Part Number: PROCESSOR-SDK-AM335X
With PSDK 03.00.00.04, "reboot -f" stops rebooting procedure.
With below three steps, the issue can be reproduced.
[Step 1] - log file (
root@am335x-evm:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.12-g3639bea54a (gtbldadm@ubuntu-16) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 PREEMPT Fri Jul 8 19:29:44 EDT 2016
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: TI AM335x BeagleBone Black
[ 0.000000] cma: Reserved 24 MiB at 0x9e800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 131072
[ 0.000000] free_area_init_node: node 0, pgdat c09fce6c, node_mem_map de36d000
[ 0.000000] Normal zone: 1152 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.0 (sgx neon )
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=00095756-02 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 483948K/524288K available (7095K kernel code, 292K rwdata, 2520K rodata, 292K init, 263K bss, 15764K reserved, 24576K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc096c034 (9617 kB)
.init : 0xc096d000 - 0xc09b6000 ( 292 kB)
.data : 0xc09b6000 - 0xc09ff248 ( 293 kB)
.bss : 0xc0a01000 - 0xc0a42ed8 ( 264 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000013] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000033] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000041] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000381] clocksource_probe: no matching clocksources found
[ 0.000532] Console: colour dummy device 80x30
[ 0.000556] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000562] This ensures that you still see kernel messages. Please
[ 0.000566] update your kernel commandline.
[ 0.000581] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[ 0.089229] pid_max: default: 32768 minimum: 301
[ 0.089340] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089350] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089956] Initializing cgroup subsys io
[ 0.089984] Initializing cgroup subsys memory
[ 0.090015] Initializing cgroup subsys devices
[ 0.090029] Initializing cgroup subsys freezer
[ 0.090042] Initializing cgroup subsys perf_event
[ 0.090052] Initializing cgroup subsys pids
[ 0.090075] CPU: Testing write buffer coherency: ok
[ 0.090434] Setting up static identity map for 0x80008200 - 0x80008258
[ 0.092185] devtmpfs: initialized
[ 0.101072] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.113480] omap_hwmod: debugss: _wait_target_disable failed
[ 0.168205] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.170183] pinctrl core: initialized pinctrl subsystem
[ 0.171351] NET: Registered protocol family 16
[ 0.173162] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.199220] cpuidle: using governor ladder
[ 0.229209] cpuidle: using governor menu
[ 0.233079] OMAP GPIO hardware version 0.1
[ 0.241640] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.276365] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.278986] vgaarb: loaded
[ 0.279573] SCSI subsystem initialized
[ 0.279841] usbcore: registered new interface driver usbfs
[ 0.279901] usbcore: registered new interface driver hub
[ 0.279998] usbcore: registered new device driver usb
[ 0.280480] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.280533] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe
[ 0.280635] media: Linux media interface: v0.10
[ 0.280687] Linux video capture interface: v2.00
[ 0.280730] pps_core: LinuxPPS API ver. 1 registered
[ 0.280736] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.280762] PTP clock support registered
[ 0.280942] EDAC MC: Ver: 3.0.0
[ 0.281946] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.282221] Advanced Linux Sound Architecture Driver Initialized.
[ 0.283247] clocksource: Switched to clocksource timer1
[ 0.292451] NET: Registered protocol family 2
[ 0.293125] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.293172] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.293210] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.293335] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.293360] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.293494] NET: Registered protocol family 1
[ 0.293834] RPC: Registered named UNIX socket transport module.
[ 0.293846] RPC: Registered udp transport module.
[ 0.293852] RPC: Registered tcp transport module.
[ 0.293857] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.293887] PCI: CLS 0 bytes, default 64
[ 0.294734] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.296395] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.303524] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.304228] NFS: Registering the id_resolver key type
[ 0.304303] Key type id_resolver registered
[ 0.304309] Key type id_legacy registered
[ 0.304371] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.306077] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.306101] io scheduler noop registered
[ 0.306112] io scheduler deadline registered
[ 0.306249] io scheduler cfq registered (default)
[ 0.307579] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.360789] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.364561] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250
[ 0.994441] console [ttyS0] enabled
[ 0.998842] [drm] Initialized drm 1.1.0 20060810
[ 1.010550] loop: module loaded
[ 1.015963] libphy: Fixed MDIO Bus: probed
[ 1.083312] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 1.089448] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 1.096479] libphy: 4a101000.mdio: probed
[ 1.100519] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 1.110401] cpsw 4a100000.ethernet: Detected MACID = 90:59:af:5c:1a:bd
[ 1.117931] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.125568] usbcore: registered new interface driver pegasus
[ 1.131326] usbcore: registered new interface driver asix
[ 1.136843] usbcore: registered new interface driver ax88179_178a
[ 1.143004] usbcore: registered new interface driver cdc_ether
[ 1.148955] usbcore: registered new interface driver smsc75xx
[ 1.154800] usbcore: registered new interface driver smsc95xx
[ 1.160611] usbcore: registered new interface driver net1080
[ 1.166348] usbcore: registered new interface driver cdc_subset
[ 1.172338] usbcore: registered new interface driver zaurus
[ 1.178043] usbcore: registered new interface driver cdc_ncm
[ 1.184373] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.190940] ehci-pci: EHCI PCI platform driver
[ 1.195495] ehci-platform: EHCI generic platform driver
[ 1.200917] ehci-omap: OMAP-EHCI Host Controller driver
[ 1.206288] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.212528] ohci-pci: OHCI PCI platform driver
[ 1.217071] ohci-platform: OHCI generic platform driver
[ 1.222713] usbcore: registered new interface driver usb-storage
[ 1.229168] mousedev: PS/2 mouse device common for all mice
[ 1.235566] i2c /dev entries driver
[ 1.240357] cpuidle: enable-method property 'ti,am3352' found operations
[ 1.247362] sdhci: Secure Digital Host Controller Interface driver
[ 1.253609] sdhci: Copyright(c) Pierre Ossman
[ 1.258520] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 1.340534] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.348848] Synopsys Designware Multimedia Card Interface Driver
[ 1.355395] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.361177] mmc0: new high speed SDHC card at address 0007
[ 1.367967] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.374671] mmcblk0: mmc0:0007 SD04G 3.71 GiB
[ 1.379742] usbcore: registered new interface driver usbhid
[ 1.385731] usbhid: USB HID core driver
[ 1.389696] mmcblk0: p1 p2
[ 1.396498] NET: Registered protocol family 10
[ 1.405379] sit: IPv6 over IPv4 tunneling driver
[ 1.410880] NET: Registered protocol family 17
[ 1.415847] Key type dns_resolver registered
[ 1.420356] omap_voltage_late_init: Voltage driver support not added
[ 1.430914] ThumbEE CPU extension supported.
[ 1.435314] Registering SWP/SWPB emulation handler
[ 1.466472] mmc1: MAN_BKOPS_EN bit is not set
[ 1.472794] mmc1: new high speed MMC card at address 0001
[ 1.479398] mmcblk1: mmc1:0001 MMC02G 1.79 GiB
[ 1.484435] mmcblk1boot0: mmc1:0001 MMC02G partition 1 1.00 MiB
[ 1.491217] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 1.496704] mmcblk1boot1: mmc1:0001 MMC02G partition 2 1.00 MiB
[ 1.503324] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.512342] mmcblk1: p1
[ 1.635607] tda998x 0-0070: found TDA19988
[ 1.641049] tilcdc 4830e000.lcdc: bound 0-0070 (ops tda998x_ops)
[ 1.647144] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.653798] [drm] No driver support for vblank timestamp query.
