Other Parts Discussed in Thread: DS90UB953-Q1EVM, , ALP
I am developing on the TDA2PXEVM with fusion board and DS90UB953-Q1EVM, running the Vision SDK v.3.03 demo program from SD card.
When I reach the UART demo menu, I first input s->2->3 to set my image sensor to be OV10640 via CSI2 to match the specs of the DS90UB953-Q1EVM.
Once I am returned to the main menu, I input 5->1 to select the single channel camera via fusion board mode. When I do this, I get an "i2c4 transfer to slave address 0x32 failed" error. Is the program expecting the 953 serializer to be at that address, or the 10640 image sensor itself? Which would be the relevant files I need to modify to resolve this issue? I have tried setting registers on the 953 EVM via ALP, but that always leads to the registers keeping their default values, or being reset to 0.
Attached is the serial terminal log:
[IPU1-0] Vision SDK Usecases, [IPU1-0] -------------------- [IPU1-0] 1: Single Camera Usecases [IPU1-0] 2: Multi-Camera LVDS Usecases [IPU1-0] 3: AVB RX Usecases, (TDA2x & TDA2Ex ONLY) [IPU1-0] 4: Dual Display Usecases, (TDA2x EVM ONLY) [IPU1-0] 5: ISS Usecases, (TDA3x ONLY) [IPU1-0] 6: TDA2x Stereo Usecases [IPU1-0] 7: Network RX/TX Usecases [IPU1-0] a: Miscellaneous test's [IPU1-0] f: TIDL Usecase [IPU1-0] [IPU1-0] s: System Settings [IPU1-0] [IPU1-0] x: Exit [IPU1-0] [IPU1-0] Enter Choice: [IPU1-0] [HOST ] 23.412645 s: NETWORK_CTRL: Starting Server (port=5000) !!! [HOST ] 23.412676 s: NETWORK_CTRL: Starting Server ... DONE (port=5000) !!! [IPU1-0] 30.206033 s: [IPU1-0] 30.206094 s: [IPU1-0] [IPU1-0] =============== [IPU1-0] System Settings [IPU1-0] =============== [IPU1-0] [IPU1-0] 1: Display Settings [IPU1-0] 2: Capture Settings [IPU1-0] 3: ISS Settings (TDA3x ONLY) [IPU1-0] 4: Enable Charging via USB2 Port (TDA2x EVM ONLY) [IPU1-0] 5: Print PRCM Statistics [IPU1-0] 6: Show Memory/CPU/DDR BW usage [IPU1-0] 7: Calibration Settings [IPU1-0] [IPU1-0] x: Exit [IPU1-0] [IPU1-0] Enter Choice: [IPU1-0] [IPU1-0] 30.206368 s: [IPU1-0] 32.318154 s: [IPU1-0] [IPU1-0] ============== [IPU1-0] Capture Source [IPU1-0] ============== [IPU1-0] [IPU1-0] 1: OV10635 Sensor 720P30 [IPU1-0] 2: HDMI Capture 1080P60 (Not Supported in TDA2x/TDA2Ex Multi-serdes board) [IPU1-0] 3: OV10640 Sensor 720P30 - CSI2 (TDA3x ONLY) [IPU1-0] 4: OV10640 Sensor 720P30 - Parallel (TDA3x ONLY) [IPU1-0] 5: AR0132 Sensor 720P60 - Parallel (TDA3x ONLY) [IPU1-0] 6: AR0140 Sensor 720P60 - Parallel (TDA3x ONLY) [IPU1-0] 7: IMX224 Sensor 1280x960 - CSI2 (TDA3x ONLY) [IPU1-0] 8: AR0140 Sensor for SV - TIDA00262 (TDA3x ONLY) [IPU1-0] 9: OV10640 Sensor for SV - IMI (TDA3x ONLY) [IPU1-0] a: OV10635 Sensor for Mosaic Display - SAT0088/OV10635 (TDA2PX, TDA2EX & TDA3x) [IPU1-0] b: OV2775 Sensor 1080p30 (TDA3x ONLY) [IPU1-0] c: AR143 MARS Camera (TDA3x ONLY) [IPU1-0] d: Skip Sensor configuration [IPU1-0] e: OV2775 Sensor 1080p30 - TIDA001130 [IPU1-0] f: IMX390 Sensor 1080p30 - D3 [IPU1-0] [IPU1-0] x: Exit [IPU1-0] [IPU1-0] Enter Choice: [IPU1-0] [IPU1-0] 32.318825 s: [IPU1-0] 34.476880 s: [IPU1-0] 34.476941 s: Current System Settings, [IPU1-0] 34.477185 s: ======================== [IPU1-0] 