Tool/software: Linux
Hello together,
I´m working with TDA2P-EVM and VisionSDK 3.3 and running Linux on Cortex A15 (kernel 4.4.84).
In order to have network access, I added kernel boot parameter ip=dhcp. During boot procedure, the eth0 port gets initialized and a vaild IP address and mask is set, but after some seconds and in most cases, the kernel crashes. When network cable is not plugged in, kernel runs stable.
Any idea what can be the cause?
Thx in advance!
Alex
U-Boot 2016.05-00009-gac1d50f (Apr 17 2018 - 03:07:36 -0700) CPU : DRA762-GP ES1.0 Model: TI DRA762 EVM Board: DRA76x EVM REV A.2 DRAM: 4 GiB MMC: mmc@4809c000: fail to find sdr104 mode FDT_ERR_NOTFOUND no pinctrl for sdr104 mmc@4809c000: fail to find ddr50 mode FDT_ERR_NOTFOUND no pinctrl for ddr50 mmc@4809c000: fail to find sdr50 mode FDT_ERR_NOTFOUND no pinctrl for sdr50 mmc@4809c000: fail to find sdr25 mode FDT_ERR_NOTFOUND no pinctrl for sdr25 mmc@4809c000: fail to find sdr12 mode FDT_ERR_NOTFOUND no pinctrl for sdr12 OMAP SD/MMC: 0, OMAP SD/MMC: 1 *** Warning - bad CRC, using default environment GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645 part_get_info_efi: *** ERROR: Invalid GPT *** GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645 part_get_info_efi: *** ERROR: Invalid Backup GPT *** ERROR: cannot find partition: 'userdata' at arch/arm/cpu/armv7/omap-common/utils.c:199/mmc_get_part_size() Warning: fastboot.userdata_size: unable to calc SCSI: SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst scanning bus for devices... Found 0 device(s). Net: Warning: ethernet@48484000 using MAC address from ROM eth0: ethernet@48484000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 reading boot.scr ** Unable to read file boot.scr ** reading uEnv.txt 303 bytes read in 4 ms (73.2 KiB/s) Loaded env from uEnv.txt Importing environment from mmc0 ... switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 3522720 bytes read in 1245 ms (2.7 MiB/s) 106530 bytes read in 160 ms (649.4 KiB/s) Booting from mmc0 ... Kernel image @ 0x82000000 [ 0x000000 - 0x35c0a0 ] ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 8ffe2000, end 8ffff021 ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.84-00105-gc66ba60-dirty (alex@ubuntu) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #118 SMP PREEMPT Thu Aug 23 14:43:45 CEST 2018 [ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] Machine model: TI DRA762 EVM [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB [ 0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB [ 0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB [ 0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB [ 0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool [ 0.000000] cma: Reserved 256 MiB at 0x00000000ef000000 [ 0.000000] Forcing write-allocate cache policy for SMP [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] OMAP4: Map 0x000000027fd00000 to fe600000 for dram barrier [ 0.000000] DRA762 ES1.0 [ 0.000000] PERCPU: Embedded 11 pages/cpu @eb726000 s14848 r8192 d22016 u45056 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1040704 [ 0.000000] Kernel command line: console=ttyO0,115200n8 vram=16M root=PARTUUID=8c970dd9-02 rw rootwait fixrtc consoleblank=0 cma=256M rootfstype=ext4 megaraid_sas.msix_disable=1 megaraid_sas.smp_affinity_enable=0 ip=dhcp libata.force=ncq ahci.marvell_enable=1 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 3695404K/4169728K available (6555K kernel code, 316K rwdata, 2364K rodata, 340K init, 286K bss, 48340K reserved, 425984K cma-reserved, 3125248K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc08be03c (8921 kB) [ 0.000000] .init : 0xc08bf000 - 0xc0914000 ( 340 kB) [ 0.000000] .data : 0xc0914000 - 0xc0963300 ( 317 kB) [ 0.000000] .bss : 0xc0965000 - 0xc09ac800 ( 286 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 32. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div [ 0.000000] OMAP clockevent source: timer1 at 32786 Hz [ 0.000000] Architected cp15 timer(s) running at 6.14MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns [ 0.000004] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns [ 0.000014] Switching to timer-based delay loop, resolution 162ns [ 0.000329] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns [ 0.000337] OMAP clocksource: 32k_counter at 32768 Hz [ 0.000790] Console: colour dummy device 80x30 [ 0.000806] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0' [ 0.000813] This ensures that you still see kernel messages. Please [ 0.000818] update your kernel commandline. [ 0.000831] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475) [ 0.000844] pid_max: default: 32768 minimum: 301 [ 0.000940] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000950] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001477] Initializing cgroup subsys io [ 0.001494] Initializing cgroup subsys memory [ 0.001518] Initializing cgroup subsys devices [ 0.001530] Initializing cgroup subsys freezer [ 0.001541] Initializing cgroup subsys perf_event [ 0.001553] Initializing cgroup subsys pids [ 0.001578] CPU: Testing write buffer coherency: ok [ 0.001768] /cpus/cpu@0 missing clock-frequency property [ 0.001785] /cpus/cpu@1 missing clock-frequency property [ 0.001795] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.001829] Setting up static identity map for 0x800082c0 - 0x80008320 [ 0.080069] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.080137] Brought up 2 CPUs [ 0.080150] SMP: Total of 2 processors activated (24.59 BogoMIPS). [ 