Hi, all
My project have 2 LCD output. Refer to the "chains_lvdsVipDualCam_DualDisplay" usecase I write a configuration here.
Void chains_vipMultiCamEncodeAdasDualDisplay_SetDisplayLinkPrms ( DisplayLink_CreateParams *pDpi1Prm, DisplayLink_CreateParams *pDpi2Prm, UInt32 width, UInt32 height) { pDpi1Prm->displayId = DISPLAY_LINK_INST_DSS_VID1; pDpi1Prm->displayScanFormat = SYSTEM_SF_PROGRESSIVE; pDpi1Prm->rtParams.tarWidth = width; pDpi1Prm->rtParams.tarHeight = height; pDpi2Prm->displayId = DISPLAY_LINK_INST_DSS_VID2; pDpi2Prm->displayScanFormat = SYSTEM_SF_PROGRESSIVE; pDpi2Prm->rtParams.tarWidth = width; pDpi2Prm->rtParams.tarHeight = height; } Int32 chains_vipMultiCamEncodeAdasDualDisplay_StartDisplayCtrl( chains_vipMultiCamEncodeAdasDualDisplayObj *pUcObj, Void *appObj) { Int32 status = OSA_SOK; chains_vipMultiCamEncodeAdasDualDisplayAppObj *pObj = (chains_vipMultiCamEncodeAdasDualDisplayAppObj*)appObj; DisplayCtrlLink_ConfigParams *pPrm = &pObj->dctrlCfgPrms; DisplayCtrlLink_VencInfo *pVInfo; DisplayCtrlLink_OvlyParams *pOvlyPrms; DisplayCtrlLink_OvlyPipeParams *pPipeOvlyPrms; DisplayCtrlLink_OvlyParams ovlyPrms[2]; /* Set the link id */ pObj->displayCtrlLinkId = SYSTEM_LINK_ID_DISPLAYCTRL; /* Number of valid entries in vencInfo array */ pPrm->numVencs = 2; /* Bitmask of tied vencs. Two vencs, which uses same pixel clock and whose vsync are synchronized, can be tied together. */ pPrm->tiedVencs = 0; /* Activate the HDMI BSP layer in the Dctrl link. This is not required if there is no HDMI display in use. */ pPrm->deviceId = DISPLAYCTRL_LINK_USE_LCD; /* Configure LCD */ pVInfo = &pPrm->vencInfo[0]; pVInfo->vencId = SYSTEM_DCTRL_DSS_VENC_LCD1; //pVInfo->vencOutputInfo.fidPolarity = SYSTEM_DCTRL_POLARITY_ACT_HIGH; pVInfo->vencOutputInfo.actVidPolarity = SYSTEM_DCTRL_POLARITY_ACT_HIGH; pVInfo->vencOutputInfo.pixelClkPolarity = SYSTEM_DCTRL_POLARITY_ACT_HIGH; pVInfo->vencOutputInfo.dvoFormat = SYSTEM_DCTRL_DVOFMT_BT1120_EMBSYNC; pVInfo->vencOutputInfo.vsPolarity = SYSTEM_DCTRL_POLARITY_ACT_HIGH; pVInfo->vencOutputInfo.hsPolarity = SYSTEM_DCTRL_POLARITY_ACT_HIGH; pVInfo->vencOutputInfo.dataFormat = SYSTEM_DF_YUV422I_YUYV; pVInfo->vencOutputInfo.videoIfWidth = SYSTEM_VIFW_16BIT; pVInfo->vencOutputInfo.aFmt = SYSTEM_DCTRL_A_OUTPUT_MAX; pVInfo->outputPort = SYSTEM_DCTRL_DSS_DPI1_OUTPUT; pVInfo->mInfo.standard = SYSTEM_STD_CUSTOM; pVInfo->mInfo.width = 1280; pVInfo->mInfo.height = 720; pVInfo->mInfo.scanFormat = SYSTEM_SF_PROGRESSIVE; //pVInfo->mInfo.pixelClock = 74250U; pVInfo->mInfo.pixelClock = 28125U;/* 28.125Mhz */ //pVInfo->mInfo.pixelClock = 26250U;/* 26.25Mhz */ pVInfo->mInfo.fps = 25U; pVInfo->mInfo.hFrontPorch = 111u; pVInfo->mInfo.hBackPorch = 111u; pVInfo->mInfo.hSyncLen = 212u;/**/ pVInfo->mInfo.vFrontPorch = 14u; pVInfo->mInfo.vBackPorch = 14u; pVInfo->mInfo.vSyncLen = 3u; pVInfo->vencDivisorInfo.divisorLCD = 1; pVInfo->vencDivisorInfo.divisorPCD = 1; pVInfo->mode = 0; pVInfo->isInputPipeConnected[0] = TRUE; pVInfo->isInputPipeConnected[1] = FALSE; pVInfo->isInputPipeConnected[2] = FALSE; pVInfo->isInputPipeConnected[3] = FALSE; pVInfo->writeBackEnabledFlag = FALSE; /* Configure LCD overlay params */ pOvlyPrms = &ovlyPrms[0]; pOvlyPrms->vencId = pVInfo->vencId; pOvlyPrms->deltaLinesPerPanel = 0; pOvlyPrms->alphaBlenderEnable = 0; pOvlyPrms->backGroundColor = 0x10; pOvlyPrms->colorKeyEnable = 1; pOvlyPrms->colorKeySel = SYSTEM_DSS_DISPC_TRANS_COLOR_KEY_SRC; pOvlyPrms->ovlyOptimization = SYSTEM_DSS_DISPC_OVLY_FETCH_ALLDATA; pOvlyPrms->transColorKey = DRAW2D_TRANSPARENT_COLOR; /* Setting LCD overlay pipe parameters */ pPipeOvlyPrms = &pObj->pipeParams[0]; pPipeOvlyPrms->pipeLine = SYSTEM_DSS_DISPC_PIPE_VID1; pPipeOvlyPrms->globalAlpha = 