Part Number: TDA2EVM5777
Other Parts Discussed in Thread: SYSCONFIG, SYSBIOS
Tool/software: Linux
hi,
I get the following error when i try to build the linux sdk.
i have done make linux_all and make linux_install. Both worked fine.
i get the following error when i try to build the sdk with make -s -j depend
aaa@aaa-VirtualBox:~/PROCESSOR_SDK_VISION_03_04_00_00/vision_sdk/build$ make -s -j depend
mkdir: cannot create directory ‘/home/aaa/PROCESSOR_SDK_VISION_03_04_00_00/vision_sdk/links_fw/include/config’: File exists
mkdir: cannot create directory ‘/home/aaa/PROCESSOR_SDK_VISION_03_04_00_00/vision_sdk/links_fw/include/config/apps’: File exists
mkdir: cannot create directory ‘/home/aaa/PROCESSOR_SDK_VISION_03_04_00_00/vision_sdk/links_fw/include/config/apps/tda2xx_evm_linux_all’: File exists
# makeconfig: Config is [ tda2xx_evm_linux_all ]
# makeconfig: Output file is @ /home/aaa/PROCESSOR_SDK_VISION_03_04_00_00/vision_sdk/links_fw/include/config/apps/tda2xx_evm_linux_all/system_cfg.h
# makeconfig: Input file is @ /home/aaa/PROCESSOR_SDK_VISION_03_04_00_00/vision_sdk/build/configs/tda2xx_evm_linux_all/cfg.mk
# makeconfig: Generating header ...
# makeconfig: Generating alg plugin config ...
# makeconfig: Generating usecase config ...
# makeconfig: Generating footer ...
# makeconfig: Done !!!
# CPUs that are NOT required but included in config [ tda2xx_evm_linux_all ],
# CPUs that are required but not included in config [ tda2xx_evm_linux_all ],
# Edit /home/aaa/PROCESSOR_SDK_VISION_03_04_00_00/vision_sdk/build/configs/tda2xx_evm_linux_all/cfg.mk to include or exclude CPUs in an application
Nothing to be done for tda2xx ipu1_0 csl_init
Nothing to be done for tda2xx csl_intc
Nothing to be done for tda2xx pm_rtos
Nothing to be done for tda2xx ipu1_0 sbl_utils
/home/aaa/PROCESSOR_SDK_VISION_03_04_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/ti/drv/pm/src/pmhal/obj/tda2xx/m4/release/.deps/hw_pmhal_vmdata.P:16: *** missing separator. Stop.
makefile:137: recipe for target 'pm_hal' failed
make[3]: *** [pm_hal] Error 2
make[3]: *** Waiting for unfinished jobs....
/home/aaa/PROCESSOR_SDK_VISION_03_04_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/ti/drv/pm/src/pmhal/optimized/obj/tda2xx/m4/release/.deps/pmhal_vm.P:16: *** missing separator. Stop.
makefile:137: recipe for target 'pm_hal_optimized' failed
make[3]: *** [pm_hal_optimized] Error 2
/home/aaa/PROCESSOR_SDK_VISION_03_04_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/ti/drv/pm/src/pmlib/obj/tda2xx/m4/release/.deps/pmlib_sysconfig.P:31: *** missing separator. Stop.
makefile:137: recipe for target 'pm_lib' failed
make[3]: *** [pm_lib] Error 2
/home/aaa/PROCESSOR_SDK_VISION_03_04_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/ti/drv/pm/src/pmlib/optimized/obj/tda2xx/m4/release/.deps/pmlib_sysconfig.P:30: *** missing separator. Stop.
makefile:137: recipe for target 'pm_lib_optimized' failed
make[3]: *** [pm_lib_optimized] Error 2
/home/aaa/PROCESSOR_SDK_VISION_03_04_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/ti/diag/obj/tda2xx/m4/release/.deps/diagLib_utils.P:48: *** missing separator. Stop.
