Part Number: AM3358
Tool/software: Linux
Dear Kemal,
I am having a similar problem with linux RT am335x 5.00.00.15. Looks like the patch hadn't made its way to latest build. Could you provide a patch for qemu_2.10.0. Much appreciated
Similar fault occurs with bitbake qtcharts too.
Summary error as follows
ERROR: qemu-native-2.10.0-r0 do_compile: oe_runmake failed
ERROR: qemu-native-2.10.0-r0 do_compile: Function failed: do_compile (log file is located at /home/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/temp/log.do_compile.3812)
ERROR: Logfile of failure stored in: /home/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/temp/log.do_compile.3812
ERROR: Function failed: do_compile (log file is located at /home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/temp/log.do_compile.3812)
ERROR: Task (virtual:native:/home/tisdk/sources/oe-core/meta/recipes-devtools/qemu/qemu_2.10.0.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 603 tasks of which 598 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
PS:
To get this far I also had to save the linaro gcc to /opt/ directory. bitbake appeared to be searching for it there. So
tar -Jxvf gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf.tar.xz -C /opt/
export PATH=/opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin:$PATH
best regards
Naseer
DEBUG: Executing shell function do_compile
NOTE: make -j 3 LD=ld AR=ar OBJCOPY=objcopy LDFLAGS=-L/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/recipe-sysroot-native/usr/lib -L/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/recipe-sysroot-native/lib -Wl,-rpath-link,/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/recipe-sysroot-native/lib -Wl,-O1 -fuse-ld=bfd
LINK tests/qemu-iotests/socket_scm_helper
GEN qemu-doc.txt
GEN qemu-doc.html
GEN qemu.1
GEN docs/interop/qemu-qmp-ref.html
GEN docs/interop/qemu-qmp-ref.txt
GEN docs/interop/qemu-qmp-ref.7
GEN docs/interop/qemu-ga-ref.html
GEN docs/interop/qemu-ga-ref.txt
GEN docs/interop/qemu-ga-ref.7
CC qga/commands.o
CC qga/guest-agent-command-state.o
CC qga/main.o
CC qga/commands-posix.o
CC qga/channel-posix.o
CC qga/qapi-generated/qga-qapi-types.o
CC qga/qapi-generated/qga-qapi-visit.o
CC qga/qapi-generated/qga-qmp-marshal.o
AR libqemuutil.a
AR libqemustub.a
CC block/parallels.o
CC block/blkdebug.o
CC block/blkverify.o
CC block/blkreplay.o
CC block/block-backend.o
CC block/snapshot.o
CC block/qapi.o
CC block/file-posix.o
CC block/null.o
CC block/mirror.o
CC block/commit.o
CC block/io.o
CC block/throttle-groups.o
CC block/nbd.o
CC block/nbd-client.o
CC block/sheepdog.o
CC block/accounting.o
CC block/dirty-bitmap.o
CC block/write-threshold.o
CC block/backup.o
CC block/replication.o
CC block/crypto.o
CC nbd/server.o
CC nbd/client.o
CC nbd/common.o
CC crypto/init.o
CC crypto/hash.o
CC crypto/hash-glib.o
CC crypto/hmac.o
CC crypto/hmac-glib.o
CC crypto/aes.o
CC crypto/desrfb.o
CC crypto/cipher.o
CC crypto/tlscreds.o
CC crypto/tlscredsanon.o
CC crypto/tlscredsx509.o
CC crypto/tlssession.o
CC crypto/secret.o
CC crypto/random-platform.o
CC crypto/pbkdf.o
CC crypto/ivgen.o
