Tool/software: Linux
I'm newbie to use TI's tda2xx evm board with Vision SDK. I am using linux os with tda2xx_evm_linux_all config. After I added PlatformUART2SetPinMux() in Bsp_boardTda2xxInit(), I am able to send strings with uart2 by typing "echo 123 > /dev/ttyS1" in uart1 terminal. The correct waveform on uart2 tx can be seen on the oscilloscope. Then I connected uart2 rx to uart2 tx, sent a string by "echo 123 > /dev/ttyS1" , then "cat /dev/ttyS1": I got nothing. Seems nothing is recieved from uart2.
Did I miss anything to use uart2 on linux? Is there documents about my issue?
thanks very much.
Dong
