Other Parts Discussed in Thread: DRA71, PMP
Tool/software: Linux
Hi.
I'm testing TDA2EX17 EVM Board.
After compile VISION_SDK through user guide, I cound see the console output.
But, my board's ethernet is not working. In u-boot, network ping also failed.
I didn't change anything from vision_sdk sw. VISION SDK version is 03_03 and compiled with MAKECONFIG=tda2ex_17x17_evm_linux_all.
What's the problem?
Thanks in advance.
Here's my boot log.
U-Boot 2016.05-00009-gac1d50f-dirty (Sep 04 2018 - 16:24:30 +0900)
CPU : DRA722-GP ES2.1
Model: TI DRA71 EVM
Board: DRA71x EVM REV A.4
DRAM: 2 GiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
** First descriptor is NOT a primary desc on 1:1 **
GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
part_get_info_efi: *** ERROR: Invalid GPT ***
part_get_info_efi: *** ERROR: Invalid Backup GPT ***
ERROR: cannot find partition: 'userdata'
at arch/arm/cpu/armv7/omap-common/utils.c:199/mmc_get_part_size()
Warning: fastboot.userdata_size: unable to calc
SCSI: SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net: Could not get PHY for ethernet@48484000: addr 2
eth0: ethernet@48484000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
166 bytes read in 2 ms (81.1 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc0 ...
3553832 bytes read in 111 ms (30.5 MiB/s)
101306 bytes read in 22 ms (4.4 MiB/s)
Booting from mmc0 ...
Kernel image @ 0x82000000 [ 0x000000 - 0x363a28 ]
Loading Device Tree to 8ffe4000, end 8ffffbb9 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.84-00018-gc66ba60 (root@nexreal.com) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 SMP PREEMPT Mon Jul 9 15:45:16 KST 2018
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine model: TI DRA718 EVM
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000040300000, size 3 MiB
[ 0.000000] Reserved memory: initialized node cmem@40300000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: regions without no-map are not yet supported
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 80 MiB
[ 0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009e000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a1000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 64 MiB
[ 0.000000] Reserved memory: initialized node cmem@A9000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x00000000be400000
[ 0.000000] Forcing write-allocate cache policy for SMP
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] OMAP4: Map 0x00000000bfd00000 to fe600000 for dram barrier
[ 0.000000] DRA722 ES2.1
[ 0.000000] PERCPU: Embedded 11 pages/cpu @ef649000 s14912 r8192 d21952 u45056
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 243264
[ 0.000000] Kernel command line: console=ttyO0,115200n8 vram=16M root=PARTUUID=b9441ee0-02 rw rootwait ip=none mem=1024M
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 509268K/979968K available (6623K kernel code, 319K rwdata, 2388K rodata, 336K init, 290K bss, 298668K reserved, 172032K cma-reserved, 234496K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc08d502c (9013 kB)
[ 0.000000] .init : 0xc08d6000 - 0xc092a000 ( 336 kB)
[ 0.000000] .data : 0xc092a000 - 0xc0979f60 ( 320 kB)
[ 0.000000] .bss : 0xc097b000 - 0xc09c3800 ( 290 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] Architected cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000015] Switching to timer-based delay loop, resolution 162ns
[ 0.000321] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000328] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000753] Console: colour dummy device 80x30
[ 0.000769] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000775] This ensures that you still see kernel messages. Please
[ 0.000780] update your kernel commandline.
[ 0.000793] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000805] pid_max: default: 32768 minimum: 301
[ 0.000906] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000916] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001450] Initializing cgroup subsys io
[ 0.001466] Initializing cgroup subsys memory
[ 0.001492] Initializing cgroup subsys devices
[ 0.001504] Initializing cgroup subsys freezer
[ 0.001516] Initializing cgroup subsys perf_event
[ 0.001527] Initializing cgroup subsys pids
[ 0.001554] CPU: Testing write buffer coherency: ok
[ 0.001757] /cpus/cpu@0 missing clock-frequency property
[ 0.001769] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001802] Setting up static identity map for 0x80008380 - 0x800083e0
[ 0.050022] Brought up 1 CPUs
[ 0.050032] SMP: Total of 1 processors activated (12.29 BogoMIPS).
[ 0.050039] CPU: All CPU(s) started in HYP mode.
[ 0.050045] CPU: Virtualization extensions available.
