Linux/TDA2PXEVM: RTOS usecase conversion to linux
Part Number: TDA2PXEVM
Tool/software: Linux
Hi.
I try to merge to the linux source from RTOS usecase. (UC_iss_mult_capture_isp_dewarp_3dsv_tda3xx) but an error occurs as follows.
source is vision sdk 3.04 version.
'/home/kyungtae.oh/ti/sdk/PROCESSOR_SDK_VISION/vision_sdk/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu2/release/vision_sdk_configuro/osa_mem_map.h' -> '/home/kyungtae.oh/ti/sdk/PROCESSOR_SDK_VISION/vision_sdk/links_fw/src/hlos/osa/include/osa_mem_map.h'
# links_a15_algorithm: tda2px-evm: Compiling algorithmLink_cfg.c
# osa: tda2px-evm: Compiling osa_remote_log_client.c
# osa: tda2px-evm: Compiling osa_mem.c
# osa: tda2px-evm: Compiling osa_remote_log_server.c
# system: tda2px-evm: Compiling system_common.c
# system: tda2px-evm: Compiling system_ipc.c
# links_a15_algorithm: tda2px-evm: Creating archive links_a15_algorithm.a
# osa: tda2px-evm: Creating archive osa.a
# system: tda2px-evm: Creating archive system.a
In file included from /home/kyungtae.oh/ti/sdk/PROCESSOR_SDK_VISION/vision_sdk/links_fw/include/link_api/issM2mResizerLink.h:112:0,
from chains_issMultCaptIspSimcop_Stereo_priv.h:78,
from chains_issMultCaptIspSimcop_Stereo.c:66:
/home/kyungtae.oh/ti/sdk/PROCESSOR_SDK_VISION/vision_sdk/links_fw/include/link_api/issIspConfiguration.h:97:50: fatal error: ti/drv/vps/include/iss/vps_isscommon.h: No such file or directory
compilation terminated.
from chains_issMultCaptIspSimcop_Stereo_priv.c:70:
/home/kyungtae.oh/ti/sdk/PROCESSOR_SDK_VISION/vision_sdk/build/hlos/makerules/linux/common_footer_a15.mk:81: recipe for target 'depend' failed
make[6]: *** [depend] Error 1
MAKEFILE_adas.MK:14: recipe for target 'vision_sdk_linux_demo' failed
make[5]: *** [vision_sdk_linux_demo] Error 2
MAKEFILE_adas.MK:5: recipe for target 'apps' failed
make[4]: *** [apps] Error 2
Makefile:183: recipe for target 'apps_exe_hlos' failed
make[3]: *** [apps_exe_hlos] Error 2
Makefile:64: recipe for target 'apps_hlos' failed
make[2]: *** [apps_hlos] Error 2
Makefile:36: recipe for target 'apps' failed
make[1]: *** [apps] Error 2
Makefile:12: recipe for target 'vision_sdk' failed
make: *** [vision_sdk] Error 2
I do the build according to this document.(VisionSDK_Linux_UserGuide.pdf)
the TDA2PXEVM board works well with Linux.
So I wanted to import RTOS usecase and test it on linux.
In order to merge on linux, I refer to this documents.(VisionSDK_UserGuide_UsecaseGen.pdf, VisionSDK_UserGuide_BuildSystem.pdf)
please check the Error
    I can see the error is coming  chains_issMultCaptIspSimcop_Stereo_priv.h file not from the usecase which you have added.
    Can you try to make your usecase inclusion as no in below file
    vision_sdk\$(MAKEAPPNAME)\configs\$(MAKECONFIG)\uc_cfg.mk
    Confirm by doing make showconfig and check your usecase is not added and then try to build.
    Anuj
  • HI Anuj
    I check the uc_cfg.mk file and make show config.
    I don't have idea.
    please check the file and make show config.
