490] OP - ipsId = 0x0
@44,612,066us: [+3 T:0x40b47490] OP - ipsEventNo = 0x2
@44,612,144us: [+3 T:0x40b47490] OP - arg1 = 0x0
@44,612,217us: [+3 T:0x40b47490] OP - arg2 = 0x0
@44,612,288us: [+3 T:0x40b47490] OP -
@44,612,497us: [+3 T:0x40b47490] OP - linkCfg->dspConfigs[0]->mqtObjects->
@44,612,626us: [+3 T:0x40b47490] OP - name = "ZCPYMQT"
@44,612,746us: [+3 T:0x40b47490] OP - memEntry = 0x1
@44,612,864us: [+3 T:0x40b47490] OP - maxMsgSize = 0xffffffff
@44,612,981us: [+3 T:0x40b47490] OP - ipsId = 0x0
@44,613,097us: [+3 T:0x40b47490] OP - ipsEventNo = 0x1
@44,613,216us: [+3 T:0x40b47490] OP - arg1 = 0x0
@44,613,331us: [+3 T:0x40b47490] OP - arg2 = 0x0
@44,613,449us: [+3 T:0x40b47490] OP -
@44,613,562us: [+3 T:0x40b47490] OP - linkCfg->dspConfigs[0]->ringIoObjects->
@44,613,683us: [+3 T:0x40b47490] OP - name = "RINGIOTABLE"
@44,613,799us: [+3 T:0x40b47490] OP - memEntry = 0x1
@44,613,916us: [+3 T:0x40b47490] OP - maxEntries = 0x40
@44,614,033us: [+3 T:0x40b47490] OP - ipsId = 0x0
@44,614,151us: [+3 T:0x40b47490] OP - ipsEventNo = 0x0
@44,614,270us: [+3 T:0x40b47490] OP -
@44,614,407us: [+3 T:0x40b47490] OP - linkCfg->dspConfigs[0]->mplistObjects->
@44,614,535us: [+3 T:0x40b47490] OP - name = "MPLISTTABLE"
@44,614,654us: [+3 T:0x40b47490] OP - memEntry = 0x1
@44,614,771us: [+3 T:0x40b47490] OP - maxEntries = 0x40
@44,614,889us: [+3 T:0x40b47490] OP - ipsId = 0xffffffff
@44,615,007us: [+3 T:0x40b47490] OP - ipsEventNo = 0xffffffff
@44,615,126us: [+3 T:0x40b47490] OP -
@44,615,239us: [+3 T:0x40b47490] OP - linkCfg->dspConfigs[0]->mpcsObjects->
@44,615,361us: [+3 T:0x40b47490] OP - name = "MPCS"
@44,615,476us: [+3 T:0x40b47490] OP - memEntry = 0x1
@44,615,594us: [+3 T:0x40b47490] OP - maxEntries = 0x100
@44,615,712us: [+3 T:0x40b47490] OP - ipsId = 0xffffffff
@44,615,831us: [+3 T:0x40b47490] OP - ipsEventNo = 0xffffffff
@44,618,542us: [+2 T:0x40b47490] OP - Processor_create_d> Attaching to DSP PROC...
@44,624,589us: [+2 T:0x40b47490] OP - Processor_create_d> Opening MSGQ pool...
@44,625,222us: [+2 T:0x40b47490] OP - Processor_create_d> Loading cs.x64P on DSP (1 args)...
@45,256,787us: [+2 T:0x40b47490] OP - Processor_create_d> Starting DSP PROC...
@45,299,784us: [+2 T:0x40b47490] OP - Processor_create_d> Opening remote transport...
@45,300,982us: [+2 T:0x40b47490] OP - Processor_create_d> return (1)
@45,301,094us: [+0 T:0x40b47490] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x148190]
@45,301,227us: [+0 T:0x41347490] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x148190] status[0]
@45,301,328us: [+0 T:0x41347490] OP - doCmd> Exit (result=1)
@45,301,408us: [+0 T:0x41347490] OP - Processor_create> return (0x159570)
@45,301,485us: [+0 T:0x41347490] CE - rserverOpen('cs.x64P'): 0x101dc8 done.
@45,303,147us: [+0 T:0x41347490] CE - checkServer(0x159540)
@45,303,489us: [+0 T:0x41347490] CE - rmsInit> RMS initialized(0x159540); CE_DEBUG on, setting DSP trace mask to *+01234567,CR=67,ti.sdo.fc.dman3-2,ti3
@45,303,617us: [+0 T:0x41347490] CE - Engine_setTrace> Enter(engine=0x159540, mask='*+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=123)
@45,303,730us: [+1 T:0x41347490] CE - Engine_setTrace> Requesting DSP set trace ...
@45,303,922us: [+0 T:0x40b47490] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x148190]
@45,304,030us: [+0 T:0x40b47490] OP - getCmd_d> Enter (proc=0x40b46dd8)
@45,304,116us: [+0 T:0x40b47490] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x148178] timeout[0xffffffff]
@45,305,494us: [+0 T:0x41347490] CE - Engine_setTrace> return(0)
[DSP] @0x000001a1:[T:0x00000000] codec_unitserver - main> Welcome to CS2DM6467 1.00.00.10 DSP server's main().