[ 0.050357] devtmpfs: initialized
[ 0.080058] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.081056] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.261818] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.261842] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.273666] pinctrl core: initialized pinctrl subsystem
[ 0.274565] NET: Registered protocol family 16
[ 0.275557] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.300179] cpuidle: using governor ladder
[ 0.330204] cpuidle: using governor menu
[ 0.338929] OMAP GPIO hardware version 0.1
[ 0.345400] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[ 0.367138] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.367149] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.367645] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.367654] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.368244] OMAP DMA hardware revision 0.0
[ 0.451019] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.452178] edma 43300000.edma: memcpy is disabled
[ 0.456989] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.461641] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.461821] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.461988] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.462153] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.481362] pcf857x 0-0020: probed
[ 0.481960] pcf857x 0-0021: probed
[ 0.482335] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.482778] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.482950] media: Linux media interface: v0.10
[ 0.483002] Linux video capture interface: v2.00
[ 0.483043] pps_core: LinuxPPS API ver. 1 registered
[ 0.483050] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.483079] PTP clock support registered
[ 0.483129] EDAC MC: Ver: 3.0.0
[ 0.491463] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.491660] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.491985] Advanced Linux Sound Architecture Driver Initialized.
[ 0.492830] clocksource: Switched to clocksource arch_sys_counter
[ 0.502920] NET: Registered protocol family 2
[ 0.503414] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.503478] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.503602] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.503653] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.503685] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.503896] NET: Registered protocol family 1
[ 0.514188] RPC: Registered named UNIX socket transport module.
[ 0.514197] RPC: Registered udp transport module.
[ 0.514203] RPC: Registered tcp transport module.
[ 0.514209] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.515187] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.535180] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.545853] NFS: Registering the id_resolver key type
[ 0.545886] Key type id_resolver registered
[ 0.545894] Key type id_legacy registered
[ 0.545948] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.547482] bounce: pool size: 64 pages
[ 0.547636] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.547652] io scheduler noop registered
[ 0.547663] io scheduler deadline registered
[ 0.547697] io scheduler cfq registered (default)
[ 0.551722] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 0.551840] pinctrl-single 4a002e8c.pinmux: 1 pins at pa fc002e8c size 4
[ 0.555012] PCI host bridge /ocp/axi@0/pcie_rc@51000000 ranges:
[ 0.555026] No bus range found for /ocp/axi@0/pcie_rc@51000000, using [bus 00-ff]
[ 0.555059] IO 0x20003000..0x20012fff -> 0x00000000
[ 0.555080] MEM 0x20013000..0x2fffffff -> 0x20013000
[ 0.584509] dra7-pcie 51000000.pcie_rc: link is not up
[ 0.584681] dra7-pcie 51000000.pcie_rc: PCI host bridge to bus 0000:00
[ 0.584694] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.584704] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.584714] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 0.585115] PCI: bus0: Fast back to back transfers disabled
[ 0.585231] PCI: bus1: Fast back to back transfers enabled
[ 0.585320] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[ 0.585336] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[ 0.585348] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.585568] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 0.641654] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.645052] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250
[ 1.605480] console [ttyS0] enabled
[ 1.609879] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 302, base_baud = 3000000) is a 8250
[ 1.619865] [drm] Initialized drm 1.1.0 20060810
[ 1.625511] omapdss_dss 58000000.dss: master bind failed: -517
[ 1.719052] loop: module loaded
[ 1.729566] vmemexp device MAJOR num = 246
[ 1.733724] vmemexp class registered
[ 1.737436] /dev/vmemexp device registered