[ 1.660090] tilcdc 4830e000.lcdc: No connectors reported connected with modes
[ 1.667298] [drm] Cannot find any crtc or sizes - going 1024x768
[ 1.681760] Console: switching to colour frame buffer device 128x48
[ 1.693372] tilcdc 4830e000.lcdc: fb0: frame buffer device
[ 1.723277] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[ 1.729205] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.736116] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.743198] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.750353] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.757437] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.764383] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 1.772061] hctosys: unable to open rtc device (rtc0)
[ 1.780629] ALSA device list:
[ 1.783774] No soundcards found.
[ 1.812640] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.820910] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.830795] devtmpfs: mounted
[ 1.834132] Freeing unused kernel memory: 292K (c096d000 - c09b6000)
[ 1.840671] This architecture does not have kernel memory protection.
[ 2.176665] systemd[1]: System time before build time, advancing clock.
[ 2.250952] random: systemd urandom read with 18 bits of entropy available
[ 2.277370] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 2.296501] systemd[1]: Detected architecture arm.
[ 2.325482] systemd[1]: Set hostname to <am335x-evm>.
[ 2.959150] systemd[1]: [/lib/systemd/system/gadget-init.service:15] Unknown lvalue 'ExecStopPre' in section 'Service'
[ 3.288666] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
[ 3.296642] systemd[1]: sysinit.target: Found dependency on alignment.service/start
[ 3.304469] systemd[1]: sysinit.target: Found dependency on basic.target/start
[ 3.311737] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
[ 3.319207] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
[ 3.328680] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
[ 3.369246] systemd[1]: Reached target Remote File Systems.
[ 3.394245] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.423984] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.453967] systemd[1]: Listening on Journal Socket.
[ 3.483740] systemd[1]: Reached target Swap.
[ 3.503857] systemd[1]: Listening on Syslog Socket.
[ 3.535958] systemd[1]: Created slice System Slice.
[ 3.568008] systemd[1]: Mounting Debug File System...
[ 3.609053] systemd[1]: Starting Setup Virtual Console...
[ 3.689857] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 3.749583] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.805537] systemd[1]: Created slice User and Session Slice.
[ 3.822920] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.844029] systemd[1]: Reached target Slices.
[ 3.888289] systemd[1]: Mounting Temporary Directory...
[ 3.927742] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.973979] systemd[1]: Listening on udev Control Socket.
[ 4.005002] systemd[1]: Created slice system-getty.slice.
[ 4.033948] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.063583] systemd[1]: Reached target Paths.
[ 4.099607] systemd[1]: Starting Load Kernel Modules...
[ 4.133962] systemd[1]: Listening on udev Kernel Socket.
[ 4.147638] systemd[1]: Listening on Network Service Netlink Socket.
[ 4.154500] cryptodev: driver 1.8 loaded.
[ 4.197945] systemd[1]: Starting Journal Service...
[ 4.235737] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 4.264175] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 4.343216] systemd[1]: Mounted Debug File System.
[ 4.394109] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.423900] systemd[1]: Mounted Temporary Directory.
[ 4.454500] systemd[1]: Started Journal Service.
[ 5.894026] systemd-journald[107]: Received request to flush runtime journal from PID 1
[ 7.970556] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 8.048019] 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 8.181409] omap_rtc 44e3e000.rtc: already running
[ 8.223881] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 8.284178] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 8.551575] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 9.529370] ti-pruss 4a300000.pruss: creating PRU cores and other child platform devices
[ 9.663826] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 9.692827] remoteproc0: 4a334000.pru0 is available
[ 9.779828] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 9.787425] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 9.903452] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 10.057534] remoteproc0: registered virtio0 (type 7)
[ 10.062695] pru-rproc 4a334000.pru0: PRU rproc node /ocp/pruss@4a300000/pru0@4a334000 probed successfully
[ 10.100861] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
[ 10.140835] remoteproc1: wkup_m3 is available
[ 10.199275] remoteproc2: 4a338000.pru1 is available
[ 10.208853] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 10.239958] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 10.268767] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 10.302958] PM: Cannot get wkup_m3_ipc handle
[ 10.319237] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 10.393413] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 10.475211] PM: bootloader does not support rtc-only!
[ 10.482985] remoteproc1: powering up wkup_m3
[ 10.555821] remoteproc2: registered virtio1 (type 7)
[ 10.560984] pru-rproc 4a338000.pru1: PRU rproc node /ocp/pruss@4a300000/pru1@4a338000 probed successfully
[ 10.573521] remoteproc1: Booting fw image am335x-pm-firmware.elf, size 216252
[ 10.581050] remoteproc1: remote processor wkup_m3 is now up
[ 10.586750] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x191
[ 10.816138] asoc-simple-card sound: i2s-hifi <-> 48038000.mcasp mapping ok
[ 11.091650] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 13.191867] Bluetooth: Core ver 2.21
[ 13.283581] NET: Registered protocol family 31
[ 13.288072] Bluetooth: HCI device and connection manager initialized
[ 13.400215] Bluetooth: HCI socket layer initialized
[ 13.465892] Bluetooth: L2CAP socket layer initialized
[ 13.592315] Bluetooth: SCO socket layer initialized
[ 13.720998] random: nonblocking pool is initialized
[ 13.796965] net eth0: initializing cpsw version 1.12 (0)
[ 13.864115] net eth0: initialized cpsw ale version 1.4
[ 13.957197] net eth0: phy found : id is : 0x7c0f1
[ 14.010537] libphy: PHY 4a101000.mdio:01 not found
[ 14.067311] net eth0: phy "4a101000.mdio:01" not found on slave 1, err -19
[ 14.210441] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.347713] NET: Registered protocol family 15
[ 15.151466] Initializing XFRM netlink socket
[ 15.368156] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 15.368186] musb-hdrc: MHDRC RTL version 2.0
[ 15.368195] musb-hdrc: setup fifo_mode 4
[ 15.368213] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 15.472370] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 15.472399] musb-hdrc: MHDRC RTL version 2.0
[ 15.472408] musb-hdrc: setup fifo_mode 4
[ 15.472426] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 15.472569] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
[ 15.547632] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 1
[ 15.637447] hub 1-0:1.0: USB hub found
[ 15.689906] hub 1-0:1.0: 1 port detected
[ 15.923775] remoteproc0: powering up 4a334000.pru0
[ 15.929267] remoteproc0: Booting fw image am335x-pru0-fw, size 80252
[ 16.063617] ti-pruss 4a300000.pruss: configured system_events = 0x1000000000000000 intr_channels = 0x00000001 host_intr = 0x00000001
[ 16.189361] remoteproc0: remote processor 4a334000.pru0 is now up
[ 16.243116] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
[ 16.250287] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 16.285440] remoteproc2: powering up 4a338000.pru1
[ 16.290929] remoteproc2: Booting fw image am335x-pru1-fw, size 80252
[ 16.373574] ti-pruss 4a300000.pruss: configured system_events = 0x0800000000000000 intr_channels = 0x00000002 host_intr = 0x00000002
[ 16.472861] remoteproc2: remote processor 4a338000.pru1 is now up
[ 16.533774] virtio_rpmsg_bus virtio1: creating channel rpmsg-pru addr 0x1f
[ 16.540775] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 16.664314] rpmsg_pru rpmsg0: new rpmsg_pru device: /dev/rpmsg_pru30
[ 16.714413] rpmsg_pru rpmsg1: new rpmsg_pru device: /dev/rpmsg_pru31
[ 16.974054] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 17.014960] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 19.879135] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
root@am335x-evm:~#
root@am335x-evm:~#
root@am335x-evm:~# halt --reboot
[ OK ] Stopped target Sound Card.
