Part Number: TDA2
Other Parts Discussed in Thread: PMP, DRA742, DRA752
Tool/software: Linux
this is my uenv.txt!
fdtfile=dra7-evm-infoadas.dtb
args_mmc=setenv bootargs 'console=ttyO0,115200n8 vram=16M root=/dev/nfs rw nfsroot=172.17.218.40:/home/hancan/PROCESSOR_SDK_VISION_03_02_00_00/ti_components/os_tools/linux/targetfs rootwait ip=dhcp mem=1024M'
follow is booting log
** First descriptor is NOT a primary desc on 1:1 **
GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
part_get_info_efi: *** ERROR: Invalid GPT ***
part_get_info_efi: *** ERROR: Invalid Backup GPT ***
ERROR: cannot find partition: 'userdata'
at arch/arm/cpu/armv7/omap-common/utils.c:195/mmc_get_part_size()
Warning: fastboot.userdata_size: unable to calc
SCSI: SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net:
Warning: ethernet@48484000 using MAC address from ROM
eth0: ethernet@48484000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
239 bytes read in 2 ms (116.2 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc0 ...
3552176 bytes read in 113 ms (30 MiB/s)
106665 bytes read in 16 ms (6.4 MiB/s)
Booting from mmc0 ...
Kernel image @ 0x82000000 [ 0x000000 - 0x3633b0 ]
Loading Device Tree to 8ffe2000, end 8ffff0a8 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.84-00018-gd326d64-dirty (hancan@hancan-virtual-machine) (gcc version 5.4.1 20170404 (Linaro GCC 5.4-2017.05) ) #15 SMP PREEMPT Fri Jul 20 11:12:46 CST 2018
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine model: TI DRA742
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000040300000, size 3 MiB
[ 0.000000] Reserved memory: initialized node cmem@40300000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: regions without no-map are not yet supported
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 80 MiB
[ 0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009e000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a1000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a3000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 64 MiB
[ 0.000000] Reserved memory: initialized node cmem@A9000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x00000000be400000
[ 0.000000] Forcing write-allocate cache policy for SMP
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] OMAP4: Map 0x00000000bfd00000 to fe600000 for dram barrier
[ 0.000000] DRA752 ES2.0
[ 0.000000] PERCPU: Embedded 11 pages/cpu @ef62b000 s14912 r8192 d21952 u45056
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 243264
[ 0.000000] Kernel command line: console=ttyO0,115200n8 vram=16M root=/dev/nfs rw nfsroot=172.17.218.40:/home/hancan/PROCESSOR_SDK_VISION_03_02_00_00/ti_components/os_tools/linux/targetfs rootwait ip=dhcp mem=1024M
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 410844K/979968K available (6619K kernel code, 319K rwdata, 2388K rodata, 340K init, 290K bss, 364324K reserved, 204800K cma-reserved, 234496K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc08d402c (9009 kB)
[ 0.000000] .init : 0xc08d5000 - 0xc092a000 ( 340 kB)
[ 0.000000] .data : 0xc092a000 - 0xc0979d60 ( 320 kB)
[ 0.000000] .bss : 0xc097b000 - 0xc09c3800 ( 290 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] Architected cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000004] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000015] Switching to timer-based delay loop, resolution 162ns
[ 0.000341] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000350] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000793] Console: colour dummy device 80x30
[ 0.000810] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000816] This ensures that you still see kernel messages. Please
[ 0.000821] update your kernel commandline.
[ 0.000836] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000849] pid_max: default: 32768 minimum: 301
[ 0.000947] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000957] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001500] Initializing cgroup subsys io
[ 0.001517] Initializing cgroup subsys memory
[ 0.001541] Initializing cgroup subsys devices
[ 0.001553] Initializing cgroup subsys freezer
[ 0.001564] Initializing cgroup subsys perf_event
[ 0.001575] Initializing cgroup subsys pids
[ 0.001602] CPU: Testing write buffer coherency: ok
[ 0.001799] /cpus/cpu@0 missing clock-frequency property
[ 0.001816] /cpus/cpu@1 missing clock-frequency property
[ 0.001827] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001859] Setting up static identity map for 0x80008380 - 0x800083e0
[ 0.080089] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.080158] Brought up 2 CPUs
[ 0.080171] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[ 0.080177] CPU: All CPU(s) started in HYP mode.
[ 0.080183] CPU: Virtualization extensions available.