0xFF; pPipeOvlyPrms->preMultiplyAlpha = 0; pPipeOvlyPrms->zorderEnable = TRUE; pPipeOvlyPrms->zorder = SYSTEM_DSS_DISPC_ZORDER0; /* Configure LCD2 */ pVInfo = &pPrm->vencInfo[1]; pVInfo->vencId = SYSTEM_DCTRL_DSS_VENC_LCD2; //pVInfo->vencOutputInfo.fidPolarity = SYSTEM_DCTRL_POLARITY_ACT_HIGH; pVInfo->vencOutputInfo.actVidPolarity = SYSTEM_DCTRL_POLARITY_ACT_HIGH; pVInfo->vencOutputInfo.pixelClkPolarity = SYSTEM_DCTRL_POLARITY_ACT_HIGH; pVInfo->vencOutputInfo.dvoFormat = SYSTEM_DCTRL_DVOFMT_BT1120_EMBSYNC; pVInfo->vencOutputInfo.vsPolarity = SYSTEM_DCTRL_POLARITY_ACT_HIGH; pVInfo->vencOutputInfo.hsPolarity = SYSTEM_DCTRL_POLARITY_ACT_HIGH; pVInfo->vencOutputInfo.dataFormat = SYSTEM_DF_YUV422I_YUYV; pVInfo->vencOutputInfo.videoIfWidth = SYSTEM_VIFW_16BIT; pVInfo->vencOutputInfo.aFmt = SYSTEM_DCTRL_A_OUTPUT_MAX; pVInfo->outputPort = SYSTEM_DCTRL_DSS_DPI2_OUTPUT; pVInfo->mInfo.standard = SYSTEM_STD_CUSTOM; pVInfo->mInfo.width = 1280; pVInfo->mInfo.height = 720; pVInfo->mInfo.scanFormat = SYSTEM_SF_PROGRESSIVE; //pVInfo->mInfo.pixelClock = 74250U; pVInfo->mInfo.pixelClock = 28125U;/* 28.125Mhz */ //pVInfo->mInfo.pixelClock = 26250U;/* 26.25Mhz */ pVInfo->mInfo.fps = 25U; pVInfo->mInfo.hFrontPorch = 111u; pVInfo->mInfo.hBackPorch = 111u; pVInfo->mInfo.hSyncLen = 212u;/**/ pVInfo->mInfo.vFrontPorch = 14u; pVInfo->mInfo.vBackPorch = 14u; pVInfo->mInfo.vSyncLen = 3u; pVInfo->vencDivisorInfo.divisorLCD = 1; pVInfo->vencDivisorInfo.divisorPCD = 1; pVInfo->mode = 0; pVInfo->isInputPipeConnected[0] = FALSE; pVInfo->isInputPipeConnected[1] = TRUE; pVInfo->isInputPipeConnected[2] = FALSE; pVInfo->isInputPipeConnected[3] = FALSE; pVInfo->writeBackEnabledFlag = FALSE; /* Configure LCD overlay params */ pOvlyPrms = &ovlyPrms[1]; pOvlyPrms->vencId = pVInfo->vencId; pOvlyPrms->deltaLinesPerPanel = 0; pOvlyPrms->alphaBlenderEnable = 0; pOvlyPrms->backGroundColor = 0x10; pOvlyPrms->colorKeyEnable = 1; pOvlyPrms->colorKeySel = SYSTEM_DSS_DISPC_TRANS_COLOR_KEY_SRC; pOvlyPrms->ovlyOptimization = SYSTEM_DSS_DISPC_OVLY_FETCH_ALLDATA; pOvlyPrms->transColorKey = DRAW2D_TRANSPARENT_COLOR; /* Setting LCD overlay pipe parameters */ pPipeOvlyPrms = &pObj->pipeParams[1]; pPipeOvlyPrms->pipeLine = SYSTEM_DSS_DISPC_PIPE_VID2; pPipeOvlyPrms->globalAlpha = 0xFF; pPipeOvlyPrms->preMultiplyAlpha = 0; pPipeOvlyPrms->zorderEnable = TRUE; pPipeOvlyPrms->zorder = SYSTEM_DSS_DISPC_ZORDER0; /* Create, configure and start the Display Ctrl link */ status = System_linkCreate(pObj->displayCtrlLinkId, NULL, 0); UTILS_assert(status == SYSTEM_LINK_STATUS_SOK); status = System_linkControl(pObj->displayCtrlLinkId, DISPLAYCTRL_LINK_CMD_SET_CONFIG, &pObj->dctrlCfgPrms, sizeof(DisplayCtrlLink_ConfigParams), TRUE); UTILS_assert(status == SYSTEM_LINK_STATUS_SOK); status = System_linkControl(pObj->displayCtrlLinkId, DISPLAYCTRL_LINK_CMD_SET_OVLY_PARAMS, &ovlyPrms[0], sizeof(DisplayCtrlLink_OvlyParams), TRUE); UTILS_assert(status == SYSTEM_LINK_STATUS_SOK); status = System_linkControl(pObj->displayCtrlLinkId, DISPLAYCTRL_LINK_CMD_SET_OVLY_PARAMS, &ovlyPrms[1], sizeof(DisplayCtrlLink_OvlyParams), TRUE); UTILS_assert(status == SYSTEM_LINK_STATUS_SOK); status = System_linkControl(pObj->displayCtrlLinkId, DISPLAYCTRL_LINK_CMD_SET_OVLY_PIPELINE_PARAMS, &pObj->pipeParams[0], sizeof(DisplayCtrlLink_OvlyPipeParams), TRUE); UTILS_assert(status == SYSTEM_LINK_STATUS_SOK); status = System_linkControl(pObj->displayCtrlLinkId, DISPLAYCTRL_LINK_CMD_SET_OVLY_PIPELINE_PARAMS, &pObj->pipeParams[1], sizeof(DisplayCtrlLink_OvlyPipeParams), TRUE); UTILS_assert(status == SYSTEM_LINK_STATUS_SOK); return status; }
Then I use "dss_clockdumps.sh" script to dump the clock. I find that the LCD2 clock overlay LCD1, and LCD1 clock is 0Hz.
