Calling assembli function from TCONF files
I need to set the fxn parameter of a HWI instance as a function written in assembly (in a s64P file)
I have already set a the fxn of a HWI instance to a C function whthout any issues:
prog.module("HWI").instance("HWI_INT5").fxn = prog.extern("ISR_fxn");
But when I try to assign the fxn as an assembly function  I get a compilation error:
 prog.module("HWI").instance("HWI_INT4").fxn = prog.extern("asm_isr", "asm");
The error I get is something like:
undefined
 symbol
asm_isr
Do you know if I am missing something?
Armando