CC crypto/ivgen-essiv.o
CC crypto/ivgen-plain.o
CC crypto/ivgen-plain64.o
CC crypto/afsplit.o
CC crypto/xts.o
CC crypto/block.o
CC crypto/block-qcow.o
CC crypto/block-luks.o
CC io/channel.o
CC io/channel-buffer.o
CC io/channel-command.o
CC io/channel-file.o
CC io/channel-socket.o
CC io/channel-tls.o
CC io/channel-watch.o
CC io/channel-websock.o
CC io/channel-util.o
CC io/dns-resolver.o
CC io/task.o
CC qom/object.o
CC qom/container.o
CC qom/qom-qobject.o
CC qom/object_interfaces.o
GEN qemu-img-cmds.h
CC qemu-io.o
CC qemu-bridge-helper.o
CC blockdev.o
CC blockdev-nbd.o
CC bootdevice.o
CC iothread.o
CC qdev-monitor.o
CC device-hotplug.o
CC os-posix.o
CC bt-host.o
CC bt-vhci.o
CC dma-helpers.o
CC vl.o
CC tpm.o
CC device_tree.o
CC qmp-marshal.o
CC qmp.o
CC hmp.o
CC cpus-common.o
CC audio/audio.o
CC audio/noaudio.o
CC audio/wavaudio.o
CC audio/mixeng.o
CC audio/ossaudio.o
CC audio/alsaaudio.o
CC audio/wavcapture.o
CC backends/rng.o
CC backends/rng-egd.o
CC backends/rng-random.o
CC backends/tpm.o
CC backends/hostmem.o
CC backends/hostmem-ram.o
CC backends/hostmem-file.o
CC backends/cryptodev.o
CC backends/cryptodev-builtin.o
CC block/stream.o
CC chardev/msmouse.o
CC chardev/wctablet.o
CC chardev/testdev.o
CC disas/arm.o
CXX disas/arm-a64.o
CC disas/i386.o
CC disas/mips.o
CC disas/ppc.o
CC disas/sh4.o
CXX disas/libvixl/vixl/utils.o
CXX disas/libvixl/vixl/compiler-intrinsics.o
CXX disas/libvixl/vixl/a64/instructions-a64.o
CXX disas/libvixl/vixl/a64/decoder-a64.o
CXX disas/libvixl/vixl/a64/disasm-a64.o
CC fsdev/qemu-fsdev-dummy.o
CC fsdev/qemu-fsdev-opts.o
CC fsdev/qemu-fsdev-throttle.o
CC hw/acpi/core.o
CC hw/acpi/piix4.o
CC hw/acpi/pcihp.o
CC hw/acpi/ich9.o
CC hw/acpi/tco.o
CC hw/acpi/cpu_hotplug.o
CC hw/acpi/memory_hotplug.o
CC hw/acpi/cpu.o
CC hw/acpi/nvdimm.o
CC hw/acpi/vmgenid.o
CC hw/acpi/acpi_interface.o
CC hw/acpi/bios-linker-loader.o
CC hw/acpi/aml-build.o
CC hw/acpi/ipmi.o
CC hw/acpi/acpi-stub.o
CC hw/acpi/ipmi-stub.o
CC hw/audio/sb16.o
CC hw/audio/es1370.o
CC hw/audio/ac97.o
CC hw/audio/fmopl.o
CC hw/audio/adlib.o
CC hw/audio/gus.o
CC hw/audio/gusemu_hal.o
CC hw/audio/gusemu_mixer.o
CC hw/audio/cs4231a.o
CC hw/audio/intel-hda.o
CC hw/audio/hda-codec.o
CC hw/audio/pcspk.o
CC hw/audio/wm8750.o
CC hw/audio/pl041.o
CC hw/audio/lm4549.o
CC hw/audio/marvell_88w8618.o
CC hw/audio/soundhw.o
CC hw/block/block.o
CC hw/block/cdrom.o
CC hw/block/hd-geometry.o
CC hw/block/fdc.o
CC hw/block/m25p80.o
CC hw/block/nand.o
CC hw/block/pflash_cfi01.o
CC hw/block/pflash_cfi02.o
CC hw/block/ecc.o
CC hw/block/onenand.o
CC hw/block/nvme.o
CC hw/bt/core.o
CC hw/bt/l2cap.o
CC hw/bt/sdp.o
CC hw/bt/hci.o
CC hw/bt/hid.o
CC hw/bt/hci-csr.o
CC hw/char/ipoctal232.o
CC hw/char/escc.o
CC hw/char/parallel.o
CC hw/char/pl011.o
CC hw/char/serial.o
CC hw/char/serial-isa.o
CC hw/char/serial-pci.o
CC hw/char/virtio-console.o
CC hw/char/xilinx_uartlite.o
CC hw/char/cadence_uart.o
CC hw/char/cmsdk-apb-uart.o
CC hw/char/debugcon.o
CC hw/char/imx_serial.o
CC hw/core/qdev.o
CC hw/core/bus.o
CC hw/core/qdev-properties.o
CC hw/core/reset.o
CC hw/core/fw-path-provider.o
CC hw/core/irq.o