~ # cd /home/ /home # sh dss_clockdumps.sh =====================DSS clock script=================== Dumps internal clocks and muxes of DSS CTRL_CORE_DSS_PLL_CONTROL (0x4a002538) = 0x00000286 video1 PLL : Enabled video2 PLL : Disabled HDMI PLL : Disabled DSI1_A_CLK mux : DPLL Video1 DSI1_B_CLK mux : DPLL Video1 DSI1_C_CLK mux : DPLL Video1 DSS_CTRL (0x58000040) = 0x00011001 2: LCD1 clk switch : DSI1_A_CLK 3: LCD2 clk switch : DSI1_B_CLK 10: LCD3 clk switch : DSS clk 1: func clk switch : DSS clk 13: DPI1 output : LCD1 DSS_STATUS (0x5800005C) = 0x01409280 DSI_CLK_CTRL (0x58004054) = 0x80004001 CM_DSS_CLKSTCTRL (0x4A009100) = 0x00061F02 CM_DSS_DSS_CLKCTRL (0x4A009120) = 0x00003F02 ======================================================== Register dump for DPLL video1 |----------------------------| | Address (hex) | Data (hex) | |----------------------------| | 0x58004300 | 0x00000018 | | 0x58004304 | 0x00002603 | | 0x58004308 | 0x00000000 | | 0x5800430C | 0x02AF78FE | | 0x58004310 | 0x00E06108 | | 0x58004314 | 0x00000015 | | 0x58004318 | 0x00000000 | | 0x5800431C | 0x00000000 | | 0x58004320 | 0x00000000 | |----------------------------| Details for DPLL video1 PLL status : Locked M4 hsdiv(1) : inactive M5 hsdiv(2) : inactive M6 hsdiv(3) : Active M7 hsdiv(4) : inactive PLL_REGM = 1980 PLL_REGN = 127 M4 DIV = 21 M6 DIV = 21 M7 DIV = 0 Clock calculations (DPLL video1) sysclk = 20000000 DCO clk = sysclk * 2 * REGM / (REGN + 1) = 618750000 M4clk (clkcout1) = DCO clk / (M4 DIV + 1) = 0 M6clk (clkcout3) = DCO clk / (M6 DIV + 1) = 28125000 M7clk (clkcout4) = DCO clk / (M7 DIV + 1) = 0 ======================================================== Clock O/P of MUXes DPLL PER H12 Output 192000000 CM_DIV_H12_DPLL_PER (0x4A00815C) = 0x00000204 DSI1_A_CLK : 0 DSI1_B_CLK : 28125000 DSI1_C_CLK : 28125000 DISPC_DIVISOR (0x58001804) = 0x00010001 2: LCD1 clk : 0 3: LCD2 clk : 28125000 10: LCD3 clk : 192000000 1: func clk : 192000000 LCD1 logic clk(/ 1 ) : 0 pix clk(/ 1 ) : 0 LCD2 logic clk(/ 1 ) : 28125000 pix clk(/ 1 ) : 28125000 LCD3 logic clk(/ 4 ) : 48000000 pix clk(/ 1 ) : 48000000 /home # /home # /home # /home # /home # sh dss_ dss_clockdumps.sh dss_regdumps.sh /home # sh dss_regdumps.sh |----------------------------| | Address (hex) | Data (hex) | |----------------------------| | 0x58000000 | 0x00000061 | | 0x58000010 | 0x00000000 | | 0x58000014 | 0x00000001 | | 0x58000040 | 0x00011001 | | 0x5800005C | 0x01409280 | | 0x4A0A0000 | 0x50060006 | | 0x4A0A0010 | 0x00000011 | | 0x4A0A0014 | 0x00000001 | | 0x4A0A0018 | 0x00000001 | | 0x58004054 | 0x80004001 | | 0x58005054 | 0x00000001 | |----------------------------| |----------------------------| | Address (hex) | Data (hex) | |----------------------------| | 0x58004300 | 0x00000018 | | 0x58004304 | 0x00002603 | | 0x58004308 | 0x00000000 | | 0x5800430C | 0x02AF78FE | | 0x58004310 | 0x00E06108 | | 0x58004314 | 0x00000015 | | 0x58004318 | 0x00000000 | | 0x5800431C | 0x00000000 | | 0x58004320 | 0x00000000 | |----------------------------| |----------------------------| | Address (hex) | Data (hex) | |----------------------------| | 0x58040200 | 0x00000000 | | 0x58040204 | 0x00000000 | | 0x58040208 | 0x00000000 | | 0x5804020C | 0x00000000 | | 0x58040210 | 0x00000000 | | 0x58040214 | 0x00000000 | | 0x58040218 | 0x00000000 | | 0x5804021C | 0x00000000 | | 0x58040220 | 0x00000000 | |----------------------------| |----------------------------| | Address (hex) | Data (hex) | |----------------------------| | 0x58040000 | 0x50031D00 | | 0x58040004 | 0x00000000 | | 0x58040008 | 0x00000000 | | 0x5804000C | 0x00000000 | | 0x58040010 | 0x00000008 | | 0x58040014 | 0x00000000 | | 0x58040018 | 0x00000000 | | 0x5804001C | 0x00000000 | | 0x58040020 | 0x00000000 | | 0x58040024 | 0x00000000 | | 0x58040028 | 0x00000000 | | 0x5804002C | 0x00000000 | | 0x58040030 | 0x00000000 | | 0x58040034 | 0x00000000 | | 0x58040038 | 0x00000000 | | 0x5804003C | 0x00000000 | | 0x58040040 | 0x00000000 | | 0x58040044 | 0x00001414 | | 0x58040048 | 0x00000000 | | 0x5804004C | 0x00000000 | | 0x58040050 | 0x00000700 | | 0x58040054 | 0x00000000 | | 0x58040058 | 0x00000000 | | 0x5804005C | 0x00000000 | | 0x58040060 | 0x00000000 | | 0x58040064 | 0x00000000 | | 0x58040068 | 0x00000000 | | 0x5804006C | 0x00000000 | | 0x58040070 | 0x00000700 | | 0x58040074 | 0x00000000 | | 0x58040078 | 0x00000000 | | 0x5804007C | 0x00000000 | | 0x58040080 | 0x01030005 | | 0x58040084 | 0x000010C0 | | 0x58040088 | 0x00000010 | | 0x5804008C | 0x00000000 | | 0x58040090 | 0x00000000 | | 0x58040094 | 0x00000000 | |----------------------------| |----------------------------| | Address (hex) | Data (hex) | |----------------------------| | 0x58001000 | 0x00000051 | | 0x58001004 | 0x00000000 | | 0x58001008 | 0x00000000 | | 0x5800100C | 0x00000000 | | 0x58001010 | 0x00000001 | | 0x58001014 | 0x00000001 | | 0x58001018 | 0x00000000 | | 0x5800101C | 0x02165662 | | 0x58001020 | 0x00000000 | | 0x58001024 | 0x00000000 | | 0x58001028 | 0x00000000 | | 0x5800102C | 0x00000000 | | 0x58001030 | 0x00000000 | | 0x58001034 | 0x00000000 | | 0x58001038 | 0x00000000 | | 0x5800103C | 0x00000000 | | 0x58001040 | 0x00000129 | | 0x58001044 | 0x01200C04 | | 0x58001048 | 0x00000000 | | 0x5800104C | 0x00000010 | | 0x58001050 | 0x00000000 | | 0x58001054 | 0x00000000 | | 0x58001058 | 0x00000000 | | 0x5800105C | 0x00000000 | | 0x58001060 | 0x000002CB | | 0x58001064 | 0x06E06ED3 | | 0x58001068 | 0x00E00E02 | | 0x5800106C | 0x00000000 | | 0x58001070 | 0x00010001 | | 0x58001074 | 0xFFFFFFFF | | 0x58001078 | 0x00000000 | | 0x5800107C | 0x02CF04FF | | 0x58001080 | 0x00000000 | | 0x58001084 | 0x00000000 | | 0x58001088 | 0x00000000 | | 0x5800108C | 0x00000000 | | 0x58001090 | 0x00000000 | | 0x58001094 | 0x00000000 | | 0x58001098 | 0x00000000 | | 0x5800109C | 0x00000000 | | 0x580010A0 | 0x000000A0 | | 0x580010A4 | 0x04FF04F8 | | 0x580010A8 | 0x00000500 | | 0x580010AC | 0x00000001 | | 0x580010B0 | 0x00000001 | | 0x580010B4 | 0x00000000 | | 0x580010B8 | 0x00000000 | | 0x580010BC | 0x8994F400 | | 0x580010C0 | 0x00000000 | | 0x580010C4 | 0x00000000 | | 0x580010C8 | 0x02CF04FF | | 0x580010CC | 0x02200A61 | | 0x580010D0 | 0x07FF07F8 | | 0x580010D4 | 0x00000800 | | 0x580010D8 | 0x00000001 | | 0x580010DC | 0x00000001 | | 0x580010E0 | 0x04000400 | | 0x580010E4 | 0x02CF04FF | | 0x580010E8 | 0x00000000 | | 0x580010EC | 0x00000000 | | 0x580010F0 | 0x00800000 | | 0x580010F4 | 0x00800000 | | 0x580010F8 | 0x0E7DF601 | | 0x580010FC | 0x0E7DF6FE | | 0x58001100 | 0x2172F102 | | 0x58001104 | 0x2172F1FA | | 0x58001108 | 0x3762F001 | | 0x5800110C | 0x3762F0F6 | | 0x58001110 | 0xF24E4EF2 | | 0x58001114 | 0xF24E4E00 | | 0x58001118 | 0xF06237F6 | | 0x5800111C | 0xF0623701 | | 0x58001120 | 0xF17221FA | | 0x58001124 | 0xF1722102 | | 