[ 1.741549] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
[ 1.749255] m25p80 spi32766.0: s25fl256s1 (32768 Kbytes)
[ 1.754693] 7 ofpart partitions found on MTD device spi32766.0
[ 1.760550] Creating 7 MTD partitions on "spi32766.0":
[ 1.765726] 0x000000000000-0x000000040000 : "QSPI.SPL"
[ 1.781820] 0x000000040000-0x000000140000 : "QSPI.u-boot"
[ 1.798182] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
[ 1.815126] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
[ 1.831798] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
[ 1.849202] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
[ 1.865554] 0x0000009e0000-0x000002000000 : "QSPI.file-system"
[ 1.883339] libphy: Fixed MDIO Bus: probed
[ 1.889282] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 1.896489] mousedev: PS/2 mouse device common for all mice
[ 1.912742] i2c /dev entries driver
[ 1.921445] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 1.927078] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 1.933511] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 1.940073] vsys_3v3: supplied by evm_12v0
[ 1.944273] evm_3v3: supplied by vsys_3v3
[ 1.983306] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr25 mode
[ 1.990748] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr12 mode
[ 1.999181] omap_hsmmc 480d1000.mmc: no pinctrl state for hs mode
[ 2.036838] mmc0: MAN_BKOPS_EN bit is not set
[ 2.043586] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.052508] mmc0: new HS200 MMC card at address 0001
[ 2.058855] aic_dvdd: supplied by evm_3v3
[ 2.065932] NET: Registered protocol family 10
[ 2.071096] sit: IPv6 over IPv4 tunneling driver
[ 2.076490] NET: Registered protocol family 17
[ 2.081179] Key type dns_resolver registered
[ 2.085545] mmcblk0: mmc0:0001 MMC08G 7.25 GiB
[ 2.090333] omap_voltage_late_init: Voltage driver support not added
[ 2.097302] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.103673] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.109901] cpu0 supply vdd not found, using dummy regulator
[ 2.115630] mmcblk0boot0: mmc0:0001 MMC08G partition 1 8.00 MiB
[ 2.121953] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.128207] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.134594] cpu0 supply vdd not found, using dummy regulator
[ 2.140511] mmcblk0boot1: mmc0:0001 MMC08G partition 2 8.00 MiB
[ 2.148979] Power Management for TI OMAP4+ devices.
[ 2.157235] Registering SWP/SWPB emulation handler
[ 2.163750] dmm 4e000000.dmm: workaround for errata i878 in use
[ 2.172230] dmm 4e000000.dmm: initialized all PAT entries
[ 2.188927] evm_5v0: supplied by evm_12v0
[ 2.193054] lp8733-ldo1: supplied by evm_5v0
[ 2.198824] lp8732-ldo0: supplied by vsys_3v3
[ 2.203736] OMAP DSS rev 6.1
[ 2.207458] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 2.215806] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 2.222526] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 2.227556] evm_3v3_sd: supplied by evm_3v3
[ 2.264873] asoc-simple-card sound@0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
[ 2.295933] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.302579] [drm] No driver support for vblank timestamp query.
[ 2.321173] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[ 2.327747] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 2.334547] hctosys: unable to open rtc device (rtc0)
[ 2.355190] aic_dvdd: disabling
[ 2.358353] vmmcwl_fixed: disabling
[ 2.362035] lp8733-ldo0: disabling
[ 2.365987] ALSA device list:
[ 2.368967] #0: DRA7xx-EVM
[ 2.372808] Waiting for root device PARTUUID=b9441ee0-02...
[ 2.542114] mmc2: host does not support reading read-only switch, assuming write-enable
[ 2.556008] mmc2: new ultra high speed DDR50 SDHC card at address e624
[ 2.573064] mmcblk1: mmc2:e624 SB16G 14.8 GiB
[ 2.582590] mmcblk1: p1 p2
[ 2.586529] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 2.596423] EXT4-fs (mmcblk1p2): couldn't mount as ext3 due to feature incompatibilities
[ 2.607843] EXT4-fs (mmcblk1p2): couldn't mount as ext2 due to feature incompatibilities
[ 2.641284] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.649750] VFS: Mounted root (ext4 filesystem) on device 179:50.
[ 2.660796] devtmpfs: mounted
[ 2.664086] Freeing unused kernel memory: 336K
[ 2.668547] This architecture does not have kernel memory protection.
[ 2.818977] systemd[1]: System time before build time, advancing clock.
[ 2.854584] random: systemd: uninitialized urandom read (16 bytes read, 11 bits of entropy available)
[ 2.870560] random: systemd: uninitialized urandom read (16 bytes read, 11 bits of entropy available)
[ 2.882272] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 2.900864] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.12!
[ 2.936848] systemd[1]: Set hostname to <dra7xx-evm>.