CC hw/core/hotplug.o
CC hw/core/nmi.o
CC hw/core/empty_slot.o
CC hw/core/ptimer.o
CC hw/core/sysbus.o
CC hw/core/machine.o
CC hw/core/loader.o
CC hw/core/loader-fit.o
CC hw/core/qdev-properties-system.o
CC hw/core/register.o
CC hw/core/or-irq.o
CC hw/core/platform-bus.o
CC hw/cpu/core.o
CC hw/display/ads7846.o
CC hw/display/cirrus_vga.o
CC hw/display/g364fb.o
CC hw/display/jazz_led.o
CC hw/display/pl110.o
CC hw/display/ssd0303.o
CC hw/display/ssd0323.o
CC hw/display/vga-pci.o
CC hw/display/vga-isa.o
CC hw/display/vga-isa-mm.o
CC hw/display/vmware_vga.o
CC hw/display/blizzard.o
CC hw/display/exynos4210_fimd.o
CC hw/display/framebuffer.o
CC hw/display/tc6393xb.o
CC hw/dma/rc4030.o
CC hw/dma/pl080.o
CC hw/dma/pl330.o
CC hw/dma/i82374.o
CC hw/dma/i8257.o
CC hw/dma/xlnx-zynq-devcfg.o
CC hw/gpio/max7310.o
CC hw/gpio/pl061.o
CC hw/gpio/zaurus.o
CC hw/gpio/mpc8xxx.o
CC hw/gpio/gpio_key.o
CC hw/i2c/core.o
CC hw/i2c/smbus.o
CC hw/i2c/smbus_eeprom.o
CC hw/i2c/i2c-ddc.o
CC hw/i2c/versatile_i2c.o
CC hw/i2c/smbus_ich9.o
CC hw/i2c/pm_smbus.o
CC hw/i2c/bitbang_i2c.o
CC hw/i2c/exynos4210_i2c.o
CC hw/i2c/imx_i2c.o
CC hw/i2c/aspeed_i2c.o
CC hw/ide/core.o
CC hw/ide/atapi.o
CC hw/ide/qdev.o
CC hw/ide/pci.o
CC hw/ide/isa.o
CC hw/ide/piix.o
CC hw/ide/cmd646.o
CC hw/ide/macio.o
CC hw/ide/mmio.o
CC hw/ide/via.o
CC hw/ide/microdrive.o
CC hw/ide/ahci.o
CC hw/ide/ich.o
CC hw/input/adb.o
CC hw/input/hid.o
CC hw/input/lm832x.o
CC hw/input/pckbd.o
CC hw/input/pl050.o
CC hw/input/ps2.o
CC hw/input/stellaris_input.o
CC hw/input/tsc2005.o
CC hw/input/vmmouse.o
CC hw/input/virtio-input.o
CC hw/input/virtio-input-hid.o
CC hw/input/virtio-input-host.o
CC hw/intc/heathrow_pic.o
CC hw/intc/i8259_common.o
CC hw/intc/i8259.o
CC hw/intc/pl190.o
CC hw/intc/xilinx_intc.o
CC hw/intc/imx_avic.o
CC hw/intc/realview_gic.o
CC hw/intc/ioapic_common.o
CC hw/intc/arm_gic_common.o
CC hw/intc/arm_gic.o
CC hw/intc/arm_gicv2m.o
CC hw/intc/arm_gicv3_common.o
CC hw/intc/arm_gicv3.o
CC hw/intc/arm_gicv3_dist.o
CC hw/intc/arm_gicv3_redist.o
CC hw/intc/arm_gicv3_its_common.o
CC hw/intc/openpic.o
CC hw/intc/intc.o
CC hw/ipack/ipack.o
CC hw/ipack/tpci200.o
CC hw/ipmi/ipmi.o
CC hw/ipmi/ipmi_bmc_sim.o
CC hw/ipmi/ipmi_bmc_extern.o
CC hw/ipmi/isa_ipmi_kcs.o
CC hw/ipmi/isa_ipmi_bt.o
CC hw/isa/isa-bus.o
CC hw/isa/apm.o
CC hw/isa/i82378.o
CC hw/isa/pc87312.o
CC hw/isa/piix4.o
CC hw/isa/vt82c686.o
CC hw/mem/pc-dimm.o
CC hw/mem/nvdimm.o
CC hw/misc/applesmc.o
CC hw/misc/max111x.o
CC hw/misc/tmp105.o
CC hw/misc/tmp421.o
CC hw/misc/debugexit.o
CC hw/misc/sga.o
CC hw/misc/pc-testdev.o
CC hw/misc/pci-testdev.o
CC hw/misc/edu.o
CC hw/misc/unimp.o
CC hw/misc/arm_l2x0.o
CC hw/misc/arm_integrator_debug.o
CC hw/misc/a9scu.o
CC hw/misc/arm11scu.o
CC hw/misc/macio/macio.o
CC hw/misc/macio/cuda.o
CC hw/misc/macio/mac_dbdma.o
CC hw/net/dp8393x.o
CC hw/net/ne2000.o
CC hw/net/eepro100.o
CC hw/net/pcnet-pci.o
CC hw/net/pcnet.o
CC hw/net/e1000.o
CC hw/net/e1000x_common.o
CC hw/net/net_tx_pkt.o
CC hw/net/net_rx_pkt.o
CC hw/net/e1000e.o
CC hw/net/e1000e_core.o
CC hw/net/rtl8139.o
CC hw/net/vmxnet3.o
CC hw/net/smc91c111.o
CC hw/net/lan9118.o