Stopping Save/Restore Sound Card State...
[ OK ] Stopped target Timers.
[ OK ] Stopped target Swap.
[ OK ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Stopped target System Time Synchronized.
Stopping Load/Save Random Seed...
Stopping User Manager fo Stopping Session c1 of user root.
[ OK ] Stopped Setup Virtual Console.
[ OK ] Stopped Daily Cleanup of Temporary Directories.
[ OK ] Stopped Synchronize System and HW clocks.
Stopping Network Time Synchronization...
[ OK ] Stopped Update UTMP about System Runlevel Changes.
[ OK ] Stopped target Multi-User System.
Stopping gplv3-notice.service...
Stopping Lightning Fast Webserver With Light System Requirements...
Stopping System Logging Service...
Stopping Telephony service...
Stopping Avahi mDNS/DNS-SD Stack...
[ OK ] Stopped target Login Prompts.
Stopping Serial Getty on ttyS3...
[ OK ] Stopped Serial Getty on ttyGS0.
Stopping Serial Getty on ttyS0...
[ OK ] Stopped Serial Getty on ttyO3.
[ OK ] Stopped Serial Getty on ttyO0.
Stopping Network Name Resolution...
Stopping Kernel Logging Service...
Stopping Getty on tty1...
Stopping strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf...
Stopping Update UTMP about System Boot/Shutdown...
[ OK ] Stopped Kernel Logging Service.
[ OK ] Stopped Telephony service.
[ OK ] Stopped Avahi mDNS/DNS-SD Stack.
[ OK ] Stopped strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
[ OK ] Stopped System Logging Service.
[ OK ] Stopped Getty on tty1.
[ OK ] Stopped Serial Getty on ttyS0.
[ OK ] Stopped Network Name Resolution.
[ OK ] Stopped Lightning Fast Webserver With Light System Requirements.
[ OK ] Stopped Serial Getty on ttyS3.
[ OK ] Stopped User Manager for UID 0.
[ OK ] Stopped Session c1 of user root.
[ OK ] Removed slice User Slice of root.
Stopping Login Service...
[ OK ] Stopped target Network.
Stopping Network Service...
[ OK ] Removed slice system-serial\x2dgetty.slice.
Stopping Permit User Sessions...
[ OK ] Removed slice system-getty.slice.
[ OK ] Stopped Login Service.
[ OK ] Stopped Network Service.
[ OK ] Stopped Load/Save Random Seed.
Stopping D-Bus System Message Bus...
[ OK ] Stopped Apply Kernel Variables.
[ OK ] Stopped Load Kernel Modules.
[ OK ] Stopped D-Bus System Message Bus.
[ OK ] Stopped Save/Restore Sound Card State.
[ OK ] Stopped Update UTMP about System Boot/Shutdown.
[ OK ] Stopped Permit User Sessions.
[ OK ] Stopped Network Time Synchronization.
[ OK ] Stopped Create Volatile Files and Directories.
[ OK ] Stopped target Local File Systems.
Unmounting /run/media/mmcblk1p1...
Unmounting /var/volatile...
Unmounting /media/ram...
Unmounting /run/user/0...
Unmounting /run/media/mmcblk0p1...
[ OK ] Unmounted /run/media/mmcblk1p1.
[ OK ] Unmounted /var/volatile.
[ OK ] Unmounted /media/ram.
[ OK ] Unmounted /run/user/0.
[ OK ] Unmounted /run/media/mmcblk0p1.
[ OK ] Stopped gplv3-notice.service.
Stopping thermal-zone-init.service...
Stopping parse-ip.service...
[ OK ] Stopped target Local File Systems (Pre).
[ OK ] Stopped Remount Root and Kernel File Systems.
[ OK ] Stopped Create Static Device Nodes in /dev.
[ OK ] Stopped thermal-zone-init.service.
[ OK ] Stopped parse-ip.service.
Stopping matrix-gui-2.0.service...
[ OK ] Stopped matrix-gui-2.0.service.
Stopping rng-tools.service...
[ OK ] Stopped rng-tools.service.
Stopping thttpd.service...
Stopping busybox-udhcpd.service...
[ OK ] Stopped thttpd.service.
[ OK ] Stopped busybox-udhcpd.service.
Stopping telnetd.service...
[ OK ] Stopped telnetd.service.
Stopping weston.service...
[ OK ] Stopped weston.service.
Stopping rc.pvr.service...
[ OK ] Stopped target Remote File Systems.
[ OK ] Stopped rc.pvr.service.
Stopping uim-sysfs.service...
[ OK ] Stopped uim-sysfs.service.
[ OK ] Stopped target Basic System.
[ OK ] Stopped target Paths.
[ OK ] Stopped Dispatch Password Requests to Console Directory Watch.
[ OK ] Stopped Forward Password Requests to Wall Directory Watch.
[ OK ] Stopped target Sockets.
[ OK ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Closed D-Bus System Message Bus Socket.
[ OK ] Closed dropbear.socket.
[ OK ] Closed RPCbind Server Activation Socket.
[ OK ] Closed Syslog Socket.
[ OK ] Stopped target Slices.
[ OK ] Removed slice User and Session Slice.
[ OK ] Reached target Shutdown.
Unmounting Temporary Directory...
[ OK ] Unmounted Temporary Directory.
[ OK ] Reached target Unmount All Filesystems.
[ OK ] Reached target Final Step.
Starting Reboot...
[ 75.744049] watchdog watchdog0: watchdog did not stop!
[ 75.782650] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[ 75.810115] systemd-journald[107]: Received SIGTERM from PID 1 (systemd-shutdow).
[ 85.833770] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[ 85.877564] systemd-shutdown[1]: Sending SIGKILL to PID 726 (rngd).
[ 85.901431] systemd-shutdown[1]: Hardware watchdog 'OMAP Watchdog', version 0
[ 85.912776] systemd-shutdown[1]: Unmounting file systems.
[ 85.920962] systemd-shutdown[1]: Remounting '/' read-only with options 'data=ordered'.
[ 93.777169] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 93.801062] systemd-shutdown[1]: Remounting '/' read-only with options 'data=ordered'.
[ 93.812102] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 93.818563] systemd-shutdown[1]: All filesystems unmounted.
[ 93.824275] systemd-shutdown[1]: Deactivating swaps.
[ 93.830001] systemd-shutdown[1]: All swaps deactivated.