0.080156] CPU: All CPU(s) started in HYP mode. [ 0.080161] CPU: Virtualization extensions available. [ 0.080493] devtmpfs: initialized [ 0.109864] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0 [ 0.110830] omap_hwmod: l3_main_2 using broken dt data from ocp [ 0.226208] omap_hwmod: dcan1: _wait_target_disable failed [ 0.326514] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.326537] futex hash table entries: 512 (order: 3, 32768 bytes) [ 0.334607] pinctrl core: initialized pinctrl subsystem [ 0.335459] NET: Registered protocol family 16 [ 0.336472] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.360244] cpuidle: using governor ladder [ 0.390265] cpuidle: using governor menu [ 0.399094] OMAP GPIO hardware version 0.1 [ 0.403274] GPIO line 161 (radio_rst) hogged as output/low [ 0.405663] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 ! [ 0.432960] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.432970] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.433430] omap4_sram_init:Unable to allocate sram needed to handle errata I688 [ 0.433439] omap4_sram_init:Unable to get sram pool needed to handle errata I688 [ 0.434014] OMAP DMA hardware revision 0.0 [ 0.462823] edma 43300000.edma: memcpy is disabled [ 0.467480] edma 43300000.edma: TI EDMA DMA engine driver [ 0.472371] omap-iommu 40d01000.mmu: 40d01000.mmu registered [ 0.472546] omap-iommu 40d02000.mmu: 40d02000.mmu registered [ 0.472723] omap-iommu 58882000.mmu: 58882000.mmu registered [ 0.472883] omap-iommu 55082000.mmu: 55082000.mmu registered [ 0.473159] omap-iommu 41501000.mmu: 41501000.mmu registered [ 0.473339] omap-iommu 41502000.mmu: 41502000.mmu registered [ 0.476614] palmas 0-0058: IRQ missing: skipping irq request [ 0.490711] palmas 0-0058: Muxing GPIO 51, PWM 0, LED 2 [ 0.541257] irq: no irq domain found for /ocp/i2c@48070000/tps65917@58 ! [ 0.542182] pcf857x 0-0020: probed [ 0.542764] pcf857x 0-0021: probed [ 0.543146] GPIO line 465 (vin6_sel_s0) hogged as output/low [ 0.543241] pcf857x 0-0026: probed [ 0.543393] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz [ 0.543784] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz [ 0.560570] pcf857x: probe of 3-0021 failed with error -121 [ 0.560606] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz [ 0.580580] pca953x 4-0020: failed reading register [ 0.580598] pca953x: probe of 4-0020 failed with error -121 [ 0.581209] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz [ 0.581424] media: Linux media interface: v0.10 [ 0.581476] Linux video capture interface: v2.00 [ 0.581514] pps_core: LinuxPPS API ver. 1 registered [ 0.581521] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.581544] PTP clock support registered [ 0.581585] EDAC MC: Ver: 3.0.0 [ 0.582344] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400 [ 0.582638] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400 [ 0.583003] Advanced Linux Sound Architecture Driver Initialized. [ 0.583928] clocksource: Switched to clocksource arch_sys_counter [ 0.594212] NET: Registered protocol family 2 [ 0.594703] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 0.594767] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 0.594891] TCP: Hash tables configured (established 8192 bind 8192) [ 0.594937] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.594968] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.595116] NET: Registered protocol family 1 [ 0.595370] RPC: Registered named UNIX socket transport module. [ 0.595379] RPC: Registered udp transport module. [ 0.595385] RPC: Registered tcp transport module. [ 0.595391] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.605849] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.606487] NFS: Registering the id_resolver key type [ 0.606512] Key type id_resolver registered [ 0.606519] Key type id_legacy registered [ 0.606584] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.607845] bounce: pool size: 64 pages [ 0.607991] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [ 0.608007] io scheduler noop registered [ 0.608021] io scheduler deadline registered [ 0.608055] io scheduler cfq registered (default) [ 0.610392] vsys_5v0: supplied by vsys_12v0 [ 0.610441] ldo3: supplied by vsys_5v0 [ 0.614183] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128 [ 0.617534] PCI host bridge /ocp/axi@0/pcie_rc@51000000 ranges: [ 0.617546] No bus range found for /ocp/axi@0/pcie_rc@51000000, using [bus 00-ff] [ 0.617578] IO 0x20003000..0x20012fff -> 0x00000000 [ 0.617600] MEM 0x20013000..0x2fffffff -> 0x20013000 [ 0.647427] dra7-pcie 51000000.pcie_rc: link is not up [ 0.647592] dra7-pcie 51000000.pcie_rc: PCI host bridge to bus 0000:00 [ 0.647605] pci_bus 0000:00: root bus resource [bus 00-ff] [ 0.647616] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] [ 0.647626] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff] [ 1.283951] PCI: bus0: Fast back to back transfers disabled [ 1.303950] PCI: bus1: Fast back to back transfers enabled [ 1.304034] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff] [ 1.304049] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff] [ 1.304062] pci 0000:00:00.0: PCI bridge to [bus 01] [ 1.304281] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt [ 1.364522] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 1.367848] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250 [ 2.369980] console [ttyS0] enabled [ 2.374383] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 302, base_baud = 3000000) is a 8250 [ 