CC hw/net/ne2000-isa.o
CC hw/net/xgmac.o
CC hw/net/mipsnet.o
CC hw/net/allwinner_emac.o
CC hw/net/imx_fec.o
CC hw/net/cadence_gem.o
CC hw/net/stellaris_enet.o
CC hw/net/ftgmac100.o
CC hw/net/rocker/rocker.o
CC hw/net/rocker/rocker_fp.o
CC hw/net/rocker/rocker_desc.o
CC hw/net/rocker/rocker_world.o
CC hw/net/rocker/rocker_of_dpa.o
CC hw/nvram/ds1225y.o
CC hw/nvram/eeprom93xx.o
CC hw/nvram/fw_cfg.o
CC hw/nvram/chrp_nvram.o
CC hw/nvram/mac_nvram.o
CC hw/pci-bridge/pci_bridge_dev.o
CC hw/pci-bridge/pcie_root_port.o
CC hw/pci-bridge/gen_pcie_root_port.o
CC hw/pci-bridge/pci_expander_bridge.o
CC hw/pci-bridge/xio3130_upstream.o
CC hw/pci-bridge/xio3130_downstream.o
CC hw/pci-bridge/ioh3420.o
CC hw/pci-bridge/i82801b11.o
CC hw/pci-bridge/dec.o
CC hw/pci-host/pam.o
CC hw/pci-host/prep.o
CC hw/pci-host/grackle.o
CC hw/pci-host/uninorth.o
CC hw/pci-host/ppce500.o
CC hw/pci-host/versatile.o
CC hw/pci-host/bonito.o
CC hw/pci-host/piix.o
CC hw/pci-host/q35.o
CC hw/pci-host/gpex.o
CC hw/pci-host/xilinx-pcie.o
CC hw/pci/pci.o
CC hw/pci/pci_bridge.o
CC hw/pci/msix.o
CC hw/pci/msi.o
CC hw/pci/shpc.o
CC hw/pci/slotid_cap.o
CC hw/pci/pci_host.o
CC hw/pci/pcie_host.o
CC hw/pci/pcie.o
CC hw/pci/pcie_aer.o
CC hw/pci/pcie_port.o
CC hw/pci/pci-stub.o
CC hw/pcmcia/pcmcia.o
CC hw/scsi/scsi-disk.o
CC hw/scsi/scsi-bus.o
CC hw/scsi/scsi-generic.o
CC hw/scsi/lsi53c895a.o
CC hw/scsi/mptsas.o
CC hw/scsi/mptconfig.o
CC hw/scsi/mptendian.o
CC hw/scsi/megasas.o
CC hw/scsi/vmw_pvscsi.o
CC hw/scsi/esp.o
CC hw/scsi/esp-pci.o
CC hw/sd/pl181.o
CC hw/sd/ssi-sd.o
CC hw/sd/sd.o
CC hw/sd/core.o
CC hw/sd/sdhci.o
CC hw/smbios/smbios.o
CC hw/smbios/smbios_type_38.o
CC hw/smbios/smbios-stub.o
CC hw/smbios/smbios_type_38-stub.o
CC hw/ssi/pl022.o
CC hw/ssi/ssi.o
CC hw/ssi/xilinx_spips.o
CC hw/ssi/aspeed_smc.o
CC hw/ssi/stm32f2xx_spi.o
CC hw/timer/arm_timer.o
CC hw/timer/arm_mptimer.o
CC hw/timer/armv7m_systick.o
CC hw/timer/a9gtimer.o
CC hw/timer/cadence_ttc.o
CC hw/timer/ds1338.o
CC hw/timer/hpet.o
CC hw/timer/i8254_common.o
CC hw/timer/i8254.o
CC hw/timer/m48t59.o
CC hw/timer/m48t59-isa.o
CC hw/timer/pl031.o
CC hw/timer/twl92230.o
CC hw/timer/xilinx_timer.o
CC hw/timer/imx_epit.o
CC hw/timer/imx_gpt.o
CC hw/timer/stm32f2xx_timer.o
CC hw/timer/aspeed_timer.o
CC hw/timer/cmsdk-apb-timer.o
CC hw/tpm/tpm_tis.o
CC hw/tpm/tpm_passthrough.o
CC hw/tpm/tpm_util.o
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/hw/tpm/tpm_passthrough.c: In function ‘tpm_passthrough_shutdown’:
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/hw/tpm/tpm_passthrough.c:315:9: warning: implicit declaration of function ‘migrate_del_blocker’ [-Wimplicit-function-declaration]
migrate_del_blocker(tpm_pt->migration_blocker);
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/hw/tpm/tpm_passthrough.c:315:9: warning: nested extern declaration of ‘migrate_del_blocker’ [-Wnested-externs]
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/hw/tpm/tpm_passthrough.c: In function ‘tpm_passthrough_block_migration’:
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/hw/tpm/tpm_passthrough.c:651:13: warning: implicit declaration of function ‘migrate_add_blocker’ [-Wimplicit-function-declaration]