[ 93.835491] systemd-shutdown[1]: Detaching loop devices.
[ 93.861292] systemd-shutdown[1]: All loop devices detached.
[ 93.867195] systemd-shutdown[1]: Detaching DM devices.
[ 93.874162] systemd-shutdown[1]: All DM devices detached.
[ 93.899376] systemd-shutdown[1]: Rebooting.
[ 93.904224] musb-hdrc musb-hdrc.2.auto: remove, state 4
[ 93.909538] usb usb1: USB disconnect, device number 1
[ 93.915984] musb-hdrc musb-hdrc.2.auto: USB bus 1 deregistered
[ 93.927280] reboot: Restarting system
U-Boot SPL 2016.05-gb4e185a8c3 (Jul 08 2016 - 19:27:52)
Trying to boot from MMC1
reading args
spl_load_image_fat_os: error reading image args, err - -1
reading u-boot.img
reading u-boot.img
reading u-boot.img
reading u-boot.img
U-Boot 2016.05-gb4e185a8c3 (Jul 08 2016 - 19:27:52 -0400)
Watchdog enabled
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
reading uboot.env
** Unable to read "uboot.env" from mmc0:1 **
Using default environment
<ethaddr> not set. Validating first E-fuse MAC
Net: eth0: ethernet@4a100000
Warning: usb_ether MAC addresses don't match:
Address in SROM is de:ad:be:ef:00:01
Address in environment is 90:59:af:5c:1a:bf
, eth1: usb_ether
Press SPACE to abort autoboot in 2 seconds
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
** Unable to read file uEnv.txt **
Scanning mmc 0:1...
reading boot.scr
reading uEnv.txt
3664216 bytes read in 272 ms (12.8 MiB/s)
36841 bytes read in 89 ms (403.3 KiB/s)
Kernel image @ 0x82000000 [ 0x000000 - 0x37e958 ]
Loading Device Tree to 8fff4000, end 8fffffe8 ... OK
Starting kernel ...
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc096c034 (9617 kB)
[ 0.000000] .init : 0xc096d000 - 0xc09b6000 ( 292 kB)
[ 0.000000] .data : 0xc09b6000 - 0xc09ff248 ( 293 kB)
[ 0.000000] .bss : 0xc0a01000 - 0xc0a42ed8 ( 264 kB)
[ 0.000016] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000035] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000044] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000536] Console: colour dummy device 80x30
[ 0.000559] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000564] This ensures that you still see kernel messages. Please
[ 0.000569] update your kernel commandline.
[ 0.000584] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[ 0.089237] pid_max: default: 32768 minimum: 301
[ 0.089347] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089357] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089962] Initializing cgroup subsys io
[ 0.089992] Initializing cgroup subsys memory
[ 0.090023] Initializing cgroup subsys devices
[ 0.090036] Initializing cgroup subsys freezer
[ 0.090049] Initializing cgroup subsys perf_event
[ 0.090059] Initializing cgroup subsys pids
[ 0.090085] CPU: Testing write buffer coherency: ok
[ 0.090436] Setting up static identity map for 0x80008200 - 0x80008258
[ 0.092187] devtmpfs: initialized
[ 0.101056] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.113476] omap_hwmod: debugss: _wait_target_disable failed
[ 0.168209] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.170214] pinctrl core: initialized pinctrl subsystem
[ 0.171396] NET: Registered protocol family 16
[ 0.173195] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.199231] cpuidle: using governor ladder
[ 0.229216] cpuidle: using governor menu
[ 0.233075] OMAP GPIO hardware version 0.1
[ 0.241636] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.276377] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.278999] vgaarb: loaded
[ 0.279585] SCSI subsystem initialized
[ 0.279857] usbcore: registered new interface driver usbfs
[ 0.279917] usbcore: registered new interface driver hub
[ 0.280010] usbcore: registered new device driver usb
[ 0.280491] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.280541] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe
[ 0.280647] media: Linux media interface: v0.10
[ 0.280701] Linux video capture interface: v2.00
[ 0.280744] pps_core: LinuxPPS API ver. 1 registered
[ 0.280750] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.280775] PTP clock support registered
[ 0.280951] EDAC MC: Ver: 3.0.0
[ 0.281938] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.282214] Advanced Linux Sound Architecture Driver Initialized.
[ 0.283234] clocksource: Switched to clocksource timer1
[ 0.292469] NET: Registered protocol family 2
[ 0.293152] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.293198] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.293294] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.293368] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.293394] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.293526] NET: Registered protocol family 1
[ 0.293874] RPC: Registered named UNIX socket transport module.
[ 0.293885] RPC: Registered udp transport module.
[ 0.293891] RPC: Registered tcp transport module.
[ 0.293896] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.294774] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.296423] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.303583] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.304277] NFS: Registering the id_resolver key type
[ 0.304348] Key type id_resolver registered
[ 0.304354] Key type id_legacy registered
[ 0.304416] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.306113] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.306136] io scheduler noop registered
[ 0.306147] io scheduler deadline registered
[ 0.306281] io scheduler cfq registered (default)
[ 0.307613] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.360788] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.364557] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250
[ 0.994443] console [ttyS0] enabled
[ 0.998838] [drm] Initialized drm 1.1.0 20060810
[ 1.010584] loop: module loaded
[ 1.015985] libphy: Fixed MDIO Bus: probed
[ 1.083295] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 1.089433] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 1.096488] libphy: 4a101000.mdio: probed
[ 1.100528] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 1.110414] cpsw 4a100000.ethernet: Detected MACID = 90:59:af:5c:1a:bd
[ 1.117945] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.125586] usbcore: registered new interface driver pegasus
[ 1.131342] usbcore: registered new interface driver asix
[ 1.136858] usbcore: registered new interface driver ax88179_178a
[ 1.143018] usbcore: registered new interface driver cdc_ether
[ 1.148969] usbcore: registered new interface driver smsc75xx
[ 1.154814] usbcore: registered new interface driver smsc95xx
[ 1.160624] usbcore: registered new interface driver net1080
[ 1.166362] usbcore: registered new interface driver cdc_subset
[ 1.172352] usbcore: registered new interface driver zaurus
[ 1.178054] usbcore: registered new interface driver cdc_ncm
[ 1.184381] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.190947] ehci-pci: EHCI PCI platform driver
[ 1.200916] ehci-omap: OMAP-EHCI Host Controller driver
[ 1.206291] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.212532] ohci-pci: OHCI PCI platform driver
[ 1.217075] ohci-platform: OHCI generic platform driver
[ 1.222726] usbcore: registered new interface driver usb-storage
[ 1.229187] mousedev: PS/2 mouse device common for all mice
[ 1.235603] i2c /dev entries driver
[ 1.240381] cpuidle: enable-method property 'ti,am3352' found operations
[ 1.247382] sdhci: Secure Digital Host Controller Interface driver
[ 1.253628] sdhci: Copyright(c) Pierre Ossman
[ 1.258547] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 1.340519] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.348830] Synopsys Designware Multimedia Card Interface Driver
[ 1.355367] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.361145] mmc0: new high speed SDHC card at address 0007
[ 1.367944] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.374655] mmcblk0: mmc0:0007 SD04G 3.71 GiB
[ 1.379715] usbcore: registered new interface driver usbhid
[ 1.385700] usbhid: USB HID core driver
[ 1.389665] mmcblk0: p1 p2
[ 1.396427] NET: Registered protocol family 10
[ 1.405290] sit: IPv6 over IPv4 tunneling driver
[ 1.410818] NET: Registered protocol family 17
[ 1.415773] Key type dns_resolver registered
[ 1.420284] omap_voltage_late_init: Voltage driver support not added
[ 1.428891] ThumbEE CPU extension supported.