[DSP] @0,017,500tk: [+0 T:0x8ba0006c] OG - Global_setSpecialTrace> enter(mask='*+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_)
[DSP] @0,017,586tk: [+4 T:0x8ba0006c] OG - Global_setSpecialTrace> This program was built with the following packages:
[DSP] @0,017,638tk: [+4 T:0x8ba0006c] OG - package ti.targets.rts6000 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/xdctools_3_16_01_27/pa]
[DSP] @0,017,718tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.aachedec (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_]
[DSP] @0,017,798tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.g711dec (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_1]
[DSP] @0,017,878tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.g711enc (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_1]
[DSP] @0,017,959tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.h2641080p60vdec (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1]
[DSP] @0,018,044tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.h264dec (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_1]
[DSP] @0,018,124tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.h264enc (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_1]
[DSP] @0,018,204tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.h264fhdvenc (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_]
[DSP] @0,018,287tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.mpeg2dec (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_]
[DSP] @0,018,368tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.jpegdec (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_1]
[DSP] @0,018,448tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.jpegenc (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_1]
[DSP] @0,018,528tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.mpeg4dec (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_]
[DSP] @0,018,608tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.mpeg4enc (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_]
[DSP] @0,018,689tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.hdvicp (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10]
[DSP] @0,018,769tk: [+4 T:0x8ba0006c] OG - package ti.xdais (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/xdais_6_25_02_11/packages/ti/xda]
[DSP] @0,018,838tk: [+4 T:0x8ba0006c] OG - package ti.sdo.fc.global (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_components_2_2]
[DSP] @0,018,919tk: [+4 T:0x8ba0006c] OG - package ti.rtdx (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/rtdx/]
[DSP] @0,018,988tk: [+4 T:0x8ba0006c] OG - package ti.psl (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/psl/) ]
[DSP] @0,019,056tk: [+4 T:0x8ba0006c] OG - package ti.pmi (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/pmi/) ]
[DSP] @0,019,124tk: [+4 T:0x8ba0006c] OG - package ti.pscl (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/pscl/]
[DSP] @0,019,193tk: [+4 T:0x8ba0006c] OG - package ti.bios (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/bios/]
[DSP] @0,019,262tk: [+4 T:0x8ba0006c] OG - package ti.sdo.fc.ires (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_components_2_25_]
[DSP] @0,019,341tk: [+4 T:0x8ba0006c] OG - package ti.sdo.fc.ires.hdvicp (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_component]
[DSP] @0,019,424tk: [+4 T:0x8ba0006c] OG - package ti.sdo.fc.hdintc (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_components_2_2]
[DSP] @0,019,505tk: [+4 T:0x8ba0006c] OG - package ti.sdo.edma3.rm (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/edma3_lld_01_11_00_03/pac]
[DSP] @0,019,582tk: [+4 T:0x8ba0006c] OG - package ti.sdo.fc.ires.nullresource (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_com]
[DSP] @0,019,670tk: [+4 T:0x8ba0006c] OG - package ti.sdo.utils.trace (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_components_2]
[DSP] @0,019,752tk: [+4 T:0x8ba0006c] OG - package ti.sdo.fc.dskt2 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_components_2_25]
[DSP] @0,019,831tk: [+4 T:0x8ba0006c] OG - package ti.sdo.fc.rman (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_components_2_25_]
[DSP] @0,019,911tk: [+4 T:0x8ba0006c] OG - package ti.sdo.fc.edma3 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_components_2_25]
[DSP] @0,019,990tk: [+4 T:0x8ba0006c] OG - package ti.sdo.fc.ires.edma3chan (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_compon]
[DSP] @0,020,076tk: [+4 T:0x8ba0006c] OG - package ti.sdo.ce.global (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/]
[DSP] @0,020,154tk: [+4 T:0x8ba0006c] OG - package ti.xdais.dm (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/xdais_6_25_02_11/packages/ti/]
[DSP] @0,020,225tk: [+4 T:0x8ba0006c] OG - package ti.sdo.ce.utils.xdm (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_]
[DSP] @0,020,304tk: [+4 T:0x8ba0006c] OG - package ti.sdo.ce.node (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/pa]
[DSP] @0,020,380tk: [+4 T:0x8ba0006c] OG - package ti.sdo.ce.ipc.dsplink.dsp (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_]
[DSP] @0,020,464tk: [+4 T:0x8ba0006c] OG - package ti.sdo.fc.dman3 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_components_2_25]
[DSP] @0,020,543tk: [+4 T:0x8ba0006c] OG - package ti.sdo.fc.memutils (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_components_2]
[DSP] @0,020,625tk: [+4 T:0x8ba0006c] OG - package ti.sdo.fc.acpy3 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/framework_components_2_25]
[DSP] @0,020,705tk: [+4 T:0x8ba0006c] OG - package dsplink.dsp (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/dsplink_linux_1_64/dsplink/ds]
[DSP] @0,020,773tk: [+4 T:0x8ba0006c] OG - package ti.bios.utils (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/biosutils_1_02_02/packages/]
[DSP] @0,020,848tk: [+4 T:0x8ba0006c] OG - package ti.catalog.c6000 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/xdctools_3_16_01_27/pack]
[DSP] @0,020,925tk: [+4 T:0x8ba0006c] OG - package ti.catalog (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/t]
[DSP] @0,020,996tk: [+4 T:0x8ba0006c] OG - package ti.platforms.evmDM6467 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/xdctools_3_16_01_2]
[DSP] @0,021,077tk: [+4 T:0x8ba0006c] OG - package ti.sdo.ce.osal (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/pa]
[DSP] @0,021,154tk: [+4 T:0x8ba0006c] OG - package ti.sdo.ce.osal.bios (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_]
[DSP] @0,021,233tk: [+4 T:0x8ba0006c] OG - package ti.sdo.ce.ipc (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/pac]
[DSP] @0,021,308tk: [+4 T:0x8ba0006c] OG - package ti.sdo.ce.ipc.bios (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_1]
[DSP] @0,021,387tk: [+4 T:0x8ba0006c] OG - package ti.sdo.ce.alg (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/pac]
[DSP] @0,021,463tk: [+4 T:0x8ba0006c] OG - package ti.sdo.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/package]
[DSP] @0,021,535tk: [+4 T:0x8ba0006c] OG - package ti.sdo.ce.bioslog (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16]
[DSP] @0,021,613tk: [+4 T:0x8ba0006c] OG - package ti.sdo.ce.audio1 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/]
[DSP] @0,021,690tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.aachedec.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_]
[DSP] @0,021,773tk: [+4 T:0x8ba0006c] OG - package ti.sdo.ce.speech1 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16]
[DSP] @0,021,851tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.g711dec.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_0]
[DSP] @0,021,933tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.g711enc.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_0]
[DSP] @0,022,015tk: [+4 T:0x8ba0006c] OG - package ti.sdo.ce.video2 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/]
[DSP] @0,022,092tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.h2641080p60vdec.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm646]
[DSP] @0,022,180tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.h264dec.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_0]
[DSP] @0,022,262tk: [+4 T:0x8ba0006c] OG - package ti.sdo.ce.video1 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/]
[DSP] @0,022,339tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.h264enc.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_0]
[DSP] @0,022,422tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.h264fhdvenc.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_]
[DSP] @0,022,506tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.mpeg2dec.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_]
[DSP] @0,022,589tk: [+4 T:0x8ba0006c] OG - package ti.sdo.ce.image1 (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/codec_engine_2_25_05_16/]
[DSP] @0,022,667tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.jpegdec.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_0]
[DSP] @0,022,749tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.jpegenc.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_0]
[DSP] @0,022,831tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.mpeg4dec.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_]
[DSP] @0,022,914tk: [+4 T:0x8ba0006c] OG - package ti.sdo.codecs.mpeg4enc.ce (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_]
[DSP] @0,022,997tk: [+4 T:0x8ba0006c] OG - package ti.sdo.server.cs (/sim/scratch_a0868396/arago-install/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/pac]
[DSP] @0,023,073tk: [+0 T:0x8ba0006c] OG - Global_setSpecialTrace> return
@46,324,462us: [+0 T:0x41347490] CE - Engine_fwriteTrace> returning count [13697]
@46,324,582us: [+0 T:0x41347490] CE - Engine_open> return(1414464)
[DVTB-LOG]: ../core/linux/dvtbEngine.c: Engine <encodedecode> opened.