    - uc_cfg.mk
    UC_srv_calibration=yes
    UC_csi2Cal_multi_cam_view=yes
    UC_csi2Cal_multi_cam_3d_srv=yes
    #kyungtae.oh modify
    UC_iss_mult_capture_isp_simcop_stereo_tda2px=yes
    ifeq ($(ISS_INCLUDE),yes)
    UC_iss_capture_isp_simcop_display=yes
    UC_iss_multi_cam_isp_sgx_3d_srv_display=yes
    UC_iss_multi_cam_isp_sgx_2mp_3d_srv=yes
    endif
    UC_vip_single_cam_connectorLinksA15_sgx_display=yes
    UC_vip_single_cam_enc_dec_sgx_display=yes
    UC_vip_single_cam_framecopy_sgx_display=yes
    UC_vip_single_cam_framecopyEve_sgx_display=yes
    UC_vip_single_cam_sgx_display=yes
    UC_lvds_vip_multi_cam_3d_srv=yes
    UC_lvds_vip_multi_cam_view_sgx_display=yes
    ifeq ($(AVB_INCLUDE),yes)
    UC_avb_rx_multi_cam_decode_sgx_display=yes
    endif
    - make show config
    make -C /home/kyungtae.oh/ti/sdk/PROCESSOR_SDK_VISION/vision_sdk/apps/configs -f build_makeconfig.mk showconfig
    make[1]: Entering directory '/home/kyungtae.oh/ti/sdk/PROCESSOR_SDK_VISION/vision_sdk/apps/configs'
    # Build Config is [ tda2px_evm_linux_all ]
    # Build Config file is @ /home/kyungtae.oh/ti/sdk/PROCESSOR_SDK_VISION/vision_sdk/configs/tda2px_evm_linux_all/cfg.mk
    # Build Config .h file is @ /home/kyungtae.oh/ti/sdk/PROCESSOR_SDK_VISION/vision_sdk/links_fw/include/config/apps/tda2px_evm_linux_all/system_cfg.h
    # Build CPUs is @ ipu2 a15_0 dsp1 dsp2 eve1 eve2
    # CPUs included in application,
    # PROC_IPU1_0_INCLUDE=no
    # PROC_IPU1_1_INCLUDE=no
    # PROC_IPU2_INCLUDE=yes
    # PROC_DSP1_INCLUDE=yes
    # PROC_DSP2_INCLUDE=yes
    # PROC_EVE1_INCLUDE=yes
    # PROC_EVE2_INCLUDE=yes
    # PROC_EVE3_INCLUDE=no
    # PROC_EVE4_INCLUDE=no
    # PROC_A15_0_INCLUDE=yes
    # Platform config,
    # VSDK_BOARD_TYPE=TDA2PX_EVM [options: TDA2XX_EVM TDA2EX_EVM TDA3XX_EVM TDA3XX_RVP TDA2XX_RVP]
    # PLATFORM=tda2px-evm
    # DUAL_A15_SMP_BIOS=no
    # DDR_MEM=DDR_MEM_1024M [options: DDR_MEM_128M DDR_MEM_512M DDR_MEM_1024M]
    # NDK_PROC_TO_USE=none [options: a15_0 ipu1_0 ipu1_1 ipu2 none]
    # NSP_TFDTP_INCLUDE=no [options: yes no]
    # TDA2EX_ETHSRV_BOARD=no [options: yes no]
    # FATFS_PROC_TO_USE=none [options: ipu1_0 none]
    # RADAR_BOARD=none [options: TDA3XX_AR12_ALPS TDA3XX_AR12_VIB_DAB_BOOSTER TDA3XX_RADAR_RVP none]
    # Build config,
    # BUILD_OS=Linux [options: Windows_NT Linux]
    # BUILD_DEPENDENCY_ALWAYS=no
    # BUILD_ALGORITHMS=no
    # BUILD_INFOADAS=no
    # PROFILE=release [options: debug release]
    # KW_BUILD=no
    # CPLUSPLUS_BUILD=no
    # IPU_PRIMARY_CORE=ipu2 [options: ipu1_0 ipu2]
    # IPU_SECONDARY_CORE=ipu1_0 [options: ipu1_0 ipu2]
    # A15_TARGET_OS=Linux [options: Bios Linux Qnx]
    # BSP_STW_PACKAGE_SELECT=all [options: all vps-iss-dss-only vps-vip-vpe]
    # Safety Module config,
    # RTI_INCLUDE=no
    # ECC_FFI_INCLUDE=no
    # DCC_ESM_INCLUDE=no
    # Video Module config,
    # IVAHD_INCLUDE=yes
    # VPE_INCLUDE=yes
    # CAL_INCLUDE=yes
    # ISS_INCLUDE=yes
    # ISS_ENABLE_DEBUG_TAPS=no
    # WDR_LDC_INCLUDE=no
    # DSS_INCLUDE=yes
    # Open Compute config,
    # OPENCL_INCLUDE=no
    # TARGET_ROOTDIR=/home/kyungtae.oh/ti/sdk/PROCESSOR_SDK_VISION/vision_sdk/../ti_components/os_tools/linux/targetfs
    # ENABLE_OPENCV=no
    # ENABLE_OPENCV_TESTS=no
    # OPENVX_INCLUDE=no
    # Log config,
    # ENABLE_UART_LOG=yes
    # ENABLE_NETWORK_LOG=no
    # ENABLE_CCS_LOG=no
    # CIO_REDIRECT=yes
    # IPC config,