0x58001128 | 0xF67D0EFE | | 0x5800112C | 0xF67D0E01 | | 0x58001130 | 0x0199012A | | 0x58001134 | 0x012A0000 | | 0x58001138 | 0x079C0730 | | 0x5800113C | 0x0000012A | | 0x58001140 | 0x00000205 | | 0x58001144 | 0x00000000 | | 0x58001148 | 0x00000000 | | 0x5800114C | 0x897FDC00 | | 0x58001150 | 0x00000000 | | 0x58001154 | 0x00000000 | | 0x58001158 | 0x02CF04FF | | 0x5800115C | 0x42200A61 | | 0x58001160 | 0x07FF07F8 | | 0x58001164 | 0x00000800 | | 0x58001168 | 0x00000001 | | 0x5800116C | 0x00000001 | | 0x58001170 | 0x04000400 | | 0x58001174 | 0x02CF04FF | | 0x58001178 | 0x00000000 | | 0x5800117C | 0x00000000 | | 0x58001180 | 0x00800000 | | 0x58001184 | 0x00800000 | | 0x58001188 | 0x0E7DF601 | | 0x5800118C | 0x0E7DF6FE | | 0x58001190 | 0x2172F102 | | 0x58001194 | 0x2172F1FA | | 0x58001198 | 0x3762F001 | | 0x5800119C | 0x3762F0F6 | | 0x580011A0 | 0xF24E4EF2 | | 0x580011A4 | 0xF24E4E00 | | 0x580011A8 | 0xF06237F6 | | 0x580011AC | 0xF0623701 | | 0x580011B0 | 0xF17221FA | | 0x580011B4 | 0xF1722102 | | 0x580011B8 | 0xF67D0EFE | | 0x580011BC | 0xF67D0E01 | | 0x580011C0 | 0x0199012A | | 0x580011C4 | 0x012A0000 | | 0x580011C8 | 0x079C0730 | | 0x580011CC | 0x0000012A | | 0x580011D0 | 0x00000205 | | 0x580011D4 | 0x00000000 | | 0x580011D8 | 0x00000000 | | 0x580011DC | 0x00000000 | | 0x580011E0 | 0x00000000 | | 0x580011E4 | 0x0000FE01 | | 0x580011E8 | 0x0000FA02 | | 0x580011EC | 0x0000F601 | | 0x580011F0 | 0x000000F2 | | 0x580011F4 | 0x000001F6 | | 0x580011F8 | 0x000002FA | | 0x580011FC | 0x000001FE | | 0x58001200 | 0x00000000 | | 0x58001204 | 0x0000FE01 | | 0x58001208 | 0x0000FA02 | | 0x5800120C | 0x0000F601 | | 0x58001210 | 0x000000F2 | | 0x58001214 | 0x000001F6 | | 0x58001218 | 0x000002FA | | 0x5800121C | 0x000001FE | | 0x58001220 | 0x1344B01D | | 0x58001224 | 0xF51D4883 | | 0x58001228 | 0x20DC93EB | | 0x5800122C | 0x00000100 | | 0x58001230 | 0x00000100 | | 0x58001234 | 0x00000100 | | 0x58001238 | 0x00000129 | | 0x5800123C | 0x00000000 | | 0x58001240 | 0x00000000 | | 0x58001244 | 0x00000000 | | 0x58001248 | 0x00000000 | | 0x5800124C | 0x00000000 | | 0x58001250 | 0x00000000 | | 0x58001254 | 0x00000000 | | 0x58001258 | 0x00000000 | | 0x5800125C | 0x00000000 | | 0x58001260 | 0x00000000 | | 0x58001264 | 0x00000000 | | 0x58001268 | 0x00000000 | | 0x5800126C | 0x00000000 | | 0x58001270 | 0x00000000 | | 0x58001274 | 0x00000000 | | 0x58001278 | 0x00000000 | | 0x5800127C | 0x00000000 | | 0x58001280 | 0x00000000 | | 0x58001284 | 0x00000000 | | 0x58001288 | 0x00000000 | | 0x5800128C | 0x00000000 | | 0x58001290 | 0x00000000 | | 0x58001294 | 0x00000000 | | 0x58001298 | 0x00000000 | | 0x5800129C | 0x00000000 | | 0x580012A0 | 0x00000000 | | 0x580012A4 | 0x00000000 | | 0x580012A8 | 0x00000000 | | 0x580012AC | 0x00000000 | | 0x580012B0 | 0x00000000 | | 0x580012B4 | 0x00000000 | | 0x580012B8 | 0x00000000 | | 0x580012BC | 0x00000000 | | 0x580012C0 | 0x00000000 | | 0x580012C4 | 0x00000000 | | 0x580012C8 | 0x00000000 | | 0x580012CC | 0x00000000 | | 0x580012D0 | 0x00000000 | | 0x580012D4 | 0x00000000 | | 0x580012D8 | 0x00000000 | | 0x580012DC | 0x00000000 | | 0x580012E0 | 0x00000000 | | 0x580012E4 | 0x00000000 | | 0x580012E8 | 0x00000000 | | 0x580012EC | 0x00000000 | | 0x580012F0 | 0x00000000 | | 0x580012F4 | 0x00000000 | | 0x580012F8 | 0x00000000 | | 0x580012FC | 0x00000000 | | 0x58001300 | 0x00000000 | | 0x58001304 | 0x00000000 | | 0x58001308 | 