[ 0.080563] devtmpfs: initialized
[ 0.109216] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.110211] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.313075] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.313095] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.317329] pinctrl core: initialized pinctrl subsystem
[ 0.318175] NET: Registered protocol family 16
[ 0.319102] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.340228] cpuidle: using governor ladder
[ 0.370255] cpuidle: using governor menu
[ 0.378691] OMAP GPIO hardware version 0.1
[ 0.385080] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[ 0.401126] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 0.401140] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 0.410440] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.410450] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.410912] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.410922] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.411501] OMAP DMA hardware revision 0.0
[ 0.451285] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.452441] edma 43300000.edma: memcpy is disabled
[ 0.457006] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.461338] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.461521] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.461684] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.461841] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.462129] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 0.462314] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 0.465298] palmas 0-0058: IRQ missing: skipping irq request
[ 0.480763] palmas 0-0058: Muxing GPIO 2e, PWM 0, LED 0
[ 0.553058] pcf857x 0-0020: probed
[ 0.553616] pcf857x 0-0021: probed
[ 0.553766] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.554151] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.554358] media: Linux media interface: v0.10
[ 0.554410] Linux video capture interface: v2.00
[ 0.554453] pps_core: LinuxPPS API ver. 1 registered
[ 0.554460] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.554483] PTP clock support registered
[ 0.554527] EDAC MC: Ver: 3.0.0
[ 0.555272] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.555571] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.555900] Advanced Linux Sound Architecture Driver Initialized.
[ 0.556734] clocksource: Switched to clocksource arch_sys_counter
[ 0.567166] NET: Registered protocol family 2
[ 0.567670] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.567733] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.567858] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.567905] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.567936] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.568147] NET: Registered protocol family 1
[ 0.568416] RPC: Registered named UNIX socket transport module.
[ 0.568426] RPC: Registered udp transport module.
[ 0.568433] RPC: Registered tcp transport module.
[ 0.568439] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.569450] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.579255] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.579900] NFS: Registering the id_resolver key type
[ 0.579925] Key type id_resolver registered
[ 0.579934] Key type id_legacy registered
[ 0.579987] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.581240] bounce: pool size: 64 pages
[ 0.581387] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.581403] io scheduler noop registered
[ 0.581415] io scheduler deadline registered
[ 0.581447] io scheduler cfq registered (default)
[ 0.586314] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 0.589469] PCI host bridge /ocp/axi@0/pcie_rc@51000000 ranges:
[ 0.589482] No bus range found for /ocp/axi@0/pcie_rc@51000000, using [bus 00-ff]
[ 0.589515] IO 0x20003000..0x20012fff -> 0x00000000
[ 0.589537] MEM 0x20013000..0x2fffffff -> 0x20013000
[ 0.619541] dra7-pcie 51000000.pcie_rc: link is not up
[ 0.619713] dra7-pcie 51000000.pcie_rc: PCI host bridge to bus 0000:00
[ 0.619726] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.619736] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.619746] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 0.620139] PCI: bus0: Fast back to back transfers disabled
[ 0.620259] PCI: bus1: Fast back to back transfers enabled
[ 0.620342] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[ 0.620357] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[ 0.620369] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.620585] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 0.679838] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.683189] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250
[ 1.702019] console [ttyS0] enabled
[ 1.706400] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 302, base_baud = 3000000) is a 8250
[ 1.716095] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 303, base_baud = 3000000) is a 8250
[ 1.726142] [drm] Initialized drm 1.1.0 20060810
[ 1.732193] OMAP DSS rev 6.1