    # WORKQ_INCLUDE=no
    # IPC_LIB_INCLUDE=no
    # Surround View config,
    # SRV_FAST_BOOT_INCLUDE=no
    # Other Module config,
    # AVB_INCLUDE=no
    # DCAN_INCLUDE=no
    # RADAR_INCLUDE=no
    # CPU_IDLE_ENABLED=yes
    # FAST_BOOT_INCLUDE=no
    # DATA_VIS_INCLUDE=no
    # HS_DEVICE=no
    # ULTRASONIC_INCLUDE=no
    # Linux config,
    # DEFAULT_UBOOT_CONFIG=dra7xx_evm_vision_config
    # DEFAULT_KERNEL_CONFIG=ti_sdk_dra7x_release_defconfig
    # DEFAULT_DTB=dra76-evm-infoadas.dtb
    # CMEM_INCLUDE=yes
    # IPUMM_INCLUDE=no
    # IPU1_EVELOADER_INCLUDE=yes
    # ROBUST_RVC_INCLUDE=no
    # BUILD_ADAM_CAR=no
    # Alg plugins included in build,
    # ALG_autocalibration ALG_census ALG_disparityhamdist ALG_dmaSwMs ALG_framecopy ALG_remapmerge ALG_sceneobstruction ALG_stereo_postprocessing ALG_surroundview ALG_iss_aewb
    # Use-cases included in build,
    # UC_iss_capture_isp_simcop_display UC_srv_calibration UC_lvds_vip_multi_cam_3d_srv UC_csi2Cal_multi_cam_3d_srv UC_csi2Cal_multi_cam_view UC_lvds_vip_multi_cam_view_sgx_display UC_vip_single_cam_connectorLinksA15_sgx_display UC_vip_single_cam_enc_dec_sgx_display UC_vip_single_cam_framecopy_sgx_display UC_vip_single_cam_framecopyEve_sgx_display UC_vip_single_cam_sgx_display UC_iss_mult_capture_isp_simcop_stereo_tda2px UC_iss_multi_cam_isp_sgx_3d_srv_display UC_iss_multi_cam_isp_sgx_2mp_3d_srv
    make -s -fbuild_makeconfig.mk check_cpu_include
    make[2]: Entering directory '/home/kyungtae.oh/ti/sdk/PROCESSOR_SDK_VISION/vision_sdk/apps/configs'
    # CPUs that are NOT required but included in config [ tda2px_evm_linux_all ],
    # WARNING: DSP2 can be excluded from application
    # WARNING: EVE2 can be excluded from application
    # CPUs that are required but not included in config [ tda2px_evm_linux_all ],
    # ERROR: IPU1_0 MUST be included in application
    # Edit /home/kyungtae.oh/ti/sdk/PROCESSOR_SDK_VISION/vision_sdk/build/configs/tda2px_evm_linux_all/cfg.mk to include or exclude CPUs in an application
    make[2]: Leaving directory '/home/kyungtae.oh/ti/sdk/PROCESSOR_SDK_VISION/vision_sdk/apps/configs'
    make[1]: Leaving directory '/home/kyungtae.oh/ti/sdk/PROCESSOR_SDK_VISION/vision_sdk/apps/configs'
    thanks
    kyungtae
    The error is coming due to UC_iss_mult_capture_isp_simcop_stereo_tda2px usecase.
    Please make that as no.
    Anuj
  • Hi, Anuj
    UC_iss_mult_capture_isp_simcop_stereo_tda2px is UC_iss_mult_capture_isp_simcop_streo_tda3xx.
    we changeed the name to distinguish RTOS usecase and HLOS usecase.
    the explanation is as follows.
    1. create folder
    vision_sdk\apps\src\hlos\adas\src\usecases\iss_mult_capture_isp_simcop_stereo_tda2px
    2. add *.c and *.h files
    3. add MAKEFILE.MK
    4. Add cfg.mk
    5. Add make config : UC_LIST in cfg.mk, UC_iss_mult_capture_isp_simcop_stereo_tda2px in uc_cfg.mk
    6. make show config
    7. add menu-item string(vision_sdk\apps\src\hlos\adas\src\common\chains_main_linux_iss.c)
    8. add chain main function(vision_sdk\apps\src\hlos\adas\include\chains.h)
    9. add MAKEFILE_adas.MK
    but we have the Error.
    RTOS usecase don't change the HLOS usecase.
    check the this problem.
    thanks
    Your compilation is getting fail die to vps_isscommon.h file.
    can you just check whether you have this file or not?
    And the path for that file has been added in the makefile.
    Anuj
    Have you verified the above things?
    Anuj
