Tool/software: Linux
Helllo,
I am running PROCESSOR_SDK_VISION_03_03_00_00 Linux on TDA2x and I need to install packages like minicom or nano.
Is it possible to install packages into the rootfs in the compile environment?
What is the correct way to install packages into VisionSDK Linux?
I attempted two different methods to install packages and was unsuccessful in both methods.
Method 1: I attempted to use opkg, but when I try to use the command opkg update the command gives me wget errors:
root@dra7xx-evm:~# opkg update
Downloading lcpd.gt.design.ti.com/.../Packages.gz.
wget: bad address 'lcpd.gt.design.ti.com'
Collected errors:
* opkg_download_backend: Failed to download lcpd.gt.design.ti.com/.../Packages.gz, wget returned 1.
root@dra7xx-evm:~#
Method 2: When I attempt to cross compile the packages on my development computer by downloading them and using ./configure && make, I would get errors where I would need to install something like coreutils, and when I attempt to install that, I would get lower level errors.
Thank you,
-iFer