[ 1.435279] Registering SWP/SWPB emulation handler
[ 1.466465] mmc1: MAN_BKOPS_EN bit is not set
[ 1.472835] mmc1: new high speed MMC card at address 0001
[ 1.479417] mmcblk1: mmc1:0001 MMC02G 1.79 GiB
[ 1.485004] mmcblk1boot0: mmc1:0001 MMC02G partition 1 1.00 MiB
[ 1.491089] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 1.496944] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.503929] mmcblk1boot1: mmc1:0001 MMC02G partition 2 1.00 MiB
[ 1.511684] mmcblk1: p1
[ 1.635581] tda998x 0-0070: found TDA19988
[ 1.641024] tilcdc 4830e000.lcdc: bound 0-0070 (ops tda998x_ops)
[ 1.647125] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.653778] [drm] No driver support for vblank timestamp query.
[ 1.660059] tilcdc 4830e000.lcdc: No connectors reported connected with modes
[ 1.667260] [drm] Cannot find any crtc or sizes - going 1024x768
[ 1.681728] Console: switching to colour frame buffer device 128x48
[ 1.693341] tilcdc 4830e000.lcdc: fb0: frame buffer device
[ 1.723263] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[ 1.729188] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.736107] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.743185] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.750333] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.757413] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.764359] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 1.772024] hctosys: unable to open rtc device (rtc0)
[ 1.780598] ALSA device list:
[ 1.783751] No soundcards found.
[ 1.813770] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.821976] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.831901] devtmpfs: mounted
[ 1.835243] Freeing unused kernel memory: 292K (c096d000 - c09b6000)
[ 1.841776] This architecture does not have kernel memory protection.
[ 2.179858] systemd[1]: System time before build time, advancing clock.
[ 2.254053] random: systemd urandom read with 18 bits of entropy available
[ 2.280375] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 2.299520] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.05!
[ 2.325380] systemd[1]: Set hostname to <am335x-evm>.
[ 2.958600] systemd[1]: [/lib/systemd/system/gadget-init.service:15] Unknown lvalue 'ExecStopPre' in section 'Service'
[ 3.286277] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
[ 3.294232] systemd[1]: sysinit.target: Found dependency on alignment.service/start
[ 3.301952] systemd[1]: sysinit.target: Found dependency on basic.target/start
[ 3.309323] systemd[1]: sysinit.target: Found dependency on sockets.target/start
[ 3.316787] systemd[1]: sysinit.target: Found dependency on dropbear.socket/stop
[ 3.324244] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
[ 3.331686] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
[ 3.341152] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
[ SKIP ] Ordering cycle found, skipping alignment.service
[ 3.379895] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 3.404021] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 3.433885] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 3.466094] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 3.493632] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 3.523913] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 3.553589] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 3.575008] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 3.604102] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 3.633669] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 3.654023] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 3.683913] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 3.744411] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 3.775642] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 3.803736] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 3.825382] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 3.854168] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 3.888961] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.954107] systemd[1]: Starting Load Kernel Modules...
[ 3.999418] systemd[1]: Mounting Temporary Directory...
[ 4.025916] cryptodev: driver 1.8 loaded.
[ 4.059399] systemd[1]: Starting Journal Service...
[ 4.119139] systemd[1]: Mounting Debug File System...
[ 4.179098] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.247800] systemd[1]: Starting Setup Virtual Console...
[ 4.279405] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.328314] systemd[1]: Starting Create list of required static device nodes for the current kernel...
Starting Create list of required st... nodes for the current kernel...
[ 4.427768] systemd[1]: Mounted Debug File System.
[ OK ] Mounted Debug File System.
[ 4.453785] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 4.484488] systemd[1]: Mounted Temporary Directory.
[ OK ] Mounted Temporary Directory.
[ 4.514415] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Setup Virtual Console.el File Systems.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
Starting Create Static Device Nodes in /dev...
Starting udev Coldplug all Devices...
Starting Apply Kernel Variables...
Starting Flush Journal to Persistent Storage...
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Apply Kernel Variables.
[ 5.917239] systemd-journald[86]: Received request to flush runtime journal from PID 1
[ OK ] Started Flush Journal to Persistent Storage.
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started udev Coldplug all Devices.
[ 7.365562] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 7.468334] omap_rtc 44e3e000.rtc: already running
[ 7.504429] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 7.542782] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 7.645493] 47401b00.usb-phy supply vcc not found, using dummy regulator
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
[ 7.971671] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
Starting Create Volatile Files and Directories...
[ OK ] Started Load/Save Random Seed.
[ 8.235203] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ OK ] Found device /dev/ttyS0.
[ 8.430629] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 8.498584] ti-pruss 4a300000.pruss: creating PRU cores and other child platform devices
[ 8.574589] remoteproc0: wkup_m3 is available
[ 8.579079] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 8.614968] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
[ 8.638975] remoteproc1: 4a334000.pru0 is available
[ OK ] Started Create Volatile Files and Directories.
[ 8.727967] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 8.748582] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 8.784693] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 8.821593] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 8.844926] PM: Cannot get wkup_m3_ipc handle
[ 8.871666] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 8.919829] PM: Cannot get wkup_m3_ipc handle
[ 8.973914] PM: bootloader does not support rtc-only!
[ 8.979162] remoteproc0: powering up wkup_m3
[ 9.021721] asoc-simple-card sound: i2s-hifi <-> 48038000.mcasp mapping ok
[ 9.050449] remoteproc1: registered virtio0 (type 7)
[ 9.057522] remoteproc0: Booting fw image am335x-pm-firmware.elf, size 216252
[ 9.083588] pru-rproc 4a334000.pru0: PRU rproc node /ocp/pruss@4a300000/pru0@4a334000 probed successfully
[ 9.114216] remoteproc0: remote processor wkup_m3 is now up
[ 9.114235] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x191
[ 9.163770] remoteproc2: 4a338000.pru1 is available
[ 9.234362] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 9.363487] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 9.513222] remoteproc2: registered virtio1 (type 7)
[ 9.518501] pru-rproc 4a338000.pru1: PRU rproc node /ocp/pruss@4a300000/pru1@4a338000 probed successfully
[ OK ] Found device /dev/ttyS3.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Starting Network Time Synchronization...
[ 10.754541] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Network Time Synchronization.
[ OK ] Found device /dev/mmcblk0p1.
[ OK ] Started Update UTMP about System Boot/Shutdown.
Starting Synchronize System and HW clocks...
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Synchronize System and HW clocks.