migrate_add_blocker(tpm_pt->migration_blocker);
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/hw/tpm/tpm_passthrough.c:651:13: warning: nested extern declaration of ‘migrate_add_blocker’ [-Wnested-externs]
CC hw/usb/core.o
CC hw/usb/combined-packet.o
CC hw/usb/bus.o
CC hw/usb/libhw.o
CC hw/usb/desc.o
CC hw/usb/desc-msos.o
CC hw/usb/hcd-uhci.o
CC hw/usb/hcd-ohci.o
CC hw/usb/hcd-ehci.o
CC hw/usb/hcd-ehci-pci.o
CC hw/usb/hcd-ehci-sysbus.o
CC hw/usb/hcd-xhci.o
CC hw/usb/hcd-xhci-nec.o
CC hw/usb/hcd-musb.o
CC hw/usb/dev-hub.o
CC hw/usb/dev-hid.o
CC hw/usb/dev-wacom.o
CC hw/usb/dev-storage.o
CC hw/usb/dev-uas.o
CC hw/usb/dev-audio.o
CC hw/usb/dev-serial.o
CC hw/usb/dev-network.o
CC hw/usb/dev-bluetooth.o
CC hw/usb/dev-smartcard-reader.o
CC hw/usb/dev-mtp.o
CC hw/usb/host-stub.o
CC hw/virtio/virtio-rng.o
CC hw/virtio/virtio-pci.o
CC hw/virtio/virtio-bus.o
CC hw/virtio/virtio-mmio.o
CC hw/virtio/vhost-stub.o
CC hw/watchdog/watchdog.o
CC hw/watchdog/wdt_i6300esb.o
CC hw/watchdog/wdt_ib700.o
CC hw/watchdog/wdt_aspeed.o
CC migration/migration.o
CC migration/socket.o
CC migration/fd.o
CC migration/exec.o
CC migration/tls.o
CC migration/channel.o
CC migration/savevm.o
CC migration/colo-comm.o
CC migration/colo.o
CC migration/colo-failover.o
CC migration/vmstate.o
CC migration/vmstate-types.o
CC migration/page_cache.o
CC migration/qemu-file.o
CC migration/global_state.o
CC migration/qemu-file-channel.o
CC migration/xbzrle.o
CC migration/postcopy-ram.o
CC migration/qjson.o
CC migration/block.o
CC net/net.o
CC net/queue.o
CC net/checksum.o
CC net/util.o
CC net/hub.o
CC net/socket.o
CC net/dump.o
CC net/eth.o
CC net/l2tpv3.o
CC net/vhost-user.o
CC net/slirp.o
CC net/filter.o
CC net/filter-buffer.o
CC net/filter-mirror.o
CC net/colo-compare.o
CC net/colo.o
CC net/filter-rewriter.o
CC net/filter-replay.o
CC net/tap.o
CC net/tap-linux.o
CC qom/cpu.o
CC replay/replay.o
CC replay/replay-internal.o
CC replay/replay-events.o
CC replay/replay-time.o
CC replay/replay-input.o
CC replay/replay-char.o
CC replay/replay-snapshot.o
CC replay/replay-net.o
CC replay/replay-audio.o
CC slirp/cksum.o
CC slirp/if.o
CC slirp/ip_icmp.o
CC slirp/ip6_icmp.o
CC slirp/ip6_input.o
CC slirp/ip6_output.o
CC slirp/ip_input.o
CC slirp/ip_output.o
CC slirp/dnssearch.o
CC slirp/dhcpv6.o
CC slirp/slirp.o
CC slirp/mbuf.o
CC slirp/misc.o
CC slirp/sbuf.o
CC slirp/tcp_input.o
CC slirp/socket.o
CC slirp/tcp_output.o
CC slirp/tcp_subr.o
CC slirp/tcp_timer.o
CC slirp/udp.o
CC slirp/udp6.o
CC slirp/bootp.o
CC slirp/tftp.o
CC slirp/arp_table.o
CC slirp/ndp_table.o
CC slirp/ncsi.o
CC ui/keymaps.o
CC ui/console.o
CC ui/cursor.o
CC ui/qemu-pixman.o
CC ui/input.o
CC ui/input-keymap.o
CC ui/input-legacy.o
CC ui/input-linux.o
CC ui/vnc.o
CC ui/vnc-enc-zlib.o
CC ui/vnc-enc-hextile.o
CC ui/vnc-enc-tight.o
CC ui/vnc-palette.o
CC ui/vnc-enc-zrle.o
CC ui/vnc-auth-vencrypt.o
CC ui/vnc-ws.o
CC ui/vnc-jobs.o
CC chardev/char.o
CC chardev/char-fd.o
CC chardev/char-fe.o
CC chardev/char-file.o
CC chardev/char-io.o
CC chardev/char-mux.o