0x00000000 | | 0x5800130C | 0x00000000 | | 0x58001310 | 0x00000000 | | 0x58001314 | 0x00000000 | | 0x58001318 | 0x00000000 | | 0x5800131C | 0x00000000 | | 0x58001320 | 0x00000000 | | 0x58001324 | 0x00000000 | | 0x58001328 | 0x00000000 | | 0x5800132C | 0x00000000 | | 0x58001330 | 0x00000000 | | 0x58001334 | 0x00000000 | | 0x58001338 | 0x00000000 | | 0x5800133C | 0x00000000 | | 0x58001340 | 0x00000000 | | 0x58001344 | 0x00000000 | | 0x58001348 | 0x00000000 | | 0x5800134C | 0x00000000 | | 0x58001350 | 0x00000000 | | 0x58001354 | 0x00000000 | | 0x58001358 | 0x00000000 | | 0x5800135C | 0x00000000 | | 0x58001360 | 0x00000000 | | 0x58001364 | 0x00000000 | | 0x58001368 | 0x00000000 | | 0x5800136C | 0x00000000 | | 0x58001370 | 0x00008400 | | 0x58001374 | 0x00000000 | | 0x58001378 | 0x00000000 | | 0x5800137C | 0x00000000 | | 0x58001380 | 0x00000000 | | 0x58001384 | 0x00000000 | | 0x58001388 | 0x00000800 | | 0x5800138C | 0x07FF07F8 | | 0x58001390 | 0x04000400 | | 0x58001394 | 0x00000000 | | 0x58001398 | 0x00000001 | | 0x5800139C | 0x00000000 | | 0x580013A0 | 0x00000100 | | 0x580013A4 | 0x00000001 | | 0x580013A8 | 0x00000000 | | 0x580013AC | 0x00000010 | | 0x580013B0 | 0x00000000 | | 0x580013B4 | 0x20DC93EB | | 0x580013B8 | 0xF51D4883 | | 0x580013BC | 0x1344B01D | | 0x580013C0 | 0x00000000 | | 0x580013C4 | 0x00000000 | | 0x580013C8 | 0x00000000 | | 0x580013CC | 0x02CF04FF | | 0x580013D0 | 0x00000000 | | 0x580013D4 | 0x00000000 | | 0x580013D8 | 0x00000000 | | 0x580013DC | 0x00000000 | | 0x580013E0 | 0x00000000 | | 0x580013E4 | 0x00000000 | | 0x580013E8 | 0x00000000 | | 0x580013EC | 0x00000000 | | 0x580013F0 | 0x00000000 | | 0x580013F4 | 0x00000000 | | 0x580013F8 | 0x00000000 | | 0x580013FC | 0x00000000 | | 0x58001400 | 0x06E06ED3 | | 0x58001404 | 0x00E00E02 | | 0x58001408 | 0x00000000 | | 0x5800140C | 0x00010001 | | 0x58001410 | 0x00000000 | | 0x58001414 | 0x00000000 | | 0x58001418 | 0x00000000 | | 0x5800141C | 0x00000000 | | 0x58001420 | 0x00000000 | | 0x58001424 | 0x00000000 | | 0x58001428 | 0x00000000 | | 0x5800142C | 0x00000000 | | 0x58001430 | 0x00000000 | | 0x58001434 | 0x00000000 | | 0x58001438 | 0x00000000 | | 0x5800143C | 0x00000000 | | 0x58001440 | 0x00000000 | | 0x58001444 | 0x00000000 | | 0x58001448 | 0x00000000 | | 0x5800144C | 0x00000000 | | 0x58001450 | 0x00000000 | | 0x58001454 | 0x00000000 | | 0x58001458 | 0x00000000 | | 0x5800145C | 0x00000000 | | 0x58001460 | 0x00000000 | | 0x58001464 | 0x00000000 | | 0x58001468 | 0x00000000 | | 0x5800146C | 0x00000000 | | 0x58001470 | 0x00000000 | | 0x58001474 | 0x00000000 | | 0x58001478 | 0x00000000 | | 0x5800147C | 0x00000000 | | 0x58001480 | 0x00000000 | | 0x58001484 | 0x00000000 | | 0x58001488 | 0x00000000 | | 0x5800148C | 0x00000000 | | 0x58001490 | 0x00000000 | | 0x58001494 | 0x00000000 | | 0x58001498 | 0x00000000 | | 0x5800149C | 0x00000000 | | 0x580014A0 | 0x00000000 | | 0x580014A4 | 0x00000000 | | 0x580014A8 | 0x00000000 | | 0x580014AC | 0x00000000 | | 0x580014B0 | 0x00000000 | | 0x580014B4 | 0x00000000 | | 0x580014B8 | 0x00000000 | | 0x580014BC | 0x00000000 | | 0x580014C0 | 0x00000000 | | 0x580014C4 | 0x00000000 | | 0x580014C8 | 0x00000000 | | 0x580014CC | 0x00000000 | | 0x580014D0 | 0x00000000 | | 0x580014D4 | 0x00000000 | | 0x580014D8 | 0x00000000 | | 0x580014DC | 0x00000000 | | 0x580014E0 | 0x00000000 | | 0x580014E4 | 0x00000000 | | 0x580014E8 | 0x00000000 | | 