Part Number: TDA2PXEVM
Other Parts Discussed in Thread: TDA2
Tool/software: Linux
Hi
I am facing issues while compiling the config "tda2px_evm_linux_all".
make -s -j depend is successful but make -s -j is giving error
1) Unresolved symbols for the following:
IpcMgr_rpmsgStartup /home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/lib/tda2px-evm/ipu1_1/release/links_common_system.aem4<system_rpmsg.oem4>
NameMap_register /home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/lib/tda2px-evm/ipu1_1/release/links_common_system.aem4<system_rpmsg.oem4>
NameMap_unregister /home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/lib/tda2px-evm/ipu1_1/release/links_common_system.aem4<system_rpmsg.oem4>
RPMessage_create /home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/lib/tda2px-evm/ipu1_1/release/links_common_system.aem4<system_rpmsg.oem4>
RPMessage_delete /home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/lib/tda2px-evm/ipu1_1/release/links_common_system.aem4<system_rpmsg.oem4>
RPMessage_send /home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/lib/tda2px-evm/ipu1_1/release/links_common_system.aem4<system_rpmsg.oem4>
ti_ipc_remoteproc_Resource_getVdevStatus__E /home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/lib/tda2px-evm/ipu1_1/release/links_common_system.aem4<system_rpmsg.oem4>
error: unresolved symbols remain
../../master/ELFLNK/build.c:2612:internal fatal error #10251:
("xdc.meta:MAIN_APP_ipu1_1_pem4.oem4")
INTERNAL ERROR: /home/deepika/FFC/scripts/..//sdk/ti/PROCESSOR_SDK_VISION_03_03_00_00/ti_components/cg_tools/linux/ti-cgt-arm_16.9.2.LTS/bin/armlnk had an internal inconsistency and aborted
I have downloaded and reinstalled ti-cgt-arm_16.9.2.LTS again n the ti_components/linux directory
I am attaching the full error.
Deep
Compilation log
gmake[1]: Leaving directory `/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/utils'
making /home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/sysbios/sysbios.ae66 ...
gmake[1]: Entering directory `/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/sysbios'
cle66 /home/deepika/FFC/sdk/ti/PROCESSOR_SDK_VISION_03_03_00_00/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/BIOS.c ...
# Linking into /home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/vision_sdk/bin/tda2px-evm/vision_sdk_ipu1_1_release.xem4...
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 220: warning:
memory range not found: IPU1_1_DATA_MEM on page 0
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 220: error:
no valid memory range(null) available for placement of "GROUP_1"
program will not fit into available memory. run placement with alignment
fails for section "GROUP_1" size 0x1be600
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 247: warning:
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 247: error:
".bss:taskStackSection"
fails for section ".bss:taskStackSection" size 0x1b6000
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 218: warning:
memory range not found: IPU1_1_CODE_MEM on page 0
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 218: error:
no valid memory range(null) available for placement of ".text"
program will not fit into available memory. placement with alignment fails
for section ".text" size 0x36730
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 230: warning:
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 230: error:
no valid memory range(null) available for placement of ".data"
fails for section ".data" size 0x30ef6
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 229: warning:
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 229: error:
no valid memory range(null) available for placement of ".const"
for section ".const" size 0x8a74
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 219: warning:
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 219: error:
no valid memory range(null) available for placement of ".stack"
fails for section ".stack" size 0x4000
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 235: warning:
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 235: error:
no valid memory range(null) available for placement of ".args"
for section ".args" size 0x64
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 226: warning:
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 226: error:
fails for section ".binit" size 0x0
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 228: warning:
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 228: error:
fails for section ".init_array" size 0x0
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 231: warning:
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 231: error:
fails for section ".fardata" size 0x0
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 232: warning:
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 232: error:
fails for section ".switch" size 0x0
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 233: warning:
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 233: error:
fails for section ".sysmem" size 0x0
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 234: warning:
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 234: error:
fails for section ".far" size 0x0
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 236: warning:
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 236: error:
fails for section ".cio" size 0x0
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 237: warning:
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 237: error:
fails for section ".ARM.exidx" size 0x0
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 238: warning:
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 238: error:
fails for section ".ARM.extab" size 0x0
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 246: warning:
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 246: error:
fails for section ".plt" size 0x0
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 252: warning:
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 252: error:
for section "xdc.meta" size 0x147
error: program will not fit into available memory. run placement with
alignment fails for section ".TI.persistent" size 0x0
asme66 /home/deepika/FFC/sdk/ti/PROCESSOR_SDK_VISION_03_03_00_00/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c64p/Exception_asm.s64P ...