[DVTB-DEBUG]: ../core/linux/dvtbEngine.c: Engine Handle 159540
[DVTB-DEBUG]: linux/dvtbH264fhdEnc1.c:
<======== H264FHD Encoder Params Debug Start ==========>
[DVTB-DEBUG]: linux/dvtbH264fhdEnc1.c: Encoding Preset : 0
[DVTB-DEBUG]: linux/dvtbH264fhdEnc1.c: Rate Ctrl Preset : 2
[DVTB-DEBUG]: linux/dvtbH264fhdEnc1.c: Max Height : 1088
[DVTB-DEBUG]: linux/dvtbH264fhdEnc1.c: Max Width : 1920
[DVTB-DEBUG]: linux/dvtbH264fhdEnc1.c: Max Frame Rate : 30000
[DVTB-DEBUG]: linux/dvtbH264fhdEnc1.c: Max Bit Rate : 10000000
[DVTB-DEBUG]: linux/dvtbH264fhdEnc1.c: Endianness : 3
[DVTB-DEBUG]: linux/dvtbH264fhdEnc1.c: Max Inter Frame : 0
[DVTB-DEBUG]: linux/dvtbH264fhdEnc1.c: Input Chroma Fmt : 9
[DVTB-DEBUG]: linux/dvtbH264fhdEnc1.c: Input Content : 0
[DVTB-DEBUG]: linux/dvtbH264fhdEnc1.c: profileIdc : 66
[DVTB-DEBUG]: linux/dvtbH264fhdEnc1.c: levelIdc : 40
[DVTB-DEBUG]: linux/dvtbH264fhdEnc1.c: EntropyCodingMode : 0
<======== H264FHD Encoder Params Debug End ============>
@46,661,067us: [+0 T:0x41347490] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> Enter (engine=0x159540, name='h264fhdvenc', params=0x1049dc)
@46,661,199us: [+0 T:0x41347490] CV - VISA_create(0x159540, 'h264fhdvenc', 0x1049dc, 0x520, 'ti.sdo.ce.video1.IVIDENC1')
@46,661,300us: [+0 T:0x41347490] CV - VISA_create2(0x159540, 'h264fhdvenc', 0x1049dc, 0x3c, 0x520, 'ti.sdo.ce.video1.IVIDENC1')
@46,661,449us: [+0 T:0x41347490] CE - Engine_createNode(0x159540, 'h264fhdvenc', 520, 0x1049dc, 0x3c, 0x41346c08)
@46,661,554us: [+0 T:0x41347490] CE - Engine> allocNode Enter(engine=0x159540, impId='h264fhdvenc')
@46,661,664us: [+0 T:0x41347490] CE - Engine> allocNode(). Calling (Comm_create(gppfromnode_1621_1, 0x159848, NULL)
@46,691,694us: [+4 T:0x41347490] CE - Engine_createNode> created node(stdIn=0x2, stdOut=0x10001, msgq=0x159868, algName='h264fhdvenc', rmsNode=0x8fc66)
[DSP] @5,273,063tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0x18)
[DSP] @5,273,106tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc66d00)
[DSP] @5,273,150tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0xe)
[DSP] @5,273,186tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc66d18)
[DSP] @5,273,235tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0x20)
[DSP] @5,273,273tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc66d28)
[DSP] @5,273,316tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0x24)
[DSP] @5,273,353tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc66d48)
[DSP] @5,273,418tk: [+0 T:0x8ba0006c] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> Enter (engine=0x0, name='h264fhdvenc', params=0x8ff03940)
[DSP] @5,273,489tk: [+0 T:0x8ba0006c] CV - VISA_create(0x0, 'h264fhdvenc', 0x8ff03940, 0x520, 'ti.sdo.ce.video1.IVIDENC1')
[DSP] @5,273,554tk: [+0 T:0x8ba0006c] CV - VISA_create2(0x0, 'h264fhdvenc', 0x8ff03940, 0x3c, 0x520, 'ti.sdo.ce.video1.IVIDENC1')
[DSP] @5,273,629tk: [+0 T:0x8ba0006c] CE - Engine_open> Enter('local', 0x8ba03d4c, 0x8ff03940)
[DSP] @5,273,680tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0x2c)
[DSP] @5,273,723tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc66db8)
[DSP] @5,273,770tk: [+0 T:0x8ba0006c] CE - Engine_open> return(-1882821192)
[DSP] @5,273,827tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0x34)
[DSP] @5,273,865tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc66de8)
[DSP] @5,273,909tk: [+0 T:0x8ba0006c] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0x8fb86bb4, idma3Fxns=0x0, iresFxns=0x8fb86b0c, params=0x)
[DSP] @5,273,997tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0x10)
[DSP] @5,274,034tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc66e20)
[DSP] @5,380,736tk: [+0 T:0x8ba0006c] ti.sdo.ce.osal.Sem - Sem_create> count 1
[DSP] @5,380,786tk: [+0 T:0x8ba0006c] ti.sdo.ce.osal.Sem - Sem_create> sem: 0x8c23fdb4