[ 2.986033] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 12 bits of entropy available)
[ 2.997557] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 12 bits of entropy available)
[ 3.011012] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 12 bits of entropy available)
[ 3.034802] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 13 bits of entropy available)
[ 3.047874] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 14 bits of entropy available)
[ 3.115437] random: systemd: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
[ 3.125145] random: systemd: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
[ 3.135294] random: systemd: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
[ 3.486561] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
[ 3.494466] systemd[1]: sysinit.target: Found dependency on alignment.service/start
[ 3.502165] systemd[1]: sysinit.target: Found dependency on basic.target/start
[ 3.509490] systemd[1]: sysinit.target: Found dependency on sockets.target/start
[ 3.516937] systemd[1]: sysinit.target: Found dependency on avahi-daemon.socket/start
[ 3.524821] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
[ 3.532254] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
[ 3.541708] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
[ SKIP ] Ordering cycle found, skipping alignment.service
[ 3.576006] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 3.603232] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 3.643710] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 3.673231] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 3.703344] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 3.733259] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 3.763063] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 3.783178] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 3.813146] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 3.844531] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 3.873852] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 3.903802] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 3.933222] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 3.965407] systemd[1]: Starting Journal Service...
[ 3.995770] systemd[1]: Mounting Debug File System...
[ 4.024481] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.075991] systemd[1]: Starting Create list of required static device nodes for the current kernel...
Starting Create list of required st... nodes for the current kernel...
[ 4.151501] systemd[1]: Starting Load Kernel Modules...
[ 4.189429] systemd[1]: Mounting Temporary Directory...
[ 4.225650] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.262558] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 4.271509] systemd[1]: Starting Setup Virtual Console...
[ 4.313417] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 4.343858] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 4.373108] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 4.393086] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 4.423746] systemd[1]: Mounted Debug File System.
[ OK ] Mounted Debug File System.
[ 4.453215] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 4.483136] systemd[1]: Mounted Temporary Directory.
[ OK ] Mounted Temporary Directory.
[ 4.513404] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Setup Virtual Console.
Starting udev Coldplug all Devices...
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
Starting Flush Journal to Persistent Storage...
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ 5.390925] systemd-journald[104]: Received request to flush runtime journal from PID 1
[ OK ] Started Flush Journal to Persistent Storage.
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
[ OK ] Mounted /media/ram.
[ OK ] Mounted /var/volatile.
[ OK ] Started udev Kernel Device Manager.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Volatile Files and Directories.
[ 6.345235] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
[ 6.449573] remoteproc0: 55020000.ipu is available
[ 6.467110] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 6.529395] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 6.645185] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 6.653057] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
[ OK ] Started udev Coldplug all Devices.
[ 6.753263] remoteproc1: 40800000.dsp is available
[ 6.812293] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 6.886121] remoteproc0: registered virtio0 (type 7)
[ 6.954079] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 7.042028] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 7.047983] cpsw 48484000.ethernet: gpio request failed, ret -517
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ 7.138071] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[ 7.145682] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 7.225570] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 7.261053] remoteproc1: registered virtio1 (type 7)
[ OK ] Found device /dev/ttyS0.
[ OK ] Started Network Time Synchronization.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ 8.092136] CAN device driver interface
[ 8.170420] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=348)
Starting Synchronize System and HW clocks...
[ OK ] Reached target System Time Synchronized.
[ 8.284050] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ 8.289964] cpsw 48484000.ethernet: gpio request failed, ret -517
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ 8.403353] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 8.409348] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 8.485118] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 8.491569] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 8.526851] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 8.583963] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 8.853538] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
[ 8.861116] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 8.959671] cpsw 48484000.ethernet: gpio request failed, ret -517
[ OK ] Reached target System Initialization.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Listening on dropbear.socket.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Avahi mDNS/DNS-SD Stack...
Starting Print notice about GPLv3 packages...
Starting Telephony service...
Starting TI MultiCore Tools Daemon...
[ OK ] Started Kernel Logging Service.
Starting Save/Restore Sound Card State...
[ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
Starting Permit User Sessions...
Starting uim-sysfs.service...
Starting Login Service...
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Started System Logging Service.
[ OK ] Started D-Bus System Message Bus.
[ 10.312097] NET: Registered protocol family 15
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Telephony service.
Starting Network Service...
[FAILED] Failed to start TI MultiCore Tools Daemon.
See 'systemctl status ti-mct-daemon.service' for details.
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Started Permit User Sessions.
[ 10.532202] Bluetooth: Core ver 2.21
[ 10.587940] NET: Registered protocol family 31
[ 10.592411] Bluetooth: HCI device and connection manager initialized
[ OK ] Started Network Service.
