Part Number: AM5728
Other Parts Discussed in Thread: MATHLIB
Tool/software: Linux
I am trying to follow the instructions (below) to build the IPC examples for the AM5728 EVM but I am running into some problems.
http://processors.wiki.ti.com/index.php/Processor_SDK_IPC_Quick_Start_Guide#Build_IPC_Linux_examples
The problem I am having is that when I go to build using
make ti-ipc-linux
I get the following output:
$ sudo make ti-ipc-linux
Error: TI_RTOS_PATH () does not contain
the corresponding Processor SDK RTOS release!
Please install Processor SDK RTOS 04.03.00.05 for am57xx-evm.
Makefile:767: recipe for target 'ti-ipc-rtos-path-check' failed
make: *** [ti-ipc-rtos-path-check] Error 1
I have tried exporting the RTOS install path as an environment variable but it continues to output the same thing.
For reference here is the directory listing for the directory I point to for the RTOS install:
├── bios_6_52_00_12
├── cg_xml
├── ctoolslib_2_2_0_0
├── dsplib_c66x_3_4_0_0
├── edma3_lld_2_12_05_30C
├── framework_components_3_40_02_07
├── gcc-arm-none-eabi-6-2017-q1-update
├── imglib_c66x_3_1_1_0
├── ipc_3_47_01_00
├── mathlib_c66x_3_1_1_0
├── ndk_2_26_00_08
├── openmp_dsp_am57xx_2_06_02_01
├── pdk_am57xx_1_0_10
├── processor_sdk_rtos_am57xx_4_03_00_05
├── ti-cgt-arm_16.9.3.LTS
├── ti-cgt-c6000_8.2.2
├── ti-cgt-pru_2.2.1
├── uia_2_21_02_07
├── xdais_7_24_00_04
└── xdctools_3_50_03_33_core
I have Linux SDK Version 04.03.00.05
and TI RTOS SDK Version 04.03.00.05
What could be the cause of this error?