CC chardev/char-null.o
CC chardev/char-parallel.o
CC chardev/char-pipe.o
CC chardev/char-pty.o
CC chardev/char-ringbuf.o
CC chardev/char-serial.o
CC chardev/char-socket.o
CC chardev/char-stdio.o
CC chardev/char-udp.o
nm: arch-query-cpu-model-expansion.o: File format not recognized
nm: arch-query-cpu-model-comparison.o: File format not recognized
nm: arch-query-cpu-model-baseline.o: File format not recognized
nm: bdrv-next-monitor-owned.o: File format not recognized
nm: blk-commit-all.o: File format not recognized
nm: blockdev-close-all-bdrv-states.o: File format not recognized
nm: clock-warp.o: File format not recognized
nm: cpu-get-clock.o: File format not recognized
nm: cpu-get-icount.o: File format not recognized
nm: dump.o: File format not recognized
nm: error-printf.o: File format not recognized
nm: fdset.o: File format not recognized
nm: gdbstub.o: File format not recognized
nm: get-vm-name.o: File format not recognized
nm: iothread.o: File format not recognized
nm: iothread-lock.o: File format not recognized
nm: is-daemonized.o: File format not recognized
nm: machine-init-done.o: File format not recognized
nm: migr-blocker.o: File format not recognized
nm: change-state-handler.o: File format not recognized
nm: monitor.o: File format not recognized
nm: notify-event.o: File format not recognized
nm: qtest.o: File format not recognized
nm: replay.o: File format not recognized
nm: runstate-check.o: File format not recognized
nm: set-fd-handler.o: File format not recognized
nm: slirp.o: File format not recognized
nm: sysbus.o: File format not recognized
nm: trace-control.o: File format not recognized
nm: uuid.o: File format not recognized
nm: vm-stop.o: File format not recognized
nm: vmstate.o: File format not recognized
nm: qmp_pc_dimm_device_list.o: File format not recognized
nm: target-monitor-defs.o: File format not recognized
nm: target-get-monitor-def.o: File format not recognized
nm: pc_madt_cpu_entry.o: File format not recognized
nm: vmgenid.o: File format not recognized
nm: xen-common.o: File format not recognized
nm: xen-hvm.o: File format not recognized
LINK qemu-ga
LINK ivshmem-client
contrib/ivshmem-client/ivshmem-client.o: file not recognized: File truncated
collect2: error: ld returned 1 exit status
Makefile:473: recipe for target 'ivshmem-client' failed
make: *** [ivshmem-client] Error 1
make: *** Waiting for unfinished jobs....
libqemuutil.a(control.o): In function `trace_enable_events':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/trace/control.c:205: undefined reference to `cur_mon'
libqemuutil.a(control.o): In function `do_trace_enable_events':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/trace/control.c:189: undefined reference to `trace_event_set_state_dynamic'
libqemuutil.a(control.o): In function `trace_fini_vcpu':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/trace/control.c:283: undefined reference to `trace_event_set_vcpu_state_dynamic'
libqemuutil.a(osdep.o): In function `qemu_open':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/osdep.c:261: undefined reference to `monitor_fdset_get_fd'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/osdep.c:271: undefined reference to `monitor_fdset_dup_fd_add'