[ 10.704104] Bluetooth: HCI socket layer initialized
[ 10.751390] Bluetooth: L2CAP socket layer initialized
[ 10.808746] Bluetooth: SCO socket layer initialized
[ 11.018380] Initializing XFRM netlink socket
[ 11.206196] random: nonblocking pool is initialized
[ 12.100904] remoteproc0: powering up 55020000.ipu
[ 12.264074] remoteproc0: Booting fw image dra7-ipu2-fw.xem4, size 7356812
[ 12.271074] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ 12.562811] remoteproc0: remote processor 55020000.ipu is now up
[ 12.646099] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 12.652263] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 12.694587] remoteproc1: powering up 40800000.dsp
[ 12.882578] remoteproc1: Booting fw image dra7-dsp1-fw.xe66, size 6862836
[ 12.923768] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 12.929668] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 12.935647] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[ 13.198215] remoteproc1: remote processor 40800000.dsp is now up
[ 13.205454] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x50
[ 13.254308] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 13.260452] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 13.268902] virtio_rpmsg_bus virtio1: creating channel rpmsg-proto addr 0x50
[ 13.355307] NET: Registered protocol family 41
[ 13.360436] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 13.393103] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 13.461665] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 14.435727] cpsw 48484000.ethernet: gpio request failed, ret -517
NOTICE: This file system contains the following GPLv3 packages:
autoconf
binutils-dev
binutils
bison-dev
bison
cpp-symlinks
cpp
dosfstools
g++-symlinks
g++
gawk-dev
gawk
gcc-symlinks
gcc
gdb
gdbc6x
gdbserver
gstreamer1.0-libav
libcairo-perf-utils
libgmp10
libidn11
libmpc3
libmpfr4
m4-dev
m4
make
nettle
parted
swig-dev
swig
[ 14.581011] usbcore: registered new interface driver usbfs
f Iyou do not wish to distribute GPLv3 components please remove
he above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ 14.684042] usbcore: registered new interface driver hub
[ 14.706358] usbcore: registered new device driver usb
[ OK ] Started Print notice about GPLv3 packages.
[ 14.754023] dwc3 48890000.usb: otg: primary host xhci-hcd.4.auto registered
[ 14.761028] dwc3 48890000.usb: otg: shared host xhci-hcd.4.auto registered
[ 14.816531] dwc3 48890000.usb: otg: can't start till gadget registers
[ 14.841510] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 14.847828] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 14.875104] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 1
[ 14.905858] xhci-hcd xhci-hcd.5.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
[ 14.956304] xhci-hcd xhci-hcd.5.auto: irq 487, io mem 0x488d0000
[ 14.979777] hub 1-0:1.0: USB hub found
[ 15.005350] hub 1-0:1.0: 1 port detected
[ 15.015343] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 15.021775] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 15.053754] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 15.061977] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 2
[ 15.087616] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 15.134860] hub 2-0:1.0: USB hub found
[ 15.152893] hub 2-0:1.0: 1 port detected
[ 15.167574] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 15.204071] cpsw 48484000.ethernet: gpio request failed, ret -517
[ OK ] Started Login Service.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Reached target Sound Card.
[ OK ] Reached target Network.
Starting Lightning Fast Webserver With Light System Requirements...
Starting Network Name Resolution...
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started Lightning Fast Webserver With Light System Requirements.
[ OK ] Started Network Name Resolution.
[ OK ] Started uim-sysfs.service.
Starting rc.pvr.service...
[ 16.235734] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[ OK ] Started rc.pvr.service.
Starting weston.service...
[ OK ] Started weston.service.
Starting telnetd.service...
Starting tiipclad-daemon.service...
[ OK ] Started telnetd.service.
[ OK ] Started tiipclad-daemon.service.
Starting thttpd.service...
[ OK ] Started thttpd.service.
Starting rng-tools.service...
[ OK ] Started rng-tools.service.
Starting gdbserverproxy.service...
[ OK ] Started gdbserverproxy.service.
Starting matrix-gui-2.0.service...
[ OK ] Started matrix-gui-2.0.service.
Starting thermal-zone-init.service...
[ OK ] Started thermal-zone-init.service.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org dra7xx-evm ttyS0
Arago 2016.12 dra7xx-evm ttyS0
dra7xx-evm login:
