Tool/software: Linux
Hi all,
communication over mmc3 instance on am3352 ( in device tree node : mmc@47810000) to sdcard connected over sdio doesn't seem to work. I suspect that my settings in device tree are not right, specifically the dma configuration. But I couldn't figure out what would be the correct settings.
With a different cpu board that connects to the same sdcard on the main board but uses mmc1 instance on the cpu board it works fine. So HW wiring is ok.
General/System information:
* Linux Kernel version: v4.4.97
* Snippet of device tree for mmc3 configuration:
/* SD card on JTAG board */
&am33xx_pinmux {
mmc2_pins: pinmux_mmc2_pins {
pinctrl-single,pins = <
0x030 (PIN_INPUT_PULLUP | MUX_MODE3) /* GPMC_AD12.mmc2_data0, 39, NC (SD_DATA0) */
0x034 (PIN_INPUT_PULLUP | MUX_MODE3) /* GPMC_AD13.mmc2_data1, 44, NC (SD_DATA1) */
0x038 (PIN_INPUT_PULLUP | MUX_MODE3) /* GPMC_AD14.mmc2_data2, 40, NC (SD_DATA2) */
0x03c (PIN_INPUT_PULLUP | MUX_MODE3) /* GPMC_AD15.mmc2_data3, 32, NC (SD_DATA3) */
0x088 (PIN_INPUT_PULLUP | MUX_MODE3) /* GPMC_CSn3.mmc2_cmd, 56, NC (SD_CMD) */
0x08c (PIN_INPUT | MUX_MODE3) /* GPMC_CLK.mmc2_clk, 43, NC (SD_CLK) */
0x164 (PIN_INPUT_PULLUP | MUX_MODE7) /* ecap0_in_pwm0_out, 60, NC (SD_DET) */
0x11c (PIN_INPUT_PULLUP | MUX_MODE7) /* MII1_TXD3.gpio0_16, 31, NC (SD_Power) */
&mmc3 {
pinctrl-names = "default";
pinctrl-0 = <&mmc2_pins>;
vmmc-supply = <&vmmcsd_fixed1>;
max-frequency = <50000000>;
dmas = <&edma_xbar 12 0 0
&edma_xbar 13 0 0>;
dma-names = "tx", "rx";
status = "okay";
bus-width = <1>;
disable-wp;
cd-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>; /* ecap0_in_pwm0_out, 60, NC (SD_DET) */
mmc-reply-go-idle;
* Debug message log from dmsg:
root@etamin:~# dmesg | grep mmc
[ 1.117419] omap_hsmmc 48060000.mmc: GPIO lookup for consumer cd
[ 1.117445] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup
[ 1.117487] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/mmc@48060000[0]' - status (0)
[ 1.117593] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 1.122459] omap_hsmmc 48060000.mmc: GPIO lookup for consumer wp
[ 1.122471] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup
[ 1.122485] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@48060000[0]'
[ 1.122500] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@48060000[0]'
[ 1.122513] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup
[ 1.122526] omap_hsmmc 48060000.mmc: lookup for GPIO wp failed
[ 1.122650] omap_hsmmc 48060000.mmc: context is restored: restore count 1
[ 1.122664] omap_hsmmc 48060000.mmc: enabled
[ 1.123023] omap_hsmmc 48060000.mmc: unable to get vmmc_aux regulator -19
[ 1.123047] omap_hsmmc 48060000.mmc: unable to get pbias regulator -19
[ 1.124188] mmc0: clock 0Hz busmode 2 powermode 1 cs 0 Vdd 21 width 0 timing 0
[ 1.124236] omap_hsmmc 48060000.mmc: Initial signal voltage of 3.3v
[ 1.143628] mmc0: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 0 timing 0
[ 1.163772] mmc0: mmc_rescan_try_freq: trying to init card at 400000 Hz
[ 1.170745] mmc0: starting CMD52 arg 00000c00 flags 00000195
[ 1.171142] mmc0: req done (CMD52): -110: 00000000 00000000 00000000 00000000
[ 1.171221] omap_hsmmc 47810000.mmc: GPIO lookup for consumer cd
[ 1.171237] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup
[ 1.171277] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/mmc@47810000[0]' - status (0)
[ 1.171302] omap_hsmmc 47810000.mmc: Got CD GPIO
[ 1.176269] omap_hsmmc 47810000.mmc: GPIO lookup for consumer wp
[ 1.176285] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup
[ 1.176301] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@47810000[0]'
[ 1.176315] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@47810000[0]'
[ 1.176328] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup
[ 1.176341] omap_hsmmc 47810000.mmc: lookup for GPIO wp failed
[ 1.176481] omap_hsmmc 47810000.mmc: context is restored: restore count 1
[ 1.176496] omap_hsmmc 47810000.mmc: enabled
[ 1.176807] omap_hsmmc 47810000.mmc: unable to get vmmc_aux regulator -19
[ 1.176830] omap_hsmmc 47810000.mmc: unable to get pbias regulator -19
[ 1.177127] mmc0: starting CMD52 arg 80000c08 flags 00000195
[ 1.177211] mmc1: clock 0Hz busmode 2 powermode 1 cs 0 Vdd 21 width 0 timing 0
[ 1.177239] omap_hsmmc 47810000.mmc: Initial signal voltage of 3.3v
[ 1.177526] mmc0: req done (CMD52): -110: 00000000 00000000 00000000 00000000
[ 1.177570] mmc0: clock 400000Hz busmode 2 powermode 2 cs 1 Vdd 21 width 0 timing 0
[ 1.178589] mmc0: starting CMD0 arg 00000000 flags 000000c0
[ 1.178758] mmc0: req done (CMD0): 0: 00000000 00000000 00000000 00000000
[ 1.179784] mmc0: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 0 timing 0
[ 1.180800] mmc0: starting CMD8 arg 000001aa flags 000002f5
[ 1.181165] mmc0: req done (CMD8): -110: 00000000 00000000 00000000 00000000
[ 1.181189] mmc0: starting CMD5 arg 00000000 flags 000002e1
[ 1.181560] mmc0: req failed (CMD5): -110, retrying...
[ 1.181928] mmc0: req failed (CMD5): -110, retrying...
[ 1.182295] mmc0: req failed (CMD5): -110, retrying...
[ 1.182657] mmc0: req done (CMD5): -110: 00000000 00000000 00000000 00000000
[ 1.182681] mmc0: starting CMD55 arg 00000000 flags 000000f5
[ 1.183045] mmc0: req done (CMD55): -110: 00000000 00000000 00000000 00000000
[ 1.183066] mmc0: starting CMD55 arg 00000000 flags 000000f5
[ 1.183430] mmc0: req done (CMD55): -110: 00000000 00000000 00000000 00000000
[ 1.183451] mmc0: starting CMD55 arg 00000000 flags 000000f5
[ 1.183819] mmc0: req done (CMD55): -110: 00000000 00000000 00000000 00000000
[ 1.183844] mmc0: starting CMD55 arg 00000000 flags 000000f5
[ 1.184208] mmc0: req done (CMD55): -110: 00000000 00000000 00000000 00000000
[ 1.184234] mmc0: clock 400000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
[ 1.184253] mmc0: starting CMD1 arg 00000000 flags 000000e1
[ 1.184558] mmc0: req done (CMD1): 0: 00ff8080 00000000 00000000 00000000
[ 1.184585] mmc0: clock 400000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
[ 1.184603] mmc0: clock 400000Hz busmode 1 powermode 2 cs 1 Vdd 21 width 0 timing 0
[ 1.185615] mmc0: starting CMD0 arg 00000000 flags 000000c0
[ 1.185778] mmc0: req done (CMD0): 0: 00000000 00000000 00000000 00000000
[ 1.186797] mmc0: clock 400000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
[ 1.187810] mmc0: starting CMD1 arg 40200000 flags 000000e1
[ 1.188115] mmc0: req done (CMD1): 0: 00ff8080 00000000 00000000 00000000
[ 1.193544] mmc1: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 0 timing 0
[ 1.203572] mmc0: starting CMD1 arg 40200000 flags 000000e1
[ 1.203884] mmc0: req done (CMD1): 0: c0ff8080 00000000 00000000 00000000
[ 1.203908] mmc0: starting CMD2 arg 00000000 flags 00000067
[ 1.204436] mmc0: req done (CMD2): 0: 13014e52 314a3536 4c1111d5 a090c2e1
[ 1.204465] mmc0: starting CMD3 arg 00010000 flags 00000015
[ 1.204770] mmc0: req done (CMD3): 0: 00000500 00000000 00000000 00000000
[ 1.204793] mmc0: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 0 timing 0
[ 1.204812] mmc0: starting CMD9 arg 00010000 flags 00000007
[ 1.205338] mmc0: req done (CMD9): 0: d04f0132 0f5913ff ffffffef 8a4000bf
[ 1.205364] mmc0: starting CMD7 arg 00010000 flags 00000015
[ 1.205670] mmc0: req done (CMD7): 0: 00000700 00000000 00000000 00000000
[ 1.205712] mmc0: starting CMD8 arg 00000000 flags 000000b5
[ 1.205728] mmc0: blksz 512 blocks 1 flags 00000200 tsac 400 ms nsac 1000
[ 1.221959] mmc0: req done (CMD8): 0: 00000900 00000000 00000000 00000000
[ 1.221966] mmc0: 512 bytes transferred: 0
[ 1.222027] mmc0: MAN_BKOPS_EN bit is not set
[ 1.227515] mmc0: starting CMD6 arg 03af0101 flags 0000049d
[ 1.232689] mmc0: req done (CMD6): 0: 00000800 00000000 00000000 00000000
[ 1.232722] mmc0: starting CMD13 arg 00010000 flags 00000195
[ 1.239198] mmc0: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 1.239335] mmc0: starting CMD6 arg 03220101 flags 0000049d
[ 1.246699] mmc0: req done (CMD6): 0: 00000800 00000000 00000000 00000000
[ 1.246789] mmc0: starting CMD13 arg 00010000 flags 00000195
[ 1.254433] mmc0: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 1.254571] mmc0: starting CMD6 arg 03b90101 flags 0000049d
[ 1.255106] mmc0: req done (CMD6): 0: 00000800 00000000 00000000 00000000
[ 1.255141] mmc0: starting CMD13 arg 00010000 flags 00000195
[ 1.260787] mmc0: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 1.260815] mmc0: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 0 timing 1
[ 1.260840] mmc0: clock 52000000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 0 timing 1
[ 1.260861] mmc0: starting CMD6 arg 03b70201 flags 0000049d
[ 1.265527] mmc0: req done (CMD6): 0: 00000800 00000000 00000000 00000000
[ 1.265637] mmc0: starting CMD13 arg 00010000 flags 00000195
[ 1.265669] mmc0: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 1.265804] mmc0: clock 52000000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 3 timing 1
[ 1.265828] mmc0: starting CMD8 arg 00000000 flags 000000b5
[ 1.265842] mmc0: blksz 512 blocks 1 flags 00000200 tsac 400 ms nsac 1000
[ 1.270717] mmc0: req done (CMD8): 0: 00000900 00000000 00000000 00000000
[ 1.270724] mmc0: 512 bytes transferred: 0
[ 1.270765] mmc0: starting CMD6 arg 03a10101 flags 0000049d
[ 1.271439] mmc0: req done (CMD6): 0: 00000800 00000000 00000000 00000000
[ 1.271517] mmc0: starting CMD13 arg 00010000 flags 00000195
[ 1.271549] mmc0: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 1.271576] mmc0: starting CMD6 arg 03210101 flags 0000049d
[ 1.277924] mmc0: req done (CMD6): 0: 00000800 00000000 00000000 00000000
[ 1.278073] mmc0: starting CMD13 arg 00010000 flags 00000195
[ 1.278108] mmc0: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 1.278249] mmc0: new high speed MMC card at address 0001
[ 1.294799] mmcblk0: mmc0:0001 R1J56L 6.88 GiB
[ 1.299889] mmcblk0boot0: mmc0:0001 R1J56L partition 1 16.0 MiB
[ 1.319522] omap_hsmmc 47810000.mmc: disabled
[ 1.319869] mmcblk0boot1: mmc0:0001 R1J56L partition 2 16.0 MiB
[ 1.327069] mmc0: starting CMD18 arg 00000000 flags 000000b5
[ 1.327092] mmc0: blksz 512 blocks 8 flags 00000200 tsac 400 ms nsac 1000
[ 1.327103] mmc0: CMD12 arg 00000000 flags 00000095
[ 1.331909] mmc0: req done (CMD18): 0: 00000900 00000000 00000000 00000000
[ 1.331916] mmc0: 4096 bytes transferred: 0
[ 1.331923] mmc0: (CMD12): 0: 00000b00 00000000 00000000 00000000
[ 1.332153] mmc0: starting CMD18 arg 00340800 flags 000000b5
[ 1.332170] mmc0: blksz 512 blocks 8 flags 00000200 tsac 400 ms nsac 1000
[ 1.332182] mmc0: CMD12 arg 00000000 flags 00000095
[ 1.336973] mmc0: req done (CMD18): 0: 00000900 00000000 00000000 00000000
[ 1.336987] mmc0: 4096 bytes transferred: 0
[ 1.336998] mmc0: (CMD12): 0: 00000b00 00000000 00000000 00000000
[ 1.337159] mmc0: starting CMD18 arg 00be0008 flags 000000b5
[ 1.337175] mmc0: blksz 512 blocks 8 flags 00000200 tsac 400 ms nsac 1000
[ 1.337187] mmc0: CMD12 arg 00000000 flags 00000095
[ 1.344198] mmc0: req done (CMD18): 0: 00000900 00000000 00000000 00000000
[ 1.344211] mmc0: 4096 bytes transferred: 0
[ 1.344223] mmc0: (CMD12): 0: 00000b00 00000000 00000000 00000000
[ 1.344288] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[ 1.358271] omap_hsmmc 47810000.mmc: enabled
[ 1.358305] mmc1: mmc_rescan_try_freq: trying to init card at 400000 Hz
[ 1.372801] mmc1: starting CMD52 arg 00000c00 flags 00000195
[ 1.372930] mmc1: req done (CMD52): -110: 00000000 00000000 00000000 00000000
[ 1.373809] mmc1: starting CMD52 arg 80000c08 flags 00000195
[ 1.373916] mmc1: req done (CMD52): -110: 00000000 00000000 00000000 00000000
[ 1.373952] mmc1: clock 400000Hz busmode 2 powermode 2 cs 1 Vdd 21 width 0 timing 0
[ 1.374970] mmc1: starting CMD0 arg 00000000 flags 000000d5
[ 1.375053] mmc1: req done (CMD0): -110: 00000000 00000000 00000000 00000000
[ 1.384708] mmc1: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 0 timing 0
[ 1.385734] mmc1: starting CMD8 arg 000001aa flags 000002f5
[ 1.385831] mmc1: req done (CMD8): -110: 00000000 00000000 00000000 00000000
[ 1.386023] mmc1: starting CMD5 arg 00000000 flags 000002e1
[ 1.386128] mmc1: req failed (CMD5): -110, retrying...
[ 1.386225] mmc1: req failed (CMD5): -110, retrying...
[ 1.386312] mmc1: req failed (CMD5): -110, retrying...
[ 1.386397] mmc1: req done (CMD5): -110: 00000000 00000000 00000000 00000000
[ 1.386427] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 1.386507] mmc1: req done (CMD55): -110: 00000000 00000000 00000000 00000000
[ 1.386531] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 1.386618] mmc1: req done (CMD55): -110: 00000000 00000000 00000000 00000000
[ 1.386644] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 1.386729] mmc1: req done (CMD55): -110: 00000000 00000000 00000000 00000000
[ 1.386754] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 1.386835] mmc1: req done (CMD55): -110: 00000000 00000000 00000000 00000000
[ 1.386864] mmc1: clock 400000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
[ 1.386884] mmc1: starting CMD1 arg 00000000 flags 000000e1
[ 1.386966] mmc1: req done (CMD1): -110: 00000000 00000000 00000000 00000000
[ 1.386996] mmc1: clock 0Hz busmode 2 powermode 0 cs 0 Vdd 0 width 0 timing 0
[ 1.453836] omap_hsmmc 48060000.mmc: disabled
[ 1.483554] omap_hsmmc 47810000.mmc: disabled
Any ideas?
Sam