2.384087] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 303, base_baud = 3000000) is a 8250 [ 2.394187] [drm] Initialized drm 1.1.0 20060810 [ 2.400518] vsys_3v3: supplied by vsys_12v0 [ 2.404813] ldo5: supplied by vsys_3v3 [ 2.409137] OMAP DSS rev 6.1 [ 2.412876] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops) [ 2.421330] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops) [ 2.497280] loop: module loaded [ 2.503250] vmemexp device MAJOR num = 246 [ 2.507404] vmemexp class registered [ 2.511118] /dev/vmemexp device registered [ 2.515251] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120 [ 2.523576] m25p80 spi32766.0: s25fl256s1 (32768 Kbytes) [ 2.528994] 7 ofpart partitions found on MTD device spi32766.0 [ 2.534867] Creating 7 MTD partitions on "spi32766.0": [ 2.540029] 0x000000000000-0x000000040000 : "QSPI.SPL" [ 2.556149] 0x000000040000-0x000000140000 : "QSPI.u-boot" [ 2.572538] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os" [ 2.579522] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env" [ 2.586214] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1" [ 2.593589] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel" [ 2.599913] 0x0000009e0000-0x000002000000 : "QSPI.file-system" [ 2.606696] ti-qspi 4b300000.qspi: No Rx DMA available, trying mmap mode [ 2.614662] libphy: Fixed MDIO Bus: probed [ 2.663960] davinci_mdio 48485000.mdio: davinci mdio revision 1.6 [ 2.670085] libphy: 48485000.mdio: probed [ 2.678040] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver TI DP83867 [ 2.686385] davinci_mdio 48485000.mdio: phy[3]: device 48485000.mdio:03, driver TI DP83867 [ 2.695371] cpsw 48484000.ethernet: Detected MACID = 74:e1:82:b4:fe:ba [ 2.702013] cpsw 48484000.ethernet: cpts: overflow check period 800 [ 2.709025] cpsw 48484000.ethernet: cpsw: Detected MACID = 74:e1:82:b4:fe:bb [ 2.717786] mousedev: PS/2 mouse device common for all mice [ 2.724125] i2c /dev entries driver [ 2.728283] tvp5158 4-0058: Unable to of_probe [ 2.733279] ov1063x 4-0037: Failed writing register 0x0103! [ 2.738937] ov1063x: probe of 4-0037 failed with error -121 [ 2.744748] ov490 4-0024: Failed reading register 0x300a! [ 2.750179] ov490: probe of 4-0024 failed with error -121 [ 2.756293] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin [ 2.763354] vip 48970000.vip: loading firmware vpdma-1b8.bin [ 2.773750] omap_hsmmc 4809c000.mmc: Got CD GPIO [ 2.778625] vpe 489d0000.vpe: Device registered as /dev/video0 [ 2.784518] vip 48970000.vip: VPDMA firmware loaded [ 2.784733] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode [ 2.784739] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode [ 2.784744] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode [ 2.784748] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode [ 2.784753] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode [ 2.789615] vio_3v3: supplied by vsys_3v3 [ 2.789670] vio_3v3_sd: supplied by vio_3v3 [ 2.789815] ldo4: supplied by vsys_5v0 [ 2.874529] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode [ 2.880914] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode [ 2.887487] smps5: supplied by vsys_3v3 [ 2.891546] vio_1v8: supplied by smps5 [ 2.935748] ledtrig-cpu: registered to indicate activity on CPUs [ 2.946861] hwspinlock_user gatemp: requested 20 hwspinlocks [ 2.953803] aic_dvdd: supplied by vio_3v3 [ 2.960866] NET: Registered protocol family 10 [ 2.976152] sit: IPv6 over IPv4 tunneling driver [ 2.981318] NET: Registered protocol family 17 [ 2.986048] Key type dns_resolver registered [ 2.990529] omap_voltage_late_init: Voltage driver support not added [ 2.997432] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm [ 3.003641] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm [ 3.009969] buck10: supplied by vsys_3v3 [ 3.014578] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm [ 3.020788] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm [ 3.028979] Power Management for TI OMAP4+ devices. [ 3.034063] Registering SWP/SWPB emulation handler [ 3.039648] dmm 4e000000.dmm: failed to initialize work-around, WA not used [ 3.047669] dmm 4e000000.dmm: initialized all PAT entries [ 3.055489] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 3.062129] [drm] No driver support for vblank timestamp query. [ 3.068475] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0 [ 3.074676] tvp5158 4-0058: Unable to of_probe [ 3.080253] input: gpio_keys as /devices/platform/gpio_keys/input/input0 [ 3.087147] tvp5158 4-0058: Unable to of_probe [ 3.092094] hctosys: unable to open rtc device (rtc0) [ 3.104310] net eth0: initializing cpsw version 1.15 (0) [ 3.109654] net eth0: initialized cpsw ale version 1.4 [ 3.111381] mmc0: host does not support reading read-only switch, assuming write-enable [ 3.113311] mmc0: Problem switching card into high-speed mode! [ 3.113363] mmc0: new SDHC card at address 0001 [ 3.123685] mmcblk0: mmc0:0001 00000 29.8 GiB [ 3.130363] mmcblk0: p1 p2 [ 3.130921] tvp5158 4-0058: Unable to of_probe [ 3.145015] net eth0: ALE Table size 1024 [ 3.167721] mmc1: MAN_BKOPS_EN bit is not set [ 3.179951] mmc1: new HS200 MMC card at address 0001 [ 3.195442] mmcblk1: mmc1:0001 MMC08G 7.25 GiB [ 3.200904] net eth0: phy found : id is : 0x2000a231 [ 3.210273] mmcblk1boot0: mmc1:0001 MMC08G partition 1 8.00 MiB [ 3.211891] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 3.211913] net eth1: initializing cpsw version 1.15 (0) [ 3.237747] mmcblk1boot1: mmc1:0001 MMC08G partition 2 8.00 MiB [ 3.244380] mmcblk1: p1 p2 [ 3.248820] tvp5158 4-0058: Unable to of_probe [ 3.263301] net eth1: phy found : id is : 0x2000a231 [ 3.272896] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready [ 7.201499] cpsw 48484000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx [ 7.213944] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 7.233932] Sending DHCP requests ., OK [ 7.343938] IP-Config: Got DHCP answer from 192.168.13.1, my address is 192.168.13.111 [ 7.357204] IP-Config: Complete: [ 7.360444] device=eth0, hwaddr=74:e1:82:b4:fe:ba, ipaddr=192.168.13.111, mask=255.255.255.0, gw=192.168.13.1 [ 7.370855] host=192.168.13.111, domain=Speedport_W_921V_1_44_000, nis-domain=(none) [ 7.379085] bootserver=192.168.13.1, rootserver=192.168.13.1, rootpath= [ 7.386008] nameserver0=192.168.13.1 [ 7.390309] aic_dvdd: disabling [ 7.393604] ALSA device list: [ 7.396589] No soundcards found. [ 7.509583] EXT4-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended [ 7.522281] EXT4-fs (mmcblk0p2): recovery complete [ 7.530433] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 7.538583] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 7.546191] devtmpfs: mounted [ 7.549285] Freeing unused kernel memory: 340K [ 7.553743] This architecture does not have kernel memory protection. [ 7.999557] systemd[1]: System time before build time, advancing clock. [ 8.085379] random: systemd: uninitialized urandom read (16 bytes read, 17 bits of entropy available) [ 8.098420] random: systemd: uninitialized urandom read (16 bytes read, 17 bits of entropy available) [ 8.109939] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN) [ 8.128273] systemd[1]: Detected architecture arm. Welcome to Arago 2016.12! [ 8.155633] systemd[1]: Set hostname to <dra7xx-evm>. [ 8.236823] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 18 bits of entropy available) [ 8.246938] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 18 bits of entropy available) [ 8.287762] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 18 bits of entropy available) [ 8.317471] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available) [ 8.330345] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available) [ 8.489972] random: systemd: uninitialized urandom read (16 bytes read, 22 bits of entropy available) [ 8.499408] random: systemd: uninitialized urandom read (16 bytes read, 22 bits of entropy available) [ 8.509091] random: systemd: uninitialized urandom read (16 bytes read, 22 bits of entropy available) [ 9.150647] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start [ 9.158448] systemd[1]: sysinit.target: Found dependency on alignment.service/start [ 9.166152] systemd[1]: sysinit.target: Found dependency on basic.target/start [ 9.173404] systemd[1]: sysinit.target: Found dependency on sockets.target/start [ 9.180846] systemd[1]: sysinit.target: Found dependency on avahi-daemon.socket/start [ 9.188718] systemd[1]: sysinit.target: Found dependency on sysinit.target/start [ 9.196165] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start [ 9.212151] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start [ SKIP ] Ordering cycle found, skipping alignment.service [ 9.245696] systemd[1]: Listening on Syslog Socket. [ OK ] Listening on Syslog Socket. [ 9.274995] systemd[1]: Created slice System Slice. [ OK ] Created slice System Slice. [ 9.304550] systemd[1]: Created slice system-getty.slice. [ OK ] Created slice system-getty.slice. [ 9.324117] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ OK ] Listening on /dev/initctl Compatibility Named Pipe. [ 9.354053] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 9.384043] systemd[1]: Reached target Swap. [ OK ] Reached target Swap. [ 9.404089] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 9.434444] systemd[1]: Created slice system-serial\x2dgetty.slice. [ OK ] Created slice system-serial\x2dgetty.slice. [ 9.464163] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ 9.494113] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 9.544178] systemd[1]: Starting Setup Virtual Console... Starting Setup Virtual Console... [ 9.576309] systemd[1]: Mounting Temporary Directory... Mounting Temporary Directory... [ 9.608497] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 9.664078] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 9.685541] systemd[1]: Mounting Debug File System... Mounting Debug File System... [ 9.704493] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 9.764199] systemd[1]: Starting Remount Root and Kernel File Systems... Starting Remount Root and Kernel File Systems... [ 9.780531] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 9.786163] systemd[1]: Reached target Slices. [ OK ] Reached target Slices. [ 9.814179] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 9.834116] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 9.864185] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 9.894165] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password Requests to Wall Directory Watch. [ 9.964214] systemd[1]: Starting Journal Service... Starting Journal Service... [ 9.984081] systemd[1]: Reached target Paths. [ OK ] Reached target Paths. [ 10.015623] systemd[1]: Starting Create list of required static device nodes for the current kernel... Starting Create list of required st... nodes for the current kernel... [ 10.051044] systemd[1]: Mounted POSIX Message Queue File System. [ OK ] Mounted POSIX Message Queue File System. [ 10.074241] systemd[1]: Mounted Debug File System. [ OK ] Mounted Debug File System. [ 10.094149] systemd[1]: Mounted Temporary Directory. [ OK ] Mounted Temporary Directory. [ 10.114237] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Started Setup Virtual Console. [FAILED] Failed to start Load Kernel Modules. See 'systemctl status systemd-modules-load.service' for details. [ OK ] Started Remount Root and Kernel File Systems. [ OK ] Started Create list of required sta...ce nodes for the current kernel. Starting Create Static Device Nodes in /dev... Starting udev Coldplug all Devices... Starting Apply Kernel Variables... Starting Flush Journal to Persistent Storage... [ 10.634319] systemd-journald[152]: Received request to flush runtime journal from PID 1 [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Started Create Static Device Nodes in /dev. [ OK ] Started Apply Kernel Variables. Starting udev Kernel Device Manager... [ OK ] Reached target Local File Systems (Pre). Mounting /media/ram... Mounting /var/volatile... [ OK ] Mounted /var/volatile. [ OK ] Mounted /media/ram. [ OK ] Started udev Kernel Device Manager. [ OK ] Started udev Coldplug all Devices. [ 11.042650] CAN device driver interface [ 11.164306] m_can 42c01a00.mcan: hclk could not be found Starting Load/Save Random Seed... [ 11.174756] m_can 42c01a00.mcan: m_can device registered (irq=367, version=32) [ OK ] Reached target Local File Systems. [ 11.190210] tvp5158 4-0058: Unable to of_probe [ 11.201362] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000 [ 11.213295] remoteproc0: 58820000.ipu is available [ 11.222035] remoteproc0: Note: remoteproc is still under development and considered experimental. [ 11.241226] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [ 11.261461] tvp5158 4-0058: Unable to of_probe Starting Create Volatile Files and Directories... [ 11.274175] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000 [ 1.290362] remoteproc1: 55020000.ipu is available [ OK ] Started Load/Save Random Seed. [ 11.295801] remoteproc1: Note: remoteproc is still under development and considered experimental. [ 11.316358] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [ 11.328509] tvp5158 4-0058: Unable to of_probe [ OK ] Found device /dev/ttyS0. [ 11.335320] remoteproc0: registered virtio0 (type 7) [ 11.350050] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000 [ 11.360576] remoteproc2: 40800000.dsp is available [ 11.376786] remoteproc2: Note: remoteproc is still under development and considered experimental. [ 11.401574] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [ 11.414347] tvp5158 4-0058: Unable to of_probe [ 11.420880] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20 [ 11.431541] tvp5158 4-0058: Unable to of_probe [ 11.436225] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000 [ 11.450285] remoteproc3: 41000000.dsp is available [ OK ] Started Create Volatile Files and Directories.[ 11.465852] remoteproc3: Note: remoteproc is still under development and considered experimental. [ 11.485801] remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [ 11.502218] remoteproc3: Direct firmware load for dra7-dsp2-fw.xe66 failed with error -2 [ 11.510761] tvp5158 4-0058: Unable to of_probe [ 11.533580] remoteproc3: failed to load dra7-dsp2-fw.xe66 Starting Network Time Synchronization... Starting Update UTMP about System Boot/Shutdown... [ 12.037080] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3 [ 12.044275] tvp5158 4-0058: Unable to of_probe [ 12.063626] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported) [ 12.074466] tvp5158 4-0058: Unable to of_probe [ 12.179976] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2 [ 12.194543] tvp5158 4-0058: Unable to of_probe [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Time Synchronized. Starting Synchronize System and HW clocks... [ 12.750008] remoteproc2: registered virtio1 (type 7) [FAILED] Failed to start Synchronize System and HW clocks. See 'systemctl status sync-clocks.service' for details. [ 12.949103] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3 [ 12.959916] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3 [ 12.959931] tvp5158 4-0058: Unable to of_probe [ 12.971415] tvp5158 4-0058: Unable to of_probe [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Reached target System Initialization. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target Timers. [ 13.230610] SCSI subsystem initialized [ 13.327295] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 13.334398] tvp5158 4-0058: Unable to of_probe [ OK ] Listening on dropbear.socket. [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Reached target Sockets. [ OK ] Reached target Basic System. [ 13.908648] tvp5158 4-0058: Unable to of_probe Starting Login Service... [ OK ] Started Kernel Logging Service. [ OK ] Started D-Bus System Message Bus. [ 14.091062] pvrsrvkm: disagrees about version of symbol module_layout [ 14.116361] remoteproc1: registered virtio2 (type 7) [ 14.137178] pvrsrvkm: disagrees about version of symbol module_layout [ 14.324733] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled [ 14.331470] ahci 4a140000.sata: Enable 32-bit DMA instead of 64-bit. [ 14.343412] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode [ 14.361601] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst [ 14.397150] scsi host0: ahci [ 14.400274] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 343 [ 14.429618] tvp5158 4-0058: Unable to of_probe [ 14.471904] tvp5158 4-0058: Unable to of_probe [ 14.478116] tvp5158 