0x580014EC | 0x00000000 | | 0x580014F0 | 0x00000000 | | 0x580014F4 | 0x00000000 | | 0x580014F8 | 0x00000000 | | 0x580014FC | 0x00000000 | | 0x58001500 | 0x00000000 | | 0x58001504 | 0x00000000 | | 0x58001508 | 0x00000000 | | 0x5800150C | 0x00000000 | | 0x58001510 | 0x00000000 | | 0x58001514 | 0x00000000 | | 0x58001518 | 0x00000000 | | 0x5800151C | 0x00000000 | | 0x58001520 | 0x00000000 | | 0x58001524 | 0x00000000 | | 0x58001528 | 0x00000000 | | 0x5800152C | 0x00000000 | | 0x58001530 | 0x00000000 | | 0x58001534 | 0x00000000 | | 0x58001538 | 0x00000000 | | 0x5800153C | 0x00000000 | | 0x58001540 | 0x00000000 | | 0x58001544 | 0x00000000 | | 0x58001548 | 0x00000000 | | 0x5800154C | 0x00000000 | | 0x58001550 | 0x00000000 | | 0x58001554 | 0x00000000 | | 0x58001558 | 0x00000000 | | 0x5800155C | 0x00000000 | | 0x58001560 | 0x00000000 | | 0x58001564 | 0x00000000 | | 0x58001568 | 0x00000000 | | 0x5800156C | 0x00000000 | | 0x58001570 | 0x00008000 | | 0x58001574 | 0x00000000 | | 0x58001578 | 0x00000000 | | 0x5800157C | 0x00000000 | | 0x58001580 | 0x00000000 | | 0x58001584 | 0x00000000 | | 0x58001588 | 0x00000800 | | 0x5800158C | 0x07FF07F8 | | 0x58001590 | 0x04000400 | | 0x58001594 | 0x00000000 | | 0x58001598 | 0x00000001 | | 0x5800159C | 0x00000000 | | 0x580015A0 | 0x00000000 | | 0x580015A4 | 0x00000001 | | 0x580015A8 | 0x00000000 | | 0x580015AC | 0x00000000 | | 0x580015B0 | 0x00000000 | | 0x580015B4 | 0x00000000 | | 0x580015B8 | 0x00000000 | | 0x580015BC | 0x00000000 | | 0x580015C0 | 0x00000000 | | 0x580015C4 | 0x00000000 | | 0x580015C8 | 0x00000000 | | 0x580015CC | 0x00000000 | | 0x580015D0 | 0x00000000 | | 0x580015D4 | 0x00000000 | | 0x580015D8 | 0x00000000 | | 0x580015DC | 0x00000000 | | 0x580015E0 | 0x00000000 | | 0x580015E4 | 0x00000000 | | 0x580015E8 | 0x00000000 | | 0x580015EC | 0x00000000 | | 0x580015F0 | 0x00000000 | | 0x580015F4 | 0x00000000 | | 0x580015F8 | 0x00000000 | | 0x580015FC | 0x00000000 | | 0x58001600 | 0x89A30400 | | 0x58001604 | 0x00000000 | | 0x58001608 | 0x898DEC00 | | 0x5800160C | 0x00000000 | | 0x58001610 | 0x00000000 | | 0x58001614 | 0x00000000 | | 0x58001618 | 0x00000000 | | 0x5800161C | 0x00000000 | | 0x58001620 | 0x01200C00 | | 0x00000100 | | 0x58001628 | 0x00000100 | | 0x5800162C | 0x00000000 | | 0x58001630 | 0x00000000 | | 0x58001634 | 0x00000000 | | 0x58001638 | 0x00000000 | | 0x5800163C | 0x02000200 | | 0x58001640 | 0x00000000 | | 0x58001644 | 0x00000000 | | 0x58001648 | 0x00800000 | | 0x5800164C | 0x00800000 | | 0x58001650 | 0x0E7DF601 | | 0x58001654 | 0x0E7DF6FE | | 0x58001658 | 0x2172F102 | | 0x5800165C | 0x2172F1FA | | 0x58001660 | 0x3762F001 | | 0x58001664 | 0x3762F0F6 | | 0x58001668 | 0xF24E4EF2 | | 0x5800166C | 0xF24E4E00 | | 0x58001670 | 0xF06237F6 | | 0x58001674 | 0xF0623701 | | 0x58001678 | 0xF17221FA | | 0x5800167C | 0xF1722102 | | 0x58001680 | 0xF67D0EFE | | 0x58001684 | 0xF67D0E01 | | 0x58001688 | 0x00000000 | | 0x5800168C | 0x0000FE01 | | 0x58001690 | 0x0000FA02 | | 0x58001694 | 0x0000F601 | | 0x58001698 | 0x000000F2 | | 0x5800169C | 0x000001F6 | | 0x580016A0 | 0x000002FA | | 0x580016A4 | 0x000001FE | | 0x580016A8 | 0x02000200 | | 0x580016AC | 0x00000000 | | 0x580016B0 | 0x00000000 | | 0x580016B4 | 0x00800000 | | 0x580016B8 | 0x00800000 | | 0x580016BC | 0x0E7DF601 | | 0x580016C0 | 0x0E7DF6FE | | 0x580016C4 | 0x2172F102 | | 0x580016C8 | 0x2172F1FA | | 0x580016CC | 0x3762F001 | | 