[DSP] @5,380,879tk: [+0 T:0x8ba0006c] ti.sdo.ce.osal.Sem - Sem_create> count 1
[DSP] @5,380,918tk: [+0 T:0x8ba0006c] ti.sdo.ce.osal.Sem - Sem_create> sem: 0x8c23fde4
[DSP] @5,382,865tk: [+0 T:0x8ba0006c] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x8fc66e20)
[DSP] @5,382,926tk: [+5 T:0x8ba0006c] CV - VISA_create> local codec created (name='h264fhdvenc', handle=0x8fc66e20)
[DSP] @5,382,986tk: [+0 T:0x8ba0006c] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> return (0x8fc66de8)
[DSP] @5,383,040tk: [+4 T:0x8ba0006c] OT - Thread_create > name: "h264fhdvenc#0", pri: -1, stack size: 20480, stack seg: 0
@46,694,539us: [+0 T:0x41347490] CE - Engine_fwriteTrace> returning count [2573]
@47,030,094us: [+2 T:0x41347490] CE - Engine_createNode> Returning 0x159840
@47,030,215us: [+5 T:0x41347490] CV - VISA_create> remote codec created (name='h264fhdvenc', localQueueID=0x10001, remoteQueueID=0x0002)
@47,030,319us: [+0 T:0x41347490] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> return (0x1597f8)
@47,030,450us: [+0 T:0x41347490] ti.sdo.ce.video1.VIDENC1 - VIDENC1_control> Enter (handle=0x1597f8, id=1, dynParams=0x104a18 (size=0x84), status=0x10)
@47,030,577us: [+4 T:0x41347490] CV - VISA_getMaxMsgSize(0x1597f8): returning 0x2000
@47,030,667us: [+5 T:0x41347490] CV - VISA_allocMsg> Allocating message for messageId=0x00020001
@47,030,754us: [+0 T:0x41347490] CV - VISA_call(visa=0x1597f8, msg=0x41b56900): messageId=0x00020001, command=0x1
[DSP] @6,696,233tk: [+5 T:0x8c23fa44] CN - NODE> 0x8fc66d28(h264fhdvenc#0) call(algHandle=0x8fc66de8, msg=0x8ff05900); messageId=0x00020001
[DSP] @6,696,319tk: [+0 T:0x8c23fa44] ti.sdo.ce.video1.VIDENC1 - VIDENC1_control> Enter (handle=0x8fc66de8, id=1, dynParams=0x8ff05934 (size=0x84), st)
[DSP] @6,696,416tk: [+5 T:0x8c23fa44] CV - VISA_enter(visa=0x8fc66de8): algHandle = 0x8fc66e20
[DSP] @6,696,467tk: [+0 T:0x8c23fa44] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x8fc66e20)
[DSP] @6,696,602tk: [+0 T:0x8c23fa44] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Exit
[DSP] @6,696,737tk: [+5 T:0x8c23fa44] CV - VISA_exit(visa=0x8fc66de8): algHandle = 0x8fc66e20
[DSP] @6,696,789tk: [+0 T:0x8c23fa44] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x8fc66e20)
[DSP] @6,696,841tk: [+0 T:0x8c23fa44] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Exit
[DSP] @6,696,887tk: [+0 T:0x8c23fa44] ti.sdo.ce.video1.VIDENC1 - VIDENC1_control> Exit (handle=0x8fc66de8, retVal=0x0)
[DSP] @6,696,947tk: [+5 T:0x8c23fa44] CN - NODE> returned from call(algHandle=0x8fc66de8, msg=0x8ff05900); messageId=0x00020001
@47,032,551us: [+0 T:0x41347490] CE - Engine_fwriteTrace> returning count [1148]
@47,032,649us: [+0 T:0x41347490] CV - VISA_call Completed: messageId=0x00020001, command=0x1, return(status=0)
@47,032,747us: [+5 T:0x41347490] CV - VISA_freeMsg(0x1597f8, 0x41b56900): Freeing message with messageId=0x00020001
@47,032,863us: [+0 T:0x41347490] ti.sdo.ce.video1.VIDENC1 - VIDENC1_control> Exit (handle=0x1597f8, retVal=0x0)
@47,032,954us: [+0 T:0x41347490] ti.sdo.ce.video1.VIDENC1 - VIDENC1_control> Enter (handle=0x1597f8, id=5, dynParams=0x104a18 (size=0x84), status=0x10)
@47,033,056us: [+4 T:0x41347490] CV - VISA_getMaxMsgSize(0x1597f8): returning 0x2000
@47,033,141us: [+5 T:0x41347490] CV - VISA_allocMsg> Allocating message for messageId=0x00020002
@47,033,230us: [+0 T:0x41347490] CV - VISA_call(visa=0x1597f8, msg=0x41b56900): messageId=0x00020002, command=0x1
[DSP] @6,705,799tk: [+5 T:0x8c23fa44] CN - NODE> 0x8fc66d28(h264fhdvenc#0) call(algHandle=0x8fc66de8, msg=0x8ff05900); messageId=0x00020002
[DSP] @6,705,876tk: [+0 T:0x8c23fa44] ti.sdo.ce.video1.VIDENC1 - VIDENC1_control> Enter (handle=0x8fc66de8, id=5, dynParams=0x8ff05934 (size=0x84), st)
[DSP] @6,705,964tk: [+5 T:0x8c23fa44] CV - VISA_enter(visa=0x8fc66de8): algHandle = 0x8fc66e20