libqemuutil.a(osdep.o): In function `qemu_close':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/osdep.c:314: undefined reference to `monitor_fdset_dup_fd_find'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/osdep.c:320: undefined reference to `monitor_fdset_dup_fd_remove'
libqemuutil.a(qemu-error.o): In function `error_printf':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-error.c:32: undefined reference to `error_vprintf'
libqemuutil.a(qemu-error.o): In function `vreport':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-error.c:204: undefined reference to `cur_mon'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-error.c:224: undefined reference to `error_vprintf'
libqemuutil.a(qemu-error.o): In function `print_loc':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-error.c:165: undefined reference to `cur_mon'
libqemuutil.a(qemu-error.o): In function `error_printf_unless_qmp':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-error.c:41: undefined reference to `error_vprintf_unless_qmp'
libqemuutil.a(qemu-sockets.o): In function `socket_connect':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-sockets.c:1144: undefined reference to `cur_mon'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-sockets.c:1144: undefined reference to `monitor_get_fd'
libqemuutil.a(qemu-sockets.o): In function `socket_listen':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-sockets.c:1175: undefined reference to `cur_mon'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-sockets.c:1175: undefined reference to `monitor_get_fd'
libqemuutil.a(log.o): In function `qemu_set_log':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/log.c:98: undefined reference to `is_daemonized'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/log.c:63: undefined reference to `is_daemonized'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/log.c:71: undefined reference to `is_daemonized'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/log.c:79: undefined reference to `is_daemonized'
libqemuutil.a(async.o): In function `aio_co_enter':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/async.c:461: undefined reference to `qemu_get_current_aio_context'
libqemuutil.a(qemu-timer.o): In function `qemu_clock_use_for_deadline':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-timer.c:142: undefined reference to `use_icount'
libqemuutil.a(qemu-timer.o): In function `timerlist_rearm':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-timer.c:402: undefined reference to `qemu_start_warp_timer'