4-0058: Unable to of_probe [ 14.728039] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 14.773994] ata1: SATA link down (SStatus 0 SControl 300) [ 14.866598] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. Starting Network Service... Starting Telephony service... Starting Print notice about GPLv3 packages... Starting uim-sysfs.service... [ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf. [ OK ] Started System Logging Service. Starting TI MultiCore Tools Daemon... Starting Avahi mDNS/DNS-SD Stack... [ 15.021848] net eth1: initializing cpsw version 1.15 (0) Starting Permit User Sessions... [ OK ] Started Network Service. [ OK ] Started Permit User Sessions. [ 15.224492] net eth1: phy found : id is : 0x2000a231 [ 15.248791] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready [FAILED] Failed to start TI MultiCore Tools Daemon. See 'systemctl status ti-mct-daemon.service' for details. [ 15.755737] remoteproc0: powering up 58820000.ipu [ 15.761062] remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 471504 [ 15.802672] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1 [ 15.868591] remoteproc0: remote processor 58820000.ipu is now up [ 15.881817] virtio_rpmsg_bus virtio0: rpmsg host is online [ 15.889062] tvp5158 4-0058: Unable to of_probe [ 15.895536] remoteproc2: powering up 40800000.dsp [ 15.906500] remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 5578463 [ 15.919959] omap_hwmod: mmu0_dsp1: _wait_target_disable failed [ 15.925836] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0 [ 15.931771] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0 [ 15.958111] remoteproc2: remote processor 40800000.dsp is now up [ 15.964994] virtio_rpmsg_bus virtio1: rpmsg host is online [ 15.971011] tvp5158 4-0058: Unable to of_probe [ 15.979241] remoteproc1: powering up 55020000.ipu [ 16.205819] Bluetooth: Core ver 2.21 [ 16.209772] NET: Registered protocol family 31 [ 16.215101] Bluetooth: HCI device and connection manager initialized [ 16.222062] Bluetooth: HCI socket layer initialized [ 16.228257] Bluetooth: L2CAP socket layer initialized [ 16.233391] Bluetooth: SCO socket layer initialized [ 16.287373] NET: Registered protocol family 15 [ 16.328246] remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 9634012 [ 16.336121] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1 [ 16.363370] remoteproc1: remote processor 55020000.ipu is now up [ 16.370594] virtio_rpmsg_bus virtio2: rpmsg host is online [ 16.378241] tvp5158 4-0058: Unable to of_probe [ OK ] Started uim-sysfs.service. [ 16.611450] Unable to handle kernel paging request at virtual address 40000000 [ 16.618724] pgd = edd01e40 [ 16.621452] [40000000] *pgd=00000000 [ 16.625072] Internal error: Oops: 2a05 [#1] PREEMPT SMP ARM [ 16.630663] Modules linked in: xfrm_ipcomp esp4 ah4 dwc3(+) udc_core af_key bluetooth xfrm_algo virtio_rpmsg_bus extcon_usb_gpio ahci_platform libahci_platform libahci libata dwc3_omap omap_wdt scsi_mod omap_aes_driver extcon omap_des omap_dma omap_sham omap_rng rng_core omap_remoteproc m_can remoteproc can_dev virtio virtio_ring sch_fq_codel [ 16.661306] CPU: 0 PID: 214 Comm: systemd-udevd Not tainted 4.4.84-00105-gc66ba60-dirty #118 [ 16.669776] Hardware name: Generic DRA74X (Flattened Device Tree) [ 16.675891] task: edd59400 ti: ed900000 task.ti: ed900000 [ 16.681311] PC is at v7_dma_inv_range+0x30/0x48 [ 16.685859] LR is at dma_cache_maint_page+0x8c/0x128 [ 16.690841] pc : [<c001e570>] lr : [<c0019958>] psr: 60010113 [ 16.690841] sp : ed901970 ip : ed901970 fp : ed9019a4 [ 16.702361] r10: 00000002 r9 : c0991880 r8 : c0919584 [ 16.707602] r7 : c0916480 r6 : 00000000 r5 : 00000000 r4 : 00000000 [ 16.714152] r3 : 0000003f r2 : 00000040 r1 : 40000000 r0 : 40000000 [ 16.720702] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user [ 16.727863] Control: 30c5387d Table: add01e40 DAC: fffffffd [ 16.733628] Process systemd-udevd (pid: 214, stack limit = 0xed900210) [ 16.740178] Stack: (0xed901970 to 0xed902000) [ 16.744547] 1960: c02a71cc c0016e60 ffff914d ea5a2000 [ 16.752754] 1980: 00000002 ee302910 00000000 00000000 00000000 c001aa70 ed9019d4 ed9019a8 [ 16.760961] 19a0: c0019c18 c00198d8 c001e600 00000161 eea6c9c0 eb7a2000 ee285a90 ee302910 [ 16.769168] 19c0: 00000000 00000000 ed9019ec ed9019d8 c001aad0 c0019b8c fa486420 ee285a90 [ 16.777374] 19e0: ed901a24 ed9019f0 c0443518 c001aa7c 00000000 ee808000 c0933238 ee285a90 [ 16.785582] 1a00: 00000000 fa486420 ee285ab0 ee302910 00000000 48486420 ed901a5c ed901a28 [ 16.793788] 1a20: c04436a8 c04434ac 20010113 fa486000 ed901bc8 00000000 ee285a90 00000040 [ 16.801996] 1a40: 0000012c ffff914f c0916100 ed901ac0 ed901a7c ed901a60 c044370c c0443564 [ 16.810204] 1a60: ee2ec440 c044b5d4 00000040 0000012c ed901a9c ed901a80 c044b5f0 c04436d4 [ 16.818411] 1a80: ee2ec440 c044b5d4 00000040 0000012c ed901afc ed901aa0 c05611fc c044b5e0 [ 16.826618] 1aa0: c0872918 c0875dd0 c087258c c0917220 c096283f 2ae17000 c0912880 eb729880 [ 16.834826] 1ac0: ed901ac0 ed901ac0 ed901ac8 ed901ac8 ee808000 00000000 c091608c ed900000 [ 16.843033] 1ae0: 00000100 c0916080 00000003 40000003 ed901b5c ed901b00 c0037174 c056100c [ 16.851240] 1b00: eea6ca20 c09334e4 00000000 00400140 c0916100 ffff914e 0000000a c0670328 [ 16.859447] 1b20: c0966300 c0916080 ed901b00 c090f308 c007c24c ffffe000 00000161 00000000 [ 16.867653] 1b40: 00000000 ee808000 c0933238 ed867000 ed901b74 ed901b60 c0037580 c0037064 [ 16.875860] 1b60: c0910424 00000161 ed901b9c ed901b78 c0077b60 c00374d0 c09168d4 fa21200c [ 16.884067] 1b80: ed901bc8 fa212000 fa213000 c0933238 ed901bc4 ed901ba0 c000948c c0077b04 [ 16.892274] 1ba0: c04eb230 a0010113 ffffffff ed901bfc 00002500 c0933238 ed901c24 ed901bc8 [ 16.900481] 1bc0: c0013e00 c0009458 00000562 00000000 df54e710 c04eb224 c0997428 00001803 [ 16.908688] 1be0: 0930ac7c ed8d4810 00002500 c0933238 ed867000 ed901c24 ed901c28 ed901c18 [ 16.916895] 1c00: c0016e70 c04eb230 a0010113 ffffffff ed867000 ed901c54 ed901c34 ed901c28 [ 16.925103] 1c20: c0016e70 c04eb230 ed901c54 ed901c38 c02a7238 c0016e60 ee382810 0000005b [ 16.933310] 1c40: 066665b0 ed8d4810 ed901c64 ed901c58 c02a7270 c02a71f0 ed901cc4 ed901c68 [ 16.941517] 1c60: bf26df18 c02a7254 00000000 ed072320 edf74460 ed8d4810 c091abfc ed867000 [ 16.949724] 1c80: 024000c0 00000001 c017cc88 0c01ff9c 00000000 00000000 ed8d4818 c099f79c [ 16.957930] 1ca0: ed8d4810 bf278c44 fffffdfb 00000017 ed1d0a88 00000000 ed901ce4 ed901cc8 [ 16.966137] 1cc0: c03d94dc bf26cf30 c099f79c ed8d4810 00000000 bf278c44 ed901d0c ed901ce8 [ 16.974345] 1ce0: c03d7a64 c03d9494 ed8d4810 bf278c44 ed8d4844 00000000 12e2f59c ed1d0a88 [ 16.982552] 1d00: ed901d2c ed901d10 c03d7bec c03d786c 00000000 bf278c44 c03d7b58 00000000 [ 16.990760] 1d20: ed901d54 ed901d30 c03d5cec c03d7b64 ee85cf5c edff61b4 ee85cf70 bf278c44 [ 16.998966] 1d40: eda06e00 c0943d60 ed901d64 ed901d58 c03d7350 c03d5c88 ed901d8c ed901d68 [ 17.007173] 1d60: c03d6f8c c03d7338 bf276d08 ed901d78 bf278c44 bf27d000 c09196a0 ed1d0b80 [ 17.015379] 1d80: ed901da4 ed901d90 c03d838c c03d6df0 c0943d60 bf27d000 ed901dbc ed901da8 [ 17.023587] 1da0: c03d9404 c03d8318 c09196a0 bf27d000 ed901dcc ed901dc0 bf27d01c c03d93c8 [ 17.031795] 1dc0: ed901e4c ed901dd0 c000978c bf27d00c 00000000 00080000 00000001 ebdfc738 [ 17.040001] 1de0: ed2de0c0 c00fd320 ed900000 ee801e40 ed901e08 00022696 ed901e3c ed901e08 [ 17.048209] 1e00: c0108808 c0107cb0 00000001 c00fd320 12e2f59c 000000fb ed2de0c0 f9aa3000 [ 17.056417] 1e20: 00000001 bf278cc0 00000001 ed1d0b40 00000001 12e2f59c ed1d0a88 bf278cc0 [ 17.064625] 1e40: ed901e74 ed901e50 c00c65d0 c0009700 ed901e74 ed901e60 c00fd40c ed901f44 [ 17.072833] 1e60: 00000001 ed1d0a80 ed901f3c ed901e78 c00a3288 c00c6574 bf278ccc 00007fff [ 17.081040] 1e80: bf278cc0 c00a0484 ed8c3300 c0807448 c0807420 c0807414 c0807478 c06715ec [ 17.089248] 1ea0: 00000000 bf278ccc f9b9d4ec bf278e60 c09164b4 bf278e80 bf278d08 c009fdf4 [ 17.097455] 1ec0: f9aa3000 000fa53c 0015fc3e 00000000 0b300002 00000000 00000000 00000000 [ 17.105662] 1ee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 17.113869] 1f00: 00000000 00000000 00000000 00000000 000007d8 00000000 0000000e b6ddfd90 [ 17.122076] 1f20: 0000017b c000fbc4 ed900000 00000000 ed901fa4 ed901f40 c00a36c8 c00a149c [ 17.130283] 1f40: 00000002 f9aa3000 000fa53c f9b9cf24 f9b5f7a9 f9b61cf4 0000ce80 0000e8d0 [ 17.138490] 1f60: 00000000 00000000 00000000 00003964 00000025 00000026 0000000f 0000000b [ 17.146697] 1f80: 00000009 00000000 00000000 00000000 004ce928 00000000 00000000 ed901fa8 [ 17.154904] 1fa0: c000fa20 c00a364c 00000000 004ce928 0000000e b6ddfd90 00000000 004de4d8 [ 17.163111] 1fc0: 00000000 004ce928 00000000 0000017b 004e1e78 00000000 004e1e78 004d0548 [ 17.171318] 1fe0: bee919d8 bee919c8 b6dd8c08 b6edbdf2 600f0030 0000000e 00000000 00000000 [ 17.179523] Backtrace: [ 17.181984] [<c00198cc>] (dma_cache_maint_page) from [<c0019c18>] (__dma_page_dev_to_cpu+0x98/0x138) [ 17.191150] r10:c001aa70 r9:00000000 r8:00000000 r7:00000000 r6:ee302910 r5:00000002 [ 17.199038] r4:ea5a2000 [ 17.201584] [<c0019b80>] (__dma_page_dev_to_cpu) from [<c001aad0>] (arm_dma_unmap_page+0x60/0x64) [ 17.210487] r8:00000000 r7:00000000 r6:ee302910 r5:ee285a90 r4:eb7a2000 [ 17.217248] [<c001aa70>] (arm_dma_unmap_page) from [<c0443518>] (__cpdma_chan_free+0x78/0xb8) [ 17.225802] r5:ee285a90 r4:fa486420 [ 17.229402] [<c04434a0>] (__cpdma_chan_free) from [<c04436a8>] (__cpdma_chan_process+0x150/0x170) [ 17.238305] r10:48486420 r9:00000000 r8:ee302910 r7:ee285ab0 r6:fa486420 r5:00000000 [ 17.246192] r4:ee285a90 [ 17.248738] [<c0443558>] (__cpdma_chan_process) from [<c044370c>] (cpdma_chan_process+0x44/0x6c) [ 17.257554] r10:ed901ac0 r9:c0916100 r8:ffff914f r7:0000012c r6:00000040 r5:ee285a90 [ 17.265440] r4:00000000 [ 17.267986] [<c04436c8>] (cpdma_chan_process) from [<c044b5f0>] (cpsw_rx_poll+0x1c/0x7c) [ 17.276104] r7:0000012c r6:00000040 r5:c044b5d4 r4:ee2ec440 [ 17.281811] [<c044b5d4>] (cpsw_rx_poll) from [<c05611fc>] (net_rx_action+0x1fc/0x2ec) [ 17.289667] r7:0000012c r6:00000040 r5:c044b5d4 r4:ee2ec440 [ 17.295372] [<c0561000>] (net_rx_action) from [<c0037174>] (__do_softirq+0x11c/0x234) [ 17.303228] r10:40000003 r9:00000003 r8:c0916080 r7:00000100 r6:ed900000 r5:c091608c [ 17.311117] r4:00000000 [ 17.313661] [<c0037058>] (__do_softirq) from [<c0037580>] (irq_exit+0xbc/0x11c) [ 17.320994] r10:ed867000 r9:c0933238 r8:ee808000 r7:00000000 r6:00000000 r5:00000161 [ 17.328881] r4:ffffe000 [ 17.331430] [<c00374c4>] (irq_exit) from [<c0077b60>] (__handle_domain_irq+0x68/0xbc) [ 17.339287] r5:00000161 r4:c0910424 [ 17.342885] [<c0077af8>] (__handle_domain_irq) from [<c000948c>] (gic_handle_irq+0x40/0x7c) [ 17.351264] r9:c0933238 r8:fa213000 r7:fa212000 r6:ed901bc8 r5:fa21200c r4:c09168d4 [ 17.359070] [<c000944c>] (gic_handle_irq) from [<c0013e00>] (__irq_svc+0x40/0x74) [ 17.366579] Exception stack(0xed901bc8 to 0xed901c10) [ 17.371645] 1bc0: 00000562 00000000 df54e710 c04eb224 c0997428 00001803 [ 17.379854] 1be0: 0930ac7c ed8d4810 00002500 c0933238 ed867000 ed901c24 ed901c28 ed901c18 [ 17.388059] 1c00: c0016e70 c04eb230 