[DSP] @6,706,015tk: [+0 T:0x8c23fa44] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x8fc66e20)
[DSP] @6,706,068tk: [+0 T:0x8c23fa44] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Exit
[DSP] @6,706,112tk: [+5 T:0x8c23fa44] CV - VISA_exit(visa=0x8fc66de8): algHandle = 0x8fc66e20
[DSP] @6,706,163tk: [+0 T:0x8c23fa44] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x8fc66e20)
[DSP] @6,706,215tk: [+0 T:0x8c23fa44] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Exit
[DSP] @6,706,257tk: [+0 T:0x8c23fa44] ti.sdo.ce.video1.VIDENC1 - VIDENC1_control> Exit (handle=0x8fc66de8, retVal=0x0)
[DSP] @6,706,314tk: [+5 T:0x8c23fa44] CN - NODE> returned from call(algHandle=0x8fc66de8, msg=0x8ff05900); messageId=0x00020002
@47,368,855us: [+0 T:0x41347490] CE - Engine_fwriteTrace> returning count [1148]
@47,368,961us: [+0 T:0x41347490] CV - VISA_call Completed: messageId=0x00020002, command=0x1, return(status=0)
@47,369,063us: [+5 T:0x41347490] CV - VISA_freeMsg(0x1597f8, 0x41b56900): Freeing message with messageId=0x00020002
@47,369,157us: [+0 T:0x41347490] ti.sdo.ce.video1.VIDENC1 - VIDENC1_control> Exit (handle=0x1597f8, retVal=0x0)
[DVTB-DEBUG]: linux/dvtbH264fhdEnc1.c: Video Encoder <h264fhdvenc> initialized
[DVTB-DEBUG]: linux/dvtbH264fhdEnc1.c: EntropyCodUnable to handle kernel NULL pointer dereference at virtual address 00000068
ingMode : 0
[DVTB-DEBUG]: linupgd = c2638000
<========[00000068] *pgd=82606031 H264FHD Encoder Params Debug En, *pte=00000000d ============>
@47,370,175us, *ppte=00000000: [+4 T:0x41347490] OM - Memory_
contigAlloc> CMEM_alloc(2088960)Internal error: Oops: 17 [#1] PREEMPT
Modules linked in: dsplinkk cmemk ipv6 minix
CPU: 0 Not tainted (2.6.32-rc2-davinci1 #1)
PC is at skb_put+0xc/0x6c
LR is at emac_poll+0x3e8/0x650
pc : [<c0283d28>] lr : [<c01f5150>] psr: 40000013
sp : c262d5c8 ip : c262d5e8 fp : c262d5e4
r10: c00005ea r9 : 00000001 r8 : 40000013
r7 : 00000010 r6 : c31f82e0 r5 : c31c5400 r4 : 000005ea
r3 : 00000000 r2 : c262c000 r1 : 000005ea r0 : 00000010
Flags: nZcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 0005317f Table: 82638000 DAC: 00000017
Process dvtb-d (pid: 1623, stack limit = 0xc262c270)
Stack: (0xc262d5c8 to 0xc262e000)
d5c0: 000005ea c31c5400 c31f82e0 00000010 c262d644 c262d5e8
d5e0: c01f5150 c0283d2c c03f8128 c04b3c20 00000040 c31f82ec c31f8000 c31f8210
d600: 00000001 c262c000 00000010 c31f6022 000005ea c3461f00 c262c000 c31f82ec
d620: 00000040 00000001 c262c000 00000000 0000012c c262c000 c262d67c c262d648
d640: c028c6c0 c01f4d78 60000093 ffffc76b c262d674 00000102 0000000c 00000001
d660: c262c000 00000003 0000000a c0423180 c262d6bc c262d680 c0047960 c028c620
d680: c262d6ac c262d690 c262c000 00000000 00000019 00000019 00000000 c31f8000
d6a0: 00000001 00000000 c262c000 00000040 c262d6cc c262d6c0 c0047a44 c00478d8
d6c0: c262d6e4 c262d6d0 c002c074 c0047a04 ffffffff fec48000 c262d75c c262d6e8
d6e0: c002cacc c002c010 00000000 c044b000 c262d6c0 00000000 c262c000 c3461240
d700: c31f8000 00000040 c31b5700 00000000 00000040 c262d75c c262d6c0 c262d730
d720: c0047dc8 c02af248 40000013 ffffffff c262d764 c262d740 c02ad6fc c02861c4
d740: c262d74c c3461240 c3461240 c31f2000 c262d774 c262d760 c02ae174 c02af174
d760: c31e1010 c3461240 c262d7a4 c262d778 c02ae470 c02ae158 c02ad69c 000005c8
d780: c3461240 c262d820 c31f2000 c31e1024 00000000 c31f2000 c262d7dc c262d7a8
d7a0: c02cb10c c02ae188 c02a74dc c31f2070 00000001 180110ac c262d820 310110ac
d7c0: c262d9d4 00000000 00000000 c31f2000 c262d89c c262d7e0 c02ccb28 c02cae54
d7e0: 00000008 c262d85c c262d86c 00004040 c31f2000 00000078 00000000 00000011
d800: 0000f002 00000000 310110ac 00000000 00000108 00000000 00000000 00000000
d820: 00000000 00000000 00000000 310110ac 180110ac 00000000 00000000 00000000