[ 13.082666] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
[ 13.127923] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 1
[ 13.200042] hub 1-0:1.0: USB hub found
[ 13.240452] hub 1-0:1.0: 1 port detected
[ 13.280054] remoteproc1: powering up 4a334000.pru0
[ 13.327297] remoteproc1: Booting fw image am335x-pru0-fw, size 80252
[ 13.378881] ti-pruss 4a300000.pruss: configured system_events = 0x1000000000000000 intr_channels = 0x00000001 host_intr = 0x00000001
[ 13.434096] remoteproc1: remote processor 4a334000.pru0 is now up
[ 13.472947] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
[ 13.480295] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 13.489299] remoteproc2: powering up 4a338000.pru1
[ 13.505445] remoteproc2: Booting fw image am335x-pru1-fw, size 80252
[ 13.533504] ti-pruss 4a300000.pruss: configured system_events = 0x0800000000000000 intr_channels = 0x00000002 host_intr = 0x00000002
[ 13.556763] remoteproc2: remote processor 4a338000.pru1 is now up
[ 13.583902] virtio_rpmsg_bus virtio1: creating channel rpmsg-pru addr 0x1f
[ 13.591533] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 13.648147] rpmsg_pru rpmsg0: new rpmsg_pru device: /dev/rpmsg_pru30
[ 13.665743] rpmsg_pru rpmsg1: new rpmsg_pru device: /dev/rpmsg_pru31
[ OK ] Reached target Sound Card.
[ OK ] Reached target System Initialization.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on dropbear.socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Permit User Sessions...
[ OK ] Started D-Bus System Message Bus.
Starting Network Service...
Starting Start USB gadget...
Starting Save/Restore Sound Card State...
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started Kernel Logging Service.
[ 14.791524] random: nonblocking pool is initialized
Starting uim-sysfs.service...
[ 14.864596] net eth0: initializing cpsw version 1.12 (0)
[ 14.869984] net eth0: initialized cpsw ale version 1.4
Starting Telephony service...
[ 14.937337] net eth0: phy found : id is : 0x7c0f1
[ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
[ 15.030693] libphy: PHY 4a101000.mdio:01 not found
[ OK ] Started System Logging Service.
[ 15.067221] net eth0: phy "4a101000.mdio:01" not found on slave 1, err -19
Starting Login Service...
[ OK ] Started Network Service.
[ 15.259028] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 15.271899] using random self ethernet address
[ 15.290189] using random host ethernet address
[ OK ] Started Permit User Sessions.
[ 15.344009] using host ethernet address: 90:59:AF:5C:1A:BF
[ 15.349448] using random self ethernet address
[ OK ] Started Save/Restore Sound Card State.
[ 15.388751] Bluetooth: Core ver 2.21
[ 15.422635] NET: Registered protocol family 31
[ 15.433198] using random host ethernet address
[ 15.457904] Bluetooth: HCI device and connection manager initialized
[ 15.465979] using host ethernet address: 90:59:AF:5C:1A:BF
[ 15.497415] Bluetooth: HCI socket layer initialized
[ 15.502529] Bluetooth: L2CAP socket layer initialized
[ 15.514149] usb0: HOST MAC 90:59:af:5c:1a:bf
[ 15.551643] usb0: MAC 52:03:bc:07:f0:eb
[ 15.585844] Bluetooth: SCO socket layer initialized
[ 15.645485] Mass Storage Function, version: 2009/09/11
[ 15.650672] LUN: removable file: (no medium)
[ 15.720697] LUN: removable read only file: /dev/mmcblk0p1
[ 15.771621] Number of LUNs=1
[ 15.774875] NET: Registered protocol family 15
[ 15.803661] g_multi gadget: Multifunction Composite Gadget
[ 15.809197] g_multi gadget: g_multi ready
[ OK ] Found device /dev/ttyGS0.
[ 15.901213] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 16.395675] Initializing XFRM netlink socket
[ OK ] Started Start USB gadget.
[ 17.954069] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 17.962179] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Telephony service.
Mounting Configuration File System...
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyGS0.
[ OK ] Started Serial Getty on ttyS3.
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Reached target Network.
Starting Lightning Fast Webserver With Light System Requirements...
Starting Network Name Resolution...
[ OK ] Started Login Service.
[ OK ] Started Network Name Resolution.
[ OK ] Started Lightning Fast Webserver With Light System Requirements.
[ OK ] Started uim-sysfs.service.
Starting rc.pvr.service...
[ 20.613514] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[ OK ] Mounted Configuration File System.
[ OK ] Started rc.pvr.service.
Starting weston.service...
[ OK ] Started weston.service.
Starting telnetd.service...
[ OK ] Started telnetd.service.
Starting thttpd.service...
Starting busybox-udhcpd.service...
[ OK ] Started thttpd.service.
[ OK ] Started busybox-udhcpd.service.
Starting rng-tools.service...
[ OK ] Started rng-tools.service.
Starting matrix-gui-2.0.service...
[ OK ] Started matrix-gui-2.0.service.
Starting parse-ip.service...
Starting thermal-zone-init.service...
[ OK ] Started thermal-zone-init.service.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am335x-evm ttyS0
Arago 2016.05 am335x-evm ttyS0
am335x-evm login: root
root@am335x-evm:~#
With "halt --reboot" there is no issue of rebooting the system.
[Step 2] - log file (
[ 0.293926] PCI: CLS 0 bytes, default 64
[ 12.996660] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 12.996689] musb-hdrc: MHDRC RTL version 2.0
[ 12.996697] musb-hdrc: setup fifo_mode 4
[ 12.996715] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 13.082460] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 13.082491] musb-hdrc: MHDRC RTL version 2.0
[ 13.082499] musb-hdrc: setup fifo_mode 4
[ 13.082517] musb-hdrc: 28/31 max ep, 16384/16384 memory
root@am335x-evm:~#
root@am335x-evm:~#
root@am335x-evm:~# halt --reboot -f
Rebooting.[ 80.505857] musb-hdrc musb-hdrc.2.auto: remove, state 4
[ 80.511586] usb usb1: USB disconnect, device number 1
[ 80.551882] musb-hdrc musb-hdrc.2.auto: USB bus 1 deregistered
When doing "halt --reboot -f", the console log stops as below.
[Step 3] - log file (
Stopping User Manager for UID 0...
Stopping SSH Per-Connection Server (192.168.0.3:58663)...
Stopping Serial Getty on ttyGS0...
[ OK ] Stopped SSH Per-Connection Server (192.168.0.3:58663).
[ OK ] Removed slice system-dropbear.slice.
Stopping Start USB gadget...
[ OK ] Stopped Start USB gadget.
[ 165.119975] reboot: Restarting system
reading args
reading u-boot.img
reading u-boot.img
reading u-boot.img
reading u-boot.img
Watchdog enabled
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
reading uboot.env
, eth1: usb_ether
reading boot.scr
reading uEnv.txt
Scanning mmc 0:1...
reading boot.scr
reading uEnv.txt
3664216 bytes read in 273 ms (12.8 MiB/s)
Starting kernel ...
[ 0.000015] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000042] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000535] Console: colour dummy device 80x30
[ 0.000558] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000563] This ensures that you still see kernel messages. Please
[ 0.000568] update your kernel commandline.
