I am tring to find out if the DM6467T can accept a progressive BT656 data stream at its video inputs (54Mhz pixel clk)
Does it mean that the output of the same channel has to be progressive also ?
Yes, it can support your input stream.
No, the output doesn't have to be progressive. The input and output ports are independent. However VPIF itself doesn't do any signal/data processing, so you might need to use DSP for what what you want to do.