d840: 00000000 00000000 00000000 00000000 00000011 0108f002 00000000 310110ac
d860: 00000000 00000000 18011000 00000000 c0443654 c31f2000 00000078 c262d8c0
d880: c262d9d4 00000010 c3049c00 c262d9d4 c262d8bc c262d8a0 c02d2ea4 c02cc634
d8a0: 00000000 00000000 c262d9d4 c262d8c0 c262d9ac c262d8c0 c027d254 c02d2e58
d8c0: c02aa054 c02a9e00 00000000 00000001 ffffffff 00000000 00000000 00000000
d8e0: 00000000 00000000 c306e3c0 c02a9fd4 00000000 00000000 c03f86dc c306e3c0
d900: c00588b0 c262d904 c262d904 c31f8000 c31f8000 00000000 c262d950 c262d928
d920: c02a9db8 c02a97b4 fec83400 c31f8000 c262d95c c262d940 c003195c c3cc7540
d940: c04439e0 00000008 c262d984 c262d958 c028be9c c003acf4 fec833e0 00000078
d960: c3049c00 c262d970 00000000 c262d9d4 fec833e0 c31c5400 c262d9e4 c262d988
d980: c01f5228 c01f2d00 c028be9c c003acf4 00000017 bf000000 c3014664 c349500c
d9a0: c262d9c4 c262d9b0 c027d5cc c027d1b4 00004040 00000000 c262da24 c262d9c8
d9c0: c02f4354 c027d598 00000078 00000000 0000012c c349500c 00000010 c262d9f0
d9e0: 00000001 00000000 00000000 00004040 c349d004 00000078 c262da54 00000078
da00: 00000000 00000010 c2bc41a4 00000000 c2bc41a4 c3014664 c262da6c c262da28
da20: c02f4408 c02f42c8 00000000 00000000 c30b93e0 c3049c00 c262c000 c349d02c
da40: 00000001 c3014708 c3014660 c3495000 c2bc41a4 c3495000 c2bc41a4 c3014660
da60: c262da94 c262da70 c02f483c c02f4374 00000000 c262da80 c3014708 c30146e8
da80: c30146d4 c2bc41a4 c262dac4 c262da98 c02f2618 c02f4808 00000000 c31b5900
daa0: c3014660 c3014660 c2bc41a4 00000000 c26ce338 00001000 c262daec c262dac8
dac0: c02efc8c c02f2520 c2bc42d8 c2bc41ec c2bc41a4 c2bc41ec 00000000 00000001
dae0: c262db0c c262daf0 c02f7044 c02efa74 c2bc41a4 c262db6c c2b4d600 c262db88
db00: c262db24 c262db10 c02f72e0 c02f6fc8 c2bc41a4 c262db6c c262db3c c262db28
db20: c02f0630 c02f72b8 00000001 00000000 c262dbc4 c262db40 c01293d4 c02f05d8
db40: c262c000 c262dcf8 c262db64 c262db58 c0076e84 c0099b98 c2bc41a0 c0317c44
db60: c305bfa0 c31b5900 c2b4d7c0 c2bc41a4 c31b5900 c262db88 c0317c44 c2bc41a0
db80: c305bfa0 00000001 c0406540 c2bc42d8 c2bc4300 c3f83840 0000000f c262dc90
dba0: c2bc42c0 c2bc431c 00001000 c26ce338 0000000f c262dcf8 c262dbec c262dbc8
dbc0: c01296b0 c0129220 00000000 c262dbd8 c262dc90 c262dc90 c04a1880 00002000
dbe0: c262dc0c c262dbf0 c0126dd8 c0129604 00000000 c0169c40 c262dc2c c2b4d5c0
dc00: c262dc2c c262dc10 c0126f08 c0126d98 00001000 c2b4d5c0 c04a1880 c262dcb8
dc20: c262dc5c c262dc30 c0128eec c0126e1c 00001000 00000000 c262dc5c c04a1880
dc40: c262dcf8 c26ce3e0 c262dcb8 c0128dd4 c262dc84 c262dc60 c007d078 c0128de4
dc60: c31c6600 c26ce338 c3cb0980 00001000 c26ce3e0 0000000f c262dce4 c262dc88
dc80: c0128a14 c007d008 00000000 00000002 c262dc90 c262dc90 00007000 00001000
dca0: 00001000 00000000 c26ce338 c01295f4 00000000 00000000 c262dc90 c358ef00
dcc0: c262dcf8 0000000f 0000000f c26ce3e0 0000002d c262c000 c262dd2c c262dce8
dce0: c007cab0 c01288f0 c03fd530 c3cb0980 c26ce3e4 000035ef c04a0458 c04a18b8
dd00: c262dd24 c3cb09c0 00000001 0000000f 00000000 0000000f c26ce3e0 000001ef
dd20: c262dd44 c262dd30 c007cb94 c007c91c 0000000f c04eb3b8 c262dd84 c262dd48
dd40: c007ce8c c007cb74 c306e3c0 c262dd74 c04a2840 c3cb0980 00000007 c26ce3e0
dd60: c3cb09c0 c3cb0980 00000000 0000000f c3cb0980 00000000 c262ddac c262dd88
dd80: c007cf40 c007cc8c 0000000f 000001ef 00001000 00001000 c049f8c0 00001000
dda0: c262de3c c262ddb0 c00766c0 c007ceac 0000000f 000001ef 00000001 c262ddc8
ddc0: c019d134 c262df18 00000000 c262ded8 c262c000 000001fe c3cb09c0 c26ce338
dde0: c26ce3e0 00000000 00000000 0000000e 00000000 00000001 c262de14 0000f000
de00: 001ef000 424d4000 00000000 001fe000 c262de3c c31c6600 00000000 001fe000
de20: c262de88 c262df18 00000000 00000001 c262de7c c262de40 c011f17c c0076400
de40: 00000000 00000000 c2125f20 00000000 c3cc6180 c262de88 c3cb0980 c262df70