a0010113 ffffffff [ 17.393124] r9:c0933238 r8:00002500 r7:ed901bfc r6:ffffffff r5:a0010113 r4:c04eb230 [ 17.400929] [<c04eb224>] (arch_counter_get_cntpct) from [<c0016e70>] (arch_timer_read_counter_long+0x1c/0x20) [ 17.410887] [<c0016e54>] (arch_timer_read_counter_long) from [<c02a7238>] (__timer_delay+0x54/0x64) [ 17.419969] [<c02a71e4>] (__timer_delay) from [<c02a7270>] (__timer_const_udelay+0x28/0x2c) [ 17.428348] r7:ed8d4810 r6:066665b0 r5:0000005b r4:ee382810 [ 17.434067] [<c02a7248>] (__timer_const_udelay) from [<bf26df18>] (dwc3_probe+0xff4/0x1944 [dwc3]) [ 17.443069] [<bf26cf24>] (dwc3_probe [dwc3]) from [<c03d94dc>] (platform_drv_probe+0x54/0xb8) [ 17.451623] r10:00000000 r9:ed1d0a88 r8:00000017 r7:fffffdfb r6:bf278c44 r5:ed8d4810 [ 17.459510] r4:c099f79c [ 17.462057] [<c03d9488>] (platform_drv_probe) from [<c03d7a64>] (driver_probe_device+0x204/0x2f8) [ 17.470959] r7:bf278c44 r6:00000000 r5:ed8d4810 r4:c099f79c [ 17.476662] [<c03d7860>] (driver_probe_device) from [<c03d7bec>] (__driver_attach+0x94/0x98) [ 17.485131] r9:ed1d0a88 r8:12e2f59c r7:00000000 r6:ed8d4844 r5:bf278c44 r4:ed8d4810 [ 17.492934] [<c03d7b58>] (__driver_attach) from [<c03d5cec>] (bus_for_each_dev+0x70/0xa4) [ 17.501140] r7:00000000 r6:c03d7b58 r5:bf278c44 r4:00000000 [ 17.506846] [<c03d5c7c>] (bus_for_each_dev) from [<c03d7350>] (driver_attach+0x24/0x28) [ 17.514878] r6:c0943d60 r5:eda06e00 r4:bf278c44 [ 17.519527] [<c03d732c>] (driver_attach) from [<c03d6f8c>] (bus_add_driver+0x1a8/0x220) [ 17.527562] [<c03d6de4>] (bus_add_driver) from [<c03d838c>] (driver_register+0x80/0x100) [ 17.535679] r7:ed1d0b80 r6:c09196a0 r5:bf27d000 r4:bf278c44 [ 17.541384] [<c03d830c>] (driver_register) from [<c03d9404>] (__platform_driver_register+0x48/0x50) [ 17.550461] r5:bf27d000 r4:c0943d60 [ 17.554068] [<c03d93bc>] (__platform_driver_register) from [<bf27d01c>] (dwc3_driver_init+0x1c/0x24 [dwc3]) [ 17.563845] r5:bf27d000 r4:c09196a0 [ 17.567449] [<bf27d000>] (dwc3_driver_init [dwc3]) from [<c000978c>] (do_one_initcall+0x98/0x1e4) [ 17.576359] [<c00096f4>] (do_one_initcall) from [<c00c65d0>] (do_init_module+0x68/0x378) [ 17.584477] r10:bf278cc0 r9:ed1d0a88 r8:12e2f59c r7:00000001 r6:ed1d0b40 r5:00000001 [ 17.592363] r4:bf278cc0 [ 17.594911] [<c00c6568>] (do_init_module) from [<c00a3288>] (load_module+0x1df8/0x2068) [ 17.602942] r6:ed1d0a80 r5:00000001 r4:ed901f44 [ 17.607593] [<c00a1490>] (load_module) from [<c00a36c8>] (SyS_finit_module+0x88/0x98) [ 17.615449] r10:00000000 r9:ed900000 r8:c000fbc4 r7:0000017b r6:b6ddfd90 r5:0000000e [ 17.623334] r4:00000000 [ 17.625882] [<c00a3640>] (SyS_finit_module) from [<c000fa20>] (ret_fast_syscall+0x0/0x34) [ 17.634087] r6:00000000 r5:004ce928 r4:00000000 [ 17.638736] Code: 1e070f3e e1110003 e1c11003 1e071f3e (ee070f36) [ 17.644883] ---[ end trace fb27af56855d4122 ]--- [ 17.649526] Kernel panic - not syncing: Fatal exception in interrupt [ 17.655905] CPU1: stopping [ 17.658625] CPU: 1 PID: 761 Comm: kworker/1:3 Tainted: G D 4.4.84-00105-gc66ba60-dirty #118 [ 17.668140] Hardware name: Generic DRA74X (Flattened Device Tree) [ 17.674264] Workqueue: events_power_efficient phy_state_machine [ 17.680210] Backtrace: [ 17.682671] [<c0013110>] (dump_backtrace) from [<c001330c>] (show_stack+0x18/0x1c) [ 17.690266] r7:edb9bdf0 r6:20010193 r5:00000000 r4:c0933250 [ 17.695972] [<c00132f4>] (show_stack) from [<c02a9468>] (dump_stack+0x8c/0xa0) [ 17.703222] [<c02a93dc>] (dump_stack) from [<c0016460>] (handle_IPI+0x184/0x198) [ 17.710643] r7:edb9bdf0 r6:00000000 r5:00000001 r4:c0910424 [ 17.716347] [<c00162dc>] (handle_IPI) from [<c00094c4>] (gic_handle_irq+0x78/0x7c) [ 17.723942] r7:fa212000 r6:edb9bdf0 r5:fa21200c r4:c09168d4 [ 17.729645] [<c000944c>] (gic_handle_irq) from [<c0013e00>] (__irq_svc+0x40/0x74) [ 17.737154] Exception stack(0xedb9bdf0 to 0xedb9be38) [ 17.742223] bde0: fa485000 ffff91bf fa485080 80220000 [ 17.750431] be00: c0916100 80220000 ee2cae90 c084f034 00000001 00000000 eb7339c0 edb9be64 [ 17.758637] be20: edb9be20 edb9be40 c03e16a8 c04422cc a0010113 ffffffff [ 17.765273] r9:00000000 r8:00000001 r7:edb9be24 r6:ffffffff r5:a0010113 r4:c04422cc [ 17.773078] [<c04421ec>] (davinci_mdio_read) from [<c0439258>] (mdiobus_read+0x5c/0x74) [ 17.781111] r9:00000000 r8:eb737500 r7:00000001 r6:00000002 r5:ee2e882c r4:ee2e8800 [ 17.788911] [<c04391fc>] (mdiobus_read) from [<c0438358>] (genphy_update_link+0x20/0x58) [ 17.797030] r7:00000000 r6:00000001 r5:ee2e8c00 r4:ee2e8c00 [ 17.802728] [<c0438338>] (genphy_update_link) from [<c04383a4>] (genphy_read_status+0x14/0x1e8) [ 17.811457] r5:ee2e8c00 r4:ee2e8e14 [ 17.815056] [<c0438390>] (genphy_read_status) from [<c04372fc>] (phy_state_machine+0x428/0x468) [ 17.823784] r7:00000000 r6:00000001 r5:ee2e8e4c r4:ee2e8e14 [ 17.829490] [<c0436ed4>] (phy_state_machine) from [<c00489ec>] (process_one_work+0x124/0x3f4) [ 17.838044] r7:00000000 r6:eb7339c0 r5:ed0a0180 r4:ee2e8e14 [ 17.843744] [<c00488c8>] (process_one_work) from [<c0048d08>] (worker_thread+0x4c/0x524) [ 17.851863] r10:eb7339c0 r9:ed0a0180 r8:00000008 r7:edb9a000 r6:eb7339d4 r5:ed0a0198 [ 17.859750] r4:eb7339c0 [ 17.862296] [<c0048cbc>] (worker_thread) from [<c004e83c>] (kthread+0x100/0x118) [ 17.869716] r10:00000000 r9:00000000 r8:c0048cbc r7:ed0a0180 r6:edb9a000 r5:edb3f580 [ 17.877604] r4:00000000 [ 17.880151] [<c004e73c>] (kthread) from [<c000fac8>] (ret_from_fork+0x14/0x2c) [ 17.887397] r8:00000000 r7:00000000 r6:00000000 r5:c004e73c r4:edb3f580 [ 17.894153] ---[ end Kernel panic - not syncing: Fatal exception in interrupt