34.477246 s: Display Type : HDMI 1920x1080 @ 60fps [IPU1-0] 34.477307 s: Capture Source : Sensor OV10640 1280x720 @ 30fps - ISS CSI2, Bayer (TDA3x EVM ONLY) [IPU1-0] 34.477398 s: My IP address : 0.0.0.0 [IPU1-0] 34.477459 s: ISS Settings : LDC=[OFF] VTNF=[OFF] WDR=[OFF] [IPU1-0] 34.477551 s: [IPU1-0] 34.477581 s: ============ [IPU1-0] 34.477642 s: Usecase Menu [IPU1-0] 34.477673 s: ============ [IPU1-0] 34.477734 s: [IPU1-0] [IPU1-0] Vision SDK Usecases, [IPU1-0] -------------------- [IPU1-0] 1: Single Camera Usecases [IPU1-0] 2: Multi-Camera LVDS Usecases [IPU1-0] 3: AVB RX Usecases, (TDA2x & TDA2Ex ONLY) [IPU1-0] 4: Dual Display Usecases, (TDA2x EVM ONLY) [IPU1-0] 5: ISS Usecases, (TDA3x ONLY) [IPU1-0] 6: TDA2x Stereo Usecases [IPU1-0] 7: Network RX/TX Usecases [IPU1-0] a: Miscellaneous test's [IPU1-0] f: TIDL Usecase [IPU1-0] [IPU1-0] s: System Settings [IPU1-0] [IPU1-0] x: Exit [IPU1-0] [IPU1-0] Enter Choice: [IPU1-0] [IPU1-0] 36.634356 s: [IPU1-0] 36.634508 s: [IPU1-0] [IPU1-0] ISS Usecases (TDA3x ONLY) [IPU1-0] --------------------------- [IPU1-0] 1: 1CH ISS capture + ISS ISP + ISS LDC+VTNF + Display [IPU1-0] 2: 4CH ISS capture + ISS ISP + Simcop + Surround View (DSP1) + Display [IPU1-0] 4: 3D SRV 4CH ISS capture + ISS ISP + DeWarp + Synthesis (DSP1) + Display [IPU1-0] 5: Surround View Calibration [IPU1-0] 6: 3D + 2D SRV 4CH ISS capture + ISS ISP + DeWarp + Synthesis (DSP1) + Display [IPU1-0] c: 4 Channel (2 ch per CSI2 Inst) ISS Capture (OV2775 Sensor) Display [IPU1-0] [IPU1-0] x: Exit [IPU1-0] [IPU1-0] Enter Choice: [IPU1-0] [IPU1-0] 37.708869 s: [IPU1-0] 37.708930 s: Entered Chains_issIspSimcop_Display [IPU1-0] 39.067681 s: ISSCAPTURE: Create in progress !!! [IPU1-0] 39.068931 s: UTILS: DMA: Allocated CH (TCC) = 48 (48) [IPU1-0] 39.069084 s: UTILS: DMA: 0 of 1: Allocated PaRAM = 48 (0x63304800) [IPU1-0] 39.069358 s: ISSCAPTURE: Create Done !!! [IPU1-0] 39.069511 s: ISSM2MISP: Create in progress !!! [IPU1-0] 39.070395 s: UTILS: DMA: Allocated CH (TCC) = 49 (49) [IPU1-0] 39.070517 s: UTILS: DMA: 0 of 1: Allocated PaRAM = 49 (0x63304820) [IPU1-0] 39.073811 s: ISSM2MISP: Create Done !!! [IPU1-0] 39.073994 s: ALGORITHM: Create in progress (algId = 6) !!! [IPU1-0] 39.074574 s: ALGORITHM: Create Done (algId = 6) !!! [IPU1-0] 39.075062 s: ISS Resizer: Create in progress !!! [IPU1-0] 39.079363 s: ISS RESIZER: Create Done !!! [IPU1-0] 39.079515 s: DISPLAY: Create in progress !!! [IPU1-0] 39.080034 s: DISPLAY: Create Done !!! [IPU1-0] 39.080247 s: ALGORITHM: Create in progress (algId = 3) !!! [IPU1-0] 39.097480 s: ALG_ISS_AEWB: Memory requirement is 867036 bytes. [IPU1-0] 39.097602 s: ALG_ISS_AEWB: Memory provided by user is 917504 bytes. [IPU1-0] 39.097663 s: ALG_ISS_AEWB: Unused Memory is 50468 bytes. [IPU1-0] 39.097755 s: ALGORITHM: Create Done (algId = 3) !!! [IPU1-0] 39.097907 s: ISSM2MSIMCOP: Create in progress !!! [IPU1-0] 39.098853 s: UTILS: DMA: Allocated CH (TCC) = 50 (50) [IPU1-0] 39.098975 s: UTILS: DMA: 0 of 1: Allocated PaRAM = 50 (0x63304840) [IPU1-0] 39.100439 s: ISSM2MSIMCOP: Create Done !!! [IPU1-0] 39.100744 s: DISPLAY: Create in progress !!! [IPU1-0] 39.101323 s: DISPLAY: Create Done !!! [IPU1-0] 39.101689 s: GRPXSRC: Create in progress !!! [IPU1-0] 40.594034 s: GRPXSRC: Create Done !!! [IPU1-0] 40.594522 s: DISPLAY: Create in progress !!! [IPU1-0] 40.594979 s: DISPLAY: Create Done !!! [IPU1-0] 40.595498 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022 [IPU1-0] 40.595650 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 243976 B (238 KB) [IPU1-0] 40.595803 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB) [IPU1-0] 40.595955 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x88103000, Total size = 368037888 B (350 MB), Free size = 339918336 B (324 MB) [IPU1-0] 40.596138 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xbfc00000, Total size = 127872 B (0 MB), Free size = 106368 B (0 MB) [IPU1-0] 40.603336 s: QSPI Read Started, please wait! [IPU1-0] 40.603611 s: QSPI Read Completed Sucessfully [IPU1-0] 40.605654 s: CHAINS: DCC Tag ID check failed for QSPI [IPU1-0] 40.605776 s: CHAINS: Using DCC Profile from Driver [IPU1-0] 40.616970 s: [IPU1-0] 40.617306 s: i2cMdSubmitChan: i2c4 transfer to slave address 0x32 failed [IPU1-0] 40.617428 s: src/bsp_deviceI2c.c @ Line 667: [IPU1-0] 40.617519 s: I2C4: DEV 0x32: ERROR !!! [IPU1-0] 40.617580 s: src/bsp_deviceI2c.c @ Line 689: [IPU1-0] 40.617672 s: I2C4: Error timeout 1 ms!!! [IPU1-0] 40.617733 s: Assertion @ Line: 507 in C:/PROCESSOR_SDK_VISION_03_03_00_00/vision_sdk/apps/src/rtos/iss/src/common/app_util_iss.c: 0 == status : failed !!! [IPU1-0] 40.618404 s: Assertion @ Line: 507 in C:/PROCESSOR_SDK_VISION_03_03_00_00/vision_sdk/apps/src/rtos/iss/src/common/app_util_iss.c: 0 == status : failed !!! [IPU1-0] 40.619959 s: *** UTILS: CPU KHz = 20000 Khz *** [IPU1-1] 40.596840 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [IPU1-1] 40.596962 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 655360 B (640 KB), Free size = 645320 B (630 KB) [HOST ] 40.597389 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [HOST ] 40.597419 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 6291456 B (6144 KB), Free size = 6249648 B (6103 KB) [DSP1 ] 40.597663 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [DSP1 ] 40.597694 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB) [DSP1 ] 40.597755 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516456 B (504 KB) [DSP2 ] 40.598029 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [DSP2 ] 40.598060 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB) [DSP2 ] 40.598121 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516456 B (504 KB) [EVE1 ] 40.598822 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [EVE1 ] 40.599127 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [EVE1 ] 40.599676 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254288 B (248 KB) [EVE2 ] 40.600957 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [EVE2 ] 40.601262 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [EVE2 ] 40.601811 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254288 B (248 KB) [IPU2 ] 40.602818 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [IPU2 ] 40.602940 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 252056 B (246 KB)
Richard
