How to change the Codec Combo path with the DM6467
I'm trying to follow the WIKI below to change the Codec Combo path from the current directory to another folder.
http://wiki.davincidsp.com/index.php?title=Configuring_Codec_Engine_in_Arm_apps_with_createFromServer
I modified the app.cfg file with the new path, however when I build the application it still points to the current directory.  I get the following output, where <mypath> is the folder I want to locate the combo:
======== Building decode ========
Configuring application using decode.cfg
configuring decode.x470MV from package/cfg/decode_x470MV.cfg ...
Info: Configuring engine named 'decode' from the info file for DSP server '<mypath>/decodeCombo.x64P',
          located in package 'ti.sdo.servers.decode':
      Target app will look for the DSP server image 'decodeCombo.x64P' in its current directory.
Thanks for your help!
Chris