makefile:137: recipe for target 'diag' failed
make[3]: *** [diag] Error 2
# Compiling tda2xx:ipu1_0:release:csl_uart_console: ./src/uartConfig.c
/home/aaa/PROCESSOR_SDK_VISION_03_04_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/ti/boot/sbl_auto/sbl_lib/obj/tda2xx-evm/m4/release/.deps/sbl_lib_weak.P:102: *** missing separator. Stop.
makefile:137: recipe for target 'sbl_lib' failed
make[3]: *** [sbl_lib] Error 2
# Compiling tda2xx:ipu1_0:release:csl_utils_i2c: ./src/i2c.c
# Compiling tda2xx:ipu1_0:release:csl_utils_common: ./src/app_utils.c
# Compiling tda2xx:ipu1_0:release:csl: ./soc/common/csl_device_xbar.c
# Compiling tda2xx:ipu1_0:release:csl: ./soc/common/csl_device_common.c
# Compiling tda2xx:ipu1_0:release:csl: ./arch/m4/src/interrupt.c
# Compiling tda2xx:ipu1_0:release:csl: ./arch/m4/src/ipu_wugen.c
# Compiling tda2xx:ipu1_0:release:csl: ./arch/m4/src/ammu.c
# Compiling tda2xx:ipu1_0:release:csl: ./arch/m4/src/unicache.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/dcan/V0/priv/dcan.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/edma/V1/priv/edma.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/elm/V0/priv/elm.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/emif/V0/priv/emif.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/epwm/V0/priv/csl_epwm.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/gpio/V1/priv/gpio_v2.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/gpmc/V1/priv/gpmc.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/i2c/V2/priv/i2c.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/l3fw/V0/priv/l3fw.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/l4fw/V0/priv/l4fw.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/mailbox/V0/priv/mailbox.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/mcspi/V0/priv/mcspi.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l1.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/mmc/V0/priv/mmcsd.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l2.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/mcasp/V0/priv/mcasp.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/mmu/dsp/V0/priv/mmu.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/qspi/V1/priv/qspi.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/spinlock/V0/priv/spinlock.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/timer/V1/priv/timer.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/uart/V1/priv/uart.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/wd_timer/V0/priv/wd_timer.c
# Compiling tda2xx:ipu1_0:release:csl: src/ip/pcie/V1/priv/pcie.c
# Archiving tda2xx:ipu1_0:release:csl_uart_console into /home/aaa/PROCESSOR_SDK_VISION_03_04_00_00/ti_components/drivers/pdk_01_10_00_08/packages/ti/csl/example/utils/uart_console/lib/tda2xx/m4/release/csl_uart_console.aem4 ...
# Archiving tda2xx:ipu1_0:release:csl_utils_common into /home/aaa/PROCESSOR_SDK_VISION_03_04_00_00/ti_components/drivers/pdk_01_10_00_08/packages/ti/csl/example/utils/common/lib/tda2xx/m4/release/csl_utils_common.aem4 ...
# Archiving tda2xx:ipu1_0:release:csl_utils_i2c into /home/aaa/PROCESSOR_SDK_VISION_03_04_00_00/ti_components/drivers/pdk_01_10_00_08/packages/ti/csl/example/utils/i2c/lib/tda2xx/m4/release/csl_utils_i2c.aem4 ...
# Archiving tda2xx:ipu1_0:release:csl into /home/aaa/PROCESSOR_SDK_VISION_03_04_00_00/ti_components/drivers/pdk_01_10_00_08/packages/ti/csl/lib/tda2xx/m4/release/ti.csl.aem4 ...
build_pdk.mk:64: recipe for target 'pdk' failed
make[2]: *** [pdk] Error 2
Makefile:338: recipe for target 'pdk' failed
make[1]: *** [pdk] Error 2
Makefile:270: recipe for target 'depend' failed
make: *** [depend] Error 2