libqemuutil.a(qemu-timer.o): In function `qemu_clock_get_ns':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-timer.c:607: undefined reference to `use_icount'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-timer.c:610: undefined reference to `cpu_get_clock'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-timer.c:621: undefined reference to `replay_mode'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-timer.c:621: undefined reference to `cpu_get_clock'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-timer.c:621: undefined reference to `replay_save_clock'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-timer.c:613: undefined reference to `replay_mode'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-timer.c:608: undefined reference to `cpu_get_icount'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-timer.c:613: undefined reference to `replay_save_clock'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-timer.c:613: undefined reference to `replay_read_clock'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-timer.c:621: undefined reference to `replay_read_clock'
libqemuutil.a(qemu-timer.o): In function `timerlist_run_timers':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-timer.c:502: undefined reference to `replay_checkpoint'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-timer.c:512: undefined reference to `replay_checkpoint'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-timer.c:507: undefined reference to `replay_checkpoint'
libqemuutil.a(qemu-timer.o): In function `timerlistgroup_deadline_ns':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-timer.c:581: undefined reference to `replay_mode'
libqemuutil.a(main-loop.o): In function `qemu_init_main_loop':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/main-loop.c:147: undefined reference to `qemu_timer_notify_cb'
libqemuutil.a(main-loop.o): In function `main_loop_wait':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/main-loop.c:503: undefined reference to `slirp_pollfds_fill'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/main-loop.c:516: undefined reference to `slirp_pollfds_poll'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/main-loop.c:520: undefined reference to `qemu_start_warp_timer'
libqemuutil.a(main-loop.o): In function `os_host_main_loop_wait':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/main-loop.c:238: undefined reference to `qtest_allowed'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/main-loop.c:238: undefined reference to `qtest_driver'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/main-loop.c:250: undefined reference to `qemu_mutex_unlock_iothread'
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/main-loop.c:258: undefined reference to `qemu_mutex_lock_iothread'
libqemuutil.a(qemu-coroutine.o): In function `qemu_coroutine_enter':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-coroutine.c:149: undefined reference to `qemu_get_current_aio_context'
libqemuutil.a(qemu-coroutine-lock.o): In function `qemu_co_mutex_lock':
/home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/qemu-2.10.0/util/qemu-coroutine-lock.c:267: undefined reference to `qemu_get_current_aio_context'
Makefile:447: recipe for target 'qemu-ga' failed
make: *** [qemu-ga] Error 1
make: *** wait: No child processes. Stop.
ERROR: oe_runmake failed
WARNING: /home/multisensor/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/qemu-native/2.10.0-r0/temp/run.do_compile.3812:1 exit 1 from 'exit 1'