[ 0.000583] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[ 0.089235] pid_max: default: 32768 minimum: 301
[ 0.089345] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089354] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089955] Initializing cgroup subsys io
[ 0.089987] Initializing cgroup subsys memory
[ 0.090018] Initializing cgroup subsys devices
[ 0.090031] Initializing cgroup subsys freezer
[ 0.090044] Initializing cgroup subsys perf_event
[ 0.090054] Initializing cgroup subsys pids
[ 0.090076] CPU: Testing write buffer coherency: ok
[ 0.090429] Setting up static identity map for 0x80008200 - 0x80008258
[ 0.092181] devtmpfs: initialized
[ 0.101042] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.113460] omap_hwmod: debugss: _wait_target_disable failed
[ 0.168204] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.170184] pinctrl core: initialized pinctrl subsystem
[ 0.171353] NET: Registered protocol family 16
[ 0.173169] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.199229] cpuidle: using governor ladder
[ 0.229215] cpuidle: using governor menu
[ 0.233052] OMAP GPIO hardware version 0.1
[ 0.241630] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.276330] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.278942] vgaarb: loaded
[ 0.279522] SCSI subsystem initialized
[ 0.279794] usbcore: registered new interface driver usbfs
[ 0.279856] usbcore: registered new interface driver hub
[ 0.279951] usbcore: registered new device driver usb
[ 0.280428] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.280477] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe
[ 0.280579] media: Linux media interface: v0.10
[ 0.280631] Linux video capture interface: v2.00
[ 0.280673] pps_core: LinuxPPS API ver. 1 registered
[ 0.280679] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.280704] PTP clock support registered
[ 0.280887] EDAC MC: Ver: 3.0.0
[ 0.281885] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.282163] Advanced Linux Sound Architecture Driver Initialized.
[ 0.283189] clocksource: Switched to clocksource timer1
[ 0.292433] NET: Registered protocol family 2
[ 0.293114] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.293160] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.293257] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.293331] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.293356] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.293841] RPC: Registered named UNIX socket transport module.
[ 0.293855] RPC: Registered udp transport module.
[ 0.293861] RPC: Registered tcp transport module.
[ 0.293866] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.294740] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.296384] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.303523] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.304223] NFS: Registering the id_resolver key type
[ 0.304294] Key type id_resolver registered
[ 0.304302] Key type id_legacy registered
[ 0.304363] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.306058] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.306083] io scheduler noop registered
[ 0.306093] io scheduler deadline registered
[ 0.306229] io scheduler cfq registered (default)
[ 0.307552] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.360667] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.364453] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250
[ 0.994333] console [ttyS0] enabled
[ 0.998733] [drm] Initialized drm 1.1.0 20060810
[ 1.010428] loop: module loaded
[ 1.015832] libphy: Fixed MDIO Bus: probed
[ 1.083254] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 1.089389] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 1.096431] libphy: 4a101000.mdio: probed
[ 1.100471] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 1.110357] cpsw 4a100000.ethernet: Detected MACID = 90:59:af:5c:1a:bd
[ 1.117892] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.125530] usbcore: registered new interface driver pegasus
[ 1.131287] usbcore: registered new interface driver asix
[ 1.136805] usbcore: registered new interface driver ax88179_178a
[ 1.142965] usbcore: registered new interface driver cdc_ether
[ 1.148913] usbcore: registered new interface driver smsc75xx
[ 1.154757] usbcore: registered new interface driver smsc95xx
[ 1.160566] usbcore: registered new interface driver net1080
[ 1.166304] usbcore: registered new interface driver cdc_subset
[ 1.172291] usbcore: registered new interface driver zaurus
[ 1.177996] usbcore: registered new interface driver cdc_ncm
[ 1.184324] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.190889] ehci-pci: EHCI PCI platform driver
[ 1.195445] ehci-platform: EHCI generic platform driver
[ 1.200866] ehci-omap: OMAP-EHCI Host Controller driver
[ 1.206239] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.212483] ohci-pci: OHCI PCI platform driver
[ 1.217029] ohci-platform: OHCI generic platform driver
[ 1.222683] usbcore: registered new interface driver usb-storage
[ 1.229137] mousedev: PS/2 mouse device common for all mice
[ 1.235553] i2c /dev entries driver
[ 1.240336] cpuidle: enable-method property 'ti,am3352' found operations
[ 1.247338] sdhci: Secure Digital Host Controller Interface driver
[ 1.253584] sdhci: Copyright(c) Pierre Ossman
[ 1.258495] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 1.340480] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.348797] Synopsys Designware Multimedia Card Interface Driver
[ 1.355337] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.361117] mmc0: new high speed SDHC card at address 0007
[ 1.367925] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.374618] mmcblk0: mmc0:0007 SD04G 3.71 GiB
[ 1.379691] usbcore: registered new interface driver usbhid
[ 1.385675] usbhid: USB HID core driver
[ 1.389639] mmcblk0: p1 p2
[ 1.396445] NET: Registered protocol family 10
[ 1.405331] sit: IPv6 over IPv4 tunneling driver
[ 1.410834] NET: Registered protocol family 17
[ 1.415806] Key type dns_resolver registered
[ 1.420316] omap_voltage_late_init: Voltage driver support not added
[ 1.430893] ThumbEE CPU extension supported.
[ 1.435284] Registering SWP/SWPB emulation handler
[ 1.466418] mmc1: MAN_BKOPS_EN bit is not set
[ 1.472803] mmc1: new high speed MMC card at address 0001
[ 1.479397] mmcblk1: mmc1:0001 MMC02G 1.79 GiB
[ 1.484986] mmcblk1boot0: mmc1:0001 MMC02G partition 1 1.00 MiB
[ 1.491073] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 1.496935] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.503918] mmcblk1boot1: mmc1:0001 MMC02G partition 2 1.00 MiB
[ 1.511674] mmcblk1: p1
[ 1.635539] tda998x 0-0070: found TDA19988
[ 1.640991] tilcdc 4830e000.lcdc: bound 0-0070 (ops tda998x_ops)
[ 1.647086] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.653739] [drm] No driver support for vblank timestamp query.
[ 1.660023] tilcdc 4830e000.lcdc: No connectors reported connected with modes
[ 1.667229] [drm] Cannot find any crtc or sizes - going 1024x768
[ 1.681688] Console: switching to colour frame buffer device 128x48
[ 1.693297] tilcdc 4830e000.lcdc: fb0: frame buffer device
[ 1.723220] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[ 1.729146] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.736053] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.743132] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.750287] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.757378] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.764324] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 1.771980] hctosys: unable to open rtc device (rtc0)
[ 1.780540] ALSA device list:
[ 1.783690] No soundcards found.
[ 10.368245] EXT4-fs (mmcblk0p2): recovery complete
[ 10.383326] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 10.391590] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 10.408435] devtmpfs: mounted
[ 10.412606] Freeing unused kernel memory: 292K (c096d000 - c09b6000)
[ 10.419071] This architecture does not have kernel memory protection.
[ 10.707473] systemd[1]: System time before build time, advancing clock.
[ 10.782084] random: systemd urandom read with 33 bits of entropy available
[ 10.811472] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 10.830644] systemd[1]: Detected architecture arm.
[ 10.855372] systemd[1]: Set hostname to <am335x-evm>.
