Linux/TMDXSK437X: Kernel modules build issue
Part Number: TMDXSK437X
Tool/software: Linux
How to correctly rebuild loadable kernel modules with "Enable stack unwinding support" ?
When kernel and modules are built with debug info and "Enable stack unwinding support" config option,
the modules are failed to boot: "disagrees about version of symbol module_layout"
ti-processor-sdk-linux-am437x-evm-04.03.00.05
am437x-sk-evm
Boot log:
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[  OK  ] Started Remount Root and Kernel File Systems.
[   11.018150] remoteproc: disagrees about version of symbol module_layout
[   11.042719] omap_wdt: disagrees about version of symbol module_layout
[   11.556268] snd_soc_tlv320aic3x: disagrees about version of symbol module_layout
[   12.202015] am437x_vpfe: disagrees about version of symbol module_layout
[   12.219460] am437x_vpfe: disagrees about version of symbol module_layout
Insmod:
root@am437x-evm:~# insmod /lib/modules/4.9.69-g9ce43c71ae/kernel/drivers/media/platform/am437x/am437x-vpfe.ko
[ 1522.165787] am437x_vpfe: disagrees about version of symbol module_layout
insmod: ERROR: could not insert module /lib/modules/4.9.69-g9ce43c71ae/kernel/drivers/media/platform/am437x/am437x-vpfe.ko: Invalid module format
Modinfo:
root@am437x-evm:~# modinfo /lib/modules/4.9.69-g9ce43c71ae/kernel/drivers/media/platform/am437x/am437x-vpfe.ko
filename:       /lib/modules/4.9.69-g9ce43c71ae/kernel/drivers/media/platform/am437x/am437x-vpfe.ko
version:        0.1.0
license:        GPL
description:    TI AM437x VPFE driver
author:         Texas Instruments
srcversion:     068F2F1D15C039784AD1932
alias:          of:N*T*Cti,am437x-vpfeC*
depends:
intree:         Y
vermagic:       4.9.69-g9ce43c71ae preempt mod_unload modversions ARMv7 p2v8
parm:           debug:Debug level 0-8 (int)
Objdump:
root@am437x-evm:~# objdump -i /lib/modules/4.9.69-g9ce43c71ae/kernel/drivers/media/platform/am437x/am437x-vpfe.ko
BFD header file version (GNU Binutils) 2.27.0.20160806
elf32-littlearm
 (header little endian, data little endian)
  arm
elf32-bigarm
 (header big endian, data big endian)
  arm
elf32-little
  plugin
  arm
elf32-big
  plugin
  arm
plugin
srec
 (header endianness unknown, data endianness unknown)
  plugin
  arm
symbolsrec
  plugin
  arm
verilog
  plugin
  arm
tekhex
  plugin
  arm
binary
  plugin
  arm
ihex
  plugin
  arm
               elf32-littlearm elf32-bigarm elf32-little elf32-big plugin srec
        plugin --------------- ------------ elf32-little elf32-big ------ srec
           arm elf32-littlearm elf32-bigarm elf32-little elf32-big ------ srec
               symbolsrec verilog tekhex binary ihex
        plugin symbolsrec verilog tekhex binary ihex
           arm symbolsrec verilog tekhex binary ihex
Built with "Enable stack unwinding support" in cofig:
export PATH=$PATH:/home/od/ti/ti-processor-sdk-linux-am437x-evm-04.03.00.05/linux-devkit/sysroots/x86_64-arago-linux/usr/bin
export ARCH=arm
export CROSS_COMPILE=arm-linux-gnueabihf-
export INSTALL_MOD_PATH=/home/od/ti/ti-processor-sdk-linux-am437x-evm-04.03.00.05/targetNFS
make mrproper
make am437x-evm_debug_defconfig
echo "=================================zImage===================================="
make zImage
cp arch/arm/boot/zImage ../../targetNFS/boot/
echo "=================================modules==================================="
make modules
make modules_install
  • Hello Oleksiy,
    Please, do it in this way.
    1) Clean.
    make linux_clean
    2) Backup your defconfig file
    cp board-support/linux-<version>/arch/arm/configs/tisdk_am437x-evm_defconfig board-support/linux-<version>/arch/arm/configs/tisdk_am437x-evm_defconfig.bak
    3) Load default config.
    cd board-support/linux-<version>/
    make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- tisdk_am437x-evm_defconfig
    4) Config in Menuconfig and enable the needed options, unwinding support in your case.
    make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- menuconfig
    Kernel hacking ---> [*] Enable stack unwinding support
    5) Replace the old defconfig file with the new one which includes unwinding support.
    cd ../../
    cp board-support/linux-<version>/.config board-support/linux-<version>/arch/arm/configs/tisdk_am437x-evm_defconfig
    6) Compile and install the dtb, linux and modules.
    make linux
    make linux_install
    7) Compile and install the ti-sgx-ddk-km modules.
    make ti-sgx-ddk-km
    make ti-sgx-ddk-km_install
    8) Copy the needed dtb, kernel and modules in a proper places at your SD card.
    sudo cp -r targetNFS/boot/ /media/<username>/rootfs/
    sudo cp -r targetNFS/lib/modules/ /media/<username>/rootfs/lib/
    Kemal