de60: 001fe000 001fe000 c262c000 001fe000 c262df3c c262de80 c009d0a0 c011f058
de80: 00000000 00000000 c262dec4 c262de98 00000000 00000001 ffffffff c3cb0980
dea0: 00000000 00000000 00000000 00000000 c306e3c0 00000000 00000000 00000000
dec0: c008f834 c306e3c0 c00588b0 c262decc c262decc 000429ce 00000000 00000000
dee0: 00000022 00001000 00000000 00000001 001fe000 c2125ac0 c2125ac4 c2125aa8
df00: c262df2c 429ce000 00000000 00000077 00001000 c3cc6180 424c5000 001fe000
df20: c262df74 c3cb0980 424c5000 c262df70 c262df6c c262df40 c009dcfc c009cffc
df40: c262df6c c262df50 c009e320 00000000 00000000 c3cb0980 001fe000 424c5000
df60: c262dfa4 c262df70 c009de6c c009dc54 00000000 00000000 00000022 00000001
df80: ffffffff 00000000 001591d0 001fe000 00000003 c002d044 00000000 c262dfa8
dfa0: c002cec0 c009de38 00000000 001591d0 00000006 424c5000 001fe000 00000000
dfc0: 00000000 001591d0 001fe000 00000003 001fe000 424c5000 001fe000 41347490
dfe0: 00000000 41346c40 402231f4 40208a54 60000010 00000006 00000000 00000000
Backtrace:
[<c0283d1c>] (skb_put+0x0/0x6c) from [<c01f5150>] (emac_poll+0x3e8/0x650)
r7:00000010 r6:c31f82e0 r5:c31c5400 r4:000005ea
[<c01f4d68>] (emac_poll+0x0/0x650) from [<c028c6c0>] (net_rx_action+0xb0/0x224)
[<c028c610>] (net_rx_action+0x0/0x224) from [<c0047960>] (__do_softirq+0x98/0x12c)
[<c00478c8>] (__do_softirq+0x0/0x12c) from [<c0047a44>] (irq_exit+0x50/0xa8)
[<c00479f4>] (irq_exit+0x0/0xa8) from [<c002c074>] (asm_do_IRQ+0x74/0x8c)
[<c002c000>] (asm_do_IRQ+0x0/0x8c) from [<c002cacc>] (__irq_svc+0x4c/0x90)
Exception stack(0xc262d6e8 to 0xc262d730)
d6e0: 00000000 c044b000 c262d6c0 00000000 c262c000 c3461240
r5:fec48000 r4:ffffffff
[<c02af164>] (ip_output+0x0/0xf8) from [<c02ae174>] (ip_local_out+0x2c/0x30)
r6:c31f2000 r5:c3461240 r4:c3461240
[<c02ae148>] (ip_local_out+0x0/0x30) from [<c02ae470>] (ip_push_pending_frames+0x2f8/0x394)
r5:c3461240 r4:c31e1010
[<c02ae178>] (ip_push_pending_frames+0x0/0x394) from [<c02cb10c>] (udp_push_pending_frames+0x2c8/0x3fc)
[<c02cae44>] (udp_push_pending_frames+0x0/0x3fc) from [<c02ccb28>] (udp_sendmsg+0x504/0x650)
[<c02cc624>] (udp_sendmsg+0x0/0x650) from [<c02d2ea4>] (inet_sendmsg+0x5c/0x64)
[<c02d2e48>] (inet_sendmsg+0x0/0x64) from [<c027d254>] (sock_sendmsg+0xb0/0xd0)
r7:c262d8c0 r6:c262d9d4 r5:00000000 r4:00000000
[<c027d1a4>] (sock_sendmsg+0x0/0xd0) from [<c027d5cc>] (kernel_sendmsg+0x44/0x78)
r7:c349500c r6:c3014664 r5:bf000000 r4:00000017
[<c027d588>] (kernel_sendmsg+0x0/0x78) from [<c02f4354>] (xs_send_kvec+0x9c/0xac)
r5:00000000 r4:00004040
[<c02f42b8>] (xs_send_kvec+0x0/0xac) from [<c02f4408>] (xs_sendpages+0xa4/0x21c)
[<c02f4364>] (xs_sendpages+0x0/0x21c) from [<c02f483c>] (xs_udp_send_request+0x44/0x140)
[<c02f47f8>] (xs_udp_send_request+0x0/0x140) from [<c02f2618>] (xprt_transmit+0x108/0x1fc)
r7:c2bc41a4 r6:c30146d4 r5:c30146e8 r4:c3014708
[<c02f2510>] (xprt_transmit+0x0/0x1fc) from [<c02efc8c>] (call_transmit+0x228/0x2a0)
[<c02efa64>] (call_transmit+0x0/0x2a0) from [<c02f7044>] (__rpc_execute+0x8c/0x2f0)
r7:00000001 r6:00000000 r5:c2bc41ec r4:c2bc41a4
[<c02f6fb8>] (__rpc_execute+0x0/0x2f0) from [<c02f72e0>] (rpc_execute+0x38/0x3c)
r7:c262db88 r6:c2b4d600 r5:c262db6c r4:c2bc41a4
[<c02f72a8>] (rpc_execute+0x0/0x3c) from [<c02f0630>] (rpc_run_task+0x68/0x70)
[<c02f05c8>] (rpc_run_task+0x0/0x70) from [<c01293d4>] (nfs_read_rpcsetup+0x1c4/0x1ec)
r5:00000000 r4:00000001
[<c0129210>] (nfs_read_rpcsetup+0x0/0x1ec) from [<c01296b0>] (nfs_pagein_one+0xbc/0x11c)
[<c01295f4>] (nfs_pagein_one+0x0/0x11c) from [<c0126dd8>] (nfs_pageio_doio+0x50/0x84)
r7:00002000 r6:c04a1880 r5:c262dc90 r4:c262dc90
[<c0126d88>] (nfs_pageio_doio+0x0/0x84) from [<c0126f08>] (nfs_pageio_add_request+0xfc/0x110)
r4:c2b4d5c0
[<c0126e0c>] (nfs_pageio_add_request+0x0/0x110) from [<c0128eec>] (readpage_async_filler+0x118/0x190)
r7:c262dcb8 r6:c04a1880 r5:c2b4d5c0 r4:00001000