[ 1.735941] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 1.751618] loop: module loaded
[ 1.755132] vmemexp device MAJOR num = 246
[ 1.759286] vmemexp class registered
[ 1.762998] /dev/vmemexp device registered
[ 1.767130] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
[ 1.772798] nand: No NAND device found
[ 1.776569] omap2-nand 8000000.nand: scan failed, may be bus-width mismatch
[ 1.786496] m25p80 spi32766.0: s25fl256s1 (32768 Kbytes)
[ 1.791916] 7 ofpart partitions found on MTD device spi32766.0
[ 1.797795] Creating 7 MTD partitions on "spi32766.0":
[ 1.802956] 0x000000000000-0x000000040000 : "QSPI.SPL"
[ 1.809063] 0x000000040000-0x000000140000 : "QSPI.u-boot"
[ 1.815380] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
[ 1.822324] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
[ 1.829017] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
[ 1.836386] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
[ 1.842742] 0x0000009e0000-0x000002000000 : "QSPI.file-system"
[ 1.850513] libphy: Fixed MDIO Bus: probed
[ 1.906763] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[ 1.912886] davinci_mdio 48485000.mdio: detected phy mask fffffff3
[ 1.923418] libphy: 48485000.mdio: probed
[ 1.927491] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver unknown
[ 1.935532] davinci_mdio 48485000.mdio: phy[3]: device 48485000.mdio:03, driver unknown
[ 1.944242] cpsw 48484000.ethernet: Detected MACID = 7c:38:66:a1:e2:a6
[ 1.950941] cpsw 48484000.ethernet: cpts: overflow check period 800
[ 1.957945] cpsw 48484000.ethernet: cpsw: Detected MACID = 7c:38:66:a1:e2:a7
[ 1.966539] mousedev: PS/2 mouse device common for all mice
[ 1.972756] i2c /dev entries driver
[ 1.981533] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 1.987155] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 1.993540] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 2.000096] evm_3v3_sw: supplied by sysen1
[ 2.080509] mmc0: MAN_BKOPS_EN bit is not set
[ 2.116767] mmc0: new HS200 MMC card at address 0001
[ 2.132203] mmcblk0: mmc0:0001 MMC08G 7.25 GiB
[ 2.147258] mmcblk0boot0: mmc0:0001 MMC08G partition 1 8.00 MiB
[ 2.158518] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.164703] mmcblk0boot1: mmc0:0001 MMC08G partition 2 8.00 MiB
[ 2.173413] aic_dvdd: supplied by evm_3v3_sw
[ 2.179371] davinci-mcasp 4847c000.mcasp: invalid tdm slots: 0
[ 2.186798] NET: Registered protocol family 10
[ 2.202069] sit: IPv6 over IPv4 tunneling driver
[ 2.207278] NET: Registered protocol family 17
[ 2.211956] Key type dns_resolver registered
[ 2.216365] omap_voltage_late_init: Voltage driver support not added
[ 2.223258] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.229489] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.236184] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.242420] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.250619] Power Management for TI OMAP4+ devices.
[ 2.255688] Registering SWP/SWPB emulation handler
[ 2.262561] dmm 4e000000.dmm: initialized all PAT entries
[ 2.269906] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.276549] [drm] No driver support for vblank timestamp query.
[ 2.282855] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[ 2.299706] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 2.338073] asoc-simple-card sound0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
[ 2.357735] input: gpio_keys as /devices/platform/gpio_keys/input/input0
[ 2.365616] hctosys: unable to open rtc device (rtc0)
[ 2.379019] net eth0: initializing cpsw version 1.15 (0)
[ 2.384368] net eth0: initialized cpsw ale version 1.4
[ 2.389551] net eth0: ALE Table size 1024
[ 2.400775] net eth0: phy found : id is : 0x20005c7a
[ 2.411786] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 2.417687] net eth1: initializing cpsw version 1.15 (0)
[ 2.429896] net eth1: phy found : id is : 0x20005c7a
[ 2.439504] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 2.616598] mmc2: host does not support reading read-only switch, assuming write-enable
[ 2.631709] mmc2: new ultra high speed DDR50 SDHC card at address aaaa
[ 2.638675] mmcblk1: mmc2:aaaa SS08G 7.40 GiB
[ 2.648355] mmcblk1: p1 p2
[ 4.404334] cpsw 48484000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 4.416776] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 4.436759] Sending DHCP requests ., OK
[ 4.596765] IP-Config: Got DHCP answer from 172.17.192.1, my address is 172.17.218.87
[ 4.610392] IP-Config: Complete:
[ 4.613640] device=eth0, hwaddr=7c:38:66:a1:e2:a6, ipaddr=172.17.218.87, mask=255.255.224.0, gw=172.17.192.1
[ 4.623987] host=172.17.218.87, domain=apac.arcsoft.corp, nis-domain=(none)
[ 4.631455] bootserver=172.17.11.203, rootserver=172.17.218.40, rootpath=
[ 4.638604] nameserver0=172.17.10.20, nameserver1=172.17.10.31
[ 4.645240] evm_1v8: disabling
[ 4.648325] aic_dvdd: disabling
[ 4.651481] vmmcwl_fixed: disabling
[ 4.655202] ldousb: disabling
[ 4.658718] ALSA device list:
[ 4.661700] #0: DRA7xx-EVM
i donot know what is the problem and how to Solve this problem!
BESTWISHES!