[ 11.461788] systemd[1]: [/lib/systemd/system/gadget-init.service:15] Unknown lvalue 'ExecStopPre' in section 'Service'
[ 11.787573] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
[ 11.795636] systemd[1]: sysinit.target: Found dependency on alignment.service/start
[ 11.803429] systemd[1]: sysinit.target: Found dependency on basic.target/start
[ 11.810704] systemd[1]: sysinit.target: Found dependency on sockets.target/start
[ 11.818177] systemd[1]: sysinit.target: Found dependency on dbus.socket/start
[ 11.825601] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
[ 11.833159] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
[ 11.842744] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
[ 11.889494] systemd[1]: Listening on Syslog Socket.
[ 11.913956] systemd[1]: Listening on Journal Socket (/dev/log).
[ 11.946095] systemd[1]: Created slice User and Session Slice.
[ 11.973847] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 12.003750] systemd[1]: Listening on udev Kernel Socket.
[ 12.033573] systemd[1]: Reached target Remote File Systems.
[ 12.063894] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 12.093539] systemd[1]: Reached target Swap.
[ 12.113928] systemd[1]: Listening on Journal Socket.
[ 12.143955] systemd[1]: Listening on udev Control Socket.
[ 12.195466] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 12.223834] systemd[1]: Reached target Paths.
[ 12.244343] systemd[1]: Listening on Network Service Netlink Socket.
[ 12.275275] systemd[1]: Created slice System Slice.
[ 12.313987] systemd[1]: Starting Load Kernel Modules...
[ 12.349149] systemd[1]: Starting Setup Virtual Console...
[ 12.394188] cryptodev: driver 1.8 loaded.
[ 12.429321] systemd[1]: Starting Journal Service...
[ 12.479921] systemd[1]: Mounting POSIX Message Queue File System...
[ 12.515496] systemd[1]: Created slice system-getty.slice.
[ 12.544471] systemd[1]: Reached target Slices.
[ 12.588792] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 12.671317] systemd[1]: Mounting Temporary Directory...
[ 12.699428] systemd[1]: Mounting Debug File System...
[ 12.765151] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 12.797530] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 12.876168] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 12.897752] systemd[1]: Mounted Debug File System.
[ 12.923757] systemd[1]: Mounted POSIX Message Queue File System.
[ 12.953672] systemd[1]: Mounted Temporary Directory.
[ 12.987329] systemd[1]: Started Journal Service.
[ OK ] Started Remount Root and Kernel File Systems.
[ 14.392030] systemd-journald[82]: Received request to flush runtime journal from PID 1
[ 15.964401] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 16.028650] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 16.135406] 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 16.294035] omap_rtc 44e3e000.rtc: already running
[ 16.314898] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 16.554862] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 17.010530] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 17.164939] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 17.222732] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
[ 17.277937] remoteproc0: wkup_m3 is available
[ 17.282426] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 17.309224] ti-pruss 4a300000.pruss: creating PRU cores and other child platform devices
[ 17.401317] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 17.430604] remoteproc1: 4a334000.pru0 is available
[ 17.516255] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 17.540195] PM: Cannot get wkup_m3_ipc handle
[ 17.550836] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 17.683665] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 17.695233] PM: bootloader does not support rtc-only!
[ 17.701205] remoteproc0: powering up wkup_m3
[ 17.761786] remoteproc0: Booting fw image am335x-pm-firmware.elf, size 216252
[ 17.863939] remoteproc1: registered virtio0 (type 7)
[ 17.891920] remoteproc0: remote processor wkup_m3 is now up
[ 17.891942] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x191
[ 17.912956] pru-rproc 4a334000.pru0: PRU rproc node /ocp/pruss@4a300000/pru0@4a334000 probed successfully
[ 18.000323] remoteproc2: 4a338000.pru1 is available
[ 18.075354] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 18.103041] asoc-simple-card sound: i2s-hifi <-> 48038000.mcasp mapping ok
[ 18.209253] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 18.335658] remoteproc2: registered virtio1 (type 7)
[ 18.340819] pru-rproc 4a338000.pru1: PRU rproc node /ocp/pruss@4a300000/pru1@4a338000 probed successfully
[ 19.287844] EXT4-fs (mmcblk1p1): recovery complete
[ 19.292725] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 19.416164] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 21.283996] random: nonblocking pool is initialized
Starting Login Service...[ 21.569140] net eth0: initializing cpsw version 1.12 (0)
[ 21.667250] net eth0: initialized cpsw ale version 1.4
[ 21.778267] net eth0: phy found : id is : 0x7c0f1
[ 21.866631] libphy: PHY 4a101000.mdio:01 not found
[ 21.961277] net eth0: phy "4a101000.mdio:01" not found on slave 1, err -19
[ 22.051226] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 22.369895] Bluetooth: Core ver 2.21
[ 22.432370] NET: Registered protocol family 31
[ 22.494032] Bluetooth: HCI device and connection manager initialized
[ 22.596180] Bluetooth: HCI socket layer initialized
[ 22.601118] Bluetooth: L2CAP socket layer initialized
[ 22.733468] Bluetooth: SCO socket layer initialized
[ 22.741667] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
[ 22.869080] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 1
[ 22.980336] hub 1-0:1.0: USB hub found
[ 22.988552] NET: Registered protocol family 15
[ 23.033539] hub 1-0:1.0: 1 port detected
[FAILED] Failed to start Start USB gadget.
See 'systemctl status gadget-init.service' for details.
[ 23.271700] remoteproc1: powering up 4a334000.pru0
[ 23.350005] remoteproc1: Booting fw image am335x-pru0-fw, size 80252
[ 23.444651] ti-pruss 4a300000.pruss: configured system_events = 0x1000000000000000 intr_channels = 0x00000001 host_intr = 0x00000001
[ 23.543341] remoteproc1: remote processor 4a334000.pru0 is now up
[ 23.549930] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
[ 23.606223] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 23.633772] remoteproc2: powering up 4a338000.pru1
[ 23.639296] remoteproc2: Booting fw image am335x-pru1-fw, size 80252
[ 23.735017] ti-pruss 4a300000.pruss: configured system_events = 0x0800000000000000 intr_channels = 0x00000002 host_intr = 0x00000002
[ 23.811559] Initializing XFRM netlink socket
[ 23.820739] remoteproc2: remote processor 4a338000.pru1 is now up
[ 23.873947] virtio_rpmsg_bus virtio1: creating channel rpmsg-pru addr 0x1f
[ 23.883045] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 23.992821] rpmsg_pru rpmsg0: new rpmsg_pru device: /dev/rpmsg_pru30
[ 24.045209] rpmsg_pru rpmsg1: new rpmsg_pru device: /dev/rpmsg_pru31
[ 24.794016] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 24.829497] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ OK ] Reached target Network.[ 27.932258] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
_____ _____ _ _
|___| |___|
root@am335x-evm:~#
When the issue happened, user still can connect SSH console. At the console, when doing "halt --reboot", the system normally reboot as attached log file.
So, please check why the rebooting process stops when doing reboot with "-f" option.
Checked that there is no such issue with PSDK 04.00.00.04 and the latest 04.03.00.05.
Thanks and regards,
Hayden