0x580016D0 | 0x3762F0F6 | | 0x580016D4 | 0xF24E4EF2 | | 0x580016D8 | 0xF24E4E00 | | 0x580016DC | 0xF06237F6 | | 0x580016E0 | 0xF0623701 | | 0x580016E4 | 0xF17221FA | | 0x580016E8 | 0xF1722102 | | 0x580016EC | 0xF67D0EFE | | 0x580016F0 | 0xF67D0E01 | | 0x580016F4 | 0x00000000 | | 0x580016F8 | 0x0000FE01 | | 0x580016FC | 0x0000FA02 | | 0x58001700 | 0x0000F601 | |----------------------------| |----------------------------| | Address (hex) | Data (hex) | |----------------------------| | 0x58001700 | 0x0000F601 | | 0x58001704 | 0x000000F2 | | 0x58001708 | 0x000001F6 | | 0x5800170C | 0x000002FA | | 0x58001710 | 0x000001FE | | 0x58001714 | 0x00000000 | | 0x58001718 | 0x00000000 | | 0x5800171C | 0x00000000 | | 0x58001720 | 0x00000000 | | 0x58001724 | 0x04000400 | | 0x58001728 | 0x00000000 | | 0x5800172C | 0x00000000 | | 0x58001730 | 0x00000000 | | 0x58001734 | 0x00000000 | | 0x58001738 | 0x00000000 | | 0x5800173C | 0x00000000 | | 0x58001740 | 0x00000000 | | 0x58001744 | 0x00000000 | | 0x58001748 | 0x00000000 | | 0x5800174C | 0x00000000 | | 0x58001750 | 0x00000000 | | 0x58001754 | 0x00000000 | | 0x58001758 | 0x00000000 | | 0x5800175C | 0x00000000 | | 0x58001760 | 0x00000000 | | 0x58001764 | 0x00000000 | | 0x58001768 | 0x00000000 | | 0x5800176C | 0x00000000 | | 0x58001770 | 0x00000000 | | 0x58001774 | 0x00000000 | | 0x58001778 | 0x00000000 | | 0x5800177C | 0x00000000 | | 0x58001780 | 0x00000000 | | 0x58001784 | 0x00000000 | | 0x58001788 | 0x00000000 | | 0x5800178C | 0x00000000 | | 0x58001790 | 0x04000400 | | 0x58001794 | 0x00000000 | | 0x58001798 | 0x00000000 | | 0x5800179C | 0x00000000 | | 0x580017A0 | 0x00000000 | | 0x580017A4 | 0x00000000 | | 0x580017A8 | 0x00000000 | | 0x580017AC | 0x00000000 | | 0x580017B0 | 0x00000000 | | 0x580017B4 | 0x00000000 | | 0x580017B8 | 0x00000000 | | 0x580017BC | 0x00000000 | | 0x580017C0 | 0x00000000 | | 0x580017C4 | 0x00000000 | | 0x580017C8 | 0x00000000 | | 0x580017CC | 0x00000000 | | 0x580017D0 | 0x00000000 | | 0x580017D4 | 0x00000000 | | 0x580017D8 | 0x00000000 | | 0x580017DC | 0x00000000 | | 0x580017E0 | 0x00000000 | | 0x580017E4 | 0x00000000 | | 0x580017E8 | 0x00000000 | | 0x580017EC | 0x00000000 | | 0x580017F0 | 0x00000000 | | 0x580017F4 | 0x00000000 | | 0x580017F8 | 0x00000000 | | 0x580017FC | 0x00000000 | | 0x58001800 | 0x246D2240 | |----------------------------| |----------------------------| | Address (hex) | Data (hex) | |----------------------------| | 0x58001800 | 0x246D2240 | | 0x58001804 | 0x00010001 | | 0x58001808 | 0x00000000 | | 0x5800180C | 0x00000000 | | 0x58001810 | 0x00000000 | | 0x58001814 | 0x00000000 | | 0x58001818 | 0x00000000 | | 0x5800181C | 0x00000000 | | 0x58001820 | 0x00000000 | | 0x58001824 | 0x00000000 | | 0x58001828 | 0x00000000 | | 0x5800182C | 0x00000000 | | 0x58001830 | 0x00000000 | | 0x58001834 | 0x00000000 | | 0x58001838 | 0x00040001 | | 0x5800183C | 0x00000000 | | 0x58001840 | 0x00000000 | | 0x58001844 | 0x00000000 | | 0x58001848 | 0x00000300 | | 0x5800184C | 0x00000000 | | 0x58001850 | 0x00000000 | | 0x58001854 | 0x00000000 | | 0x58001858 | 0x00000001 | | 0x5800185C | 0x00000005 | | 0x58001860 | 0x00000000 | | 0x58001864 | 0x00000000 | | 0x58001868 | 0x00000000 | | 0x5800186C | 0x00000000 | | 0x58001870 | 0x00000000 | |----------------------------| /home #
Is there any problem with my configuration? Please help me to check it.
Best Regards
Jaye