[<c0128dd4>] (readpage_async_filler+0x0/0x190) from [<c007d078>] (read_cache_pages+0x80/0xf8)
r8:c0128dd4 r7:c262dcb8 r6:c26ce3e0 r5:c262dcf8 r4:c04a1880
[<c007cff8>] (read_cache_pages+0x0/0xf8) from [<c0128a14>] (nfs_readpages+0x134/0x1c4)
r9:0000000f r8:c26ce3e0 r7:00001000 r6:c3cb0980 r5:c26ce338
r4:c31c6600
[<c01288e0>] (nfs_readpages+0x0/0x1c4) from [<c007cab0>] (__do_page_cache_readahead+0x1a4/0x258)
[<c007c90c>] (__do_page_cache_readahead+0x0/0x258) from [<c007cb94>] (ra_submit+0x30/0x38)
[<c007cb64>] (ra_submit+0x0/0x38) from [<c007ce8c>] (ondemand_readahead+0x210/0x220)
[<c007cc7c>] (ondemand_readahead+0x0/0x220) from [<c007cf40>] (page_cache_async_readahead+0xa4/0xac)
[<c007ce9c>] (page_cache_async_readahead+0x0/0xac) from [<c00766c0>] (generic_file_aio_read+0x2d0/0x6f0)
r6:00001000 r5:c049f8c0 r4:00001000
[<c00763f0>] (generic_file_aio_read+0x0/0x6f0) from [<c011f17c>] (nfs_file_read+0x134/0x14c)
[<c011f048>] (nfs_file_read+0x0/0x14c) from [<c009d0a0>] (do_sync_read+0xb4/0x104)
[<c009cfec>] (do_sync_read+0x0/0x104) from [<c009dcfc>] (vfs_read+0xb8/0x164)
r6:c262df70 r5:424c5000 r4:c3cb0980
[<c009dc44>] (vfs_read+0x0/0x164) from [<c009de6c>] (sys_read+0x44/0x70)
r8:424c5000 r7:001fe000 r6:c3cb0980 r5:00000000 r4:00000000
[<c009de28>] (sys_read+0x0/0x70) from [<c002cec0>] (ret_fast_syscall+0x0/0x28)
r8:c002d044 r7:00000003 r6:001fe000 r5:001591d0 r4:00000000
Code: e89da830 e1a0c00d e92dd8f0 e24cb004 (e5903058)
= 0x41bc5000.
@47,370,307us: [Kernel panic - not syncing: Fatal exception in interrupt
+4 T:0x41347490] OM - Memory_conBacktrace: tigAlloc> CMEM_getPhys(0x41bc500
0) = 0x86117000.
@47,370,535us:[<c00307d0>] [+4 T:0x41347490] OM - Memory_c(dump_backtrace+0x0/0x114) ontigAlloc> CMEM_alloc(1044480) from [<c030af14>] = 0x41fba000.
@47,370,664us: [+(dump_stack+0x18/0x1c)
4 T:0x41347490] OM - Memory_cont r7:c262d580igAlloc> CMEM_getPhys(0x41fba000 r6:c306e3c0) = 0x8b6cd000.
@47,385,796us: r5:c262c000[+4 T:0x41347490] OM - Memory_co r4:c041e850ntigAlloc> CMEM_alloc(2088960) =
0x420ba000.
@47,385,928us: [+4[<c030aefc>] T:0x41347490] OM - Memory_conti(dump_stack+0x0/0x1c) gAlloc> CMEM_getPhys(0x420ba000)from [<c030af6c>] = 0x85d22000.
@47,386,113us: [(panic+0x54/0x124)
+4 T:0x41347490] OM - Memory_con[<c030af18>] tigAlloc> CMEM_alloc(4080) = 0x4(panic+0x0/0x124) 24af000.
@47,386,243us: [+4 T:0from [<c0030b74>] x41347490] OM - Memory_contigAll(die+0x170/0x19c)
oc> CMEM_getPhys(0x424af000) = 0 r3:00000100x8b662000.
@47,386,579us: [+4 T r2:c262d468:0x41347490] OM - Memory_contigA r1:c041e850lloc> CMEM_alloc(2088960) = 0x42 r0:c03970144c5000.
@47,386,713us: [+4 T:0x
41347490] OM - Memory_contigAllo[<c0030a04>] c> CMEM_getPhys(0x424c5000) = 0x(die+0x0/0x19c) 8592d000.
@47,386,911us: [+4 T:from [<c0032628>] 0x41347490] OM - Memory_contigAl(__do_kernel_fault+0x6c/0x7c)
loc> CMEM_alloc(522240) = 0x428b[<c00325bc>] a000.
@47,387,040us: [+4 T:0x41(__do_kernel_fault+0x0/0x7c) 347490] OM - Memory_contigAlloc>from [<c0032808>] CMEM_getPhys(0x428ba000) = 0x8b(do_page_fault)
5c2000.
@47,387,239us: [+4 T:0x r7:c3cc618041347490] OM - Memory_contigAllo r6:00000068c> CMEM_alloc(522240) = 0x429440 r5:c306e3c000.
@47,387,370us: [+4 T:0x4134 r4:c03fa6647490] OM - Memory_contigAlloc> C
MEM_getPhys(0x42944000) = 0x8b53[<c0032638>] 8000.
(do_page_fault+0x0/0x1e8) from [<c002c288>] (do_DataAbort+0x3c/0x9c)
[<c002c24c>] (do_DataAbort+0x0/0x9c) from [<c002ca6c>] (__dabt_svc+0x4c/0x60)
Exception stack(0xc262d580 to 0xc262d5c8)
d580: 00000010 000005ea c262c000 00000000 000005ea c31c5400 c31f82e0 00000010
d5a0: 40000013 00000001 c00005ea c262d5e4 c262d5e8 c262d5c8 c01f5150 c0283d28
d5c0: 40000013 ffffffff
r8:40000013 r7:00000010 r6:c31f82e0 r5:c262d5b4 r4:ffffffff
r4:c2b4d5c0
r4:c31c6600
CTRL-A Z for help |115200 8N1 | NOR | Minicom 2.4 | VT102 | Offline