asme66 /home/deepika/FFC/sdk/ti/PROCESSOR_SDK_VISION_03_03_00_00/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c64p/Hwi_asm.s62 ...
asme66 /home/deepika/FFC/sdk/ti/PROCESSOR_SDK_VISION_03_03_00_00/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c64p/Hwi_asm_switch.s62 ...
asme66 /home/deepika/FFC/sdk/ti/PROCESSOR_SDK_VISION_03_03_00_00/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c64p/Hwi_disp_always.s64P ...
asme66 /home/deepika/FFC/sdk/ti/PROCESSOR_SDK_VISION_03_03_00_00/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/timers/dmtimer/Timer_asm.s64P ...
asme66 /home/deepika/FFC/sdk/ti/PROCESSOR_SDK_VISION_03_03_00_00/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c62/TaskSupport_asm.s62 ...
asme66 /home/deepika/FFC/sdk/ti/PROCESSOR_SDK_VISION_03_03_00_00/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/rts/ti/tls_get_tp.asm ...
are66 BIOS.obj c64p_Exception_asm.obj c64p_Hwi_asm.obj c64p_Hwi_asm_switch.obj c64p_Hwi_disp_always.obj dmtimer_Timer_asm.obj c62_TaskSupport_asm.obj ti_tls_get_tp.obj ...
gmake[1]: Leaving directory `/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src/sysbios'
Build of libraries done.
warning: xdc.cfg.Program: "/home/deepika/FFC/sdk/ti/PROCESSOR_SDK_VISION_03_03_00_00/ti_components/os_tools/linux/xdctools_3_32_01_22_core/packages/xdc/cfg/Program.xs", line 110: xdc.cfg.Program.SectionSpec#0 : Entry for the section '.bss:heapMemL2' in Program.sectMap is set to 'undefined'. This section allocation will be ignored.
# Configuro done!
# Making tda2px-evm:c66xdsp_2:release:vision_sdk_lib...
# Compiling tda2px-evm:c66xdsp_2:release:vision_sdk: src/main_common_c6xdsp2.c
# Compiling tda2px-evm:c66xdsp_2:release:vision_sdk: /home/deepika/FFC/source/vision/platform/ti/tda2/apps/src/common/app_init/app_init_dsp.c
# Compiling tda2px-evm:c66xdsp_2:release:vision_sdk: /home/deepika/FFC/source/vision/platform/ti/tda2/apps/src/common/main_app/tda2px/dsp2/src/main_c6xdsp2.c
# Compiling generated MAIN_APP_c6xdsp2_pe66.oe66
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 227: warning:
"/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/linker_mod.cmd", line 227: error:
no valid memory range(null) available for placement of ".cinit"
for section ".cinit" size 0x2091
gmake[1]: Leaving directory `/home/deepika/FFC/source/vision/platform/ti/tda2/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/sysbios'
# Configuro done!
# Making tda2px-evm:c66xdsp_1:release:vision_sdk_lib...
# Compiling tda2px-evm:c66xdsp_1:release:vision_sdk: /home/deepika/FFC/source/vision/platform/ti/tda2/apps/src/common/app_init/app_init_dsp.c
# Compiling tda2px-evm:c66xdsp_1:release:vision_sdk: /home/deepika/FFC/source/vision/platform/ti/tda2/apps/src/common/main_app/tda2px/dsp1/src/main_c6xdsp1.c
# Compiling generated MAIN_APP_c6xdsp1_pe66.oe66
# Compiling tda2px-evm:c66xdsp_1:release:vision_sdk: src/main_common_c6xdsp1.c
undefined first referenced
symbol in file
